verdict_test.cpp File Reference
#include "moab/Core.hpp"
#include "moab/CartVect.hpp"
#include "moab/Range.hpp"
#include "moab/verdict/VerdictWrapper.hpp"
#include <iostream>
#include <iomanip>
#include <cstdio>
#include "TestUtil.hpp"
+ Include dependency graph for verdict_test.cpp:
Classes
struct  test_case
Defines
#define MAX_NODES_PER_ELEMENT   27
#define MAX_TESTS_PER_ELEMENT   20
#define VERDICT_SIGNIFICANT_FIG   15
#define MAX_STR_LEN   30
Functions
void verdict_test1 ()
void verdict_unit_tests ()
int main (int argc, char *argv[])
Variables
std::string filename = "unittest/mbtest1.vtk"
Define Documentation
Referenced by verdict_unit_tests().
Definition at line 84 of file verdict_test.cpp.
Definition at line 89 of file verdict_test.cpp.
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 17 of file verdict_test.cpp.
References filename, RUN_TEST, verdict_test1(), and verdict_unit_tests().
    if( argc > 1 )
        if( argc > 1 ) filename = std::string( argv[1] );
    int result = 0;
    result += RUN_TEST( verdict_test1 );
    result += RUN_TEST( verdict_unit_tests );
    return result;
void verdict_test1 ( )
Definition at line 29 of file verdict_test.cpp.
References moab::VerdictWrapper::all_quality_measures(), moab::Range::begin(), CHECK_ERR, moab::Range::end(), entities, ErrorCode, filename, moab::Interface::get_entities_by_handle(), moab::Interface::id_from_handle(), moab::Interface::list_entity(), moab::Interface::load_mesh(), mb, MB_NOT_IMPLEMENTED, moab::MB_QUALITY_COUNT, MB_SUCCESS, MBHEX, MBVERTEX, moab::VerdictWrapper::quality_measure(), moab::VerdictWrapper::quality_name(), moab::VerdictWrapper::set_size(), moab::TYPE_FROM_HANDLE(), and moab::Interface::type_from_handle().
Referenced by main().
    ErrorCode rval;
    Core moab_core;
    Interface* mb = &moab_core;
    rval          = mb->load_mesh( filename.c_str() );CHECK_ERR( rval );
    Range entities;
    rval = mb->get_entities_by_handle( 0, entities );  // all entities from the model
    CHECK_ERR( rval );
    VerdictWrapper vw( mb );
    // for size methods/quality, we need a size, to compute relative sizes and stuff
    rval = vw.set_size( 1.0 );CHECK_ERR( rval );
    for( Range::iterator eit = entities.begin(); eit != entities.end(); ++eit )
        EntityHandle eh  = *eit;
        EntityType etype = TYPE_FROM_HANDLE( eh );
        if( etype == MBVERTEX || etype > MBHEX ) continue;
        for( int quality = 0; quality < MB_QUALITY_COUNT; quality++ )
            QualityType q = (QualityType)quality;
            double qm;
            rval = vw.quality_measure( eh, q, qm );
            if( MB_NOT_IMPLEMENTED == rval ) continue;
            if( MB_FAILURE == rval )
                std::cerr << " failure for entity " << mb->list_entity( eh ) << " quality " << vw.quality_name( q )
                          << "\n";
            if( MB_SUCCESS == rval )
                std::cout << "Entity type " << (EntityType)mb->type_from_handle( eh )
                          << " id:" << mb->id_from_handle( eh ) << " quality:" << vw.quality_name( q ) << " : " << qm
                          << "\n";
        // now compute all qualities for each entity handle
        std::map< QualityType, double > qualities;
        rval = vw.all_quality_measures( eh, qualities );
            mb->list_entity( eh );
            for( std::map< QualityType, double >::iterator mit = qualities.begin(); mit != qualities.end(); ++mit )
                std::cout << "   " << vw.quality_name( mit->first ) << " " << mit->second << " \n";
    return;
Definition at line 107 of file verdict_test.cpp.
References test_case::answer, ErrorCode, test_case::function, iface, MAX_STR_LEN, moab::MB_AREA, moab::MB_ASPECT_RATIO, moab::MB_CONDITION, moab::MB_DIAGONAL, moab::MB_DIMENSION, moab::MB_DISTORTION, moab::MB_JACOBIAN, moab::MB_LENGTH, moab::MB_MAXIMUM_ANGLE, moab::MB_MINIMUM_ANGLE, moab::MB_RELATIVE_SIZE_SQUARED, moab::MB_SCALED_JACOBIAN, MB_SET_ERR_RET, moab::MB_SHAPE, moab::MB_SHAPE_AND_SIZE, moab::MB_SHEAR, moab::MB_SHEAR_AND_SIZE, moab::MB_SKEW, moab::MB_STRETCH, MB_SUCCESS, moab::MB_TAPER, moab::MB_UNDEFINED_QUALITY, moab::MB_VOLUME, moab::MB_WARPAGE, MBEDGE, MBHEX, MBMAXTYPE, MBPRISM, MBQUAD, MBTET, MBTRI, moab::VerdictWrapper::quality_measure(), moab::QualityType_ToString(), test_case::testname, moab::tolerance, and VERDICT_SIGNIFICANT_FIG.
    // all test cases go here
    test_case testcases[] = {
        { "edge calc 1",
          MBEDGE,
          { MB_LENGTH, MB_UNDEFINED_QUALITY },
          2,
          { 0.0, 0.0, 0.0, 1.0, 1.0, 1.0 },
          { 1.732050807568877, 0.0 } },
        { "edge calc 2",
          MBEDGE,
          2,
          { 0.0, 0.0, 0.0, 1.0, 0.0, 0.0 },
          { 1.0, 0.0 } },
        { "edge calc 3",
          MBEDGE,
          2,
          { 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 },
          { 0.0, 0.0 } },
        { "simple wedge",
          MBPRISM,
          { MB_VOLUME, MB_UNDEFINED_QUALITY },
          6,
          { 0.0, 0.0, 0.0, -1.0, 1.0, 0.0, -1.0, 0.0, 0.0, 0.0, 0.0, 1.0, -1.0, 1.0, 1.0, -1.0, 0.0, 1.0 },
          { 0.5, 0.0 } },
        { "singularity wedge",
          MBPRISM,
          6,
          { 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 },
          { 0.0, 0.0 } },
        { "simple tri",
          MBTRI,
          { MB_AREA, MB_MINIMUM_ANGLE, MB_MAXIMUM_ANGLE, MB_CONDITION, MB_SCALED_JACOBIAN, MB_SHAPE,
            MB_RELATIVE_SIZE_SQUARED, MB_SHAPE_AND_SIZE, MB_DISTORTION, MB_UNDEFINED_QUALITY },
          3,
              0.0,
              0.0,
              0.0,
              5,
              0.0,
              0.0,
              2.5,
              4.330127,
              0.0,
          { 10.825317499999997, 5.999999989158383329e+01, 6.000000021683238316e+01, 1.000000000000000000e+00,
            9.999999989075266660e-01, 1.000000000000000000e+00, 8.533333407912848181e-03, 8.533333407912848181e-03,
            1.000000000000000000e+00, 0.0 } },
            "singular tri",
            MBTRI,
            { v_tri_area, v_tri_aspect_ratio, v_tri_condition,
              v_tri_distortion, v_tri_minimum_angle, v_tri_maximum_angle,
              v_tri_relative_size_squared, v_tri_shape, v_tri_shape_and_size,
            3,
              {0,0,0},
              {0.5,0.8660254037,0},
              {1,0,0}
            { 123, 1234, 1234, 1234, 1234, 1234, 1234, 1234, 1234,0}
            "simple quad",
            MBQUAD,
            { v_quad_skew, MB_UNDEFINED_QUALITY},
            4,
              {0,0,0},
              {1,0,0},
              {1,7,0},
              {0,7,0 }
            { 1.3333333333333333333, 0 }
        { "simple quad",
          MBQUAD,
          { MB_ASPECT_RATIO, MB_SKEW, MB_TAPER, MB_WARPAGE, MB_AREA, MB_STRETCH, MB_MAXIMUM_ANGLE, MB_MINIMUM_ANGLE,
            MB_CONDITION, MB_JACOBIAN, MB_SCALED_JACOBIAN, MB_SHEAR, MB_SHAPE, MB_RELATIVE_SIZE_SQUARED,
            MB_SHAPE_AND_SIZE, MB_SHEAR_AND_SIZE, MB_DISTORTION, MB_UNDEFINED_QUALITY },
          4,
              2.0, 0.0, 0.0,  // 1
              1.0, 1.0, 2.0,  // 2
              0.0, 1.0, 0.0,  // 3
              0.0, 0.0, 0.0,  // 0
          { 1.429964171762364344e+00, 9.245003270420482089e-02, 7.453559924999298980e-01, 7.999999999999998432e-03,
            2.692582403567252314e+00, 5.773502691896258421e-01, 9.000000000000000000e+01, 5.678908923910092454e+01,
            2.307927774486215888e+00, 1.114172029062311164e+00, 5.570860145311555822e-01, 5.570860145311555822e-01,
            4.332891224131210084e-01, 9.999999999999995559e-01, 4.332891224131208419e-01, 5.570860145311553602e-01,
            5.626795729450876360e-01, 0.0 } },
        { "tet test",
          MBTET,
          { /*MB_SHEAR,*/ MB_VOLUME, MB_CONDITION, MB_JACOBIAN, MB_SHAPE, MB_RELATIVE_SIZE_SQUARED, MB_SHAPE_AND_SIZE,
          4,
              -5.0,
              -5.0,
              -5.0,
              -5.0,
              5.0,
              -5.0,
              -5.0,
              -5.0,
              5.0,
              5.0,
              -5.0,
              -5.0,
          { 1.666666666666666572e+02, 1.224744871391589385e+00, 1.000000000000000000e+03, 8.399473665965818681e-01,
            3.599999999998462557e-05, 3.023810519746403209e-05, 1.000000000000000000e+00, 0.0 } },
        { "hex test",
          MBHEX,
          { /*MB_ASPECT_RATIO,*/ MB_SKEW, MB_TAPER, MB_VOLUME, MB_STRETCH, MB_DIAGONAL, MB_DIMENSION, MB_CONDITION,
            MB_JACOBIAN, MB_SCALED_JACOBIAN, MB_SHEAR, MB_SHAPE, MB_RELATIVE_SIZE_SQUARED, MB_SHEAR_AND_SIZE,
          8,
              -0.2, -0.7, -0.3,  // 1
              -0.7, 0.4,  -0.6,  // 2
              -0.5, 0.5,  0.3,   // 3
              -0.3, -0.5, 0.5,   // 0
              0.5,  -0.8, -0.2,  // 5
              0.4,  0.4,  -0.6,  // 6
              0.2,  0.5,  0.2,   // 7
              0.5,  -0.3, 0.8    // 4
          { 2.458897037399689067e-01, 1.784576525620624188e-01, 8.130624999999999103e-01, 6.209702997008308412e-01,
            6.896219298787312768e-01, 5.245942005845132261e-01, 1.273059825673506174e+00, 4.769999999999999241e-01,
            7.778495101180593618e-01, 7.778495101180593618e-01, 7.897852810190353345e-01, 6.738357656250002492e-01,
            5.241428201914338780e-01, 5.321855695148176579e-01, 5.847977114834492784e-01, 0.0 } },
        // keep this one last
        // { 0, {MB_UNDEFINED_QUALITY} , 0, {{0}} , {0} } };
        { 0, MBMAXTYPE, { MB_UNDEFINED_QUALITY }, 0, { 0.0, 0.0 }, { 0.0, 0.0 } }
    int i;
    int j = 0;
    double answer_from_lib;
    double tolerance;
    //   double norm_answer_from_lib;
    char exponent[MAX_STR_LEN];
    char* base_ptr;
    int base;
    bool passed = true;  // have all the tests performed so far passed?
    cout.setf( ios::scientific, ios::floatfield );
    cout.precision( VERDICT_SIGNIFICANT_FIG + 3 );
    ErrorCode merr;
    Interface* iface   = new Core();
    VerdictWrapper* vw = new VerdictWrapper( iface );
    EntityHandle dummy = 0;
    // loop through each test
    for( i = 0; testcases[i].testname != 0; i++ )
        cout << endl
             << "[" << i << "]: "
             << "Test case: " << testcases[i].testname << endl;
        for( j = 0; testcases[i].function[j] != MB_UNDEFINED_QUALITY; j++ )
            answer_from_lib =
              (testcases[i].function[j])
              (testcases[i].num_nodes, testcases[i].coords);
            cout << "\t #" << j + 1 << " TESTING :: " << QualityType_ToString( testcases[i].function[j] ) << endl;
            merr = vw->quality_measure( dummy, testcases[i].function[j], answer_from_lib, testcases[i].num_nodes,
                                        testcases[i].etype, testcases[i].coords );
            if( MB_SUCCESS != merr )
                delete vw;
                delete iface;
                MB_SET_ERR_RET( "Failed to compute the quality for an element" );
            sprintf( exponent, "%e", testcases[i].answer[j] );
            base_ptr = strstr( exponent, "e" );
            base_ptr = &base_ptr[1];
            base = atoi( base_ptr );
            tolerance = pow( 10.0, -VERDICT_SIGNIFICANT_FIG ) * pow( 10.0, base );
            if( fabs( answer_from_lib - testcases[i].answer[j] ) > tolerance )
                cout << "\t #" << j + 1 << " FAILED :: " << QualityType_ToString( testcases[i].function[j] ) << endl;
                cout << "\t\t calculated ( " << answer_from_lib << " ) and "
                     << "expected ( " << testcases[i].answer[j] << ") " << endl;
                passed = false;
            else
                cout << "\t #" << j + 1 << " PASSED :: " << QualityType_ToString( testcases[i].function[j] ) << endl;
    delete vw;
    delete iface;
    std::cout << endl << "All tests passed ? " << ( passed ? 1 : 0 ) << endl;
    return;
Variable Documentation
Definition at line 10 of file verdict_test.cpp.
