MOAB: Mesh Oriented datABase
(version 5.2.1)
#include "TestUtil.hpp"
#include <iostream>
#include <cstdlib>
#include <vector>
#include <algorithm>
#include "Mesquite.hpp"
#include "MsqError.hpp"
#include "MeshImpl.hpp"
#include "ViscousCFDTetShapeWrapper.hpp"
#include "MsqVertex.hpp"
Functions | |
void | help (const char *argv0) |
void | tet_dihedral_angle_ratios (Mesh &mesh, double &ratio_min, double &ratio_avg, double &ratio_max, MsqError &err) |
int | main (int argc, char *argv[]) |
static double | da (double dot) |
Variables | |
std::string | DEFAULT_INPUT = "/3D/vtk/tets/untangled/flat-tet-sphere.vtk" |
static double da | ( | double | dot | ) | [inline, static] |
Definition at line 143 of file viscous_cfd.cpp.
Referenced by v_quad_max_aspect_frobenius(), v_quad_med_aspect_frobenius(), and v_quad_radius_ratio().
{ return 180 - ( 180 / M_PI ) * acos( dot ); }
void help | ( | const char * | argv0 | ) |
Definition at line 65 of file viscous_cfd.cpp.
References DEFAULT_INPUT.
{ std::cerr << "Usage: " << argv0 << " [<input_file>] [<output_file>]" << std::endl << " default input file is: " << DEFAULT_INPUT << std::endl << " defualt is no output file" << std::endl << " Warning: input mesh is assumed to lie in Z=5 plane" << std::endl; exit( 1 ); }
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 78 of file viscous_cfd.cpp.
References DEFAULT_INPUT, help(), input_file, mesh, MBMesquite::MeshImpl::read_vtk(), MBMesquite::IQInterface::run_instructions(), tet_dihedral_angle_ratios(), and MBMesquite::MeshImpl::write_vtk().
{ const char* input_file = DEFAULT_INPUT.c_str(); const char* output_file = NULL; switch( argc ) { default: help( argv[0] ); case 3: if( !strcmp( argv[2], "-h" ) ) help( argv[0] ); output_file = argv[2]; case 2: if( !strcmp( argv[1], "-h" ) ) help( argv[0] ); input_file = argv[1]; case 1:; } /* Read a VTK Mesh file */ MsqPrintError err( cout ); MBMesquite::MeshImpl mesh; mesh.read_vtk( input_file, err ); if( err ) { std::cerr << input_file << ": file read failed" << endl; return 1; } double min_ini, avg_ini, max_ini; tet_dihedral_angle_ratios( mesh, min_ini, avg_ini, max_ini, err ); /* Run optimizer */ ViscousCFDTetShapeWrapper smoother( 1e-2 ); smoother.run_instructions( &mesh, err ); if( err ) return 1; double min_fin, avg_fin, max_fin; tet_dihedral_angle_ratios( mesh, min_fin, avg_fin, max_fin, err ); cout << "\tMinimum \tAverage \tMaximum " << endl << "Init\t" << min_ini << '\t' << avg_ini << '\t' << max_ini << endl << "Fini\t" << min_fin << '\t' << avg_fin << '\t' << max_fin << endl; if( output_file ) { mesh.write_vtk( output_file, err ); if( err ) { std::cerr << output_file << ": file write failed" << endl; return 1; } else { std::cout << "Wrote file: " << output_file << endl; } } if( min_ini > min_fin || avg_ini > avg_fin || max_ini > max_fin ) { std::cerr << "Dihedral handle ratio decreased" << endl; return 1; } return 0; }
void tet_dihedral_angle_ratios | ( | Mesh & | mesh, |
double & | ratio_min, | ||
double & | ratio_avg, | ||
double & | ratio_max, | ||
MsqError & | err | ||
Definition at line 148 of file viscous_cfd.cpp.
References MBMesquite::arrptr(), MBMesquite::da(), MBMesquite::Mesh::elements_get_attached_vertices(), MBMesquite::Mesh::elements_get_topologies(), MBMesquite::Mesh::get_all_elements(), MBMesquite::TETRAHEDRON, and MBMesquite::Mesh::vertices_get_coordinates().
Referenced by main().
{ std::vector< Mesh::VertexHandle > verts; std::vector< Mesh::ElementHandle > tets; std::vector< MsqVertex > coords( 4 ); std::vector< size_t > junk; mesh.get_all_elements( tets, err ); ratio_min = HUGE_VAL; ratio_max = -HUGE_VAL; ratio_avg = 0; size_t count = 0; for( std::vector< Mesh::ElementHandle >::iterator i = tets.begin(); i != tets.end(); ++i ) { Mesh::ElementHandle e = *i; EntityTopology type; mesh.elements_get_topologies( &e, &type, 1, err ); assert( !err ); if( type != TETRAHEDRON ) continue; verts.clear(); mesh.elements_get_attached_vertices( &e, 1, verts, junk, err ); assert( !err ); assert( verts.size() == 4 ); mesh.vertices_get_coordinates( arrptr( verts ), arrptr( coords ), 4, err ); assert( !err ); Vector3D v01 = coords[1] - coords[0]; Vector3D v02 = coords[2] - coords[0]; Vector3D v31 = coords[1] - coords[3]; Vector3D v32 = coords[2] - coords[3]; Vector3D n012 = ~( v02 * v01 ); Vector3D n013 = ~( v31 * v01 ); Vector3D n023 = ~( v02 * v32 ); Vector3D n123 = ~( v31 * v32 ); double ds[] = { da( n012 % n013 ), da( n012 % n123 ), da( n012 % n023 ), da( n013 % n023 ), da( n013 % n123 ), da( n023 % n123 ) }; double ratio = *std::min_element( ds, ds + 6 ) / *std::max_element( ds, ds + 6 ); if( ratio < ratio_min ) ratio_min = ratio; if( ratio > ratio_max ) ratio_max = ratio; ratio_avg += ratio; count++; } if( count ) ratio_avg /= count; }
std::string DEFAULT_INPUT = "/3D/vtk/tets/untangled/flat-tet-sphere.vtk" |
Definition at line 63 of file viscous_cfd.cpp.
