MeshKit
1.0
00001 00021 #include "meshkit/MKCore.hpp" 00022 #include "meshkit/MeshOp.hpp" 00023 #include "meshkit/MeshOpTemplate.hpp" 00024 #include "meshkit/TFIMapping.hpp" 00025 #include "meshkit/OneToOneSwept.hpp" 00026 00027 using namespace MeshKit; 00028 00029 MKCore *mk; 00030 bool save_mesh = true; 00031 00032 void test_mesh_op_template(); 00033 00034 int main(int argc, char **argv) 00035 { 00036 mk = new MKCore(); 00037 MEntVector all_curves, all_surfs, the_vol, tfi_surface; 00038 int source_surface = 0; // These are 00039 int target_surface = 1; // chosen by magic! 00040 00041 // Make the brick! 00042 MeshOpTemplate *mot = (MeshOpTemplate*) mk->construct_meshop("MeshOpTemplate", MEntVector()); 00043 mot->set_name("MeshOpTemplate"); 00044 mk->setup_and_execute(); 00045 mk->populate_model_ents(); 00046 mk->clear_graph(); 00047 00048 // Get entity data 00049 mk->get_entities_by_dimension(1, all_curves); 00050 mk->get_entities_by_dimension(2, all_surfs); 00051 mk->get_entities_by_dimension(3, the_vol); 00052 00053 // Size some things! 00054 ModelEnt *some_vol = (*the_vol.rbegin()); 00055 SizingFunction wsize(mk, 4, -1); 00056 some_vol->sizing_function_index(wsize.core_index()); 00057 00058 // Mesh Surface 00059 (tfi_surface = all_surfs).resize(1); 00060 TFIMapping *tfi = (TFIMapping*) mk->construct_meshop("TFIMapping", tfi_surface); 00061 tfi->set_name("TFI"); 00062 00063 // Sweep Surface to Surface 00064 OneToOneSwept *oto = (OneToOneSwept*) mk->construct_meshop("OneToOneSwept", the_vol); 00065 oto->set_name("OTO"); 00066 oto->SetSourceSurface(source_surface); 00067 oto->SetTargetSurface(target_surface); 00068 00069 // Do work! 00070 printf("Pre-Setup\n"); 00071 mk->setup(); 00072 printf("Pre-Execute\n"); 00073 mk->execute(); 00074 printf("Pre-Clear\n"); 00075 mk->clear_graph(); 00076 00077 // Some declarations for tags 00078 moab::Interface *mb = mk->moab_instance(); 00079 moab::Tag matTag, neuTag; 00080 moab::Range matEnts, neuEnts; 00081 moab::EntityHandle matEntSet, neuEntSet; 00082 int matVal = 2, neuVal = 4; // these values are arbitrary 00083 00084 // Tag the material set 00085 // Collect the entites into a set 00086 mb->create_meshset(moab::MESHSET_SET, matEntSet); 00087 mb->get_entities_by_dimension(mb->get_root_set(), 3, matEnts, true); 00088 mb->add_entities(matEntSet, matEnts); 00089 00090 // Grab a tag and attach it to the set 00091 mb->tag_get_handle("MATERIAL_SET", matTag); 00092 mb->tag_set_data(matTag, &matEntSet, 1, (void*) &matVal); 00093 00094 // The same thing for the Neumann set! 00095 mb->create_meshset(moab::MESHSET_SET, neuEntSet); 00096 mb->get_entities_by_dimension(mb->get_root_set(), 2, neuEnts, true); 00097 mb->add_entities(neuEntSet, neuEnts); 00098 00099 mb->tag_get_handle("NEUMANN_SET", neuTag); 00100 mb->tag_set_data(neuTag, &neuEntSet, 1, (void*) &neuVal); 00101 00102 // Possibly output (as files) our hard work! 00103 if(save_mesh) { 00104 #ifdef HAVE_ACIS 00105 mk->save_geometry("un_meshed_brick.sat"); 00106 mk->save_mesh("meshed_brick.exo"); 00107 #elif defined(HAVE_OCC) 00108 mk->save_geometry("un_meshed_brick.stp"); 00109 mk->save_mesh("meshed_brick.exo"); 00110 #endif 00111 } 00112 00113 return 0; 00114 }
