MOAB: Mesh Oriented datABase
(version 5.2.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2009 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2009) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file main.cpp 00028 * \brief 00029 * \author Jason Kraftcheck 00030 */ 00031 #include "TestUtil.hpp" 00032 00033 #include <iostream> 00034 using std::cout; 00035 using std::endl; 00036 #include <cstdlib> 00037 #include <cstdio> 00038 #include <vector> 00039 #include <algorithm> 00040 00041 #include "Mesquite.hpp" 00042 #include "MsqError.hpp" 00043 #include "MeshImpl.hpp" 00044 #include "SizeAdaptShapeWrapper.hpp" 00045 #include "SphericalDomain.hpp" 00046 #include "MsqVertex.hpp" 00047 00048 using namespace MBMesquite; 00049 00050 std::string DEFAULT_INPUT = TestDir + "/2D/vtk/quads/untangled/bias-sphere-quads.vtk"; 00051 00052 void help( const char* argv0 ) 00053 { 00054 std::cerr << "Usage: " << argv0 << " [<output_file>]" << std::endl 00055 << " Input file is always: " << DEFAULT_INPUT << std::endl 00056 << " default is no output file" << std::endl; 00057 exit( 1 ); 00058 } 00059 00060 typedef std::vector< Mesh::ElementHandle > elem_vec_t; 00061 00062 // Assume mesh is on a sphere of radius 10 with an axis equal to Z. 00063 // Return elements near poles and elements near equator. 00064 void find_z10_extreme_elements( Mesh& mesh, elem_vec_t& polar_elems, elem_vec_t& equatorial_elems, MsqError& err ); 00065 00066 // Get areas of quads and tris 00067 void elem_areas( Mesh& mesh, const elem_vec_t& elems, double& min, double& mean, double& max, MsqError& err ); 00068 00069 int main( int argc, char* argv[] ) 00070 { 00071 const char* input_file = DEFAULT_INPUT.c_str(); 00072 const char* output_file = NULL; 00073 switch( argc ) 00074 { 00075 default: 00076 help( argv[0] ); 00077 case 2: 00078 if( !strcmp( argv[1], "-h" ) ) help( argv[0] ); 00079 output_file = argv[1]; 00080 case 1:; 00081 } 00082 00083 /* Read a VTK Mesh file */ 00084 MsqPrintError err( cout ); 00085 MBMesquite::MeshImpl mesh; 00086 mesh.read_vtk( input_file, err ); 00087 if( err ) 00088 { 00089 std::cerr << input_file << ": file read failed" << endl; 00090 return 1; 00091 } 00092 00093 elem_vec_t polar, equatorial; 00094 find_z10_extreme_elements( mesh, polar, equatorial, err ); 00095 if( err ) return 1; 00096 00097 double eq_min, eq_max, eq_mean, pol_min, pol_max, pol_mean; 00098 elem_areas( mesh, polar, pol_min, pol_mean, pol_max, err ); 00099 if( err ) return 1; 00100 elem_areas( mesh, equatorial, eq_min, eq_mean, eq_max, err ); 00101 if( err ) return 1; 00102 00103 /* Run optimizer */ 00104 SphericalDomain geom( Vector3D( 0, 0, 0 ), 10.0 ); 00105 SizeAdaptShapeWrapper smoother( 1e-2 ); 00106 MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &geom ); 00107 smoother.run_instructions( &mesh_and_domain, err ); 00108 if( err ) return 1; 00109 00110 if( output_file ) 00111 { 00112 mesh.write_vtk( output_file, err ); 00113 if( err ) 00114 { 00115 std::cerr << output_file << ": file write failed" << endl; 00116 return 1; 00117 } 00118 else 00119 { 00120 std::cout << "Wrote file: " << output_file << endl; 00121 } 00122 } 00123 00124 double eq2_min, eq2_max, eq2_mean, pol2_min, pol2_max, pol2_mean; 00125 elem_areas( mesh, polar, pol2_min, pol2_mean, pol2_max, err ); 00126 if( err ) return 1; 00127 elem_areas( mesh, equatorial, eq2_min, eq2_mean, eq2_max, err ); 00128 if( err ) return 1; 00129 00130 double eq_min_pct = 100 * fabs( eq_min - eq2_min ) / eq_min; 00131 double eq_max_pct = 100 * fabs( eq_max - eq2_max ) / eq_max; 00132 double eq_mean_pct = 100 * fabs( eq_mean - eq2_mean ) / eq_mean; 00133 double pol_min_pct = 100 * fabs( pol_min - pol2_min ) / pol_min; 00134 double pol_max_pct = 100 * fabs( pol_max - pol2_max ) / pol_max; 00135 double pol_mean_pct = 100 * fabs( pol_mean - pol2_mean ) / pol_mean; 00136 00137 std::printf( "\n\n" ); 00138 std::printf( "AREAS: Initial Final Difference Change\n" ); 00139 std::printf( "Polar:\n" ); 00140 std::printf( " Minimum: %10f %10f %10f %10f%%\n", pol_min, pol2_min, fabs( pol_min - pol2_min ), pol_min_pct ); 00141 std::printf( " Average: %10f %10f %10f %10f%%\n", pol_mean, pol2_mean, fabs( pol_mean - pol2_mean ), 00142 pol_mean_pct ); 00143 std::printf( " Maximum: %10f %10f %10f %10f%%\n", pol_max, pol2_max, fabs( pol_max - pol2_max ), pol_max_pct ); 00144 std::printf( "Equatorial:\n" ); 00145 std::printf( " Minimum: %10f %10f %10f %10f%%\n", eq_min, eq2_min, fabs( eq_min - eq2_min ), eq_min_pct ); 00146 std::printf( " Average: %10f %10f %10f %10f%%\n", eq_mean, eq2_mean, fabs( eq_mean - eq2_mean ), eq_mean_pct ); 00147 std::printf( " Maximum: %10f %10f %10f %10f%%\n", eq_max, eq2_max, fabs( eq_max - eq2_max ), eq_max_pct ); 00148 00149 bool success = pol_min_pct < 6.0 && pol_max_pct < 6.5 && eq_min_pct < 25.0 && eq_max_pct < 6.5; 00150 return !success; 00151 } 00152 00153 void find_z10_extreme_elements( Mesh& mesh, elem_vec_t& polar_elems, elem_vec_t& equatorial_elems, MsqError& err ) 00154 { 00155 elem_vec_t elems; 00156 mesh.get_all_elements( elems, err );MSQ_ERRRTN( err ); 00157 00158 std::vector< Mesh::VertexHandle > verts; 00159 std::vector< MsqVertex > coords; 00160 std::vector< size_t > junk; 00161 for( elem_vec_t::iterator i = elems.begin(); i != elems.end(); ++i ) 00162 { 00163 verts.clear(); 00164 junk.clear(); 00165 mesh.elements_get_attached_vertices( &*i, 1, verts, junk, err );MSQ_ERRRTN( err ); 00166 coords.resize( verts.size() ); 00167 mesh.vertices_get_coordinates( arrptr( verts ), arrptr( coords ), verts.size(), err );MSQ_ERRRTN( err ); 00168 00169 for( std::vector< MsqVertex >::iterator j = coords.begin(); j != coords.end(); ++j ) 00170 { 00171 double z = ( *j )[2]; 00172 if( fabs( z ) < 1e-6 ) 00173 { 00174 equatorial_elems.push_back( *i ); 00175 break; 00176 } 00177 else if( fabs( z ) - 10 < 1e-6 ) 00178 { 00179 polar_elems.push_back( *i ); 00180 break; 00181 } 00182 } 00183 } 00184 } 00185 00186 void elem_areas( Mesh& mesh, const elem_vec_t& elems, double& min, double& mean, double& max, MsqError& err ) 00187 { 00188 min = HUGE_VAL; 00189 max = -1; 00190 mean = 0.0; 00191 00192 std::vector< EntityTopology > types( elems.size() ); 00193 mesh.elements_get_topologies( arrptr( elems ), arrptr( types ), elems.size(), err );MSQ_ERRRTN( err ); 00194 00195 std::vector< Mesh::VertexHandle > verts; 00196 std::vector< MsqVertex > coords; 00197 std::vector< size_t > junk; 00198 for( size_t i = 0; i < elems.size(); ++i ) 00199 { 00200 verts.clear(); 00201 junk.clear(); 00202 mesh.elements_get_attached_vertices( &elems[i], 1, verts, junk, err );MSQ_ERRRTN( err ); 00203 coords.resize( verts.size() ); 00204 mesh.vertices_get_coordinates( arrptr( verts ), arrptr( coords ), verts.size(), err );MSQ_ERRRTN( err ); 00205 00206 Vector3D v1, v2; 00207 double area; 00208 if( types[i] == TRIANGLE ) 00209 { 00210 assert( coords.size() == 3 ); 00211 v1 = coords[1] - coords[0]; 00212 v2 = coords[2] - coords[0]; 00213 area = 0.5 * ( v1 * v2 ).length(); 00214 } 00215 else if( types[i] == QUADRILATERAL ) 00216 { 00217 assert( coords.size() == 4 ); 00218 v1 = coords[0] + coords[1] - coords[2] - coords[3]; 00219 v2 = coords[0] + coords[3] - coords[1] - coords[2]; 00220 area = 0.25 * ( v1 * v2 ).length(); 00221 } 00222 else 00223 { 00224 MSQ_SETERR( err ) 00225 ( "Input file contains volume elements", MsqError::UNSUPPORTED_ELEMENT ); 00226 return; 00227 } 00228 00229 if( min > area ) min = area; 00230 if( max < area ) max = area; 00231 mean += area; 00232 } 00233 00234 mean /= elems.size(); 00235 }
