MeshKit
1.0
Functions | |
| void | moab_printer (moab::ErrorCode error_code) |
| moab::ErrorCode | delete_all_edges () |
| moab::ErrorCode | find_degenerate_tris () |
| moab::ErrorCode | prepare_curves (moab::Range &curve_sets, moab::Tag geom_tag, moab::Tag id_tag, moab::Tag merge_tag, const double FACET_TOL, const bool debug, bool verbose=true) |
| moab::ErrorCode | create_arc_pair (const double FACET_TOL, const moab::EntityHandle surf_set, std::vector< moab::EntityHandle > &skin_loop, std::vector< moab::EntityHandle > &curve_sets, const moab::EntityHandle front_endpt, const bool debug, moab::EntityHandle &curve_set, bool &curve_is_reversed, std::vector< moab::EntityHandle > &curve, std::vector< moab::EntityHandle > &skin_arc) |
| moab::ErrorCode | seal_arc_pair (const bool debug, const double FACET_TOL, const moab::Tag normal_tag, std::vector< moab::EntityHandle > &edge, std::vector< moab::EntityHandle > &skin, const int surf_id) |
| moab::ErrorCode | seal_loop (bool debug, const double FACET_TOL, const moab::Tag normal_tag, const moab::Tag orig_curve_tag, const moab::EntityHandle surf_set, std::vector< moab::EntityHandle > &curve_sets, std::vector< moab::EntityHandle > &skin_loop, bool verbose=false) |
| moab::ErrorCode | prepare_surfaces (moab::Range &surface_sets, moab::Tag geom_tag, moab::Tag id_tag, moab::Tag normal_tag, moab::Tag merge_tag, moab::Tag orig_curve_tag, const double SME_RESABS_TOL, const double FACET_TOL, const bool debug, bool verbose=true) |
| moab::ErrorCode | fix_normals (moab::Range surface_sets, moab::Tag id_tag, moab::Tag normal_tag, const bool debug, const bool verbose) |
| re-orients triangles with inverted normal vectors after being sealed | |
| moab::ErrorCode | restore_moab_curve_representation (const moab::Range curve_sets) |
| moab::ErrorCode | get_geom_size_before_sealing (const moab::Range geom_sets[], const moab::Tag geom_tag, const moab::Tag size_tag, bool debug, bool verbose) |
| prints the size of every entity in geom_sets | |
| moab::ErrorCode | get_geom_size_after_sealing (const moab::Range geom_sets[], const moab::Tag geom_tag, const moab::Tag size_tag, const double FACET_TOL, bool debug, bool verbose) |
| prints changes in size to the mesh after sealing | |
| moab::ErrorCode | delete_merged_curves (moab::Range &existing_curve_sets, moab::Tag merge_tag, bool debug=false) |
| deletes all curves with a merge_tag and removes them from the curve sets of the mesh | |
| moab::ErrorCode | delete_sealing_tags (moab::Tag normal_tag, moab::Tag merge_tag, moab::Tag size_tag, moab::Tag orig_curve_tag) |
| deletes all tags created for use in sealing the model | |
| moab::ErrorCode | get_unmerged_curves (moab::EntityHandle surface, std::vector< moab::EntityHandle > &curves, std::vector< moab::EntityHandle > &unmerged_curves, moab::Tag merge_tag, bool verbose, bool debug) |
| gets all curve sets an returns them in curves. Places any unmerged curves in unmerged_curves. | |
| moab::ErrorCode | create_skin_vert_loops (moab::Range &skin_edges, moab::Range tris, std::vector< std::vector< moab::EntityHandle > > &skin, int surf_id, bool &cont, bool debug) |
| moab::ErrorCode | merge_skin_verts (moab::Range &skin_verts, moab::Range &skin_edges, double SME_RESABS_TOL, int surf_id, bool cont, bool debug) |
| moab::ErrorCode | seal_surface_loops (moab::EntityHandle surf, moab::EntityHandle skin_loops[], std::vector< std::vector< moab::EntityHandle > > skin, std::vector< moab::EntityHandle > curves, moab::Tag normal_tag, moab::Tag orig_curve_tag, double FACET_TOL, int surf_id, bool debug) |
| runs the make_watertight algorithm on each set of skin_loops for the surface, surf. | |
| moab::ErrorCode | make_mesh_watertight (moab::EntityHandle input_set, double &facet_tol, bool verbose=true) |
| takes the mesh in input_set and makes it watertight | |
| ErrorCode | prepare_curves (Range &curve_sets, Tag geom_tag, Tag id_tag, Tag merge_tag, const double FACET_TOL, const bool debug, bool verbose) |
| ErrorCode | create_arc_pair (const double FACET_TOL, const EntityHandle surf_set, std::vector< EntityHandle > &skin_loop, std::vector< EntityHandle > &curve_sets, const EntityHandle front_endpt, const bool debug, EntityHandle &curve_set, bool &curve_is_reversed, std::vector< EntityHandle > &curve, std::vector< EntityHandle > &skin_arc) |
| ErrorCode | seal_arc_pair (const bool debug, const double FACET_TOL, const Tag normal_tag, std::vector< EntityHandle > &edge, std::vector< EntityHandle > &skin, const int surf_id) |
| ErrorCode | seal_loop (bool debug, const double FACET_TOL, const Tag normal_tag, const Tag orig_curve_tag, const EntityHandle surf_set, std::vector< EntityHandle > &curve_sets, std::vector< EntityHandle > &skin_loop, bool verbose) |
| seals the skin_loop to the closest curves in curve sets in a watertight fashion | |
| ErrorCode | prepare_surfaces (Range &surface_sets, Tag geom_tag, Tag id_tag, Tag normal_tag, Tag merge_tag, Tag orig_curve_tag, const double SME_RESABS_TOL, const double FACET_TOL, const bool debug, bool verbose) |
| ErrorCode | fix_normals (Range surface_sets, Tag id_tag, Tag normal_tag, const bool debug, const bool verbose) |
| ErrorCode | restore_moab_curve_representation (const Range curve_sets) |
| ErrorCode | get_geom_size_before_sealing (const Range geom_sets[], const Tag geom_tag, const Tag size_tag, bool debug, bool verbose) |
| ErrorCode | get_geom_size_after_sealing (const Range geom_sets[], const Tag geom_tag, const Tag size_tag, const double FACET_TOL, bool debug, bool verbose) |
| ErrorCode | delete_merged_curves (Range &existing_curve_sets, Tag merge_tag, bool debug) |
| ErrorCode | delete_sealing_tags (Tag normal_tag, Tag merge_tag, Tag size_tag, Tag orig_curve_tag) |
| ErrorCode | get_unmerged_curves (EntityHandle surface, std::vector< EntityHandle > &curves, std::vector< EntityHandle > &unmerged_curves, Tag merge_tag, bool verbose, bool debug) |
| ErrorCode | create_skin_vert_loops (Range &skin_edges, Range tris, std::vector< std::vector< EntityHandle > > &skin, int surf_id, bool &cont, bool debug) |
| ErrorCode | merge_skin_verts (Range &skin_verts, Range &skin_edges, double SME_RESABS_TOL, int surf_id, bool cont, bool debug) |
| ErrorCode | seal_surface_loops (EntityHandle surf, EntityHandle skin_loops[], std::vector< std::vector< EntityHandle > > skin, std::vector< EntityHandle > curves, Tag normal_tag, Tag orig_curve_tag, double FACET_TOL, int surf_id, bool debug) |
| ErrorCode | make_mesh_watertight (EntityHandle input_set, double &facet_tol, bool verbose) |
| moab::ErrorCode mw_func::create_arc_pair | ( | const double | FACET_TOL, |
| const moab::EntityHandle | surf_set, | ||
| std::vector< moab::EntityHandle > & | skin_loop, | ||
| std::vector< moab::EntityHandle > & | curve_sets, | ||
| const moab::EntityHandle | front_endpt, | ||
| const bool | debug, | ||
| moab::EntityHandle & | curve_set, | ||
| bool & | curve_is_reversed, | ||
| std::vector< moab::EntityHandle > & | curve, | ||
| std::vector< moab::EntityHandle > & | skin_arc | ||
| const EntityHandle | surf_set, | ||
| std::vector< EntityHandle > & | skin_loop, | ||
| std::vector< EntityHandle > & | curve_sets, | ||
| const EntityHandle | front_endpt, | ||
| std::vector< EntityHandle > & | curve, | ||
| std::vector< EntityHandle > & | skin_arc | ||
Cut an arc out of the skin. Return a corresponding curve, the curve's set, and is the curve has ben reversed. The returned skin has the arc cut away. The returned vector of curve sets has the curve removed.
Definition at line 207 of file mw_func.cpp.
| moab::ErrorCode mw_func::create_skin_vert_loops | ( | moab::Range & | skin_edges, |
| moab::Range | tris, | ||
| std::vector< std::vector< moab::EntityHandle > > & | skin, | ||
| int | surf_id, | ||
| bool & | cont, | ||
| bool | debug | ||
takes the skin_edges from the moab skinner and creates loops of vertices between the facets and geometric curves. The vertex loops are returned in the vector array, skin.
| ErrorCode mw_func::create_skin_vert_loops | ( | Range & | skin_edges, |
| Range | tris, | ||
| std::vector< std::vector< EntityHandle > > & | skin, | ||
| int | surf_id, | ||
| bool & | cont, | ||
| bool | debug | ||
Definition at line 1553 of file mw_func.cpp.
| ErrorCode delete_all_edges | ( | ) |
Definition at line 41 of file mw_func.cpp.
| moab::ErrorCode mw_func::delete_merged_curves | ( | moab::Range & | existing_curve_sets, |
| moab::Tag | merge_tag, | ||
| bool | debug = false |
| ErrorCode mw_func::delete_merged_curves | ( | Range & | existing_curve_sets, |
| bool | debug | ||
Definition at line 1442 of file mw_func.cpp.
| moab::ErrorCode mw_func::delete_sealing_tags | ( | moab::Tag | normal_tag, |
| moab::Tag | size_tag, | ||
| moab::Tag | orig_curve_tag | ||
| ErrorCode mw_func::delete_sealing_tags | ( | Tag | normal_tag, |
Definition at line 1482 of file mw_func.cpp.
| ErrorCode find_degenerate_tris | ( | ) |
gets all triangles from the mesh set and checks them for degeneracy. if any degenerate triangles are found, the program will exit
Definition at line 55 of file mw_func.cpp.
| moab::ErrorCode mw_func::fix_normals | ( | moab::Range | surface_sets, |
| moab::Tag | id_tag, | ||
| moab::Tag | normal_tag, | ||
| const bool | verbose | ||
| ErrorCode mw_func::fix_normals | ( | Range | surface_sets, |
| Tag | id_tag, | ||
Definition at line 1108 of file mw_func.cpp.
| moab::ErrorCode mw_func::get_geom_size_after_sealing | ( | const moab::Range | geom_sets[], |
| const moab::Tag | geom_tag, | ||
| const moab::Tag | size_tag, | ||
| const double | FACET_TOL, | ||
| bool | debug, | ||
| bool | verbose | ||
| ErrorCode mw_func::get_geom_size_after_sealing | ( | const Range | geom_sets[], |
| const Tag | geom_tag, | ||
| const Tag | size_tag, | ||
| bool | debug, | ||
| bool | verbose | ||
Definition at line 1308 of file mw_func.cpp.
| moab::ErrorCode mw_func::get_geom_size_before_sealing | ( | const moab::Range | geom_sets[], |
| bool | debug, | ||
| bool | verbose | ||
| ErrorCode mw_func::get_geom_size_before_sealing | ( | const Range | geom_sets[], |
| bool | debug, | ||
| bool | verbose | ||
Definition at line 1272 of file mw_func.cpp.
| moab::ErrorCode mw_func::get_unmerged_curves | ( | moab::EntityHandle | surface, |
| std::vector< moab::EntityHandle > & | curves, | ||
| std::vector< moab::EntityHandle > & | unmerged_curves, | ||
| bool | verbose, | ||
| bool | debug | ||
| ErrorCode mw_func::get_unmerged_curves | ( | EntityHandle | surface, |
| std::vector< EntityHandle > & | curves, | ||
| std::vector< EntityHandle > & | unmerged_curves, | ||
| bool | debug | ||
Definition at line 1498 of file mw_func.cpp.
| moab::ErrorCode mw_func::make_mesh_watertight | ( | moab::EntityHandle | input_set, |
| double & | facet_tol, | ||
| bool | verbose = true |
| ErrorCode mw_func::make_mesh_watertight | ( | EntityHandle | input_set, |
| bool | verbose | ||
Definition at line 1720 of file mw_func.cpp.
| moab::ErrorCode mw_func::merge_skin_verts | ( | moab::Range & | skin_verts, |
| moab::Range & | skin_edges, | ||
| double | SME_RESABS_TOL, | ||
| int | surf_id, | ||
| bool | cont, | ||
| bool | debug | ||
merges any skin vertices closer in proximity than the SME_RESABS_TOL. It then checks the skins for any degenerate edges resultant of vertex merging.
| ErrorCode mw_func::merge_skin_verts | ( | Range & | skin_verts, |
| int | surf_id, | ||
| bool | cont, | ||
| bool | debug | ||
Definition at line 1640 of file mw_func.cpp.
| void mw_func::moab_printer | ( | moab::ErrorCode | error_code | ) |
| moab::ErrorCode mw_func::prepare_curves | ( | moab::Range & | curve_sets, |
prepares all curves for the make_watertight algorithm. Merges curves that are coincident and deletes curves that are smallerthan the faceting tolerance
| ErrorCode mw_func::prepare_curves | ( | Range & | curve_sets, |
| Tag | id_tag, | ||
| bool | verbose | ||
Definition at line 81 of file mw_func.cpp.
| moab::ErrorCode mw_func::prepare_surfaces | ( | moab::Range & | surface_sets, |
| moab::Tag | orig_curve_tag, | ||
| const double | SME_RESABS_TOL, | ||
| ErrorCode mw_func::prepare_surfaces | ( | Range & | surface_sets, |
| Tag | id_tag, | ||
| bool | verbose | ||
Definition at line 970 of file mw_func.cpp.
| moab::ErrorCode mw_func::restore_moab_curve_representation | ( | const moab::Range | curve_sets | ) |
| ErrorCode mw_func::restore_moab_curve_representation | ( | const Range | curve_sets | ) |
Definition at line 1172 of file mw_func.cpp.
| moab::ErrorCode mw_func::seal_arc_pair | ( | const bool | debug, |
| const moab::Tag | normal_tag, | ||
| std::vector< moab::EntityHandle > & | edge, | ||
| std::vector< moab::EntityHandle > & | skin, | ||
| const int | surf_id | ||
| const Tag | normal_tag, | ||
| std::vector< EntityHandle > & | edge, | ||
| std::vector< EntityHandle > & | skin, | ||
Runs the make_watertight algorithm on the edge (curve) and skin (arc). See PHD Thesis of Brandon Smith University of Wisconsin - Madison 2011 for details
Definition at line 402 of file mw_func.cpp.
| moab::ErrorCode mw_func::seal_loop | ( | bool | debug, |
| const moab::Tag | orig_curve_tag, | ||
| bool | verbose = false |
| const Tag | orig_curve_tag, | ||
| bool | verbose | ||
Definition at line 723 of file mw_func.cpp.
| moab::ErrorCode mw_func::seal_surface_loops | ( | moab::EntityHandle | surf, |
| moab::EntityHandle | skin_loops[], | ||
| std::vector< std::vector< moab::EntityHandle > > | skin, | ||
| std::vector< moab::EntityHandle > | curves, | ||
| int | surf_id, | ||
| bool | debug | ||
| ErrorCode mw_func::seal_surface_loops | ( | EntityHandle | surf, |
| std::vector< std::vector< EntityHandle > > | skin, | ||
| std::vector< EntityHandle > | curves, | ||
| int | surf_id, | ||
| bool | debug | ||
Definition at line 1676 of file mw_func.cpp.
