MOAB
4.9.3pre
A sparse direct LU factorization and solver based on the SuperLU library. More...
#include <SuperLUSupport.h>
This class allows to solve for A.X = B sparse linear problems via a direct LU factorization using the SuperLU library. The sparse matrix A must be squared and invertible. The vectors or matrices X and B can be either dense or sparse.
| _MatrixType | the type of the sparse matrix A, it must be a SparseMatrix<> |
Definition at line 462 of file SuperLUSupport.h.
| typedef SuperLUBase<_MatrixType,SuperLU> Eigen::SuperLU< _MatrixType >::Base |
Reimplemented from Eigen::SuperLUBase< _MatrixType, SuperLU< _MatrixType > >.
Definition at line 465 of file SuperLUSupport.h.
| typedef Base::IntColVectorType Eigen::SuperLU< _MatrixType >::IntColVectorType |
Definition at line 471 of file SuperLUSupport.h.
| typedef Base::IntRowVectorType Eigen::SuperLU< _MatrixType >::IntRowVectorType |
Definition at line 470 of file SuperLUSupport.h.
| typedef TriangularView<LUMatrixType, Lower|UnitDiag> Eigen::SuperLU< _MatrixType >::LMatrixType |
Definition at line 474 of file SuperLUSupport.h.
| typedef Base::LUMatrixType Eigen::SuperLU< _MatrixType >::LUMatrixType |
Definition at line 473 of file SuperLUSupport.h.
| typedef _MatrixType Eigen::SuperLU< _MatrixType >::MatrixType |
Definition at line 466 of file SuperLUSupport.h.
| typedef Base::PermutationMap Eigen::SuperLU< _MatrixType >::PermutationMap |
Definition at line 472 of file SuperLUSupport.h.
| typedef Base::RealScalar Eigen::SuperLU< _MatrixType >::RealScalar |
Definition at line 468 of file SuperLUSupport.h.
| typedef Base::Scalar Eigen::SuperLU< _MatrixType >::Scalar |
Definition at line 467 of file SuperLUSupport.h.
| typedef Base::StorageIndex Eigen::SuperLU< _MatrixType >::StorageIndex |
Definition at line 469 of file SuperLUSupport.h.
| typedef TriangularView<LUMatrixType, Upper> Eigen::SuperLU< _MatrixType >::UMatrixType |
Definition at line 475 of file SuperLUSupport.h.
| Eigen::SuperLU< _MatrixType >::SuperLU | ( | ) | [inline] |
Definition at line 480 of file SuperLUSupport.h.
| Eigen::SuperLU< _MatrixType >::SuperLU | ( | const MatrixType & | matrix | ) | [inline, explicit] |
Definition at line 482 of file SuperLUSupport.h.
: Base() { init(); Base::compute(matrix); }
| Eigen::SuperLU< _MatrixType >::~SuperLU | ( | ) | [inline] |
Definition at line 488 of file SuperLUSupport.h.
| Eigen::SuperLU< _MatrixType >::SuperLU | ( | SuperLU< _MatrixType > & | ) | [inline, private] |
Definition at line 583 of file SuperLUSupport.h.
| void Eigen::SuperLU< MatrixType >::_solve_impl | ( | const MatrixBase< Rhs > & | b, |
| MatrixBase< Dest > & | dest | ||
| ) | const |
Definition at line 623 of file SuperLUSupport.h.
eigen_assert(m_factorizationIsOk && "The decomposition is not in a valid state for solving, you must first call either compute() or analyzePattern()/factorize()");
const Index size = m_matrix.rows();
const Index rhsCols = b.cols();
eigen_assert(size==b.rows());
m_sluOptions.Trans = NOTRANS;
m_sluOptions.Fact = FACTORED;
m_sluOptions.IterRefine = NOREFINE;
m_sluFerr.resize(rhsCols);
m_sluBerr.resize(rhsCols);
Ref<const Matrix<typename Rhs::Scalar,Dynamic,Dynamic,ColMajor> > b_ref(b);
Ref<const Matrix<typename Dest::Scalar,Dynamic,Dynamic,ColMajor> > x_ref(x);
m_sluB = SluMatrix::Map(b_ref.const_cast_derived());
m_sluX = SluMatrix::Map(x_ref.const_cast_derived());
typename Rhs::PlainObject b_cpy;
if(m_sluEqued!='N')
b_cpy = b;
m_sluB = SluMatrix::Map(b_cpy.const_cast_derived());
StatInit(&m_sluStat);
int info = 0;
RealScalar recip_pivot_growth, rcond;
SuperLU_gssvx(&m_sluOptions, &m_sluA,
m_q.data(), m_p.data(),
&m_sluEtree[0], &m_sluEqued,
&m_sluRscale[0], &m_sluCscale[0],
&m_sluL, &m_sluU,
NULL, 0,
&m_sluB, &m_sluX,
&recip_pivot_growth, &rcond,
&m_sluFerr[0], &m_sluBerr[0],
&m_sluStat, &info, Scalar());
StatFree(&m_sluStat);
if(x.derived().data() != x_ref.data())
x = x_ref;
m_info = info==0 ? Success : NumericalIssue;
| void Eigen::SuperLU< _MatrixType >::analyzePattern | ( | const MatrixType & | matrix | ) | [inline] |
Performs a symbolic decomposition on the sparcity of matrix.
This function is particularly useful when solving for several problems having the same structure.
Definition at line 498 of file SuperLUSupport.h.
m_info = InvalidInput;
m_isInitialized = false;
Base::analyzePattern(matrix);
| SuperLU< MatrixType >::Scalar Eigen::SuperLU< MatrixType >::determinant | ( | ) | const |
Definition at line 767 of file SuperLUSupport.h.
eigen_assert(m_factorizationIsOk && "The decomposition is not in a valid state for computing the determinant, you must first call either compute() or analyzePattern()/factorize()");
if (m_extractedDataAreDirty)
this->extractData();
Scalar det = Scalar(1);
for (int j=0; j<m_u.cols(); ++j)
if (m_u.outerIndexPtr()[j+1]-m_u.outerIndexPtr()[j] > 0)
int lastId = m_u.outerIndexPtr()[j+1]-1;
eigen_assert(m_u.innerIndexPtr()[lastId]<=j);
if (m_u.innerIndexPtr()[lastId]==j)
det *= m_u.valuePtr()[lastId];
if(PermutationMap(m_p.data(),m_p.size()).determinant()*PermutationMap(m_q.data(),m_q.size()).determinant()<0)
det = -det;
if(m_sluEqued!='N')
return det/m_sluRscale.prod()/m_sluCscale.prod();
else
return det;
| void Eigen::SuperLU< MatrixType >::factorize | ( | const MatrixType & | matrix | ) |
Performs a numeric decomposition of matrix
The given matrix must has the same sparcity than the matrix on which the symbolic decomposition has been performed.
Definition at line 587 of file SuperLUSupport.h.
eigen_assert(m_analysisIsOk && "You must first call analyzePattern()");
if(!m_analysisIsOk)
return;
this->initFactorization(a);
m_sluOptions.ColPerm = COLAMD;
int info = 0;
RealScalar ferr, berr;
SuperLU_gssvx(&m_sluOptions, &m_sluA, m_q.data(), m_p.data(), &m_sluEtree[0],
&m_sluEqued, &m_sluRscale[0], &m_sluCscale[0],
&m_sluL, &m_sluU,
NULL, 0,
&m_sluB, &m_sluX,
&ferr, &berr,
m_extractedDataAreDirty = true;
// FIXME how to better check for errors ???
m_info = info == 0 ? Success : NumericalIssue;
m_factorizationIsOk = true;
| void Eigen::SuperLU< _MatrixType >::init | ( | ) | [inline, protected] |
Definition at line 570 of file SuperLUSupport.h.
Base::init();
set_default_options(&this->m_sluOptions);
m_sluOptions.PrintStat = NO;
m_sluOptions.ConditionNumber = NO;
| const LMatrixType& Eigen::SuperLU< _MatrixType >::matrixL | ( | ) | const [inline] |
Definition at line 517 of file SuperLUSupport.h.
if (m_extractedDataAreDirty) this->extractData();
return m_l;
| const UMatrixType& Eigen::SuperLU< _MatrixType >::matrixU | ( | ) | const [inline] |
Definition at line 523 of file SuperLUSupport.h.
return m_u;
| const IntColVectorType& Eigen::SuperLU< _MatrixType >::permutationP | ( | ) | const [inline] |
Definition at line 529 of file SuperLUSupport.h.
return m_p;
| const IntRowVectorType& Eigen::SuperLU< _MatrixType >::permutationQ | ( | ) | const [inline] |
Definition at line 535 of file SuperLUSupport.h.
return m_q;
