MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "TestUtil.hpp"
#include "Mesquite.hpp"
#include "DeformingDomainWrapper.hpp"
#include "MeshImpl.hpp"
#include "MsqError.hpp"
#include "MeshDomain1D.hpp"
#include "PlanarDomain.hpp"
#include "QualityAssessor.hpp"
#include "MsqVertex.hpp"
#include <iostream>
#include <cstdlib>
#include <algorithm>
Defines | |
#define | CHKMESH(COND, ERR) |
Functions | |
void | usage (const char *argv0) |
void | classify_boundary (Mesh *mesh, Mesh::VertexHandle corners_out[4], std::vector< Mesh::VertexHandle > curves_out[4], MsqError &err) |
void | cond_write_file (MeshImpl &mesh, const char *filename) |
int | main (int argc, char *argv[]) |
Variables | |
std::string | INPUT_FILE = "/sph-10-zsquare.vtk" |
const double | Z = 7.0 |
const double | HD = 4.5 |
#define CHKMESH | ( | COND, | |
ERR | |||
do \ { \ if( !( COND ) ) \ { \ MSQ_SETERR( err )( "Unexpected mesh topology", MsqError::INVALID_MESH ); \ return; \ } \ } while( false )
Definition at line 179 of file deforming.cpp.
void classify_boundary | ( | Mesh * | mesh, |
Mesh::VertexHandle | corners_out[4], | ||
std::vector< Mesh::VertexHandle > | curves_out[4], | ||
MsqError & | err | ||
void cond_write_file | ( | MeshImpl & | mesh, |
const char * | filename | ||
Definition at line 69 of file deforming.cpp.
References MSQ_CHKERR, and MBMesquite::MeshImpl::write_vtk().
Referenced by main().
{ if( filename ) { MsqPrintError err( std::cerr ); mesh.write_vtk( filename, err ); if( MSQ_CHKERR( err ) ) { std::cerr << filename << ": failed to write file" << std::endl; exit( 1 ); } std::cout << "Wrote file: " << filename << std::endl; } }
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 84 of file deforming.cpp.
References classify_boundary(), cond_write_file(), corners, fixed, HD, INPUT_FILE, MBMesquite::QualityAssessor::invalid_elements(), mesh, MSQ_CHKERR, MBMesquite::DeformingCurveSmoother::PROPORTIONAL, MBMesquite::Wrapper::quality_assessor(), MBMesquite::MeshImpl::read_vtk(), MBMesquite::IQInterface::run_instructions(), size, MBMesquite::DeformingCurveSmoother::smooth_curve(), MBMesquite::DeformingDomainWrapper::store_initial_mesh(), MBMesquite::DeformingCurveSmoother::store_initial_mesh(), usage, MBMesquite::MeshImpl::vertex_set_coordinates(), MBMesquite::MeshImpl::vertices_set_fixed_flag(), MBMesquite::PlanarDomain::XY, and MBMesquite::MeshWriter::Z.
{ const char* deformed_file = 0; const char* smoothed_file = 0; const char* tag_file = 0; struct { const char* flag; const char** name_ptr; } flags[] = { { "-d", &deformed_file }, { "-t", &tag_file }, { "-f", &smoothed_file }, { 0, 0 } }; for( int i = 1; i < argc; ++i ) { int j; for( j = 0; flags[j].flag && strcmp( flags[j].flag, argv[i] ); ++j ) ; if( !flags[j].flag ) { std::cerr << "Invalid argument: \"" << argv[i] << '"' << std::endl; usage( argv[0] ); } else if( ++i == argc ) { std::cerr << "Expected argument following \"" << argv[i - 1] << '"' << std::endl; usage( argv[0] ); } *( flags[j].name_ptr ) = argv[i]; } // load mesh MsqPrintError err( std::cerr ); MeshImpl mesh; mesh.read_vtk( INPUT_FILE.c_str(), err ); if( MSQ_CHKERR( err ) ) return 1; // find boundary vertices std::vector< Mesh::VertexHandle > curves[4]; Mesh::VertexHandle corners[4]; classify_boundary( &mesh, corners, curves, err ); if( MSQ_CHKERR( err ) ) return 1; // new, "deformed" domain will be an 2HDx2HD planar square const double corner_coords[][3] = { { -HD, -HD, Z }, { HD, -HD, Z }, { HD, HD, Z }, { -HD, HD, Z } }; LineDomain lines[4] = { LineDomain( Vector3D( corner_coords[0] ), Vector3D( 1, 0, 0 ) ), LineDomain( Vector3D( corner_coords[1] ), Vector3D( 0, 1, 0 ) ), LineDomain( Vector3D( corner_coords[2] ), Vector3D( -1, 0, 0 ) ), LineDomain( Vector3D( corner_coords[3] ), Vector3D( 0, -1, 0 ) ) }; PlanarDomain surface( PlanarDomain::XY, Z ); // save initial mesh state DeformingCurveSmoother curve_tool; for( int i = 0; i < 4; ++i ) { curve_tool.store_initial_mesh( &mesh, &curves[i][0], curves[i].size(), &lines[i], err ); if( MSQ_CHKERR( err ) ) return 1; } DeformingDomainWrapper wrapper; wrapper.store_initial_mesh( &mesh, err ); if( MSQ_CHKERR( err ) ) return 1; cond_write_file( mesh, tag_file ); // move corner vertices to new location for( int i = 0; i < 4; ++i ) { Vector3D vect( corner_coords[i] ); mesh.vertex_set_coordinates( corners[i], vect, err ); if( MSQ_CHKERR( err ) ) return 1; } std::vector< bool > fixed( 4, true ); mesh.vertices_set_fixed_flag( corners, fixed, 4, err ); if( MSQ_CHKERR( err ) ) return 1; // smooth curves for( int i = 0; i < 4; ++i ) { curve_tool.smooth_curve( &mesh, &curves[i][0], curves[i].size(), &lines[i], DeformingCurveSmoother::PROPORTIONAL, err ); if( MSQ_CHKERR( err ) ) return 1; fixed.resize( curves[i].size(), true ); mesh.vertices_set_fixed_flag( &curves[i][0], fixed, curves[i].size(), err ); if( MSQ_CHKERR( err ) ) return 1; } cond_write_file( mesh, deformed_file ); // smooth surface mesh MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &surface ); wrapper.run_instructions( &mesh_and_domain, err ); if( MSQ_CHKERR( err ) ) return 1; cond_write_file( mesh, smoothed_file ); return wrapper.quality_assessor().invalid_elements(); }
void usage | ( | const char * | argv0 | ) |
Definition at line 54 of file deforming.cpp.
{ std::cerr << "Usage: " << argv0 << " [-t <file>] [-d <file>] [-f <file>]" << std::endl << "\t-t : write initial mesh with tags containing reference mesh" << std::endl << "\t-d : write file containing deformed mesh with smoothed curves " << std::endl << "\t-f : write file containing final mesh" << std::endl << std::endl; std::exit( 1 ); }
const double HD = 4.5 |
Definition at line 52 of file deforming.cpp.
std::string INPUT_FILE = "/sph-10-zsquare.vtk" |
Definition at line 48 of file deforming.cpp.
const double Z = 7.0 |
Definition at line 50 of file deforming.cpp.
