MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iostream>
#include <sstream>
#include <ctime>
#include <cstdlib>
#include <cstdio>
#include <cstring>
#include "moab/Core.hpp"
#include "moab/Interface.hpp"
#include "moab/IntxMesh/Intx2MeshInPlane.hpp"
#include "moab/IntxMesh/IntxUtils.hpp"
#include "TestUtil.hpp"
#include <cmath>
Functions | |
int | main (int argc, char *argv[]) |
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 21 of file intx_in_plane_test.cpp.
References moab::Interface::add_entities(), moab::Interface::create_meshset(), edges, ErrorCode, moab::Intx2Mesh::FindMaxEdges(), moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_type(), moab::Intx2Mesh::intersect_meshes(), moab::Interface::load_file(), mb, MB_CHK_ERR, MB_SUCCESS, MBPOLYGON, MESHSET_SET, moab::IntxAreaUtils::positive_orientation(), moab::Intx2Mesh::set_error_tolerance(), moab::Range::size(), STRINGIFY, moab::Interface::UNION, and moab::Interface::write_mesh().
{ // check command line arg const char* filename_mesh1 = STRINGIFY( MESHDIR ) "/mbcslam/m1.vtk"; const char* filename_mesh2 = STRINGIFY( MESHDIR ) "/mbcslam/m2.vtk"; const char* newFile = "intx1.vtk"; const char* edgesFile = "polyWithEdges.vtk"; if( argc == 4 ) { filename_mesh1 = argv[1]; filename_mesh2 = argv[2]; newFile = argv[3]; } else { printf( "Usage: %s <mesh_filename1> <mesh_filename2> <newFile>\n", argv[0] ); if( argc != 1 ) return 1; printf( "No files specified. Defaulting to: %s %s %s\n", filename_mesh1, filename_mesh2, newFile ); } // read meshes in 2 file sets Core moab; Interface* mb = &moab; // global EntityHandle sf1, sf2; ErrorCode rval = mb->create_meshset( MESHSET_SET, sf1 ); if( MB_SUCCESS != rval ) return 1; rval = mb->create_meshset( MESHSET_SET, sf2 ); if( MB_SUCCESS != rval ) return 1; rval = mb->load_file( filename_mesh1, &sf1 ); if( MB_SUCCESS != rval ) return 1; rval = mb->load_file( filename_mesh2, &sf2 ); if( MB_SUCCESS != rval ) return 1; EntityHandle outputSet; rval = mb->create_meshset( MESHSET_SET, outputSet ); if( MB_SUCCESS != rval ) return 1; Intx2MeshInPlane worker( mb ); IntxAreaUtils areaAdaptor; rval = areaAdaptor.positive_orientation( mb, sf1, -1 );MB_CHK_ERR( rval ); rval = areaAdaptor.positive_orientation( mb, sf2, -1 );MB_CHK_ERR( rval ); worker.set_error_tolerance( 1.e-5 ); rval = worker.FindMaxEdges( sf1, sf2 );MB_CHK_ERR( rval ); // worker.enable_debug(); rval = worker.intersect_meshes( sf1, sf2, outputSet ); if( MB_SUCCESS != rval ) return 1; rval = mb->write_mesh( newFile, &outputSet, 1 ); if( MB_SUCCESS != rval ) return 1; // retrieve polygons and get adjacent edges Range polygons; rval = mb->get_entities_by_type( outputSet, MBPOLYGON, polygons ); if( MB_SUCCESS != rval ) return 1; Range edges; rval = mb->get_adjacencies( polygons, 1, true, edges, Interface::UNION ); if( MB_SUCCESS != rval ) return 1; std::cout << "number of edges:" << edges.size() << "\n"; // add edges to the output set rval = mb->add_entities( outputSet, edges ); if( MB_SUCCESS != rval ) return 1; rval = mb->write_mesh( edgesFile, &outputSet, 1 ); if( MB_SUCCESS != rval ) return 1; return 0; }
