moab::NCHelperGCRM Class Reference
Child helper class for GCRM grid. More...
#include <NCHelperGCRM.hpp>
+ Inheritance diagram for moab::NCHelperGCRM:
+ Collaboration diagram for moab::NCHelperGCRM:
Public Member Functions
 NCHelperGCRM (ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet)
Static Public Member Functions
static bool can_read_file (ReadNC *readNC)
Private Member Functions
virtual ErrorCode init_mesh_vals ()
 Implementation of NCHelper::init_mesh_vals()
virtual ErrorCode check_existing_mesh ()
 Implementation of NCHelper::check_existing_mesh()
virtual ErrorCode create_mesh (Range &faces)
 Implementation of NCHelper::create_mesh()
virtual std::string get_mesh_type_name ()
 Implementation of NCHelper::get_mesh_type_name()
virtual ErrorCode read_ucd_variables_to_nonset_allocate (std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums)
 Implementation of UcdNCHelper::read_ucd_variables_to_nonset_allocate()
virtual ErrorCode read_ucd_variables_to_nonset (std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums)
 Implementation of UcdNCHelper::read_ucd_variables_to_nonset()
ErrorCode create_local_vertices (const std::vector< int > &vertices_on_local_cells, EntityHandle &start_vertex)
 Create local vertices.
ErrorCode create_local_edges (EntityHandle start_vertex)
 Create local edges (optional)
ErrorCode create_padded_local_cells (const std::vector< int > &vertices_on_local_cells, EntityHandle start_vertex, Range &faces)
 Create local cells with padding (pentagons are padded to hexagons)
ErrorCode create_gather_set_vertices (EntityHandle gather_set, EntityHandle &gather_set_start_vertex)
 Create gather set vertices.
ErrorCode create_gather_set_edges (EntityHandle gather_set, EntityHandle gather_set_start_vertex)
 Create gather set edges (optional)
ErrorCode create_padded_gather_set_cells (EntityHandle gather_set, EntityHandle gather_set_start_vertex)
 Create gather set cells with padding (pentagons are padded to hexagons)
Private Attributes
bool createGatherSet
Range facesOwned
Detailed Description
Definition at line 20 of file NCHelperGCRM.hpp.
moab::NCHelperGCRM::NCHelperGCRM ( ReadNC readNC,
int  fileId,
const FileOptions opts,
Definition at line 19 of file NCHelperGCRM.cpp.
References moab::NCHelper::ignoredVarNames.
    : UcdNCHelper( readNC, fileId, opts, fileSet ), createGatherSet( false )
    // Ignore variables containing topological information
    ignoredVarNames.insert( "grid" );
    ignoredVarNames.insert( "cell_corners" );
    ignoredVarNames.insert( "cell_edges" );
    ignoredVarNames.insert( "edge_corners" );
    ignoredVarNames.insert( "cell_neighbors" );
Member Function Documentation
bool moab::NCHelperGCRM::can_read_file ( ReadNC readNC) [static]
Definition at line 30 of file NCHelperGCRM.cpp.
References moab::ReadNC::dimNames.
Referenced by moab::NCHelper::get_nc_helper().
    std::vector< std::string >& dimNames = readNC->dimNames;
    // If dimension name "cells" exists then it should be the GCRM grid
    if( std::find( dimNames.begin(), dimNames.end(), std::string( "cells" ) ) != dimNames.end() ) return true;
    return false;
Implements moab::NCHelper.
Definition at line 178 of file NCHelperGCRM.cpp.
References moab::Range::empty(), ErrorCode, moab::Interface::get_entities_by_dimension(), MB_CHK_SET_ERR, MB_SUCCESS, moab::Range::size(), and moab::Interface::tag_get_data().
    Interface*& mbImpl = _readNC->mbImpl;
    Tag& mGlobalIdTag  = _readNC->mGlobalIdTag;
    bool& noMesh       = _readNC->noMesh;
    if( noMesh )
        ErrorCode rval;
        if( localGidVerts.empty() )
            // Get all vertices from current file set (it is the input set in no_mesh scenario)
            Range local_verts;
            rval = mbImpl->get_entities_by_dimension( _fileSet, 0, local_verts );MB_CHK_SET_ERR( rval, "Trouble getting local vertices in current file set" );
            if( !local_verts.empty() )
                std::vector< int > gids( local_verts.size() );
                // !IMPORTANT : this has to be the GLOBAL_ID tag
                rval = mbImpl->tag_get_data( mGlobalIdTag, local_verts, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting local gid values of vertices" );
                // Restore localGidVerts
                std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidVerts ) );
                nLocalVertices = localGidVerts.size();
        if( localGidEdges.empty() )
            // Get all edges from current file set (it is the input set in no_mesh scenario)
            Range local_edges;
            rval = mbImpl->get_entities_by_dimension( _fileSet, 1, local_edges );MB_CHK_SET_ERR( rval, "Trouble getting local edges in current file set" );
            if( !local_edges.empty() )
                std::vector< int > gids( local_edges.size() );
                rval = mbImpl->tag_get_data( mGlobalIdTag, local_edges, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting local gid values of edges" );
                // Restore localGidEdges
                std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidEdges ) );
                nLocalEdges = localGidEdges.size();
        if( localGidCells.empty() )
            // Get all cells from current file set (it is the input set in no_mesh scenario)
            Range local_cells;
            rval = mbImpl->get_entities_by_dimension( _fileSet, 2, local_cells );MB_CHK_SET_ERR( rval, "Trouble getting local cells in current file set" );
            if( !local_cells.empty() )
                std::vector< int > gids( local_cells.size() );
                rval = mbImpl->tag_get_data( mGlobalIdTag, local_cells, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting local gid values of cells" );
                // Restore localGidCells
                std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidCells ) );
                nLocalCells = localGidCells.size();
    return MB_SUCCESS;
ErrorCode moab::NCHelperGCRM::create_gather_set_edges ( EntityHandle  gather_set,
) [private]
Definition at line 1275 of file NCHelperGCRM.cpp.
References moab::Interface::add_entities(), ErrorCode, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MBEDGE, NCDF_SIZE, NCFUNC, and NCFUNCG.
    // Create gather set edges
    EntityHandle start_edge;
    EntityHandle* conn_arr_gather_set_edges = NULL;
    // Don't need to specify allocation number here, because we know enough edges were created
    // before
    ErrorCode rval =
        _readNC->readMeshIface->get_element_connect( nEdges, 2, MBEDGE, 0, start_edge, conn_arr_gather_set_edges );MB_CHK_SET_ERR( rval, "Failed to create gather set edges" );
    // Add edges to the gather set
    Range gather_set_edges_range( start_edge, start_edge + nEdges - 1 );
    rval = mbImpl->add_entities( gather_set, gather_set_edges_range );MB_CHK_SET_ERR( rval, "Failed to add edges to the gather set" );
    // Read vertices on each edge
    int verticesOnEdgeVarId;
    int success = NCFUNC( inq_varid )( _fileId, "edge_corners", &verticesOnEdgeVarId );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of edge_corners" );
    // Utilize the memory storage pointed by conn_arr_gather_set_edges
    int* vertices_on_gather_set_edges = (int*)conn_arr_gather_set_edges;
    NCDF_SIZE read_starts[2]          = { 0, 0 };
    NCDF_SIZE read_counts[2]          = { static_cast< NCDF_SIZE >( nEdges ), 2 };
#ifdef MOAB_HAVE_PNETCDF
    // Enter independent I/O mode, since this read is only for the gather processor
    success = NCFUNC( begin_indep_data )( _fileId );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to begin independent I/O mode" );
    success =
        NCFUNCG( _vara_int )( _fileId, verticesOnEdgeVarId, read_starts, read_counts, vertices_on_gather_set_edges );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read edge_corners data" );
    success = NCFUNC( end_indep_data )( _fileId );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to end independent I/O mode" );
#else
    success =
#endif
    // Populate connectivity data for gather set edges
    // Convert in-place from int (stored in the first half) to EntityHandle
    // Reading backward is the trick
    for( int edge_vert = nEdges * 2 - 1; edge_vert >= 0; edge_vert-- )
        // Note, indices stored in vertices_on_gather_set_edges are 0 based
        int gather_set_vert_idx = vertices_on_gather_set_edges[edge_vert];  // Global vertex index, 0 based
        // Connectivity array is shifted by where the gather set vertices start
        conn_arr_gather_set_edges[edge_vert] = gather_set_start_vertex + gather_set_vert_idx;
    return MB_SUCCESS;
ErrorCode moab::NCHelperGCRM::create_gather_set_vertices ( EntityHandle  gather_set,
) [private]
Definition at line 1172 of file NCHelperGCRM.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::Range::end(), ErrorCode, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, NCDF_SIZE, NCFUNC, NCFUNCG, moab::Interface::tag_get_bytes(), and moab::Interface::tag_iterate().
    const Tag*& mpFileIdTag = _readNC->mpFileIdTag;
    // Create gather set vertices
    std::vector< double* > arrays;
    // Don't need to specify allocation number here, because we know enough vertices were created
    // before
    ErrorCode rval = _readNC->readMeshIface->get_node_coords( 3, nVertices, 0, gather_set_start_vertex, arrays );MB_CHK_SET_ERR( rval, "Failed to create gather set vertices" );
    // Add vertices to the gather set
    Range gather_set_verts_range( gather_set_start_vertex, gather_set_start_vertex + nVertices - 1 );
    rval = mbImpl->add_entities( gather_set, gather_set_verts_range );MB_CHK_SET_ERR( rval, "Failed to add vertices to the gather set" );
    // Read x coordinates for gather set vertices
    double* xptr = arrays[0];
    int xVertexVarId;
    int success = NCFUNC( inq_varid )( _fileId, "grid_corner_lon", &xVertexVarId );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of grid_corner_lon" );
    NCDF_SIZE read_start = 0;
    NCDF_SIZE read_count = static_cast< NCDF_SIZE >( nVertices );
    success = NCFUNCG( _vara_double )( _fileId, xVertexVarId, &read_start, &read_count, xptr );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read grid_corner_lon data" );
#else
#endif
    // Read y coordinates for gather set vertices
    double* yptr = arrays[1];
    int yVertexVarId;
    success = NCFUNC( inq_varid )( _fileId, "grid_corner_lat", &yVertexVarId );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of grid_corner_lat" );
    success = NCFUNCG( _vara_double )( _fileId, yVertexVarId, &read_start, &read_count, yptr );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read grid_corner_lat data" );
#else
#endif
    // Convert lon/lat/rad to x/y/z
    double* zptr = arrays[2];
    double rad   = 8000.0 + levVals[0];
    for( int i = 0; i < nVertices; i++ )
        double cosphi = cos( yptr[i] );
        double zmult  = sin( yptr[i] );
        double xmult  = cosphi * cos( xptr[i] );
        double ymult  = cosphi * sin( xptr[i] );
        xptr[i]       = rad * xmult;
        yptr[i]       = rad * ymult;
        zptr[i]       = rad * zmult;
    // Get ptr to GID memory for gather set vertices
    int count  = 0;
    void* data = NULL;
    rval =
        mbImpl->tag_iterate( mGlobalIdTag, gather_set_verts_range.begin(), gather_set_verts_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on gather set vertices" );
    assert( count == nVertices );
    int* gid_data = (int*)data;
    for( int j = 1; j <= nVertices; j++ )
        gid_data[j - 1] = j;
    // Set the file id tag too, it should be bigger something not interfering with global id
    if( mpFileIdTag )
        rval = mbImpl->tag_iterate( *mpFileIdTag, gather_set_verts_range.begin(), gather_set_verts_range.end(), count,
                                    data );MB_CHK_SET_ERR( rval, "Failed to iterate file id tag on gather set vertices" );
        int bytes_per_tag = 4;
        rval              = mbImpl->tag_get_bytes( *mpFileIdTag, bytes_per_tag );MB_CHK_SET_ERR( rval, "Can't get number of bytes for file id tag" );
        if( 4 == bytes_per_tag )
                gid_data[j - 1] = nVertices + j;  // Bigger than global id tag
        else if( 8 == bytes_per_tag )
        {  // Should be a handle tag on 64 bit machine?
            long* handle_tag_data = (long*)data;
                handle_tag_data[j - 1] = nVertices + j;  // Bigger than global id tag
    return MB_SUCCESS;
Definition at line 983 of file NCHelperGCRM.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MBEDGE, NCDF_SIZE, NCFUNC, NCFUNCAG, moab::Interface::tag_iterate(), and moab::DebugOutput::tprintf().
    DebugOutput& dbgOut = _readNC->dbgOut;
    // Read edges on each local cell, to get localGidEdges
    int edgesOnCellVarId;
    int success = NCFUNC( inq_varid )( _fileId, "cell_edges", &edgesOnCellVarId );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of cell_edges" );
    std::vector< int > edges_on_local_cells( nLocalCells * EDGES_PER_CELL );
    dbgOut.tprintf( 1, "   edges_on_local_cells.size() = %d\n", (int)edges_on_local_cells.size() );
    size_t nb_reads = localGidCells.psize();
    std::vector< int > requests( nb_reads );
    std::vector< int > statuss( nb_reads );
    size_t idxReq = 0;
#endif
    size_t indexInArray = 0;
    for( Range::pair_iterator pair_iter = localGidCells.pair_begin(); pair_iter != localGidCells.pair_end();
         ++pair_iter )
        EntityHandle starth = pair_iter->first;
        EntityHandle endh   = pair_iter->second;
        dbgOut.tprintf( 1, "   starth = %d\n", (int)starth );
        dbgOut.tprintf( 1, "   endh = %d\n", (int)endh );
        NCDF_SIZE read_starts[2] = { static_cast< NCDF_SIZE >( starth - 1 ), 0 };
        NCDF_SIZE read_counts[2] = { static_cast< NCDF_SIZE >( endh - starth + 1 ),
                                     static_cast< NCDF_SIZE >( EDGES_PER_CELL ) };
        // Do a partial read in each subrange
        success = NCFUNCREQG( _vara_int )( _fileId, edgesOnCellVarId, read_starts, read_counts,
                                           &( edges_on_local_cells[indexInArray] ), &requests[idxReq++] );
#else
        success = NCFUNCAG( _vara_int )( _fileId, edgesOnCellVarId, read_starts, read_counts,
                                         &( edges_on_local_cells[indexInArray] ) );
#endif
        if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read cell_edges data in a loop" );
        // Increment the index for next subrange
        indexInArray += ( endh - starth + 1 ) * EDGES_PER_CELL;
    // Wait outside the loop
    success = NCFUNC( wait_all )( _fileId, requests.size(), &requests[0], &statuss[0] );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" );
#endif
    // GCRM is 0 based, convert edge indices from 0 to 1 based
    for( std::size_t idx = 0; idx < edges_on_local_cells.size(); idx++ )
        edges_on_local_cells[idx] += 1;
    // Collect local edges
    std::sort( edges_on_local_cells.begin(), edges_on_local_cells.end() );
    std::copy( edges_on_local_cells.rbegin(), edges_on_local_cells.rend(), range_inserter( localGidEdges ) );
    dbgOut.tprintf( 1, "   localGidEdges.psize() = %d\n", (int)localGidEdges.psize() );
    dbgOut.tprintf( 1, "   localGidEdges.size() = %d\n", (int)localGidEdges.size() );
    // Create local edges
    EntityHandle* conn_arr_edges = NULL;
    ErrorCode rval =
        _readNC->readMeshIface->get_element_connect( nLocalEdges, 2, MBEDGE, 0, start_edge, conn_arr_edges,
                                                     // Might have to create gather mesh later
                                                     ( createGatherSet ? nLocalEdges + nEdges : nLocalEdges ) );MB_CHK_SET_ERR( rval, "Failed to create local edges" );
    // Add local edges to current file set
    Range local_edges_range( start_edge, start_edge + nLocalEdges - 1 );
    rval = _readNC->mbImpl->add_entities( _fileSet, local_edges_range );MB_CHK_SET_ERR( rval, "Failed to add local edges to current file set" );
    // Get ptr to GID memory for edges
    int count  = 0;
    void* data = NULL;
    rval       = mbImpl->tag_iterate( mGlobalIdTag, local_edges_range.begin(), local_edges_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on local edges" );
    assert( count == nLocalEdges );
    std::copy( localGidEdges.begin(), localGidEdges.end(), gid_data );
    // Read vertices on each local edge, to get edge connectivity
    // Utilize the memory storage pointed by conn_arr_edges
    int* vertices_on_local_edges = (int*)conn_arr_edges;
    nb_reads = localGidEdges.psize();
    requests.resize( nb_reads );
    statuss.resize( nb_reads );
    idxReq = 0;
#endif
    indexInArray = 0;
    for( Range::pair_iterator pair_iter = localGidEdges.pair_begin(); pair_iter != localGidEdges.pair_end();
         ++pair_iter )
        NCDF_SIZE read_counts[2] = { static_cast< NCDF_SIZE >( endh - starth + 1 ), 2 };
        success = NCFUNCREQG( _vara_int )( _fileId, verticesOnEdgeVarId, read_starts, read_counts,
                                           &( vertices_on_local_edges[indexInArray] ), &requests[idxReq++] );
#else
        success = NCFUNCAG( _vara_int )( _fileId, verticesOnEdgeVarId, read_starts, read_counts,
                                         &( vertices_on_local_edges[indexInArray] ) );
#endif
        if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read edge_corners data in a loop" );
        indexInArray += ( endh - starth + 1 ) * 2;
#endif
    // Populate connectivity data for local edges
    for( int edge_vert = nLocalEdges * 2 - 1; edge_vert >= 0; edge_vert-- )
        // Note, indices stored in vertices_on_local_edges are 0 based
        int global_vert_idx = vertices_on_local_edges[edge_vert] + 1;  // Global vertex index, 1 based
        int local_vert_idx  = localGidVerts.index( global_vert_idx );  // Local vertex index, 0 based
        assert( local_vert_idx != -1 );
        conn_arr_edges[edge_vert] = start_vertex + local_vert_idx;
    return MB_SUCCESS;
ErrorCode moab::NCHelperGCRM::create_local_vertices ( const std::vector< int > &  vertices_on_local_cells,
) [private]
Definition at line 808 of file NCHelperGCRM.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, NCDF_SIZE, NCFUNC, NCFUNCAG, moab::Interface::tag_get_bytes(), moab::Interface::tag_iterate(), and moab::DebugOutput::tprintf().
    std::map< std::string, ReadNC::VarData >& varInfo = _readNC->varInfo;
    // Make a copy of vertices_on_local_cells for sorting (keep original one to set cell
    // connectivity later)
    std::vector< int > vertices_on_local_cells_sorted( vertices_on_local_cells );
    std::sort( vertices_on_local_cells_sorted.begin(), vertices_on_local_cells_sorted.end() );
    std::copy( vertices_on_local_cells_sorted.rbegin(), vertices_on_local_cells_sorted.rend(),
    dbgOut.tprintf( 1, "   localGidVerts.psize() = %d\n", (int)localGidVerts.psize() );
    dbgOut.tprintf( 1, "   localGidVerts.size() = %d\n", (int)localGidVerts.size() );
    // Create local vertices
    ErrorCode rval =
        _readNC->readMeshIface->get_node_coords( 3, nLocalVertices, 0, start_vertex, arrays,
                                                 ( createGatherSet ? nLocalVertices + nVertices : nLocalVertices ) );MB_CHK_SET_ERR( rval, "Failed to create local vertices" );
    // Add local vertices to current file set
    Range local_verts_range( start_vertex, start_vertex + nLocalVertices - 1 );
    rval = _readNC->mbImpl->add_entities( _fileSet, local_verts_range );MB_CHK_SET_ERR( rval, "Failed to add local vertices to current file set" );
    // Get ptr to GID memory for local vertices
    int count  = 0;
    void* data = NULL;
    rval       = mbImpl->tag_iterate( mGlobalIdTag, local_verts_range.begin(), local_verts_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on local vertices" );
    assert( count == nLocalVertices );
    std::copy( localGidVerts.begin(), localGidVerts.end(), gid_data );
    // Duplicate GID data, which will be used to resolve sharing
    if( mpFileIdTag )
        rval = mbImpl->tag_iterate( *mpFileIdTag, local_verts_range.begin(), local_verts_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate file id tag on local vertices" );
        rval              = mbImpl->tag_get_bytes( *mpFileIdTag, bytes_per_tag );MB_CHK_SET_ERR( rval, "can't get number of bytes for file id tag" );
            std::copy( localGidVerts.begin(), localGidVerts.end(), handle_tag_data );
    size_t nb_reads = localGidVerts.psize();
    size_t idxReq = 0;
#endif
    // Store lev values in levVals
    std::map< std::string, ReadNC::VarData >::iterator vmit;
    if( ( vmit = varInfo.find( "layers" ) ) != varInfo.end() && ( *vmit ).second.varDims.size() == 1 )
        rval = read_coordinate( "layers", 0, nLevels - 1, levVals );MB_CHK_SET_ERR( rval, "Trouble reading 'layers' variable" );
    else if( ( vmit = varInfo.find( "interfaces" ) ) != varInfo.end() && ( *vmit ).second.varDims.size() == 1 )
        rval = read_coordinate( "interfaces", 0, nLevels - 1, levVals );MB_CHK_SET_ERR( rval, "Trouble reading 'interfaces' variable" );
    else
        MB_SET_ERR( MB_FAILURE, "Couldn't find 'layers' or 'interfaces' variable" );
    // Decide whether down is positive
    char posval[10] = { 0 };
    int success     = NCFUNC( get_att_text )( _fileId, ( *vmit ).second.varId, "positive", posval );
    if( 0 == success && !strncmp( posval, "down", 4 ) )
        for( std::vector< double >::iterator dvit = levVals.begin(); dvit != levVals.end(); ++dvit )
            ( *dvit ) *= -1.0;
    // Read x coordinates for local vertices
    int xVertexVarId;
    for( Range::pair_iterator pair_iter = localGidVerts.pair_begin(); pair_iter != localGidVerts.pair_end();
         ++pair_iter )
        NCDF_SIZE read_start = (NCDF_SIZE)( starth - 1 );
        NCDF_SIZE read_count = (NCDF_SIZE)( endh - starth + 1 );
        success = NCFUNCREQG( _vara_double )( _fileId, xVertexVarId, &read_start, &read_count, &( xptr[indexInArray] ),
#else
        success = NCFUNCAG( _vara_double )( _fileId, xVertexVarId, &read_start, &read_count, &( xptr[indexInArray] ) );
#endif
        if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read grid_corner_lon data in a loop" );
        indexInArray += ( endh - starth + 1 );
#endif
    // Read y coordinates for local vertices
    int yVertexVarId;
    idxReq = 0;
#endif
    indexInArray = 0;
         ++pair_iter )
        success = NCFUNCREQG( _vara_double )( _fileId, yVertexVarId, &read_start, &read_count, &( yptr[indexInArray] ),
#else
        success = NCFUNCAG( _vara_double )( _fileId, yVertexVarId, &read_start, &read_count, &( yptr[indexInArray] ) );
#endif
        if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read grid_corner_lat data in a loop" );
#endif
    for( int i = 0; i < nLocalVertices; i++ )
    return MB_SUCCESS;
ErrorCode moab::NCHelperGCRM::create_mesh ( Range faces) [private, virtual]
Definition at line 249 of file NCHelperGCRM.cpp.
References moab::EDGES_PER_CELL, ErrorCode, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, NCDF_SIZE, NCFUNC, NCFUNCAG, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), and moab::DebugOutput::tprintf().
    bool& noEdges       = _readNC->noEdges;
#ifdef MOAB_HAVE_MPI
    int rank         = 0;
    int procs        = 1;
    bool& isParallel = _readNC->isParallel;
    ParallelComm* myPcomm = NULL;
    if( isParallel )
        myPcomm = _readNC->myPcomm;
        rank                   = myPcomm->proc_config().proc_rank();
        procs                  = myPcomm->proc_config().proc_size();
    // Need to know whether we'll be creating gather mesh
    if( rank == _readNC->gatherSetRank ) createGatherSet = true;
    if( procs >= 2 )
        // Shift rank to obtain a rotated trivial partition
        int shifted_rank           = rank;
        int& trivialPartitionShift = _readNC->trivialPartitionShift;
        if( trivialPartitionShift > 0 ) shifted_rank = ( rank + trivialPartitionShift ) % procs;
        // Compute the number of local cells on this proc
        nLocalCells = int( std::floor( 1.0 * nCells / procs ) );
        // The starting global cell index in the GCRM file for this proc
        int start_cell_idx = shifted_rank * nLocalCells;
        // Number of extra cells after equal split over procs
        int iextra = nCells % procs;
        // Allocate extra cells over procs
        if( shifted_rank < iextra ) nLocalCells++;
        start_cell_idx += std::min( shifted_rank, iextra );
        start_cell_idx++;  // 0 based -> 1 based
        // Redistribute local cells after trivial partition (e.g. apply Zoltan partition)
        ErrorCode rval = redistribute_local_cells( start_cell_idx, myPcomm);MB_CHK_SET_ERR( rval, "Failed to redistribute local cells after trivial partition" );
    else
        nLocalCells = nCells;
        localGidCells.insert( 1, nLocalCells );
#else
#endif
    dbgOut.tprintf( 1, " localGidCells.psize() = %d\n", (int)localGidCells.psize() );
    dbgOut.tprintf( 1, " localGidCells.size() = %d\n", (int)localGidCells.size() );
    // Read vertices on each local cell, to get localGidVerts and cell connectivity later
    int verticesOnCellVarId;
    int success = NCFUNC( inq_varid )( _fileId, "cell_corners", &verticesOnCellVarId );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of cell_corners" );
    std::vector< int > vertices_on_local_cells( nLocalCells * EDGES_PER_CELL );
    dbgOut.tprintf( 1, " nLocalCells = %d\n", (int)nLocalCells );
    dbgOut.tprintf( 1, " vertices_on_local_cells.size() = %d\n", (int)vertices_on_local_cells.size() );
    size_t idxReq = 0;
#endif
         ++pair_iter )
        dbgOut.tprintf( 1, " cell_corners starth = %d\n", (int)starth );
        dbgOut.tprintf( 1, " cell_corners   endh = %d\n", (int)endh );
        success = NCFUNCREQG( _vara_int )( _fileId, verticesOnCellVarId, read_starts, read_counts,
                                           &( vertices_on_local_cells[indexInArray] ), &requests[idxReq++] );
#else
        success = NCFUNCAG( _vara_int )( _fileId, verticesOnCellVarId, read_starts, read_counts,
                                         &( vertices_on_local_cells[indexInArray] ) );
#endif
        if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read cell_corners data in a loop" );
#endif
    // Correct vertices_on_local_cells array. Pentagons as hexagons should have
    // a connectivity like 123455 and not 122345
    for( int local_cell_idx = 0; local_cell_idx < nLocalCells; local_cell_idx++ )
        int* pvertex = &vertices_on_local_cells[local_cell_idx * EDGES_PER_CELL];
        for( int k = 0; k < EDGES_PER_CELL - 2; k++ )
            if( *( pvertex + k ) == *( pvertex + k + 1 ) )
                // Shift the connectivity
                for( int kk = k + 1; kk < EDGES_PER_CELL - 1; kk++ )
                    *( pvertex + kk ) = *( pvertex + kk + 1 );
                // No need to try next k
                break;
    // GCRM is 0 based, convert vertex indices from 0 to 1 based
    for( std::size_t idx = 0; idx < vertices_on_local_cells.size(); idx++ )
        vertices_on_local_cells[idx] += 1;
    EntityHandle start_vertex;
    ErrorCode rval = create_local_vertices( vertices_on_local_cells, start_vertex );MB_CHK_SET_ERR( rval, "Failed to create local vertices for GCRM mesh" );
    // Create local edges (unless NO_EDGES read option is set)
    if( !noEdges )
        rval = create_local_edges( start_vertex );MB_CHK_SET_ERR( rval, "Failed to create local edges for GCRM mesh" );
    // Create local cells, padded
    rval = create_padded_local_cells( vertices_on_local_cells, start_vertex, faces );MB_CHK_SET_ERR( rval, "Failed to create padded local cells for GCRM mesh" );
    if( createGatherSet )
        EntityHandle gather_set;
        rval = _readNC->readMeshIface->create_gather_set( gather_set );MB_CHK_SET_ERR( rval, "Failed to create gather set" );
        EntityHandle start_gather_set_vertex;
        rval = create_gather_set_vertices( gather_set, start_gather_set_vertex );MB_CHK_SET_ERR( rval, "Failed to create gather set vertices for GCRM mesh" );
        // Create gather set edges (unless NO_EDGES read option is set)
        if( !noEdges )
            rval = create_gather_set_edges( gather_set, start_gather_set_vertex );MB_CHK_SET_ERR( rval, "Failed to create gather set edges for GCRM mesh" );
        // Create gather set cells with padding
        rval = create_padded_gather_set_cells( gather_set, start_gather_set_vertex );MB_CHK_SET_ERR( rval, "Failed to create padded gather set cells for GCRM mesh" );
    return MB_SUCCESS;
ErrorCode moab::NCHelperGCRM::create_padded_gather_set_cells ( EntityHandle  gather_set,
) [private]
Definition at line 1328 of file NCHelperGCRM.cpp.
References moab::Interface::add_entities(), moab::EDGES_PER_CELL, ErrorCode, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MBPOLYGON, NCDF_SIZE, NCFUNC, and NCFUNCG.
    EntityHandle start_element;
    EntityHandle* conn_arr_gather_set_cells = NULL;
    // Don't need to specify allocation number here, because we know enough cells were created
    // before
    ErrorCode rval = _readNC->readMeshIface->get_element_connect( nCells, EDGES_PER_CELL, MBPOLYGON, 0, start_element,
        conn_arr_gather_set_cells );MB_CHK_SET_ERR( rval, "Failed to create gather set cells" );
    // Add cells to the gather set
    Range gather_set_cells_range( start_element, start_element + nCells - 1 );
    rval = mbImpl->add_entities( gather_set, gather_set_cells_range );MB_CHK_SET_ERR( rval, "Failed to add cells to the gather set" );
    // Read vertices on each gather set cell (connectivity)
    // Utilize the memory storage pointed by conn_arr_gather_set_cells
    int* vertices_on_gather_set_cells = (int*)conn_arr_gather_set_cells;
    NCDF_SIZE read_counts[2] = { static_cast< NCDF_SIZE >( nCells ), static_cast< NCDF_SIZE >( EDGES_PER_CELL ) };
    success =
        NCFUNCG( _vara_int )( _fileId, verticesOnCellVarId, read_starts, read_counts, vertices_on_gather_set_cells );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read cell_corners data" );
#else
    success =
#endif
    // Correct gather set cell vertices array in the same way as local cell vertices array
    // Pentagons as hexagons should have a connectivity like 123455 and not 122345
    for( int gather_set_cell_idx = 0; gather_set_cell_idx < nCells; gather_set_cell_idx++ )
        int* pvertex = vertices_on_gather_set_cells + gather_set_cell_idx * EDGES_PER_CELL;
                break;
    // Populate connectivity data for gather set cells
    for( int cell_vert = nCells * EDGES_PER_CELL - 1; cell_vert >= 0; cell_vert-- )
        // Note, indices stored in vertices_on_gather_set_cells are 0 based
        int gather_set_vert_idx = vertices_on_gather_set_cells[cell_vert];  // Global vertex index, 0 based
        conn_arr_gather_set_cells[cell_vert] = gather_set_start_vertex + gather_set_vert_idx;
    return MB_SUCCESS;
ErrorCode moab::NCHelperGCRM::create_padded_local_cells ( const std::vector< int > &  vertices_on_local_cells,
Range faces
) [private]
Definition at line 1124 of file NCHelperGCRM.cpp.
References moab::Range::begin(), moab::EDGES_PER_CELL, moab::Range::end(), ErrorCode, moab::Range::insert(), MB_CHK_SET_ERR, MB_SUCCESS, MBPOLYGON, and moab::Interface::tag_iterate().
    // Create cells
    EntityHandle* conn_arr_local_cells = NULL;
    ErrorCode rval =
        _readNC->readMeshIface->get_element_connect( nLocalCells, EDGES_PER_CELL, MBPOLYGON, 0, start_element,
                                                     conn_arr_local_cells,
                                                     ( createGatherSet ? nLocalCells + nCells : nLocalCells ) );MB_CHK_SET_ERR( rval, "Failed to create local cells" );
    faces.insert( start_element, start_element + nLocalCells - 1 );
    // Add local cells to current file set
    Range local_cells_range( start_element, start_element + nLocalCells - 1 );
    rval = _readNC->mbImpl->add_entities( _fileSet, local_cells_range );MB_CHK_SET_ERR( rval, "Failed to add local cells to current file set" );
    // Get ptr to GID memory for local cells
    int count  = 0;
    void* data = NULL;
    rval       = mbImpl->tag_iterate( mGlobalIdTag, local_cells_range.begin(), local_cells_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on local cells" );
    assert( count == nLocalCells );
    std::copy( localGidCells.begin(), localGidCells.end(), gid_data );
    // Set connectivity array with proper local vertices handles
    // vertices_on_local_cells array was already corrected to have
    // the last vertices repeated for pentagons, e.g. 122345 => 123455
        for( int i = 0; i < EDGES_PER_CELL; i++ )
            // Note, indices stored in vertices_on_local_cells are 1 based
            EntityHandle global_vert_idx =
                vertices_on_local_cells[local_cell_idx * EDGES_PER_CELL + i];  // Global vertex index, 1 based
            conn_arr_local_cells[local_cell_idx * EDGES_PER_CELL + i] = start_vertex + local_vert_idx;
    return MB_SUCCESS;
virtual std::string moab::NCHelperGCRM::get_mesh_type_name ( ) [inline, private, virtual]
Definition at line 34 of file NCHelperGCRM.hpp.
        return "GCRM";
Definition at line 40 of file NCHelperGCRM.cpp.
References moab::NCHelper::_readNC, moab::UcdNCHelper::cDim, moab::ReadNC::dimLens, moab::ReadNC::dimNames, moab::UcdNCHelper::eDim, moab::ReadNC::VarData::entLoc, moab::ReadNC::ENTLOCEDGE, moab::ReadNC::ENTLOCFACE, moab::ReadNC::ENTLOCVERT, ErrorCode, moab::NCHelper::levDim, MB_CHK_SET_ERR, MB_SET_ERR, moab::UcdNCHelper::nCells, moab::UcdNCHelper::nEdges, moab::NCHelper::nLevels, moab::NCHelper::nTimeSteps, moab::ReadNC::VarData::numLev, moab::UcdNCHelper::nVertices, moab::NCHelper::read_coordinate(), t, moab::NCHelper::tDim, moab::NCHelper::tVals, moab::ReadNC::VarData::varDims, moab::ReadNC::varInfo, and moab::UcdNCHelper::vDim.
    std::vector< std::string >& dimNames              = _readNC->dimNames;
    std::vector< int >& dimLens                       = _readNC->dimLens;
    ErrorCode rval;
    unsigned int idx;
    std::vector< std::string >::iterator vit;
    // Look for time dimension
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "Time" ) ) != dimNames.end() )
        idx = vit - dimNames.begin();
    else if( ( vit = std::find( dimNames.begin(), dimNames.end(), "time" ) ) != dimNames.end() )
    else
        MB_SET_ERR( MB_FAILURE, "Couldn't find 'Time' or 'time' dimension" );
    tDim       = idx;
    nTimeSteps = dimLens[idx];
    // Get number of cells
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "cells" ) ) != dimNames.end() )
    else
        MB_SET_ERR( MB_FAILURE, "Couldn't find 'cells' dimension" );
    cDim   = idx;
    nCells = dimLens[idx];
    // Get number of edges
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "edges" ) ) != dimNames.end() )
    else
        MB_SET_ERR( MB_FAILURE, "Couldn't find 'edges' dimension" );
    eDim   = idx;
    nEdges = dimLens[idx];
    // Get number of vertices
    vDim = -1;
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "corners" ) ) != dimNames.end() )
    else
        MB_SET_ERR( MB_FAILURE, "Couldn't find 'corners' dimension" );
    vDim      = idx;
    nVertices = dimLens[idx];
    // Get number of layers
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "layers" ) ) != dimNames.end() )
    else
        MB_SET_ERR( MB_FAILURE, "Couldn't find 'layers' dimension" );
    levDim  = idx;
    nLevels = dimLens[idx];
    // Dimension indices for other optional levels
    std::vector< unsigned int > opt_lev_dims;
    // Get index of interface levels
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "interfaces" ) ) != dimNames.end() )
        opt_lev_dims.push_back( idx );
    // Store time coordinate values in tVals
    if( nTimeSteps > 0 )
        if( ( vmit = varInfo.find( "time" ) ) != varInfo.end() )
            rval = read_coordinate( "time", 0, nTimeSteps - 1, tVals );MB_CHK_SET_ERR( rval, "Trouble reading 'time' variable" );
        else if( ( vmit = varInfo.find( "t" ) ) != varInfo.end() )
            rval = read_coordinate( "t", 0, nTimeSteps - 1, tVals );MB_CHK_SET_ERR( rval, "Trouble reading 't' variable" );
        else
            // If expected time variable is not available, set dummy time coordinate values to tVals
            for( int t = 0; t < nTimeSteps; t++ )
                tVals.push_back( (double)t );
    // For each variable, determine the entity location type and number of levels
    for( vmit = varInfo.begin(); vmit != varInfo.end(); ++vmit )
        ReadNC::VarData& vd = ( *vmit ).second;
        // Default entLoc is ENTLOCSET
        if( std::find( vd.varDims.begin(), vd.varDims.end(), tDim ) != vd.varDims.end() )
            if( std::find( vd.varDims.begin(), vd.varDims.end(), vDim ) != vd.varDims.end() )
                vd.entLoc = ReadNC::ENTLOCVERT;
            else if( std::find( vd.varDims.begin(), vd.varDims.end(), eDim ) != vd.varDims.end() )
                vd.entLoc = ReadNC::ENTLOCEDGE;
            else if( std::find( vd.varDims.begin(), vd.varDims.end(), cDim ) != vd.varDims.end() )
                vd.entLoc = ReadNC::ENTLOCFACE;
        // Default numLev is 0
        if( std::find( vd.varDims.begin(), vd.varDims.end(), levDim ) != vd.varDims.end() )
            vd.numLev = nLevels;
        else
            // If layers dimension is not found, try other optional levels such as interfaces
            for( unsigned int i = 0; i < opt_lev_dims.size(); i++ )
                if( std::find( vd.varDims.begin(), vd.varDims.end(), opt_lev_dims[i] ) != vd.varDims.end() )
                    vd.numLev = dimLens[opt_lev_dims[i]];
                    break;
    // Hack: create dummy variables for dimensions (like cells) with no corresponding coordinate
    // variables
    rval = create_dummy_variables();MB_CHK_SET_ERR( rval, "Failed to create dummy variables" );
    return MB_SUCCESS;
ErrorCode moab::NCHelperGCRM::read_ucd_variables_to_nonset ( std::vector< ReadNC::VarData > &  vdatas,
std::vector< int > &  tstep_nums
Implements moab::UcdNCHelper.
Definition at line 645 of file NCHelperGCRM.cpp.
References ErrorCode, moab::DebugOutput::get_verbosity(), MB_CHK_SET_ERR, MB_SET_ERR, NCDF_SIZE, NCFUNCAG, moab::Range::pair_begin(), moab::Range::pair_end(), moab::DebugOutput::printf(), moab::Range::psize(), t, and moab::DebugOutput::tprintf().
    ErrorCode rval = read_ucd_variables_to_nonset_allocate( vdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble allocating space to read non-set variables" );
    // Finally, read into that space
    int success;
    Range* pLocalGid = NULL;
    for( unsigned int i = 0; i < vdatas.size(); i++ )
        // Skip edge variables, if specified by the read options
        if( noEdges && vdatas[i].entLoc == ReadNC::ENTLOCEDGE ) continue;
        switch( vdatas[i].entLoc )
            case ReadNC::ENTLOCVERT:
                pLocalGid = &localGidVerts;
                break;
            case ReadNC::ENTLOCFACE:
                pLocalGid = &localGidCells;
                break;
            case ReadNC::ENTLOCEDGE:
                pLocalGid = &localGidEdges;
                break;
            default:
                MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << vdatas[i].varName );
        std::size_t sz = vdatas[i].sz;
        for( unsigned int t = 0; t < tstep_nums.size(); t++ )
            // Set readStart for each timestep along time dimension
            vdatas[i].readStarts[0] = tstep_nums[t];
            switch( vdatas[i].varDataType )
                case NC_FLOAT:
                case NC_DOUBLE: {
                    // Read float as double
                    std::vector< double > tmpdoubledata( sz );
                    // In the case of ucd mesh, and on multiple proc,
                    // we need to read as many times as subranges we have in the
                    // localGid range;
                    // basically, we have to give a different point
                    // for data to start, for every subrange :(
                    size_t indexInDoubleArray = 0;
                    size_t ic = 0;
                    for( Range::pair_iterator pair_iter = pLocalGid->pair_begin(); pair_iter != pLocalGid->pair_end();
                         ++pair_iter, ic++ )
                        EntityHandle endh = pair_iter->second;  // Inclusive
                        vdatas[i].readStarts[1] = (NCDF_SIZE)( starth - 1 );
                        vdatas[i].readCounts[1] = (NCDF_SIZE)( endh - starth + 1 );
                        success = NCFUNCAG( _vara_double )( _fileId, vdatas[i].varId, &( vdatas[i].readStarts[0] ),
                                                            &( vdatas[i].readCounts[0] ),
                                                            &( tmpdoubledata[indexInDoubleArray] ) );
                        if( success )
                                        "Failed to read double data in a loop for variable " << vdatas[i].varName );
                        // We need to increment the index in double array for the
                        // next subrange
                        indexInDoubleArray += ( endh - starth + 1 ) * 1 * vdatas[i].numLev;
                    assert( ic == pLocalGid->psize() );
                    void* data = vdatas[i].varDatas[t];
                    for( std::size_t idx = 0; idx != tmpdoubledata.size(); idx++ )
                        ( (double*)data )[idx] = tmpdoubledata[idx];
                    break;
                default:
                    MB_SET_ERR( MB_FAILURE, "Unexpected data type for variable " << vdatas[i].varName );
    // Debug output, if requested
    if( 1 == dbgOut.get_verbosity() )
        dbgOut.printf( 1, "Read variables: %s", vdatas.begin()->varName.c_str() );
        for( unsigned int i = 1; i < vdatas.size(); i++ )
            dbgOut.printf( 1, ", %s ", vdatas[i].varName.c_str() );
        dbgOut.tprintf( 1, "\n" );
    return rval;
ErrorCode moab::NCHelperGCRM::read_ucd_variables_to_nonset_allocate ( std::vector< ReadNC::VarData > &  vdatas,
Definition at line 408 of file NCHelperGCRM.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::ParallelComm::filter_pstatus(), moab::Interface::get_entities_by_dimension(), MB_CHK_SET_ERR, MB_INDEX_OUT_OF_RANGE, MB_SET_ERR, moab::Range::psize(), PSTATUS_NOT, PSTATUS_NOT_OWNED, moab::Range::size(), t, moab::Interface::tag_iterate(), and moab::DebugOutput::tprintf().
    Range* range = NULL;
    // Get vertices
    Range verts;
    ErrorCode rval = mbImpl->get_entities_by_dimension( _fileSet, 0, verts );MB_CHK_SET_ERR( rval, "Trouble getting vertices in current file set" );
    assert( "Should only have a single vertex subrange, since they were read in one shot" && verts.psize() == 1 );
    // Get edges
    Range edges;
    rval = mbImpl->get_entities_by_dimension( _fileSet, 1, edges );MB_CHK_SET_ERR( rval, "Trouble getting edges in current file set" );
    // Get faces
    Range faces;
    rval = mbImpl->get_entities_by_dimension( _fileSet, 2, faces );MB_CHK_SET_ERR( rval, "Trouble getting faces in current file set" );
    assert( "Should only have a single face subrange, since they were read in one shot" && faces.psize() == 1 );
    if( isParallel )
        ParallelComm*& myPcomm = _readNC->myPcomm;
        rval                   = myPcomm->filter_pstatus( faces, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &facesOwned );MB_CHK_SET_ERR( rval, "Trouble getting owned faces in current file set" );
    else
        facesOwned = faces;  // not running in parallel, but still with MPI
#else
    facesOwned = faces;
#endif
        // Support non-set variables with 3 dimensions like (time, cells, layers), or
        // 2 dimensions like (time, cells)
        assert( 3 == vdatas[i].varDims.size() || 2 == vdatas[i].varDims.size() );
        // For a non-set variable, time should be the first dimension
        assert( tDim == vdatas[i].varDims[0] );
        // Set up readStarts and readCounts
        vdatas[i].readStarts.resize( 3 );
        vdatas[i].readCounts.resize( 3 );
        // First: Time
        vdatas[i].readStarts[0] = 0;  // This value is timestep dependent, will be set later
        vdatas[i].readCounts[0] = 1;
        // Next: nVertices / nCells / nEdges
                // Vertices
                // Start from the first localGidVerts
                // Actually, this will be reset later on in a loop
                vdatas[i].readStarts[1] = localGidVerts[0] - 1;
                vdatas[i].readCounts[1] = nLocalVertices;
                range                   = &verts;
                break;
                // Faces
                // Start from the first localGidCells
                vdatas[i].readStarts[1] = localGidCells[0] - 1;
                vdatas[i].readCounts[1] = nLocalCells;
                range                   = &facesOwned;
                break;
                // Edges
                // Start from the first localGidEdges
                vdatas[i].readStarts[1] = localGidEdges[0] - 1;
                vdatas[i].readCounts[1] = nLocalEdges;
                range                   = &edges;
                break;
            default:
        // Finally: layers or other optional levels, it is possible that there is no
        // level dimension (numLev is 0) for this non-set variable
        if( vdatas[i].numLev < 1 ) vdatas[i].numLev = 1;
        vdatas[i].readStarts[2] = 0;
        vdatas[i].readCounts[2] = vdatas[i].numLev;
        // Get variable size
        vdatas[i].sz = 1;
        for( std::size_t idx = 0; idx != 3; idx++ )
            vdatas[i].sz *= vdatas[i].readCounts[idx];
            dbgOut.tprintf( 2, "Reading variable %s, time step %d\n", vdatas[i].varName.c_str(), tstep_nums[t] );
            if( tstep_nums[t] >= dimLens[tDim] )
                MB_SET_ERR( MB_INDEX_OUT_OF_RANGE, "Wrong value for timestep number " << tstep_nums[t] );
            // Get the tag to read into
            if( !vdatas[i].varTags[t] )
                rval = get_tag_to_nonset( vdatas[i], tstep_nums[t], vdatas[i].varTags[t], vdatas[i].numLev );MB_CHK_SET_ERR( rval, "Trouble getting tag for variable " << vdatas[i].varName );
            // Get ptr to tag space
            assert( 1 == range->psize() );
            void* data;
            int count;
            rval = mbImpl->tag_iterate( vdatas[i].varTags[t], range->begin(), range->end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate tag for variable " << vdatas[i].varName );
            assert( (unsigned)count == range->size() );
            vdatas[i].varDatas[t] = data;
    return rval;
Member Data Documentation
Definition at line 78 of file NCHelperGCRM.hpp.
Definition at line 79 of file NCHelperGCRM.hpp.
List of all members.
