MOAB
4.9.3pre
Classes | |
| struct | Eigen::internal::pastix_traits< PastixLU< _MatrixType > > |
| struct | Eigen::internal::pastix_traits< PastixLLT< _MatrixType, Options > > |
| struct | Eigen::internal::pastix_traits< PastixLDLT< _MatrixType, Options > > |
| class | Eigen::PastixBase< Derived > |
| class | Eigen::PastixLU< _MatrixType, IsStrSym > |
| Sparse direct LU solver based on PaStiX library. More... | |
| class | Eigen::PastixLLT< _MatrixType, _UpLo > |
| A sparse direct supernodal Cholesky (LLT) factorization and solver based on the PaStiX library. More... | |
| class | Eigen::PastixLDLT< _MatrixType, _UpLo > |
Namespaces | |
| namespace | Eigen |
| namespace | Eigen::internal |
Defines | |
| #define | PASTIX_COMPLEX std::complex<float> |
| #define | PASTIX_DCOMPLEX std::complex<double> |
Functions | |
| void | Eigen::internal::eigen_pastix (pastix_data_t **pastix_data, int pastix_comm, int n, int *ptr, int *idx, float *vals, int *perm, int *invp, float *x, int nbrhs, int *iparm, double *dparm) |
| void | Eigen::internal::eigen_pastix (pastix_data_t **pastix_data, int pastix_comm, int n, int *ptr, int *idx, double *vals, int *perm, int *invp, double *x, int nbrhs, int *iparm, double *dparm) |
| void | Eigen::internal::eigen_pastix (pastix_data_t **pastix_data, int pastix_comm, int n, int *ptr, int *idx, std::complex< float > *vals, int *perm, int *invp, std::complex< float > *x, int nbrhs, int *iparm, double *dparm) |
| void | Eigen::internal::eigen_pastix (pastix_data_t **pastix_data, int pastix_comm, int n, int *ptr, int *idx, std::complex< double > *vals, int *perm, int *invp, std::complex< double > *x, int nbrhs, int *iparm, double *dparm) |
| template<typename MatrixType > | |
| void | Eigen::internal::c_to_fortran_numbering (MatrixType &mat) |
| void | Eigen::internal::fortran_to_c_numbering (MatrixType &mat) |
| #define PASTIX_COMPLEX std::complex<float> |
Definition at line 19 of file PaStiXSupport.h.
| #define PASTIX_DCOMPLEX std::complex<double> |
Definition at line 20 of file PaStiXSupport.h.
