MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2009 Gael Guennebaud <[email protected]> 00005 // 00006 // This Source Code Form is subject to the terms of the Mozilla 00007 // Public License v. 2.0. If a copy of the MPL was not distributed 00008 // with this file, You can obtain one at http://mozilla.org/MPL/2.0/. 00009 00010 #ifndef EIGEN_BANDMATRIX_H 00011 #define EIGEN_BANDMATRIX_H 00012 00013 namespace Eigen { 00014 00015 namespace internal { 00016 00017 template<typename Derived> 00018 class BandMatrixBase : public EigenBase<Derived> 00019 { 00020 public: 00021 00022 enum { 00023 Flags = internal::traits<Derived>::Flags, 00024 CoeffReadCost = internal::traits<Derived>::CoeffReadCost, 00025 RowsAtCompileTime = internal::traits<Derived>::RowsAtCompileTime, 00026 ColsAtCompileTime = internal::traits<Derived>::ColsAtCompileTime, 00027 MaxRowsAtCompileTime = internal::traits<Derived>::MaxRowsAtCompileTime, 00028 MaxColsAtCompileTime = internal::traits<Derived>::MaxColsAtCompileTime, 00029 Supers = internal::traits<Derived>::Supers, 00030 Subs = internal::traits<Derived>::Subs, 00031 Options = internal::traits<Derived>::Options 00032 }; 00033 typedef typename internal::traits<Derived>::Scalar Scalar; 00034 typedef Matrix<Scalar,RowsAtCompileTime,ColsAtCompileTime> DenseMatrixType; 00035 typedef typename DenseMatrixType::StorageIndex StorageIndex; 00036 typedef typename internal::traits<Derived>::CoefficientsType CoefficientsType; 00037 typedef EigenBase<Derived> Base; 00038 00039 protected: 00040 enum { 00041 DataRowsAtCompileTime = ((Supers!=Dynamic) && (Subs!=Dynamic)) 00042 ? 1 + Supers + Subs 00043 : Dynamic, 00044 SizeAtCompileTime = EIGEN_SIZE_MIN_PREFER_DYNAMIC(RowsAtCompileTime,ColsAtCompileTime) 00045 }; 00046 00047 public: 00048 00049 using Base::derived; 00050 using Base::rows; 00051 using Base::cols; 00052 00054 inline Index supers() const { return derived().supers(); } 00055 00057 inline Index subs() const { return derived().subs(); } 00058 00060 inline const CoefficientsType& coeffs() const { return derived().coeffs(); } 00061 00063 inline CoefficientsType& coeffs() { return derived().coeffs(); } 00064 00068 inline Block<CoefficientsType,Dynamic,1> col(Index i) 00069 { 00070 EIGEN_STATIC_ASSERT((Options&RowMajor)==0,THIS_METHOD_IS_ONLY_FOR_COLUMN_MAJOR_MATRICES); 00071 Index start = 0; 00072 Index len = coeffs().rows(); 00073 if (i<=supers()) 00074 { 00075 start = supers()-i; 00076 len = (std::min)(rows(),std::max<Index>(0,coeffs().rows() - (supers()-i))); 00077 } 00078 else if (i>=rows()-subs()) 00079 len = std::max<Index>(0,coeffs().rows() - (i + 1 - rows() + subs())); 00080 return Block<CoefficientsType,Dynamic,1>(coeffs(), start, i, len, 1); 00081 } 00082 00084 inline Block<CoefficientsType,1,SizeAtCompileTime> diagonal() 00085 { return Block<CoefficientsType,1,SizeAtCompileTime>(coeffs(),supers(),0,1,(std::min)(rows(),cols())); } 00086 00088 inline const Block<const CoefficientsType,1,SizeAtCompileTime> diagonal() const 00089 { return Block<const CoefficientsType,1,SizeAtCompileTime>(coeffs(),supers(),0,1,(std::min)(rows(),cols())); } 00090 00091 template<int Index> struct DiagonalIntReturnType { 00092 enum { 00093 ReturnOpposite = (Options&SelfAdjoint) && (((Index)>0 && Supers==0) || ((Index)<0 && Subs==0)), 00094 Conjugate = ReturnOpposite && NumTraits<Scalar>::IsComplex, 00095 ActualIndex = ReturnOpposite ? -Index : Index, 00096 DiagonalSize = (RowsAtCompileTime==Dynamic || ColsAtCompileTime==Dynamic) 00097 ? Dynamic 00098 : (ActualIndex<0 00099 ? EIGEN_SIZE_MIN_PREFER_DYNAMIC(ColsAtCompileTime, RowsAtCompileTime + ActualIndex) 00100 : EIGEN_SIZE_MIN_PREFER_DYNAMIC(RowsAtCompileTime, ColsAtCompileTime - ActualIndex)) 00101 }; 00102 typedef Block<CoefficientsType,1, DiagonalSize> BuildType; 00103 typedef typename internal::conditional<Conjugate, 00104 CwiseUnaryOp<internal::scalar_conjugate_op<Scalar>,BuildType >, 00105 BuildType>::type Type; 00106 }; 00107 00109 template<int N> inline typename DiagonalIntReturnType<N>::Type diagonal() 00110 { 00111 return typename DiagonalIntReturnType<N>::BuildType(coeffs(), supers()-N, (std::max)(0,N), 1, diagonalLength(N)); 00112 } 00113 00115 template<int N> inline const typename DiagonalIntReturnType<N>::Type diagonal() const 00116 { 00117 return typename DiagonalIntReturnType<N>::BuildType(coeffs(), supers()-N, (std::max)(0,N), 1, diagonalLength(N)); 00118 } 00119 00121 inline Block<CoefficientsType,1,Dynamic> diagonal(Index i) 00122 { 00123 eigen_assert((i<0 && -i<=subs()) || (i>=0 && i<=supers())); 00124 return Block<CoefficientsType,1,Dynamic>(coeffs(), supers()-i, std::max<Index>(0,i), 1, diagonalLength(i)); 00125 } 00126 00128 inline const Block<const CoefficientsType,1,Dynamic> diagonal(Index i) const 00129 { 00130 eigen_assert((i<0 && -i<=subs()) || (i>=0 && i<=supers())); 00131 return Block<const CoefficientsType,1,Dynamic>(coeffs(), supers()-i, std::max<Index>(0,i), 1, diagonalLength(i)); 00132 } 00133 00134 template<typename Dest> inline void evalTo(Dest& dst) const 00135 { 00136 dst.resize(rows(),cols()); 00137 dst.setZero(); 00138 dst.diagonal() = diagonal(); 00139 for (Index i=1; i<=supers();++i) 00140 dst.diagonal(i) = diagonal(i); 00141 for (Index i=1; i<=subs();++i) 00142 dst.diagonal(-i) = diagonal(-i); 00143 } 00144 00145 DenseMatrixType toDenseMatrix() const 00146 { 00147 DenseMatrixType res(rows(),cols()); 00148 evalTo(res); 00149 return res; 00150 } 00151 00152 protected: 00153 00154 inline Index diagonalLength(Index i) const 00155 { return i<0 ? (std::min)(cols(),rows()+i) : (std::min)(rows(),cols()-i); } 00156 }; 00157 00177 template<typename _Scalar, int _Rows, int _Cols, int _Supers, int _Subs, int _Options> 00178 struct traits<BandMatrix<_Scalar,_Rows,_Cols,_Supers,_Subs,_Options> > 00179 { 00180 typedef _Scalar Scalar; 00181 typedef Dense StorageKind; 00182 typedef Eigen::Index StorageIndex; 00183 enum { 00184 CoeffReadCost = NumTraits<Scalar>::ReadCost, 00185 RowsAtCompileTime = _Rows, 00186 ColsAtCompileTime = _Cols, 00187 MaxRowsAtCompileTime = _Rows, 00188 MaxColsAtCompileTime = _Cols, 00189 Flags = LvalueBit, 00190 Supers = _Supers, 00191 Subs = _Subs, 00192 Options = _Options, 00193 DataRowsAtCompileTime = ((Supers!=Dynamic) && (Subs!=Dynamic)) ? 1 + Supers + Subs : Dynamic 00194 }; 00195 typedef Matrix<Scalar,DataRowsAtCompileTime,ColsAtCompileTime,Options&RowMajor?RowMajor:ColMajor> CoefficientsType; 00196 }; 00197 00198 template<typename _Scalar, int Rows, int Cols, int Supers, int Subs, int Options> 00199 class BandMatrix : public BandMatrixBase<BandMatrix<_Scalar,Rows,Cols,Supers,Subs,Options> > 00200 { 00201 public: 00202 00203 typedef typename internal::traits<BandMatrix>::Scalar Scalar; 00204 typedef typename internal::traits<BandMatrix>::StorageIndex StorageIndex; 00205 typedef typename internal::traits<BandMatrix>::CoefficientsType CoefficientsType; 00206 00207 explicit inline BandMatrix(Index rows=Rows, Index cols=Cols, Index supers=Supers, Index subs=Subs) 00208 : m_coeffs(1+supers+subs,cols), 00209 m_rows(rows), m_supers(supers), m_subs(subs) 00210 { 00211 } 00212 00214 inline Index rows() const { return m_rows.value(); } 00215 00217 inline Index cols() const { return m_coeffs.cols(); } 00218 00220 inline Index supers() const { return m_supers.value(); } 00221 00223 inline Index subs() const { return m_subs.value(); } 00224 00225 inline const CoefficientsType& coeffs() const { return m_coeffs; } 00226 inline CoefficientsType& coeffs() { return m_coeffs; } 00227 00228 protected: 00229 00230 CoefficientsType m_coeffs; 00231 internal::variable_if_dynamic<Index, Rows> m_rows; 00232 internal::variable_if_dynamic<Index, Supers> m_supers; 00233 internal::variable_if_dynamic<Index, Subs> m_subs; 00234 }; 00235 00236 template<typename _CoefficientsType,int _Rows, int _Cols, int _Supers, int _Subs,int _Options> 00237 class BandMatrixWrapper; 00238 00239 template<typename _CoefficientsType,int _Rows, int _Cols, int _Supers, int _Subs,int _Options> 00240 struct traits<BandMatrixWrapper<_CoefficientsType,_Rows,_Cols,_Supers,_Subs,_Options> > 00241 { 00242 typedef typename _CoefficientsType::Scalar Scalar; 00243 typedef typename _CoefficientsType::StorageKind StorageKind; 00244 typedef typename _CoefficientsType::StorageIndex StorageIndex; 00245 enum { 00246 CoeffReadCost = internal::traits<_CoefficientsType>::CoeffReadCost, 00247 RowsAtCompileTime = _Rows, 00248 ColsAtCompileTime = _Cols, 00249 MaxRowsAtCompileTime = _Rows, 00250 MaxColsAtCompileTime = _Cols, 00251 Flags = LvalueBit, 00252 Supers = _Supers, 00253 Subs = _Subs, 00254 Options = _Options, 00255 DataRowsAtCompileTime = ((Supers!=Dynamic) && (Subs!=Dynamic)) ? 1 + Supers + Subs : Dynamic 00256 }; 00257 typedef _CoefficientsType CoefficientsType; 00258 }; 00259 00260 template<typename _CoefficientsType,int _Rows, int _Cols, int _Supers, int _Subs,int _Options> 00261 class BandMatrixWrapper : public BandMatrixBase<BandMatrixWrapper<_CoefficientsType,_Rows,_Cols,_Supers,_Subs,_Options> > 00262 { 00263 public: 00264 00265 typedef typename internal::traits<BandMatrixWrapper>::Scalar Scalar; 00266 typedef typename internal::traits<BandMatrixWrapper>::CoefficientsType CoefficientsType; 00267 typedef typename internal::traits<BandMatrixWrapper>::StorageIndex StorageIndex; 00268 00269 explicit inline BandMatrixWrapper(const CoefficientsType& coeffs, Index rows=_Rows, Index cols=_Cols, Index supers=_Supers, Index subs=_Subs) 00270 : m_coeffs(coeffs), 00271 m_rows(rows), m_supers(supers), m_subs(subs) 00272 { 00273 EIGEN_UNUSED_VARIABLE(cols); 00274 //internal::assert(coeffs.cols()==cols() && (supers()+subs()+1)==coeffs.rows()); 00275 } 00276 00278 inline Index rows() const { return m_rows.value(); } 00279 00281 inline Index cols() const { return m_coeffs.cols(); } 00282 00284 inline Index supers() const { return m_supers.value(); } 00285 00287 inline Index subs() const { return m_subs.value(); } 00288 00289 inline const CoefficientsType& coeffs() const { return m_coeffs; } 00290 00291 protected: 00292 00293 const CoefficientsType& m_coeffs; 00294 internal::variable_if_dynamic<Index, _Rows> m_rows; 00295 internal::variable_if_dynamic<Index, _Supers> m_supers; 00296 internal::variable_if_dynamic<Index, _Subs> m_subs; 00297 }; 00298 00311 template<typename Scalar, int Size, int Options> 00312 class TridiagonalMatrix : public BandMatrix<Scalar,Size,Size,Options&SelfAdjoint?0:1,1,Options|RowMajor> 00313 { 00314 typedef BandMatrix<Scalar,Size,Size,Options&SelfAdjoint?0:1,1,Options|RowMajor> Base; 00315 typedef typename Base::StorageIndex StorageIndex; 00316 public: 00317 explicit TridiagonalMatrix(Index size = Size) : Base(size,size,Options&SelfAdjoint?0:1,1) {} 00318 00319 inline typename Base::template DiagonalIntReturnType<1>::Type super() 00320 { return Base::template diagonal<1>(); } 00321 inline const typename Base::template DiagonalIntReturnType<1>::Type super() const 00322 { return Base::template diagonal<1>(); } 00323 inline typename Base::template DiagonalIntReturnType<-1>::Type sub() 00324 { return Base::template diagonal<-1>(); } 00325 inline const typename Base::template DiagonalIntReturnType<-1>::Type sub() const 00326 { return Base::template diagonal<-1>(); } 00327 protected: 00328 }; 00329 00330 00331 struct BandShape {}; 00332 00333 template<typename _Scalar, int _Rows, int _Cols, int _Supers, int _Subs, int _Options> 00334 struct evaluator_traits<BandMatrix<_Scalar,_Rows,_Cols,_Supers,_Subs,_Options> > 00335 : public evaluator_traits_base<BandMatrix<_Scalar,_Rows,_Cols,_Supers,_Subs,_Options> > 00336 { 00337 typedef BandShape Shape; 00338 }; 00339 00340 template<typename _CoefficientsType,int _Rows, int _Cols, int _Supers, int _Subs,int _Options> 00341 struct evaluator_traits<BandMatrixWrapper<_CoefficientsType,_Rows,_Cols,_Supers,_Subs,_Options> > 00342 : public evaluator_traits_base<BandMatrixWrapper<_CoefficientsType,_Rows,_Cols,_Supers,_Subs,_Options> > 00343 { 00344 typedef BandShape Shape; 00345 }; 00346 00347 template<> struct AssignmentKind<DenseShape,BandShape> { typedef EigenBase2EigenBase Kind; }; 00348 00349 } // end namespace internal 00350 00351 } // end namespace Eigen 00352 00353 #endif // EIGEN_BANDMATRIX_H
