MOAB: Mesh Oriented datABase
(version 5.2.1)
#include "ShapeImprover.hpp"
#include "MeshImpl.hpp"
#include "CLArgs.hpp"
#include "MsqError.hpp"
#include "domain.hpp"
#include <iostream>
Functions | |
int | main (int argc, char *argv[]) |
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 12 of file shape-improve.cpp.
References add_domain_args(), CLArgs::add_required_arg(), args, CLArgs::double_flag(), input_file, mesh, CLArgs::parse_options(), CLArgs::print_usage(), process_domain_args(), MBMesquite::MeshImpl::read_vtk(), MBMesquite::IQInterface::run_instructions(), CLArgs::ArgIBase::seen(), MBMesquite::ShapeImprover::set_cpu_time_limit(), MBMesquite::ShapeImprover::set_vertex_movement_limit_factor(), CLArgs::DoubleRangeArg::value(), and MBMesquite::MeshImpl::write_vtk().
{ const double zero = 0.0, one = 1.0; double default_cpu_time = 0.0; CLArgs::DoubleRangeArg movement_beta( &zero, &one ), cpu_time( default_cpu_time, &zero, 0 ); CLArgs args( "msqshape", "Run Shape Improvement smoother for input mesh.", "Read VTK file, smooth, and re-write file." ); args.double_flag( 'b', "Vtx Movement Beta", "fraction of mean edge length to use as termination criterion on vertex movement", &movement_beta ); args.double_flag( 't', "Cpu Seconds", "time-out", &cpu_time ); add_domain_args( args ); args.add_required_arg( "input_file" ); args.add_required_arg( "output_file" ); std::vector< std::string > files; if( !args.parse_options( argc, argv, files, std::cerr ) ) { args.print_usage( std::cerr ); exit( 1 ); } std::string input_file = files[0]; std::string output_file = files[1]; MsqError err; MeshImpl mesh; mesh.read_vtk( input_file.c_str(), err ); if( err ) { std::cerr << "ERROR READING FILE: " << input_file << std::endl << err << std::endl; return 2; } MeshDomain* domain = process_domain_args( &mesh ); ShapeImprover smoother; if( movement_beta.seen() ) smoother.set_vertex_movement_limit_factor( movement_beta.value() ); if( cpu_time.seen() ) smoother.set_cpu_time_limit( cpu_time.value() ); MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, domain ); smoother.run_instructions( &mesh_and_domain, err ); if( err ) { std::cerr << err << std::endl; return 3; } mesh.write_vtk( output_file.c_str(), err ); if( err ) { std::cerr << "ERROR WRITING FILE: " << output_file << std::endl << err << std::endl; return 2; } return 0; }
