MOAB: Mesh Oriented datABase
(version 5.2.1)
#include <iostream>
#include <sstream>
#include <stdlib.h>
#include "Mesquite.hpp"
#include "MeshImpl.hpp"
#include "MsqError.hpp"
#include "InstructionQueue.hpp"
#include "TerminationCriterion.hpp"
#include "QualityAssessor.hpp"
#include "PlanarDomain.hpp"
#include "IdealWeightInverseMeanRatio.hpp"
#include "ElementPMeanP.hpp"
#include "TInverseMeanRatio.hpp"
#include "TQualityMetric.hpp"
#include "TOffset.hpp"
#include "IdealShapeTarget.hpp"
#include "PMeanPTemplate.hpp"
#include "SteepestDescent.hpp"
#include "ConjugateGradient.hpp"
#include "QuasiNewton.hpp"
#include "MeshWriter.hpp"
#include "MsqTimer.hpp"
#include "TestUtil.hpp"
Classes | |
class | NumericQM |
class | CompareMetric |
Enumerations | |
enum | Solver { STEEP_DESCENT, CONJ_GRAD, QUASI_NEWT } |
Functions | |
void | usage (const char *argv0=0, bool err=true) |
double | run (QualityMetric *metric, Solver solver, const char *input_file, double &seconds_out, int &iterations_out) |
int | main (int argc, char *argv[]) |
Variables | |
std::string | DEFAULT_INPUT = "/2D/vtk/tris/untangled/equil_tri2.vtk" |
const char * | vtk_file = 0 |
const char * | eps_file = 0 |
const char * | gpt_file = 0 |
const char * | plot_file = 0 |
enum Solver |
Definition at line 96 of file idft_time_test.cpp.
{ STEEP_DESCENT, CONJ_GRAD, QUASI_NEWT };
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 187 of file idft_time_test.cpp.
References CONJ_GRAD, DEFAULT_INPUT, eps_file, gpt_file, input_file, plot_file, QUASI_NEWT, run(), STEEP_DESCENT, usage, and vtk_file.
{ Solver solver = STEEP_DESCENT; bool do_non_target_metric = false; bool do_new_target_metric = false; bool do_new_target_average = false; bool do_new_target_numeric = false; bool do_compare_metric = false; const char* input_file = DEFAULT_INPUT.c_str(); bool no_more_flags = false; std::list< const char** > exp_list; for( int i = 1; i < argc; ++i ) { if( argv[i][0] == '-' && !no_more_flags ) { for( int k = 1; argv[i][k]; ++k ) { switch( argv[i][k] ) { case 'n': solver = STEEP_DESCENT; break; case 'c': solver = CONJ_GRAD; break; case 'q': solver = QUASI_NEWT; break; case 'e': do_non_target_metric = true; break; case 't': do_new_target_metric = true; break; case 'a': do_new_target_average = true; break; case 'N': do_new_target_numeric = true; break; case 'C': do_compare_metric = true; break; case 'v': exp_list.push_back( &vtk_file ); break; case 'g': exp_list.push_back( &gpt_file ); break; case 'p': exp_list.push_back( &eps_file ); break; case 'P': exp_list.push_back( &plot_file ); break; case 'h': usage( argv[0], false ); return 0; case '-': no_more_flags = true; break; default: cerr << "Invalid flag: '" << argv[i][k] << "'" << endl; usage( argv[0] ); } } } else if( !exp_list.empty() ) { const char** ptr = exp_list.front(); exp_list.pop_front(); *ptr = argv[i]; } else { if( !DEFAULT_INPUT.compare( input_file ) ) { cerr << "Unexpected argument: \"" << argv[i] << '"' << endl; usage( argv[0] ); } input_file = argv[i]; } } int count = 0; if( do_non_target_metric ) ++count; if( do_new_target_metric ) ++count; if( do_new_target_average ) ++count; if( do_new_target_numeric ) ++count; if( do_compare_metric ) ++count; if( !count ) { do_compare_metric = true; count = 1; } if( ( vtk_file || gpt_file || eps_file ) && count != 1 ) { cerr << "Error: Cannot write output file if running multiple tests" << endl; return 2; } IdealWeightInverseMeanRatio non_target_metric; IdealShapeTarget new_target; TInverseMeanRatio tmp; TOffset tmp_off( 1.0, &tmp ); // target metrics are zero-based TQualityMetric new_target_metric( &new_target, &tmp_off ); ElementPMeanP new_target_average( 1.0, &new_target_metric ); NumericQM new_target_numeric( &new_target_metric ); CompareMetric comp_metric( &non_target_metric, &new_target_average, true ); std::ostringstream os; double secs, qual; if( do_non_target_metric ) { qual = run( &non_target_metric, solver, input_file, secs, count ); os << "IdealWeightInverseMeanRatio: " << qual << " after " << count << " iterations in " << secs << " seconds" << endl; } if( do_new_target_metric ) { qual = run( &new_target_metric, solver, input_file, secs, count ); os << "TQualityMetric : " << qual << " after " << count << " iterations in " << secs << " seconds" << endl; } if( do_new_target_average ) { qual = run( &new_target_average, solver, input_file, secs, count ); os << "ElementPMeanP : " << qual << " after " << count << " iterations in " << secs << " seconds" << endl; } if( do_new_target_numeric ) { qual = run( &new_target_numeric, solver, input_file, secs, count ); os << "TQualityMetric (FD) : " << qual << " after " << count << " iterations in " << secs << " seconds" << endl; } if( do_compare_metric ) { qual = run( &comp_metric, solver, input_file, secs, count ); os << "Metric comparison : " << qual << " after " << count << " iterations in " << secs << " seconds" << endl; } cout << endl << os.str() << endl; return 0; }
double run | ( | QualityMetric * | metric, |
Solver | solver, | ||
const char * | input_file, | ||
double & | seconds_out, | ||
int & | iterations_out | ||
Definition at line 337 of file idft_time_test.cpp.
References MBMesquite::TerminationCriterion::add_absolute_vertex_movement(), MBMesquite::TerminationCriterion::add_iteration_limit(), MBMesquite::QualityAssessor::add_quality_assessment(), MBMesquite::InstructionQueue::add_quality_assessor(), MBMesquite::arrptr(), CONJ_GRAD, eps_file, MBMesquite::MeshImpl::get_all_vertices(), MBMesquite::QualityAssessor::Assessor::get_average(), MBMesquite::TerminationCriterion::get_iteration_count(), MBMesquite::QualityAssessor::get_results(), gpt_file, MBMesquite::inner(), mesh, MBMesquite::outer(), plot_file, QUASI_NEWT, MBMesquite::MeshImpl::read_vtk(), MBMesquite::IQInterface::run_instructions(), MBMesquite::QualityImprover::set_inner_termination_criterion(), MBMesquite::InstructionQueue::set_master_quality_improver(), MBMesquite::QualityImprover::set_outer_termination_criterion(), MBMesquite::Timer::since_birth(), size, STEEP_DESCENT, MBMesquite::MeshImpl::vertices_get_coordinates(), vtk_file, MBMesquite::MeshWriter::write_eps(), MBMesquite::MeshWriter::write_gnuplot(), MBMesquite::TerminationCriterion::write_iterations(), MBMesquite::MeshWriter::write_vtk(), MBMesquite::PlanarDomain::XY, MBMesquite::PlanarDomain::XZ, and MBMesquite::PlanarDomain::YZ.
Referenced by main(), and mb_skin_adjacent_surf_patches().
{ MsqPrintError err( cerr ); IdealWeightInverseMeanRatio qa_metric; TerminationCriterion inner, outer; outer.add_iteration_limit( 1 ); inner.add_absolute_vertex_movement( 1e-4 ); inner.add_iteration_limit( 100 ); PMeanPTemplate of( 1.0, metric ); QualityAssessor qa( &qa_metric ); qa.add_quality_assessment( metric ); InstructionQueue q; SteepestDescent steep( &of ); QuasiNewton quasi( &of ); ConjugateGradient conj( &of ); VertexMover* solver = 0; switch( solver_type ) { case STEEP_DESCENT: solver = &steep; break; case QUASI_NEWT: solver = &quasi; break; case CONJ_GRAD: solver = &conj; break; } q.set_master_quality_improver( solver, err ); q.add_quality_assessor( &qa, err ); solver->set_inner_termination_criterion( &inner ); solver->set_outer_termination_criterion( &outer ); if( plot_file ) inner.write_iterations( plot_file, err ); MeshImpl mesh; mesh.read_vtk( input_file, err ); if( err ) { cerr << "Failed to read input file: \"" << input_file << '"' << endl; exit( 1 ); } std::vector< Mesh::VertexHandle > handles; mesh.get_all_vertices( handles, err ); if( handles.empty() ) { cerr << "no veritces in mesh" << endl; exit( 1 ); } std::vector< MsqVertex > coords( handles.size() ); mesh.vertices_get_coordinates( arrptr( handles ), arrptr( coords ), handles.size(), err ); Vector3D min( HUGE_VAL ), max( -HUGE_VAL ); for( size_t i = 0; i < coords.size(); ++i ) { for( int j = 0; j < 3; ++j ) { if( coords[i][j] < min[j] ) min[j] = coords[i][j]; if( coords[i][j] > max[j] ) max[j] = coords[i][j]; } } Vector3D size = max - min; PlanarDomain* domain = 0; if( size[0] < 1e-4 ) domain = new PlanarDomain( PlanarDomain::YZ, min[0] ); else if( size[1] < 1e-4 ) domain = new PlanarDomain( PlanarDomain::XZ, min[1] ); else if( size[2] < 1e-4 ) domain = new PlanarDomain( PlanarDomain::XY, min[2] ); Timer timer; MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, domain ); q.run_instructions( &mesh_and_domain, err ); seconds_out = timer.since_birth(); if( err ) { cerr << "Optimization failed." << endl << err << endl; abort(); } if( vtk_file ) { MeshWriter::write_vtk( &mesh, vtk_file, err ); if( err ) cerr << vtk_file << ": failed to write file." << endl; } if( gpt_file ) { MeshWriter::write_gnuplot( &mesh, gpt_file, err ); if( err ) cerr << gpt_file << ": failed to write file." << endl; } if( eps_file ) { PlanarDomain xy( PlanarDomain::XY ); MeshWriter::Projection proj( domain ? domain : &xy ); MeshWriter::write_eps( &mesh, eps_file, proj, err ); if( err ) cerr << eps_file << ": failed to write file." << endl; } delete domain; iterations_out = inner.get_iteration_count(); const QualityAssessor::Assessor* a = qa.get_results( &qa_metric ); return a->get_average(); }
void usage | ( | const char * | argv0 = 0 , |
bool | err = true |
Definition at line 64 of file idft_time_test.cpp.
References argv0, and DEFAULT_INPUT.
{ std::ostream& s = err ? cerr : cout; const char* defname = "main"; if( !argv0 ) argv0 = defname; s << "Usage: " << defname << " [-n|-c|-q] [-e] [-t] [-a] [-N] [{-v|-g|-p} <output_file>] [<input_file>]" << endl << " " << defname << " -h" << std::endl; if( err ) exit( 1 ); s << " -n : Use SteepestDescent solver (default)" << endl << " -c : Use ConjugateGradient solver" << endl << " -q : Use QuasiNewton solver" << endl << " -e : Test IdealWeightInverseMeanRatio metric" << endl << " -t : Test InverseMeanRatio3D target metric" << endl << " -a : Test ElementPMeanP(InverseMeanRatio3D)" << endl << " -N : Test InverseMeanRatio3D with finite difference derivatives" << endl << " -C : Compare InverseMeanRatio3D and IdealWeightInverseMeanRatio" << endl << " -v : Write output mesh to specified VTK file" << endl << " -g : Write output mesh to specified GnuPlot file" << endl << " -p : Write output mesh to specified EPS file" << endl << " -P : Write solver plot data to specified file." << endl << "Default is all metrics if non specified." << endl << "Default input file: " << DEFAULT_INPUT << endl; }
std::string DEFAULT_INPUT = "/2D/vtk/tris/untangled/equil_tri2.vtk" |
Definition at line 61 of file idft_time_test.cpp.
const char* eps_file = 0 |
Definition at line 92 of file idft_time_test.cpp.
const char* gpt_file = 0 |
Definition at line 93 of file idft_time_test.cpp.
const char* plot_file = 0 |
Definition at line 94 of file idft_time_test.cpp.
const char* vtk_file = 0 |
Definition at line 91 of file idft_time_test.cpp.
Referenced by main(), run(), QualityAssessorTest::setUp(), MeshImplTest::skin_mesh_2D(), MeshImplTest::skin_mesh_3D(), MeshImplTest::skin_mesh_higher_order(), and MeshImplTest::skin_mesh_mixed().
