exodus_test.cpp
00001 #include "TestUtil.hpp"
00002 #include "moab/Core.hpp"
00003 #include "MBTagConventions.hpp"
00004 #include "moab/CN.hpp"
00005 #include "moab/Range.hpp"
00006 #include "ReadNCDF.hpp"
00007 #include "moab/FileOptions.hpp"
00008 #define IS_BUILDING_MB
00009 #include "ExoIIUtil.hpp"
00010 #include <cmath>
00011 #include <algorithm>
00012
00013 using namespace moab;
00014
00015 /* Input test file: ho_test.g
00016  *
00017  * File is expected to contain at least one block for every
00018  * supported higher-order element type.  The coordinates of
00019  * every higher-order node are expected to be the mean of the
00020  * adjacent corner vertices of the element.
00021  */
00022 #ifdef MESHDIR
00023 static const char ho_file[]  = STRINGIFY( MESHDIR ) "/io/ho_test.g";
00024 static const char file_one[] = STRINGIFY( MESHDIR ) "/mbtest1.g";
00025 static const char alt_file[] = STRINGIFY( MESHDIR ) "/io/hex_2x2x2_ss.exo";
00026 static const char polyg[]    = STRINGIFY( MESHDIR ) "/io/poly8-10.vtk";
00027 static const char polyh[]    = STRINGIFY( MESHDIR ) "/io/polyhedra.vtk";
00028 static const char rpolyg[]   = STRINGIFY( MESHDIR ) "/io/polyg.exo";
00029 static const char rpolyh[]   = STRINGIFY( MESHDIR ) "/io/polyh.exo";
00030 #else
00031 static const char ho_file[]  = "ho_test.g";
00032 static const char file_one[] = "mbtest1.g";
00033 static const char alt_file[] = "hex_2x2x2_ss.exo";
00034 static const char polyg[]    = "poly8-10.vtk";
00035 static const char polyh[]    = "polyhedra.vtk";
00036 static const char rpolyg[]   = "polyg.exo";
00037 static const char rpolyh[]   = "polyh.exo";
00038 #endif
00039
00040 void read_file( Interface& moab, const char* input_file );
00041
00042 // Check that element has expected higher-order nodes
00043 // and that each higher-order node is at the center
00044 // of the sub-entity it is on.
00045 void check_ho_element( Interface& moab, EntityHandle entity, int mid_nodes[4] );
00046
00047 void test_read_side( int sideset_id, EntityType sideset_type, int sideset_nodes_per_elem, bool shell_side = false );
00048
00049 // Validate elements of specified type.
00050 // Looks for a block containing the specified entity type
00051 // and with the specified mid-node flags set in its
00052 // HAS_MID_NODES_TAG.
00053 void test_ho_elements( EntityType type, int num_nodes );
00054
00055 // Tests originally in MBTest.cpp
00056 void mb_vertex_coordinate_test();
00057 void mb_bar_connectivity_test();
00058 void mb_tri_connectivity_test();
00059 void mb_quad_connectivity_test();
00060 void mb_hex_connectivity_test();
00061 void mb_tet_connectivity_test();
00062 void mb_write_mesh_test();
00063
00064 void test_types();
00065
00066 void test_tri6()
00067 {
00068     test_ho_elements( MBTRI, 6 );
00069 }
00070 void test_tri7()
00071 {
00072     test_ho_elements( MBTRI, 7 );
00073 }
00074
00075 void test_quad5()
00076 {
00077     test_ho_elements( MBQUAD, 5 );
00078 }
00079 void test_quad8()
00080 {
00081     test_ho_elements( MBQUAD, 8 );
00082 }
00083 void test_quad9()
00084 {
00085     test_ho_elements( MBQUAD, 9 );
00086 }
00087
00088 void test_tet8()
00089 {
00090     test_ho_elements( MBTET, 8 );
00091 }
00092 void test_tet10()
00093 {
00094     test_ho_elements( MBTET, 10 );
00095 }
00096 void test_tet14()
00097 {
00098     test_ho_elements( MBTET, 14 );
00099 }
00100
00101 void test_hex9()
00102 {
00103     test_ho_elements( MBHEX, 9 );
00104 }
00105 void test_hex20()
00106 {
00107     test_ho_elements( MBHEX, 20 );
00108 }
00109 void test_hex27()
00110 {
00111     test_ho_elements( MBHEX, 27 );
00112 }
00113
00114 void test_read_tri6_side()
00115 {
00116     test_read_side( 1, MBEDGE, 3 );
00117 }  // sideset 1
00118 void test_read_shell_side()
00119 {
00120     test_read_side( 3, MBQUAD, 9, true );
00121 }  // sideset 3
00122 void test_read_shell_edge()
00123 {
00124     test_read_side( 4, MBEDGE, 3 );
00125 }  // sideset 4
00126 void test_read_hex20_side()
00127 {
00128     test_read_side( 2, MBQUAD, 8 );
00129 }  // sideset 2
00130
00131 void test_read_block_ids();
00132 void test_read_sideset_ids();
00133 void test_read_nodeset_ids();
00134 void test_write_polygons();
00135 void test_write_polyhedra();
00136 void test_read_polygons();
00137 void test_read_polyhedra();
00138
00139 void test_read_alternate_coord_format();
00140
00141 int main()
00142 {
00143     int result = 0;
00144
00145     result += RUN_TEST( mb_vertex_coordinate_test );
00146     result += RUN_TEST( mb_bar_connectivity_test );
00147     result += RUN_TEST( mb_tri_connectivity_test );
00148     result += RUN_TEST( mb_quad_connectivity_test );
00149     result += RUN_TEST( mb_hex_connectivity_test );
00150     result += RUN_TEST( mb_tet_connectivity_test );
00151     result += RUN_TEST( mb_write_mesh_test );
00152
00153     result += RUN_TEST( test_types );
00154
00155     result += RUN_TEST( test_tri6 );
00156     result += RUN_TEST( test_tri7 );
00157     result += RUN_TEST( test_quad5 );
00158     result += RUN_TEST( test_quad8 );
00159     result += RUN_TEST( test_quad9 );
00160     result += RUN_TEST( test_tet8 );
00161     result += RUN_TEST( test_tet10 );
00162     result += RUN_TEST( test_tet14 );
00163     result += RUN_TEST( test_hex9 );
00164     result += RUN_TEST( test_hex20 );
00165     result += RUN_TEST( test_hex27 );
00166
00167     result += RUN_TEST( test_read_tri6_side );
00168     result += RUN_TEST( test_read_shell_side );
00169     result += RUN_TEST( test_read_shell_edge );
00170     result += RUN_TEST( test_read_hex20_side );
00171
00172     result += RUN_TEST( test_read_block_ids );
00173     result += RUN_TEST( test_read_sideset_ids );
00174     result += RUN_TEST( test_read_nodeset_ids );
00175
00176     result += RUN_TEST( test_read_alternate_coord_format );
00177
00178     result += RUN_TEST( test_write_polygons );
00179     result += RUN_TEST( test_write_polyhedra );
00180     result += RUN_TEST( test_read_polygons );
00181     result += RUN_TEST( test_read_polyhedra );
00182
00183     return result;
00184 }
00185
00186 void load_file_one( Interface* iface )
00187 {
00188     ErrorCode error = iface->load_mesh( file_one );
00189     if( MB_SUCCESS != error )
00190     {
00191         std::cout << "Failed to load input file: " << file_one << std::endl;
00192         std::string error_reason;
00193         iface->get_last_error( error_reason );
00194         std::cout << error_reason << std::endl;
00195     }
00196     CHECK_ERR( error );
00197 }
00198
00199 /*!
00200   @test
00201   Vertex Coordinates
00202   @li Get coordinates of vertex 1 correctly
00203   @li Get coordinates of vertex 8 correctly
00204   @li Get coordinates of vertex 6 correctly
00205 */
00206 void mb_vertex_coordinate_test()
00207 {
00208     double coords[3];
00209     EntityHandle handle;
00210     ErrorCode error;
00211     int err;
00212
00213     Core moab;
00214     Interface* MB = &moab;
00215     load_file_one( MB );
00216
00217     // coordinate 2 should be {1.5, -1.5, 3.5}
00218
00219     handle = CREATE_HANDLE( MBVERTEX, 2, err );
00220     error  = MB->get_coords( &handle, 1, coords );CHECK_ERR( error );
00221     const double exp2[] = { 1.5, -1.5, 3.5 };
00222     CHECK_ARRAYS_EQUAL( exp2, 3, coords, 3 );
00223
00224     // coordinate 9 should be {1, -2, 3.5}
00225     handle = CREATE_HANDLE( MBVERTEX, 9, err );
00226     error  = MB->get_coords( &handle, 1, coords );CHECK_ERR( error );
00227     const double exp9[] = { 1, -2, 3.5 };
00228     CHECK_ARRAYS_EQUAL( exp9, 3, coords, 3 );
00229
00230     // coordinate 7 should be {0.5, -2, 3.5}
00231     handle = CREATE_HANDLE( MBVERTEX, 7, err );
00232     error  = MB->get_coords( &handle, 1, coords );CHECK_ERR( error );
00233     const double exp7[] = { 0.5, -2, 3.5 };
00234     CHECK_ARRAYS_EQUAL( exp7, 3, coords, 3 );
00235
00236     int node_count = 0;
00237     error          = MB->get_number_entities_by_type( 0, MBVERTEX, node_count );CHECK_ERR( error );
00238     // Number of vertices (node_count) should be 83 assuming no gaps in the handle space
00239     CHECK_EQUAL( 47, node_count );
00240 }
00241
00242 /*!
00243   @test
00244   MB Bar Element Connectivity Test
00245   @li Get coordinates for 2 node bar elements
00246 */
00247
00248 void mb_bar_connectivity_test()
00249 {
00250     Core moab;
00251     Interface* MB = &moab;
00252     load_file_one( MB );
00253
00254     std::vector< EntityHandle > conn;
00255     Range bars;
00256
00257     ErrorCode error = MB->get_entities_by_type( 0, MBEDGE, bars );CHECK_ERR( error );
00258
00259     // get the connectivity of the second bar
00260     EntityHandle handle = *( ++bars.begin() );
00261
00262     error = MB->get_connectivity( &handle, 1, conn );CHECK_ERR( error );
00263
00264     CHECK_EQUAL( (size_t)2, conn.size() );
00265
00266     // from ncdump the connectivity of bar 2 (0 based) is
00267     //  14, 13
00268     CHECK_EQUAL( (EntityHandle)14, conn[0] );
00269     CHECK_EQUAL( (EntityHandle)13, conn[1] );
00270
00271     // Now try getting the connectivity of one of the vertices for fun.
00272     // just return the vertex in the connectivity
00273     handle = conn[0];
00274     error  = MB->get_connectivity( &handle, 1, conn );
00275     CHECK_EQUAL( MB_FAILURE, error );
00276 }
00277
00278 void mb_tri_connectivity_test()
00279 {
00280     Core moab;
00281     Interface* MB = &moab;
00282     load_file_one( MB );
00283
00284     std::vector< EntityHandle > conn;
00285     Range tris;
00286     ErrorCode error = MB->get_entities_by_type( 0, MBTRI, tris );CHECK_ERR( error );
00287
00288     // get the connectivity of the second tri
00289     EntityHandle handle = *( ++tris.begin() );
00290
00291     error = MB->get_connectivity( &handle, 1, conn );CHECK_ERR( error );
00292
00293     CHECK_EQUAL( (size_t)3, conn.size() );
00294
00295     // from ncdump the connectivity of tri 2 (0 based) is
00296     //  45, 37, 38
00297
00298     CHECK_EQUAL( (EntityHandle)45, conn[0] );
00299     CHECK_EQUAL( (EntityHandle)37, conn[1] );
00300     CHECK_EQUAL( (EntityHandle)38, conn[2] );
00301 }
00302
00303 void mb_quad_connectivity_test()
00304 {
00305     Core moab;
00306     Interface* MB = &moab;
00307     load_file_one( MB );
00308
00309     std::vector< EntityHandle > conn;
00310     Range quads;
00311
00312     ErrorCode error = MB->get_entities_by_type( 0, MBQUAD, quads );CHECK_ERR( error );
00313
00314     // get the connectivity of the second quad
00315     EntityHandle handle = *( ++quads.begin() );
00316
00317     error = MB->get_connectivity( &handle, 1, conn );CHECK_ERR( error );
00318
00319     CHECK_EQUAL( (size_t)4, conn.size() );
00320
00321     // from ncdump the connectivity of quad 2 (0 based) is
00322     // 20, 11, 12, 26,
00323
00324     CHECK_EQUAL( (EntityHandle)20, conn[0] );
00325     CHECK_EQUAL( (EntityHandle)11, conn[1] );
00326     CHECK_EQUAL( (EntityHandle)12, conn[2] );
00327     CHECK_EQUAL( (EntityHandle)26, conn[3] );
00328 }
00329
00330 void mb_hex_connectivity_test()
00331 {
00332     Core moab;
00333     Interface* MB = &moab;
00334     load_file_one( MB );
00335
00336     std::vector< EntityHandle > conn;
00337     Range hexes;
00338
00339     ErrorCode error = MB->get_entities_by_type( 0, MBHEX, hexes );CHECK_ERR( error );
00340
00341     // get the connectivity of the second hex
00342     EntityHandle handle = *( ++hexes.begin() );
00343
00344     error = MB->get_connectivity( &handle, 1, conn );CHECK_ERR( error );
00345
00346     CHECK_EQUAL( (size_t)8, conn.size() );
00347
00348     // from ncdump the connectivity of hex 1 (0 based) is
00349     // 19, 13, 16, 23, 21, 14, 18, 27
00350
00351     CHECK_EQUAL( (EntityHandle)19, conn[0] );
00352     CHECK_EQUAL( (EntityHandle)13, conn[1] );
00353     CHECK_EQUAL( (EntityHandle)16, conn[2] );
00354     CHECK_EQUAL( (EntityHandle)23, conn[3] );
00355     CHECK_EQUAL( (EntityHandle)21, conn[4] );
00356     CHECK_EQUAL( (EntityHandle)14, conn[5] );
00357     CHECK_EQUAL( (EntityHandle)18, conn[6] );
00358     CHECK_EQUAL( (EntityHandle)27, conn[7] );
00359 }
00360
00361 void mb_tet_connectivity_test()
00362 {
00363     Core moab;
00364     Interface* MB = &moab;
00365     load_file_one( MB );
00366
00367     std::vector< EntityHandle > conn;
00368     Range tets;
00369     ErrorCode error = MB->get_entities_by_type( 0, MBTET, tets );CHECK_ERR( error );
00370
00371     // get the connectivity of the second tet
00372     EntityHandle handle = *( ++tets.begin() );
00373
00374     error = MB->get_connectivity( &handle, 1, conn );CHECK_ERR( error );
00375
00376     CHECK_EQUAL( (size_t)4, conn.size() );
00377
00378     // from ncdump the connectivity of tet 2 (0 based) is:
00379     // 35, 34, 32, 43
00380
00381     CHECK_EQUAL( (EntityHandle)35, conn[0] );
00382     CHECK_EQUAL( (EntityHandle)34, conn[1] );
00383     CHECK_EQUAL( (EntityHandle)32, conn[2] );
00384     CHECK_EQUAL( (EntityHandle)43, conn[3] );
00385 }
00386
00387 void mb_write_mesh_test()
00388 {
00389     Core moab;
00390     Interface* MB = &moab;
00391     load_file_one( MB );
00392     ErrorCode result;
00393
00394     std::string file_name = "mb_write.g";
00395
00396     // no need to get lists, write out the whole mesh
00397     result = MB->write_mesh( file_name.c_str() );CHECK_ERR( result );
00398
00399     //---------The following tests outputting meshsets that are in meshsets of blocks ---/
00400
00401     // lets create a block meshset and put some entities and meshsets into it
00402     EntityHandle block_ms;
00403     result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, block_ms );CHECK_ERR( result );
00404
00405     // make another meshset to put quads in, so SHELLs can be written out
00406     EntityHandle block_of_shells;
00407     result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, block_of_shells );CHECK_ERR( result );
00408
00409     // tag the meshset so it's a block, with id 100
00410     int id = 100;
00411     Tag tag_handle;
00412     const int negone = -1;
00413     result           = MB->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result );
00414     result = MB->tag_set_data( tag_handle, &block_ms, 1, &id );CHECK_ERR( result );
00415     id     = 101;
00416     result = MB->tag_set_data( tag_handle, &block_of_shells, 1, &id );CHECK_ERR( result );
00417
00418     // set dimension tag on this to ensure shells get output; reuse id variable
00419     result = MB->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result );
00420     id     = 3;
00421     result = MB->tag_set_data( tag_handle, &block_of_shells, 1, &id );CHECK_ERR( result );
00422
00423     // get some entities (tets)
00424     Range temp_range;
00425     result = MB->get_entities_by_type( 0, MBHEX, temp_range );CHECK_ERR( result );
00426
00427     Range::iterator iter, end_iter;
00428     iter     = temp_range.begin();
00429     end_iter = temp_range.end();
00430
00431     // add evens to 'block_ms'
00432     std::vector< EntityHandle > temp_vec;
00433     for( ; iter != end_iter; ++iter )
00434     {
00435         if( ID_FROM_HANDLE( *iter ) % 2 == 0 ) temp_vec.push_back( *iter );
00436     }
00437     result = MB->add_entities( block_ms, &temp_vec[0], temp_vec.size() );CHECK_ERR( result );
00438
00439     // make another meshset
00440     EntityHandle ms_of_block_ms;
00441     result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, ms_of_block_ms );CHECK_ERR( result );
00442
00443     // add some entities to it
00444     temp_vec.clear();
00445     iter = temp_range.begin();
00446     for( ; iter != end_iter; ++iter )
00447     {
00448         if( ID_FROM_HANDLE( *iter ) % 2 )  // add all odds
00449             temp_vec.push_back( *iter );
00450     }
00451     result = MB->add_entities( ms_of_block_ms, &temp_vec[0], temp_vec.size() );CHECK_ERR( result );
00452
00453     // add the other meshset to the block's meshset
00454     result = MB->add_entities( block_ms, &ms_of_block_ms, 1 );CHECK_ERR( result );
00455
00456     //---------------testing sidesets----------------/
00457
00458     // lets create a sideset meshset and put some entities and meshsets into it
00459     EntityHandle sideset_ms;
00460     result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, sideset_ms );CHECK_ERR( result );
00461
00462     // tag the meshset so it's a sideset, with id 104
00463     id     = 104;
00464     result = MB->tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result );
00465
00466     result = MB->tag_set_data( tag_handle, &sideset_ms, 1, &id );CHECK_ERR( result );
00467
00468     // get some entities (tris)
00469     temp_range.clear();
00470     result = MB->get_entities_by_type( 0, MBQUAD, temp_range );CHECK_ERR( result );
00471
00472     iter     = temp_range.begin();
00473     end_iter = temp_range.end();
00474
00475     // add evens to 'sideset_ms'
00476     temp_vec.clear();
00477     for( ; iter != end_iter; ++iter )
00478     {
00479         if( ID_FROM_HANDLE( *iter ) % 2 == 0 ) temp_vec.push_back( *iter );
00480     }
00481     result = MB->add_entities( sideset_ms, &temp_vec[0], temp_vec.size() );CHECK_ERR( result );
00482
00483     // make another meshset
00484     EntityHandle ms_of_sideset_ms;
00485     result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, ms_of_sideset_ms );CHECK_ERR( result );
00486
00487     // add some entities to it
00488     temp_vec.clear();
00489     iter = temp_range.begin();
00490     for( ; iter != end_iter; ++iter )
00491     {
00492         if( ID_FROM_HANDLE( *iter ) % 2 )  // add all odds
00493             temp_vec.push_back( *iter );
00494     }
00495     result = MB->add_entities( ms_of_sideset_ms, &temp_vec[0], temp_vec.size() );CHECK_ERR( result );
00496
00497     // add the other meshset to the sideset's meshset
00498     result = MB->add_entities( sideset_ms, &ms_of_sideset_ms, 1 );CHECK_ERR( result );
00499
00500     //---------test sense on meshsets (reverse/foward)-------//
00501
00502     // get all quads whose x-coord = 2.5 and put them into a meshset_a
00503     EntityHandle meshset_a;
00504     result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, meshset_a );CHECK_ERR( result );
00505
00506     temp_range.clear();
00507     result = MB->get_entities_by_type( 0, MBQUAD, temp_range );CHECK_ERR( result );
00508
00509     std::vector< EntityHandle > nodes1, entity_vec;
00510     std::copy( temp_range.begin(), temp_range.end(), std::back_inserter( entity_vec ) );
00511     result = MB->get_connectivity( &entity_vec[0], entity_vec.size(), nodes1 );CHECK_ERR( result );
00512     assert( nodes1.size() == 4 * temp_range.size() );
00513     temp_vec.clear();
00514     std::vector< double > coords( 3 * nodes1.size() );
00515     result = MB->get_coords( &nodes1[0], nodes1.size(), &coords[0] );CHECK_ERR( result );
00516
00517     unsigned int k = 0;
00518     for( Range::iterator it = temp_range.begin(); it != temp_range.end(); ++it )
00519     {
00520         if( coords[12 * k] == 2.5 && coords[12 * k + 3] == 2.5 && coords[12 * k + 6] == 2.5 &&
00521             coords[12 * k + 9] == 2.5 )
00522             temp_vec.push_back( *it );
00523         k++;
00524     }
00525     result = MB->add_entities( meshset_a, ( temp_vec.empty() ) ? NULL : &temp_vec[0], temp_vec.size() );CHECK_ERR( result );
00526     result = MB->add_entities( block_of_shells, ( temp_vec.empty() ) ? NULL : &temp_vec[0], temp_vec.size() );CHECK_ERR( result );
00527
00528     // put these quads into a different meshset_b and tag them with a reverse sense tag
00529     EntityHandle meshset_b;
00530     result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, meshset_b );CHECK_ERR( result );
00531
00532     result = MB->add_entities( meshset_b, &meshset_a, 1 );CHECK_ERR( result );
00533
00534     result = MB->tag_get_handle( "SENSE", 1, MB_TYPE_INTEGER, tag_handle, MB_TAG_SPARSE | MB_TAG_CREAT );CHECK_ERR( result );
00535
00536     int reverse_value = -1;
00537     result            = MB->tag_set_data( tag_handle, &meshset_b, 1, &reverse_value );CHECK_ERR( result );
00538
00539     // get some random quad, whose x-coord != 2.5, and put it into a different meshset_c
00540     // and tag it with a reverse sense tag
00541
00542     iter     = temp_range.begin();
00543     end_iter = temp_range.end();
00544
00545     temp_vec.clear();
00546     for( ; iter != end_iter; ++iter )
00547     {
00548         std::vector< EntityHandle > nodes;
00549         result = MB->get_connectivity( &( *iter ), 1, nodes );CHECK_ERR( result );
00550
00551         bool not_equal_2_5 = true;
00552         for( unsigned int ku = 0; ku < nodes.size(); ku++ )
00553         {
00554             double coords2[3] = { 0 };
00555
00556             result = MB->get_coords( &( nodes[ku] ), 1, coords2 );CHECK_ERR( result );
00557
00558             if( coords2[0] == 2.5 )
00559             {
00560                 not_equal_2_5 = false;
00561                 break;
00562             }
00563         }
00564
00565         if( not_equal_2_5 && nodes.size() > 0 )
00566         {
00567             temp_vec.push_back( *iter );
00568             break;
00569         }
00570     }
00571
00572     EntityHandle meshset_c;
00573     MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, meshset_c );
00574
00575     result = MB->tag_get_handle( "SENSE", 1, MB_TYPE_INTEGER, tag_handle );CHECK_ERR( result );
00576
00577     reverse_value = -1;
00578     result        = MB->tag_set_data( tag_handle, &meshset_c, 1, &reverse_value );CHECK_ERR( result );
00579
00580     MB->add_entities( meshset_c, &temp_vec[0], temp_vec.size() );
00581     MB->add_entities( block_of_shells, &temp_vec[0], temp_vec.size() );
00582
00583     // create another meshset_abc, adding meshset_a, meshset_b, meshset_c
00584     EntityHandle meshset_abc;
00585     MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, meshset_abc );
00586
00587     temp_vec.clear();
00588     temp_vec.push_back( meshset_a );
00589     temp_vec.push_back( meshset_b );
00590     temp_vec.push_back( meshset_c );
00591
00592     MB->add_entities( meshset_abc, &temp_vec[0], temp_vec.size() );
00593
00594     // tag it so it's a sideset
00595     id     = 444;
00596     result = MB->tag_get_handle( "NEUMANN_SET", 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result );
00597
00598     result = MB->tag_set_data( tag_handle, &meshset_abc, 1, &id );CHECK_ERR( result );
00599
00600     //---------------do nodesets now -----------------//
00601
00602     // lets create a nodeset meshset and put some entities and meshsets into it
00603     EntityHandle nodeset_ms;
00604     MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, nodeset_ms );
00605
00606     // tag the meshset so it's a nodeset, with id 119
00607     id     = 119;
00608     result = MB->tag_get_handle( DIRICHLET_SET_TAG_NAME, 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result );
00609
00610     result = MB->tag_set_data( tag_handle, &nodeset_ms, 1, &id );CHECK_ERR( result );
00611
00612     // get all Quads
00613     temp_range.clear();
00614     result = MB->get_entities_by_type( 0, MBQUAD, temp_range );CHECK_ERR( result );
00615
00616     // get all the nodes of the tris
00617     Range nodes_of_quads;
00618     iter     = temp_range.begin();
00619     end_iter = temp_range.end();
00620
00621     for( ; iter != end_iter; ++iter )
00622     {
00623         std::vector< EntityHandle > nodes;
00624         result = MB->get_connectivity( &( *iter ), 1, nodes );CHECK_ERR( result );
00625
00626         for( unsigned int ku = 0; ku < nodes.size(); ku++ )
00627             nodes_of_quads.insert( nodes[ku] );
00628     }
00629
00630     iter     = nodes_of_quads.begin();
00631     end_iter = nodes_of_quads.end();
00632
00633     // add evens to 'nodeset_ms'
00634     temp_vec.clear();
00635     for( ; iter != end_iter; ++iter )
00636     {
00637         if( ID_FROM_HANDLE( *iter ) % 2 == 0 ) temp_vec.push_back( *iter );
00638     }
00639     MB->add_entities( nodeset_ms, &temp_vec[0], temp_vec.size() );
00640
00641     // make another meshset
00642     EntityHandle ms_of_nodeset_ms;
00643     MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, ms_of_nodeset_ms );
00644
00645     // add some entities to it
00646     temp_vec.clear();
00647     iter     = nodes_of_quads.begin();
00648     end_iter = nodes_of_quads.end();
00649     for( ; iter != end_iter; ++iter )
00650     {
00651         if( ID_FROM_HANDLE( *iter ) % 2 )  // add all odds
00652             temp_vec.push_back( *iter );
00653     }
00654     MB->add_entities( ms_of_nodeset_ms, &temp_vec[0], temp_vec.size() );
00655
00656     // add the other meshset to the nodeset's meshset
00657     MB->add_entities( nodeset_ms, &ms_of_nodeset_ms, 1 );
00658
00659     // no need to get lists, write out the whole mesh
00660     file_name = "mb_write2.g";
00661     std::vector< EntityHandle > output_list;
00662     output_list.push_back( block_ms );
00663     output_list.push_back( sideset_ms );
00664     output_list.push_back( meshset_abc );
00665     output_list.push_back( nodeset_ms );
00666     output_list.push_back( block_of_shells );
00667     result = MB->write_mesh( file_name.c_str(), &output_list[0], output_list.size() );CHECK_ERR( result );
00668 }
00669
00670 struct TestType
00671 {
00672     EntityType moab_type;
00673     ExoIIElementType exo_type;
00674     int num_nodes;
00675     std::string name;
00676 };
00677
00678 void check_type( const TestType& type )
00679 {
00680     int has_mid_nodes[4];
00681     CN::HasMidNodes( type.moab_type, type.num_nodes, has_mid_nodes );
00682
00683     CHECK_EQUAL( type.moab_type, ExoIIUtil::ExoIIElementMBEntity[type.exo_type] );
00684     CHECK_EQUAL( type.name, std::string( ExoIIUtil::ElementTypeNames[type.exo_type] ) );
00685     CHECK_EQUAL( type.num_nodes, ExoIIUtil::VerticesPerElement[type.exo_type] );
00686     auto dim = CN::Dimension( type.moab_type );
00687     if( 3 == dim ) CHECK_EQUAL( has_mid_nodes[3], ExoIIUtil::HasMidNodes[type.exo_type][3] );
00688     if( 2 <= dim ) CHECK_EQUAL( has_mid_nodes[2], ExoIIUtil::HasMidNodes[type.exo_type][2] );
00689     if( 1 <= dim ) CHECK_EQUAL( has_mid_nodes[1], ExoIIUtil::HasMidNodes[type.exo_type][1] );
00690
00691     Core moab;
00692     ExoIIUtil tool( &moab );
00693     CHECK_EQUAL( type.exo_type, tool.element_name_to_type( type.name.c_str() ) );
00694     CHECK_EQUAL( type.name, std::string( tool.element_type_name( type.exo_type ) ) );
00695 }
00696
00697 void test_types()
00698 {
00699     const TestType types[] = { { MBVERTEX, EXOII_SPHERE, 1, "SPHERE" },
00700                                { MBEDGE, EXOII_SPRING, 1, "SPRING" },
00701                                { MBEDGE, EXOII_BAR, 2, "BAR" },
00702                                { MBEDGE, EXOII_BAR2, 2, "BAR2" },
00703                                { MBEDGE, EXOII_BAR3, 3, "BAR3" },
00704                                { MBEDGE, EXOII_BEAM, 2, "BEAM" },
00705                                { MBEDGE, EXOII_BEAM2, 2, "BEAM2" },
00706                                { MBEDGE, EXOII_BEAM3, 3, "BEAM3" },
00707                                { MBEDGE, EXOII_TRUSS, 2, "TRUSS" },
00708                                { MBEDGE, EXOII_TRUSS2, 2, "TRUSS2" },
00709                                { MBEDGE, EXOII_TRUSS3, 3, "TRUSS3" },
00710                                { MBTRI, EXOII_TRI, 3, "TRI" },
00711                                { MBTRI, EXOII_TRI3, 3, "TRI3" },
00712                                { MBTRI, EXOII_TRI6, 6, "TRI6" },
00713                                { MBTRI, EXOII_TRI7, 7, "TRI7" },
00714                                { MBQUAD, EXOII_QUAD, 4, "QUAD" },
00715                                { MBQUAD, EXOII_QUAD4, 4, "QUAD4" },
00716                                { MBQUAD, EXOII_QUAD5, 5, "QUAD5" },
00717                                { MBQUAD, EXOII_QUAD8, 8, "QUAD8" },
00718                                { MBQUAD, EXOII_QUAD9, 9, "QUAD9" },
00719                                { MBQUAD, EXOII_SHELL, 4, "SHELL" },
00720                                { MBQUAD, EXOII_SHELL4, 4, "SHELL4" },
00721                                { MBQUAD, EXOII_SHELL5, 5, "SHELL5" },
00722                                { MBQUAD, EXOII_SHELL8, 8, "SHELL8" },
00723                                { MBQUAD, EXOII_SHELL9, 9, "SHELL9" },
00724                                { MBTET, EXOII_TETRA, 4, "TETRA" },
00725                                { MBTET, EXOII_TETRA4, 4, "TETRA4" },
00726                                { MBTET, EXOII_TET4, 4, "TET4" },
00727                                { MBTET, EXOII_TETRA8, 8, "TETRA8" },
00728                                { MBTET, EXOII_TETRA10, 10, "TETRA10" },
00729                                { MBTET, EXOII_TETRA14, 14, "TETRA14" },
00730                                { MBPYRAMID, EXOII_PYRAMID, 5, "PYRAMID" },
00731                                { MBPYRAMID, EXOII_PYRAMID5, 5, "PYRAMID5" },
00732                                { MBPYRAMID, EXOII_PYRAMID10, 10, "PYRAMID10" },
00733                                { MBPYRAMID, EXOII_PYRAMID13, 13, "PYRAMID13" },
00734                                { MBPYRAMID, EXOII_PYRAMID18, 18, "PYRAMID18" },
00735                                { MBPRISM, EXOII_WEDGE, 6, "WEDGE" },
00736                                { MBKNIFE, EXOII_KNIFE, 7, "KNIFE" },
00737                                { MBHEX, EXOII_HEX, 8, "HEX" },
00738                                { MBHEX, EXOII_HEX8, 8, "HEX8" },
00739                                { MBHEX, EXOII_HEX9, 9, "HEX9" },
00740                                { MBHEX, EXOII_HEX20, 20, "HEX20" },
00741                                { MBHEX, EXOII_HEX27, 27, "HEX27" },
00742                                { MBHEX, EXOII_HEXSHELL, 12, "HEXSHELL" } };
00743     const int num_types    = sizeof( types ) / sizeof( types[0] );
00744     for( int i = 0; i < num_types; ++i )
00745         check_type( types[i] );
00746 }
00747
00748 void read_file( Interface& moab, const char* input_file )
00749 {
00750     ErrorCode rval = moab.load_file( input_file );CHECK_ERR( rval );
00751 }
00752
00753 void write_and_read( Interface& write_mb, Interface& read_mb, EntityHandle block = 0 )
00754 {
00755     const char* tmp_file = "exodus_test_tmp.g";
00756     ErrorCode rval;
00757
00758     EntityHandle* write_set_list = &block;
00759     int write_set_list_len       = 0;  //(block != 0);
00760     rval                         = write_mb.write_file( tmp_file, "EXODUS", 0, write_set_list, write_set_list_len );
00761     if( MB_SUCCESS != rval ) remove( tmp_file );CHECK_ERR( rval );
00762
00763     rval = read_mb.load_file( tmp_file );
00764     remove( tmp_file );CHECK_ERR( rval );
00765 }
00766
00767 void check_ho_elements( Interface& moab, EntityHandle block, EntityType type, int mid_nodes[4] )
00768 {
00769     ErrorCode rval;
00770     Range elems;
00771     rval = moab.get_entities_by_handle( block, elems, ( type != MBENTITYSET ? true : false ) );CHECK_ERR( rval );
00772     CHECK( !elems.empty() );
00773     CHECK( elems.all_of_type( type ) );
00774     for( Range::const_iterator i = elems.begin(); i != elems.end(); ++i )
00775         check_ho_element( moab, *i, mid_nodes );
00776 }
00777
00778 // Check that element has expected higher-order nodes
00779 // and that each higher-order node is at the center
00780 // of the sub-entity it is on.
00781 void check_ho_element( Interface& moab, EntityHandle entity, int mid_nodes[4] )
00782 {
00783     // get element info
00784     const EntityType type = TYPE_FROM_HANDLE( entity );
00785     const EntityHandle* conn;
00786     int conn_len;
00787     ErrorCode rval = moab.get_connectivity( entity, conn, conn_len );CHECK_ERR( rval );
00788     std::vector< double > coords( 3 * conn_len );
00789     rval = moab.get_coords( conn, conn_len, &coords[0] );CHECK_ERR( rval );
00790
00791     // calculate and verify expected number of mid nodes
00792     int num_nodes = CN::VerticesPerEntity( type );
00793     for( int d = 1; d <= CN::Dimension( type ); ++d )
00794         if( mid_nodes[d] ) num_nodes += CN::NumSubEntities( type, d );
00795     CHECK_EQUAL( num_nodes, conn_len );
00796
00797     // verify that each higher-order node is at the center
00798     // of its respective sub-entity.
00799     for( int i = CN::VerticesPerEntity( type ); i < num_nodes; ++i )
00800     {
00801         // get sub-entity owning ho-node
00802         int sub_dim, sub_num;
00803         CN::HONodeParent( type, num_nodes, i, sub_dim, sub_num );
00804         // get corner vertex indices
00805         int sub_conn[8], num_sub;
00806         if( sub_dim < CN::Dimension( type ) )
00807         {
00808             CN::SubEntityVertexIndices( type, sub_dim, sub_num, sub_conn );
00809             EntityType sub_type = CN::SubEntityType( type, sub_dim, sub_num );
00810             num_sub             = CN::VerticesPerEntity( sub_type );
00811         }
00812         else
00813         {
00814             num_sub = CN::VerticesPerEntity( type );
00815             for( int j = 0; j < num_sub; ++j )
00816                 sub_conn[j] = j;
00817         }
00818         // calculate mean of corner vertices
00819         double mean[3] = { 0, 0, 0 };
00820         for( int j = 0; j < num_sub; ++j )
00821         {
00822             int co = 3 * sub_conn[j];
00823             mean[0] += coords[co];
00824             mean[1] += coords[co + 1];
00825             mean[2] += coords[co + 2];
00826         }
00827         mean[0] /= num_sub;
00828         mean[1] /= num_sub;
00829         mean[2] /= num_sub;
00830         // verify that higher-order node is at expected location
00831         CHECK_REAL_EQUAL( mean[0], coords[3 * i], 1e-6 );
00832         CHECK_REAL_EQUAL( mean[1], coords[3 * i + 1], 1e-6 );
00833         CHECK_REAL_EQUAL( mean[2], coords[3 * i + 2], 1e-6 );
00834     }
00835 }
00836
00837 EntityHandle find_block( Interface& mb, EntityType type, const int has_mid_nodes[4] )
00838 {
00839
00840     ErrorCode rval;
00841     Tag ho_tag, block_tag;
00842     const int negone = -1;
00843     rval             = mb.tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, block_tag, 0, &negone );CHECK_ERR( rval );
00844     const int mids[] = { -1, -1, -1, -1 };
00845     rval             = mb.tag_get_handle( HAS_MID_NODES_TAG_NAME, 4, MB_TYPE_INTEGER, ho_tag, 0, mids );CHECK_ERR( rval );
00846
00847     // get material sets with expected higher-order nodes
00848     Range blocks;
00849     Tag tags[2]         = { ho_tag, block_tag };
00850     const void* vals[2] = { has_mid_nodes, NULL };
00851     rval                = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, tags, vals, 2, blocks );CHECK_ERR( rval );
00852
00853     for( Range::iterator i = blocks.begin(); i != blocks.end(); ++i )
00854     {
00855         int n;
00856         rval = mb.get_number_entities_by_type( *i, type, n );CHECK_ERR( rval );
00857         if( n > 0 ) return *i;
00858     }
00859
00860     CHECK( false );  // no block matching element type description
00861     return 0;
00862 }
00863
00864 EntityHandle find_sideset( Interface& mb, int sideset_id, EntityType /*side_type*/ )
00865 {
00866     ErrorCode rval;
00867     Tag ss_tag;
00868     const int negone = -1;
00869     rval             = mb.tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, ss_tag, 0, &negone );CHECK_ERR( rval );
00870
00871     const void* tag_vals[] = { &sideset_id };
00872     Range side_sets;
00873     rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &ss_tag, tag_vals, 1, side_sets );CHECK_ERR( rval );
00874     CHECK_EQUAL( 1, (int)side_sets.size() );
00875     return side_sets.front();
00876 }
00877
00878 // Validate elements of specified type.
00879 // Looks for a block containing the specified entity type
00880 // and with the specified mid-node flags set in its
00881 // HAS_MID_NODES_TAG.
00882 void test_ho_elements( EntityType type, int num_nodes )
00883 {
00884     Core mb_impl1, mb_impl2;
00885     Interface &mb1 = mb_impl1, &mb2 = mb_impl2;
00886     int ho_flags[4];
00887     CN::HasMidNodes( type, num_nodes, ho_flags );
00888
00889     // read file
00890     read_file( mb1, ho_file );
00891     // test element connectivity order
00892     EntityHandle block = find_block( mb1, type, ho_flags );
00893     CHECK( block != 0 );
00894     check_ho_elements( mb1, block, type, ho_flags );
00895
00896     // write block and read it back in
00897     write_and_read( mb1, mb2, block );
00898     // test element connectivity order on re-read data
00899     block = find_block( mb2, type, ho_flags );
00900     CHECK( block != 0 );
00901     check_ho_elements( mb2, block, type, ho_flags );
00902 }
00903
00904 void test_read_side( int id, EntityType sideset_type, int sideset_nodes_per_elem, bool shell_side )
00905 {
00906     // read test file
00907     Core mb_impl;
00908     Interface& moab = mb_impl;
00909     read_file( moab, ho_file );
00910
00911     // get side set
00912     EntityHandle set = find_sideset( moab, id, sideset_type );
00913     CHECK( set != 0 );
00914
00915     // check expected element connectivity
00916     int ho_flags[4];
00917     CN::HasMidNodes( sideset_type, sideset_nodes_per_elem, ho_flags );
00918     check_ho_elements( moab, set, sideset_type, ho_flags );
00919
00920     if( shell_side ) return;
00921
00922     // check that each element is on the boundary of the mesh
00923     Range elems;
00924     ErrorCode rval = mb_impl.get_entities_by_handle( set, elems );CHECK_ERR( rval );
00925
00926     int dim = CN::Dimension( sideset_type );
00927     for( Range::iterator i = elems.begin(); i != elems.end(); ++i )
00928     {
00929         Range adj;
00930         rval = mb_impl.get_adjacencies( &*i, 1, dim + 1, false, adj, Interface::UNION );CHECK_ERR( rval );
00931         CHECK_EQUAL( 1, (int)adj.size() );
00932     }
00933 }
00934
00935 void test_read_ids_common( const char* file_name, const char* tag_name, const int* expected_vals, int num_expected )
00936 {
00937     Core mb;
00938     ReadNCDF reader( &mb );
00939
00940     FileOptions opts( "" );
00941     std::vector< int > values;
00942     ErrorCode rval = reader.read_tag_values( file_name, tag_name, opts, values );CHECK_ERR( rval );
00943
00944     std::vector< int > expected( expected_vals, expected_vals + num_expected );
00945     std::sort( values.begin(), values.end() );
00946     std::sort( expected.begin(), expected.end() );
00947     CHECK_EQUAL( expected, values );
00948 }
00949
00950 void test_read_block_ids()
00951 {
00952     const int expected[] = { 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13 };
00953     test_read_ids_common( ho_file, MATERIAL_SET_TAG_NAME, expected, sizeof( expected ) / sizeof( expected[0] ) );
00954 }
00955
00956 void test_read_sideset_ids()
00957 {
00958     const int expected[] = { 1, 2, 3, 4 };
00959     test_read_ids_common( ho_file, NEUMANN_SET_TAG_NAME, expected, sizeof( expected ) / sizeof( expected[0] ) );
00960 }
00961
00962 void test_read_nodeset_ids()
00963 {
00964     test_read_ids_common( ho_file, DIRICHLET_SET_TAG_NAME, 0, 0 );
00965 }
00966
00967 void test_read_alternate_coord_format()
00968 {
00969     Core moab;
00970     Interface& mb  = moab;
00971     ErrorCode rval = mb.load_file( alt_file );CHECK_ERR( rval );
00972
00973     const double exp[] = { 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 0, 0, 1, 1, 0, 1, 1, 1, 1, 0, 1, 1 };
00974
00975     Range hexes;
00976     rval = mb.get_entities_by_type( 0, MBHEX, hexes );CHECK_ERR( rval );
00977     CHECK_EQUAL( (size_t)1, hexes.size() );
00978     EntityHandle hex = hexes.front();
00979     const EntityHandle* conn;
00980     int len;
00981     rval = mb.get_connectivity( hex, conn, len );CHECK_ERR( rval );
00982     CHECK_EQUAL( 8, len );
00983     double act[3 * 8];
00984     rval = mb.get_coords( conn, len, act );CHECK_ERR( rval );
00985     CHECK_ARRAYS_EQUAL( exp, 3 * 8, act, 3 * 8 );
00986 }
00987 void test_write_polygons()
00988 {
00989     Core moab;
00990     Interface& mb  = moab;
00991     ErrorCode rval = mb.load_file( polyg );CHECK_ERR( rval );
00992     rval = mb.write_file( "polyg.exo" );CHECK_ERR( rval );
00993 }
00994
00995 void test_write_polyhedra()
00996 {
00997     Core moab;
00998     Interface& mb  = moab;
00999     ErrorCode rval = mb.load_file( polyh );CHECK_ERR( rval );
01000     rval = mb.write_file( "polyh.exo" );CHECK_ERR( rval );
01001 }
01002 void test_read_polygons()
01003 {
01004     Core moab;
01005     Interface& mb  = moab;
01006     ErrorCode rval = mb.load_file( rpolyg );CHECK_ERR( rval );
01007 }
01008 void test_read_polyhedra()
01009 {
01010     Core moab;
01011     Interface& mb  = moab;
01012     ErrorCode rval = mb.load_file( rpolyh );CHECK_ERR( rval );
01013 }
