MOAB
4.9.3pre
00001 /* 00002 Copyright (c) 2011, Intel Corporation. All rights reserved. 00003 00004 Redistribution and use in source and binary forms, with or without modification, 00005 are permitted provided that the following conditions are met: 00006 00007 * Redistributions of source code must retain the above copyright notice, this 00008 list of conditions and the following disclaimer. 00009 * Redistributions in binary form must reproduce the above copyright notice, 00010 this list of conditions and the following disclaimer in the documentation 00011 and/or other materials provided with the distribution. 00012 * Neither the name of Intel Corporation nor the names of its contributors may 00013 be used to endorse or promote products derived from this software without 00014 specific prior written permission. 00015 00016 THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND 00017 ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED 00018 WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE 00019 DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR 00020 ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES 00021 (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; 00022 LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON 00023 ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT 00024 (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS 00025 SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. 00026 00027 ******************************************************************************** 00028 * Content : Eigen bindings to Intel(R) MKL PARDISO 00029 ******************************************************************************** 00030 */ 00031 00032 #ifndef EIGEN_PARDISOSUPPORT_H 00033 #define EIGEN_PARDISOSUPPORT_H 00034 00035 namespace Eigen { 00036 00037 template<typename _MatrixType> class PardisoLU; 00038 template<typename _MatrixType, int Options=Upper> class PardisoLLT; 00039 template<typename _MatrixType, int Options=Upper> class PardisoLDLT; 00040 00041 namespace internal 00042 { 00043 template<typename IndexType> 00044 struct pardiso_run_selector 00045 { 00046 static IndexType run( _MKL_DSS_HANDLE_t pt, IndexType maxfct, IndexType mnum, IndexType type, IndexType phase, IndexType n, void *a, 00047 IndexType *ia, IndexType *ja, IndexType *perm, IndexType nrhs, IndexType *iparm, IndexType msglvl, void *b, void *x) 00048 { 00049 IndexType error = 0; 00050 ::pardiso(pt, &maxfct, &mnum, &type, &phase, &n, a, ia, ja, perm, &nrhs, iparm, &msglvl, b, x, &error); 00051 return error; 00052 } 00053 }; 00054 template<> 00055 struct pardiso_run_selector<long long int> 00056 { 00057 typedef long long int IndexType; 00058 static IndexType run( _MKL_DSS_HANDLE_t pt, IndexType maxfct, IndexType mnum, IndexType type, IndexType phase, IndexType n, void *a, 00059 IndexType *ia, IndexType *ja, IndexType *perm, IndexType nrhs, IndexType *iparm, IndexType msglvl, void *b, void *x) 00060 { 00061 IndexType error = 0; 00062 ::pardiso_64(pt, &maxfct, &mnum, &type, &phase, &n, a, ia, ja, perm, &nrhs, iparm, &msglvl, b, x, &error); 00063 return error; 00064 } 00065 }; 00066 00067 template<class Pardiso> struct pardiso_traits; 00068 00069 template<typename _MatrixType> 00070 struct pardiso_traits< PardisoLU<_MatrixType> > 00071 { 00072 typedef _MatrixType MatrixType; 00073 typedef typename _MatrixType::Scalar Scalar; 00074 typedef typename _MatrixType::RealScalar RealScalar; 00075 typedef typename _MatrixType::StorageIndex StorageIndex; 00076 }; 00077 00078 template<typename _MatrixType, int Options> 00079 struct pardiso_traits< PardisoLLT<_MatrixType, Options> > 00080 { 00081 typedef _MatrixType MatrixType; 00082 typedef typename _MatrixType::Scalar Scalar; 00083 typedef typename _MatrixType::RealScalar RealScalar; 00084 typedef typename _MatrixType::StorageIndex StorageIndex; 00085 }; 00086 00087 template<typename _MatrixType, int Options> 00088 struct pardiso_traits< PardisoLDLT<_MatrixType, Options> > 00089 { 00090 typedef _MatrixType MatrixType; 00091 typedef typename _MatrixType::Scalar Scalar; 00092 typedef typename _MatrixType::RealScalar RealScalar; 00093 typedef typename _MatrixType::StorageIndex StorageIndex; 00094 }; 00095 00096 } // end namespace internal 00097 00098 template<class Derived> 00099 class PardisoImpl : public SparseSolverBase<Derived> 00100 { 00101 protected: 00102 typedef SparseSolverBase<Derived> Base; 00103 using Base::derived; 00104 using Base::m_isInitialized; 00105 00106 typedef internal::pardiso_traits<Derived> Traits; 00107 public: 00108 using Base::_solve_impl; 00109 00110 typedef typename Traits::MatrixType MatrixType; 00111 typedef typename Traits::Scalar Scalar; 00112 typedef typename Traits::RealScalar RealScalar; 00113 typedef typename Traits::StorageIndex StorageIndex; 00114 typedef SparseMatrix<Scalar,RowMajor,StorageIndex> SparseMatrixType; 00115 typedef Matrix<Scalar,Dynamic,1> VectorType; 00116 typedef Matrix<StorageIndex, 1, MatrixType::ColsAtCompileTime> IntRowVectorType; 00117 typedef Matrix<StorageIndex, MatrixType::RowsAtCompileTime, 1> IntColVectorType; 00118 typedef Array<StorageIndex,64,1,DontAlign> ParameterType; 00119 enum { 00120 ScalarIsComplex = NumTraits<Scalar>::IsComplex, 00121 ColsAtCompileTime = Dynamic, 00122 MaxColsAtCompileTime = Dynamic 00123 }; 00124 00125 PardisoImpl() 00126 { 00127 eigen_assert((sizeof(StorageIndex) >= sizeof(_INTEGER_t) && sizeof(StorageIndex) <= 8) && "Non-supported index type"); 00128 m_iparm.setZero(); 00129 m_msglvl = 0; // No output 00130 m_isInitialized = false; 00131 } 00132 00133 ~PardisoImpl() 00134 { 00135 pardisoRelease(); 00136 } 00137 00138 inline Index cols() const { return m_size; } 00139 inline Index rows() const { return m_size; } 00140 00146 ComputationInfo info() const 00147 { 00148 eigen_assert(m_isInitialized && "Decomposition is not initialized."); 00149 return m_info; 00150 } 00151 00155 ParameterType& pardisoParameterArray() 00156 { 00157 return m_iparm; 00158 } 00159 00166 Derived& analyzePattern(const MatrixType& matrix); 00167 00174 Derived& factorize(const MatrixType& matrix); 00175 00176 Derived& compute(const MatrixType& matrix); 00177 00178 template<typename Rhs,typename Dest> 00179 void _solve_impl(const MatrixBase<Rhs> &b, MatrixBase<Dest> &dest) const; 00180 00181 protected: 00182 void pardisoRelease() 00183 { 00184 if(m_isInitialized) // Factorization ran at least once 00185 { 00186 internal::pardiso_run_selector<StorageIndex>::run(m_pt, 1, 1, m_type, -1, m_size,0, 0, 0, m_perm.data(), 0, 00187 m_iparm.data(), m_msglvl, NULL, NULL); 00188 m_isInitialized = false; 00189 } 00190 } 00191 00192 void pardisoInit(int type) 00193 { 00194 m_type = type; 00195 bool symmetric = std::abs(m_type) < 10; 00196 m_iparm[0] = 1; // No solver default 00197 m_iparm[1] = 3; // use Metis for the ordering 00198 m_iparm[2] = 1; // Numbers of processors, value of OMP_NUM_THREADS 00199 m_iparm[3] = 0; // No iterative-direct algorithm 00200 m_iparm[4] = 0; // No user fill-in reducing permutation 00201 m_iparm[5] = 0; // Write solution into x 00202 m_iparm[6] = 0; // Not in use 00203 m_iparm[7] = 2; // Max numbers of iterative refinement steps 00204 m_iparm[8] = 0; // Not in use 00205 m_iparm[9] = 13; // Perturb the pivot elements with 1E-13 00206 m_iparm[10] = symmetric ? 0 : 1; // Use nonsymmetric permutation and scaling MPS 00207 m_iparm[11] = 0; // Not in use 00208 m_iparm[12] = symmetric ? 0 : 1; // Maximum weighted matching algorithm is switched-off (default for symmetric). 00209 // Try m_iparm[12] = 1 in case of inappropriate accuracy 00210 m_iparm[13] = 0; // Output: Number of perturbed pivots 00211 m_iparm[14] = 0; // Not in use 00212 m_iparm[15] = 0; // Not in use 00213 m_iparm[16] = 0; // Not in use 00214 m_iparm[17] = -1; // Output: Number of nonzeros in the factor LU 00215 m_iparm[18] = -1; // Output: Mflops for LU factorization 00216 m_iparm[19] = 0; // Output: Numbers of CG Iterations 00217 00218 m_iparm[20] = 0; // 1x1 pivoting 00219 m_iparm[26] = 0; // No matrix checker 00220 m_iparm[27] = (sizeof(RealScalar) == 4) ? 1 : 0; 00221 m_iparm[34] = 1; // C indexing 00222 m_iparm[59] = 1; // Automatic switch between In-Core and Out-of-Core modes 00223 00224 memset(m_pt, 0, sizeof(m_pt)); 00225 } 00226 00227 protected: 00228 // cached data to reduce reallocation, etc. 00229 00230 void manageErrorCode(Index error) const 00231 { 00232 switch(error) 00233 { 00234 case 0: 00235 m_info = Success; 00236 break; 00237 case -4: 00238 case -7: 00239 m_info = NumericalIssue; 00240 break; 00241 default: 00242 m_info = InvalidInput; 00243 } 00244 } 00245 00246 mutable SparseMatrixType m_matrix; 00247 mutable ComputationInfo m_info; 00248 bool m_analysisIsOk, m_factorizationIsOk; 00249 Index m_type, m_msglvl; 00250 mutable void *m_pt[64]; 00251 mutable ParameterType m_iparm; 00252 mutable IntColVectorType m_perm; 00253 Index m_size; 00254 00255 }; 00256 00257 template<class Derived> 00258 Derived& PardisoImpl<Derived>::compute(const MatrixType& a) 00259 { 00260 m_size = a.rows(); 00261 eigen_assert(a.rows() == a.cols()); 00262 00263 pardisoRelease(); 00264 m_perm.setZero(m_size); 00265 derived().getMatrix(a); 00266 00267 Index error; 00268 error = internal::pardiso_run_selector<StorageIndex>::run(m_pt, 1, 1, m_type, 12, m_size, 00269 m_matrix.valuePtr(), m_matrix.outerIndexPtr(), m_matrix.innerIndexPtr(), 00270 m_perm.data(), 0, m_iparm.data(), m_msglvl, NULL, NULL); 00271 00272 manageErrorCode(error); 00273 m_analysisIsOk = true; 00274 m_factorizationIsOk = true; 00275 m_isInitialized = true; 00276 return derived(); 00277 } 00278 00279 template<class Derived> 00280 Derived& PardisoImpl<Derived>::analyzePattern(const MatrixType& a) 00281 { 00282 m_size = a.rows(); 00283 eigen_assert(m_size == a.cols()); 00284 00285 pardisoRelease(); 00286 m_perm.setZero(m_size); 00287 derived().getMatrix(a); 00288 00289 Index error; 00290 error = internal::pardiso_run_selector<StorageIndex>::run(m_pt, 1, 1, m_type, 11, m_size, 00291 m_matrix.valuePtr(), m_matrix.outerIndexPtr(), m_matrix.innerIndexPtr(), 00292 m_perm.data(), 0, m_iparm.data(), m_msglvl, NULL, NULL); 00293 00294 manageErrorCode(error); 00295 m_analysisIsOk = true; 00296 m_factorizationIsOk = false; 00297 m_isInitialized = true; 00298 return derived(); 00299 } 00300 00301 template<class Derived> 00302 Derived& PardisoImpl<Derived>::factorize(const MatrixType& a) 00303 { 00304 eigen_assert(m_analysisIsOk && "You must first call analyzePattern()"); 00305 eigen_assert(m_size == a.rows() && m_size == a.cols()); 00306 00307 derived().getMatrix(a); 00308 00309 Index error; 00310 error = internal::pardiso_run_selector<StorageIndex>::run(m_pt, 1, 1, m_type, 22, m_size, 00311 m_matrix.valuePtr(), m_matrix.outerIndexPtr(), m_matrix.innerIndexPtr(), 00312 m_perm.data(), 0, m_iparm.data(), m_msglvl, NULL, NULL); 00313 00314 manageErrorCode(error); 00315 m_factorizationIsOk = true; 00316 return derived(); 00317 } 00318 00319 template<class Derived> 00320 template<typename BDerived,typename XDerived> 00321 void PardisoImpl<Derived>::_solve_impl(const MatrixBase<BDerived> &b, MatrixBase<XDerived>& x) const 00322 { 00323 if(m_iparm[0] == 0) // Factorization was not computed 00324 { 00325 m_info = InvalidInput; 00326 return; 00327 } 00328 00329 //Index n = m_matrix.rows(); 00330 Index nrhs = Index(b.cols()); 00331 eigen_assert(m_size==b.rows()); 00332 eigen_assert(((MatrixBase<BDerived>::Flags & RowMajorBit) == 0 || nrhs == 1) && "Row-major right hand sides are not supported"); 00333 eigen_assert(((MatrixBase<XDerived>::Flags & RowMajorBit) == 0 || nrhs == 1) && "Row-major matrices of unknowns are not supported"); 00334 eigen_assert(((nrhs == 1) || b.outerStride() == b.rows())); 00335 00336 00337 // switch (transposed) { 00338 // case SvNoTrans : m_iparm[11] = 0 ; break; 00339 // case SvTranspose : m_iparm[11] = 2 ; break; 00340 // case SvAdjoint : m_iparm[11] = 1 ; break; 00341 // default: 00342 // //std::cerr << "Eigen: transposition option \"" << transposed << "\" not supported by the PARDISO backend\n"; 00343 // m_iparm[11] = 0; 00344 // } 00345 00346 Scalar* rhs_ptr = const_cast<Scalar*>(b.derived().data()); 00347 Matrix<Scalar,Dynamic,Dynamic,ColMajor> tmp; 00348 00349 // Pardiso cannot solve in-place 00350 if(rhs_ptr == x.derived().data()) 00351 { 00352 tmp = b; 00353 rhs_ptr = tmp.data(); 00354 } 00355 00356 Index error; 00357 error = internal::pardiso_run_selector<StorageIndex>::run(m_pt, 1, 1, m_type, 33, m_size, 00358 m_matrix.valuePtr(), m_matrix.outerIndexPtr(), m_matrix.innerIndexPtr(), 00359 m_perm.data(), nrhs, m_iparm.data(), m_msglvl, 00360 rhs_ptr, x.derived().data()); 00361 00362 manageErrorCode(error); 00363 } 00364 00365 00380 template<typename MatrixType> 00381 class PardisoLU : public PardisoImpl< PardisoLU<MatrixType> > 00382 { 00383 protected: 00384 typedef PardisoImpl<PardisoLU> Base; 00385 typedef typename Base::Scalar Scalar; 00386 typedef typename Base::RealScalar RealScalar; 00387 using Base::pardisoInit; 00388 using Base::m_matrix; 00389 friend class PardisoImpl< PardisoLU<MatrixType> >; 00390 00391 public: 00392 00393 using Base::compute; 00394 using Base::solve; 00395 00396 PardisoLU() 00397 : Base() 00398 { 00399 pardisoInit(Base::ScalarIsComplex ? 13 : 11); 00400 } 00401 00402 explicit PardisoLU(const MatrixType& matrix) 00403 : Base() 00404 { 00405 pardisoInit(Base::ScalarIsComplex ? 13 : 11); 00406 compute(matrix); 00407 } 00408 protected: 00409 void getMatrix(const MatrixType& matrix) 00410 { 00411 m_matrix = matrix; 00412 m_matrix.makeCompressed(); 00413 } 00414 }; 00415 00432 template<typename MatrixType, int _UpLo> 00433 class PardisoLLT : public PardisoImpl< PardisoLLT<MatrixType,_UpLo> > 00434 { 00435 protected: 00436 typedef PardisoImpl< PardisoLLT<MatrixType,_UpLo> > Base; 00437 typedef typename Base::Scalar Scalar; 00438 typedef typename Base::RealScalar RealScalar; 00439 using Base::pardisoInit; 00440 using Base::m_matrix; 00441 friend class PardisoImpl< PardisoLLT<MatrixType,_UpLo> >; 00442 00443 public: 00444 00445 typedef typename Base::StorageIndex StorageIndex; 00446 enum { UpLo = _UpLo }; 00447 using Base::compute; 00448 00449 PardisoLLT() 00450 : Base() 00451 { 00452 pardisoInit(Base::ScalarIsComplex ? 4 : 2); 00453 } 00454 00455 explicit PardisoLLT(const MatrixType& matrix) 00456 : Base() 00457 { 00458 pardisoInit(Base::ScalarIsComplex ? 4 : 2); 00459 compute(matrix); 00460 } 00461 00462 protected: 00463 00464 void getMatrix(const MatrixType& matrix) 00465 { 00466 // PARDISO supports only upper, row-major matrices 00467 PermutationMatrix<Dynamic,Dynamic,StorageIndex> p_null; 00468 m_matrix.resize(matrix.rows(), matrix.cols()); 00469 m_matrix.template selfadjointView<Upper>() = matrix.template selfadjointView<UpLo>().twistedBy(p_null); 00470 m_matrix.makeCompressed(); 00471 } 00472 }; 00473 00492 template<typename MatrixType, int Options> 00493 class PardisoLDLT : public PardisoImpl< PardisoLDLT<MatrixType,Options> > 00494 { 00495 protected: 00496 typedef PardisoImpl< PardisoLDLT<MatrixType,Options> > Base; 00497 typedef typename Base::Scalar Scalar; 00498 typedef typename Base::RealScalar RealScalar; 00499 using Base::pardisoInit; 00500 using Base::m_matrix; 00501 friend class PardisoImpl< PardisoLDLT<MatrixType,Options> >; 00502 00503 public: 00504 00505 typedef typename Base::StorageIndex StorageIndex; 00506 using Base::compute; 00507 enum { UpLo = Options&(Upper|Lower) }; 00508 00509 PardisoLDLT() 00510 : Base() 00511 { 00512 pardisoInit(Base::ScalarIsComplex ? ( bool(Options&Symmetric) ? 6 : -4 ) : -2); 00513 } 00514 00515 explicit PardisoLDLT(const MatrixType& matrix) 00516 : Base() 00517 { 00518 pardisoInit(Base::ScalarIsComplex ? ( bool(Options&Symmetric) ? 6 : -4 ) : -2); 00519 compute(matrix); 00520 } 00521 00522 void getMatrix(const MatrixType& matrix) 00523 { 00524 // PARDISO supports only upper, row-major matrices 00525 PermutationMatrix<Dynamic,Dynamic,StorageIndex> p_null; 00526 m_matrix.resize(matrix.rows(), matrix.cols()); 00527 m_matrix.template selfadjointView<Upper>() = matrix.template selfadjointView<UpLo>().twistedBy(p_null); 00528 m_matrix.makeCompressed(); 00529 } 00530 }; 00531 00532 } // end namespace Eigen 00533 00534 #endif // EIGEN_PARDISOSUPPORT_H
