MOAB: Mesh Oriented datABase
(version 5.2.1)
#include <iostream>
#include <cstdlib>
#include "Mesquite.hpp"
#include "MsqError.hpp"
#include "MeshImpl.hpp"
#include "Vector3D.hpp"
#include "InstructionQueue.hpp"
#include "PatchData.hpp"
#include "TerminationCriterion.hpp"
#include "QualityAssessor.hpp"
#include "PlanarDomain.hpp"
#include "MsqTimer.hpp"
#include "LInfTemplate.hpp"
#include "EdgeLengthQualityMetric.hpp"
#include "LaplaceWrapper.hpp"
#include "UntangleWrapper.hpp"
#include "ShapeImprover.hpp"
#include "SizeAdaptShapeWrapper.hpp"
#include "SphericalDomain.hpp"
#include "PaverMinEdgeLengthWrapper.hpp"
#include "DeformingDomainWrapper.hpp"
#include "MeshDomain1D.hpp"
#include "TestUtil.hpp"
Defines | |
#define | CHKMESH(COND, ERR) |
Typedefs | |
typedef std::vector < Mesh::ElementHandle > | elem_vec_t |
Functions | |
void | help (const char *) |
void | find_z10_extreme_elements (Mesh &mesh, elem_vec_t &polar_elems, elem_vec_t &equatorial_elems, MsqError &err) |
void | elem_areas (Mesh &mesh, const elem_vec_t &elems, double &min, double &mean, double &max, MsqError &err) |
void | classify_boundary (Mesh *mesh, Mesh::VertexHandle corners_out[4], std::vector< Mesh::VertexHandle > curves_out[4], MsqError &err) |
int | main (int, char *[]) |
Variables | |
std::string | shape_improv_file_name_1 = "/3D/vtk/hexes/untangled/1000hex-block-internal-bias.vtk" |
std::string | shape_improv_file_name_2 = "/3D/vtk/tets/untangled/tire.vtk" |
std::string | laplacian_file_name_1 = "/2D/vtk/quads/untangled/square_quad_10_rand.vtk" |
std::string | laplacian_file_name_2 = "/2D/vtk//quads/untangled/shashkov_quad.vtk" |
std::string | untangle_file_name_1 = "/2D/vtk/quads/tangled/tangled_horse1.vtk" |
std::string | untangle_file_name_2 = "/2D/vtk/quads/untangled//shest_grid32.vtk" |
std::string | size_adapt_shape_file_name_1 = "/2D/vtk/quads/untangled/bias-sphere-quads.vtk" |
std::string | min_edge_length_file_name_1 = "/2D/vtk/quads/untangled/quads_4by2_bad.vtk" |
std::string | min_edge_length_file_name_2 = "/2D/vtk/quads/untangled/shashkov_quad.vtk" |
std::string | deforming_domain_file_name_1 = "/3D/vtk/hexes/untangled/sph-10-zsquare.vtk" |
const double | Z = 7.0 |
const double | HD = 4.5 |
#define CHKMESH | ( | COND, | |
ERR | |||
do \ { \ if( !( COND ) ) \ { \ MSQ_SETERR( err )( "Unexpected mesh topology", MsqError::INVALID_MESH ); \ return; \ } \ } while( false )
Definition at line 702 of file benchmark_tests.cpp.
Referenced by classify_boundary().
typedef std::vector< Mesh::ElementHandle > elem_vec_t |
Definition at line 94 of file benchmark_tests.cpp.
void classify_boundary | ( | Mesh * | mesh, |
Mesh::VertexHandle | corners_out[4], | ||
std::vector< Mesh::VertexHandle > | curves_out[4], | ||
MsqError & | err | ||
Definition at line 712 of file benchmark_tests.cpp.
References CHKMESH, MBMesquite::Mesh::elements_get_attached_vertices(), MBMesquite::Mesh::get_all_vertices(), MSQ_ERRRTN, MBMesquite::Mesh::vertices_get_attached_elements(), and MBMesquite::Mesh::vertices_get_coordinates().
Referenced by main().
{ std::vector< Mesh::VertexHandle > verts; mesh->get_all_vertices( verts, err );MSQ_ERRRTN( err ); // Find the corner vertex that has negative X and Y coordinates Mesh::VertexHandle start; bool have_start = false; std::vector< Mesh::ElementHandle > elems; std::vector< size_t > offsets; for( size_t i = 0; i < verts.size(); ++i ) { elems.clear(); offsets.clear(); mesh->vertices_get_attached_elements( &verts[i], 1, elems, offsets, err );MSQ_ERRRTN( err ); if( elems.size() == 1 ) { MsqVertex coords; mesh->vertices_get_coordinates( &verts[i], &coords, 1, err );MSQ_ERRRTN( err ); if( coords[0] < 0.0 && coords[1] < 0.0 ) { CHKMESH( !have_start, err ); have_start = true; start = verts[i]; } } } CHKMESH( have_start, err ); // starting at a a corner vertex, find skin vertices std::vector< Mesh::VertexHandle > boundary; boundary.push_back( start ); elems.clear(); offsets.clear(); mesh->vertices_get_attached_elements( &start, 1, elems, offsets, err );MSQ_ERRRTN( err ); Mesh::ElementHandle prev = elems.front(); corners_out[0] = start; int ncorner = 1; do { verts.clear(); offsets.clear(); mesh->elements_get_attached_vertices( &prev, 1, verts, offsets, err ); size_t idx = std::find( verts.begin(), verts.end(), boundary.back() ) - verts.begin(); CHKMESH( idx < verts.size(), err ); Mesh::VertexHandle next = verts[( idx + 1 ) % verts.size()]; elems.clear(); offsets.clear(); mesh->vertices_get_attached_elements( &next, 1, elems, offsets, err );MSQ_ERRRTN( err ); CHKMESH( elems.size() == 1 || elems.size() == 2, err ); if( elems.size() == 2 ) { idx = std::find( elems.begin(), elems.end(), prev ) - elems.begin(); CHKMESH( idx < 2, err ); prev = elems[1 - idx]; } if( elems.size() == 1 ) { CHKMESH( ncorner < 5, err ); if( ncorner < 4 ) // don't add start vertx twice corners_out[ncorner] = next; ++ncorner; } boundary.push_back( next ); } while( boundary.front() != boundary.back() ); CHKMESH( ncorner == 5, err ); // find curve vertices size_t idx = 0; for( int c = 0; c < 4; ++c ) { Mesh::VertexHandle s, e; s = corners_out[c]; e = corners_out[( c + 1 ) % 4]; CHKMESH( idx < boundary.size(), err ); CHKMESH( boundary[idx] == s, err ); for( ; boundary[idx] != e; ++idx ) curves_out[c].push_back( boundary[idx] ); curves_out[c].push_back( e ); } }
void elem_areas | ( | Mesh & | mesh, |
const elem_vec_t & | elems, | ||
double & | min, | ||
double & | mean, | ||
double & | max, | ||
Definition at line 651 of file benchmark_tests.cpp.
References MBMesquite::arrptr(), MBMesquite::Mesh::elements_get_attached_vertices(), MBMesquite::Mesh::elements_get_topologies(), MBMesquite::length(), MSQ_ERRRTN, MSQ_SETERR, MBMesquite::QUADRILATERAL, MBMesquite::TRIANGLE, MBMesquite::MsqError::UNSUPPORTED_ELEMENT, and MBMesquite::Mesh::vertices_get_coordinates().
{ min = HUGE_VAL; max = -1; mean = 0.0; std::vector< EntityTopology > types( elems.size() ); mesh.elements_get_topologies( arrptr( elems ), arrptr( types ), elems.size(), err );MSQ_ERRRTN( err ); std::vector< Mesh::VertexHandle > verts; std::vector< MsqVertex > coords; std::vector< size_t > junk; for( size_t i = 0; i < elems.size(); ++i ) { verts.clear(); junk.clear(); mesh.elements_get_attached_vertices( &elems[i], 1, verts, junk, err );MSQ_ERRRTN( err ); coords.resize( verts.size() ); mesh.vertices_get_coordinates( arrptr( verts ), arrptr( coords ), verts.size(), err );MSQ_ERRRTN( err ); Vector3D v1, v2; double area; if( types[i] == TRIANGLE ) { assert( coords.size() == 3 ); v1 = coords[1] - coords[0]; v2 = coords[2] - coords[0]; area = 0.5 * ( v1 * v2 ).length(); } else if( types[i] == QUADRILATERAL ) { assert( coords.size() == 4 ); v1 = coords[0] + coords[1] - coords[2] - coords[3]; v2 = coords[0] + coords[3] - coords[1] - coords[2]; area = 0.25 * ( v1 * v2 ).length(); } else { MSQ_SETERR( err ) ( "Input file contains volume elements", MsqError::UNSUPPORTED_ELEMENT ); return; } if( min > area ) min = area; if( max < area ) max = area; mean += area; } mean /= elems.size(); }
void find_z10_extreme_elements | ( | Mesh & | mesh, |
elem_vec_t & | polar_elems, | ||
elem_vec_t & | equatorial_elems, | ||
Definition at line 618 of file benchmark_tests.cpp.
References MBMesquite::arrptr(), MBMesquite::Mesh::elements_get_attached_vertices(), MBMesquite::Mesh::get_all_elements(), MSQ_ERRRTN, MBMesquite::Mesh::vertices_get_coordinates(), and z.
{ elem_vec_t elems; mesh.get_all_elements( elems, err );MSQ_ERRRTN( err ); std::vector< Mesh::VertexHandle > verts; std::vector< MsqVertex > coords; std::vector< size_t > junk; for( elem_vec_t::iterator i = elems.begin(); i != elems.end(); ++i ) { verts.clear(); junk.clear(); mesh.elements_get_attached_vertices( &*i, 1, verts, junk, err );MSQ_ERRRTN( err ); coords.resize( verts.size() ); mesh.vertices_get_coordinates( arrptr( verts ), arrptr( coords ), verts.size(), err );MSQ_ERRRTN( err ); for( std::vector< MsqVertex >::iterator j = coords.begin(); j != coords.end(); ++j ) { double z = ( *j )[2]; if( fabs( z ) < 1e-6 ) { equatorial_elems.push_back( *i ); break; } else if( fabs( z ) - 10 < 1e-6 ) { polar_elems.push_back( *i ); break; } } } }
void help | ( | const char * | ) |
Definition at line 89 of file benchmark_tests.cpp.
std::cerr << "Parameters are not supported for this test" << std::endl;
exit( 1 );
int main | ( | int | , |
char * | [] | ||
Definition at line 109 of file benchmark_tests.cpp.
References MBMesquite::arrptr(), MBMesquite::UntangleWrapper::BETA, classify_boundary(), MBMesquite::MeshImpl::clear(), corners, deforming_domain_file_name_1, elem_areas(), find_z10_extreme_elements(), fixed, geom, MBMesquite::MeshImpl::get_all_vertices(), HD, laplacian_file_name_1, laplacian_file_name_2, mesh, min_edge_length_file_name_1, min_edge_length_file_name_2, MSQ_CHKERR, MBMesquite::DeformingCurveSmoother::PROPORTIONAL, MBMesquite::MeshImpl::read_vtk(), MBMesquite::Timer::reset(), MBMesquite::IQInterface::run_instructions(), MBMesquite::LaplaceWrapper::set_vertex_movement_limit_factor(), MBMesquite::UntangleWrapper::set_vertex_movement_limit_factor(), MBMesquite::DeformingDomainWrapper::set_vertex_movement_limit_factor(), shape_improv_file_name_1, shape_improv_file_name_2, MBMesquite::UntangleWrapper::SHAPESIZE, MBMesquite::Timer::since_birth(), MBMesquite::UntangleWrapper::SIZE, size, size_adapt_shape_file_name_1, MBMesquite::DeformingCurveSmoother::smooth_curve(), MBMesquite::DeformingDomainWrapper::store_initial_mesh(), MBMesquite::DeformingCurveSmoother::store_initial_mesh(), t, untangle_file_name_1, untangle_file_name_2, MBMesquite::MeshImpl::vertex_set_coordinates(), MBMesquite::MeshImpl::vertices_get_coordinates(), MBMesquite::MeshImpl::vertices_set_fixed_flag(), MBMesquite::PlanarDomain::XY, and MBMesquite::MeshWriter::Z.
{ std::cout << std::endl << "********* Wrappers Timing Tests **********" << std::endl << std::endl; MBMesquite::MsqPrintError err( cout ); MBMesquite::MeshImpl mesh; // #################### Begin ShapeImprover tests ################### ShapeImprover si_wrapper; mesh.read_vtk( shape_improv_file_name_1.c_str(), err ); Timer t; si_wrapper.run_instructions( &mesh, err ); if( err ) return 1; double si_s_secs = t.since_birth(); std::cout << std::endl << "ShapeImprover small file optimization completed in " << si_s_secs << " seconds" << std::endl; mesh.clear(); mesh.read_vtk( shape_improv_file_name_2.c_str(), err ); t.reset(); si_wrapper.run_instructions( &mesh, err ); if( err ) return 1; double si_l_secs = t.since_birth(); std::cout << std::endl << "ShapeImprover large file optimization completed in " << si_l_secs << " seconds" << std::endl; // #################### Begin LaplacianWrapper tests ################### Vector3D pnt1( 0, 0, 5 ); Vector3D s_norm( 0, 0, 1 ); MBMesquite::PlanarDomain msq_geom( s_norm, pnt1 ); LaplaceWrapper lp_wrapper; mesh.clear(); mesh.read_vtk( laplacian_file_name_1.c_str(), err ); if( err ) return 1; MeshDomainAssoc mesh_and_domain4 = MeshDomainAssoc( &mesh, &msq_geom ); t.reset(); lp_wrapper.run_instructions( &mesh_and_domain4, err ); if( err ) return 1; double lp_s_secs = t.since_birth(); std::cout << std::endl << "LaplacianWrapper small file optimization completed in " << lp_s_secs << " seconds" << std::endl; Vector3D pnt2( 0, 0, 0 ); MBMesquite::PlanarDomain msq_geom2( s_norm, pnt2 ); mesh.clear(); mesh.read_vtk( laplacian_file_name_2.c_str(), err ); if( err ) return 1; MeshDomainAssoc mesh_and_domain5 = MeshDomainAssoc( &mesh, &msq_geom2 ); t.reset(); lp_wrapper.run_instructions( &mesh_and_domain5, err ); if( err ) return 1; double lp_l1_secs = t.since_birth(); std::cout << std::endl << "LaplacianWrapper large file (term crit=0.001) completed in " << lp_l1_secs << " seconds" << std::endl; mesh.clear(); mesh.read_vtk( laplacian_file_name_2.c_str(), err ); if( err ) return 1; lp_wrapper.set_vertex_movement_limit_factor( 0.1 ); t.reset(); lp_wrapper.run_instructions( &mesh_and_domain5, err ); if( err ) return 1; double lp_l2_secs = t.since_birth(); std::cout << std::endl << "LaplacianWrapper large file (term crit=0.1) completed in " << lp_l2_secs << " seconds" << std::endl; // #################### Begin UntangleWrapper::BETA tests ################### mesh.clear(); mesh.read_vtk( untangle_file_name_1.c_str(), err ); if( err ) return 1; std::vector< Mesh::VertexHandle > verts; mesh.get_all_vertices( verts, err ); if( err || verts.empty() ) return 1; MsqVertex coords; mesh.vertices_get_coordinates( arrptr( verts ), &coords, 1, err ); if( err ) return 1; Vector3D norm( 0, 0, 1 ); PlanarDomain u_domain( norm, coords ); UntangleWrapper::UntangleMetric metric = UntangleWrapper::BETA; UntangleWrapper un_wrapper( metric ); un_wrapper.set_vertex_movement_limit_factor( 0.005 ); MeshDomainAssoc mesh_and_domain3 = MeshDomainAssoc( &mesh, &u_domain ); t.reset(); un_wrapper.run_instructions( &mesh_and_domain3, err ); if( err ) return 1; double unb_s_secs = t.since_birth(); std::cout << std::endl << "UntangleWrapper::BETA small file optimization completed in " << unb_s_secs << " seconds" << std::endl; mesh.clear(); mesh.read_vtk( untangle_file_name_2.c_str(), err ); if( err ) return 1; // get domain verts.clear(); mesh.get_all_vertices( verts, err ); if( err || verts.empty() ) return 1; MsqVertex coords2; mesh.vertices_get_coordinates( arrptr( verts ), &coords2, 1, err ); if( err ) return 1; PlanarDomain un_domain2( norm, coords2 ); MeshDomainAssoc mesh_and_domain6 = MeshDomainAssoc( &mesh, &un_domain2 ); t.reset(); un_wrapper.run_instructions( &mesh_and_domain6, err ); if( err ) return 1; double unb_l1_secs = t.since_birth(); std::cout << std::endl << "UntangleWrapper::BETA large file (term crit=0.005) completed in " << unb_l1_secs << " seconds" << std::endl; mesh.clear(); mesh.read_vtk( untangle_file_name_2.c_str(), err ); if( err ) return 1; // get domain verts.clear(); mesh.get_all_vertices( verts, err ); if( err || verts.empty() ) return 1; MsqVertex coords3; mesh.vertices_get_coordinates( arrptr( verts ), &coords3, 1, err ); if( err ) return 1; PlanarDomain un_domain3( norm, coords3 ); un_wrapper.set_vertex_movement_limit_factor( 0.1 ); MeshDomainAssoc mesh_and_domain7 = MeshDomainAssoc( &mesh, &un_domain3 ); t.reset(); un_wrapper.run_instructions( &mesh_and_domain7, err ); if( err ) return 1; double unb_l2_secs = t.since_birth(); std::cout << std::endl << "UntangleWrapper::BETA large file (term crit=0.1) completed in " << unb_l2_secs << " seconds" << std::endl; // #################### Begin UntangleWrapper::SIZE tests ################### mesh.clear(); mesh.read_vtk( untangle_file_name_1.c_str(), err ); if( err ) return 1; verts.clear(); mesh.get_all_vertices( verts, err ); if( err || verts.empty() ) return 1; MsqVertex coords2a; mesh.vertices_get_coordinates( arrptr( verts ), &coords2a, 1, err ); if( err ) return 1; PlanarDomain u_domain3( norm, coords2a ); UntangleWrapper::UntangleMetric metric2 = UntangleWrapper::SIZE; UntangleWrapper un_wrapper2s( metric2 ); UntangleWrapper un_wrapper2l( metric2 ); MeshDomainAssoc mesh_and_domain8 = MeshDomainAssoc( &mesh, &u_domain3 ); t.reset(); un_wrapper2s.run_instructions( &mesh_and_domain8, err ); if( err ) return 1; double uns_s_secs = t.since_birth(); std::cout << std::endl << "UntangleWrapper::SIZE small file optimization completed in " << uns_s_secs << " seconds" << std::endl; mesh.clear(); mesh.read_vtk( untangle_file_name_2.c_str(), err ); if( err ) return 1; // get domain verts.clear(); mesh.get_all_vertices( verts, err ); if( err || verts.empty() ) return 1; MsqVertex coords4; mesh.vertices_get_coordinates( arrptr( verts ), &coords4, 1, err ); if( err ) return 1; PlanarDomain un_domain4( norm, coords4 ); un_wrapper2s.set_vertex_movement_limit_factor( 0.005 ); MeshDomainAssoc mesh_and_domain9 = MeshDomainAssoc( &mesh, &un_domain4 ); t.reset(); un_wrapper2s.run_instructions( &mesh_and_domain9, err ); if( err ) return 1; double uns_l1_secs = t.since_birth(); std::cout << std::endl << "UntangleWrappe::SIZE large file (term crit=0.005) completed in " << uns_l1_secs << " seconds" << std::endl; mesh.clear(); mesh.read_vtk( untangle_file_name_2.c_str(), err ); if( err ) return 1; mesh.get_all_vertices( verts, err ); if( err || verts.empty() ) return 1; mesh.vertices_get_coordinates( arrptr( verts ), &coords4, 1, err ); if( err ) return 1; un_wrapper2l.set_vertex_movement_limit_factor( 0.1 ); t.reset(); un_wrapper2l.run_instructions( &mesh_and_domain9, err ); if( err ) return 1; double uns_l2_secs = t.since_birth(); std::cout << std::endl << "UntangleWrappe::SIZE large file (term crit=0.1) completed in " << uns_l2_secs << " seconds" << std::endl; // #################### Begin UntangleWrapper::SHAPESIZE tests ################### mesh.clear(); mesh.read_vtk( untangle_file_name_1.c_str(), err ); if( err ) return 1; verts.clear(); mesh.get_all_vertices( verts, err ); if( err || verts.empty() ) return 1; MsqVertex coords5; mesh.vertices_get_coordinates( arrptr( verts ), &coords5, 1, err ); if( err ) return 1; PlanarDomain u_domain5( norm, coords3 ); UntangleWrapper::UntangleMetric metric3 = UntangleWrapper::SHAPESIZE; UntangleWrapper un_wrapper3( metric3 ); MeshDomainAssoc mesh_and_domain10 = MeshDomainAssoc( &mesh, &u_domain5 ); t.reset(); un_wrapper3.run_instructions( &mesh_and_domain10, err ); if( err ) return 1; double unss_s_secs = t.since_birth(); std::cout << std::endl << "UntangleWrapper::SHAPESIZE small file optimization completed in " << unss_s_secs << " seconds" << std::endl; mesh.clear(); mesh.read_vtk( untangle_file_name_2.c_str(), err ); if( err ) return 1; // get domain verts.clear(); mesh.get_all_vertices( verts, err ); if( err || verts.empty() ) return 1; MsqVertex coords6; mesh.vertices_get_coordinates( arrptr( verts ), &coords6, 1, err ); if( err ) return 1; PlanarDomain un_domain6( norm, coords6 ); MeshDomainAssoc mesh_and_domain11 = MeshDomainAssoc( &mesh, &un_domain6 ); t.reset(); un_wrapper3.run_instructions( &mesh_and_domain11, err ); if( err ) return 1; double unss_l_secs = t.since_birth(); std::cout << std::endl << "UntangleWrapper::SHAPESIZE large file optimization completed in " << unss_l_secs << " seconds" << std::endl; // #################### Begin SizeAdaptShapeWrapper tests ################### mesh.clear(); mesh.read_vtk( size_adapt_shape_file_name_1.c_str(), err ); if( err ) return 1; elem_vec_t polar, equatorial; find_z10_extreme_elements( mesh, polar, equatorial, err ); if( err ) return 1; double eq_min, eq_max, eq_mean, pol_min, pol_max, pol_mean; elem_areas( mesh, polar, pol_min, pol_mean, pol_max, err ); if( err ) return 1; elem_areas( mesh, equatorial, eq_min, eq_mean, eq_max, err ); if( err ) return 1; SphericalDomain geom( Vector3D( 0, 0, 0 ), 10.0 ); SizeAdaptShapeWrapper sas_wrapper1( 1e-2, 50 ); SizeAdaptShapeWrapper sas_wrapper2( 1e-1, 50 ); MeshDomainAssoc mesh_and_domain12 = MeshDomainAssoc( &mesh, &geom ); t.reset(); sas_wrapper1.run_instructions( &mesh_and_domain12, err ); if( err ) return 1; double sas1_secs = t.since_birth(); std::cout << std::endl << "SizeAdaptShapeWrapper (term crit=0.01) completed in " << sas1_secs << " seconds" << std::endl; mesh.clear(); mesh.read_vtk( size_adapt_shape_file_name_1.c_str(), err ); if( err ) return 1; t.reset(); sas_wrapper2.run_instructions( &mesh_and_domain12, err ); if( err ) return 1; double sas2_secs = t.since_birth(); std::cout << std::endl << "SizeAdaptShapeWrapper (term crit=0.1) completed in " << sas2_secs << " seconds" << std::endl; // #################### Begin PaverMinEdgeLengthWrapper tests ################### PaverMinEdgeLengthWrapper mel_wrapper1( .005, 50 ); PaverMinEdgeLengthWrapper mel_wrapper2( .1, 50 ); mesh.clear(); mesh.read_vtk( min_edge_length_file_name_1.c_str(), err ); t.reset(); mel_wrapper1.run_instructions( &mesh, err ); if( err ) return 1; double mel_s_secs = t.since_birth(); std::cout << std::endl << "PaverMinEdgeLengthWrapper small file optimization completed in " << mel_s_secs << " seconds" << std::endl; mesh.clear(); mesh.read_vtk( min_edge_length_file_name_2.c_str(), err ); t.reset(); mel_wrapper1.run_instructions( &mesh, err ); if( err ) return 1; double mel1_l_secs = t.since_birth(); std::cout << std::endl << "PaverMinEdgeLengthWrapper large file (term crit=0.005) completed in " << mel1_l_secs << " seconds" << std::endl; mesh.clear(); mesh.read_vtk( min_edge_length_file_name_2.c_str(), err ); t.reset(); mel_wrapper2.run_instructions( &mesh, err ); if( err ) return 1; double mel2_l_secs = t.since_birth(); std::cout << std::endl << "PaverMinEdgeLengthWrapper large file (term crit=0.1) completed in " << mel2_l_secs << " seconds" << std::endl; // #################### Begin DeformingDomainWrapper tests ################### // load mesh mesh.clear(); mesh.read_vtk( deforming_domain_file_name_1.c_str(), err ); if( MSQ_CHKERR( err ) ) return 1; std::vector< Mesh::VertexHandle > curves[4]; Mesh::VertexHandle corners[4]; classify_boundary( &mesh, corners, curves, err ); if( MSQ_CHKERR( err ) ) return 1; // new, "deformed" domain will be an 2HDx2HD planar square const double corner_coords[][3] = { { -HD, -HD, Z }, { HD, -HD, Z }, { HD, HD, Z }, { -HD, HD, Z } }; LineDomain lines[4] = { LineDomain( Vector3D( corner_coords[0] ), Vector3D( 1, 0, 0 ) ), LineDomain( Vector3D( corner_coords[1] ), Vector3D( 0, 1, 0 ) ), LineDomain( Vector3D( corner_coords[2] ), Vector3D( -1, 0, 0 ) ), LineDomain( Vector3D( corner_coords[3] ), Vector3D( 0, -1, 0 ) ) }; PlanarDomain surface( PlanarDomain::XY, Z ); // save initial mesh state DeformingCurveSmoother curve_tool; for( int i = 0; i < 4; ++i ) { curve_tool.store_initial_mesh( &mesh, &curves[i][0], curves[i].size(), &lines[i], err ); if( MSQ_CHKERR( err ) ) return 1; } DeformingDomainWrapper dd_wrapper; dd_wrapper.store_initial_mesh( &mesh, err ); if( MSQ_CHKERR( err ) ) return 1; // move corner vertices to new location for( int i = 0; i < 4; ++i ) { Vector3D vect( corner_coords[i] ); mesh.vertex_set_coordinates( corners[i], vect, err ); if( MSQ_CHKERR( err ) ) return 1; } std::vector< bool > fixed( 4, true ); mesh.vertices_set_fixed_flag( corners, fixed, 4, err ); if( MSQ_CHKERR( err ) ) return 1; // smooth curves for( int i = 0; i < 4; ++i ) { curve_tool.smooth_curve( &mesh, &curves[i][0], curves[i].size(), &lines[i], DeformingCurveSmoother::PROPORTIONAL, err ); if( MSQ_CHKERR( err ) ) return 1; fixed.resize( curves[i].size(), true ); mesh.vertices_set_fixed_flag( &curves[i][0], fixed, curves[i].size(), err ); if( MSQ_CHKERR( err ) ) return 1; } MeshDomainAssoc mesh_and_domain1 = MeshDomainAssoc( &mesh, &surface ); t.reset(); dd_wrapper.run_instructions( &mesh_and_domain1, err ); if( MSQ_CHKERR( err ) ) return 1; double dd_secs = t.since_birth(); std::cout << std::endl << "DeformingDomainWrapper file (term crit=0.01) completed in " << dd_secs << " seconds" << std::endl; // Do it all again for the next test mesh.clear(); mesh.read_vtk( deforming_domain_file_name_1.c_str(), err ); if( MSQ_CHKERR( err ) ) return 1; std::vector< Mesh::VertexHandle > curves2[4]; Mesh::VertexHandle corners2[4]; classify_boundary( &mesh, corners2, curves2, err ); if( MSQ_CHKERR( err ) ) return 1; // new, "deformed" domain will be an 2HDx2HD planar square const double corner_coords2[][3] = { { -HD, -HD, Z }, { HD, -HD, Z }, { HD, HD, Z }, { -HD, HD, Z } }; LineDomain lines2[4] = { LineDomain( Vector3D( corner_coords2[0] ), Vector3D( 1, 0, 0 ) ), LineDomain( Vector3D( corner_coords2[1] ), Vector3D( 0, 1, 0 ) ), LineDomain( Vector3D( corner_coords2[2] ), Vector3D( -1, 0, 0 ) ), LineDomain( Vector3D( corner_coords2[3] ), Vector3D( 0, -1, 0 ) ) }; PlanarDomain surface2( PlanarDomain::XY, Z ); // save initial mesh state DeformingCurveSmoother curve_tool2; for( int i = 0; i < 4; ++i ) { curve_tool2.store_initial_mesh( &mesh, &curves2[i][0], curves2[i].size(), &lines2[i], err ); if( MSQ_CHKERR( err ) ) return 1; } DeformingDomainWrapper dd_wrapper2; dd_wrapper2.store_initial_mesh( &mesh, err ); if( MSQ_CHKERR( err ) ) return 1; // move corner vertices to new location for( int i = 0; i < 4; ++i ) { Vector3D vect( corner_coords2[i] ); mesh.vertex_set_coordinates( corners2[i], vect, err ); if( MSQ_CHKERR( err ) ) return 1; } std::vector< bool > fixed2( 4, true ); mesh.vertices_set_fixed_flag( corners2, fixed2, 4, err ); if( MSQ_CHKERR( err ) ) return 1; // smooth curves for( int i = 0; i < 4; ++i ) { curve_tool2.smooth_curve( &mesh, &curves2[i][0], curves2[i].size(), &lines2[i], DeformingCurveSmoother::PROPORTIONAL, err ); if( MSQ_CHKERR( err ) ) return 1; fixed2.resize( curves2[i].size(), true ); mesh.vertices_set_fixed_flag( &curves2[i][0], fixed2, curves2[i].size(), err ); if( MSQ_CHKERR( err ) ) return 1; } dd_wrapper2.set_vertex_movement_limit_factor( 0.1 ); MeshDomainAssoc mesh_and_domain2 = MeshDomainAssoc( &mesh, &surface2 ); t.reset(); dd_wrapper2.run_instructions( &mesh_and_domain2, err ); if( MSQ_CHKERR( err ) ) return 1; double dd_secs2 = t.since_birth(); std::cout << std::endl << "DeformingDomainWrapper file (term crit=0.1) completed in " << dd_secs2 << " seconds" << std::endl; // Timing Summary std::cout << std::endl << "********* Wrappers Timing Summary **********" << std::endl << std::endl; std::cout << "ShapeImprover small file optimization completed in " << si_s_secs << " seconds" << std::endl; std::cout << "ShapeImprover large file optimization completed in " << si_l_secs << " seconds" << std::endl; std::cout << "LaplacianWrapper small file optimization completed in " << lp_s_secs << " seconds" << std::endl; std::cout << "LaplacianWrapper large file optimization (term crit=0.001) in " << lp_l1_secs << " seconds" << std::endl; std::cout << "LaplacianWrapper large file optimization (term crit=0.1) in " << lp_l2_secs << " seconds" << std::endl; std::cout << "UntangleWrapper::BETA small file optimization completed in " << unb_s_secs << " seconds" << std::endl; std::cout << "UntangleWrapper::BETA large file (term crit=0.005) completed in " << unb_l1_secs << " seconds" << std::endl; std::cout << "UntangleWrapper::BETA large file (term crit=0.1) completed in " << unb_l2_secs << " seconds" << std::endl; std::cout << "UntangleWrapper::SIZE small file optimization completed in " << uns_s_secs << " seconds" << std::endl; std::cout << "UntangleWrapper::SIZE large file (term crit=0.005) completed in " << uns_l1_secs << " seconds" << std::endl; std::cout << "UntangleWrapper::SIZE large file (term crit=0.1) completed in " << uns_l2_secs << " seconds" << std::endl; std::cout << "UntangleWrapper::SHAPESIZE small file optimization completed in " << unss_s_secs << " seconds" << std::endl; std::cout << "UntangleWrapper::SHAPESIZE large file optimization completed in " << unss_l_secs << " seconds" << std::endl; std::cout << "SizeAdaptShapeWrapper (term crit=0.01) completed in " << sas1_secs << " seconds" << std::endl; std::cout << "SizeAdaptShapeWrapper (term crit=0.1) completed in " << sas2_secs << " seconds" << std::endl; std::cout << "PaverMinEdgeLengthWrapper small file optimization completed in " << mel_s_secs << " seconds" << std::endl; std::cout << "PaverMinEdgeLengthWrapper large file (term crit=0.005) completed in " << mel1_l_secs << " seconds" << std::endl; std::cout << "PaverMinEdgeLengthWrapper large file (term crit=0.1) completed in " << mel2_l_secs << " seconds" << std::endl; std::cout << "DeformingDomainWrapper file (term crit=0.01) completed in " << dd_secs << " seconds" << std::endl; std::cout << "DeformingDomainWrapper file (term crit=0.1) completed in " << dd_secs2 << " seconds" << std::endl; return 0; }
std::string deforming_domain_file_name_1 = "/3D/vtk/hexes/untangled/sph-10-zsquare.vtk" |
Definition at line 87 of file benchmark_tests.cpp.
const double HD = 4.5 |
Definition at line 107 of file benchmark_tests.cpp.
std::string laplacian_file_name_1 = "/2D/vtk/quads/untangled/square_quad_10_rand.vtk" |
Definition at line 80 of file benchmark_tests.cpp.
std::string laplacian_file_name_2 = "/2D/vtk//quads/untangled/shashkov_quad.vtk" |
Definition at line 81 of file benchmark_tests.cpp.
std::string min_edge_length_file_name_1 = "/2D/vtk/quads/untangled/quads_4by2_bad.vtk" |
Definition at line 85 of file benchmark_tests.cpp.
std::string min_edge_length_file_name_2 = "/2D/vtk/quads/untangled/shashkov_quad.vtk" |
Definition at line 86 of file benchmark_tests.cpp.
std::string shape_improv_file_name_1 = "/3D/vtk/hexes/untangled/1000hex-block-internal-bias.vtk" |
Definition at line 78 of file benchmark_tests.cpp.
std::string shape_improv_file_name_2 = "/3D/vtk/tets/untangled/tire.vtk" |
Definition at line 79 of file benchmark_tests.cpp.
std::string size_adapt_shape_file_name_1 = "/2D/vtk/quads/untangled/bias-sphere-quads.vtk" |
Definition at line 84 of file benchmark_tests.cpp.
std::string untangle_file_name_1 = "/2D/vtk/quads/tangled/tangled_horse1.vtk" |
Definition at line 82 of file benchmark_tests.cpp.
std::string untangle_file_name_2 = "/2D/vtk/quads/untangled//shest_grid32.vtk" |
Definition at line 83 of file benchmark_tests.cpp.
const double Z = 7.0 |
Definition at line 105 of file benchmark_tests.cpp.
