MOAB: Mesh Oriented datABase
(version 5.2.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2006 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2006) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file TRel2DShapeSizeOrientBarrier.cpp 00028 * \brief 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #include "Mesquite.hpp" 00033 #include "TShapeSizeOrientB1.hpp" 00034 #include "MsqMatrix.hpp" 00035 #include "MsqError.hpp" 00036 #include "TMPDerivs.hpp" 00037 #include "TMPCommon.hpp" 00038 00039 namespace MBMesquite 00040 { 00041 00042 std::string TShapeSizeOrientB1::get_name() const 00043 { 00044 return "TShapeSizeOrientB1"; 00045 } 00046 00047 TShapeSizeOrientB1::~TShapeSizeOrientB1() {} 00048 00049 bool TShapeSizeOrientB1::evaluate( const MsqMatrix< 2, 2 >& T, double& result, MsqError& err ) 00050 { 00051 double tau = det( T ); 00052 if( TMetric::invalid_determinant( tau ) ) 00053 { 00054 MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED ); 00055 return false; 00056 } 00057 00058 MsqMatrix< 2, 2 > T_I( T ); 00059 pluseq_scaled_I( T_I, -1 ); 00060 result = sqr_Frobenius( T_I ) / ( 2 * tau ); 00061 return true; 00062 } 00063 00064 bool TShapeSizeOrientB1::evaluate_with_grad( const MsqMatrix< 2, 2 >& T, double& result, MsqMatrix< 2, 2 >& deriv_wrt_T, 00065 MsqError& err ) 00066 { 00067 const double d = det( T ); 00068 if( TMetric::invalid_determinant( d ) ) 00069 { // barrier 00070 MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED ); 00071 return false; 00072 } 00073 00074 deriv_wrt_T = T; 00075 pluseq_scaled_I( deriv_wrt_T, -1 ); 00076 double inv_d = 1.0 / d; 00077 result = 0.5 * sqr_Frobenius( deriv_wrt_T ) * inv_d; 00078 00079 deriv_wrt_T -= result * transpose_adj( T ); 00080 deriv_wrt_T *= inv_d; 00081 00082 return true; 00083 } 00084 00085 bool TShapeSizeOrientB1::evaluate_with_hess( const MsqMatrix< 2, 2 >& T, double& result, MsqMatrix< 2, 2 >& deriv_wrt_T, 00086 MsqMatrix< 2, 2 > second_wrt_T[3], MsqError& err ) 00087 { 00088 const double d = det( T ); 00089 if( TMetric::invalid_determinant( d ) ) 00090 { // barrier 00091 MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED ); 00092 return false; 00093 } 00094 00095 deriv_wrt_T = T; 00096 pluseq_scaled_I( deriv_wrt_T, -1.0 ); 00097 double inv_d = 1.0 / d; 00098 result = 0.5 * sqr_Frobenius( deriv_wrt_T ) * inv_d; 00099 00100 MsqMatrix< 2, 2 > adjt = transpose_adj( T ); 00101 set_scaled_outer_product( second_wrt_T, 2 * result * inv_d * inv_d, adjt ); 00102 pluseq_scaled_sum_outer_product( second_wrt_T, -inv_d * inv_d, deriv_wrt_T, adjt ); 00103 pluseq_scaled_2nd_deriv_of_det( second_wrt_T, -result * inv_d, T ); 00104 pluseq_scaled_I( second_wrt_T, inv_d ); 00105 00106 deriv_wrt_T -= result * adjt; 00107 deriv_wrt_T *= inv_d; 00108 00109 return true; 00110 } 00111 00112 bool TShapeSizeOrientB1::evaluate( const MsqMatrix< 3, 3 >& T, double& result, MsqError& err ) 00113 { 00114 double tau = det( T ); 00115 if( TMetric::invalid_determinant( tau ) ) 00116 { 00117 MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED ); 00118 return false; 00119 } 00120 00121 MsqMatrix< 3, 3 > T_I( T ); 00122 pluseq_scaled_I( T_I, -1 ); 00123 result = sqr_Frobenius( T_I ) / ( 2 * tau ); 00124 return true; 00125 } 00126 00127 bool TShapeSizeOrientB1::evaluate_with_grad( const MsqMatrix< 3, 3 >& T, double& result, MsqMatrix< 3, 3 >& deriv_wrt_T, 00128 MsqError& err ) 00129 { 00130 const double d = det( T ); 00131 if( TMetric::invalid_determinant( d ) ) 00132 { // barrier 00133 MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED ); 00134 return false; 00135 } 00136 00137 deriv_wrt_T = T; 00138 pluseq_scaled_I( deriv_wrt_T, -1 ); 00139 double inv_d = 1.0 / d; 00140 result = 0.5 * sqr_Frobenius( deriv_wrt_T ) * inv_d; 00141 00142 deriv_wrt_T -= result * transpose_adj( T ); 00143 deriv_wrt_T *= inv_d; 00144 00145 return true; 00146 } 00147 00148 bool TShapeSizeOrientB1::evaluate_with_hess( const MsqMatrix< 3, 3 >& T, double& result, MsqMatrix< 3, 3 >& deriv_wrt_T, 00149 MsqMatrix< 3, 3 > second_wrt_T[6], MsqError& err ) 00150 { 00151 const double d = det( T ); 00152 if( TMetric::invalid_determinant( d ) ) 00153 { // barrier 00154 MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED ); 00155 return false; 00156 } 00157 00158 deriv_wrt_T = T; 00159 pluseq_scaled_I( deriv_wrt_T, -1.0 ); 00160 double inv_d = 1.0 / d; 00161 result = 0.5 * sqr_Frobenius( deriv_wrt_T ) * inv_d; 00162 00163 MsqMatrix< 3, 3 > adjt = transpose_adj( T ); 00164 set_scaled_outer_product( second_wrt_T, 2 * result * inv_d * inv_d, adjt ); 00165 pluseq_scaled_sum_outer_product( second_wrt_T, -inv_d * inv_d, deriv_wrt_T, adjt ); 00166 pluseq_scaled_2nd_deriv_of_det( second_wrt_T, -result * inv_d, T ); 00167 pluseq_scaled_I( second_wrt_T, inv_d ); 00168 00169 deriv_wrt_T -= result * adjt; 00170 deriv_wrt_T *= inv_d; 00171 00172 return true; 00173 } 00174 00175 // TMP_T_TEMPL_IMPL_COMMON(TShapeSizeOrientB1) 00176 00177 } // namespace MBMesquite
