MOAB: Mesh Oriented datABase
(version 5.3.1)
Definition at line 86 of file TetLagrangeShapeTest.cpp.
TetLagrangeShapeTest::CPPUNIT_TEST | ( | test_coeff_corners | ) | [private] |
TetLagrangeShapeTest::CPPUNIT_TEST | ( | test_coeff_edges | ) | [private] |
TetLagrangeShapeTest::CPPUNIT_TEST | ( | test_coeff_faces | ) | [private] |
TetLagrangeShapeTest::CPPUNIT_TEST | ( | test_coeff_center | ) | [private] |
TetLagrangeShapeTest::CPPUNIT_TEST | ( | test_deriv_corners | ) | [private] |
TetLagrangeShapeTest::CPPUNIT_TEST | ( | test_deriv_edges | ) | [private] |
TetLagrangeShapeTest::CPPUNIT_TEST | ( | test_deriv_faces | ) | [private] |
TetLagrangeShapeTest::CPPUNIT_TEST | ( | test_deriv_center | ) | [private] |
TetLagrangeShapeTest::CPPUNIT_TEST | ( | test_mid_elem_node_coeff | ) | [private] |
TetLagrangeShapeTest::CPPUNIT_TEST | ( | test_mid_elem_node_deriv | ) | [private] |
TetLagrangeShapeTest::CPPUNIT_TEST | ( | test_mid_face_node_coeff | ) | [private] |
TetLagrangeShapeTest::CPPUNIT_TEST | ( | test_mid_face_node_deriv | ) | [private] |
TetLagrangeShapeTest::CPPUNIT_TEST | ( | test_ideal_jacobian | ) | [private] |
TetLagrangeShapeTest::CPPUNIT_TEST_SUITE | ( | TetLagrangeShapeTest | ) | [private] |
TetLagrangeShapeTest::CPPUNIT_TEST_SUITE_END | ( | ) | [private] |
Definition at line 659 of file TetLagrangeShapeTest.cpp.
References nodeset_from_bits().
{ for( unsigned i = 0; i < 0x40; ++i ) { test_mid_coeff( nodeset_from_bits( i ) ); } }
Definition at line 624 of file TetLagrangeShapeTest.cpp.
{ for( unsigned i = 0; i < 0x40; ++i ) { test_corner_coeff( 0, nodeset_from_bits( i ) ); test_corner_coeff( 1, nodeset_from_bits( i ) ); test_corner_coeff( 2, nodeset_from_bits( i ) ); test_corner_coeff( 3, nodeset_from_bits( i ) ); } }
Definition at line 635 of file TetLagrangeShapeTest.cpp.
{ for( unsigned i = 0; i < 0x40; ++i ) { test_edge_coeff( 0, nodeset_from_bits( i ) ); test_edge_coeff( 1, nodeset_from_bits( i ) ); test_edge_coeff( 2, nodeset_from_bits( i ) ); test_edge_coeff( 3, nodeset_from_bits( i ) ); test_edge_coeff( 4, nodeset_from_bits( i ) ); test_edge_coeff( 5, nodeset_from_bits( i ) ); } }
Definition at line 648 of file TetLagrangeShapeTest.cpp.
{ for( unsigned i = 0; i < 0x40; ++i ) { test_face_coeff( 0, nodeset_from_bits( i ) ); test_face_coeff( 1, nodeset_from_bits( i ) ); test_face_coeff( 2, nodeset_from_bits( i ) ); test_face_coeff( 3, nodeset_from_bits( i ) ); } }
void TetLagrangeShapeTest::test_corner_coeff | ( | int | corner, |
NodeSet | nodeset | ||
) | [private] |
Definition at line 493 of file TetLagrangeShapeTest.cpp.
References compare_coefficients(), CPPUNIT_ASSERT, get_coeff(), n, and rst_corner.
{ MsqPrintError err( std::cout ); double expected[10]; get_coeff( nodebits, rst_corner[corner], expected ); double coeff[100]; size_t n = 29, indices[100]; sf.coefficients( Sample( 0, corner ), nodebits, coeff, indices, n, err ); CPPUNIT_ASSERT( !err ); compare_coefficients( coeff, indices, expected, n, corner, nodebits ); }
void TetLagrangeShapeTest::test_corner_derivs | ( | int | corner, |
) | [private] |
Definition at line 553 of file TetLagrangeShapeTest.cpp.
References compare_derivatives(), CPPUNIT_ASSERT, get_derivs(), n, and rst_corner.
{ MsqPrintError err( std::cout ); MsqVector< 3 > expected[10]; get_derivs( nodebits, rst_corner[corner], expected ); MsqVector< 3 > derivs[100]; size_t vertices[100], n = 29; sf.derivatives( Sample( 0, corner ), nodebits, vertices, derivs, n, err ); CPPUNIT_ASSERT( !err ); compare_derivatives( vertices, n, derivs, expected, corner, nodebits ); }
Definition at line 702 of file TetLagrangeShapeTest.cpp.
{ for( unsigned i = 0; i < 0x40; ++i ) { test_mid_derivs( nodeset_from_bits( i ) ); } }
Definition at line 667 of file TetLagrangeShapeTest.cpp.
{ for( unsigned i = 0; i < 0x40; ++i ) { test_corner_derivs( 0, nodeset_from_bits( i ) ); test_corner_derivs( 1, nodeset_from_bits( i ) ); test_corner_derivs( 2, nodeset_from_bits( i ) ); test_corner_derivs( 3, nodeset_from_bits( i ) ); } }
Definition at line 678 of file TetLagrangeShapeTest.cpp.
{ for( unsigned i = 0; i < 0x40; ++i ) { test_edge_derivs( 0, nodeset_from_bits( i ) ); test_edge_derivs( 1, nodeset_from_bits( i ) ); test_edge_derivs( 2, nodeset_from_bits( i ) ); test_edge_derivs( 3, nodeset_from_bits( i ) ); test_edge_derivs( 4, nodeset_from_bits( i ) ); test_edge_derivs( 5, nodeset_from_bits( i ) ); } }
Definition at line 691 of file TetLagrangeShapeTest.cpp.
{ for( unsigned i = 0; i < 0x40; ++i ) { test_face_derivs( 0, nodeset_from_bits( i ) ); test_face_derivs( 1, nodeset_from_bits( i ) ); test_face_derivs( 2, nodeset_from_bits( i ) ); test_face_derivs( 3, nodeset_from_bits( i ) ); } }
void TetLagrangeShapeTest::test_edge_coeff | ( | int | edge, |
) | [private] |
Definition at line 508 of file TetLagrangeShapeTest.cpp.
References compare_coefficients(), CPPUNIT_ASSERT, get_coeff(), n, and rst_edge.
{ MsqPrintError err( std::cout ); double expected[10]; get_coeff( nodebits, rst_edge[edge], expected ); double coeff[100]; size_t n = 29, indices[100]; sf.coefficients( Sample( 1, edge ), nodebits, coeff, indices, n, err ); CPPUNIT_ASSERT( !err ); compare_coefficients( coeff, indices, expected, n, edge + 4, nodebits ); }
void TetLagrangeShapeTest::test_edge_derivs | ( | int | edge, |
) | [private] |
Definition at line 568 of file TetLagrangeShapeTest.cpp.
References compare_derivatives(), CPPUNIT_ASSERT, get_derivs(), n, and rst_edge.
{ MsqPrintError err( std::cout ); MsqVector< 3 > expected[10]; get_derivs( nodebits, rst_edge[edge], expected ); MsqVector< 3 > derivs[100]; size_t vertices[100], n = 29; sf.derivatives( Sample( 1, edge ), nodebits, vertices, derivs, n, err ); CPPUNIT_ASSERT( !err ); compare_derivatives( vertices, n, derivs, expected, edge + 4, nodebits ); }
void TetLagrangeShapeTest::test_face_coeff | ( | int | face, |
) | [private] |
Definition at line 523 of file TetLagrangeShapeTest.cpp.
References compare_coefficients(), CPPUNIT_ASSERT, get_coeff(), n, and rst_face.
{ MsqPrintError err( std::cout ); double expected[10]; get_coeff( nodebits, rst_face[face], expected ); double coeff[100]; size_t n = 29, indices[100]; sf.coefficients( Sample( 2, face ), nodebits, coeff, indices, n, err ); CPPUNIT_ASSERT( !err ); compare_coefficients( coeff, indices, expected, n, face + 10, nodebits ); }
void TetLagrangeShapeTest::test_face_derivs | ( | int | face, |
) | [private] |
Definition at line 583 of file TetLagrangeShapeTest.cpp.
References compare_derivatives(), CPPUNIT_ASSERT, get_derivs(), n, and rst_face.
{ MsqPrintError err( std::cout ); MsqVector< 3 > expected[10]; get_derivs( nodebits, rst_face[face], expected ); MsqVector< 3 > derivs[100]; size_t vertices[100], n = 29; sf.derivatives( Sample( 2, face ), nodebits, vertices, derivs, n, err ); CPPUNIT_ASSERT( !err ); compare_derivatives( vertices, n, derivs, expected, face + 10, nodebits ); }
Definition at line 824 of file TetLagrangeShapeTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, MBMesquite::cbrt(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::det(), MBMesquite::JacobianCalculator::get_Jacobian_3D(), MBMesquite::inverse(), moab::R, MBMesquite::TETRAHEDRON, MBMesquite::transpose(), and MBMesquite::unit_edge_element().
{ MsqError err; MsqMatrix< 3, 3 > J_act, J_exp; sf.ideal( Sample( 3, 0 ), J_act, err ); ASSERT_NO_ERROR( err ); CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, det( J_act ), 1e-6 ); const Vector3D* verts = unit_edge_element( TETRAHEDRON ); CPPUNIT_ASSERT( verts ); JacobianCalculator jc; jc.get_Jacobian_3D( &sf, NodeSet(), Sample( 2, 0 ), verts, 4, J_exp, err ); ASSERT_NO_ERROR( err ); J_exp /= MBMesquite::cbrt( det( J_exp ) ); // Matrices should be a rotation of each other. // First, calculate tentative rotation matrix MsqMatrix< 3, 3 > R = inverse( J_exp ) * J_act; // next check that it is a rotation CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, det( R ), 1e-6 ); // no scaling ASSERT_MATRICES_EQUAL( transpose( R ), inverse( R ), 1e-6 ); // orthogonal }
void TetLagrangeShapeTest::test_invalid_nodebits_coeff | ( | NodeSet | nodeset | ) | [private] |
Definition at line 710 of file TetLagrangeShapeTest.cpp.
References CPPUNIT_ASSERT, and n.
{ MsqError err; double coeff[100]; size_t n, indices[100]; sf.coefficients( Sample( 0, 0 ), bits, coeff, indices, n, err ); CPPUNIT_ASSERT( err ); sf.coefficients( Sample( 0, 1 ), bits, coeff, indices, n, err ); CPPUNIT_ASSERT( err ); sf.coefficients( Sample( 0, 2 ), bits, coeff, indices, n, err ); CPPUNIT_ASSERT( err ); sf.coefficients( Sample( 0, 3 ), bits, coeff, indices, n, err ); CPPUNIT_ASSERT( err ); sf.coefficients( Sample( 1, 0 ), bits, coeff, indices, n, err ); CPPUNIT_ASSERT( err ); sf.coefficients( Sample( 1, 1 ), bits, coeff, indices, n, err ); CPPUNIT_ASSERT( err ); sf.coefficients( Sample( 1, 2 ), bits, coeff, indices, n, err ); CPPUNIT_ASSERT( err ); sf.coefficients( Sample( 1, 3 ), bits, coeff, indices, n, err ); CPPUNIT_ASSERT( err ); sf.coefficients( Sample( 1, 4 ), bits, coeff, indices, n, err ); CPPUNIT_ASSERT( err ); sf.coefficients( Sample( 1, 5 ), bits, coeff, indices, n, err ); CPPUNIT_ASSERT( err ); sf.coefficients( Sample( 2, 0 ), bits, coeff, indices, n, err ); CPPUNIT_ASSERT( err ); sf.coefficients( Sample( 2, 1 ), bits, coeff, indices, n, err ); CPPUNIT_ASSERT( err ); sf.coefficients( Sample( 2, 2 ), bits, coeff, indices, n, err ); CPPUNIT_ASSERT( err ); sf.coefficients( Sample( 2, 3 ), bits, coeff, indices, n, err ); CPPUNIT_ASSERT( err ); sf.coefficients( Sample( 3, 0 ), bits, coeff, indices, n, err ); CPPUNIT_ASSERT( err ); }
void TetLagrangeShapeTest::test_invalid_nodebits_deriv | ( | NodeSet | nodeset | ) | [private] |
Definition at line 751 of file TetLagrangeShapeTest.cpp.
{ MsqError err; size_t verts[100], n; MsqVector< 3 > derivs[100]; sf.derivatives( Sample( 0, 0 ), bits, verts, derivs, n, err ); CPPUNIT_ASSERT( err ); sf.derivatives( Sample( 0, 1 ), bits, verts, derivs, n, err ); CPPUNIT_ASSERT( err ); sf.derivatives( Sample( 0, 2 ), bits, verts, derivs, n, err ); CPPUNIT_ASSERT( err ); sf.derivatives( Sample( 0, 3 ), bits, verts, derivs, n, err ); CPPUNIT_ASSERT( err ); sf.derivatives( Sample( 1, 0 ), bits, verts, derivs, n, err ); CPPUNIT_ASSERT( err ); sf.derivatives( Sample( 1, 1 ), bits, verts, derivs, n, err ); CPPUNIT_ASSERT( err ); sf.derivatives( Sample( 1, 2 ), bits, verts, derivs, n, err ); CPPUNIT_ASSERT( err ); sf.derivatives( Sample( 1, 3 ), bits, verts, derivs, n, err ); CPPUNIT_ASSERT( err ); sf.derivatives( Sample( 1, 4 ), bits, verts, derivs, n, err ); CPPUNIT_ASSERT( err ); sf.derivatives( Sample( 1, 5 ), bits, verts, derivs, n, err ); CPPUNIT_ASSERT( err ); sf.derivatives( Sample( 2, 0 ), bits, verts, derivs, n, err ); CPPUNIT_ASSERT( err ); sf.derivatives( Sample( 2, 1 ), bits, verts, derivs, n, err ); CPPUNIT_ASSERT( err ); sf.derivatives( Sample( 2, 2 ), bits, verts, derivs, n, err ); CPPUNIT_ASSERT( err ); sf.derivatives( Sample( 2, 3 ), bits, verts, derivs, n, err ); CPPUNIT_ASSERT( err ); sf.derivatives( Sample( 3, 0 ), bits, verts, derivs, n, err ); CPPUNIT_ASSERT( err ); }
void TetLagrangeShapeTest::test_mid_coeff | ( | NodeSet | nodebits | ) | [private] |
Definition at line 538 of file TetLagrangeShapeTest.cpp.
References compare_coefficients(), CPPUNIT_ASSERT, get_coeff(), n, and rst_mid.
{ MsqPrintError err( std::cout ); double expected[10]; get_coeff( nodebits, rst_mid, expected ); double coeff[100]; size_t n = 29, indices[100]; sf.coefficients( Sample( 3, 0 ), nodebits, coeff, indices, n, err ); CPPUNIT_ASSERT( !err ); compare_coefficients( coeff, indices, expected, n, 14, nodebits ); }
void TetLagrangeShapeTest::test_mid_derivs | ( | NodeSet | nodeset | ) | [private] |
Definition at line 598 of file TetLagrangeShapeTest.cpp.
References compare_derivatives(), CPPUNIT_ASSERT, get_derivs(), n, and rst_mid.
{ MsqPrintError err( std::cout ); MsqVector< 3 > expected[10]; get_derivs( nodebits, rst_mid, expected ); MsqVector< 3 > derivs[100]; size_t vertices[100], n = 29; sf.derivatives( Sample( 3, 0 ), nodebits, vertices, derivs, n, err ); CPPUNIT_ASSERT( !err ); compare_derivatives( vertices, n, derivs, expected, 14, nodebits ); }
Definition at line 792 of file TetLagrangeShapeTest.cpp.
References MBMesquite::NodeSet::set_mid_region_node().
{ NodeSet nodeset; nodeset.set_mid_region_node(); test_invalid_nodebits_coeff( nodeset ); }
Definition at line 799 of file TetLagrangeShapeTest.cpp.
{ NodeSet nodeset; nodeset.set_mid_region_node(); test_invalid_nodebits_deriv( nodeset ); }
Definition at line 806 of file TetLagrangeShapeTest.cpp.
References MBMesquite::NodeSet::set_mid_face_node().
{ NodeSet nodeset1, nodeset2; nodeset1.set_mid_face_node( 0 ); test_invalid_nodebits_coeff( nodeset1 ); nodeset2.set_mid_face_node( 2 ); test_invalid_nodebits_coeff( nodeset2 ); }
Definition at line 815 of file TetLagrangeShapeTest.cpp.
{ NodeSet nodeset1, nodeset2; nodeset1.set_mid_face_node( 0 ); test_invalid_nodebits_deriv( nodeset1 ); nodeset2.set_mid_face_node( 2 ); test_invalid_nodebits_deriv( nodeset2 ); }
TetLagrangeShape TetLagrangeShapeTest::sf [private] |
Definition at line 110 of file TetLagrangeShapeTest.cpp.
