MeshKit
1.0
00001 00007 #include "meshkit/MKCore.hpp" 00008 #include "meshkit/MeshOp.hpp" 00009 #include "meshkit/CopyMesh.hpp" 00010 #include "meshkit/ModelEnt.hpp" 00011 #include "meshkit/MergeMesh.hpp" 00012 00013 using namespace MeshKit; 00014 00015 #include "TestUtil.hpp" 00016 #define DEFAULT_TEST_FILE1 "c.h5m" 00017 #define DEFAULT_TEST_FILE2 "d.h5m" 00018 00019 MKCore *mk; 00020 00021 void test_copy_quad(); 00022 void test_load_and_copymove(); 00023 void test_set_imesh(); 00024 00025 int main(int argc, char **argv) 00026 { 00027 mk = new MKCore(); 00028 int num_fail = 0; 00029 num_fail += RUN_TEST(test_set_imesh); 00030 num_fail += RUN_TEST(test_load_and_copymove); 00031 num_fail += RUN_TEST(test_copy_quad); 00032 00033 delete mk; 00034 return num_fail; 00035 } 00036 00037 void test_set_imesh() 00038 { 00039 std::vector <CopyMesh*> cm; 00040 iMesh *imesh = mk->imesh_instance(); 00041 int err =0; 00042 std::vector<std::string> files; 00043 std::string name1 = TestDir + "/" + DEFAULT_TEST_FILE1; 00044 std::string name2 = TestDir + "/" + DEFAULT_TEST_FILE2; 00045 00046 files.push_back(name1); 00047 files.push_back(name2); 00048 cm.resize(files.size()); 00049 iBase_EntitySetHandle orig_set; 00050 00051 for (unsigned int i = 0; i < files.size(); i++) { 00052 iMesh_createEntSet(imesh->instance(), 0, &orig_set, &err); 00053 //ERRORR("Couldn't create file set.", err); 00054 std::cout << "Loading File: " << files[i].c_str() << std::endl; 00055 iMesh_load(imesh->instance(), orig_set, files[i].c_str(), NULL, &err, strlen(files[i].c_str()), 0); 00056 00057 ModelEnt *me; 00058 me = NULL; 00059 me = new ModelEnt(mk, iBase_EntitySetHandle(0), /*igeom instance*/0, (moab::EntityHandle)orig_set, 0); 00060 MEntVector assm_set; 00061 //assm_set.clear(); 00062 assm_set.push_back(me); 00063 cm[i] = (CopyMesh*) mk->construct_meshop("CopyMesh", assm_set); 00064 cm[i]->set_name("copy_move_mesh"); 00065 cm[i]->copy_sets().add_set(orig_set); 00066 // some entity tag types are always copy or expand 00067 cm[i]->expand_sets().add_tag("MATERIAL_SET"); 00068 cm[i]->expand_sets().add_tag("DIRICHLET_SET"); 00069 cm[i]->expand_sets().add_tag("NEUMANN_SET"); 00070 cm[i]->copy_sets().add_tag("GEOM_DIMENSION"); 00071 00072 Vector<3> dx; dx[0] = 10; dx[1] = 0; dx[2] = 0; 00073 cm[i]->set_transform(Copy::Translate(dx)); 00074 } 00075 // copy and merge 00076 mk->setup_and_execute(); 00077 for (unsigned int i = 0; i < files.size(); i++) 00078 delete cm[i]; 00079 } 00080 00081 00082 void test_load_and_copymove() 00083 { 00084 //clear_mesh(mk); 00085 mk->delete_all(); 00086 std::string filename = TestDir + "/" + DEFAULT_TEST_FILE1; 00087 mk->load_mesh(filename.c_str()); 00088 00089 // get the hexes 00090 MEntVector vols, v1; 00091 //mk->get_entities_by_dimension(3, vols); 00092 moab::EntityHandle root_set = mk->moab_instance()->get_root_set(); 00093 ModelEnt me(mk, iBase_EntitySetHandle(0), /*igeom instance*/0, root_set); 00094 vols.push_back(&me); 00095 00096 CopyMesh *cm = (CopyMesh*) mk->construct_meshop("CopyMesh", vols); 00097 cm->set_name("copy_move_mesh"); 00098 // some entity tag types are always copy or expand 00099 cm->expand_sets().add_tag("MATERIAL_SET"); 00100 cm->expand_sets().add_tag("DIRICHLET_SET"); 00101 cm->expand_sets().add_tag("NEUMANN_SET"); 00102 00103 Vector<3> dx; dx[0] = 10; dx[1] = 0; dx[2] = 0; 00104 cm->set_transform(Copy::Translate(dx)); 00105 00106 //accesses entities for merging directly from moab instance, vols are used for finding the dimension 00107 MergeMesh *mm = (MergeMesh*) mk->construct_meshop("MergeMesh", v1); 00108 mm->set_name("merge_mesh"); 00109 00110 double merge_tol = 1e-3; int updatesets = 0, domerge = 1; iBase_TagHandle merge_tag = NULL; 00111 mm->set_merge_params(merge_tol, updatesets, domerge, merge_tag); 00112 00113 // put them in the graph 00114 mk->get_graph().addArc(mk->root_node()->get_node(), cm->get_node()); 00115 mk->get_graph().addArc(cm->get_node(), mm->get_node()); 00116 mk->get_graph().addArc(mm->get_node(), mk->leaf_node()->get_node()); 00117 00118 // copy and merge 00119 mk->setup_and_execute(); 00120 delete cm; 00121 } 00122 00123 00124 void test_copy_quad() 00125 { 00126 mk->delete_all(); 00127 iMesh *mesh = mk->imesh_instance(); 00128 00129 double coords[] = { 00130 0, 0, 0, 00131 1, 0, 0, 00132 1, 1, 0, 00133 0, 1, 0, 00134 }; 00135 00136 iMesh::EntityHandle verts[4]; 00137 iMesh::EntityHandle quad; 00138 iMesh::EntitySetHandle set; 00139 00140 mesh->createVtxArr(4, iBase_INTERLEAVED, coords, verts); 00141 mesh->createEnt(iMesh_QUADRILATERAL, verts, 4, quad); 00142 mesh->createEntSet(true, set); 00143 mesh->addEntToSet(quad, set); 00144 00145 ModelEnt me(mk, iBase_EntitySetHandle(0), /*igeom instance*/0, (moab::EntityHandle)set); 00146 MEntVector selection; 00147 selection.push_back(&me); 00148 00149 CopyMesh *cm = (CopyMesh*) mk->construct_meshop("CopyMesh", selection); 00150 cm->set_name("copy_move_mesh"); 00151 00152 Vector<3> dx; dx[0] = 0; dx[1] = 0; dx[2] = 10; 00153 cm->set_transform(Copy::Translate(dx)); 00154 00155 // put them in the graph 00156 mk->get_graph().addArc(mk->root_node()->get_node(), cm->get_node()); 00157 mk->get_graph().addArc(cm->get_node(), mk->leaf_node()->get_node()); 00158 00159 cm->copy_sets().add_set(set); 00160 cm->flag_process_ce_set = true; 00161 // mesh embedded boundary mesh, by calling execute 00162 mk->setup_and_execute(); 00163 00164 std::vector<iMesh::EntityHandle> new_verts; 00165 double new_coords[4*3]; 00166 std::vector<iMesh::EntityHandle> new_quad; 00167 iMesh::EntitySetHandle new_set; 00168 00169 mesh->getEntSetEHData(set, cm->copy_tag(), (iMesh::EntityHandle&)new_set); 00170 00171 mesh->getEntities(new_set, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, new_quad); 00172 CHECK_EQUAL(new_quad.size(), size_t(1)); 00173 00174 mesh->getEntAdj(new_quad[0], iBase_ALL_TYPES, new_verts); 00175 CHECK_EQUAL(new_verts.size(), size_t(4)); 00176 00177 mesh->getVtxArrCoords(&new_verts[0], new_verts.size(), iBase_INTERLEAVED, 00178 new_coords); 00179 00180 for(int i=0; i<4; i++) { 00181 CHECK_REAL_EQUAL(coords[i*3+0], new_coords[i*3+0], 0.00001); 00182 CHECK_REAL_EQUAL(coords[i*3+1], new_coords[i*3+1], 0.00001); 00183 CHECK_REAL_EQUAL(coords[i*3+2]+10, new_coords[i*3+2], 0.00001); 00184 } 00185 delete cm; 00186 }
