WriteVtk.cpp
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 #ifdef WIN32
00017 #ifdef _DEBUG
00018 // turn off warnings that say they debugging identifier has been truncated
00019 // this warning comes up when using some STL containers
00020 #pragma warning( disable : 4786 )
00021 #endif
00022 #endif
00023
00024 #include "WriteVtk.hpp"
00025 #include "moab/VtkUtil.hpp"
00026 #include "SysUtil.hpp"
00027
00028 #include <fstream>
00029 #include <iostream>
00030 #include <cstdio>
00031 #include <cassert>
00032 #include <vector>
00033 #include <set>
00034 #include <map>
00035 #include <iterator>
00036
00037 #include "moab/Interface.hpp"
00038 #include "moab/Range.hpp"
00039 #include "moab/CN.hpp"
00040 #include "MBTagConventions.hpp"
00041 #include "moab/WriteUtilIface.hpp"
00042 #include "Internals.hpp"
00043 #include "moab/FileOptions.hpp"
00044
00045 #define INS_ID( stringvar, prefix, id ) sprintf( stringvar, prefix, id )
00046
00047 namespace moab
00048 {
00049
00050 const int DEFAULT_PRECISION = 10;
00051 const bool DEFAULT_STRICT   = true;
00052
00053 WriterIface* WriteVtk::factory( Interface* iface )
00054 {
00055     return new WriteVtk( iface );
00056 }
00057
00058 WriteVtk::WriteVtk( Interface* impl )
00059     : mbImpl( impl ), writeTool( 0 ), mStrict( DEFAULT_STRICT ), freeNodes( 0 ), createOneNodeCells( false )
00060 {
00061     assert( impl != NULL );
00062     impl->query_interface( writeTool );
00063 }
00064
00065 WriteVtk::~WriteVtk()
00066 {
00067     mbImpl->release_interface( writeTool );
00068 }
00069
00070 ErrorCode WriteVtk::write_file( const char* file_name,
00071                                 const bool overwrite,
00072                                 const FileOptions& opts,
00073                                 const EntityHandle* output_list,
00074                                 const int num_sets,
00075                                 const std::vector< std::string >& /* qa_list */,
00076                                 const Tag* tag_list,
00077                                 int num_tags,
00078                                 int /* export_dimension */ )
00079 {
00080     ErrorCode rval;
00081
00082     // Get precision for node coordinates
00083     int precision;
00084     if( MB_SUCCESS != opts.get_int_option( "PRECISION", precision ) ) precision = DEFAULT_PRECISION;
00085
00086     if( MB_SUCCESS == opts.get_null_option( "STRICT" ) )
00087         mStrict = true;
00088     else if( MB_SUCCESS == opts.get_null_option( "RELAXED" ) )
00089         mStrict = false;
00090     else
00091         mStrict = DEFAULT_STRICT;
00092
00093     if( MB_SUCCESS == opts.get_null_option( "CREATE_ONE_NODE_CELLS" ) ) createOneNodeCells = true;
00094
00095     // Get entities to write
00096     Range nodes, elems;
00097     rval = gather_mesh( output_list, num_sets, nodes, elems );
00098     if( MB_SUCCESS != rval ) return rval;
00099
00100     // Honor overwrite flag
00101     if( !overwrite )
00102     {
00103         rval = writeTool->check_doesnt_exist( file_name );
00104         if( MB_SUCCESS != rval ) return rval;
00105     }
00106
00107     // Create file
00108     std::ofstream file( file_name );
00109     if( !file )
00110     {
00111         MB_SET_ERR( MB_FILE_WRITE_ERROR, "Could not open file: " << file_name );
00112     }
00113     file.precision( precision );
00114
00115     // Write file
00116     if( ( rval = write_header( file ) ) != MB_SUCCESS || ( rval = write_nodes( file, nodes ) ) != MB_SUCCESS ||
00117         ( rval = write_elems( file, nodes, elems ) ) != MB_SUCCESS ||
00118         ( rval = write_tags( file, true, nodes, tag_list, num_tags ) ) != MB_SUCCESS ||
00119         ( rval = write_tags( file, false, elems, tag_list, num_tags ) ) != MB_SUCCESS )
00120     {
00121         file.close();
00122         remove( file_name );
00123         return rval;
00124     }
00125
00126     return MB_SUCCESS;
00127 }
00128
00129 ErrorCode WriteVtk::gather_mesh( const EntityHandle* set_list, int num_sets, Range& nodes, Range& elems )
00130 {
00131     ErrorCode rval;
00132     int e;
00133
00134     if( !set_list || !num_sets )
00135     {
00136         Range a;
00137         rval = mbImpl->get_entities_by_handle( 0, a );
00138         if( MB_SUCCESS != rval ) return rval;
00139
00140         Range::const_iterator node_i, elem_i, set_i;
00141         node_i = a.lower_bound( a.begin(), a.end(), CREATE_HANDLE( MBVERTEX, 0, e ) );
00142         elem_i = a.lower_bound( node_i, a.end(), CREATE_HANDLE( MBEDGE, 0, e ) );
00143         set_i  = a.lower_bound( elem_i, a.end(), CREATE_HANDLE( MBENTITYSET, 0, e ) );
00144         nodes.merge( node_i, elem_i );
00145         elems.merge( elem_i, set_i );
00146
00147         // Filter out unsupported element types
00148         EntityType et = MBEDGE;
00149         for( et++; et < MBENTITYSET; et++ )
00150         {
00151             if( VtkUtil::get_vtk_type( et, CN::VerticesPerEntity( et ) ) ) continue;
00152             Range::iterator eit   = elems.lower_bound( elems.begin(), elems.end(), CREATE_HANDLE( et, 0, e ) ),
00153                             ep1it = elems.lower_bound( elems.begin(), elems.end(), CREATE_HANDLE( et + 1, 0, e ) );
00154             elems.erase( eit, ep1it );
00155         }
00156     }
00157     else
00158     {
00159         std::set< EntityHandle > visited;
00160         std::vector< EntityHandle > sets;
00161         sets.reserve( num_sets );
00162         std::copy( set_list, set_list + num_sets, std::back_inserter( sets ) );
00163         while( !sets.empty() )
00164         {
00165             // Get next set
00166             EntityHandle set = sets.back();
00167             sets.pop_back();
00168             // Skip sets we've already done
00169             if( !visited.insert( set ).second ) continue;
00170
00171             Range a;
00172             rval = mbImpl->get_entities_by_handle( set, a );
00173             if( MB_SUCCESS != rval ) return rval;
00174
00175             Range::const_iterator node_i, elem_i, set_i;
00176             node_i = a.lower_bound( a.begin(), a.end(), CREATE_HANDLE( MBVERTEX, 0, e ) );
00177             elem_i = a.lower_bound( node_i, a.end(), CREATE_HANDLE( MBEDGE, 0, e ) );
00178             set_i  = a.lower_bound( elem_i, a.end(), CREATE_HANDLE( MBENTITYSET, 0, e ) );
00179             nodes.merge( node_i, elem_i );
00180             elems.merge( elem_i, set_i );
00181             std::copy( set_i, a.end(), std::back_inserter( sets ) );
00182
00183             a.clear();
00184             rval = mbImpl->get_child_meshsets( set, a );
00185             std::copy( a.begin(), a.end(), std::back_inserter( sets ) );
00186         }
00187
00188         for( Range::const_iterator ei = elems.begin(); ei != elems.end(); ++ei )
00189         {
00190             std::vector< EntityHandle > connect;
00191             rval = mbImpl->get_connectivity( &( *ei ), 1, connect );
00192             if( MB_SUCCESS != rval ) return rval;
00193
00194             for( unsigned int i = 0; i < connect.size(); ++i )
00195                 nodes.insert( connect[i] );
00196         }
00197     }
00198
00199     if( nodes.empty() )
00200     {
00201         MB_SET_ERR( MB_ENTITY_NOT_FOUND, "Nothing to write" );
00202     }
00203
00204     return MB_SUCCESS;
00205 }
00206
00207 ErrorCode WriteVtk::write_header( std::ostream& stream )
00208 {
00209     stream << "# vtk DataFile Version 3.0" << std::endl;
00210     stream << MOAB_VERSION_STRING << std::endl;
00211     stream << "ASCII" << std::endl;
00212     stream << "DATASET UNSTRUCTURED_GRID" << std::endl;
00213     return MB_SUCCESS;
00214 }
00215
00216 ErrorCode WriteVtk::write_nodes( std::ostream& stream, const Range& nodes )
00217 {
00218     ErrorCode rval;
00219
00220     stream << "POINTS " << nodes.size() << " double" << std::endl;
00221
00222     double coords[3];
00223     for( Range::const_iterator i = nodes.begin(); i != nodes.end(); ++i )
00224     {
00225         coords[1] = coords[2] = 0.0;
00226         rval                  = mbImpl->get_coords( &( *i ), 1, coords );
00227         if( MB_SUCCESS != rval ) return rval;
00228         stream << coords[0] << ' ' << coords[1] << ' ' << coords[2] << std::endl;
00229     }
00230
00231     return MB_SUCCESS;
00232 }
00233
00234 ErrorCode WriteVtk::write_elems( std::ostream& stream, const Range& nodes, const Range& elems )
00235 {
00236     ErrorCode rval;
00237
00238     Range connectivity;  // because we now support polyhedra, it could contain faces
00239     rval = mbImpl->get_connectivity( elems, connectivity );MB_CHK_ERR( rval );
00240
00241     Range nodes_from_connectivity = connectivity.subset_by_type( MBVERTEX );
00242     Range faces_from_connectivity =
00243         subtract( connectivity, nodes_from_connectivity );  // these could be faces of polyhedra
00244
00245     Range connected_nodes;
00246     rval = mbImpl->get_connectivity( faces_from_connectivity, connected_nodes );MB_CHK_ERR( rval );
00247     connected_nodes.merge( nodes_from_connectivity );
00248
00249     Range free_nodes = subtract( nodes, connected_nodes );
00250
00251     // Get and write counts
00252     unsigned long num_elems, num_uses;
00253     num_elems = num_uses = elems.size();
00254
00255     std::map< EntityHandle, int > sizeFieldsPolyhedra;
00256
00257     for( Range::const_iterator i = elems.begin(); i != elems.end(); ++i )
00258     {
00259         EntityType type = mbImpl->type_from_handle( *i );
00260         if( !VtkUtil::get_vtk_type( type, CN::VerticesPerEntity( type ) ) ) continue;
00261
00262         EntityHandle elem           = *i;
00263         const EntityHandle* connect = NULL;
00264         int conn_len                = 0;
00265         // Dummy storage vector for structured mesh "get_connectivity" function
00266         std::vector< EntityHandle > storage;
00267         rval = mbImpl->get_connectivity( elem, connect, conn_len, false, &storage );MB_CHK_ERR( rval );
00268
00269         num_uses += conn_len;
00270         // if polyhedra, we will count the number of nodes in each face too
00271         if( TYPE_FROM_HANDLE( elem ) == MBPOLYHEDRON )
00272         {
00273             int numFields = 1;  // there will be one for number of faces; forgot about this one
00274             for( int j = 0; j < conn_len; j++ )
00275             {
00276                 const EntityHandle* conn = NULL;
00277                 int num_nd               = 0;
00278                 rval                     = mbImpl->get_connectivity( connect[j], conn, num_nd );MB_CHK_ERR( rval );
00279                 numFields += num_nd + 1;
00280             }
00281             sizeFieldsPolyhedra[elem] = numFields;  // will be used later, at writing
00282             num_uses += ( numFields - conn_len );
00283         }
00284     }
00285     freeNodes = (int)free_nodes.size();
00286     if( !createOneNodeCells ) freeNodes = 0;  // do not create one node cells
00287     stream << "CELLS " << num_elems + freeNodes << ' ' << num_uses + 2 * freeNodes << std::endl;
00288
00289     // Write element connectivity
00290     std::vector< int > conn_data;
00291     std::vector< unsigned > vtk_types( elems.size() + freeNodes );
00292     std::vector< unsigned >::iterator t = vtk_types.begin();
00293     for( Range::const_iterator i = elems.begin(); i != elems.end(); ++i )
00294     {
00295         // Get type information for element
00296         EntityHandle elem = *i;
00297         EntityType type   = TYPE_FROM_HANDLE( elem );
00298
00299         // Get element connectivity
00300         const EntityHandle* connect = NULL;
00301         int conn_len                = 0;
00302         // Dummy storage vector for structured mesh "get_connectivity" function
00303         std::vector< EntityHandle > storage;
00304         rval = mbImpl->get_connectivity( elem, connect, conn_len, false, &storage );MB_CHK_ERR( rval );
00305
00306         // Get VTK type
00307         const VtkElemType* vtk_type = VtkUtil::get_vtk_type( type, conn_len );
00308         if( !vtk_type )
00309         {
00310             // Try connectivity with 1 fewer node
00311             vtk_type = VtkUtil::get_vtk_type( type, conn_len - 1 );
00312             if( vtk_type )
00313                 conn_len--;
00314             else
00315             {
00316                 MB_SET_ERR( MB_FAILURE, "Vtk file format does not support elements of type "
00317                                             << CN::EntityTypeName( type ) << " (" << (int)type << ") with " << conn_len
00318                                             << " nodes" );
00319             }
00320         }
00321
00322         // Save VTK type index for later
00323         *t = vtk_type->vtk_type;
00324         ++t;
00325
00326         if( type != MBPOLYHEDRON )
00327         {
00328             // Get IDs from vertex handles
00329             assert( conn_len > 0 );
00330             conn_data.resize( conn_len );
00331             for( int j = 0; j < conn_len; ++j )
00332                 conn_data[j] = nodes.index( connect[j] );
00333
00334             // Write connectivity list
00335             stream << conn_len;
00336             if( vtk_type->node_order )
00337                 for( int k = 0; k < conn_len; ++k )
00338                     stream << ' ' << conn_data[vtk_type->node_order[k]];
00339             else
00340                 for( int k = 0; k < conn_len; ++k )
00341                     stream << ' ' << conn_data[k];
00342             stream << std::endl;
00343         }
00344         else
00345         {
00346             // POLYHEDRON needs a special case, loop over faces to get nodes
00347             stream << sizeFieldsPolyhedra[elem] << " " << conn_len;
00348             for( int k = 0; k < conn_len; k++ )
00349             {
00350                 EntityHandle face        = connect[k];
00351                 const EntityHandle* conn = NULL;
00352                 int num_nodes            = 0;
00353                 rval                     = mbImpl->get_connectivity( face, conn, num_nodes );MB_CHK_ERR( rval );
00354                 //        num_uses += num_nd + 1; // 1 for number of vertices in face
00355                 conn_data.resize( num_nodes );
00356                 for( int j = 0; j < num_nodes; ++j )
00357                     conn_data[j] = nodes.index( conn[j] );
00358
00359                 stream << ' ' << num_nodes;
00360
00361                 for( int j = 0; j < num_nodes; ++j )
00362                     stream << ' ' << conn_data[j];
00363             }
00364             stream << std::endl;
00365         }
00366     }
00367
00368     if( createOneNodeCells )
00369         for( Range::const_iterator v = free_nodes.begin(); v != free_nodes.end(); ++v, ++t )
00370         {
00371             EntityHandle node = *v;
00372             stream << "1 " << nodes.index( node ) << std::endl;
00373             *t = 1;
00374         }
00375
00376     // Write element types
00377     stream << "CELL_TYPES " << vtk_types.size() << std::endl;
00378     for( std::vector< unsigned >::const_iterator i = vtk_types.begin(); i != vtk_types.end(); ++i )
00379         stream << *i << std::endl;
00380
00381     return MB_SUCCESS;
00382 }
00383
00384 ErrorCode WriteVtk::write_tags( std::ostream& stream,
00385                                 bool nodes,
00386                                 const Range& entities,
00387                                 const Tag* tag_list,
00388                                 int num_tags )
00389 {
00390     ErrorCode rval;
00391
00392     // The #$%@#$% MOAB interface does not have a function to retrieve
00393     // all entities with a tag, only all entities with a specified type
00394     // and tag. Define types to loop over depending on the if vertex
00395     // or element tag data is being written. It seems horribly inefficient
00396     // to have the implementation subdivide the results by type and have
00397     // to call that function once for each type just to recombine the results.
00398     // Unfortunately, there doesn't seem to be any other way.
00399     EntityType low_type, high_type;
00400     if( nodes )
00401     {
00402         low_type  = MBVERTEX;
00403         high_type = MBEDGE;
00404     }
00405     else
00406     {
00407         low_type  = MBEDGE;
00408         high_type = MBENTITYSET;
00409     }
00410
00411     // Get all defined tags
00412     std::vector< Tag > tags;
00413     std::vector< Tag >::iterator i;
00414     rval = writeTool->get_tag_list( tags, tag_list, num_tags, false );
00415     if( MB_SUCCESS != rval ) return rval;
00416
00417     // For each tag...
00418     bool entities_have_tags = false;
00419     for( i = tags.begin(); i != tags.end(); ++i )
00420     {
00421         // Skip tags holding entity handles -- no way to save them
00422         DataType dtype;
00423         rval = mbImpl->tag_get_data_type( *i, dtype );
00424         if( MB_SUCCESS != rval ) return rval;
00425         if( dtype == MB_TYPE_HANDLE ) continue;
00426
00427         // If in strict mode, don't write tags that do not fit in any
00428         // attribute type (SCALAR : 1 to 4 values, VECTOR : 3 values, TENSOR : 9 values)
00429         if( mStrict )
00430         {
00431             int count;
00432             rval = mbImpl->tag_get_length( *i, count );
00433             if( MB_SUCCESS != rval ) return rval;
00434             if( count < 1 || ( count > 4 && count != 9 ) ) continue;
00435         }
00436
00437         // Get subset of input entities that have the tag set
00438         Range tagged;
00439         for( EntityType type = low_type; type < high_type; ++type )
00440         {
00441             Range tmp_tagged;
00442             rval = mbImpl->get_entities_by_type_and_tag( 0, type, &( *i ), 0, 1, tmp_tagged );
00443             if( MB_SUCCESS != rval ) return rval;
00444             tmp_tagged = intersect( tmp_tagged, entities );
00445             tagged.merge( tmp_tagged );
00446         }
00447
00448         // If any entities were tagged
00449         if( !tagged.empty() )
00450         {
00451             // If this is the first tag being written for the
00452             // entity type, write the label marking the beginning
00453             // of the tag data.
00454             if( !entities_have_tags )
00455             {
00456                 entities_have_tags = true;
00457                 if( nodes )
00458                     stream << "POINT_DATA " << entities.size() << std::endl;
00459                 else
00460                     stream << "CELL_DATA " << entities.size() + freeNodes << std::endl;
00461             }
00462
00463             // Write the tag
00464             rval = write_tag( stream, *i, entities, tagged );
00465             if( MB_SUCCESS != rval ) return rval;
00466         }
00467     }
00468
00469     return MB_SUCCESS;
00470 }
00471
00472 template < typename T >
00473 void WriteVtk::write_data( std::ostream& stream, const std::vector< T >& data, unsigned vals_per_tag )
00474 {
00475     typename std::vector< T >::const_iterator d = data.begin();
00476     const unsigned long n                       = data.size() / vals_per_tag;
00477
00478     for( unsigned long i = 0; i < n; ++i )
00479     {
00480         for( unsigned j = 0; j < vals_per_tag; ++j, ++d )
00481         {
00482             if( sizeof( T ) == 1 )
00483                 stream << (unsigned int)*d << ' ';
00484             else
00485                 stream << *d << ' ';
00486         }
00487         stream << std::endl;
00488     }
00489 }
00490
00491 // template <>
00492 // void WriteVtk::write_data<unsigned char>(std::ostream& stream,
00493 //                                         const std::vector<unsigned char>& data,
00494 //                                         unsigned vals_per_tag)
00495 //{
00496 //  std::vector<unsigned char>::const_iterator d = data.begin();
00497 //  const unsigned long n = data.size() / vals_per_tag;
00498 //
00499 //  for (unsigned long i = 0; i < n; ++i) {
00500 //    for (unsigned j = 0; j < vals_per_tag; ++j, ++d)
00501 //      stream << (unsigned int)*d << ' ';
00502 //    stream << std::endl;
00503 //  }
00504 //}
00505
00506 template < typename T >
00507 ErrorCode WriteVtk::write_tag( std::ostream& stream, Tag tag, const Range& entities, const Range& tagged, const int )
00508 {
00509     ErrorCode rval;
00510     int addFreeNodes = 0;
00511     if( TYPE_FROM_HANDLE( entities[0] ) > MBVERTEX ) addFreeNodes = freeNodes;
00512     // we created freeNodes 1-node cells, so we have to augment cell data too
00513     // we know that the 1 node cells are added at the end, after all other cells;
00514     // so the default values will be set to those extra , artificial cells
00515     const unsigned long n = entities.size() + addFreeNodes;
00516
00517     // Get tag properties
00518
00519     std::string name;
00520     int vals_per_tag;
00521     if( MB_SUCCESS != mbImpl->tag_get_name( tag, name ) || MB_SUCCESS != mbImpl->tag_get_length( tag, vals_per_tag ) )
00522         return MB_FAILURE;
00523
00524     // Get a tag value for each entity. Do this by initializing the
00525     // "data" vector with zero, and then filling in the values for
00526     // the entities that actually have the tag set.
00527     std::vector< T > data;
00528     data.resize( n * vals_per_tag, 0 );
00529     // If there is a default value for the tag, set the actual default value
00530     std::vector< T > def_value( vals_per_tag );
00531     rval = mbImpl->tag_get_default_value( tag, &( def_value[0] ) );
00532     if( MB_SUCCESS == rval ) SysUtil::setmem( &( data[0] ), &( def_value[0] ), vals_per_tag * sizeof( T ), n );
00533
00534     Range::const_iterator t               = tagged.begin();
00535     typename std::vector< T >::iterator d = data.begin();
00536     for( Range::const_iterator i = entities.begin(); i != entities.end() && t != tagged.end(); ++i, d += vals_per_tag )
00537     {
00538         if( *i == *t )
00539         {
00540             ++t;
00541             rval = mbImpl->tag_get_data( tag, &( *i ), 1, &( *d ) );
00542             if( MB_SUCCESS != rval ) return rval;
00543         }
00544     }
00545
00546     // Write the tag values, one entity per line.
00547     write_data( stream, data, vals_per_tag );
00548
00549     return MB_SUCCESS;
00550 }
00551
00552 ErrorCode WriteVtk::write_bit_tag( std::ostream& stream, Tag tag, const Range& entities, const Range& tagged )
00553 {
00554     ErrorCode rval;
00555     const unsigned long n = entities.size();
00556
00557     // Get tag properties
00558
00559     std::string name;
00560     int vals_per_tag;
00561     if( MB_SUCCESS != mbImpl->tag_get_name( tag, name ) || MB_SUCCESS != mbImpl->tag_get_length( tag, vals_per_tag ) )
00562         return MB_FAILURE;
00563
00564     if( vals_per_tag > 8 )
00565     {
00566         MB_SET_ERR( MB_FAILURE, "Invalid tag size for bit tag \"" << name << "\"" );
00567     }
00568
00569     // Get a tag value for each entity.
00570     // Get bits for each entity and unpack into
00571     // one integer in the 'data' array for each bit.
00572     // Initialize 'data' to zero because we will skip
00573     // those entities for which the tag is not set.
00574     std::vector< unsigned short > data;
00575     data.resize( n * vals_per_tag, 0 );
00576     Range::const_iterator t                   = tagged.begin();
00577     std::vector< unsigned short >::iterator d = data.begin();
00578     for( Range::const_iterator i = entities.begin(); i != entities.end() && t != tagged.end(); ++i )
00579     {
00580         if( *i == *t )
00581         {
00582             ++t;
00583             unsigned char value;
00584             rval = mbImpl->tag_get_data( tag, &( *i ), 1, &value );
00585             for( int j = 0; j < vals_per_tag; ++j, ++d )
00586                 *d = (unsigned short)( value & ( 1 << j ) ? 1 : 0 );
00587             if( MB_SUCCESS != rval ) return rval;
00588         }
00589         else
00590         {
00591             // If tag is not set for entity, skip values in array
00592             d += vals_per_tag;
00593         }
00594     }
00595
00596     // Write the tag values, one entity per line.
00597     write_data( stream, data, vals_per_tag );
00598
00599     return MB_SUCCESS;
00600 }
00601
00602 ErrorCode WriteVtk::write_tag( std::ostream& s, Tag tag, const Range& entities, const Range& tagged )
00603 {
00604     // Get tag properties
00605     std::string name;
00606     DataType type;
00607     int vals_per_tag;
00608     if( MB_SUCCESS != mbImpl->tag_get_name( tag, name ) || MB_SUCCESS != mbImpl->tag_get_length( tag, vals_per_tag ) ||
00609         MB_SUCCESS != mbImpl->tag_get_data_type( tag, type ) )
00610         return MB_FAILURE;
00611
00612     // Skip tags of type ENTITY_HANDLE
00613     if( MB_TYPE_HANDLE == type ) return MB_FAILURE;
00614
00615     // Now that we're past the point where the name would be used in
00616     // an error message, remove any spaces to conform to VTK file.
00617     for( std::string::iterator i = name.begin(); i != name.end(); ++i )
00618     {
00619         if( isspace( *i ) || iscntrl( *i ) ) *i = '_';
00620     }
00621
00622     // Write the tag description
00623     if( 3 == vals_per_tag && MB_TYPE_DOUBLE == type )
00624         s << "VECTORS " << name << ' ' << VtkUtil::vtkTypeNames[type] << std::endl;
00625     else if( 9 == vals_per_tag )
00626         s << "TENSORS " << name << ' ' << VtkUtil::vtkTypeNames[type] << std::endl;
00627     else
00628         s << "SCALARS " << name << ' ' << VtkUtil::vtkTypeNames[type] << ' ' << vals_per_tag << std::endl
00629           << "LOOKUP_TABLE default" << std::endl;
00630
00631     // Write the tag data
00632     switch( type )
00633     {
00634         case MB_TYPE_OPAQUE:
00635             return write_tag< unsigned char >( s, tag, entities, tagged, 0 );
00636         case MB_TYPE_INTEGER:
00637             return write_tag< int >( s, tag, entities, tagged, 0 );
00638         case MB_TYPE_DOUBLE:
00639             return write_tag< double >( s, tag, entities, tagged, 0 );
00640         case MB_TYPE_BIT:
00641             return write_bit_tag( s, tag, entities, tagged );
00642         default:
00643             return MB_FAILURE;
00644     }
00645 }
00646
00647 }  // namespace moab
