MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2012 Désiré Nuentsa-Wakam <[email protected]> 00005 // Copyright (C) 2012 Gael Guennebaud <[email protected]> 00006 // 00007 // This Source Code Form is subject to the terms of the Mozilla 00008 // Public License v. 2.0. If a copy of the MPL was not distributed 00009 // with this file, You can obtain one at http://mozilla.org/MPL/2.0/. 00010 00011 /* 00012 00013 * NOTE: This file is the modified version of xcolumn_bmod.c file in SuperLU 00014 00015 * -- SuperLU routine (version 3.0) -- 00016 * Univ. of California Berkeley, Xerox Palo Alto Research Center, 00017 * and Lawrence Berkeley National Lab. 00018 * October 15, 2003 00019 * 00020 * Copyright (c) 1994 by Xerox Corporation. All rights reserved. 00021 * 00022 * THIS MATERIAL IS PROVIDED AS IS, WITH ABSOLUTELY NO WARRANTY 00023 * EXPRESSED OR IMPLIED. ANY USE IS AT YOUR OWN RISK. 00024 * 00025 * Permission is hereby granted to use or copy this program for any 00026 * purpose, provided the above notices are retained on all copies. 00027 * Permission to modify the code and to distribute modified code is 00028 * granted, provided the above notices are retained, and a notice that 00029 * the code was modified is included with the above copyright notice. 00030 */ 00031 #ifndef SPARSELU_COLUMN_BMOD_H 00032 #define SPARSELU_COLUMN_BMOD_H 00033 00034 namespace Eigen { 00035 00036 namespace internal { 00052 template <typename Scalar, typename StorageIndex> 00053 Index SparseLUImpl<Scalar,StorageIndex>::column_bmod(const Index jcol, const Index nseg, BlockScalarVector dense, ScalarVector& tempv, 00054 BlockIndexVector segrep, BlockIndexVector repfnz, Index fpanelc, GlobalLU_t& glu) 00055 { 00056 Index jsupno, k, ksub, krep, ksupno; 00057 Index lptr, nrow, isub, irow, nextlu, new_next, ufirst; 00058 Index fsupc, nsupc, nsupr, luptr, kfnz, no_zeros; 00059 /* krep = representative of current k-th supernode 00060 * fsupc = first supernodal column 00061 * nsupc = number of columns in a supernode 00062 * nsupr = number of rows in a supernode 00063 * luptr = location of supernodal LU-block in storage 00064 * kfnz = first nonz in the k-th supernodal segment 00065 * no_zeros = no lf leading zeros in a supernodal U-segment 00066 */ 00067 00068 jsupno = glu.supno(jcol); 00069 // For each nonzero supernode segment of U[*,j] in topological order 00070 k = nseg - 1; 00071 Index d_fsupc; // distance between the first column of the current panel and the 00072 // first column of the current snode 00073 Index fst_col; // First column within small LU update 00074 Index segsize; 00075 for (ksub = 0; ksub < nseg; ksub++) 00076 { 00077 krep = segrep(k); k--; 00078 ksupno = glu.supno(krep); 00079 if (jsupno != ksupno ) 00080 { 00081 // outside the rectangular supernode 00082 fsupc = glu.xsup(ksupno); 00083 fst_col = (std::max)(fsupc, fpanelc); 00084 00085 // Distance from the current supernode to the current panel; 00086 // d_fsupc = 0 if fsupc > fpanelc 00087 d_fsupc = fst_col - fsupc; 00088 00089 luptr = glu.xlusup(fst_col) + d_fsupc; 00090 lptr = glu.xlsub(fsupc) + d_fsupc; 00091 00092 kfnz = repfnz(krep); 00093 kfnz = (std::max)(kfnz, fpanelc); 00094 00095 segsize = krep - kfnz + 1; 00096 nsupc = krep - fst_col + 1; 00097 nsupr = glu.xlsub(fsupc+1) - glu.xlsub(fsupc); 00098 nrow = nsupr - d_fsupc - nsupc; 00099 Index lda = glu.xlusup(fst_col+1) - glu.xlusup(fst_col); 00100 00101 00102 // Perform a triangular solver and block update, 00103 // then scatter the result of sup-col update to dense 00104 no_zeros = kfnz - fst_col; 00105 if(segsize==1) 00106 LU_kernel_bmod<1>::run(segsize, dense, tempv, glu.lusup, luptr, lda, nrow, glu.lsub, lptr, no_zeros); 00107 else 00108 LU_kernel_bmod<Dynamic>::run(segsize, dense, tempv, glu.lusup, luptr, lda, nrow, glu.lsub, lptr, no_zeros); 00109 } // end if jsupno 00110 } // end for each segment 00111 00112 // Process the supernodal portion of L\U[*,j] 00113 nextlu = glu.xlusup(jcol); 00114 fsupc = glu.xsup(jsupno); 00115 00116 // copy the SPA dense into L\U[*,j] 00117 Index mem; 00118 new_next = nextlu + glu.xlsub(fsupc + 1) - glu.xlsub(fsupc); 00119 Index offset = internal::first_multiple<Index>(new_next, internal::packet_traits<Scalar>::size) - new_next; 00120 if(offset) 00121 new_next += offset; 00122 while (new_next > glu.nzlumax ) 00123 { 00124 mem = memXpand<ScalarVector>(glu.lusup, glu.nzlumax, nextlu, LUSUP, glu.num_expansions); 00125 if (mem) return mem; 00126 } 00127 00128 for (isub = glu.xlsub(fsupc); isub < glu.xlsub(fsupc+1); isub++) 00129 { 00130 irow = glu.lsub(isub); 00131 glu.lusup(nextlu) = dense(irow); 00132 dense(irow) = Scalar(0.0); 00133 ++nextlu; 00134 } 00135 00136 if(offset) 00137 { 00138 glu.lusup.segment(nextlu,offset).setZero(); 00139 nextlu += offset; 00140 } 00141 glu.xlusup(jcol + 1) = StorageIndex(nextlu); // close L\U(*,jcol); 00142 00143 /* For more updates within the panel (also within the current supernode), 00144 * should start from the first column of the panel, or the first column 00145 * of the supernode, whichever is bigger. There are two cases: 00146 * 1) fsupc < fpanelc, then fst_col <-- fpanelc 00147 * 2) fsupc >= fpanelc, then fst_col <-- fsupc 00148 */ 00149 fst_col = (std::max)(fsupc, fpanelc); 00150 00151 if (fst_col < jcol) 00152 { 00153 // Distance between the current supernode and the current panel 00154 // d_fsupc = 0 if fsupc >= fpanelc 00155 d_fsupc = fst_col - fsupc; 00156 00157 lptr = glu.xlsub(fsupc) + d_fsupc; 00158 luptr = glu.xlusup(fst_col) + d_fsupc; 00159 nsupr = glu.xlsub(fsupc+1) - glu.xlsub(fsupc); // leading dimension 00160 nsupc = jcol - fst_col; // excluding jcol 00161 nrow = nsupr - d_fsupc - nsupc; 00162 00163 // points to the beginning of jcol in snode L\U(jsupno) 00164 ufirst = glu.xlusup(jcol) + d_fsupc; 00165 Index lda = glu.xlusup(jcol+1) - glu.xlusup(jcol); 00166 MappedMatrixBlock A( &(glu.lusup.data()[luptr]), nsupc, nsupc, OuterStride<>(lda) ); 00167 VectorBlock<ScalarVector> u(glu.lusup, ufirst, nsupc); 00168 u = A.template triangularView<UnitLower>().solve(u); 00169 00170 new (&A) MappedMatrixBlock ( &(glu.lusup.data()[luptr+nsupc]), nrow, nsupc, OuterStride<>(lda) ); 00171 VectorBlock<ScalarVector> l(glu.lusup, ufirst+nsupc, nrow); 00172 l.noalias() -= A * u; 00173 00174 } // End if fst_col 00175 return 0; 00176 } 00177 00178 } // end namespace internal 00179 } // end namespace Eigen 00180 00181 #endif // SPARSELU_COLUMN_BMOD_H
