moab::VarLenSparseTag Class Reference
Sparse tag variable-length data. More...
#include <VarLenSparseTag.hpp>
+ Inheritance diagram for moab::VarLenSparseTag:
+ Collaboration diagram for moab::VarLenSparseTag:
Public Types
typedef
MOAB_UNORDERED_MAP_NS::unordered_map
< EntityHandle, VarLenTag
MapType
 map of entity id and tag data
Public Member Functions
 VarLenSparseTag (const char *name, DataType type, const void *default_value, int default_value_bytes)
 ~VarLenSparseTag ()
virtual TagType get_storage_type () const
virtual ErrorCode release_all_data (SequenceManager *seqman, Error *error_handler, bool delete_pending)
 Remove/clear tag data for all entities.
virtual ErrorCode get_data (const SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, void *data) const
 Get tag value for passed entities.
virtual ErrorCode get_data (const SequenceManager *seqman, Error *error_handler, const Range &entities, void *data) const
virtual ErrorCode get_data (const SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, const void **data_ptrs, int *data_lengths) const
virtual ErrorCode get_data (const SequenceManager *seqman, Error *error_handler, const Range &entities, const void **data_ptrs, int *data_lengths) const
virtual ErrorCode set_data (SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, const void *data)
 Set tag value for passed entities.
virtual ErrorCode set_data (SequenceManager *seqman, Error *error_handler, const Range &entities, const void *data)
virtual ErrorCode set_data (SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, void const *const *data_ptrs, const int *data_lengths)
virtual ErrorCode set_data (SequenceManager *seqman, Error *error_handler, const Range &entities, void const *const *data_ptrs, const int *data_lengths)
virtual ErrorCode clear_data (SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, const void *value_ptr, int value_len=0)
virtual ErrorCode clear_data (SequenceManager *seqman, Error *error_handler, const Range &entities, const void *value_ptr, int value_len=0)
virtual ErrorCode remove_data (SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities)
 Remove/clear tag data for entities.
virtual ErrorCode remove_data (SequenceManager *seqman, Error *error_handler, const Range &entities)
virtual ErrorCode tag_iterate (SequenceManager *seqman, Error *error_handler, Range::iterator &iter, const Range::iterator &end, void *&data_ptr, bool allocate=true)
 Access tag data via direct pointer into contiguous blocks.
virtual ErrorCode get_tagged_entities (const SequenceManager *seqman, Range &output_entities, EntityType type=MBMAXTYPE, const Range *intersect=0) const
 Get all tagged entities.
virtual ErrorCode num_tagged_entities (const SequenceManager *seqman, size_t &output_count, EntityType type=MBMAXTYPE, const Range *intersect=0) const
 Count all tagged entities.
virtual ErrorCode find_entities_with_value (const SequenceManager *seqman, Error *error_handler, Range &output_entities, const void *value, int value_bytes=0, EntityType type=MBMAXTYPE, const Range *intersect_entities=0) const
 Get all tagged entities with tag value.
virtual bool is_tagged (const SequenceManager *, EntityHandle h) const
 Check if entity is tagged.
virtual ErrorCode get_memory_use (const SequenceManager *seqman, unsigned long &total, unsigned long &per_entity) const
 Get memory use for tag data.
unsigned long get_number_entities ()
 get number of entities
Private Member Functions
 VarLenSparseTag (const VarLenSparseTag &)
VarLenSparseTagoperator= (const VarLenSparseTag &)
ErrorCode get_data_ptr (Error *error_handler, EntityHandle entity_handle, const void *&data, int &size) const
 get the variable-length data for an entity id
Private Attributes
MapType mData
Detailed Description
Definition at line 45 of file VarLenSparseTag.hpp.
Member Typedef Documentation
typedef MOAB_UNORDERED_MAP_NS::unordered_map< EntityHandle, VarLenTag > moab::VarLenSparseTag::MapType
Definition at line 373 of file VarLenSparseTag.hpp.
moab::VarLenSparseTag::VarLenSparseTag ( const char *  name,
DataType  type,
const void *  default_value,
Definition at line 30 of file VarLenSparseTag.cpp.
    : TagInfo( name, MB_VARIABLE_LENGTH, type, default_value, default_value_bytes )
Definition at line 35 of file VarLenSparseTag.cpp.
References release_all_data().
    release_all_data( 0, 0, true );
Member Function Documentation
ErrorCode moab::VarLenSparseTag::clear_data ( SequenceManager seqman,
Error error_handler,
const EntityHandle entities,
const void *  value_ptr,
int  value_len = 0
) [virtual]
Store tag data or update stored tag values.
Parameters:
seqmanPointer to mesh entity database
entitiesEntity handles for which to store tag data
num_entitiesLength of entities array
value_ptrPointer to a single tag value which is to be stored for each of the passed entities.
value_lenLength of tag value in bytes. Ignored for fixed-length tags. Required for variable- length tags.
Implements moab::TagInfo.
Definition at line 210 of file VarLenSparseTag.cpp.
References moab::SequenceManager::check_valid_entities(), ErrorCode, MB_CHK_ERR, MB_SUCCESS, mData, remove_data(), and moab::TagInfo::validate_lengths().
    if( 0 == value_len )
        remove_data( seqman, 0, entities, num_entities );
        return MB_SUCCESS;
    ErrorCode rval = validate_lengths( NULL, &value_len, 1 );MB_CHK_ERR( rval );
    rval = seqman->check_valid_entities( NULL, entities, num_entities, true );MB_CHK_ERR( rval );
    for( size_t i = 0; i < num_entities; ++i )
        mData[entities[i]].set( value_ptr, value_len );
    return MB_SUCCESS;
const Range entities,
int  value_len = 0
) [virtual]
Parameters:
Definition at line 233 of file VarLenSparseTag.cpp.
References moab::Range::begin(), moab::SequenceManager::check_valid_entities(), moab::Range::end(), ErrorCode, MB_CHK_ERR, MB_SUCCESS, mData, remove_data(), and moab::TagInfo::validate_lengths().
        remove_data( seqman, 0, entities );
        return MB_SUCCESS;
    rval = seqman->check_valid_entities( NULL, entities );MB_CHK_ERR( rval );
    Range::const_iterator i;
    for( i = entities.begin(); i != entities.end(); ++i )
        mData[*i].set( value_ptr, value_len );
    return MB_SUCCESS;
ErrorCode moab::VarLenSparseTag::find_entities_with_value ( const SequenceManager seqman,
Range output_entities,
const void *  value,
int  value_bytes = 0,
EntityType  type = MBMAXTYPE,
const Range intersect_entities = 0
) const [virtual]
Get the list of entities which have the specified tag value.
Parameters:
seqmanPointer to entity storage database
output_entitiesResults *appended* to this range
valuePointer to tag value
value_bytesSize of tag value in bytes.
typeOptional entity type. If specified, search is limited to entities of specified type.
intersect_entitiesOptional intersect list. If specified, search is restricted to entities in this list.
Definition at line 379 of file VarLenSparseTag.cpp.
References moab::Range::begin(), moab::CREATE_HANDLE(), moab::Range::end(), moab::Range::equal_range(), moab::find_map_varlen_values_equal(), moab::find_tag_varlen_values_equal(), moab::TagInfo::get_size(), MB_END_ID, MB_INVALID_SIZE, MB_START_ID, MB_SUCCESS, MBMAXTYPE, and mData.
    if( value_bytes && value_bytes != get_size() ) return MB_INVALID_SIZE;
    MapType::const_iterator iter, end;
#ifdef MOAB_HAVE_UNORDERED_MAP
    if( intersect_entities )
        std::pair< Range::iterator, Range::iterator > r;
        if( type == MBMAXTYPE )
            r.first  = intersect_entities->begin();
            r.second = intersect_entities->end();
        else
            r = intersect_entities->equal_range( type );
        find_map_varlen_values_equal( *this, value, get_size(), r.first, r.second, mData, output_entities );
    else if( type == MBMAXTYPE )
        find_tag_varlen_values_equal( *this, value, get_size(), mData.begin(), mData.end(), output_entities );
    else
        Range tmp;
        seqman->get_entities( type, tmp );
        find_map_varlen_values_equal( *this, value, get_size(), tmp.begin(), tmp.end(), mData, output_entities );
#else
        for( Range::const_pair_iterator p = intersect_entities->begin(); p != intersect_entities->end(); ++p )
            iter = mData.lower_bound( p->first );
            end = mData.upper_bound( p->second );
            find_tag_varlen_values_equal( *this, value, get_size(), iter, end, output_entities );
    else
            iter = mData.begin();
            end = mData.end();
        else
            iter = mData.lower_bound( CREATE_HANDLE( type, MB_START_ID ) );
            end = mData.upper_bound( CREATE_HANDLE( type, MB_END_ID ) );
#endif
    return MB_SUCCESS;
ErrorCode moab::VarLenSparseTag::get_data ( const SequenceManager seqman,
void *  data
) const [virtual]
Get tag values for specified entities.
Will fail for variable-length data.
Parameters:
entitiesEntity handles for which to retrieve tag data
dataPointer to memory in which to store consecutive tag values, one for each passed entity.
Definition at line 74 of file VarLenSparseTag.cpp.
References moab::TagInfo::get_name(), MB_SET_ERR, and MB_VARIABLE_DATA_LENGTH.
    MB_SET_ERR( MB_VARIABLE_DATA_LENGTH, "No size specified for variable-length tag " << get_name() << " data" );
void *  data
) const [virtual]
Parameters:
Definition at line 83 of file VarLenSparseTag.cpp.
const void **  data_ptrs,
int *  data_lengths
) const [virtual]
Parameters:
data_ptrsArray of pointers to tag values, one pointer for each passed entity.
data_lengthsOne value for each entity specifying the length of the tag value for the corresponding entity.
Definition at line 91 of file VarLenSparseTag.cpp.
References ErrorCode, get_data_ptr(), moab::TagInfo::get_name(), MB_SET_ERR, MB_SUCCESS, and MB_VARIABLE_DATA_LENGTH.
    if( !lengths )
    ErrorCode rval;
        rval = get_data_ptr( NULL, entities[i], pointers[i], lengths[i] );
        if( rval != MB_SUCCESS ) return rval;
    return MB_SUCCESS;
int *  data_lengths
) const [virtual]
Parameters:
Definition at line 113 of file VarLenSparseTag.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, get_data_ptr(), moab::TagInfo::get_name(), MB_SET_ERR, MB_SUCCESS, and MB_VARIABLE_DATA_LENGTH.
    if( !lengths )
    ErrorCode rval;
    for( i = entities.begin(); i != entities.end(); ++i, ++pointers, ++lengths )
        rval = get_data_ptr( NULL, *i, *pointers, *lengths );
    return MB_SUCCESS;
ErrorCode moab::VarLenSparseTag::get_data_ptr ( Error error_handler,
const void *&  data,
int &  size
) const [inline, private]
Definition at line 51 of file VarLenSparseTag.cpp.
References moab::TagInfo::get_default_value(), moab::TagInfo::get_default_value_size(), MB_SUCCESS, MB_TAG_NOT_FOUND, and mData.
Referenced by get_data().
    MapType::const_iterator iter = mData.find( entity_handle );
    if( iter != mData.end() )
        ptr    = iter->second.data();
        length = iter->second.size();
    else if( get_default_value() )
        ptr    = get_default_value();
        length = get_default_value_size();
    else
        return MB_TAG_NOT_FOUND;
    return MB_SUCCESS;
ErrorCode moab::VarLenSparseTag::get_memory_use ( const SequenceManager seqman,
unsigned long &  total,
unsigned long &  per_entity
) const [virtual]
Definition at line 455 of file VarLenSparseTag.cpp.
References moab::TagInfo::get_memory_use(), MB_SUCCESS, and mData.
    total = mData.size() * ( 3 * sizeof( void* ) + sizeof( VarLenTag ) );
    for( MapType::const_iterator i = mData.begin(); i != mData.end(); ++i )
        total += i->second.mem();
    if( !mData.empty() ) per_entity = total / mData.size();
    total += sizeof( *this ) + TagInfo::get_memory_use();
    return MB_SUCCESS;
unsigned long moab::VarLenSparseTag::get_number_entities ( ) [inline]
Definition at line 366 of file VarLenSparseTag.hpp.
References mData.
        return mData.size();
Definition at line 40 of file VarLenSparseTag.cpp.
References MB_TAG_SPARSE.
    return MB_TAG_SPARSE;
ErrorCode moab::VarLenSparseTag::get_tagged_entities ( const SequenceManager seqman,
const Range intersect = 0
) const [virtual]
Gets all entity handles that match a type and tag.
Get the list of entities for which the a tag value has been set, or a close approximation if the tag storage scheme cannot accurately determine exactly which entities have explicit values.
Parameters:
intersectOptional intersect list. If specified, search is restricted to entities in this list.
Definition at line 358 of file VarLenSparseTag.cpp.
References moab::get_tagged(), MB_SUCCESS, and mData.
    get_tagged( mData, entities, type, intersect );
    return MB_SUCCESS;
bool moab::VarLenSparseTag::is_tagged ( const SequenceManager ,
EntityHandle  h
) const [virtual]
Definition at line 450 of file VarLenSparseTag.cpp.
References mData.
    return mData.find( h ) != mData.end();
ErrorCode moab::VarLenSparseTag::num_tagged_entities ( const SequenceManager seqman,
size_t &  output_count,
) const [virtual]
Count the entities for which the a tag value has been set, or a close approximation if the tag storage scheme cannot accurately determine exactly which entities have explicit values.
Parameters:
output_countThis is *incremented* for each detected entity.
Definition at line 368 of file VarLenSparseTag.cpp.
References moab::InsertCount::end(), moab::get_tagged(), MB_SUCCESS, and mData.
    InsertCount counter( output_count );
    get_tagged( mData, counter, type, intersect );
    output_count = counter.end();
    return MB_SUCCESS;
VarLenSparseTag& moab::VarLenSparseTag::operator= ( const VarLenSparseTag ) [private]
ErrorCode moab::VarLenSparseTag::release_all_data ( SequenceManager seqman,
bool  delete_pending
) [virtual]
Remove tag values from entities.
Parameters:
delete_pendingIf true, then release any global data associated with the tag in preparation for deleting the tag itself.
Invalidates tag if tag_delete_pending is true. The only valid method that can be invoked that is is the destructor.
Parameters:
Definition at line 45 of file VarLenSparseTag.cpp.
References MB_SUCCESS, and mData.
Referenced by ~VarLenSparseTag().
    mData.clear();
    return MB_SUCCESS;
ErrorCode moab::VarLenSparseTag::remove_data ( SequenceManager seqman,
size_t  num_entities
) [virtual]
Parameters:
Definition at line 256 of file VarLenSparseTag.cpp.
References ErrorCode, MB_SUCCESS, MB_TAG_NOT_FOUND, and mData.
Referenced by clear_data().
    ErrorCode result = MB_SUCCESS;
        MapType::iterator p = mData.find( entities[i] );
        if( p == mData.end() )
        else
            p->second.clear();
            mData.erase( p );
    return result;
) [virtual]
Parameters:
Definition at line 277 of file VarLenSparseTag.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, MB_SUCCESS, MB_TAG_NOT_FOUND, and mData.
    for( Range::iterator i = entities.begin(); i != entities.end(); ++i )
        MapType::iterator p = mData.find( *i );
        else
            p->second.clear();
            mData.erase( p );
    return result;
ErrorCode moab::VarLenSparseTag::set_data ( SequenceManager seqman,
const void *  data
) [virtual]
Store tag data or update stored tag values Will fail for variable-length data.
Parameters:
dataPointer to memory holding consecutive tag values, one for each passed entity.
Definition at line 135 of file VarLenSparseTag.cpp.
const void *  data
) [virtual]
Parameters:
Definition at line 144 of file VarLenSparseTag.cpp.
void const *const *  data_ptrs,
const int *  data_lengths
) [virtual]
Parameters:
data_lengthsOne value for each entity specifying the length of the tag value for the corresponding entity. Array is required for variable-length tags and is ignored for fixed-length tags.
Definition at line 152 of file VarLenSparseTag.cpp.
References moab::SequenceManager::check_valid_entities(), ErrorCode, MB_CHK_ERR, MB_SUCCESS, mData, and moab::TagInfo::validate_lengths().
    ErrorCode rval = validate_lengths( NULL, lengths, num_entities );MB_CHK_ERR( rval );
        if( lengths[i] )
            mData[entities[i]].set( pointers[i], lengths[i] );
        else
            MapType::iterator iter = mData.find( entities[i] );
                iter->second.clear();
                mData.erase( iter );
    return MB_SUCCESS;
) [virtual]
Parameters:
Definition at line 181 of file VarLenSparseTag.cpp.
References moab::Range::begin(), moab::SequenceManager::check_valid_entities(), moab::Range::end(), ErrorCode, MB_CHK_ERR, MB_SUCCESS, mData, moab::Range::size(), and moab::TagInfo::validate_lengths().
    ErrorCode rval = validate_lengths( NULL, lengths, entities.size() );MB_CHK_ERR( rval );
        if( *lengths )
            mData[*i].set( *pointers, *lengths );
        else
            MapType::iterator iter = mData.find( *i );
    return MB_SUCCESS;
ErrorCode moab::VarLenSparseTag::tag_iterate ( SequenceManager seqman,
Range::iterator iter,
const Range::iterator end,
void *&  data_ptr,
bool  allocate = true
) [virtual]
Iteratively obtain direct access to contiguous blocks of tag storage. This function cannot be used with bit tags because of the compressed bit storage. This function cannot be used with variable length tags because it does not provide a mechanism to determine the length of the value for each entity. This function may be used with sparse tags, but if it is used, it will return data for a single entity at a time.
Parameters:
iterAs input, the first entity for which to return data. As output, one past the last entity for which data was returned.
endOne past the last entity for which data is desired
data_ptrOutput: pointer to tag storage.
If this function is called for entities for which no tag value has been set, but for which a default value exists, it will force the allocation of explicit storage for each such entity even though MOAB would normally not explicitly store tag values for such entities.
Definition at line 295 of file VarLenSparseTag.cpp.
References MB_SET_ERR, and MB_VARIABLE_DATA_LENGTH.
    MB_SET_ERR( MB_VARIABLE_DATA_LENGTH, "Cannot iterate over variable-length tag data" );
Member Data Documentation
List of all members.
