cgma
00001 00023 #include "InitCGMA.hpp" 00024 #include "GMem.hpp" 00025 #include <iostream> 00026 #include <limits> 00027 #include <math.h> 00028 #include "GeometryQueryTool.hpp" 00029 #include "CubitCompat.hpp" 00030 #include "CCubitFile.hpp" 00031 00032 #include "cgm/CGMConfig.h" 00033 00034 00035 #ifdef ITAPS_SHIM 00036 # include "iGeom_private.h" 00037 # include "iGeom_binding.h" 00038 # include "CGM_iGeom.h" 00039 # define ITAPS_API static 00040 #else 00041 # include "iGeom.h" 00042 # define ITAPS_API 00043 #endif 00044 00045 const bool debug = false; 00046 00047 #define RETURN(a) do {CGM_iGeom_setLastError((*err = a)); return; } while(false) 00048 #define ERROR(a, b) do {CGM_iGeom_setLastError((*err = a), b); return; } while(false) 00049 00050 #define ARRAY_IN(b) \ 00051 b, b ## _size 00052 00053 #define ARRAY_INOUT(b) \ 00054 b, b ## _allocated, b ## _size 00055 00056 // Check the array size, and allocate the array if necessary. 00057 // Free the array upon leaving scope unless KEEP_ARRAY 00058 // is invoked. 00059 #define ALLOC_CHECK_ARRAY(array, this_size) \ 00060 iGeomArrayManager array ## _manager ( reinterpret_cast<void**>(array), *(array ## _allocated), *(array ## _size), this_size, sizeof(**array), err ); \ 00061 if (iBase_SUCCESS != *err) return 00062 00063 #define KEEP_ARRAY(array) \ 00064 array ## _manager .keep_array() 00065 00066 // Check the array size, and allocate the array if necessary. 00067 // Do NOT free the array upon leaving scope. 00068 #define ALLOC_CHECK_ARRAY_NOFAIL(array, this_size) \ 00069 ALLOC_CHECK_ARRAY(array, this_size); KEEP_ARRAY(array) 00070 00071 #define TAG_HANDLE(handle) reinterpret_cast<long>(handle) 00072 00073 #define ENTITY_HANDLE(handle) reinterpret_cast<RefEntity*>(handle) 00074 #define SET_HANDLE(handle) reinterpret_cast<RefGroup*>(handle) 00075 00076 #define ENTITY_HANDLE_ARRAY(array) reinterpret_cast<RefEntity**>(array) 00077 #define SET_HANDLE_ARRAY(array) reinterpret_cast<RefGroup**>(array) 00078 00079 #define ENTITY_HANDLE_CONST_ARRAY(array) reinterpret_cast<RefEntity* const*>(array) 00080 #define SET_HANDLE_CONST_ARRAY(array) reinterpret_cast<RefGroup* const*>(array) 00081 00082 #define ENTITY_HANDLE_ARRAY_PTR(array) reinterpret_cast<RefEntity***>(array) 00083 #define SET_HANDLE_ARRAY_PTR(array) reinterpret_cast<RefGroup***>(array) 00084 00085 #define CAST_TO_VOID(ptr) reinterpret_cast<void*>(ptr) 00086 #define TAG_HANDLE_ARRAY_INOUT(a) reinterpret_cast<long**>(a), a ## _allocated, a ## _size 00087 00088 #define TM reinterpret_cast<CGMTagManager*>(instance) 00089 00090 const double RAD_TO_DEG = 180.0 / acos(-1.0); 00091 const double DEG_TO_RAD = 1.0 / RAD_TO_DEG; 00092 00093 #include "CATag.hpp" 00094 #include "CGMAIterator.hpp" 00095 #include "iGeomError.h" 00096 00097 #include "RefEntityFactory.hpp" 00098 #include "BasicTopologyEntity.hpp" 00099 #include "RefGroup.hpp" 00100 #include "Body.hpp" 00101 #include "RefVertex.hpp" 00102 #include "RefEdge.hpp" 00103 #include "RefFace.hpp" 00104 #include "RefVolume.hpp" 00105 #include "CubitVector.hpp" 00106 00107 #ifdef USE_MPI 00108 #include "CGMReadParallel.hpp" 00109 #endif 00110 00111 #include "CGMApp.hpp" 00112 #include "GeometryModifyTool.hpp" 00113 #include "Surface.hpp" 00114 #include "BasicTopologyEntity.hpp" 00115 #include "CubitFile.hpp" 00116 #include "CubitDefines.h" 00117 #include "MergeTool.hpp" 00118 #include "GeometryDefines.h" 00119 00120 #define gqt GeometryQueryTool::instance() 00121 #define gmt GeometryModifyTool::instance() 00122 00123 const char *iGeom_entity_type_names[] = {"vertex", "curve", "surface", "body"}; 00124 const char *cgm_type_names[] = {"vertex", "curve", "surface", "volume", "body"}; 00125 00126 // Implement RAII pattern for allocated arrays 00127 class iGeomArrayManager 00128 { 00129 void** arrayPtr; 00130 00131 public: 00132 00133 00134 iGeomArrayManager( void** array_ptr, 00135 int& array_allocated_space, 00136 int& array_size, 00137 int count, 00138 int val_size, 00139 int* err ) : arrayPtr(0) 00140 { 00141 if (!*array_ptr) { 00142 *array_ptr = malloc(val_size * count); 00143 array_allocated_space = array_size = count; 00144 if (!*array_ptr) { 00145 ERROR(iBase_MEMORY_ALLOCATION_FAILED, "Couldn't allocate array."); 00146 } 00147 arrayPtr = array_ptr; 00148 } 00149 else { 00150 array_size = count; 00151 if (array_allocated_space < count) { 00152 ERROR(iBase_BAD_ARRAY_DIMENSION, 00153 "Allocated array not large enough to hold returned contents."); 00154 } 00155 } 00156 RETURN(iBase_SUCCESS); 00157 } 00158 00159 ~iGeomArrayManager() 00160 { 00161 if (arrayPtr) { 00162 free(*arrayPtr); 00163 *arrayPtr = 0; 00164 } 00165 } 00166 00167 void keep_array() 00168 { arrayPtr = 0; } 00169 }; 00170 00171 00172 // declare private-type functions here, so they aren't visible outside 00173 // this implementation file 00174 00175 /* Helper functions 00176 * Declare these outside the 'extern "C"' block because they are not 00177 * extern. 00178 */ 00179 static void 00180 iGeom_get_adjacent_entities( const RefEntity *from, 00181 const int to_dim, 00182 DLIList<RefEntity*> &adj_ents, 00183 int* err); 00184 00185 static void tokenize( const std::string& str, 00186 std::vector<std::string>& tokens ); 00187 00188 // Expect option of the form "NAME=VALUE". 00189 // If NAME portion matches, pass back VALUE and return true. 00190 // Otherwise, leave 'value' unchanged and return false. 00191 static bool match_option( const std::string& opt, 00192 const char* name, 00193 std::string& value ); 00194 00195 static void 00196 iGeom_load_cub_geometry(const char *name, int* err) ; 00197 00198 static iBase_ErrorType 00199 process_attribs(iGeom_Instance instance, DLIList<RefEntity*> &ref_list) ; 00200 00201 static void 00202 iGeom_get_adjacent_entities( const RefEntity *from, 00203 const int to_dim, 00204 DLIList<RefEntity*> &adj_ents, 00205 int* err ) ; 00206 /* Common implementation for both single-entity and array functions. */ 00207 static CubitStatus iGeom_closest_point( RefEntity* this_entity, 00208 const CubitVector& near, 00209 CubitVector& on ); 00210 00211 static CubitStatus iGeom_closest_point_trimmed( RefEntity* this_entity, 00212 const CubitVector& near, 00213 CubitVector& on ); 00214 00215 static CubitStatus 00216 iGeom_closest_point_and_normal( RefEntity* this_entity, 00217 const CubitVector& near, 00218 CubitVector& on, 00219 CubitVector& normal ); 00220 static CubitStatus 00221 iGeom_bounding_box( RefEntity* entity, CubitVector& minc, CubitVector& maxc ); 00222 00224 /* 00225 static inline void box_min_max( double dir, 00226 double min, 00227 double max, 00228 double pt, 00229 double& tmin, 00230 double& tmax ); 00231 */ 00232 /* 00233 static bool 00234 iBase_intersect_ray_box( const CubitBox& box, 00235 const CubitVector& point, 00236 const CubitVector& direction ); 00237 */ 00238 00239 static CubitStatus 00240 iGeom_fire_ray( const CubitVector& point, 00241 const CubitVector& direction, 00242 DLIList<RefEntity*>& entities, 00243 DLIList<double>& ray_params ); 00244 00245 static RefEntity* 00246 iGeom_get_point_containment( const CubitVector& pt ); 00247 00248 static int iGeom_get_nonmanifold_sense( const BasicTopologyEntity* child, 00249 const BasicTopologyEntity* parent, 00250 int* err ); 00251 00252 static 00253 int iGeom_edge_vertex_sense( const RefEdge* cedge, 00254 const RefVertex* vtx1, 00255 const RefVertex* vtx2, 00256 int* err ); 00257 00258 static int iGeom_is_parametric( RefEntity* entity ); 00259 00260 static iBase_ErrorType 00261 iGeom_get_vtx_to_u(RefVertex* vertex, RefEdge* edge, double& u); 00262 00263 static iBase_ErrorType 00264 iGeom_get_vtx_to_uv(RefVertex* vertex, RefFace* face, double& u, double& uv); 00265 00266 00267 static CubitStatus 00268 iGeom_normal_from_uv( RefFace* face, double u, double v, CubitVector& normal ); 00269 00270 static CubitStatus iGeom_is_periodic( RefEntity* entity, int& u, int& v ); 00271 00272 static bool iGeom_is_face_degenerate( RefFace* face ); 00273 00274 static 00275 int count_ibase_type( int ibase_type, 00276 const DLIList<CubitEntity*>& list, 00277 int* err ); 00278 00279 static 00280 void copy_ibase_type( int ibase_type, 00281 const DLIList<CubitEntity*>& list, 00282 iBase_EntityHandle** entity_handles, 00283 int* entity_handles_alloc, 00284 int* entity_handles_size, 00285 int* err ); 00286 00287 static 00288 void append_ibase_type( int ibase_type, 00289 const DLIList<CubitEntity*>& source_list, 00290 DLIList<RefEntity*>& target_list, 00291 int* err ); 00292 static 00293 void append_all_ibase_type( int ibase_type, 00294 DLIList<RefEntity*>& target_list, 00295 int* err ); 00296 00297 /* 00298 static 00299 CubitStatus iGeom_get_graphics(RefFace* face, 00300 DLIList<CubitVector*>& point_list, 00301 DLIList<int>& facet_list, 00302 double normal_tolerance = 15.0, 00303 double distance_tolerance = 0.0, 00304 double longest_edge = 0.0) ; 00305 00306 static 00307 CubitStatus iGeom_get_graphics(RefEdge* edge, 00308 DLIList<CubitVector*>& point_list, 00309 DLIList<int>& facet_list, 00310 double angle_tolerance = 0.0, 00311 double distance_tolerance=0.0 ) ; 00312 00313 static CubitStatus iGeom_get_graphics(RefFace* face, 00314 DLIList<CubitVector*>& point_list, 00315 DLIList<int>& facet_list, 00316 double normal_tolerance, 00317 double distance_tolerance, 00318 double longest_edge) 00319 { 00320 CubitStatus status = CUBIT_SUCCESS; 00321 GMem facets; 00322 face->get_graphics(facets, normal_tolerance, distance_tolerance, longest_edge); 00323 int num_points = 0, num_facets = 0; 00324 num_points = facets.point_list_size(); 00325 num_facets = facets.facet_list_size(); 00326 GPoint* points = facets.point_list(); 00327 int* facet_array = facets.facet_list(); 00328 for(int i = 0; i < num_points; i++) 00329 { 00330 CubitVector point(points[i].x, points[i].y, points[i].z); 00331 point_list.append(&point); 00332 } 00333 for(int i = 0; i < num_facets; i++) 00334 facet_list.append(facet_array[i]); 00335 return status; 00336 } 00337 00338 static CubitStatus iGeom_get_graphics(RefEdge* edge, 00339 DLIList<CubitVector*>& point_list, 00340 DLIList<int>& facet_list, 00341 double angle_tolerance, 00342 double distance_tolerance ) 00343 { 00344 CubitStatus status = CUBIT_SUCCESS; 00345 GMem facets; 00346 edge->get_graphics(facets, angle_tolerance, distance_tolerance); 00347 int num_points = 0, num_facets = 0; 00348 num_points = facets.point_list_size(); 00349 num_facets = facets.facet_list_size(); 00350 GPoint* points = facets.point_list(); 00351 int* facet_array = facets.facet_list(); 00352 for(int i = 0; i < num_points; i++) 00353 { 00354 CubitVector point(points[i].x, points[i].y, points[i].z); 00355 point_list.append(&point); 00356 } 00357 for(int i = 0; i < num_facets; i++) 00358 facet_list.append(facet_array[i]); 00359 return status; 00360 } 00361 */ 00362 00363 static CubitStatus init_cgm( const std::string& engine ) 00364 { 00365 CubitStatus status = CUBIT_SUCCESS; 00366 if (engine.empty()) 00367 status = InitCGMA::initialize_cgma(); 00368 else 00369 status = InitCGMA::initialize_cgma( engine.c_str() ); 00370 00371 // sometimes can't have following, depending on CGM version 00372 // CGMApp::instance()->attrib_manager()->silent_flag(true); 00373 00374 CGMApp::instance()->attrib_manager()->auto_flag(true); 00375 00376 return status; 00377 } 00378 00379 extern "C" { 00380 00381 #ifdef ITAPS_SHIM 00382 static struct iGeom_vtable CGM_iGeom_vtable = { 00383 iGeom_getDescription, 00384 iGeom_getErrorType, 00385 iGeom_dtor, 00386 iGeom_load, 00387 iGeom_save, 00388 iGeom_getRootSet, 00389 iGeom_getBoundBox, 00390 iGeom_getEntities, 00391 iGeom_getNumOfType, 00392 iGeom_getEntType, 00393 iGeom_getArrType, 00394 iGeom_getEntAdj, 00395 iGeom_getArrAdj, 00396 iGeom_getEnt2ndAdj, 00397 iGeom_getArr2ndAdj, 00398 iGeom_isEntAdj, 00399 iGeom_isArrAdj, 00400 iGeom_getTopoLevel, 00401 iGeom_getEntClosestPt, 00402 iGeom_getEntClosestPtTrimmed, 00403 iGeom_getArrClosestPt, 00404 iGeom_getEntNrmlXYZ, 00405 iGeom_getArrNrmlXYZ, 00406 iGeom_getEntNrmlPlXYZ, 00407 iGeom_getArrNrmlPlXYZ, 00408 iGeom_getEntTgntXYZ, 00409 iGeom_getArrTgntXYZ, 00410 iGeom_getFcCvtrXYZ, 00411 iGeom_getEgCvtrXYZ, 00412 iGeom_getEntArrCvtrXYZ, 00413 iGeom_getEgEvalXYZ, 00414 iGeom_getFcEvalXYZ, 00415 iGeom_getArrEgEvalXYZ, 00416 iGeom_getArrFcEvalXYZ, 00417 iGeom_getEntBoundBox, 00418 iGeom_getArrBoundBox, 00419 iGeom_getVtxCoord, 00420 iGeom_getVtxArrCoords, 00421 iGeom_getPntRayIntsct, 00422 iGeom_getPntArrRayIntsct, 00423 iGeom_getPntClsf, 00424 iGeom_getPntArrClsf, 00425 iGeom_getEntNrmlSense, 00426 iGeom_getArrNrmlSense, 00427 iGeom_getEgFcSense, 00428 iGeom_getEgFcArrSense, 00429 iGeom_getEgVtxSense, 00430 iGeom_getEgVtxArrSense, 00431 iGeom_measure, 00432 iGeom_getFaceType, 00433 iGeom_getParametric, 00434 iGeom_isEntParametric, 00435 iGeom_isArrParametric, 00436 iGeom_getEntUVtoXYZ, 00437 iGeom_getArrUVtoXYZ, 00438 iGeom_getEntUtoXYZ, 00439 iGeom_getArrUtoXYZ, 00440 iGeom_getEntXYZtoUV, 00441 iGeom_getEntXYZtoU, 00442 iGeom_getArrXYZtoUV, 00443 iGeom_getArrXYZtoU, 00444 iGeom_getEntXYZtoUVHint, 00445 iGeom_getArrXYZtoUVHint, 00446 iGeom_getEntUVRange, 00447 iGeom_getEntURange, 00448 iGeom_getArrUVRange, 00449 iGeom_getArrURange, 00450 iGeom_getEntUtoUV, 00451 iGeom_getVtxToUV, 00452 iGeom_getVtxToU, 00453 iGeom_getArrUtoUV, 00454 iGeom_getVtxArrToUV, 00455 iGeom_getVtxArrToU, 00456 iGeom_getEntNrmlUV, 00457 iGeom_getArrNrmlUV, 00458 iGeom_getEntTgntU, 00459 iGeom_getArrTgntU, 00460 iGeom_getEnt1stDrvt, 00461 iGeom_getArr1stDrvt, 00462 iGeom_getEnt2ndDrvt, 00463 iGeom_getArr2ndDrvt, 00464 iGeom_getFcCvtrUV, 00465 iGeom_getFcArrCvtrUV, 00466 iGeom_isEntPeriodic, 00467 iGeom_isArrPeriodic, 00468 iGeom_isFcDegenerate, 00469 iGeom_isFcArrDegenerate, 00470 iGeom_getTolerance, 00471 iGeom_getEntTolerance, 00472 iGeom_getArrTolerance, 00473 iGeom_initEntIter, 00474 iGeom_initEntArrIter, 00475 iGeom_getNextEntIter, 00476 iGeom_getNextEntArrIter, 00477 iGeom_resetEntIter, 00478 iGeom_resetEntArrIter, 00479 iGeom_endEntIter, 00480 iGeom_endEntArrIter, 00481 iGeom_copyEnt, 00482 iGeom_sweepEntAboutAxis, 00483 iGeom_deleteAll, 00484 iGeom_deleteEnt, 00485 iGeom_createSphere, 00486 iGeom_createPrism, 00487 iGeom_createBrick, 00488 iGeom_createCylinder, 00489 iGeom_createCone, 00490 iGeom_createTorus, 00491 iGeom_moveEnt, 00492 iGeom_rotateEnt, 00493 iGeom_reflectEnt, 00494 iGeom_scaleEnt, 00495 iGeom_uniteEnts, 00496 iGeom_subtractEnts, 00497 iGeom_intersectEnts, 00498 iGeom_sectionEnt, 00499 iGeom_imprintEnts, 00500 iGeom_mergeEnts, 00501 iGeom_createEntSet, 00502 iGeom_destroyEntSet, 00503 iGeom_isList, 00504 iGeom_getNumEntSets, 00505 iGeom_getEntSets, 00506 iGeom_addEntToSet, 00507 iGeom_rmvEntFromSet, 00508 iGeom_addEntArrToSet, 00509 iGeom_rmvEntArrFromSet, 00510 iGeom_addEntSet, 00511 iGeom_rmvEntSet, 00512 iGeom_isEntContained, 00513 iGeom_isEntArrContained, 00514 iGeom_isEntSetContained, 00515 iGeom_addPrntChld, 00516 iGeom_rmvPrntChld, 00517 iGeom_isChildOf, 00518 iGeom_getNumChld, 00519 iGeom_getNumPrnt, 00520 iGeom_getChldn, 00521 iGeom_getPrnts, 00522 iGeom_createTag, 00523 iGeom_destroyTag, 00524 iGeom_getTagName, 00525 iGeom_getTagSizeValues, 00526 iGeom_getTagSizeBytes, 00527 iGeom_getTagHandle, 00528 iGeom_getTagType, 00529 iGeom_setEntSetData, 00530 iGeom_setEntSetIntData, 00531 iGeom_setEntSetDblData, 00532 iGeom_setEntSetEHData, 00533 iGeom_setEntSetESHData, 00534 iGeom_getEntSetData, 00535 iGeom_getEntSetIntData, 00536 iGeom_getEntSetDblData, 00537 iGeom_getEntSetEHData, 00538 iGeom_getEntSetESHData, 00539 iGeom_getAllEntSetTags, 00540 iGeom_rmvEntSetTag, 00541 iGeom_getArrData, 00542 iGeom_getIntArrData, 00543 iGeom_getDblArrData, 00544 iGeom_getEHArrData, 00545 iGeom_getESHArrData, 00546 iGeom_setArrData, 00547 iGeom_setIntArrData, 00548 iGeom_setDblArrData, 00549 iGeom_setEHArrData, 00550 iGeom_setESHArrData, 00551 iGeom_rmvArrTag, 00552 iGeom_getData, 00553 iGeom_getIntData, 00554 iGeom_getDblData, 00555 iGeom_getEHData, 00556 iGeom_getESHData, 00557 iGeom_setData, 00558 iGeom_setIntData, 00559 iGeom_setDblData, 00560 iGeom_setEHData, 00561 iGeom_setESHData, 00562 iGeom_getAllTags, 00563 iGeom_rmvTag, 00564 iGeom_subtract, 00565 iGeom_intersect, 00566 iGeom_unite, 00567 iGeom_getFacets 00568 }; 00569 00570 void CGM_iGeom_register() 00571 { 00572 iGeom_register("cgm", iGeom_newGeom); 00573 } 00574 #endif 00575 00576 00577 ITAPS_API void 00578 iGeom_getErrorType( iGeom_Instance geom, 00579 int *error_type ) 00580 { 00581 *error_type = CGM_iGeom_getLastErrorType(); 00582 } 00583 00584 ITAPS_API void 00585 iGeom_getDescription( iGeom_Instance geom, 00586 char* description_buffer, 00587 int description_buffer_length ) 00588 { 00589 CGM_iGeom_getLastErrorDesc(description_buffer, description_buffer_length); 00590 } 00591 00592 ITAPS_API void 00593 iGeom_newGeom( const char* options, 00594 iGeom_Instance* instance_out, 00595 int* err, 00596 const int options_size ) 00597 { 00598 // scan options for default engine option 00599 std::string engine; 00600 if (options && options_size) { 00601 std::string tmp(options, options_size); 00602 char f[] = ";engine="; f[0]=tmp[0]; // correct delimiter 00603 size_t p = tmp.find( f ); 00604 if (p != std::string::npos) { // if we found engine option 00605 p += strlen(f); // advance to value (past '=') 00606 size_t e = tmp.find( tmp[0], p ); // find end delimiter 00607 if (e == std::string::npos) // if no end delim, then must be last option 00608 engine = tmp.substr( p, std::string::npos ); 00609 else 00610 engine = tmp.substr( p, e-p ); 00611 } 00612 } 00613 00614 // initialize static var with result so that call happens only once 00615 static const CubitStatus status = init_cgm( engine ); 00616 // but check the result for every call 00617 if (CUBIT_SUCCESS != status) 00618 RETURN (iBase_FAILURE); 00619 00620 // return the tagmanager as the instance 00621 #ifdef ITAPS_SHIM 00622 CGMTagManager::instance().vtable = &CGM_iGeom_vtable; 00623 #endif 00624 *instance_out = reinterpret_cast<iGeom_Instance>(&CGMTagManager::instance()); 00625 RETURN(iBase_SUCCESS); 00626 } 00627 00628 00629 ITAPS_API void 00630 iGeom_dtor( iGeom_Instance instance, 00631 int* err ) 00632 { 00633 if (NULL == TM) 00634 ERROR(iBase_INVALID_ARGUMENT, "NUll Instance"); 00635 00636 // delete TM; 00637 00638 // shut down CGM 00639 CGMApp::instance()->shutdown(); 00640 00641 RETURN(iBase_SUCCESS); 00642 } 00643 00644 // user defined non-static methods: 00653 ITAPS_API void 00654 iGeom_load( iGeom_Instance instance, 00655 /*in*/ const char *name, 00656 /*in*/ const char *options, 00657 int* err, 00658 int name_len, 00659 int options_size ) 00660 { 00661 // pre-get all entities, so we can filter them out later; use cubit list 00662 // 'cuz we need to get both volumes and bodies 00663 DLIList<RefEntity*> ref_list, tmp_ref_list; 00664 for (int dim = 0; dim < 5; dim++) { 00665 // Using a temporary since GeometryQueryTool::ref_entity_list cleans out 00666 // the list before appending to it 00667 gqt->ref_entity_list(cgm_type_names[dim], tmp_ref_list, false); 00668 ref_list += tmp_ref_list; 00669 } 00670 00671 // make sure we have a null-terminated string for file name 00672 std::string file_name( name, name_len ); 00673 name = file_name.c_str(); 00674 00675 // check if work in parallel 00676 bool parallel = false; 00677 std::string parallel_opt; 00678 std::vector<std::string> opts; 00679 std::string tmp_options(options, options_size); 00680 tmp_options.insert(0, ";"); 00681 tokenize(tmp_options, opts ); 00682 for (std::vector<std::string>::iterator i = opts.begin(); i != opts.end(); ++i) 00683 { 00684 if (match_option( *i, "PARALLEL", parallel_opt )) parallel = true; 00685 } 00686 00687 // parallel 00688 if (parallel) { 00689 #ifdef USE_MPI 00690 CGMParallelComm* p_comm = new CGMParallelComm(); 00691 CGMReadParallel* p_reader = new CGMReadParallel(GeometryQueryTool::instance(), p_comm); 00692 CubitStatus status = p_reader->load_file(name, options); 00693 if (CUBIT_SUCCESS != status) { 00694 ERROR(iBase_FAILURE, "Trouble loading geometry file in parallel."); 00695 } 00696 #endif 00697 } 00698 else { 00699 CubitStatus status = CUBIT_SUCCESS; 00700 00701 00702 std::string file_type; 00703 if (strstr(name, ".brep") != NULL || 00704 strstr(name, ".BREP") != NULL || 00705 strstr(name, ".occ") != NULL || 00706 strstr(name, ".OCC") != NULL) 00707 file_type = "OCC"; 00708 else if (strstr(name, ".stp") != NULL || 00709 strstr(name, ".STP") != NULL || 00710 strstr(name, ".step") != NULL || 00711 strstr(name, ".STEP") != NULL) 00712 file_type = "STEP"; 00713 else if (strstr(name, ".igs") != NULL || 00714 strstr(name, ".IGS") != NULL || 00715 strstr(name, ".iges") != NULL || 00716 strstr(name, ".IGES") != NULL) 00717 file_type = "IGES"; 00718 00719 00720 status = CubitCompat_import_solid_model(name, file_type.c_str()); 00721 00722 if (CUBIT_SUCCESS != status) { 00723 ERROR(iBase_FILE_NOT_FOUND, "Trouble loading geometry file."); 00724 00725 } 00726 } 00727 00728 DLIList<RefEntity*> ref_list_2; 00729 for (int dim = 0; dim < 5; dim++) { 00730 // Using a temporary since GeometryQueryTool::ref_entity_list cleans out 00731 // the list before appending to it 00732 gqt->ref_entity_list(cgm_type_names[dim], tmp_ref_list, false); 00733 ref_list_2 += tmp_ref_list; 00734 } 00735 00736 ref_list_2 -= ref_list; 00737 00738 // now process uncaught/unregistered attributes 00739 iBase_ErrorType result = process_attribs(instance, ref_list_2); 00740 00741 RETURN(result); 00742 } 00743 00744 // user defined non-static methods: 00753 ITAPS_API void 00754 iGeom_save( iGeom_Instance instance, 00755 /*in*/ const char *name, 00756 /*in*/ const char* options, 00757 int* err, 00758 int name_len, 00759 int options_len ) 00760 { 00761 // make sure strings are null terminated 00762 std::string name_buf(name, name_len); 00763 name = name_buf.c_str(); 00764 00765 // parse options 00766 std::string file_type; 00767 std::vector<std::string> opts; 00768 tokenize( std::string(options, options_len), opts ); 00769 for (std::vector<std::string>::iterator i = opts.begin(); i != opts.end(); ++i) 00770 { 00771 if (!match_option( *i, "TYPE", file_type )) // 00772 ERROR( iBase_INVALID_ARGUMENT, i->c_str() ); 00773 } 00774 00775 // if no type, check file type for known extensions 00776 if (file_type.empty()) { 00777 size_t name_len = name_buf.length(); 00778 if (name_buf.find(".igs") < name_len || 00779 name_buf.find(".IGS") < name_len || 00780 name_buf.find(".iges") < name_len || 00781 name_buf.find(".IGES") < name_len) 00782 file_type = "IGES"; 00783 else if (name_buf.find(".stp") < name_len || 00784 name_buf.find(".STP") < name_len || 00785 name_buf.find(".step") < name_len || 00786 name_buf.find(".STEP") < name_len) 00787 file_type = "STEP"; 00788 else if (name_buf.find(".occ") < name_len || 00789 name_buf.find(".brep") < name_len || 00790 name_buf.find(".OCC") < name_len || 00791 name_buf.find(".BREP") < name_len) 00792 file_type = "OCC"; 00793 else 00794 ERROR(iBase_FAILURE, "Unknown geometry file extension and no file type."); 00795 } 00796 00801 const char* logfile_name = NULL; 00802 if( file_type == "IGES" ){ 00803 logfile_name = "igeom_iges_export.log"; 00804 } 00805 else if( file_type == "STEP" ){ 00806 logfile_name = "igeom_step_export.log"; 00807 } 00808 00809 // process options (none right now...) 00810 DLIList<RefEntity*> bodies; 00811 int num_ents_exported; 00812 CubitString cubit_version(" (iGeom)"); 00813 CubitStatus status = CubitCompat_export_solid_model(bodies, name, file_type.c_str(), 00814 num_ents_exported, cubit_version, logfile_name ); 00815 if (CUBIT_SUCCESS != status) 00816 ERROR(iBase_FAILURE, "Trouble saving geometry file."); 00817 00818 RETURN(iBase_SUCCESS); 00819 } 00820 00821 ITAPS_API void 00822 iGeom_getRootSet( iGeom_Instance, 00823 iBase_EntitySetHandle* root, 00824 int* err ) 00825 { 00826 *root = NULL; 00827 RETURN(iBase_SUCCESS); 00828 } 00829 00830 00831 ITAPS_API void 00832 iGeom_getBoundBox( iGeom_Instance, 00833 double* min_x, 00834 double* min_y, 00835 double* min_z, 00836 double* max_x, 00837 double* max_y, 00838 double* max_z, 00839 int* err ) 00840 { 00841 CubitBox box = GeometryQueryTool::instance()->model_bounding_box(); 00842 *min_x = box.min_x(); 00843 *min_y = box.min_y(); 00844 *min_z = box.min_z(); 00845 *max_x = box.max_x(); 00846 *max_y = box.max_y(); 00847 *max_z = box.max_z(); 00848 RETURN(iBase_SUCCESS); 00849 } 00850 00851 00858 ITAPS_API void 00859 iGeom_initEntIter( iGeom_Instance instance, 00860 iBase_EntitySetHandle entity_set_handle, 00861 const int dimension, 00862 iBase_EntityIterator *iterator, 00863 int* err ) 00864 { 00865 iGeom_initEntArrIter( instance, entity_set_handle, dimension, 1, 00866 reinterpret_cast<iBase_EntityArrIterator*>(iterator), 00867 err ); 00868 } 00869 00870 ITAPS_API void 00871 iGeom_initEntArrIter( iGeom_Instance instance, 00872 /*in*/ iBase_EntitySetHandle entity_set_handle, 00873 /*in*/ int type, 00874 /*in*/ int requested_array_size, 00875 /*out*/ iBase_EntityArrIterator* entArr_iterator, 00876 int* err ) 00877 { 00878 DLIList<RefEntity*> entities; 00879 if (RefGroup* group = reinterpret_cast<RefGroup*>(entity_set_handle)) { 00880 DLIList<CubitEntity*> centities; 00881 group->get_child_entities( centities ); 00882 append_ibase_type( type, centities, entities, err ); 00883 } 00884 else { 00885 append_all_ibase_type( type, entities, err ); 00886 } 00887 00888 if (*err == iBase_SUCCESS) { 00889 CGMAIterator* iter = new CGMAIterator(entities, requested_array_size); 00890 *entArr_iterator = reinterpret_cast<iBase_EntityArrIterator>(iter); 00891 } 00892 } 00893 00894 00895 00903 ITAPS_API void 00904 iGeom_getNextEntIter( iGeom_Instance instance, 00905 /*in*/ iBase_EntityIterator gentity_iterator, 00906 /*out*/ iBase_EntityHandle *gentity_handle, 00907 int* has_data, 00908 int* err ) 00909 { 00910 CGMAIterator* iterator = reinterpret_cast<CGMAIterator*>(gentity_iterator); 00911 RefEntity** out_handle = reinterpret_cast<RefEntity**>(gentity_handle); 00912 *has_data = !iterator->at_end(); 00913 if (*has_data) { 00914 int count = 1; 00915 iterator->next( out_handle, count ); 00916 } 00917 RETURN(iBase_SUCCESS); 00918 } 00919 00920 00921 ITAPS_API void 00922 iGeom_getNextEntArrIter( iGeom_Instance instance, 00923 /*in*/ iBase_EntityArrIterator entArr_iterator, 00924 /*inout*/ iBase_EntityHandle **entity_handles, 00925 int *entity_handles_allocated, 00926 int *entity_handles_size, 00927 int* has_data, 00928 int* err ) 00929 { 00930 CGMAIterator* iterator = reinterpret_cast<CGMAIterator*>(entArr_iterator); 00931 *has_data = !iterator->at_end(); 00932 if (has_data) { 00933 ALLOC_CHECK_ARRAY_NOFAIL(entity_handles, iterator->size()); 00934 iterator->next( (RefEntity**)*entity_handles, *entity_handles_size ); 00935 } 00936 RETURN(iBase_SUCCESS); 00937 } 00938 00939 00944 ITAPS_API void 00945 iGeom_resetEntIter( iGeom_Instance instance, 00946 /*in*/ iBase_EntityIterator gentity_iterator, 00947 int* err ) 00948 { 00949 CGMAIterator* iterator = reinterpret_cast<CGMAIterator*>(gentity_iterator); 00950 iterator->reset(); 00951 RETURN(iBase_SUCCESS); 00952 } 00953 00954 ITAPS_API void 00955 iGeom_resetEntArrIter( iGeom_Instance instance, 00956 /*in*/ iBase_EntityArrIterator gentity_iterator, 00957 int* err ) 00958 { 00959 CGMAIterator* iterator = reinterpret_cast<CGMAIterator*>(gentity_iterator); 00960 iterator->reset(); 00961 RETURN(iBase_SUCCESS); 00962 } 00963 00968 ITAPS_API void 00969 iGeom_endEntIter( iGeom_Instance instance, 00970 /*in*/ iBase_EntityIterator gentity_iterator, 00971 int* err ) 00972 { 00973 CGMAIterator* iterator = reinterpret_cast<CGMAIterator*>(gentity_iterator); 00974 delete iterator; 00975 RETURN(iBase_SUCCESS); 00976 } 00977 00978 ITAPS_API void 00979 iGeom_endEntArrIter( iGeom_Instance instance, 00980 /*in*/ iBase_EntityArrIterator gentity_iterator, 00981 int* err ) 00982 { 00983 CGMAIterator* iterator = reinterpret_cast<CGMAIterator*>(gentity_iterator); 00984 delete iterator; 00985 RETURN(iBase_SUCCESS); 00986 } 00987 00992 ITAPS_API void 00993 iGeom_isChildOf( iGeom_Instance instance, 00994 /*in*/ iBase_EntitySetHandle parent_entity_set, 00995 /*in*/ iBase_EntitySetHandle child_entity_set, 00996 int* is_child, 00997 int* err ) 00998 { 00999 std::vector<RefGroup*> *par1, *ch1, *par2, *ch2; 01000 TM->pc_list(const_cast<RefGroup*>(SET_HANDLE(parent_entity_set)), par1, ch1, false); 01001 if (NULL == ch1 || ch1->empty()) { 01002 *is_child = false; 01003 RETURN (iBase_SUCCESS); 01004 } 01005 TM->pc_list(const_cast<RefGroup*>(SET_HANDLE(child_entity_set)), par2, ch2, false); 01006 if (NULL == par2 || par2->empty()) { 01007 *is_child = false; 01008 RETURN (iBase_SUCCESS); 01009 } 01010 01011 const RefGroup *group1 = SET_HANDLE(parent_entity_set); 01012 const RefGroup *group2 = SET_HANDLE(child_entity_set); 01013 if ((std::find(ch1->begin(), ch1->end(), group2) != ch1->end()) 01014 || (std::find(par2->begin(), par2->end(), group1) != par2->end())) 01015 *is_child = true; 01016 01017 else *is_child = false; 01018 RETURN(iBase_SUCCESS); 01019 } 01020 01025 ITAPS_API void 01026 iGeom_getChldn( iGeom_Instance instance, 01027 /*in*/ iBase_EntitySetHandle from_entity_set, 01028 /*in*/ const int num_hops, 01029 /*inout*/ iBase_EntitySetHandle** entity_set_handles, 01030 int* entity_set_handles_allocated, 01031 int* entity_set_handles_size, 01032 int* err ) 01033 { 01034 std::vector<RefGroup*> group_ptrs; 01035 const RefGroup *this_grp = SET_HANDLE(from_entity_set); 01036 TM->get_pc_groups(const_cast<RefGroup*>(this_grp), 1, num_hops, group_ptrs); 01037 ALLOC_CHECK_ARRAY_NOFAIL(entity_set_handles, group_ptrs.size()); 01038 01039 iBase_EntitySetHandle* ent_arr = reinterpret_cast<iBase_EntitySetHandle*>(&group_ptrs[0]); 01040 std::copy( ent_arr, ent_arr + group_ptrs.size(), *entity_set_handles); 01041 01042 RETURN(iBase_SUCCESS); 01043 } 01044 01049 ITAPS_API void 01050 iGeom_getPrnts( iGeom_Instance instance, 01051 /*in*/ iBase_EntitySetHandle from_entity_set, 01052 /*in*/ const int num_hops, 01053 /*inout*/ iBase_EntitySetHandle **entity_set_handles, 01054 int *entity_set_handles_allocated, 01055 int *entity_set_handles_size, 01056 int* err ) 01057 { 01058 std::vector<RefGroup*> group_ptrs; 01059 const RefGroup *this_grp = SET_HANDLE(from_entity_set); 01060 TM->get_pc_groups(const_cast<RefGroup*>(this_grp), 0, num_hops, group_ptrs); 01061 ALLOC_CHECK_ARRAY_NOFAIL(entity_set_handles, group_ptrs.size()); 01062 01063 iBase_EntitySetHandle* ent_arr = reinterpret_cast<iBase_EntitySetHandle*>(&group_ptrs[0]); 01064 std::copy( ent_arr, ent_arr + group_ptrs.size(), *entity_set_handles); 01065 RETURN(iBase_SUCCESS); 01066 } 01067 01072 ITAPS_API void 01073 iGeom_getNumChld( iGeom_Instance instance, 01074 /*in*/ iBase_EntitySetHandle entity_set, 01075 /*in*/ const int num_hops, 01076 int* num_child, 01077 int* err ) 01078 { 01079 // HJK: num_hops has to be handled 01080 if (0 < num_hops) { 01081 ERROR(iBase_NOT_SUPPORTED, "Num_hops argument not yet supported."); 01082 } 01083 01084 std::vector<RefGroup*> *my_children = TM->pc_list(const_cast<RefGroup*>(SET_HANDLE(entity_set)), 1, false); 01085 *num_child = my_children == NULL ? 0 : my_children->size(); 01086 RETURN (iBase_SUCCESS); 01087 } 01088 01093 ITAPS_API void 01094 iGeom_getNumPrnt( iGeom_Instance instance, 01095 /*in*/ iBase_EntitySetHandle entity_set, 01096 /*in*/ const int num_hops, 01097 int* num_parent, 01098 int* err ) 01099 { 01100 // HJK: num_hops has to be handled 01101 if (0 < num_hops) { 01102 ERROR(iBase_NOT_SUPPORTED, "Num_hops argument not yet supported."); 01103 } 01104 01105 std::vector<RefGroup*> *my_parents = TM->pc_list(const_cast<RefGroup*>(SET_HANDLE(entity_set)), 0, false); 01106 *num_parent = my_parents == NULL ? 0 : my_parents->size(); 01107 RETURN (iBase_SUCCESS); 01108 } 01109 01113 ITAPS_API void 01114 iGeom_addPrntChld( iGeom_Instance instance, 01115 /*inout*/ iBase_EntitySetHandle parent_entity_set, 01116 /*inout*/ iBase_EntitySetHandle child_entity_set, 01117 int* err ) 01118 { 01119 std::vector<RefGroup*> *my_parents = 01120 TM->pc_list(SET_HANDLE(child_entity_set), 0, true); 01121 std::vector<RefGroup*> *my_children = 01122 TM->pc_list(SET_HANDLE(parent_entity_set), 1, true); 01123 RefGroup *par_group = SET_HANDLE(parent_entity_set); 01124 RefGroup *child_group = SET_HANDLE(child_entity_set); 01125 my_parents->push_back(par_group); 01126 my_children->push_back(child_group); 01127 RETURN(iBase_SUCCESS); 01128 } 01129 01133 ITAPS_API void 01134 iGeom_rmvPrntChld( iGeom_Instance instance, 01135 /*inout*/ iBase_EntitySetHandle parent_entity_set, 01136 /*inout*/ iBase_EntitySetHandle child_entity_set, 01137 int* err ) 01138 { 01139 RefGroup *parent = reinterpret_cast<RefGroup *>(parent_entity_set); 01140 RefGroup *child = reinterpret_cast<RefGroup *>(child_entity_set); 01141 std::vector<RefGroup*> *children = TM->pc_list(parent, 1, false), 01142 *parents = TM->pc_list(child, 0, false); 01143 if (NULL == children || NULL == parents) { 01144 RETURN(iBase_INVALID_ARGUMENT); 01145 } 01146 01147 children->erase(std::remove(children->begin(), children->end(), child), children->end()); 01148 parents->erase(std::remove(parents->begin(), parents->end(), parent), parents->end()); 01149 RETURN(iBase_SUCCESS); 01150 } 01151 01158 ITAPS_API void 01159 iGeom_getEntities( iGeom_Instance instance, 01160 /*in*/ iBase_EntitySetHandle set_handle, 01161 /*in*/ int gentity_type, 01162 /*out*/ iBase_EntityHandle **gentity_handles, 01163 int *gentity_handles_allocated, 01164 int *gentity_handles_size, 01165 int* err ) 01166 { 01167 if (RefGroup *this_set = SET_HANDLE(set_handle)) { 01168 static DLIList<CubitEntity*> centities; 01169 centities.clean_out(); 01170 this_set->get_child_entities(centities); 01171 copy_ibase_type( gentity_type, centities, 01172 gentity_handles, 01173 gentity_handles_allocated, 01174 gentity_handles_size, 01175 err ); 01176 } 01177 else { 01178 static DLIList<RefEntity*> dim_entities; 01179 dim_entities.clean_out(); 01180 append_all_ibase_type( gentity_type, dim_entities, err ); 01181 if (iBase_SUCCESS != *err) 01182 return; 01183 01184 ALLOC_CHECK_ARRAY_NOFAIL(gentity_handles, dim_entities.size()); 01185 dim_entities.copy_to((RefEntity**)*gentity_handles); 01186 RETURN(iBase_SUCCESS); 01187 } 01188 } 01189 01197 ITAPS_API void 01198 iGeom_getNumOfType( iGeom_Instance instance, 01199 /*in*/ iBase_EntitySetHandle set_handle, 01200 /*in*/ int gentity_type, 01201 int* count, 01202 int* err ) 01203 { 01204 const RefGroup *this_set = SET_HANDLE(set_handle); 01205 if (0 == this_set) { 01206 switch (gentity_type) { 01207 case iBase_ALL_TYPES: 01208 *count = GeometryQueryTool::instance()->num_bodies(); 01209 *count += GeometryQueryTool::instance()->num_ref_faces(); 01210 *count += GeometryQueryTool::instance()->num_ref_edges(); 01211 *count += GeometryQueryTool::instance()->num_ref_vertices(); 01212 break; 01213 case iBase_REGION: 01214 *count = GeometryQueryTool::instance()->num_bodies(); 01215 break; 01216 case iBase_FACE: 01217 *count = GeometryQueryTool::instance()->num_ref_faces(); 01218 break; 01219 case iBase_EDGE: 01220 *count = GeometryQueryTool::instance()->num_ref_edges(); 01221 break; 01222 case iBase_VERTEX: 01223 *count = GeometryQueryTool::instance()->num_ref_vertices(); 01224 break; 01225 default: 01226 RETURN(iBase_BAD_TYPE_AND_TOPO); 01227 break; 01228 } 01229 RETURN (iBase_SUCCESS); 01230 } 01231 else { 01232 static DLIList<CubitEntity*> centities; 01233 centities.clean_out(); 01234 const_cast<RefGroup*>(this_set)->get_child_entities(centities); 01235 *count = count_ibase_type( gentity_type, centities, err ); 01236 } 01237 } 01238 01239 ITAPS_API void 01240 iGeom_getEntType( iGeom_Instance instance, 01241 iBase_EntityHandle handle, 01242 int* gtype, 01243 int* err ) 01244 { 01245 RefEntity* entity = reinterpret_cast<RefEntity*>(handle); 01246 if (dynamic_cast<Body*>(entity)) 01247 *gtype = iBase_REGION; 01248 else 01249 *gtype = static_cast<int>(entity->dimension()); 01250 RETURN(iBase_SUCCESS); 01251 } 01252 01257 ITAPS_API void 01258 iGeom_getArrType( iGeom_Instance instance, 01259 /*in*/ iBase_EntityHandle const *gentity_handles, 01260 int gentity_handles_size, 01261 /*inout*/ int **gtype, 01262 int *gtype_allocated, 01263 int *gtype_size, 01264 int* err ) 01265 { 01266 // go through each entity and look up its dimension 01267 ALLOC_CHECK_ARRAY_NOFAIL(gtype, gentity_handles_size); 01268 01269 const RefEntity **tmp_handles = (const RefEntity**)(gentity_handles); 01270 01271 for (int i = 0; i < gentity_handles_size; i++) { 01272 if (dynamic_cast<const Body*>(tmp_handles[i])) 01273 (*gtype)[i] = iBase_REGION; 01274 else 01275 (*gtype)[i] = tmp_handles[i]->dimension(); 01276 } 01277 01278 RETURN(iBase_SUCCESS); 01279 } 01280 01287 ITAPS_API void 01288 iGeom_getEntAdj( iGeom_Instance instance, 01289 /*in*/ iBase_EntityHandle gentity_handle, 01290 /*in*/int to_dimension, 01291 /*inout*/ iBase_EntityHandle **adj_gentities, 01292 int *adj_gentities_allocated, 01293 int *adj_gentities_size, 01294 int* err ) 01295 { 01296 const RefEntity *tmp_hndl = ENTITY_HANDLE(gentity_handle); 01297 01298 if (tmp_hndl->dimension() == to_dimension) { 01299 ERROR(iBase_INVALID_ARGUMENT, "Can't get adjacencies to entities of same dimension."); 01300 } 01301 01302 static DLIList<RefEntity*> tmp_ents; 01303 iGeom_get_adjacent_entities(tmp_hndl, to_dimension, tmp_ents, err); 01304 if (iBase_SUCCESS != *err) return; 01305 01306 ALLOC_CHECK_ARRAY_NOFAIL(adj_gentities, tmp_ents.size()); 01307 tmp_ents.copy_to((RefEntity**)*adj_gentities); 01308 RETURN(iBase_SUCCESS); 01309 } 01310 01311 ITAPS_API void 01312 iGeom_getArrAdj( iGeom_Instance instance, 01313 /*in*/ iBase_EntityHandle const *entity_handles, 01314 const int entity_handles_size, 01315 /*in*/ int requested_entity_type, 01316 /*inout*/ iBase_EntityHandle **adj_entity_handles, 01317 int *adj_entity_handles_allocated, 01318 int *adj_entity_handles_size, 01319 /*inout*/ int **offset, 01320 int *offset_allocated, 01321 int *offset_size, 01322 int* err ) 01323 { 01324 ALLOC_CHECK_ARRAY(offset, entity_handles_size+1); 01325 DLIList<RefEntity*> temp_list, total_list; 01326 for (int i = 0; i < entity_handles_size; ++i) { 01327 (*offset)[i] = total_list.size(); 01328 temp_list.clean_out(); 01329 iGeom_get_adjacent_entities( (RefEntity*)(entity_handles[i]), requested_entity_type, temp_list, err ); 01330 if (iBase_SUCCESS != *err) return; 01331 total_list += temp_list; 01332 } 01333 (*offset)[entity_handles_size] = total_list.size(); 01334 01335 ALLOC_CHECK_ARRAY_NOFAIL(adj_entity_handles, total_list.size()); 01336 total_list.copy_to((RefEntity**)*adj_entity_handles); 01337 KEEP_ARRAY(offset); 01338 RETURN(iBase_SUCCESS); 01339 } 01340 01353 ITAPS_API void 01354 iGeom_getEnt2ndAdj( iGeom_Instance instance, 01355 /*in*/ iBase_EntityHandle gentity_handle, 01356 /*in*/ int bridge_dimension, 01357 /*in*/ int to_dimension, 01358 /*out*/ iBase_EntityHandle **adjacent_gentities, 01359 int *adjacent_gentities_allocated, 01360 int *adjacent_gentities_size, 01361 int* err ) 01362 { 01363 // for better or worse, go to cgm as quickly as possible, to avoid working with 01364 // sidl arrays 01365 const RefEntity *gentity = ENTITY_HANDLE(gentity_handle); 01366 DLIList<RefEntity*> to_ents, bridge_ents, tmp_ents; 01367 01368 iGeom_get_adjacent_entities(gentity, bridge_dimension, bridge_ents, err); 01369 if (iBase_SUCCESS != *err) return; 01370 01371 for (int i = bridge_ents.size(); i > 0; i--) { 01372 iGeom_get_adjacent_entities(bridge_ents.get_and_step(), to_dimension, tmp_ents, err); 01373 if (iBase_SUCCESS != *err) return; 01374 01375 to_ents += tmp_ents; 01376 tmp_ents.clean_out(); 01377 } 01378 01379 to_ents.uniquify_unordered(); 01380 01381 ALLOC_CHECK_ARRAY_NOFAIL(adjacent_gentities, to_ents.size()); 01382 to_ents.copy_to((RefEntity**)*adjacent_gentities); 01383 01384 RETURN(iBase_SUCCESS); 01385 } 01386 01387 ITAPS_API void 01388 iGeom_getArr2ndAdj( iGeom_Instance instance, 01389 /*in*/ iBase_EntityHandle const *entity_handles, 01390 int entity_handles_size, 01391 /*in*/ int order_adjacent_key, 01392 /*in*/ int requested_entity_type, 01393 /*inout*/ iBase_EntityHandle **adj_entity_handles, 01394 int *adj_entity_handles_allocated, 01395 int *adj_entity_handles_size, 01396 /*inout*/ int **offset, 01397 int *offset_allocated, 01398 int *offset_size, 01399 int *err ) 01400 { 01401 ALLOC_CHECK_ARRAY(offset, entity_handles_size+1); 01402 DLIList<RefEntity*> bridge_list, temp_list, entity_list, total_list; 01403 01404 for (int i = 0; i < entity_handles_size; ++i) { 01405 bridge_list.clean_out(); 01406 entity_list.clean_out(); 01407 iGeom_get_adjacent_entities( (RefEntity*)(entity_handles[i]), order_adjacent_key, bridge_list, err ); 01408 if (iBase_SUCCESS != *err) return; 01409 bridge_list.reset(); 01410 for (int j = bridge_list.size(); j > 0; --j) { 01411 temp_list.clean_out(); 01412 iGeom_get_adjacent_entities( bridge_list.get_and_step(), requested_entity_type, temp_list, err ); 01413 if (iBase_SUCCESS != *err) return; 01414 entity_list += temp_list; 01415 } 01416 entity_list.uniquify_unordered(); 01417 (*offset)[i] = total_list.size(); 01418 total_list += entity_list; 01419 } 01420 (*offset)[entity_handles_size] = total_list.size(); 01421 01422 ALLOC_CHECK_ARRAY_NOFAIL(adj_entity_handles, total_list.size()); 01423 total_list.copy_to((RefEntity**)*adj_entity_handles); 01424 KEEP_ARRAY(offset); 01425 RETURN(iBase_SUCCESS); 01426 } 01427 01434 ITAPS_API void 01435 iGeom_isEntAdj( iGeom_Instance instance, 01436 /*in*/ iBase_EntityHandle gentity_handle1, 01437 /*in*/ iBase_EntityHandle gentity_handle2, 01438 /*out*/ int *are_adjacent, 01439 int* err ) 01440 { 01441 const TopologyEntity *ent1 = dynamic_cast<const TopologyEntity*>(ENTITY_HANDLE(gentity_handle1)); 01442 const TopologyEntity *ent2 = dynamic_cast<const TopologyEntity*>(ENTITY_HANDLE(gentity_handle2)); 01443 if (ent1 != NULL && ent2 != NULL) 01444 *are_adjacent = const_cast<TopologyEntity*>(ent1)->is_directly_related(const_cast<TopologyEntity*>(ent2)); 01445 else *are_adjacent = false; 01446 RETURN(iBase_SUCCESS); 01447 } 01448 01449 ITAPS_API void 01450 iGeom_isArrAdj( iGeom_Instance instance, 01451 /*in*/ iBase_EntityHandle const *entity_handles_1, 01452 int entity_handles_1_size, 01453 /*in*/ iBase_EntityHandle const *entity_handles_2, 01454 int entity_handles_2_size, 01455 /*inout*/ int **is_adjacent_info, 01456 int *is_adjacent_info_allocated, 01457 int *is_adjacent_info_size, 01458 int* err ) 01459 { 01460 RefEntity **list_1_iter = (RefEntity**)entity_handles_1, 01461 **list_2_iter = (RefEntity**)entity_handles_2; 01462 size_t list_1_step, list_2_step; 01463 int count; 01464 // If either list contains only 1 entry, compare that entry with 01465 // every entry in the other list. 01466 if (entity_handles_1_size == entity_handles_2_size) { 01467 list_1_step = list_2_step = 1; 01468 count = entity_handles_1_size; 01469 } 01470 else if (entity_handles_1_size == 1) { 01471 list_1_step = 0; 01472 list_2_step = 1; 01473 count = entity_handles_2_size; 01474 } 01475 else if (entity_handles_2_size == 1) { 01476 list_1_step = 1; 01477 list_2_step = 0; 01478 count = entity_handles_1_size; 01479 } 01480 else { 01481 RETURN(iBase_INVALID_ENTITY_COUNT); 01482 } 01483 01484 ALLOC_CHECK_ARRAY_NOFAIL(is_adjacent_info, count); 01485 for (int i = 0; i < count; ++i) 01486 { 01487 TopologyEntity* ent1 = dynamic_cast<TopologyEntity*>(*list_1_iter); 01488 TopologyEntity* ent2 = dynamic_cast<TopologyEntity*>(*list_2_iter); 01489 (*is_adjacent_info)[i] = ent1->is_directly_related(ent2); 01490 list_1_iter += list_1_step; 01491 list_2_iter += list_2_step; 01492 } 01493 RETURN(iBase_SUCCESS); 01494 } 01495 01496 ITAPS_API void 01497 iGeom_getTopoLevel( iGeom_Instance instance, 01498 /*out*/ int* level, 01499 int* err ) 01500 { 01501 *level = 2; // 0->basic entities only, 1->manifold, 2->non-manifold 01502 RETURN(iBase_SUCCESS); 01503 } 01504 01515 ITAPS_API void 01516 iGeom_createTag( iGeom_Instance instance, 01517 /*in*/ const char *tag_name, 01518 /*in*/ int tag_size, 01519 /*in*/ int tag_type, 01520 /*out*/ iBase_TagHandle *tag_handle, 01521 int* err, 01522 int tag_name_len ) 01523 { 01524 long new_tag; 01525 int this_size = tag_size; 01526 switch (tag_type) { 01527 case iBase_INTEGER: 01528 this_size *= sizeof(int); 01529 break; 01530 case iBase_DOUBLE: 01531 this_size *= sizeof(double); 01532 break; 01533 case iBase_ENTITY_HANDLE: 01534 this_size *= sizeof(iBase_EntityHandle); 01535 break; 01536 case iBase_ENTITY_SET_HANDLE: 01537 this_size *= sizeof(iBase_EntitySetHandle); 01538 break; 01539 case iBase_BYTES: 01540 break; 01541 } 01542 01543 // make sure string is null terminated 01544 std::string name_buf( tag_name, tag_name_len ); 01545 tag_name = name_buf.c_str(); 01546 01547 iBase_ErrorType retval = TM->createTag(tag_name, this_size, tag_type, NULL, &new_tag); 01548 *tag_handle = (iBase_TagHandle) new_tag; 01549 RETURN(retval); 01550 } 01551 01564 ITAPS_API void 01565 iGeom_destroyTag( iGeom_Instance instance, 01566 /*in*/ iBase_TagHandle tag_handle, 01567 /*in*/ int forced, 01568 int* err ) 01569 { 01570 iBase_ErrorType retval = TM->destroyTag(TAG_HANDLE(tag_handle), forced); 01571 RETURN(retval); 01572 } 01573 01577 ITAPS_API void 01578 iGeom_getTagName( iGeom_Instance instance, 01579 /*in*/ iBase_TagHandle tag_handle, 01580 char* name, 01581 int* err, 01582 int name_len ) 01583 { 01584 const char* name_ptr = TM->getTagName(TAG_HANDLE(tag_handle)); 01585 int len = strlen(name_ptr) + 1; 01586 if (len > name_len) 01587 len = name_len; 01588 memcpy( name, name_ptr, len ); 01589 RETURN(iBase_SUCCESS); 01590 } 01591 01595 ITAPS_API void 01596 iGeom_getTagSizeValues( iGeom_Instance instance, 01597 /*in*/ iBase_TagHandle tag_handle, 01598 int* tag_size, 01599 int* err ) 01600 { 01601 *tag_size = TM->getTagSize(TAG_HANDLE(tag_handle)); 01602 int type; 01603 iGeom_getTagType( instance, tag_handle, &type, err ); 01604 if (iBase_SUCCESS != *err) return; 01605 01606 switch (type) { 01607 case iBase_INTEGER: 01608 *tag_size /= sizeof(int); 01609 break; 01610 case iBase_DOUBLE: 01611 *tag_size /= sizeof(double); 01612 break; 01613 case iBase_ENTITY_HANDLE: 01614 case iBase_ENTITY_SET_HANDLE: 01615 *tag_size /= sizeof(iBase_EntityHandle); 01616 break; 01617 case iBase_BYTES: 01618 break; 01619 } 01620 RETURN(iBase_SUCCESS); 01621 } 01622 01626 ITAPS_API void 01627 iGeom_getTagSizeBytes( iGeom_Instance instance, 01628 /*in*/ iBase_TagHandle tag_handle, 01629 int* tag_size, 01630 int* err ) 01631 { 01632 *tag_size = TM->getTagSize(TAG_HANDLE(tag_handle)); 01633 RETURN(iBase_SUCCESS); 01634 } 01635 01636 ITAPS_API void 01637 iGeom_getTagType( iGeom_Instance instance, 01638 /*in*/ iBase_TagHandle tag_handle, 01639 int* type, 01640 int* err ) 01641 { 01642 *type = TM->getTagType(TAG_HANDLE(tag_handle)); 01643 RETURN(iBase_SUCCESS); 01644 } 01645 01649 ITAPS_API void 01650 iGeom_getTagHandle( iGeom_Instance instance, 01651 /*in*/ const char *tag_name, 01652 iBase_TagHandle* tag_handle, 01653 int* err, 01654 int tag_name_len ) 01655 { 01656 // make sure string is null-terminated 01657 std::string tag_name_buf( tag_name, tag_name_len ); 01658 tag_name = tag_name_buf.c_str(); 01659 *tag_handle = reinterpret_cast<iBase_TagHandle>(static_cast<size_t>(TM->getTagHandle( tag_name ))); 01660 01661 // XXX: this seems really wrong... 01662 iGeom_getErrorType(instance, err); 01663 } 01664 01665 ITAPS_API void 01666 iGeom_rmvArrTag( iGeom_Instance instance, 01667 const iBase_EntityHandle *entity_handles, 01668 int entity_handles_size, 01669 iBase_TagHandle tag_handle, 01670 int* err ) 01671 { 01672 RefEntity *const *tmp_entity_handles = reinterpret_cast<RefEntity*const *>(entity_handles); 01673 iBase_ErrorType retval = TM->rmvArrTag(tmp_entity_handles, entity_handles_size, TAG_HANDLE(tag_handle)); 01674 RETURN(retval); 01675 } 01676 01683 ITAPS_API void 01684 iGeom_rmvTag( iGeom_Instance instance, 01685 /*in*/ iBase_EntityHandle entity_handle, 01686 /*in*/ iBase_TagHandle tag_handle, 01687 int* err ) 01688 { 01689 RefEntity *tmp_entity = ENTITY_HANDLE(entity_handle); 01690 iBase_ErrorType retval = TM->rmvArrTag(&tmp_entity, 1, TAG_HANDLE(tag_handle)); 01691 RETURN(retval); 01692 } 01693 01697 ITAPS_API void 01698 iGeom_getAllTags( iGeom_Instance instance, 01699 /*in*/ iBase_EntityHandle entity_handle, 01700 /*inout*/ iBase_TagHandle **tag_handles, 01701 int *tag_handles_allocated, 01702 int *tag_handles_size, 01703 int* err ) 01704 { 01705 iBase_ErrorType retval = TM->getAllTags(SET_HANDLE(entity_handle), 01706 TAG_HANDLE_ARRAY_INOUT(tag_handles)); 01707 RETURN(retval); 01708 } 01709 01710 ITAPS_API void 01711 iGeom_getArrData( iGeom_Instance instance, 01712 /*in*/ iBase_EntityHandle const *entity_handles, 01713 int entity_handles_size, 01714 /*in*/ iBase_TagHandle tag_handle, 01715 /*inout*/ void **tag_value_tmp, 01716 int *tag_value_allocated, 01717 int *tag_value_size, 01718 int* err ) 01719 { 01720 char **tag_value = reinterpret_cast<char**>(tag_value_tmp); 01721 iBase_ErrorType retval = TM->getArrData(reinterpret_cast<RefEntity*const*>(entity_handles), 01722 entity_handles_size, 01723 TAG_HANDLE(tag_handle), 01724 ARRAY_INOUT(tag_value)); 01725 RETURN(retval); 01726 } 01727 01728 01729 ITAPS_API void 01730 iGeom_getIntArrData( iGeom_Instance instance, 01731 /*in*/ iBase_EntityHandle const *entity_handles, 01732 int entity_handles_size, 01733 /*in*/ iBase_TagHandle tag_handle, 01734 /*inout*/ int **tag_value, 01735 int *tag_value_allocated, 01736 int *tag_value_size, 01737 int* err ) 01738 { 01739 int tag_value_allocated_tmp = *tag_value_allocated * sizeof(int); 01740 int tag_value_size_tmp = *tag_value_size * sizeof(int); 01741 iGeom_getArrData(instance, entity_handles, 01742 entity_handles_size, tag_handle, 01743 reinterpret_cast<void**>(tag_value), 01744 &tag_value_allocated_tmp, 01745 &tag_value_size_tmp, 01746 err); 01747 *tag_value_allocated = tag_value_allocated_tmp / sizeof(int); 01748 *tag_value_size = tag_value_size_tmp / sizeof(int); 01749 } 01750 01751 01752 ITAPS_API void 01753 iGeom_getDblArrData( iGeom_Instance instance, 01754 /*in*/ iBase_EntityHandle const *entity_handles, 01755 int entity_handles_size, 01756 /*in*/ iBase_TagHandle tag_handle, 01757 /*inout*/ double **tag_value, 01758 int *tag_value_allocated, 01759 int *tag_value_size, 01760 int* err ) 01761 { 01762 int tag_value_allocated_tmp = *tag_value_allocated * sizeof(double); 01763 int tag_value_size_tmp = *tag_value_size * sizeof(double); 01764 iGeom_getArrData(instance, entity_handles, 01765 entity_handles_size, tag_handle, 01766 reinterpret_cast<void**>(tag_value), 01767 &tag_value_allocated_tmp, 01768 &tag_value_size_tmp, 01769 err); 01770 *tag_value_allocated = tag_value_allocated_tmp / sizeof(double); 01771 *tag_value_size = tag_value_size_tmp / sizeof(double); 01772 } 01773 01774 ITAPS_API void 01775 iGeom_getEHArrData( iGeom_Instance instance, 01776 /*in*/ iBase_EntityHandle const *entity_handles, 01777 int entity_handles_size, 01778 /*in*/ iBase_TagHandle tag_handle, 01779 /*inout*/ iBase_EntityHandle **tag_value, 01780 int *tag_value_allocated, 01781 int *tag_value_size, 01782 int* err ) 01783 { 01784 int tag_value_allocated_tmp = *tag_value_allocated * sizeof(iBase_EntityHandle); 01785 int tag_value_size_tmp = *tag_value_size * sizeof(iBase_EntityHandle); 01786 iGeom_getArrData(instance, entity_handles, 01787 entity_handles_size, tag_handle, 01788 reinterpret_cast<void**>(tag_value), 01789 &tag_value_allocated_tmp, 01790 &tag_value_size_tmp, 01791 err); 01792 *tag_value_allocated = tag_value_allocated_tmp / sizeof(iBase_EntityHandle); 01793 *tag_value_size = tag_value_size_tmp / sizeof(iBase_EntityHandle); 01794 } 01795 01796 ITAPS_API void 01797 iGeom_getESHArrData( iGeom_Instance instance, 01798 /*in*/ iBase_EntityHandle const *entity_handles, 01799 int entity_handles_size, 01800 /*in*/ iBase_TagHandle tag_handle, 01801 /*inout*/ iBase_EntitySetHandle **tag_value, 01802 int *tag_value_allocated, 01803 int *tag_value_size, 01804 int* err ) 01805 { 01806 int tag_value_allocated_tmp = *tag_value_allocated * sizeof(iBase_EntitySetHandle); 01807 int tag_value_size_tmp = *tag_value_size * sizeof(iBase_EntitySetHandle); 01808 iGeom_getArrData(instance, entity_handles, 01809 entity_handles_size, tag_handle, 01810 reinterpret_cast<void**>(tag_value), 01811 &tag_value_allocated_tmp, 01812 &tag_value_size_tmp, 01813 err); 01814 *tag_value_allocated = tag_value_allocated_tmp / sizeof(iBase_EntitySetHandle); 01815 *tag_value_size = tag_value_size_tmp / sizeof(iBase_EntitySetHandle); 01816 } 01817 01818 ITAPS_API void 01819 iGeom_setArrData( iGeom_Instance instance, 01820 const iBase_EntityHandle *entity_handles, 01821 int entity_handles_size, 01822 /*in*/ iBase_TagHandle tag_handle, 01823 /*in*/ const void *tag_value_tmp, 01824 const int tag_value_size, 01825 int* err ) 01826 { 01827 const char *tag_value = reinterpret_cast<const char*>(tag_value_tmp); 01828 iBase_ErrorType retval = TM->setArrData(ENTITY_HANDLE_CONST_ARRAY(entity_handles), 01829 entity_handles_size, 01830 TAG_HANDLE(tag_handle), 01831 ARRAY_IN(tag_value)); 01832 RETURN(retval); 01833 } 01834 01835 ITAPS_API void 01836 iGeom_setIntArrData( iGeom_Instance instance, 01837 const iBase_EntityHandle *entity_handles, 01838 int entity_handles_size, 01839 iBase_TagHandle tag_handle, 01840 const int *tag_value, 01841 int tag_value_size, 01842 int* err ) 01843 { 01844 iGeom_setArrData(instance, entity_handles, 01845 entity_handles_size, tag_handle, 01846 tag_value, sizeof(int)*tag_value_size, err); 01847 } 01848 01849 ITAPS_API void 01850 iGeom_setDblArrData( iGeom_Instance instance, 01851 const iBase_EntityHandle *entity_handles, 01852 int entity_handles_size, 01853 iBase_TagHandle tag_handle, 01854 const double *tag_value, 01855 int tag_value_size, 01856 int* err ) 01857 { 01858 iGeom_setArrData(instance, entity_handles, 01859 entity_handles_size, tag_handle, 01860 tag_value, sizeof(double)*tag_value_size, err); 01861 } 01862 01863 ITAPS_API void 01864 iGeom_setEHArrData( iGeom_Instance instance, 01865 const iBase_EntityHandle *entity_handles, 01866 int entity_handles_size, 01867 iBase_TagHandle tag_handle, 01868 iBase_EntityHandle const *tag_values, 01869 int tag_values_size, 01870 int* err ) 01871 { 01872 iGeom_setArrData(instance, entity_handles, 01873 entity_handles_size, tag_handle, 01874 tag_values, sizeof(iBase_EntityHandle)*tag_values_size, 01875 err); 01876 } 01877 01878 ITAPS_API void 01879 iGeom_setESHArrData( iGeom_Instance instance, 01880 const iBase_EntityHandle *entity_handles, 01881 int entity_handles_size, 01882 iBase_TagHandle tag_handle, 01883 iBase_EntitySetHandle const *tag_values, 01884 int tag_values_size, 01885 int* err ) 01886 { 01887 iGeom_setArrData(instance, entity_handles, 01888 entity_handles_size, tag_handle, 01889 tag_values, sizeof(iBase_EntitySetHandle)*tag_values_size, 01890 err); 01891 } 01892 01897 ITAPS_API void 01898 iGeom_getData( iGeom_Instance instance, 01899 /*in*/ iBase_EntityHandle entity_handle, 01900 /*in*/ iBase_TagHandle tag_handle, 01901 /*inout*/ void **tag_value_tmp, 01902 int *tag_value_allocated, 01903 int *tag_value_size, 01904 int* err ) 01905 { 01906 char **tag_value = reinterpret_cast<char **>(tag_value_tmp); 01907 RefEntity *tmp_entity = ENTITY_HANDLE(entity_handle); 01908 iBase_ErrorType retval = TM->getArrData(&tmp_entity, 1, TAG_HANDLE(tag_handle), 01909 ARRAY_INOUT(tag_value)); 01910 RETURN(retval); 01911 } 01912 01913 ITAPS_API void 01914 iGeom_getIntData( iGeom_Instance instance, 01915 iBase_EntityHandle entity_handle, 01916 iBase_TagHandle tag_handle, 01917 int* data_out, 01918 int* err ) 01919 { 01920 void *val_ptr = data_out; 01921 int val_size = sizeof(int); 01922 iGeom_getArrData(instance, &entity_handle, 1, 01923 tag_handle, &val_ptr, &val_size, &val_size, err); 01924 } 01925 01926 ITAPS_API void 01927 iGeom_getDblData( iGeom_Instance instance, 01928 iBase_EntityHandle entity_handle, 01929 iBase_TagHandle tag_handle, 01930 double* data_out, 01931 int* err ) 01932 { 01933 void *val_ptr = data_out; 01934 int val_size = sizeof(double); 01935 iGeom_getArrData(instance, &entity_handle, 1, 01936 tag_handle, &val_ptr, &val_size, &val_size, err); 01937 } 01938 01939 ITAPS_API void 01940 iGeom_getEHData( iGeom_Instance instance, 01941 iBase_EntityHandle entity_handle, 01942 iBase_TagHandle tag_handle, 01943 iBase_EntityHandle* data_out, 01944 int* err ) 01945 { 01946 void *val_ptr = data_out; 01947 int val_size = sizeof(iBase_EntityHandle); 01948 iGeom_getArrData(instance, &entity_handle, 1, 01949 tag_handle, &val_ptr, &val_size, &val_size, err); 01950 } 01951 01952 ITAPS_API void 01953 iGeom_getESHData( iGeom_Instance instance, 01954 iBase_EntityHandle entity_handle, 01955 iBase_TagHandle tag_handle, 01956 iBase_EntitySetHandle* data_out, 01957 int* err ) 01958 { 01959 void *val_ptr = data_out; 01960 int val_size = sizeof(iBase_EntitySetHandle); 01961 iGeom_getArrData(instance, &entity_handle, 1, 01962 tag_handle, &val_ptr, &val_size, &val_size, err); 01963 } 01964 01969 ITAPS_API void 01970 iGeom_setData( iGeom_Instance instance, 01971 /*in*/ iBase_EntityHandle entity_handle, 01972 /*in*/ iBase_TagHandle tag_handle, 01973 /*in*/ const void *tag_value_tmp, 01974 int tag_value_size, 01975 int* err ) 01976 { 01977 const char *tag_value = reinterpret_cast<const char *>(tag_value_tmp); 01978 RefEntity *tmp_entity = ENTITY_HANDLE(entity_handle); 01979 iBase_ErrorType retval = TM->setArrData(&tmp_entity, 1, 01980 TAG_HANDLE(tag_handle), 01981 ARRAY_IN(tag_value)); 01982 RETURN(retval); 01983 } 01984 01985 ITAPS_API void 01986 iGeom_setIntData( iGeom_Instance instance, 01987 /*in*/ iBase_EntityHandle entity_handle, 01988 /*in*/ iBase_TagHandle tag_handle, 01989 /*in*/ int tag_value, 01990 int* err ) 01991 { 01992 iGeom_setArrData(instance, &entity_handle, 1, 01993 tag_handle, &tag_value, sizeof(int), err); 01994 } 01995 01996 ITAPS_API void 01997 iGeom_setDblData( iGeom_Instance instance, 01998 /*in*/ iBase_EntityHandle entity_handle, 01999 /*in*/ iBase_TagHandle tag_handle, 02000 /*in*/ double tag_value, 02001 int* err ) 02002 { 02003 iGeom_setArrData(instance, &entity_handle, 1, 02004 tag_handle, &tag_value, sizeof(double), err); 02005 } 02006 02007 ITAPS_API void 02008 iGeom_setEHData( iGeom_Instance instance, 02009 /*in*/ iBase_EntityHandle entity_handle, 02010 /*in*/ iBase_TagHandle tag_handle, 02011 /*in*/ iBase_EntityHandle tag_value, 02012 int* err ) 02013 { 02014 iGeom_setArrData(instance, &entity_handle, 1, 02015 tag_handle, &tag_value, sizeof(iBase_EntityHandle), err); 02016 } 02017 02018 ITAPS_API void 02019 iGeom_setESHData( iGeom_Instance instance, 02020 /*in*/ iBase_EntityHandle entity_handle, 02021 /*in*/ iBase_TagHandle tag_handle, 02022 /*in*/ iBase_EntitySetHandle tag_value, 02023 int* err ) 02024 { 02025 iGeom_setArrData(instance, &entity_handle, 1, 02026 tag_handle, &tag_value, sizeof(iBase_EntitySetHandle), err); 02027 } 02028 02034 ITAPS_API void 02035 iGeom_rmvEntSetTag( iGeom_Instance instance, 02036 /*in*/ iBase_EntitySetHandle entity_set, 02037 /*in*/ iBase_TagHandle tag_handle, 02038 int* err ) 02039 { 02040 // have to go through RefEntity* so that RefEntity** gets set right 02041 RefEntity *tmp_entity = SET_HANDLE(entity_set); 02042 iBase_ErrorType retval = TM->rmvArrTag(&tmp_entity, 1, TAG_HANDLE(tag_handle)); 02043 RETURN(retval); 02044 } 02045 02049 ITAPS_API void 02050 iGeom_getAllEntSetTags( iGeom_Instance instance, 02051 /*in*/ iBase_EntitySetHandle entity_set, 02052 /*inout*/ iBase_TagHandle **tag_handles, 02053 int *tag_handles_allocated, 02054 int *tag_handles_size, 02055 int* err ) 02056 { 02057 // have to go through RefEntity* so that RefEntity** gets set right 02058 const RefEntity *tmp_entity = SET_HANDLE(entity_set); 02059 iBase_ErrorType retval = TM->getAllTags(tmp_entity,TAG_HANDLE_ARRAY_INOUT(tag_handles)); 02060 RETURN(retval); 02061 } 02062 02069 ITAPS_API void 02070 iGeom_getEntSetData( iGeom_Instance instance, 02071 /*in*/ iBase_EntitySetHandle entity_set, 02072 /*in*/ iBase_TagHandle tag_handle, 02073 /*inout*/ void **tag_value_tmp, 02074 int *tag_value_allocated, 02075 int *tag_value_size, 02076 int* err ) 02077 { 02078 char **tag_value = reinterpret_cast<char **>(tag_value_tmp); 02079 // have to go through RefEntity* so that RefEntity** gets set right 02080 RefEntity *tmp_entity = SET_HANDLE(entity_set); 02081 iBase_ErrorType retval = TM->getArrData(&tmp_entity, 1, TAG_HANDLE(tag_handle), 02082 ARRAY_INOUT(tag_value)); 02083 RETURN(retval); 02084 } 02085 02086 ITAPS_API void 02087 iGeom_getEntSetIntData( iGeom_Instance instance, 02088 /*in*/ iBase_EntitySetHandle entity_set, 02089 /*in*/ iBase_TagHandle tag_handle, 02090 int* tag_ptr, 02091 int* err ) 02092 { 02093 int tag_size = sizeof(int); 02094 void* data_ptr = tag_ptr; 02095 iGeom_getEntSetData(instance, entity_set, tag_handle, &data_ptr, 02096 &tag_size, &tag_size, err); 02097 } 02098 02099 ITAPS_API void 02100 iGeom_getEntSetDblData( iGeom_Instance instance, 02101 /*in*/ iBase_EntitySetHandle entity_set, 02102 /*in*/ iBase_TagHandle tag_handle, 02103 double* tag_ptr, 02104 int* err ) 02105 { 02106 int tag_size = sizeof(double); 02107 void* data_ptr = tag_ptr; 02108 iGeom_getEntSetData(instance, entity_set, tag_handle, &data_ptr, 02109 &tag_size, &tag_size, err); 02110 } 02111 02112 ITAPS_API void 02113 iGeom_getEntSetEHData( iGeom_Instance instance, 02114 /*in*/ iBase_EntitySetHandle entity_set, 02115 /*in*/ iBase_TagHandle tag_handle, 02116 iBase_EntityHandle* tag_ptr, 02117 int* err ) 02118 { 02119 int tag_size = sizeof(iBase_EntityHandle); 02120 void* data_ptr = tag_ptr; 02121 iGeom_getEntSetData(instance, entity_set, tag_handle, &data_ptr, 02122 &tag_size, &tag_size, err); 02123 } 02124 02125 ITAPS_API void 02126 iGeom_getEntSetESHData( iGeom_Instance instance, 02127 /*in*/ iBase_EntitySetHandle entity_set, 02128 /*in*/ iBase_TagHandle tag_handle, 02129 iBase_EntitySetHandle* tag_ptr, 02130 int* err ) 02131 { 02132 int tag_size = sizeof(iBase_EntitySetHandle); 02133 void* data_ptr = tag_ptr; 02134 iGeom_getEntSetData(instance, entity_set, tag_handle, &data_ptr, 02135 &tag_size, &tag_size, err); 02136 } 02137 02142 ITAPS_API void 02143 iGeom_setEntSetData( iGeom_Instance instance, 02144 /*in*/ iBase_EntitySetHandle entity_set, 02145 /*in*/ iBase_TagHandle tag_handle, 02146 /*in*/ const void *tag_value_tmp, 02147 int tag_value_size, 02148 int* err ) 02149 { 02150 const char *tag_value = reinterpret_cast<const char *>(tag_value_tmp); 02151 // have to go through RefEntity* so that RefEntity** gets set right 02152 RefEntity *tmp_entity = SET_HANDLE(entity_set); 02153 iBase_ErrorType retval = TM->setArrData(&tmp_entity, 1, TAG_HANDLE(tag_handle), 02154 ARRAY_IN(tag_value)); 02155 RETURN(retval); 02156 } 02157 02158 ITAPS_API void 02159 iGeom_setEntSetIntData( iGeom_Instance instance, 02160 /*in*/ iBase_EntitySetHandle entity_set, 02161 /*in*/ iBase_TagHandle tag_handle, 02162 /*in*/ int tag_value, 02163 int* err ) 02164 { 02165 iGeom_setEntSetData(instance, entity_set, tag_handle, 02166 &tag_value, sizeof(int), err); 02167 } 02168 02169 ITAPS_API void 02170 iGeom_setEntSetDblData( iGeom_Instance instance, 02171 /*in*/ iBase_EntitySetHandle entity_set, 02172 /*in*/ iBase_TagHandle tag_handle, 02173 /*in*/ double tag_value, 02174 int* err ) 02175 { 02176 iGeom_setEntSetData(instance, entity_set, tag_handle, 02177 &tag_value, sizeof(double), err); 02178 } 02179 02180 ITAPS_API void 02181 iGeom_setEntSetEHData( iGeom_Instance instance, 02182 /*in*/ iBase_EntitySetHandle entity_set, 02183 /*in*/ iBase_TagHandle tag_handle, 02184 /*in*/ iBase_EntityHandle tag_value, 02185 int* err ) 02186 { 02187 iGeom_setEntSetData(instance, entity_set, tag_handle, 02188 &tag_value, 02189 sizeof(iBase_EntityHandle), err); 02190 } 02191 02192 ITAPS_API void 02193 iGeom_setEntSetESHData( iGeom_Instance instance, 02194 /*in*/ iBase_EntitySetHandle entity_set, 02195 /*in*/ iBase_TagHandle tag_handle, 02196 /*in*/ iBase_EntitySetHandle tag_value, 02197 int* err ) 02198 { 02199 iGeom_setEntSetData(instance, entity_set, tag_handle, 02200 &tag_value, sizeof(iBase_EntitySetHandle), err); 02201 } 02202 02203 ITAPS_API void 02204 iGeom_getEntClosestPt( iGeom_Instance instance, 02205 /*in*/ iBase_EntityHandle entity_handle, 02206 /*in*/ double near_x, 02207 /*in*/ double near_y, 02208 /*in*/ double near_z, 02209 /*out*/ double* on_x, 02210 /*out*/ double* on_y, 02211 /*out*/ double* on_z, 02212 int* err ) 02213 { 02214 RefEntity* entity = (RefEntity*)entity_handle; 02215 CubitVector on, near(near_x, near_y, near_z); 02216 CubitStatus status = iGeom_closest_point( entity, near, on ); 02217 if (status == CUBIT_FAILURE) { 02218 ERROR(iBase_FAILURE, "Problems getting closest point for some entity."); 02219 } 02220 on.get_xyz( *on_x, *on_y, *on_z ); 02221 RETURN(iBase_SUCCESS); 02222 } 02223 02224 ITAPS_API void 02225 iGeom_getEntClosestPtTrimmed( iGeom_Instance instance, 02226 iBase_EntityHandle entity_handle, 02227 double near_x, 02228 double near_y, 02229 double near_z, 02230 double* on_x, 02231 double* on_y, 02232 double* on_z, 02233 int* err ) 02234 { 02235 RefEntity* entity = (RefEntity*)entity_handle; 02236 CubitVector on, near(near_x, near_y, near_z); 02237 CubitStatus status = iGeom_closest_point_trimmed( entity, near, on ); 02238 if (status == CUBIT_FAILURE) { 02239 ERROR(iBase_FAILURE, "Problems getting closest point for some entity."); 02240 } 02241 on.get_xyz( *on_x, *on_y, *on_z ); 02242 RETURN(iBase_SUCCESS); 02243 } 02244 02253 ITAPS_API void 02254 iGeom_getArrClosestPt( iGeom_Instance instance, 02255 /*in*/ iBase_EntityHandle const *gentity_handles, 02256 int gentity_handles_size, 02257 /*in*/ int storage_order, 02258 /*in*/ const double *near_coordinates, 02259 int near_coordinates_size, 02260 /*out*/ double **on_coordinates, 02261 int *on_coordinates_allocated, 02262 int *on_coordinates_size, 02263 int* err ) 02264 { 02265 /* set up iteration according to storage order. 02266 allow either gentity_handles or near_coordinates to contain 02267 only one value, where that single value is applied for every 02268 entry in the other list. 02269 */ 02270 size_t near_step, on_step = 1, ent_step; 02271 int count; 02272 if (3*gentity_handles_size == near_coordinates_size) { 02273 near_step = ent_step = 1; 02274 count = gentity_handles_size; 02275 } 02276 else if (near_coordinates_size == 3) { 02277 near_step = 0; 02278 ent_step = 1; 02279 count = gentity_handles_size; 02280 } 02281 else if (gentity_handles_size == 1) { 02282 near_step = 1; 02283 ent_step = 0; 02284 count = near_coordinates_size / 3; 02285 } 02286 else { 02287 ERROR( iBase_INVALID_ENTITY_COUNT, "Mismatched array sizes" ); 02288 } 02289 ALLOC_CHECK_ARRAY( on_coordinates, 3*count ); 02290 02291 const double *near_x, *near_y, *near_z; 02292 double *on_x, *on_y, *on_z; 02293 if (storage_order == iBase_BLOCKED) { 02294 near_x = near_coordinates; 02295 near_y = near_x + near_coordinates_size/3; 02296 near_z = near_y + near_coordinates_size/3; 02297 on_x = *on_coordinates; 02298 on_y = on_x + count; 02299 on_z = on_y + count; 02300 on_step = 1; 02301 } 02302 else { 02303 storage_order = iBase_INTERLEAVED; /* set if unspecified */ 02304 near_x = near_coordinates; 02305 near_y = near_x+1; 02306 near_z = near_x+2; 02307 on_x = *on_coordinates; 02308 on_y = on_x+1; 02309 on_z = on_x+2; 02310 near_step *= 3; 02311 on_step = 3; 02312 } 02313 02314 RefEntity** ent_iter = (RefEntity**)(gentity_handles); 02315 CubitStatus final_result = CUBIT_SUCCESS; 02316 for (int i = 0; i < count; ++i) { 02317 CubitVector on, near( *near_x, *near_y, *near_z ); 02318 CubitStatus status = iGeom_closest_point( *ent_iter, near, on ); 02319 if (status != CUBIT_SUCCESS) 02320 final_result = status; 02321 on.get_xyz( *on_x, *on_y, *on_z ); 02322 02323 ent_iter += ent_step; 02324 near_x += near_step; 02325 near_y += near_step; 02326 near_z += near_step; 02327 on_x += on_step; 02328 on_y += on_step; 02329 on_z += on_step; 02330 } 02331 02332 if (final_result == CUBIT_FAILURE) { 02333 ERROR(iBase_FAILURE, "Problems getting closest point for some entity."); 02334 } 02335 02336 KEEP_ARRAY(on_coordinates); 02337 RETURN(iBase_SUCCESS); 02338 } 02339 02340 02341 ITAPS_API void 02342 iGeom_getEntNrmlPlXYZ( iGeom_Instance instance, 02343 /*in*/ iBase_EntityHandle entity_handle, 02344 /*in*/ double x, 02345 /*in*/ double y, 02346 /*in*/ double z, 02347 /*out*/ double* pt_x, 02348 /*out*/ double* pt_y, 02349 /*out*/ double* pt_z, 02350 /*out*/ double* nmrl_i, 02351 /*out*/ double* nmrl_j, 02352 /*out*/ double* nmrl_k, 02353 int* err ) 02354 { 02355 RefEntity* entity = (RefEntity*)entity_handle; 02356 CubitVector pt, nmrl, near(x, y, z); 02357 CubitStatus status = iGeom_closest_point_and_normal( entity, near, pt, nmrl ); 02358 if (status == CUBIT_FAILURE) { 02359 ERROR(iBase_FAILURE, "Problems getting closest point for some entity."); 02360 } 02361 pt.get_xyz( *pt_x, *pt_y, *pt_z ); 02362 nmrl.get_xyz( *nmrl_i, *nmrl_j, *nmrl_k ); 02363 RETURN(iBase_SUCCESS); 02364 } 02365 02375 ITAPS_API void 02376 iGeom_getArrNrmlPlXYZ( iGeom_Instance instance, 02377 /*in*/ iBase_EntityHandle const *gentity_handles, 02378 const int gentity_handles_size, 02379 /*in*/ int storage_order, 02380 /*in*/ const double *near_coordinates, 02381 const int near_coordinates_size, 02382 /*out*/ double **on_coordinates, 02383 int *on_coordinates_allocated, 02384 int *on_coordinates_size, 02385 /*out*/ double **normals, 02386 int *normals_allocated, 02387 int *normals_size, 02388 int* err ) 02389 { 02390 /* set up iteration according to storage order. 02391 allow either gentity_handles or near_coordinates to contain 02392 only one value, where that single value is applied for every 02393 entry in the other list. 02394 */ 02395 size_t near_step, on_step = 1, ent_step; 02396 int count; 02397 if (3*gentity_handles_size == near_coordinates_size) { 02398 near_step = ent_step = 1; 02399 count = gentity_handles_size; 02400 } 02401 else if (near_coordinates_size == 3) { 02402 near_step = 0; 02403 ent_step = 1; 02404 count = gentity_handles_size; 02405 } 02406 else if (gentity_handles_size == 1) { 02407 near_step = 1; 02408 ent_step = 0; 02409 count = near_coordinates_size / 3; 02410 } 02411 else { 02412 ERROR( iBase_INVALID_ENTITY_COUNT, "Mismatched array sizes" ); 02413 } 02414 ALLOC_CHECK_ARRAY( on_coordinates, 3*count ); 02415 ALLOC_CHECK_ARRAY( normals, 3*count ); 02416 02417 const double *near_x, *near_y, *near_z; 02418 double *on_x, *on_y, *on_z; 02419 double *norm_x, *norm_y, *norm_z; 02420 if (storage_order == iBase_BLOCKED) { 02421 near_x = near_coordinates; 02422 near_y = near_x + near_coordinates_size/3; 02423 near_z = near_y + near_coordinates_size/3; 02424 on_x = *on_coordinates; 02425 on_y = on_x + count; 02426 on_z = on_y + count; 02427 norm_x = *normals; 02428 norm_y = norm_x + count; 02429 norm_z = norm_y + count; 02430 on_step = 1; 02431 } 02432 else { 02433 storage_order = iBase_INTERLEAVED; /* set if unspecified */ 02434 near_x = near_coordinates; 02435 near_y = near_x+1; 02436 near_z = near_x+2; 02437 on_x = *on_coordinates; 02438 on_y = on_x+1; 02439 on_z = on_x+2; 02440 norm_x = *normals; 02441 norm_y = norm_x+1; 02442 norm_z = norm_x+2; 02443 near_step *= 3; 02444 on_step = 3; 02445 } 02446 02447 RefEntity** ent_iter = (RefEntity**)(gentity_handles); 02448 CubitStatus final_result = CUBIT_SUCCESS; 02449 for (int i = 0; i < count; ++i) { 02450 CubitVector on, norm, near( *near_x, *near_y, *near_z ); 02451 CubitStatus status = iGeom_closest_point_and_normal( *ent_iter, near, on, norm ); 02452 if (status != CUBIT_SUCCESS) 02453 final_result = status; 02454 on.get_xyz( *on_x, *on_y, *on_z ); 02455 norm.get_xyz( *norm_x, *norm_y, *norm_z ); 02456 02457 ent_iter += ent_step; 02458 near_x += near_step; 02459 near_y += near_step; 02460 near_z += near_step; 02461 on_x += on_step; 02462 on_y += on_step; 02463 on_z += on_step; 02464 norm_x += on_step; 02465 norm_y += on_step; 02466 norm_z += on_step; 02467 } 02468 02469 if (final_result == CUBIT_FAILURE) { 02470 ERROR(iBase_FAILURE, "Problems getting closest point for some entity."); 02471 } 02472 02473 KEEP_ARRAY(on_coordinates); 02474 KEEP_ARRAY(normals); 02475 RETURN(iBase_SUCCESS); 02476 } 02477 02478 ITAPS_API void 02479 iGeom_getEntNrmlXYZ( iGeom_Instance instance, 02480 /*in*/ iBase_EntityHandle entity_handle, 02481 /*in*/ double near_x, 02482 /*in*/ double near_y, 02483 /*in*/ double near_z, 02484 /*out*/ double* nmrl_i, 02485 /*out*/ double* nmrl_j, 02486 /*out*/ double* nmrl_k, 02487 int* err ) 02488 { 02489 RefEntity* entity = (RefEntity*)entity_handle; 02490 RefFace* face = dynamic_cast<RefFace*>(entity); 02491 if (NULL == face) { 02492 ERROR(iBase_INVALID_ENTITY_TYPE, "Entities passed into gentityNormal must be faces."); 02493 } 02494 02495 CubitVector normal, near( near_x, near_y, near_z ); 02496 normal = face->normal_at( near ); 02497 normal.get_xyz( *nmrl_i, *nmrl_j, *nmrl_k ); 02498 RETURN(iBase_SUCCESS); 02499 } 02500 02509 ITAPS_API void 02510 iGeom_getArrNrmlXYZ( iGeom_Instance instance, 02511 /*in*/ iBase_EntityHandle const *gentity_handles, 02512 int gentity_handles_size, 02513 int storage_order, 02514 /*in*/ const double *coordinates, 02515 int coordinates_size, 02516 /*out*/ double **normals, 02517 int *normals_allocated, 02518 int *normals_size, 02519 int* err ) 02520 { 02521 /* set up iteration according to storage order. 02522 allow either gentity_handles or near_coordinates to contain 02523 only one value, where that single value is applied for every 02524 entry in the other list. 02525 */ 02526 size_t coord_step, norm_step = 1, ent_step; 02527 int count; 02528 if (3*gentity_handles_size == coordinates_size) { 02529 coord_step = ent_step = 1; 02530 count = gentity_handles_size; 02531 } 02532 else if (coordinates_size == 3) { 02533 coord_step = 0; 02534 ent_step = 1; 02535 count = gentity_handles_size; 02536 } 02537 else if (gentity_handles_size == 1) { 02538 coord_step = 1; 02539 ent_step = 0; 02540 count = coordinates_size / 3; 02541 } 02542 else { 02543 ERROR( iBase_INVALID_ENTITY_COUNT, "Mismatched array sizes" ); 02544 } 02545 02546 // check or pre-allocate the coordinate arrays 02547 ALLOC_CHECK_ARRAY( normals, 3*count ); 02548 02549 const double *coord_x, *coord_y, *coord_z; 02550 double *norm_x, *norm_y, *norm_z; 02551 if (storage_order == iBase_BLOCKED) { 02552 coord_x = coordinates; 02553 coord_y = coord_x + coordinates_size/3; 02554 coord_z = coord_y + coordinates_size/3; 02555 norm_x = *normals; 02556 norm_y = norm_x + count; 02557 norm_z = norm_y + count; 02558 norm_step = 1; 02559 } 02560 else { 02561 storage_order = iBase_INTERLEAVED; /* set if unspecified */ 02562 coord_x = coordinates; 02563 coord_y = coord_x+1; 02564 coord_z = coord_x+2; 02565 norm_x = *normals; 02566 norm_y = norm_x+1; 02567 norm_z = norm_x+2; 02568 coord_step *= 3; 02569 norm_step = 3; 02570 } 02571 02572 RefEntity** entities = (RefEntity**)(gentity_handles); 02573 for (int i = 0; i < count; ++i) 02574 { 02575 RefFace* face = dynamic_cast<RefFace*>(*entities); 02576 if (NULL == face) { 02577 ERROR(iBase_INVALID_ENTITY_TYPE, "Entities passed into gentityNormal must be faces."); 02578 } 02579 else { 02580 CubitVector normal, coords( *coord_x, *coord_y, *coord_z ); 02581 normal = face->normal_at( coords ); 02582 normal.get_xyz( *norm_x, *norm_y, *norm_z ); 02583 } 02584 entities += ent_step; 02585 coord_x += coord_step; 02586 coord_y += coord_step; 02587 coord_z += coord_step; 02588 norm_x += norm_step; 02589 norm_y += norm_step; 02590 norm_z += norm_step; 02591 } 02592 02593 KEEP_ARRAY(normals); 02594 RETURN(iBase_SUCCESS); 02595 } 02596 02597 02598 ITAPS_API void 02599 iGeom_getEntTgntXYZ( iGeom_Instance instance, 02600 /*in*/ iBase_EntityHandle entity_handle, 02601 /*in*/ double x, 02602 /*in*/ double y, 02603 /*in*/ double z, 02604 /*out*/ double* tgnt_i, 02605 /*out*/ double* tgnt_j, 02606 /*out*/ double* tgnt_k, 02607 int* err ) 02608 { 02609 RefEntity* entity = (RefEntity*)entity_handle; 02610 RefEdge* edge = dynamic_cast<RefEdge*>(entity); 02611 if (NULL == edge) { 02612 ERROR(iBase_INVALID_ENTITY_TYPE, "Entities passed into gentityTangent must be edges."); 02613 } 02614 02615 CubitVector tangent, near( x, y, x ); 02616 edge->tangent( near, tangent ); 02617 tangent.get_xyz( *tgnt_i, *tgnt_j, *tgnt_k ); 02618 RETURN(iBase_SUCCESS); 02619 } 02620 02629 ITAPS_API void 02630 iGeom_getArrTgntXYZ( iGeom_Instance instance, 02631 /*in*/ iBase_EntityHandle const *gentity_handles, 02632 int gentity_handles_size, 02633 /*in*/ int storage_order, 02634 /*in*/ const double *coordinates, 02635 int coordinates_size, 02636 /*out*/ double **tangents, 02637 int *tangents_allocated, 02638 int *tangents_size, 02639 int* err ) 02640 { 02641 /* set up iteration according to storage order. 02642 allow either gentity_handles or near_coordinates to contain 02643 only one value, where that single value is applied for every 02644 entry in the other list. 02645 */ 02646 size_t coord_step, tan_step = 1, ent_step; 02647 int count; 02648 if (3*gentity_handles_size == coordinates_size) { 02649 coord_step = ent_step = 1; 02650 count = gentity_handles_size; 02651 } 02652 else if (coordinates_size == 3) { 02653 coord_step = 0; 02654 ent_step = 1; 02655 count = gentity_handles_size; 02656 } 02657 else if (gentity_handles_size == 1) { 02658 coord_step = 1; 02659 ent_step = 0; 02660 count = coordinates_size / 3; 02661 } 02662 else { 02663 ERROR( iBase_INVALID_ENTITY_COUNT, "Mismatched array sizes" ); 02664 } 02665 02666 // check or pre-allocate the coordinate arrays 02667 ALLOC_CHECK_ARRAY( tangents, 3*count ); 02668 02669 const double *coord_x, *coord_y, *coord_z; 02670 double *tan_x, *tan_y, *tan_z; 02671 if (storage_order == iBase_BLOCKED) { 02672 coord_x = coordinates; 02673 coord_y = coord_x + coordinates_size/3; 02674 coord_z = coord_y + coordinates_size/3; 02675 tan_x = *tangents; 02676 tan_y = tan_x + count; 02677 tan_z = tan_y + count; 02678 tan_step = 1; 02679 } 02680 else { 02681 storage_order = iBase_INTERLEAVED; /* set if unspecified */ 02682 coord_x = coordinates; 02683 coord_y = coord_x+1; 02684 coord_z = coord_x+2; 02685 tan_x = *tangents; 02686 tan_y = tan_x+1; 02687 tan_z = tan_x+2; 02688 coord_step *= 3; 02689 tan_step = 3; 02690 } 02691 02692 RefEntity** entities = (RefEntity**)(gentity_handles); 02693 for (int i = 0; i < count; ++i) 02694 { 02695 RefEdge* edge = dynamic_cast<RefEdge*>(*entities); 02696 if (NULL == edge) { 02697 ERROR(iBase_INVALID_ENTITY_TYPE, "Entities passed into gentityTangent must be edges."); 02698 } 02699 else { 02700 CubitVector tangent, coords( *coord_x, *coord_y, *coord_z ); 02701 edge->tangent( coords, tangent ); 02702 tangent.get_xyz( *tan_x, *tan_y, *tan_z ); 02703 } 02704 02705 entities += ent_step; 02706 coord_x += coord_step; 02707 coord_y += coord_step; 02708 coord_z += coord_step; 02709 tan_x += tan_step; 02710 tan_y += tan_step; 02711 tan_z += tan_step; 02712 } 02713 02714 KEEP_ARRAY(tangents); 02715 RETURN(iBase_SUCCESS); 02716 } 02717 02718 02719 ITAPS_API void 02720 iGeom_getFcCvtrXYZ( iGeom_Instance instance, 02721 /*in*/ iBase_EntityHandle face_handle, 02722 /*in*/ double x, 02723 /*in*/ double y, 02724 /*in*/ double z, 02725 /*out*/ double* cvtr1_i, 02726 /*out*/ double* cvtr1_j, 02727 /*out*/ double* cvtr1_k, 02728 /*out*/ double* cvtr2_i, 02729 /*out*/ double* cvtr2_j, 02730 /*out*/ double* cvtr2_k, 02731 int* err ) 02732 { 02733 RefEntity* entity = (RefEntity*)face_handle; 02734 RefFace* face = dynamic_cast<RefFace*>(entity); 02735 if (!face) 02736 RETURN(iBase_INVALID_ENTITY_TYPE); 02737 02738 Surface* surf = face->get_surface_ptr(); 02739 CubitVector loc(x,y,z), curv1, curv2; 02740 CubitStatus status = surf->closest_point( loc, 0, 0, &curv1, &curv2 ); 02741 if (surf->bridge_sense() == CUBIT_REVERSED) { 02742 curv1 = -curv1; 02743 curv2 = -curv2; 02744 } 02745 curv1.get_xyz( *cvtr1_i, *cvtr1_j, *cvtr1_k ); 02746 curv2.get_xyz( *cvtr2_i, *cvtr2_j, *cvtr2_k ); 02747 RETURN( (status == CUBIT_SUCCESS ? iBase_SUCCESS : iBase_FAILURE) ); 02748 } 02749 02750 ITAPS_API void 02751 iGeom_getEgCvtrXYZ( iGeom_Instance instance, 02752 /*in*/ iBase_EntityHandle edge_handle, 02753 /*in*/ double x, 02754 /*in*/ double y, 02755 /*in*/ double z, 02756 /*out*/ double* cvtr_i, 02757 /*out*/ double* cvtr_j, 02758 /*out*/ double* cvtr_k, 02759 int* err ) 02760 { 02761 RefEntity* entity = (RefEntity*)edge_handle; 02762 RefEdge* edge = dynamic_cast<RefEdge*>(entity); 02763 if (!edge) 02764 RETURN(iBase_INVALID_ENTITY_TYPE); 02765 02766 CubitVector loc(x,y,z), junk, curv; 02767 CubitStatus status = edge->closest_point( loc, junk, 0, &curv ); 02768 curv.get_xyz( *cvtr_i, *cvtr_j, *cvtr_k ); 02769 RETURN( (status == CUBIT_SUCCESS ? iBase_SUCCESS : iBase_FAILURE) ); 02770 } 02771 02772 ITAPS_API void 02773 iGeom_getEntArrCvtrXYZ( iGeom_Instance instance, 02774 /*in*/ const iBase_EntityHandle *entity_handles, 02775 int entity_handles_size, 02776 /*in*/ int storage_order, 02777 /*in*/ const double *coordinates, 02778 int coordinates_size, 02779 /*inout*/ double **cvtr_1, 02780 int *cvtr_1_allocated, 02781 int *cvtr_1_size, 02782 /*inout*/ double **cvtr_2, 02783 int *cvtr_2_allocated, 02784 int *cvtr_2_size, 02785 int* err ) 02786 { 02787 RefEntity** entities = (RefEntity**)(entity_handles); 02788 02789 /* set up iteration according to storage order. 02790 allow either gentity_handles or near_coordinates to contain 02791 only one value, where that single value is applied for every 02792 entry in the other list. 02793 */ 02794 size_t coord_step, cvtr_step = 1, ent_step; 02795 int count; 02796 if (3*entity_handles_size == coordinates_size) { 02797 coord_step = ent_step = 1; 02798 count = entity_handles_size; 02799 } 02800 else if (coordinates_size == 3) { 02801 coord_step = 0; 02802 ent_step = 1; 02803 count = entity_handles_size; 02804 } 02805 else if (entity_handles_size == 1) { 02806 coord_step = 1; 02807 ent_step = 0; 02808 count = coordinates_size / 3; 02809 } 02810 else { 02811 ERROR( iBase_INVALID_ENTITY_COUNT, "Mismatched array sizes" ); 02812 } 02813 02814 /* check if input list contains any surfaces. */ 02815 bool have_surfs = false; 02816 for (int s = 0; s < entity_handles_size; ++s) 02817 if (dynamic_cast<RefFace*>(entities[s])) { 02818 have_surfs = true; 02819 break; 02820 } 02821 02822 // check or pre-allocate the coordinate arrays 02823 ALLOC_CHECK_ARRAY( cvtr_1, 3*count ); 02824 ALLOC_CHECK_ARRAY( cvtr_2, have_surfs ? 3*count : 0 ); 02825 02826 const double *coord_x, *coord_y, *coord_z; 02827 double *c1x, *c1y, *c1z, *c2x, *c2y, *c2z; 02828 if (storage_order == iBase_BLOCKED) { 02829 coord_x = coordinates; 02830 coord_y = coord_x + coordinates_size/3; 02831 coord_z = coord_y + coordinates_size/3; 02832 c1x = *cvtr_1; 02833 c1y = c1x + count; 02834 c1z = c1y + count; 02835 c2x = *cvtr_2; 02836 c2y = c2x + count; 02837 c2z = c2y + count; 02838 cvtr_step = 1; 02839 } 02840 else { 02841 storage_order = iBase_INTERLEAVED; /* set if unspecified */ 02842 coord_x = coordinates; 02843 coord_y = coord_x+1; 02844 coord_z = coord_x+2; 02845 c1x = *cvtr_1; 02846 c1y = c1x+1; 02847 c1z = c1x+2; 02848 c2x = *cvtr_2; 02849 c2y = c2x+1; 02850 c2z = c2x+2; 02851 coord_step *= 3; 02852 cvtr_step = 3; 02853 } 02854 02855 RefFace *face; 02856 RefEdge *edge; 02857 CubitStatus result = CUBIT_SUCCESS; 02858 for (int i = 0; i < count; ++i) { 02859 CubitStatus status; 02860 const CubitVector coords( *coord_x, *coord_y, *coord_z ); 02861 if ((face = dynamic_cast<RefFace*>(*entities))) { 02862 Surface* surf = face->get_surface_ptr(); 02863 CubitVector curv1, curv2; 02864 status = surf->closest_point( coords, 0, 0, &curv1, &curv2 ); 02865 curv1.get_xyz( *c1x, *c1y, *c1z ); 02866 curv2.get_xyz( *c2x, *c2y, *c2z ); 02867 } 02868 else if ((edge = dynamic_cast<RefEdge*>(*entities))) { 02869 CubitVector junk, curv; 02870 status = edge->closest_point( coords, junk, 0, &curv ); 02871 curv.get_xyz( *c1x, *c1y, *c1z ); 02872 } 02873 else { 02874 status = CUBIT_FAILURE; 02875 } 02876 02877 if (CUBIT_SUCCESS != status) 02878 result = status; 02879 02880 entities += ent_step; 02881 coord_x += coord_step; 02882 coord_y += coord_step; 02883 coord_z += coord_step; 02884 c1x += cvtr_step; 02885 c1y += cvtr_step; 02886 c1z += cvtr_step; 02887 c2x += cvtr_step; 02888 c2y += cvtr_step; 02889 c2z += cvtr_step; 02890 } 02891 02892 if (result == CUBIT_FAILURE) 02893 RETURN(iBase_FAILURE); 02894 02895 KEEP_ARRAY( cvtr_1 ); 02896 KEEP_ARRAY( cvtr_2 ); 02897 RETURN( iBase_SUCCESS ); 02898 } 02899 02900 02901 ITAPS_API void 02902 iGeom_getEgEvalXYZ( iGeom_Instance instance, 02903 /*in*/ iBase_EntityHandle edge_handle, 02904 /*in*/ double x, 02905 /*in*/ double y, 02906 /*in*/ double z, 02907 /*out*/ double* on_x, 02908 /*out*/ double* on_y, 02909 /*out*/ double* on_z, 02910 /*out*/ double* tan_i, 02911 /*out*/ double* tan_j, 02912 /*out*/ double* tan_k, 02913 /*out*/ double* cvtr_i, 02914 /*out*/ double* cvtr_j, 02915 /*out*/ double* cvtr_k, 02916 int* err ) 02917 { 02918 RefEntity* entity = (RefEntity*)edge_handle; 02919 RefEdge* edge = dynamic_cast<RefEdge*>(entity); 02920 if (!edge) 02921 RETURN(iBase_INVALID_ENTITY_TYPE); 02922 02923 CubitVector loc(x,y,z), on, tan, curv; 02924 CubitStatus status = edge->closest_point( loc, on, &tan, &curv ); 02925 on.get_xyz( *on_x, *on_y, *on_z ); 02926 tan.get_xyz( *tan_i, *tan_j, *tan_k ); 02927 curv.get_xyz( *cvtr_i, *cvtr_j, *cvtr_k ); 02928 RETURN( (status == CUBIT_SUCCESS ? iBase_SUCCESS : iBase_FAILURE) ); 02929 } 02930 02931 ITAPS_API void 02932 iGeom_getFcEvalXYZ( iGeom_Instance instance, 02933 /*in*/ iBase_EntityHandle face_handle, 02934 /*in*/ double x, 02935 /*in*/ double y, 02936 /*in*/ double z, 02937 /*out*/ double* on_x, 02938 /*out*/ double* on_y, 02939 /*out*/ double* on_z, 02940 /*out*/ double* norm_i, 02941 /*out*/ double* norm_j, 02942 /*out*/ double* norm_k, 02943 /*out*/ double* cvtr1_i, 02944 /*out*/ double* cvtr1_j, 02945 /*out*/ double* cvtr1_k, 02946 /*out*/ double* cvtr2_i, 02947 /*out*/ double* cvtr2_j, 02948 /*out*/ double* cvtr2_k, 02949 int* err ) 02950 { 02951 RefEntity* entity = (RefEntity*)face_handle; 02952 RefFace* face = dynamic_cast<RefFace*>(entity); 02953 if (!face) 02954 RETURN(iBase_INVALID_ENTITY_TYPE); 02955 02956 Surface* surf = face->get_surface_ptr(); 02957 CubitVector loc(x,y,z), on, norm, curv1, curv2; 02958 #ifdef CGM_HAVE_FACET_ENGINE_ONLY 02959 CubitStatus status = surf->closest_point( loc, &on, &norm); 02960 #else 02961 CubitStatus status = surf->closest_point( loc, &on, &norm, &curv1, &curv2 ); 02962 #endif 02963 02964 if (surf->bridge_sense() == CUBIT_REVERSED) { 02965 norm = -norm; 02966 curv1 = -curv1; 02967 curv2 = -curv2; 02968 } 02969 on.get_xyz( *on_x, *on_y, *on_z ); 02970 norm.get_xyz( *norm_i, *norm_j, *norm_k ); 02971 curv1.get_xyz( *cvtr1_i, *cvtr1_j, *cvtr1_k ); 02972 curv2.get_xyz( *cvtr2_i, *cvtr2_j, *cvtr2_k ); 02973 RETURN( (status == CUBIT_SUCCESS ? iBase_SUCCESS : iBase_FAILURE) ); 02974 } 02975 02976 ITAPS_API void 02977 iGeom_getArrEgEvalXYZ( iGeom_Instance instance, 02978 /*in*/ const iBase_EntityHandle *edge_handles, 02979 int edge_handles_size, 02980 /*in*/ int storage_order, 02981 /*in*/ const double *coordinates, 02982 int coordinates_size, 02983 /*inout*/ double **on_coords, 02984 int *on_coords_allocated, 02985 int *on_coords_size, 02986 /*inout*/ double **tangents, 02987 int *tangents_allocated, 02988 int *tangents_size, 02989 /*inout*/ double **curvatures, 02990 int *curvatures_allocated, 02991 int *curvatures_size, 02992 int* err ) 02993 { 02994 /* set up iteration according to storage order. 02995 allow either gentity_handles or near_coordinates to contain 02996 only one value, where that single value is applied for every 02997 entry in the other list. 02998 */ 02999 size_t coord_step, on_step = 1, ent_step; 03000 int count; 03001 if (3*edge_handles_size == coordinates_size) { 03002 coord_step = ent_step = 1; 03003 count = edge_handles_size; 03004 } 03005 else if (coordinates_size == 3) { 03006 coord_step = 0; 03007 ent_step = 1; 03008 count = edge_handles_size; 03009 } 03010 else if (edge_handles_size == 1) { 03011 coord_step = 1; 03012 ent_step = 0; 03013 count = coordinates_size / 3; 03014 } 03015 else { 03016 ERROR( iBase_INVALID_ENTITY_COUNT, "Mismatched array sizes" ); 03017 } 03018 03019 // check or pre-allocate the coordinate arrays 03020 ALLOC_CHECK_ARRAY( on_coords, 3*count ); 03021 ALLOC_CHECK_ARRAY( tangents, 3*count ); 03022 ALLOC_CHECK_ARRAY( curvatures, 3*count ); 03023 03024 const double *coord_x, *coord_y, *coord_z; 03025 double *on_x, *on_y, *on_z; 03026 double *tan_x, *tan_y, *tan_z; 03027 double *curv_x, *curv_y, *curv_z; 03028 if (storage_order == iBase_BLOCKED) { 03029 coord_x = coordinates; 03030 coord_y = coord_x + coordinates_size/3; 03031 coord_z = coord_y + coordinates_size/3; 03032 on_x = *on_coords; 03033 on_y = on_x + count; 03034 on_z = on_y + count; 03035 tan_x = *tangents; 03036 tan_y = tan_x + count; 03037 tan_z = tan_y + count; 03038 curv_x = *curvatures; 03039 curv_y = curv_x + count; 03040 curv_z = curv_y + count; 03041 on_step = 1; 03042 } 03043 else { 03044 storage_order = iBase_INTERLEAVED; /* set if unspecified */ 03045 coord_x = coordinates; 03046 coord_y = coord_x+1; 03047 coord_z = coord_x+2; 03048 on_x = *on_coords; 03049 on_y = on_x + 1; 03050 on_z = on_x + 2; 03051 tan_x = *tangents; 03052 tan_y = tan_x+1; 03053 tan_z = tan_x+2; 03054 curv_x = *curvatures; 03055 curv_y = curv_x + 1; 03056 curv_z = curv_x + 2; 03057 coord_step *= 3; 03058 on_step = 3; 03059 } 03060 03061 RefEntity** ent_iter = (RefEntity**)edge_handles; 03062 iBase_ErrorType result = iBase_SUCCESS; 03063 for (int i = 0; i < count; ++i) { 03064 RefEdge* edge = dynamic_cast<RefEdge*>(*ent_iter); 03065 if (!edge) { 03066 ERROR(iBase_INVALID_ENTITY_TYPE, "Non-edge input handle."); 03067 } 03068 else { 03069 const CubitVector coords( *coord_x, *coord_y, *coord_z ); 03070 CubitVector on, tan, curv; 03071 CubitStatus s = edge->closest_point( coords, on, &tan, &curv ); 03072 if (s == CUBIT_FAILURE) 03073 result = iBase_FAILURE; 03074 on.get_xyz( *on_x, *on_y, *on_z ); 03075 tan.get_xyz( *tan_x, *tan_y, *tan_z ); 03076 curv.get_xyz( *curv_x, *curv_y, *curv_z ); 03077 } 03078 03079 ent_iter += ent_step; 03080 coord_x += coord_step; 03081 coord_y += coord_step; 03082 coord_z += coord_step; 03083 on_x += on_step; 03084 on_y += on_step; 03085 on_z += on_step; 03086 tan_x += on_step; 03087 tan_y += on_step; 03088 tan_z += on_step; 03089 curv_x += on_step; 03090 curv_y += on_step; 03091 curv_z += on_step; 03092 } 03093 03094 KEEP_ARRAY( on_coords ); 03095 KEEP_ARRAY( tangents ); 03096 KEEP_ARRAY( curvatures ); 03097 RETURN(result); 03098 } 03099 03100 ITAPS_API void 03101 iGeom_getArrFcEvalXYZ( iGeom_Instance instance, 03102 /*in*/ const iBase_EntityHandle *face_handles, 03103 int face_handles_size, 03104 /*in*/ int storage_order, 03105 /*in*/ const double *coordinates, 03106 int coordinates_size, 03107 /*inout*/ double **on_coords, 03108 int *on_coords_allocated, 03109 int *on_coords_size, 03110 /*inout*/ double **normals, 03111 int *normals_allocated, 03112 int *normals_size, 03113 /*inout*/ double **curvatures_1, 03114 int *curvatures_1_allocated, 03115 int *curvatures_1_size, 03116 /*inout*/ double **curvatures_2, 03117 int *curvatures_2_allocated, 03118 int *curvatures_2_size, 03119 int* err ) 03120 { 03121 /* set up iteration according to storage order. 03122 allow either gentity_handles or near_coordinates to contain 03123 only one value, where that single value is applied for every 03124 entry in the other list. 03125 */ 03126 size_t coord_step, on_step = 1, ent_step; 03127 int count; 03128 if (3*face_handles_size == coordinates_size) { 03129 coord_step = ent_step = 1; 03130 count = face_handles_size; 03131 } 03132 else if (coordinates_size == 3) { 03133 coord_step = 0; 03134 ent_step = 1; 03135 count = face_handles_size; 03136 } 03137 else if (face_handles_size == 1) { 03138 coord_step = 1; 03139 ent_step = 0; 03140 count = coordinates_size / 3; 03141 } 03142 else { 03143 ERROR( iBase_INVALID_ENTITY_COUNT, "Mismatched array sizes" ); 03144 } 03145 03146 // check or pre-allocate the coordinate arrays 03147 ALLOC_CHECK_ARRAY( on_coords, 3*count ); 03148 ALLOC_CHECK_ARRAY( normals, 3*count ); 03149 ALLOC_CHECK_ARRAY( curvatures_1, 3*count ); 03150 ALLOC_CHECK_ARRAY( curvatures_2, 3*count ); 03151 03152 const double *coord_x, *coord_y, *coord_z; 03153 double *on_x, *on_y, *on_z; 03154 double *norm_x, *norm_y, *norm_z; 03155 double *curv1_x, *curv1_y, *curv1_z; 03156 double *curv2_x, *curv2_y, *curv2_z; 03157 if (storage_order == iBase_BLOCKED) { 03158 coord_x = coordinates; 03159 coord_y = coord_x + coordinates_size/3; 03160 coord_z = coord_y + coordinates_size/3; 03161 on_x = *on_coords; 03162 on_y = on_x + count; 03163 on_z = on_y + count; 03164 norm_x = *normals; 03165 norm_y = norm_x + count; 03166 norm_z = norm_y + count; 03167 curv1_x = *curvatures_1; 03168 curv1_y = curv1_x + count; 03169 curv1_z = curv1_y + count; 03170 curv2_x = *curvatures_2; 03171 curv2_y = curv2_x + count; 03172 curv2_z = curv2_y + count; 03173 on_step = 1; 03174 } 03175 else { 03176 storage_order = iBase_INTERLEAVED; /* set if unspecified */ 03177 coord_x = coordinates; 03178 coord_y = coord_x+1; 03179 coord_z = coord_x+2; 03180 on_x = *on_coords; 03181 on_y = on_x + 1; 03182 on_z = on_x + 2; 03183 norm_x = *normals; 03184 norm_y = norm_x+1; 03185 norm_z = norm_x+2; 03186 curv1_x = *curvatures_1; 03187 curv1_y = curv1_x + 1; 03188 curv1_z = curv1_x + 2; 03189 curv2_x = *curvatures_2; 03190 curv2_y = curv2_x + 1; 03191 curv2_z = curv2_x + 2; 03192 coord_step *= 3; 03193 on_step = 3; 03194 } 03195 03196 RefEntity** ent_iter = (RefEntity**)face_handles; 03197 iBase_ErrorType result = iBase_SUCCESS; 03198 for (int i = 0; i < count; ++i) { 03199 RefFace* face = dynamic_cast<RefFace*>(*ent_iter); 03200 if (!face) { 03201 ERROR(iBase_INVALID_ENTITY_TYPE, "Non-face input handle."); 03202 result = iBase_INVALID_ENTITY_TYPE; 03203 } 03204 else { 03205 const CubitVector coords( *coord_x, *coord_y, *coord_z ); 03206 CubitVector on, norm, curv1, curv2; 03207 Surface* surf = face->get_surface_ptr(); 03208 #ifdef CGM_HAVE_FACET_ENGINE_ONLY 03209 CubitStatus s = surf->closest_point( coords, &on, &norm); 03210 #else 03211 CubitStatus s = surf->closest_point( coords, &on, &norm, &curv1, &curv2 ); 03212 #endif 03213 if (s == CUBIT_FAILURE) 03214 result = iBase_FAILURE; 03215 on.get_xyz( *on_x, *on_y, *on_z ); 03216 norm.get_xyz( *norm_x, *norm_y, *norm_z ); 03217 curv1.get_xyz( *curv1_x, *curv1_y, *curv1_z ); 03218 curv2.get_xyz( *curv2_x, *curv2_y, *curv2_z ); 03219 } 03220 03221 ent_iter += ent_step; 03222 coord_x += coord_step; 03223 coord_y += coord_step; 03224 coord_z += coord_step; 03225 on_x += on_step; 03226 on_y += on_step; 03227 on_z += on_step; 03228 norm_x += on_step; 03229 norm_y += on_step; 03230 norm_z += on_step; 03231 curv1_x += on_step; 03232 curv1_y += on_step; 03233 curv1_z += on_step; 03234 curv2_x += on_step; 03235 curv2_y += on_step; 03236 curv2_z += on_step; 03237 } 03238 03239 KEEP_ARRAY( on_coords ); 03240 KEEP_ARRAY( normals ); 03241 KEEP_ARRAY( curvatures_1 ); 03242 KEEP_ARRAY( curvatures_2 ); 03243 RETURN(result); 03244 } 03245 03253 ITAPS_API void 03254 iGeom_measure( iGeom_Instance instance, 03255 /*in*/ const iBase_EntityHandle *gentity_handles, 03256 int gentity_handles_size, 03257 /*out*/ double **measures, 03258 int *measures_allocated, 03259 int *measures_size, 03260 int* err ) 03261 { 03262 RefEntity **handle_array = (RefEntity**)(gentity_handles); 03263 03264 // check or pre-allocate the measure arrays 03265 ALLOC_CHECK_ARRAY_NOFAIL(measures, gentity_handles_size); 03266 for (int i = 0; i < gentity_handles_size; i++) 03267 (*measures)[i] = handle_array[i]->measure(); 03268 03269 RETURN(iBase_SUCCESS); 03270 } 03271 03272 ITAPS_API void 03273 iGeom_getEntBoundBox( iGeom_Instance instance, 03274 /*in*/ iBase_EntityHandle entity_handle, 03275 /*out*/ double* min_x, 03276 /*out*/ double* min_y, 03277 /*out*/ double* min_z, 03278 /*out*/ double* max_x, 03279 /*out*/ double* max_y, 03280 /*out*/ double* max_z, 03281 int* err ) 03282 { 03283 RefEntity* entity = (RefEntity*)entity_handle; 03284 CubitVector minc, maxc; 03285 CubitStatus status = iGeom_bounding_box( entity, minc, maxc ); 03286 minc.get_xyz( *min_x, *min_y, *min_z ); 03287 maxc.get_xyz( *max_x, *max_y, *max_z ); 03288 RETURN( (status == CUBIT_SUCCESS ? iBase_SUCCESS : iBase_FAILURE) ); 03289 } 03290 03296 ITAPS_API void 03297 iGeom_getFaceType( iGeom_Instance instance, 03298 /*in*/ iBase_EntityHandle gentity_handle, 03299 /*out*/ char *face_type, 03300 int* err, 03301 int *face_type_length ) 03302 { 03303 static const char *surf_types[] = {"cone", "plane", "sphere", "spline", 03304 "torus", "best_fit", "facet", "undefined"}; 03305 03306 RefEntity *this_ent = ENTITY_HANDLE(gentity_handle); 03307 RefFace *this_face = dynamic_cast<RefFace*>(this_ent); 03308 if (!this_face) 03309 RETURN(iBase_INVALID_ENTITY_TYPE); 03310 GeometryType this_type = this_face->get_surface_ptr()->geometry_type(); 03311 if (this_type < CONE_SURFACE_TYPE || this_type > UNDEFINED_SURFACE_TYPE) { 03312 RETURN(iBase_FAILURE); 03313 } 03314 03315 const char* result = surf_types[this_type - CONE_SURFACE_TYPE]; 03316 const int len = strlen(result); 03317 if (len < *face_type_length) { 03318 strcpy(face_type, result); 03319 *face_type_length = len; 03320 } 03321 else { 03322 strncpy(face_type, result, *face_type_length-1); 03323 face_type[*face_type_length] = '\0'; 03324 } 03325 03326 RETURN(iBase_SUCCESS); 03327 } 03328 03336 ITAPS_API void 03337 iGeom_getArrBoundBox( iGeom_Instance instance, 03338 /*in*/ const iBase_EntityHandle *gentity_handles, 03339 int gentity_handles_size, 03340 /*in*/ int storage_order, 03341 /*out*/ double **min_corner, 03342 int *min_corner_allocated, 03343 int *min_corner_size, 03344 /*out*/ double **max_corner, 03345 int *max_corner_allocated, 03346 int *max_corner_size, 03347 int* err ) 03348 { 03349 // check or pre-allocate the coordinate arrays 03350 ALLOC_CHECK_ARRAY(min_corner, 3*gentity_handles_size); 03351 ALLOC_CHECK_ARRAY(max_corner, 3*gentity_handles_size); 03352 03353 size_t step, init; 03354 if (storage_order == iBase_BLOCKED) { 03355 step = 1; 03356 init = gentity_handles_size; 03357 } 03358 else { 03359 step = 3; 03360 init = 1; 03361 } 03362 double *min_x, *min_y, *min_z, *max_x, *max_y, *max_z; 03363 min_x = *min_corner; 03364 max_x = *max_corner; 03365 min_y = min_x + init; 03366 max_y = max_x + init; 03367 min_z = min_y + init; 03368 max_z = max_y + init; 03369 03370 iBase_ErrorType result = iBase_SUCCESS; 03371 RefEntity** entities = (RefEntity**)gentity_handles; 03372 for (int i = 0; i < gentity_handles_size; ++i) 03373 { 03374 CubitVector min_c, max_c; 03375 CubitStatus s = iGeom_bounding_box( entities[i], min_c, max_c ); 03376 if (s != CUBIT_SUCCESS) 03377 result = iBase_FAILURE; 03378 min_c.get_xyz( *min_x, *min_y, *min_z ); 03379 max_c.get_xyz( *max_x, *max_y, *max_z ); 03380 03381 min_x += step; 03382 max_x += step; 03383 min_y += step; 03384 max_y += step; 03385 min_z += step; 03386 max_z += step; 03387 } 03388 03389 KEEP_ARRAY(min_corner); 03390 KEEP_ARRAY(max_corner); 03391 RETURN(result); 03392 } 03393 03394 ITAPS_API void 03395 iGeom_getVtxCoord( iGeom_Instance instance, 03396 /*in*/ iBase_EntityHandle vertex_handle, 03397 /*out*/ double* x, 03398 /*out*/ double* y, 03399 /*out*/ double* z, 03400 int* err ) 03401 { 03402 RefEntity* entity = (RefEntity*)vertex_handle; 03403 RefVertex* vertex = dynamic_cast<RefVertex*>(entity); 03404 if (!vertex) { 03405 ERROR(iBase_INVALID_ENTITY_TYPE, "Entity not a vertex"); 03406 } 03407 vertex->coordinates().get_xyz(*x, *y, *z); 03408 RETURN(iBase_SUCCESS); 03409 } 03410 03417 ITAPS_API void 03418 iGeom_getVtxArrCoords( iGeom_Instance instance, 03419 /*in*/ const iBase_EntityHandle *gentity_handles, 03420 int gentity_handles_size, 03421 /*in*/ int storage_order, 03422 /*out*/ double **coordinates, 03423 int *coordinates_allocated, 03424 int *coordinates_size, 03425 int* err ) 03426 { 03427 const RefEntity **handle_array = (const RefEntity**)(gentity_handles); 03428 03429 // check or pre-allocate the coordinate arrays 03430 ALLOC_CHECK_ARRAY(coordinates, 3*gentity_handles_size); 03431 03432 CubitVector dumvec; 03433 const RefVertex *this_vertex; 03434 03435 double *x, *y, *z; 03436 size_t step; 03437 if (storage_order == iBase_BLOCKED) { 03438 x = *coordinates; 03439 y = x + gentity_handles_size; 03440 z = y + gentity_handles_size; 03441 step = 1; 03442 } 03443 else { 03444 x = *coordinates; 03445 y = x + 1; 03446 z = x + 2; 03447 step = 3; 03448 } 03449 03450 for (int i = 0; i < gentity_handles_size; i++) { 03451 this_vertex = dynamic_cast<const RefVertex*>(handle_array[i]); 03452 if (NULL == this_vertex) { 03453 ERROR(iBase_INVALID_ENTITY_TYPE, "Entities passed into getGvertexCoordinates must be vertices."); 03454 } 03455 else { 03456 dumvec = this_vertex->coordinates(); 03457 dumvec.get_xyz(*x,*y,*z); 03458 x += step; 03459 y += step; 03460 z += step; 03461 } 03462 } 03463 03464 KEEP_ARRAY(coordinates); 03465 RETURN(iBase_SUCCESS); 03466 } 03467 03468 ITAPS_API void 03469 iGeom_getPntRayIntsct( iGeom_Instance instance, 03470 /*in*/ double x, 03471 /*in*/ double y, 03472 /*in*/ double z, 03473 /*in*/ double dx, 03474 /*in*/ double dy, 03475 /*in*/ double dz, 03476 /*inout*/ iBase_EntityHandle **intersect_entity_handles, 03477 int *intersect_entity_handles_allocated, 03478 int *intersect_entity_handles_size, 03479 /*in*/ int storage_order, 03480 /*inout*/ double **intersect_coords, 03481 int *intersect_coords_allocated, 03482 int *intersect_coords_size, 03483 /*inout*/ double **param_coords, 03484 int *param_coords_allocated, 03485 int *param_coords_size, 03486 int* err ) 03487 { 03488 DLIList<double> ray_params; 03489 DLIList<RefEntity*> entities; 03490 CubitVector point(x,y,z), dir(dx,dy,dz); 03491 CubitStatus status = iGeom_fire_ray( point, dir, entities, ray_params ); 03492 if (status != CUBIT_SUCCESS) 03493 RETURN(iBase_FAILURE); 03494 03495 ALLOC_CHECK_ARRAY_NOFAIL( intersect_entity_handles, entities.size() ); 03496 ALLOC_CHECK_ARRAY_NOFAIL( intersect_coords, 3*ray_params.size() ); 03497 ALLOC_CHECK_ARRAY_NOFAIL( param_coords, ray_params.size() ); 03498 03499 size_t init, step; 03500 if (storage_order == iBase_BLOCKED) { 03501 init = ray_params.size(); 03502 step = 1; 03503 } 03504 else { 03505 init = 1; 03506 step = 3; 03507 } 03508 03509 double *x_iter = *intersect_coords; 03510 double *y_iter = x_iter + init; 03511 double *z_iter = y_iter + init; 03512 for (size_t i = ray_params.size(); i > 0; --i) { 03513 double t = ray_params.get_and_step(); 03514 CubitVector pos = t * dir + point; 03515 pos.get_xyz( *x_iter, *y_iter, *z_iter ); 03516 x_iter += step; 03517 y_iter += step; 03518 z_iter += step; 03519 } 03520 ray_params.copy_to( *param_coords ); 03521 entities.copy_to( (RefEntity**)*intersect_entity_handles ); 03522 03523 RETURN(iBase_SUCCESS); 03524 } 03525 03526 ITAPS_API void 03527 iGeom_getPntArrRayIntsct( iGeom_Instance instance, 03528 /*in*/ int storage_order, 03529 /*in*/ const double *points, 03530 int points_size, 03531 /*in*/ const double *directions, 03532 int directions_size, 03533 /*inout*/ iBase_EntityHandle **intersect_entity_handles, 03534 int *intersect_entity_handles_allocated, 03535 int *intersect_entity_handles_size, 03536 /*inout*/ int **offset, 03537 int *offset_allocated, 03538 int *offset_size, 03539 /*inout*/ double **intersect_coords, 03540 int *intersect_coords_allocated, 03541 int *intersect_coords_size, 03542 /*inout*/ double **param_coords, 03543 int *param_coords_allocated, 03544 int *param_coords_size, 03545 int* err ) 03546 { 03547 if (points_size != directions_size || points_size % 3) { 03548 ERROR(iBase_INVALID_ARGUMENT, "Mismatched or invalid input array size"); 03549 } 03550 03551 const int count = points_size / 3; 03552 ALLOC_CHECK_ARRAY( offset, count ); 03553 03554 const double *px, *py, *pz, *dx, *dy, *dz; 03555 size_t init, step; 03556 if (storage_order == iBase_BLOCKED) { 03557 init = count; 03558 step = 1; 03559 } 03560 else { 03561 storage_order = iBase_INTERLEAVED; 03562 init = 1; 03563 step = 3; 03564 } 03565 px = points; 03566 py = px + init; 03567 pz = py + init; 03568 dx = directions; 03569 dy = dx + init; 03570 dz = dy + init; 03571 03572 DLIList<RefEntity*> entities, tmp_entities; 03573 DLIList<double> params, tmp_params; 03574 std::vector<CubitVector> coords; 03575 for (int i = 0; i < count; ++i) 03576 { 03577 tmp_entities.clean_out(); 03578 tmp_params.clean_out(); 03579 (*offset)[i] = params.size(); 03580 const CubitVector point(*px, *py, *pz), dir(*dx, *dy, *dz); 03581 CubitStatus s = iGeom_fire_ray( point, dir, tmp_entities, tmp_params ); 03582 if (CUBIT_SUCCESS != s) { 03583 RETURN(iBase_FAILURE); 03584 } 03585 03586 entities += tmp_entities; 03587 params += tmp_params; 03588 tmp_params.reset(); 03589 for (int j = tmp_params.size(); j > 0; --j) 03590 coords.push_back( tmp_params.get_and_step() * dir + point ); 03591 03592 px += step; 03593 py += step; 03594 pz += step; 03595 dx += step; 03596 dy += step; 03597 dz += step; 03598 } 03599 03600 ALLOC_CHECK_ARRAY_NOFAIL( intersect_entity_handles, entities.size() ); 03601 ALLOC_CHECK_ARRAY_NOFAIL( intersect_coords, coords.size() ); 03602 ALLOC_CHECK_ARRAY_NOFAIL( param_coords, params.size() ); 03603 entities.copy_to( (RefEntity**)*intersect_entity_handles ); 03604 params.copy_to( *param_coords ); 03605 03606 double *x = *intersect_coords; 03607 double *y = x + init; 03608 double *z = y + init; 03609 for (std::vector<CubitVector>::const_iterator k = coords.begin(); k != coords.end(); ++k) 03610 { 03611 k->get_xyz( *x, *y, *z ); 03612 x += step; 03613 y += step; 03614 z += step; 03615 } 03616 03617 KEEP_ARRAY(offset); 03618 RETURN(iBase_SUCCESS); 03619 } 03620 03621 ITAPS_API void 03622 iGeom_getPntClsf( iGeom_Instance instance, 03623 /*in*/ double x, 03624 /*in*/ double y, 03625 /*in*/ double z, 03626 /*out*/ iBase_EntityHandle* entity_handle, 03627 int* err ) 03628 { 03629 RefEntity** ptr = (RefEntity**)entity_handle; 03630 const CubitVector pt(x,y,z); 03631 *ptr = iGeom_get_point_containment( pt ); 03632 RETURN( *ptr ? iBase_SUCCESS : iBase_FAILURE ); 03633 } 03634 03635 ITAPS_API void 03636 iGeom_getPntArrClsf( iGeom_Instance instance, 03637 /*in*/ int storage_order, 03638 /*in*/ const double *coords, 03639 int coords_size, 03640 /*inout*/ iBase_EntityHandle **entity_handles, 03641 int *entity_handles_allocated, 03642 int *entity_handles_size, 03643 int* err ) 03644 { 03645 size_t init, step; 03646 int count = coords_size / 3; 03647 if (storage_order == iBase_BLOCKED) { 03648 init = count; 03649 step = 1; 03650 } 03651 else { 03652 storage_order = iBase_INTERLEAVED; 03653 init = 1; 03654 step = 3; 03655 } 03656 const double *x = coords; 03657 const double *y = x + init; 03658 const double *z = y + init; 03659 03660 ALLOC_CHECK_ARRAY( entity_handles, count ); 03661 03662 RefEntity** array = (RefEntity**)*entity_handles; 03663 for (int i = 0; i < count; ++i) 03664 { 03665 const CubitVector pt( *x, *y, *z ); 03666 array[i] = iGeom_get_point_containment( pt ); 03667 if (!array[i]) { 03668 RETURN(iBase_FAILURE); 03669 } 03670 x += step; 03671 y += step; 03672 z += step; 03673 } 03674 03675 KEEP_ARRAY(entity_handles); 03676 RETURN(iBase_SUCCESS); 03677 } 03678 03686 ITAPS_API void 03687 iGeom_getEntNrmlSense( iGeom_Instance instance, 03688 /*in*/ iBase_EntityHandle gface, 03689 /*in*/ iBase_EntityHandle gregion, 03690 int* rel_sense, 03691 int* err ) 03692 { 03693 const RefFace *face_ent = dynamic_cast<const RefFace*>(ENTITY_HANDLE(gface)); 03694 if (NULL == face_ent) { 03695 ERROR(iBase_INVALID_ENTITY_TYPE, "1st argument to getEntNrmlSense must be a face."); 03696 } 03697 03698 // XXX: workaround; remove this when we switch iBase_REGIONs to RefVolume 03699 const RefVolume *volume_ent; 03700 Body *body_ent = dynamic_cast<Body*>(ENTITY_HANDLE(gregion)); 03701 if (NULL != body_ent) { 03702 DLIList<RefEntity*> children; 03703 body_ent->get_child_ref_entities(children); 03704 if (children.size() != 1) { 03705 ERROR(iBase_FAILURE, "Can only support bodies with one volume"); 03706 } 03707 volume_ent = dynamic_cast<const RefVolume*>(children[0]); 03708 } 03709 else { 03710 volume_ent = dynamic_cast<const RefVolume*>(ENTITY_HANDLE(gregion)); 03711 } 03712 03713 if (NULL == volume_ent) { 03714 ERROR(iBase_INVALID_ENTITY_TYPE, "2nd argument to getEntNrmlSense must be a region."); 03715 } 03716 03717 *rel_sense = iGeom_get_nonmanifold_sense( face_ent, volume_ent, err ); 03718 } 03719 03720 ITAPS_API void 03721 iGeom_getArrNrmlSense( iGeom_Instance instance, 03722 /*in*/ iBase_EntityHandle const *faces, 03723 int faces_size, 03724 /*in*/ iBase_EntityHandle const *regions, 03725 int regions_size, 03726 /*inout*/ int **senses, 03727 int *senses_allocated, 03728 int *senses_size, 03729 int* err ) 03730 { 03731 size_t faces_step, regions_step; 03732 int count; 03733 if (faces_size == regions_size) { 03734 faces_step = regions_step = 1; 03735 count = faces_size; 03736 } 03737 else if (faces_size == 1) { 03738 faces_step = 0; 03739 regions_step = 1; 03740 count = regions_size; 03741 } 03742 else if (regions_size == 1) { 03743 faces_step = 1; 03744 regions_step = 0; 03745 count = faces_size; 03746 } 03747 else { 03748 ERROR( iBase_INVALID_ENTITY_COUNT, "Mismatched input array sizes" ); 03749 RETURN (iBase_INVALID_ENTITY_COUNT); 03750 } 03751 03752 RefEntity** face_iter = (RefEntity**)faces; 03753 RefEntity** region_iter = (RefEntity**)regions; 03754 ALLOC_CHECK_ARRAY( senses, count ); 03755 for (int i = 0; i < count; ++i) { 03756 RefFace *face_ent = dynamic_cast<RefFace*>(*face_iter); 03757 if (NULL == face_ent) { 03758 ERROR(iBase_INVALID_ENTITY_TYPE, "1st argument to getArrNrmlSense must be a face."); 03759 } 03760 03761 // XXX: workaround; remove this when we switch iBase_REGIONs to RefVolume 03762 const RefVolume *volume_ent; 03763 Body *body_ent = dynamic_cast<Body*>(*region_iter); 03764 if (NULL != body_ent) { 03765 DLIList<RefEntity*> children; 03766 body_ent->get_child_ref_entities(children); 03767 if (children.size() != 1) { 03768 ERROR(iBase_FAILURE, "Can only support bodies with one volume"); 03769 } 03770 volume_ent = dynamic_cast<const RefVolume*>(children[0]); 03771 } 03772 else { 03773 volume_ent = dynamic_cast<const RefVolume*>(*region_iter); 03774 } 03775 03776 if (NULL == volume_ent) { 03777 ERROR(iBase_INVALID_ENTITY_TYPE, "2nd argument to getArrNrmlSense must be a region."); 03778 } 03779 03780 (*senses)[i] = iGeom_get_nonmanifold_sense( face_ent, volume_ent, err ); 03781 if (iBase_SUCCESS != *err) 03782 return; 03783 03784 face_iter += faces_step; 03785 region_iter += regions_step; 03786 } 03787 03788 KEEP_ARRAY(senses); 03789 RETURN(iBase_SUCCESS); 03790 } 03791 03792 03793 03801 ITAPS_API void 03802 iGeom_getEgFcSense( iGeom_Instance instance, 03803 /*in*/ iBase_EntityHandle gedge, 03804 /*in*/ iBase_EntityHandle gface, 03805 int* rel_sense, 03806 int* err ) 03807 { 03808 const RefEdge *edge_ent = dynamic_cast<const RefEdge*>(ENTITY_HANDLE(gedge)); 03809 if (NULL == edge_ent) { 03810 ERROR(iBase_INVALID_ENTITY_TYPE, "1st argument to getGtangentSense must be an edge."); 03811 } 03812 const RefFace *face_ent = dynamic_cast<const RefFace*>(ENTITY_HANDLE(gface)); 03813 if (NULL == face_ent) { 03814 ERROR(iBase_INVALID_ENTITY_TYPE, "2nd argument to getGtangentSense must be a face."); 03815 } 03816 *rel_sense = iGeom_get_nonmanifold_sense( edge_ent, face_ent, err ); 03817 RETURN(iBase_SUCCESS); 03818 } 03819 03820 ITAPS_API void 03821 iGeom_getEgFcArrSense( iGeom_Instance instance, 03822 /*in*/ iBase_EntityHandle const *edges, 03823 int edges_size, 03824 /*in*/ iBase_EntityHandle const *faces, 03825 int faces_size, 03826 /*inout*/ int **senses, 03827 int *senses_allocated, 03828 int *senses_size, 03829 int* err ) 03830 { 03831 size_t faces_step, edges_step; 03832 int count; 03833 if (faces_size == edges_size) { 03834 faces_step = edges_step = 1; 03835 count = faces_size; 03836 } 03837 else if (faces_size == 1) { 03838 faces_step = 0; 03839 edges_step = 1; 03840 count = edges_size; 03841 } 03842 else if (edges_size == 1) { 03843 faces_step = 1; 03844 edges_step = 0; 03845 count = faces_size; 03846 } 03847 else { 03848 ERROR( iBase_INVALID_ENTITY_COUNT, "Mismatched input array sizes" ); 03849 } 03850 03851 RefEntity** face_iter = (RefEntity**)faces; 03852 RefEntity** edge_iter = (RefEntity**)edges; 03853 ALLOC_CHECK_ARRAY( senses, count ); 03854 for (int i = 0; i < count; ++i) { 03855 RefEdge *edge_ent = dynamic_cast<RefEdge*>(*edge_iter); 03856 if (NULL == edge_ent) { 03857 ERROR(iBase_INVALID_ENTITY_TYPE, "1st argument to getGnormalSense must be a face."); 03858 } 03859 RefFace *face_ent = dynamic_cast<RefFace*>(*face_iter); 03860 if (NULL == face_ent) { 03861 ERROR(iBase_INVALID_ENTITY_TYPE, "2nd argument to getGnormalSense must be a region."); 03862 } 03863 (*senses)[i] = iGeom_get_nonmanifold_sense( edge_ent, face_ent, err ); 03864 if (iBase_SUCCESS != *err) 03865 return; 03866 03867 face_iter += faces_step; 03868 edge_iter += edges_step; 03869 } 03870 03871 KEEP_ARRAY(senses); 03872 RETURN(iBase_SUCCESS); 03873 } 03874 03885 ITAPS_API void 03886 iGeom_getEgVtxSense( iGeom_Instance instance, 03887 /*in*/ iBase_EntityHandle gedge, 03888 /*in*/ iBase_EntityHandle gvertex1, 03889 /*in*/ iBase_EntityHandle gvertex2, 03890 int* rel_sense, 03891 int* err ) 03892 { 03893 const RefEdge *this_edge = dynamic_cast<const RefEdge*>(ENTITY_HANDLE(gedge)); 03894 const RefVertex *vertex1 = dynamic_cast<const RefVertex*>(ENTITY_HANDLE(gvertex1)); 03895 const RefVertex *vertex2 = dynamic_cast<const RefVertex*>(ENTITY_HANDLE(gvertex2)); 03896 if (NULL == this_edge || NULL == vertex1 || NULL == vertex2) { 03897 ERROR(iBase_INVALID_ENTITY_TYPE, "Bad entity argument to getGvertexTangentSense."); 03898 } 03899 *rel_sense = iGeom_edge_vertex_sense( this_edge, vertex1, vertex2, err ); 03900 RETURN(iBase_SUCCESS); 03901 } 03902 03903 ITAPS_API void 03904 iGeom_getEgVtxArrSense( iGeom_Instance instance, 03905 /*in*/ iBase_EntityHandle const *edges , 03906 int edges_size, 03907 /*in*/ iBase_EntityHandle const *start_vertices , 03908 int start_vertices_size, 03909 /*in*/ iBase_EntityHandle const *end_vertices , 03910 int end_vertices_size, 03911 /*inout*/ int **senses , 03912 int *senses_allocated, 03913 int *senses_size, 03914 int* err ) 03915 { 03916 int count; 03917 size_t edge_step, start_step, end_step; 03918 edge_step = edges_size > 1; 03919 start_step = start_vertices_size > 1; 03920 end_step = end_vertices_size > 1; 03921 count = edges_size; 03922 if (count != 1) { 03923 if (start_vertices_size != 1 && start_vertices_size != count) { 03924 ERROR( iBase_INVALID_ENTITY_COUNT, "Mismatched input array sizes" ); 03925 } 03926 } 03927 else 03928 count = start_vertices_size; 03929 if (count != 1) { 03930 if (end_vertices_size != 1 && end_vertices_size != count) { 03931 ERROR( iBase_INVALID_ENTITY_COUNT, "Mismatched input array sizes" ); 03932 } 03933 } 03934 else 03935 count = end_vertices_size; 03936 03937 ALLOC_CHECK_ARRAY( senses, count ); 03938 03939 RefEntity** edge_iter = (RefEntity**)edges; 03940 RefEntity** start_iter = (RefEntity**)start_vertices; 03941 RefEntity** end_iter = (RefEntity**)end_vertices; 03942 for (int i = 0; i < count; ++i) { 03943 RefEdge* edge = dynamic_cast<RefEdge*>(*edge_iter); 03944 RefVertex* vtx1 = dynamic_cast<RefVertex*>(*start_iter); 03945 RefVertex* vtx2 = dynamic_cast<RefVertex*>(*end_iter); 03946 if (!edge || !vtx1 || !vtx2) { 03947 ERROR(iBase_INVALID_ENTITY_TYPE, "Bad entity argument to getGvertexTangentSense."); 03948 } 03949 03950 (*senses)[i] = iGeom_edge_vertex_sense( edge, vtx1, vtx2, err ); 03951 if (iBase_SUCCESS != *err) 03952 return; 03953 edge_iter += edge_step; 03954 start_iter += start_step; 03955 end_iter += end_step; 03956 } 03957 03958 KEEP_ARRAY(senses); 03959 RETURN(iBase_SUCCESS); 03960 } 03961 03962 03963 03964 03965 03972 ITAPS_API void 03973 iGeom_getNumEntSets( iGeom_Instance instance, 03974 /*in*/ iBase_EntitySetHandle entity_set, 03975 /*in*/ int num_hops, 03976 int* num_ent_sets, 03977 int* err ) 03978 { 03979 // HJK: num_hops has to be handled 03980 if (0 < num_hops) { 03981 ERROR(iBase_NOT_SUPPORTED, "Num_hops argument not yet supported."); 03982 } 03983 03984 const RefGroup *this_set = SET_HANDLE(entity_set); 03985 if (NULL == this_set) 03986 *num_ent_sets = RefEntityFactory::instance()->num_ref_groups(); 03987 else { 03988 DLIList<RefEntity*> tmp_ents; 03989 DLIList<RefGroup*> groups; 03990 const_cast<RefGroup*>(this_set)->get_child_ref_entities(tmp_ents); 03991 CAST_LIST(tmp_ents, groups, RefGroup); 03992 *num_ent_sets = groups.size(); 03993 } 03994 03995 RETURN(iBase_SUCCESS); 03996 } 03997 04005 ITAPS_API void 04006 iGeom_getEntSets( iGeom_Instance instance, 04007 /*in*/ iBase_EntitySetHandle entity_set, 04008 /*in*/ int num_hops, 04009 /*inout*/ iBase_EntitySetHandle **contained_entity_set_handles, 04010 int *contained_entity_set_handles_allocated, 04011 int *contained_entity_set_handles_size, 04012 int *err ) 04013 { 04014 if (0 < num_hops) { 04015 ERROR(iBase_NOT_SUPPORTED, "Num_hops argument not yet supported."); 04016 } 04017 04018 const RefGroup *this_set = SET_HANDLE(entity_set); 04019 DLIList<RefEntity*> tmp_ents; 04020 DLIList<RefGroup*> groups; 04021 if (NULL == this_set) 04022 RefEntityFactory::instance()->ref_groups(groups); 04023 else { 04024 const_cast<RefGroup*>(this_set)->get_child_ref_entities(tmp_ents); 04025 CAST_LIST(tmp_ents, groups, RefGroup); 04026 } 04027 04028 ALLOC_CHECK_ARRAY_NOFAIL(contained_entity_set_handles, groups.size()); 04029 04030 groups.copy_to(*SET_HANDLE_ARRAY_PTR(contained_entity_set_handles)); 04031 04032 RETURN(iBase_SUCCESS); 04033 } 04034 04048 ITAPS_API void 04049 iGeom_createEntSet( iGeom_Instance instance, 04050 /*in*/ int isList, 04051 /*out*/ iBase_EntitySetHandle *entity_set, 04052 int* err ) 04053 { 04054 RefGroup* grp = RefEntityFactory::instance()->construct_RefGroup(); 04055 *entity_set = reinterpret_cast<iBase_EntitySetHandle>(grp); 04056 // need to set a tag denoting multiset or not... 04057 if (*entity_set == NULL) { 04058 RETURN(iBase_FAILURE); 04059 } 04060 04061 else { 04062 RETURN(iBase_SUCCESS); 04063 } 04064 } 04065 04071 ITAPS_API void 04072 iGeom_destroyEntSet( iGeom_Instance instance, 04073 /*in*/ iBase_EntitySetHandle entity_set, 04074 int* err ) 04075 { 04076 if (NULL == entity_set) { 04077 ERROR(iBase_INVALID_ARGUMENT, "Can't destroy interface set."); 04078 } 04079 04080 CubitStatus result = RefGroup::delete_group(SET_HANDLE(entity_set)); 04081 if (CUBIT_SUCCESS == result) { 04082 RETURN(iBase_SUCCESS); 04083 } 04084 04085 else { 04086 RETURN(iBase_FAILURE); 04087 } 04088 04089 } 04090 04091 ITAPS_API void 04092 iGeom_isList( iGeom_Instance instance, 04093 /*in*/ iBase_EntitySetHandle entity_set, 04094 int* result, 04095 int* err ) 04096 { 04097 *result = true; 04098 RETURN (iBase_SUCCESS); 04099 } 04100 04110 ITAPS_API void 04111 iGeom_addEntSet( iGeom_Instance instance, 04112 /*in*/ iBase_EntitySetHandle entity_set_to_add, 04113 /*inout*/ iBase_EntitySetHandle entity_set_handle, 04114 int* err ) 04115 { 04116 iGeom_addEntToSet(instance, reinterpret_cast<iBase_EntityHandle>(entity_set_to_add), entity_set_handle, err); 04117 } 04118 04127 ITAPS_API void 04128 iGeom_rmvEntSet( iGeom_Instance instance, 04129 /*in*/ iBase_EntitySetHandle entity_set_to_remove, 04130 /*inout*/ iBase_EntitySetHandle entity_set_handle, 04131 int* err ) 04132 { 04133 iGeom_rmvEntFromSet(instance, reinterpret_cast<iBase_EntityHandle>(entity_set_to_remove), entity_set_handle, err); 04134 } 04135 04145 ITAPS_API void 04146 iGeom_addEntToSet( iGeom_Instance instance, 04147 /*in*/ iBase_EntityHandle entity_to_add, 04148 /*inout*/ iBase_EntitySetHandle entity_set_handle, 04149 int* err ) 04150 { 04151 if (NULL == entity_to_add) RETURN(iBase_INVALID_ARGUMENT); 04152 04153 CubitStatus status = SET_HANDLE(entity_set_handle)-> 04154 add_ref_entity(const_cast<RefEntity*>(ENTITY_HANDLE(entity_to_add))); 04155 04156 if (CUBIT_SUCCESS != status) { 04157 ERROR(iBase_FAILURE, "Problem adding entity to another set."); 04158 } 04159 04160 RETURN(iBase_SUCCESS); 04161 } 04162 04171 ITAPS_API void 04172 iGeom_rmvEntFromSet( iGeom_Instance instance, 04173 /*in*/ iBase_EntityHandle entity_to_remove, 04174 /*inout*/ iBase_EntitySetHandle entity_set_handle, 04175 int* err ) 04176 { 04177 if (NULL == entity_set_handle) RETURN(iBase_INVALID_ARGUMENT); 04178 04179 CubitStatus status = SET_HANDLE(entity_set_handle)-> 04180 remove_ref_entity(const_cast<RefEntity*>(ENTITY_HANDLE(entity_to_remove))); 04181 if (CUBIT_SUCCESS != status) { 04182 ERROR(iBase_FAILURE, "Problem removing entity from a set."); 04183 } 04184 04185 RETURN(iBase_SUCCESS); 04186 } 04187 04188 ITAPS_API void 04189 iGeom_isEntContained( iGeom_Instance instance, 04190 /*in*/ iBase_EntitySetHandle containing_entity_set, 04191 /*in*/ iBase_EntityHandle contained_entity, 04192 int* is_contained, 04193 int* err ) 04194 { 04195 // everything is contained in root set 04196 if (NULL == containing_entity_set && NULL != contained_entity) { 04197 *is_contained = true; 04198 RETURN( iBase_SUCCESS ); 04199 } 04200 04201 DLIList<RefGroup*> containing_groups; 04202 RefEntity *contained_entity_temp = const_cast<RefEntity*>(ENTITY_HANDLE(contained_entity)); 04203 RefGroup::get_groups_within(contained_entity_temp, containing_groups, CUBIT_FALSE); 04204 *is_contained = containing_groups.size() > 0 && 04205 containing_groups.move_to(const_cast<RefGroup*>(SET_HANDLE(containing_entity_set))) ; 04206 04207 RETURN(iBase_SUCCESS); 04208 } 04209 04210 ITAPS_API void 04211 iGeom_isEntArrContained( iGeom_Instance instance, 04212 /*in*/ iBase_EntitySetHandle containing_set, 04213 /*in*/ const iBase_EntityHandle* entity_handles, 04214 /*in*/ int num_entity_handles, 04215 /*inout*/ int** is_contained, 04216 /*inout*/ int* is_contained_allocated, 04217 /*out*/ int* is_contained_size, 04218 /*out*/ int* err ) 04219 { 04220 // go through each entity and look up its dimension 04221 ALLOC_CHECK_ARRAY(is_contained, num_entity_handles); 04222 04223 for (int i = 0; i < num_entity_handles; ++i) { 04224 iGeom_isEntContained( instance, containing_set, entity_handles[i], (*is_contained)+i, err ); 04225 if (iBase_SUCCESS != *err) 04226 return; 04227 } 04228 04229 KEEP_ARRAY(is_contained); 04230 RETURN(iBase_SUCCESS); 04231 } 04232 04233 ITAPS_API void 04234 iGeom_isEntSetContained( iGeom_Instance instance, 04235 /*in*/ iBase_EntitySetHandle containing_entity_set, 04236 /*in*/ iBase_EntitySetHandle contained_entity_set, 04237 int* is_contained, 04238 int* err ) 04239 { 04240 iGeom_isEntContained( instance, containing_entity_set, 04241 reinterpret_cast<iBase_EntityHandle>(contained_entity_set), 04242 is_contained, err); 04243 } 04244 04253 ITAPS_API void 04254 iGeom_addEntArrToSet( iGeom_Instance instance, 04255 /*in*/ iBase_EntityHandle const* entity_handles, 04256 int entity_handles_size, 04257 /*inout*/ iBase_EntitySetHandle entity_set, 04258 int* err ) 04259 { 04260 if (NULL == entity_set) RETURN(iBase_INVALID_ARGUMENT); 04261 04262 RefGroup *this_set = SET_HANDLE(entity_set); 04263 RefEntity **ent_array = (RefEntity**)(entity_handles); 04264 CubitStatus status = CUBIT_SUCCESS, tmp_status; 04265 for (int i = 0; i < entity_handles_size; i++) { 04266 tmp_status = this_set->add_ref_entity(ent_array[i]); 04267 if (CUBIT_SUCCESS != tmp_status) status = tmp_status; 04268 } 04269 04270 if (CUBIT_SUCCESS != status) { 04271 ERROR(iBase_FAILURE, "Problem adding entities to a set."); 04272 } 04273 04274 RETURN(iBase_SUCCESS); 04275 } 04276 04282 ITAPS_API void 04283 iGeom_rmvEntArrFromSet( iGeom_Instance instance, 04284 /*in*/ iBase_EntityHandle const* entity_handles, 04285 int entity_handles_size, 04286 /*inout*/ iBase_EntitySetHandle entity_set, 04287 int* err ) 04288 { 04289 if (NULL == entity_set) RETURN(iBase_INVALID_ARGUMENT); 04290 04291 RefGroup *this_set = SET_HANDLE(entity_set); 04292 RefEntity **ent_array = (RefEntity**)(entity_handles); 04293 CubitStatus status = CUBIT_SUCCESS, tmp_status; 04294 for (int i = 0; i < entity_handles_size; i++) { 04295 tmp_status = this_set->remove_ref_entity(ent_array[i]); 04296 if (CUBIT_SUCCESS != tmp_status) status = tmp_status; 04297 } 04298 04299 if (CUBIT_SUCCESS != status) { 04300 ERROR(iBase_FAILURE, "Problem removing entities from a set."); 04301 } 04302 04303 RETURN(iBase_SUCCESS); 04304 } 04305 04313 ITAPS_API void 04314 iGeom_getTolerance( iGeom_Instance instance, 04315 /*out*/ int* type, 04316 /*out*/ double* tolerance, 04317 int* err ) 04318 { 04319 *type = 1; 04320 *tolerance = gqt->get_sme_resabs_tolerance(); 04321 RETURN(iBase_SUCCESS); 04322 } 04323 04324 ITAPS_API void 04325 iGeom_getEntTolerance( iGeom_Instance instance, 04326 /*in*/ iBase_EntityHandle entity_handle, 04327 double* tolerance, 04328 int* err ) 04329 { 04330 *tolerance = gqt->get_sme_resabs_tolerance(); 04331 RETURN(iBase_SUCCESS); 04332 } 04333 04342 ITAPS_API void 04343 iGeom_getArrTolerance( iGeom_Instance instance, 04344 /*in*/ iBase_EntityHandle const *gentity_handles, 04345 const int gentity_handles_size, 04346 /*out*/ double **tolerances, 04347 int *tolerances_allocated, 04348 int *tolerances_size, 04349 int* err ) 04350 { 04351 ALLOC_CHECK_ARRAY_NOFAIL(tolerances, gentity_handles_size); 04352 double dum_abs_tol = gqt->get_sme_resabs_tolerance(); 04353 for (int i = 0; i < gentity_handles_size; i++) { 04354 (*tolerances)[i] = dum_abs_tol; 04355 } 04356 RETURN(iBase_SUCCESS); 04357 } 04358 04359 ITAPS_API void 04360 iGeom_getParametric( iGeom_Instance instance, 04361 int* is_parametric, 04362 int* err ) 04363 { 04364 *is_parametric = true; 04365 RETURN(iBase_SUCCESS); 04366 } 04367 04374 ITAPS_API void 04375 iGeom_isEntParametric( iGeom_Instance instance, 04376 /*in*/ iBase_EntityHandle gentity_handle, 04377 int* is_parametric, 04378 int* err ) 04379 { 04380 *is_parametric = iGeom_is_parametric( (RefEntity*)gentity_handle ); 04381 RETURN (iBase_SUCCESS); 04382 } 04383 04384 ITAPS_API void 04385 iGeom_isArrParametric( iGeom_Instance instance, 04386 iBase_EntityHandle const *entity_handles, 04387 int entity_handles_size, 04388 int **is_parametric, 04389 int *is_parametric_allocated, 04390 int *is_parametric_size, 04391 int* err ) 04392 { 04393 ALLOC_CHECK_ARRAY_NOFAIL( is_parametric, entity_handles_size ); 04394 RefEntity** const ent_array = (RefEntity**)entity_handles; 04395 for (int i = 0; i < entity_handles_size; ++i) 04396 (*is_parametric)[i] = iGeom_is_parametric( ent_array[i] ); 04397 RETURN(iBase_SUCCESS); 04398 } 04399 04400 ITAPS_API void 04401 iGeom_getEntUVtoXYZ( iGeom_Instance instance, 04402 /*in*/ iBase_EntityHandle entity_handle, 04403 /*in*/ double u, 04404 /*in*/ double v, 04405 /*out*/ double* x, 04406 /*out*/ double* y, 04407 /*out*/ double* z, 04408 int* err ) 04409 { 04410 RefEntity* entity = (RefEntity*)entity_handle; 04411 RefFace* face = dynamic_cast<RefFace*>(entity); 04412 if (!face) { 04413 ERROR(iBase_INVALID_ENTITY_TYPE, "Expected face for UV method."); 04414 } 04415 04416 CubitVector xyz = face->position_from_u_v( u, v ); 04417 xyz.get_xyz( *x, *y, *z ); 04418 RETURN(iBase_SUCCESS); 04419 } 04420 04429 ITAPS_API void 04430 iGeom_getArrUVtoXYZ( iGeom_Instance instance, 04431 /*in*/ iBase_EntityHandle const *gentity_handles, 04432 int gentity_handles_size, 04433 /*in*/ int storage_order, 04434 /*in*/ const double *uv, 04435 int uv_size, 04436 /*out*/ double **coordinates, 04437 int *coordinates_allocated, 04438 int *coordinates_size, 04439 int* err ) 04440 { 04441 size_t ent_step, coord_step, uv_step; 04442 int count; 04443 if (2*gentity_handles_size == uv_size) { 04444 ent_step = uv_step = 1; 04445 count = gentity_handles_size; 04446 } 04447 else if (uv_size == 2) { 04448 ent_step = 1; 04449 uv_step = 0; 04450 count = gentity_handles_size; 04451 } 04452 else if (gentity_handles_size == 1) { 04453 ent_step = 0; 04454 uv_step = 1; 04455 count = uv_size/2; 04456 } 04457 else { 04458 ERROR(iBase_INVALID_ENTITY_COUNT, "Mismatched input array sizes."); 04459 } 04460 04461 ALLOC_CHECK_ARRAY( coordinates, 3*count ); 04462 04463 const double *u, *v; 04464 double *x, *y, *z; 04465 u = uv; 04466 x = *coordinates; 04467 if (storage_order == iBase_BLOCKED) { 04468 v = u + (uv_step ? count : 1); 04469 y = x + count; 04470 z = y + count; 04471 coord_step = 1; 04472 } 04473 else { 04474 storage_order = iBase_INTERLEAVED; 04475 v = u + 1; 04476 y = x + 1; 04477 z = x + 2; 04478 coord_step = 3; 04479 uv_step *= 2; 04480 } 04481 04482 RefEntity** ent = (RefEntity**)gentity_handles; 04483 for (int i = 0; i < count; ++i) { 04484 RefFace* face = dynamic_cast<RefFace*>(*ent); 04485 if (!face) { 04486 ERROR(iBase_INVALID_ENTITY_TYPE, "Expected face for UV method."); 04487 } 04488 04489 CubitVector xyz = face->position_from_u_v( *u, *v ); 04490 xyz.get_xyz( *x, *y, *z ); 04491 04492 ent += ent_step; 04493 u += uv_step; 04494 v += uv_step; 04495 x += coord_step; 04496 y += coord_step; 04497 z += coord_step; 04498 } 04499 04500 KEEP_ARRAY(coordinates); 04501 RETURN(iBase_SUCCESS); 04502 } 04503 04504 ITAPS_API void 04505 iGeom_getEntUtoXYZ( iGeom_Instance instance, 04506 /*in*/ iBase_EntityHandle entity_handle, 04507 /*in*/ double u, 04508 /*out*/ double* x, 04509 /*out*/ double* y, 04510 /*out*/ double* z, 04511 int* err ) 04512 { 04513 RefEntity* entity = (RefEntity*)entity_handle; 04514 RefEdge* edge = dynamic_cast<RefEdge*>(entity); 04515 if (!edge) { 04516 ERROR(iBase_INVALID_ENTITY_TYPE, "Expected edge for 1-param method."); 04517 } 04518 04519 CubitVector xyz; 04520 CubitStatus s = edge->position_from_u( u, xyz ); 04521 xyz.get_xyz( *x, *y, *z ); 04522 RETURN( (s == CUBIT_SUCCESS ? iBase_SUCCESS : iBase_FAILURE) ); 04523 } 04524 04525 ITAPS_API void 04526 iGeom_getArrUtoXYZ( iGeom_Instance instance, 04527 /*in*/ iBase_EntityHandle const *gentity_handles, 04528 int gentity_handles_size, 04529 /*in*/ const double *u, 04530 int u_size, 04531 /*in*/ int storage_order, 04532 /*out*/ double **coordinates, 04533 int *coordinates_allocated, 04534 int *coordinates_size, 04535 int* err ) 04536 { 04537 int count; 04538 size_t ent_step, coord_step, u_step; 04539 if (gentity_handles_size == u_size) { 04540 ent_step = u_step = 1; 04541 count = gentity_handles_size; 04542 } 04543 else if (u_size == 1) { 04544 ent_step = 1; 04545 u_step = 0; 04546 count = gentity_handles_size; 04547 } 04548 else if (gentity_handles_size == 1) { 04549 ent_step = 0; 04550 u_step = 1; 04551 count = u_size; 04552 } 04553 else { 04554 ERROR(iBase_INVALID_ENTITY_COUNT, "Mismatched input array sizes."); 04555 } 04556 04557 ALLOC_CHECK_ARRAY( coordinates, 3*count ); 04558 04559 const double *u_iter; 04560 double *x, *y, *z; 04561 u_iter = u; 04562 x = *coordinates; 04563 if (storage_order == iBase_BLOCKED) { 04564 y = x + count; 04565 z = y + count; 04566 coord_step = 1; 04567 } 04568 else { 04569 y = x + 1; 04570 z = x + 2; 04571 coord_step = 3; 04572 } 04573 04574 iBase_ErrorType result = iBase_SUCCESS; 04575 RefEntity** ent = (RefEntity**)gentity_handles; 04576 for (int i = 0; i < count; ++i) { 04577 RefEdge* edge = dynamic_cast<RefEdge*>(*ent); 04578 if (!edge) { 04579 ERROR(iBase_INVALID_ENTITY_TYPE, "Expected edge for 1-param method."); 04580 } 04581 04582 CubitVector xyz; 04583 CubitStatus s = edge->position_from_u( *u_iter, xyz ); 04584 if (CUBIT_SUCCESS != s) 04585 result = iBase_FAILURE; 04586 xyz.get_xyz( *x, *y, *z ); 04587 04588 ent += ent_step; 04589 u_iter += u_step; 04590 x += coord_step; 04591 y += coord_step; 04592 z += coord_step; 04593 } 04594 04595 KEEP_ARRAY(coordinates); 04596 RETURN(result); 04597 } 04598 04599 ITAPS_API void 04600 iGeom_getEntXYZtoUV( iGeom_Instance instance, 04601 /*in*/ iBase_EntityHandle entity_handle, 04602 /*in*/ double x, 04603 /*in*/ double y, 04604 /*in*/ double z, 04605 /*out*/ double* u, 04606 /*out*/ double* v, 04607 int* err ) 04608 { 04609 RefEntity* entity = (RefEntity*)entity_handle; 04610 RefFace* face = dynamic_cast<RefFace*>(entity); 04611 if (!face) { 04612 ERROR(iBase_INVALID_ENTITY_TYPE, "Expected face for UV method."); 04613 } 04614 04615 const CubitVector xyz( x, y, z ); 04616 CubitStatus s = face->u_v_from_position( xyz, *u, *v ); 04617 RETURN( (s == CUBIT_SUCCESS ? iBase_SUCCESS : iBase_FAILURE) ); 04618 } 04619 04620 04629 ITAPS_API void 04630 iGeom_getArrXYZtoUV( iGeom_Instance instance, 04631 /*in*/ iBase_EntityHandle const *gentity_handles, 04632 int gentity_handles_size, 04633 /*in*/ int storage_order, 04634 /*in*/ const double *coordinates, 04635 int coordinates_size, 04636 /*out*/ double **uv, 04637 int *uv_allocated, 04638 int *uv_size, 04639 int* err ) 04640 { 04641 int count; 04642 size_t ent_step, coord_step, uv_step; 04643 if (3*gentity_handles_size == coordinates_size) { 04644 ent_step = coord_step = 1; 04645 count = gentity_handles_size; 04646 } 04647 else if (coordinates_size == 3) { 04648 ent_step = 1; 04649 coord_step = 0; 04650 count = gentity_handles_size; 04651 } 04652 else if (gentity_handles_size == 1) { 04653 ent_step = 0; 04654 coord_step = 1; 04655 count = coordinates_size/3; 04656 } 04657 else { 04658 ERROR(iBase_INVALID_ENTITY_COUNT, "Mismatched input array sizes."); 04659 } 04660 04661 ALLOC_CHECK_ARRAY( uv, 2*count ); 04662 04663 double *u, *v; 04664 const double *x, *y, *z; 04665 u = *uv; 04666 x = coordinates; 04667 if (storage_order == iBase_BLOCKED) { 04668 v = u + count; 04669 y = x + (coord_step ? count : 1); 04670 z = y + (coord_step ? count : 1); 04671 uv_step = 1; 04672 } 04673 else { 04674 storage_order = iBase_INTERLEAVED; 04675 v = u + 1; 04676 y = x + 1; 04677 z = x + 2; 04678 coord_step *= 3; 04679 uv_step = 2; 04680 } 04681 04682 RefEntity** ent = (RefEntity**)gentity_handles; 04683 for (int i = 0; i < count; ++i) { 04684 RefFace* face = dynamic_cast<RefFace*>(*ent); 04685 if (!face) { 04686 ERROR(iBase_INVALID_ENTITY_TYPE, "Expected face for UV method."); 04687 } 04688 04689 CubitVector xyz( *x, *y, *z ); 04690 CubitStatus s = face->u_v_from_position( xyz, *u, *v ); 04691 if (CUBIT_SUCCESS != s) 04692 RETURN(iBase_FAILURE); 04693 04694 ent += ent_step; 04695 u += uv_step; 04696 v += uv_step; 04697 x += coord_step; 04698 y += coord_step; 04699 z += coord_step; 04700 } 04701 04702 KEEP_ARRAY(uv); 04703 RETURN(iBase_SUCCESS); 04704 } 04705 04706 04707 ITAPS_API void 04708 iGeom_getEntXYZtoU( iGeom_Instance instance, 04709 /*in*/ iBase_EntityHandle entity_handle, 04710 /*in*/ double x, 04711 /*in*/ double y, 04712 /*in*/ double z, 04713 /*out*/ double* u, 04714 int* err ) 04715 { 04716 RefEntity* entity = (RefEntity*)entity_handle; 04717 RefEdge* edge = dynamic_cast<RefEdge*>(entity); 04718 if (!edge) { 04719 ERROR(iBase_INVALID_ENTITY_TYPE, "Expected edge for 1-param method."); 04720 } 04721 04722 const CubitVector xyz( x, y, z ); 04723 *u = edge->u_from_position( xyz ); 04724 RETURN(iBase_SUCCESS); 04725 } 04726 04727 04728 ITAPS_API void 04729 iGeom_getArrXYZtoU( iGeom_Instance instance, 04730 /*in*/ iBase_EntityHandle const *gentity_handles, 04731 int gentity_handles_size, 04732 /*in*/ int storage_order, 04733 /*in*/ const double *coordinates, 04734 int coordinates_size, 04735 /*out*/ double **u, 04736 int *u_allocated, 04737 int *u_size, 04738 int* err ) 04739 { 04740 int count; 04741 size_t ent_step, coord_step; 04742 if (3*gentity_handles_size == coordinates_size) { 04743 ent_step = coord_step = 1; 04744 count = gentity_handles_size; 04745 } 04746 else if (coordinates_size == 3) { 04747 ent_step = 1; 04748 coord_step = 0; 04749 count = gentity_handles_size; 04750 } 04751 else if (gentity_handles_size == 1) { 04752 ent_step = 0; 04753 coord_step = 1; 04754 count = coordinates_size/3; 04755 } 04756 else { 04757 ERROR(iBase_INVALID_ENTITY_COUNT, "Mismatched input array sizes."); 04758 } 04759 04760 const double *x, *y, *z; 04761 x = coordinates; 04762 if (storage_order == iBase_BLOCKED) { 04763 y = x + (coord_step ? count : 1); 04764 z = y + (coord_step ? count : 1); 04765 } 04766 else { 04767 storage_order = iBase_INTERLEAVED; 04768 y = x + 1; 04769 z = x + 2; 04770 coord_step *= 3; 04771 } 04772 04773 ALLOC_CHECK_ARRAY( u, count ); 04774 04775 RefEntity** ent = (RefEntity**)gentity_handles; 04776 for (int i = 0; i < count; ++i) { 04777 RefEdge* edge = dynamic_cast<RefEdge*>(*ent); 04778 if (!edge) { 04779 ERROR(iBase_INVALID_ENTITY_TYPE, "Expected edge for 1-param method."); 04780 } 04781 04782 CubitVector xyz( *x, *y, *z ); 04783 (*u)[i] = edge->u_from_position( xyz ); 04784 04785 ent += ent_step; 04786 x += coord_step; 04787 y += coord_step; 04788 z += coord_step; 04789 } 04790 04791 KEEP_ARRAY(u); 04792 RETURN(iBase_SUCCESS); 04793 } 04794 04795 ITAPS_API void 04796 iGeom_getEntXYZtoUVHint( iGeom_Instance instance, 04797 /*in*/ iBase_EntityHandle entity_handle, 04798 /*in*/ double x, 04799 /*in*/ double y, 04800 /*in*/ double z, 04801 /*inout*/ double* u, 04802 /*inout*/ double* v, 04803 int* err ) 04804 { 04805 RefEntity* entity = (RefEntity*)entity_handle; 04806 RefFace* face = dynamic_cast<RefFace*>(entity); 04807 if (!face) { 04808 ERROR(iBase_INVALID_ENTITY_TYPE, "Expected face for UV method."); 04809 } 04810 04811 CubitVector xyz( x, y, z ); 04812 face->move_to_surface( xyz, u, v ); 04813 RETURN(iBase_SUCCESS); 04814 } 04815 04816 04825 ITAPS_API void 04826 iGeom_getArrXYZtoUVHint( iGeom_Instance instance, 04827 /*in*/ iBase_EntityHandle const *gentity_handles, 04828 int gentity_handles_size, 04829 /*in*/ int storage_order, 04830 /*in*/ const double *coordinates, 04831 int coordinates_size, 04832 /*inout*/ double **uv, 04833 int *uv_allocated, 04834 int *uv_size, 04835 int* err ) 04836 { 04837 int count; 04838 size_t ent_step, coord_step, uv_step; 04839 if (3*gentity_handles_size == coordinates_size) { 04840 ent_step = coord_step = 1; 04841 count = gentity_handles_size; 04842 } 04843 else if (coordinates_size == 3) { 04844 ent_step = 1; 04845 coord_step = 0; 04846 count = gentity_handles_size; 04847 } 04848 else if (gentity_handles_size == 1) { 04849 ent_step = 0; 04850 coord_step = 1; 04851 count = coordinates_size/3; 04852 } 04853 else { 04854 ERROR(iBase_INVALID_ENTITY_COUNT, "Mismatched input array sizes."); 04855 } 04856 04857 double *u, *v; 04858 const double *x, *y, *z; 04859 u = *uv; 04860 x = coordinates; 04861 if (storage_order == iBase_BLOCKED) { 04862 v = u + count; 04863 y = x + (coord_step ? count : 1); 04864 z = y + (coord_step ? count : 1); 04865 uv_step = 1; 04866 } 04867 else { 04868 storage_order = iBase_INTERLEAVED; 04869 v = u + 1; 04870 y = x + 1; 04871 z = x + 2; 04872 coord_step *= 3; 04873 uv_step = 2; 04874 } 04875 04876 ALLOC_CHECK_ARRAY( uv, 2*count ); 04877 04878 RefEntity** ent = (RefEntity**)gentity_handles; 04879 for (int i = 0; i < count; ++i) { 04880 RefFace* face = dynamic_cast<RefFace*>(*ent); 04881 if (!face) { 04882 ERROR(iBase_INVALID_ENTITY_TYPE, "Expected face for UV method."); 04883 } 04884 04885 CubitVector xyz( *x, *y, *z ); 04886 face->move_to_surface( xyz, u, v ); 04887 04888 ent += ent_step; 04889 u += uv_step; 04890 v += uv_step; 04891 x += coord_step; 04892 y += coord_step; 04893 z += coord_step; 04894 } 04895 04896 KEEP_ARRAY(uv); 04897 RETURN(iBase_SUCCESS); 04898 } 04899 04900 ITAPS_API void 04901 iGeom_getEntUVRange( iGeom_Instance instance, 04902 /*in*/ iBase_EntityHandle entity_handle, 04903 /*out*/ double *u_min, 04904 /*out*/ double *v_min, 04905 /*out*/ double *u_max, 04906 /*out*/ double *v_max, 04907 int* err ) 04908 { 04909 RefEntity* entity = (RefEntity*)entity_handle; 04910 RefFace* face = dynamic_cast<RefFace*>(entity); 04911 if (!face) { 04912 ERROR(iBase_INVALID_ENTITY_TYPE, "Expected face for UV method."); 04913 } 04914 04915 CubitBoolean r1 = face->get_param_range_U(*u_min, *u_max); 04916 CubitBoolean r2 = face->get_param_range_V(*v_min, *v_max); 04917 RETURN( ((r1 && r2) ? iBase_SUCCESS : iBase_FAILURE) ); 04918 } 04919 04920 ITAPS_API void 04921 iGeom_getEntURange( iGeom_Instance instance, 04922 /*in*/ iBase_EntityHandle entity_handle, 04923 /*out*/ double *u_min, 04924 /*out*/ double *u_max, 04925 int* err ) 04926 { 04927 RefEntity* entity = (RefEntity*)entity_handle; 04928 RefEdge* edge = dynamic_cast<RefEdge*>(entity); 04929 if (!edge) { 04930 ERROR(iBase_INVALID_ENTITY_TYPE, "Expected edge for 1-param method."); 04931 } 04932 04933 CubitBoolean r1 = edge->get_param_range(*u_min, *u_max); 04934 RETURN( (r1 ? iBase_SUCCESS : iBase_FAILURE) ); 04935 } 04936 04937 04944 ITAPS_API void 04945 iGeom_getArrUVRange( iGeom_Instance instance, 04946 /*in*/ iBase_EntityHandle const *gentity_handles, 04947 int gentity_handles_size, 04948 /*in*/ int storage_order, 04949 /*out*/ double **uv_min, 04950 int *uv_min_allocated, 04951 int *uv_min_size, 04952 /*out*/ double **uv_max, 04953 int *uv_max_allocated, 04954 int *uv_max_size, 04955 int* err ) 04956 { 04957 ALLOC_CHECK_ARRAY(uv_min, 2*gentity_handles_size); 04958 ALLOC_CHECK_ARRAY(uv_max, 2*gentity_handles_size); 04959 04960 size_t init, step; 04961 if (storage_order == iBase_BLOCKED) { 04962 init = gentity_handles_size; 04963 step = 1; 04964 } 04965 else { 04966 init = 1; 04967 step = 2; 04968 } 04969 04970 double *u_min = *uv_min; 04971 double *v_min = u_min + init; 04972 double *u_max = *uv_max; 04973 double *v_max = u_max + init; 04974 04975 RefEntity** entities = (RefEntity**)gentity_handles; 04976 for (int i = 0; i < gentity_handles_size; ++i) { 04977 RefFace* face = dynamic_cast<RefFace*>(entities[i]); 04978 if (!face) { 04979 ERROR(iBase_INVALID_ENTITY_TYPE, "Expected face for UV method."); 04980 } 04981 04982 CubitBoolean r1 = face->get_param_range_U(*u_min, *u_max); 04983 CubitBoolean r2 = face->get_param_range_V(*v_min, *v_max); 04984 if (!(r1 && r2)) { 04985 RETURN(iBase_FAILURE); 04986 } 04987 04988 u_min += step; 04989 v_min += step; 04990 u_max += step; 04991 v_max += step; 04992 } 04993 04994 KEEP_ARRAY(uv_min); 04995 KEEP_ARRAY(uv_max); 04996 RETURN(iBase_SUCCESS); 04997 } 04998 04999 ITAPS_API void 05000 iGeom_getArrURange( iGeom_Instance instance, 05001 /*in*/ iBase_EntityHandle const *gentity_handles, 05002 const int gentity_handles_size, 05003 /*out*/ double **u_min, 05004 int *u_min_allocated, 05005 int *u_min_size, 05006 /*out*/ double **u_max, 05007 int *u_max_allocated, 05008 int *u_max_size, 05009 int* err ) 05010 { 05011 ALLOC_CHECK_ARRAY(u_min, gentity_handles_size); 05012 ALLOC_CHECK_ARRAY(u_max, gentity_handles_size); 05013 05014 RefEntity** entities = (RefEntity**)gentity_handles; 05015 for (int i = 0; i < gentity_handles_size; ++i) { 05016 RefEdge* edge = dynamic_cast<RefEdge*>(entities[i]); 05017 if (!edge) { 05018 ERROR(iBase_INVALID_ENTITY_TYPE, "Expected edge for 1-param method."); 05019 } 05020 05021 CubitBoolean r1 = edge->get_param_range((*u_min)[i], (*u_max)[i]); 05022 if (!r1) { 05023 RETURN(iBase_FAILURE); 05024 } 05025 } 05026 05027 KEEP_ARRAY(u_min); 05028 KEEP_ARRAY(u_max); 05029 RETURN(iBase_SUCCESS); 05030 } 05031 05032 ITAPS_API void 05033 iGeom_getEntUtoUV( iGeom_Instance instance, 05034 /*in*/ iBase_EntityHandle edge_handle, 05035 /*in*/ iBase_EntityHandle face_handle, 05036 /*in*/ double in_u, 05037 /*out*/ double* u, 05038 /*out*/ double* v, 05039 int* err ) 05040 { 05041 RefEdge* edge = dynamic_cast<RefEdge*>((RefEntity*)edge_handle); 05042 RefFace* face = dynamic_cast<RefFace*>((RefEntity*)face_handle); 05043 if (!edge || !face) { 05044 RETURN(iBase_INVALID_ENTITY_TYPE); 05045 } 05046 05047 CubitVector xyz; 05048 CubitStatus s; 05049 s = edge->position_from_u( in_u, xyz ); 05050 if (s != CUBIT_SUCCESS) 05051 RETURN(iBase_FAILURE); 05052 05053 s = face->u_v_from_position( xyz, *u, *v ); 05054 RETURN( (s == CUBIT_SUCCESS ? iBase_SUCCESS : iBase_FAILURE) ); 05055 } 05056 05057 static bool 05058 iGeom_check_array_size(int size1, int size2) 05059 { 05060 return size1 == 1 || size2 == 1 || size1 == size2; 05061 } 05062 05063 ITAPS_API void 05064 iGeom_getArrUtoUV( iGeom_Instance instance, 05065 /*in*/ iBase_EntityHandle const *edge_handles, 05066 int edge_handles_size, 05067 /*in*/ iBase_EntityHandle const *face_handles, 05068 int face_handles_size, 05069 /*in*/ const double *in_u, 05070 int in_u_size, 05071 /*in*/ int storage_order, 05072 /*inout*/ double **uv, 05073 int *uv_allocated, 05074 int *uv_size, 05075 int* err ) 05076 { 05077 int count; 05078 size_t edge_step, face_step, coord_step, in_u_step; 05079 05080 if (!(iGeom_check_array_size(edge_handles_size, face_handles_size) && 05081 iGeom_check_array_size(edge_handles_size, in_u_size) && 05082 iGeom_check_array_size(face_handles_size, in_u_size))) { 05083 ERROR(iBase_INVALID_ENTITY_COUNT, "Mismatched input array sizes."); 05084 } 05085 05086 edge_step = (edge_handles_size == 1) ? 0:1; 05087 face_step = (face_handles_size == 1) ? 0:1; 05088 in_u_step = (in_u_size == 1) ? 0:1; 05089 05090 count = std::max(edge_handles_size, std::max(face_handles_size, in_u_size)); 05091 05092 ALLOC_CHECK_ARRAY( uv, 2*count ); 05093 05094 const double *in_u_iter; 05095 double *u, *v; 05096 in_u_iter = in_u; 05097 u = *uv; 05098 if (storage_order == iBase_BLOCKED) { 05099 v = u + count; 05100 coord_step = 1; 05101 } 05102 else { 05103 v = u + 1; 05104 coord_step = 2; 05105 } 05106 05107 RefEntity** edge_ent = (RefEntity**)edge_handles; 05108 RefEntity** face_ent = (RefEntity**)face_handles; 05109 for (int i = 0; i < count; ++i) { 05110 RefEdge* edge = dynamic_cast<RefEdge*>(*edge_ent); 05111 RefFace* face = dynamic_cast<RefFace*>(*face_ent); 05112 if (!edge || !face) { 05113 RETURN(iBase_INVALID_ENTITY_TYPE); 05114 } 05115 05116 CubitVector xyz; 05117 CubitStatus s; 05118 s = edge->position_from_u( *in_u_iter, xyz ); 05119 if (CUBIT_SUCCESS != s) 05120 RETURN(iBase_FAILURE); 05121 s = face->u_v_from_position( xyz, *u, *v ); 05122 if (CUBIT_SUCCESS != s) 05123 RETURN(iBase_FAILURE); 05124 05125 edge_ent += edge_step; 05126 face_ent += face_step; 05127 in_u_iter += in_u_step; 05128 u += coord_step; 05129 v += coord_step; 05130 } 05131 05132 KEEP_ARRAY(uv); 05133 RETURN(iBase_SUCCESS); 05134 } 05135 05136 ITAPS_API void 05137 iGeom_getVtxToUV( iGeom_Instance instance, 05138 /*in*/ iBase_EntityHandle vertex_handle, 05139 /*in*/ iBase_EntityHandle face_handle, 05140 /*out*/ double* u, 05141 /*out*/ double* v, 05142 int* err ) 05143 { 05144 RefVertex* vtx = dynamic_cast<RefVertex*>((RefEntity*)vertex_handle); 05145 RefFace* face = dynamic_cast<RefFace*>((RefEntity*)face_handle); 05146 if (!vtx || !face) { 05147 RETURN(iBase_INVALID_ENTITY_TYPE); 05148 } 05149 05150 iBase_ErrorType result = iGeom_get_vtx_to_uv( vtx, face, *u, *v ); 05151 RETURN(result); 05152 } 05153 05154 ITAPS_API void 05155 iGeom_getVtxArrToUV( iGeom_Instance instance, 05156 /*in*/ iBase_EntityHandle const *vertex_handles, 05157 int vertex_handles_size, 05158 /*in*/ iBase_EntityHandle const *face_handles, 05159 int face_handles_size, 05160 /*in*/ int storage_order, 05161 /*inout*/ double **uv, 05162 int *uv_allocated, 05163 int *uv_size, 05164 int* err ) 05165 { 05166 int count; 05167 size_t vtx_step, face_step, uv_step; 05168 if (vertex_handles_size == face_handles_size) { 05169 count = vertex_handles_size; 05170 vtx_step = face_step = 1; 05171 } 05172 else if (face_handles_size == 1) { 05173 count = vertex_handles_size; 05174 vtx_step = 1; 05175 face_step = 0; 05176 } 05177 else if (vertex_handles_size == 1) { 05178 count = face_handles_size; 05179 vtx_step = 0; 05180 face_step = 1; 05181 } 05182 else { 05183 ERROR(iBase_INVALID_ENTITY_COUNT, "Mismatched input array sizes."); 05184 } 05185 05186 ALLOC_CHECK_ARRAY( uv, 2*count ); 05187 05188 double *u, *v; 05189 u = *uv; 05190 if (storage_order == iBase_BLOCKED) { 05191 v = u + count; 05192 uv_step = 1; 05193 } 05194 else { 05195 storage_order = iBase_INTERLEAVED; 05196 v = u + 1; 05197 uv_step = 2; 05198 } 05199 05200 RefEntity** vtx_iter = (RefEntity**)vertex_handles; 05201 RefEntity** face_iter = (RefEntity**)face_handles; 05202 for (int i = 0; i < count; ++i) { 05203 RefVertex* vtx = dynamic_cast<RefVertex*>(*vtx_iter); 05204 RefFace* face = dynamic_cast<RefFace*>(*face_iter); 05205 if (!vtx || !face) { 05206 RETURN(iBase_INVALID_ENTITY_TYPE); 05207 } 05208 05209 iBase_ErrorType rval = iGeom_get_vtx_to_uv( vtx, face, *u, *v ); 05210 if (iBase_SUCCESS != rval) { 05211 RETURN(rval); 05212 } 05213 05214 vtx_iter += vtx_step; 05215 face_iter += face_step; 05216 u += uv_step; 05217 v += uv_step; 05218 } 05219 KEEP_ARRAY(uv); 05220 RETURN(iBase_SUCCESS); 05221 } 05222 05223 ITAPS_API void 05224 iGeom_getVtxToU( iGeom_Instance instance, 05225 /*in*/ iBase_EntityHandle vertex_handle, 05226 /*in*/ iBase_EntityHandle edge_handle, 05227 /*out*/ double* u, 05228 int* err ) 05229 { 05230 RefVertex* vtx = dynamic_cast<RefVertex*>((RefEntity*)vertex_handle); 05231 RefEdge* edge = dynamic_cast<RefEdge*>((RefEntity*)edge_handle); 05232 if (!vtx || !edge) { 05233 RETURN(iBase_INVALID_ENTITY_TYPE); 05234 } 05235 05236 iBase_ErrorType result = iGeom_get_vtx_to_u( vtx, edge, *u ); 05237 RETURN(result); 05238 } 05239 05240 ITAPS_API void 05241 iGeom_getVtxArrToU( iGeom_Instance instance, 05242 /*in*/ iBase_EntityHandle const *vertex_handles , 05243 int vertex_handles_size, 05244 /*in*/ iBase_EntityHandle const *edge_handles , 05245 int edge_handles_size, 05246 /*inout*/ double **u , 05247 int *u_allocated, 05248 int *u_size, 05249 int* err ) 05250 { 05251 int count; 05252 size_t vtx_step, edge_step; 05253 if (vertex_handles_size == edge_handles_size) { 05254 count = vertex_handles_size; 05255 vtx_step = edge_step = 1; 05256 } 05257 else if (edge_handles_size == 1) { 05258 count = vertex_handles_size; 05259 vtx_step = 1; 05260 edge_step = 0; 05261 } 05262 else if (vertex_handles_size == 1) { 05263 count = edge_handles_size; 05264 vtx_step = 0; 05265 edge_step = 1; 05266 } 05267 else { 05268 ERROR(iBase_INVALID_ENTITY_COUNT, "Mismatched input array sizes."); 05269 } 05270 05271 ALLOC_CHECK_ARRAY( u, count ); 05272 05273 RefEntity** vtx_iter = (RefEntity**)vertex_handles; 05274 RefEntity** edge_iter = (RefEntity**)edge_handles; 05275 for (int i = 0; i < count; ++i) { 05276 RefVertex* vtx = dynamic_cast<RefVertex*>(*vtx_iter); 05277 RefEdge* edge = dynamic_cast<RefEdge*>(*edge_iter); 05278 if (!vtx || !edge) { 05279 RETURN(iBase_INVALID_ENTITY_TYPE); 05280 } 05281 05282 iBase_ErrorType rval = iGeom_get_vtx_to_u( vtx, edge, (*u)[i] ); 05283 if (iBase_SUCCESS != rval) { 05284 RETURN(rval); 05285 } 05286 05287 vtx_iter += vtx_step; 05288 edge_iter += edge_step; 05289 } 05290 KEEP_ARRAY(u); 05291 RETURN(iBase_SUCCESS); 05292 } 05293 05294 ITAPS_API void 05295 iGeom_getEntNrmlUV( iGeom_Instance instance, 05296 /*in*/ iBase_EntityHandle entity_handle, 05297 /*in*/ double u, 05298 /*in*/ double v, 05299 /*out*/ double* nrml_i, 05300 /*out*/ double* nrml_j, 05301 /*out*/ double* nrml_k, 05302 int* err ) 05303 { 05304 RefFace* face = dynamic_cast<RefFace*>((RefEntity*)entity_handle); 05305 if (!face) { 05306 RETURN (iBase_INVALID_ENTITY_TYPE); 05307 } 05308 05309 CubitVector normal; 05310 CubitStatus s = iGeom_normal_from_uv( face, u, v, normal ); 05311 normal.get_xyz( *nrml_i, *nrml_j, *nrml_k ); 05312 RETURN ((s == CUBIT_SUCCESS ? iBase_SUCCESS : iBase_FAILURE)); 05313 } 05314 05323 ITAPS_API void 05324 iGeom_getArrNrmlUV( iGeom_Instance instance, 05325 /*in*/ iBase_EntityHandle const *gface_handles, 05326 int gface_handles_size, 05327 /*in*/ int storage_order, 05328 /*in*/ const double *parameters, 05329 int parameters_size, 05330 /*out*/ double **normals, 05331 int *normals_allocated, 05332 int *normals_size, 05333 int* err ) 05334 { 05335 int count; 05336 size_t face_step, param_step, norm_step; 05337 if (2*gface_handles_size == parameters_size) { 05338 count = gface_handles_size; 05339 face_step = param_step = 1; 05340 } 05341 else if (parameters_size == 2) { 05342 count = gface_handles_size; 05343 face_step = 1; 05344 param_step = 0; 05345 } 05346 else if (gface_handles_size == 1) { 05347 count = parameters_size/2; 05348 face_step = 0; 05349 param_step = 1; 05350 } 05351 else { 05352 ERROR(iBase_INVALID_ENTITY_COUNT, "Mismatched input array sizes."); 05353 } 05354 05355 // check or pre-allocate the coordinate arrays 05356 ALLOC_CHECK_ARRAY( normals, 3*count ); 05357 05358 const double *u, *v; 05359 double *x, *y, *z; 05360 u = parameters; 05361 x = *normals; 05362 if (storage_order == iBase_BLOCKED) { 05363 v = u + (param_step ? count : 1); 05364 y = x + count; 05365 z = y + count; 05366 norm_step = 1; 05367 } 05368 else { 05369 storage_order = iBase_INTERLEAVED; 05370 v = u + 1; 05371 y = x + 1; 05372 z = x + 2; 05373 norm_step = 3; 05374 param_step *= 2; 05375 } 05376 05377 RefEntity** face_iter = (RefEntity**)gface_handles; 05378 for (int i = 0; i < count; ++i) { 05379 RefFace* face = dynamic_cast<RefFace*>(*face_iter); 05380 if (!face) { RETURN (iBase_INVALID_ENTITY_TYPE); } 05381 05382 CubitVector normal; 05383 CubitStatus s = iGeom_normal_from_uv( face, *u, *v, normal ); 05384 normal.get_xyz( *x, *y, *z ); 05385 if (CUBIT_SUCCESS != s) { 05386 RETURN(iBase_FAILURE); 05387 } 05388 05389 face_iter += face_step; 05390 x += norm_step; 05391 y += norm_step; 05392 z += norm_step; 05393 u += param_step; 05394 v += param_step; 05395 } 05396 05397 KEEP_ARRAY(normals); 05398 RETURN(iBase_SUCCESS); 05399 } 05400 05401 05402 ITAPS_API void 05403 iGeom_getEntTgntU( iGeom_Instance instance, 05404 /*in*/ iBase_EntityHandle entity_handle, 05405 /*in*/ double param_coord, 05406 /*out*/ double* tngt_i, 05407 /*out*/ double* tngt_j, 05408 /*out*/ double* tngt_k, 05409 int* err ) 05410 { 05411 double x, y, z; 05412 iGeom_getEntUtoXYZ( instance, entity_handle, param_coord, &x, &y, &z, err ); 05413 if (iBase_SUCCESS == *err) 05414 iGeom_getEntTgntXYZ( instance, entity_handle, x, y, z, tngt_i, tngt_j, tngt_k, err ); 05415 } 05416 05425 ITAPS_API void 05426 iGeom_getArrTgntU( iGeom_Instance instance, 05427 /*in*/ iBase_EntityHandle const *gedge_handles, 05428 int gedge_handles_size, 05429 /*in*/ int storage_order, 05430 /*in*/ const double *parameters, 05431 int parameters_size, 05432 /*out*/ double **tangents, 05433 int *tangents_allocated, 05434 int *tangents_size, 05435 int* err ) 05436 { 05437 iGeom_getArrUtoXYZ(instance, ARRAY_IN(gedge_handles), 05438 ARRAY_IN(parameters), storage_order, 05439 ARRAY_INOUT(tangents), err); 05440 if (iBase_SUCCESS == *err) 05441 iGeom_getArrTgntXYZ(instance, ARRAY_IN(gedge_handles), storage_order, 05442 *tangents, *tangents_size, ARRAY_INOUT(tangents), err); 05443 } 05444 05445 ITAPS_API void 05446 iGeom_getEnt1stDrvt( iGeom_Instance instance, 05447 /*in*/ iBase_EntityHandle entity_handle, 05448 /*in*/ double u, 05449 /*in*/ double v, 05450 /*inout*/ double **dvrt_u , 05451 int *dvrt_u_allocated, 05452 int *dvrt_u_size, 05453 /*inout*/ double **dvrt_v , 05454 int *dvrt_v_allocated, 05455 int *dvrt_v_size, 05456 int* err ) 05457 { 05458 RefFace* face = dynamic_cast<RefFace*>((RefEntity*)entity_handle); 05459 if (!face) { 05460 ERROR( iBase_INVALID_ENTITY_TYPE, "Derivatives only for faces." ); 05461 } 05462 05463 CubitVector du, dv; 05464 CubitStatus s = face->get_surface_ptr()->uv_derivitives( u, v, du, dv ); 05465 if (CUBIT_SUCCESS != s) { 05466 RETURN(iBase_FAILURE); 05467 } 05468 05469 ALLOC_CHECK_ARRAY_NOFAIL( dvrt_u, 3 ); 05470 ALLOC_CHECK_ARRAY_NOFAIL( dvrt_v, 3 ); 05471 du.get_xyz( *dvrt_u ); 05472 dv.get_xyz( *dvrt_v ); 05473 RETURN (iBase_SUCCESS); 05474 } 05475 05476 ITAPS_API void 05477 iGeom_getArr1stDrvt( iGeom_Instance instance, 05478 /*in*/ iBase_EntityHandle const *entity_handles , 05479 int entity_handles_size, 05480 /*in*/ int storage_order, 05481 /*in*/ const double *uv , 05482 int uv_size, 05483 /*inout*/ double **drvt_u , 05484 int *drvt_u_allocated, 05485 int *drvt_u_size, 05486 /*inout*/ int **u_offset , 05487 int *u_offset_allocated, 05488 int *u_offset_size, 05489 /*inout*/ double **drvt_v , 05490 int *drvt_v_allocated, 05491 int *drvt_v_size, 05492 /*inout*/ int **v_offset , 05493 int *v_offset_allocated, 05494 int *v_offset_size, 05495 int* err ) 05496 { 05497 if (2*entity_handles_size != uv_size) { 05498 ERROR(iBase_INVALID_ENTITY_COUNT, "Mismatched input array sizes."); 05499 RETURN(iBase_INVALID_ENTITY_COUNT); 05500 } 05501 05502 ALLOC_CHECK_ARRAY( drvt_u, 3*entity_handles_size ); 05503 ALLOC_CHECK_ARRAY( drvt_v, 3*entity_handles_size ); 05504 ALLOC_CHECK_ARRAY( u_offset, entity_handles_size+1 ); 05505 ALLOC_CHECK_ARRAY( v_offset, entity_handles_size+1 ); 05506 05507 size_t u_step, du_step, init; 05508 if (storage_order == iBase_BLOCKED) { 05509 u_step = du_step = 1; 05510 init = entity_handles_size; 05511 } 05512 else { 05513 storage_order = iBase_INTERLEAVED; 05514 u_step = 2; 05515 du_step = 3; 05516 init = 1; 05517 } 05518 05519 const double *u = uv; 05520 const double *v = u + init; 05521 double *du_x = *drvt_u; 05522 double *du_y = du_x + init; 05523 double *du_z = du_y + init; 05524 double *dv_x = *drvt_v; 05525 double *dv_y = dv_x + init; 05526 double *dv_z = dv_y + init; 05527 05528 int off = 0; 05529 RefEntity** entities = (RefEntity**)entity_handles; 05530 for (int i = 0; i < entity_handles_size; ++i) { 05531 RefFace* face = dynamic_cast<RefFace*>(entities[i]); 05532 if (!face) { 05533 ERROR( iBase_INVALID_ENTITY_TYPE, "Derivatives only for faces." ); 05534 } 05535 05536 CubitVector du, dv; 05537 CubitStatus s = face->get_surface_ptr()->uv_derivitives( *u, *v, du, dv ); 05538 if (s != CUBIT_SUCCESS) { RETURN(iBase_FAILURE); } 05539 du.get_xyz( *du_x, *du_y, *du_z ); 05540 dv.get_xyz( *dv_x, *dv_y, *dv_z ); 05541 05542 u += u_step; 05543 v += u_step; 05544 du_x += du_step; 05545 du_y += du_step; 05546 du_z += du_step; 05547 dv_x += du_step; 05548 dv_y += du_step; 05549 dv_z += du_step; 05550 05551 (*u_offset)[i] = off; 05552 (*v_offset)[i] = off; 05553 off += du_step; 05554 } 05555 (*u_offset)[entity_handles_size] = off; 05556 (*v_offset)[entity_handles_size] = off; 05557 05558 KEEP_ARRAY( drvt_u ); 05559 KEEP_ARRAY( drvt_v ); 05560 KEEP_ARRAY( u_offset ); 05561 KEEP_ARRAY( v_offset ); 05562 RETURN(iBase_SUCCESS); 05563 } 05564 05565 ITAPS_API void 05566 iGeom_getEnt2ndDrvt( iGeom_Instance instance, 05567 /*in*/ iBase_EntityHandle entity_handle, 05568 /*in*/ double u, 05569 /*in*/ double v, 05570 /*inout*/ double **dvrt_uu , 05571 int *dvrt_uu_allocated, 05572 int *dvrt_uu_size, 05573 /*inout*/ double **dvrt_uv , 05574 int *dvrt_uv_allocated, 05575 int *dvrt_uv_size, 05576 /*inout*/ double **dvrt_vv , 05577 int *dvrt_vv_allocated, 05578 int *dvrt_vv_size, 05579 int* err ) 05580 { 05581 RETURN(iBase_NOT_SUPPORTED); 05582 } 05583 05584 ITAPS_API void 05585 iGeom_getArr2ndDrvt( iGeom_Instance instance, 05586 /*in*/ iBase_EntityHandle const *entity_handles , 05587 int entity_handles_size, 05588 /*in*/ int storage_order, 05589 /*in*/ const double *uv , 05590 int uv_size, 05591 /*inout*/ double **drvt_uu , 05592 int *drvt_uu_allocated, 05593 int *drvt_uu_size, 05594 /*inout*/ int **uu_offset , 05595 int *uu_offset_allocated, 05596 int *uu_offset_size, 05597 /*inout*/ double **drvt_uv , 05598 int *drvt_uv_allocated, 05599 int *drvt_uv_size, 05600 /*inout*/ int **uv_offset , 05601 int *uv_offset_allocated, 05602 int *uv_offset_size, 05603 /*inout*/ double **drvt_vv , 05604 int *drvt_vv_allocated, 05605 int *drvt_vv_size, 05606 /*inout*/ int **vv_offset , 05607 int *vv_offset_allocated, 05608 int *vv_offset_size, 05609 int* err ) 05610 { 05611 RETURN(iBase_NOT_SUPPORTED); 05612 } 05613 05614 ITAPS_API void 05615 iGeom_getFcCvtrUV( iGeom_Instance instance, 05616 /*in*/ iBase_EntityHandle entity_handle, 05617 /*in*/ double u, 05618 /*in*/ double v, 05619 /*out*/ double* cvtr1_i, 05620 /*out*/ double* cvtr1_j, 05621 /*out*/ double* cvtr1_k, 05622 /*out*/ double* cvtr2_i, 05623 /*out*/ double* cvtr2_j, 05624 /*out*/ double* cvtr2_k, 05625 int* err ) 05626 { 05627 double x, y, z; 05628 iGeom_getEntUVtoXYZ(instance, entity_handle, u, v, &x, &y, &z, err ); 05629 if (*err == iBase_SUCCESS) 05630 iGeom_getFcCvtrXYZ(instance, entity_handle, x, y, z, 05631 cvtr1_i, cvtr1_j, cvtr1_k, 05632 cvtr2_i, cvtr2_j, cvtr2_k, 05633 err ); 05634 } 05635 05636 05637 ITAPS_API void 05638 iGeom_getFcArrCvtrUV( iGeom_Instance instance, 05639 /*in*/ const iBase_EntityHandle *face_handles , 05640 int face_handles_size, 05641 /*in*/ int storage_order, 05642 /*in*/ const double *uv , 05643 int uv_size, 05644 /*inout*/ double **cvtr_1 , 05645 int *cvtr_1_allocated, 05646 int *cvtr_1_size, 05647 /*inout*/ double **cvtr_2 , 05648 int *cvtr_2_allocated, 05649 int *cvtr_2_size, 05650 int* err ) 05651 { 05652 iGeom_getArrUVtoXYZ(instance, ARRAY_IN(face_handles), storage_order, 05653 ARRAY_IN(uv), ARRAY_INOUT(cvtr_1), err); 05654 if (*err == iBase_SUCCESS) 05655 iGeom_getEntArrCvtrXYZ(instance, ARRAY_IN(face_handles), storage_order, 05656 *cvtr_1, *cvtr_1_size, 05657 ARRAY_INOUT(cvtr_1), ARRAY_INOUT(cvtr_2), err); 05658 } 05659 05660 ITAPS_API void 05661 iGeom_isEntPeriodic( iGeom_Instance instance, 05662 /*in*/ iBase_EntityHandle entity_handle, 05663 /*out*/ int* in_u, 05664 /*out*/ int* in_v, 05665 int* err ) 05666 { 05667 CubitStatus s = iGeom_is_periodic( (RefEntity*)entity_handle, *in_u, *in_v ); 05668 RETURN( (s == CUBIT_SUCCESS ? iBase_SUCCESS : iBase_FAILURE) ); 05669 } 05670 05671 ITAPS_API void 05672 iGeom_isArrPeriodic( iGeom_Instance instance, 05673 /*in*/ iBase_EntityHandle const *entity_handles , 05674 const int entity_handles_size, 05675 /*inout*/ int **in_uv , 05676 int *in_uv_allocated, 05677 int *in_uv_size, 05678 int* err ) 05679 { 05680 ALLOC_CHECK_ARRAY( in_uv, 2*entity_handles_size ); 05681 RefEntity** ents = (RefEntity**)entity_handles; 05682 for (int i = 0; i < entity_handles_size; ++i) { 05683 CubitStatus s = iGeom_is_periodic( ents[i], (*in_uv)[2*i], (*in_uv)[2*i+1] ); 05684 if (s != CUBIT_SUCCESS) { 05685 RETURN(iBase_FAILURE); 05686 } 05687 } 05688 KEEP_ARRAY(in_uv); 05689 RETURN(iBase_SUCCESS); 05690 } 05691 05692 ITAPS_API void 05693 iGeom_isFcDegenerate( iGeom_Instance instance, 05694 /*in*/ iBase_EntityHandle entity_handle, 05695 int* is_degenerate, 05696 int* err ) 05697 { 05698 RefFace* face = dynamic_cast<RefFace*>((RefEntity*)entity_handle); 05699 if (!face) { RETURN (iBase_INVALID_ENTITY_TYPE); } 05700 *is_degenerate = iGeom_is_face_degenerate(face); 05701 RETURN (iBase_SUCCESS); 05702 } 05703 05704 ITAPS_API void 05705 iGeom_isFcArrDegenerate( iGeom_Instance instance, 05706 /*in*/ iBase_EntityHandle const *face_handles , 05707 const int face_handles_size, 05708 /*inout*/ int **degenerate , 05709 int *degenerate_allocated, 05710 int *degenerate_size, 05711 int* err ) 05712 { 05713 ALLOC_CHECK_ARRAY( degenerate, face_handles_size ); 05714 RefEntity** faces = (RefEntity**)face_handles; 05715 for (int i = 0; i < face_handles_size; ++i) { 05716 RefFace* face = dynamic_cast<RefFace*>(faces[i]); 05717 if (!face) { RETURN (iBase_INVALID_ENTITY_TYPE); } 05718 (*degenerate)[i] = iGeom_is_face_degenerate( face ); 05719 } 05720 KEEP_ARRAY(degenerate); 05721 RETURN(iBase_SUCCESS); 05722 } 05723 05724 05734 ITAPS_API void 05735 iGeom_subtract( iGeom_Instance instance, 05736 /*in*/ iBase_EntitySetHandle entity_set_1, 05737 /*in*/ iBase_EntitySetHandle entity_set_2, 05738 /*out*/ iBase_EntitySetHandle *result_entity_set, 05739 int* err ) 05740 { 05741 const RefGroup *set1 = SET_HANDLE(entity_set_1); 05742 const RefGroup *set2 = SET_HANDLE(entity_set_2); 05743 RefGroup *set3 = SET_HANDLE(*result_entity_set); 05744 if (NULL == set3) { 05745 set3 = RefEntityFactory::instance()->construct_RefGroup(); 05746 *result_entity_set = reinterpret_cast<iBase_EntitySetHandle>(set3); 05747 } 05748 05749 const_cast<RefGroup*>(set1)->subtract(const_cast<RefGroup*>(set2), set3); 05750 RETURN(iBase_SUCCESS); 05751 } 05752 05758 ITAPS_API void 05759 iGeom_intersect( iGeom_Instance instance, 05760 /*in*/ iBase_EntitySetHandle entity_set_1, 05761 /*in*/ iBase_EntitySetHandle entity_set_2, 05762 /*out*/ iBase_EntitySetHandle *result_entity_set, 05763 int* err ) 05764 { 05765 const RefGroup *set1 = SET_HANDLE(entity_set_1); 05766 const RefGroup *set2 = SET_HANDLE(entity_set_2); 05767 RefGroup *set3 = SET_HANDLE(*result_entity_set); 05768 if (NULL == set3) { 05769 set3 = RefEntityFactory::instance()->construct_RefGroup(); 05770 *result_entity_set = reinterpret_cast<iBase_EntitySetHandle>(set3); 05771 } 05772 05773 const_cast<RefGroup*>(set1)->intersect(const_cast<RefGroup*>(set2), set3); 05774 RETURN(iBase_SUCCESS); 05775 } 05776 05782 ITAPS_API void 05783 iGeom_unite( iGeom_Instance instance, 05784 /*in*/ iBase_EntitySetHandle entity_set_1, 05785 /*in*/ iBase_EntitySetHandle entity_set_2, 05786 /*out*/ iBase_EntitySetHandle *result_entity_set, 05787 int* err ) 05788 { 05789 const RefGroup *set1 = SET_HANDLE(entity_set_1); 05790 const RefGroup *set2 = SET_HANDLE(entity_set_2); 05791 RefGroup *set3 = SET_HANDLE(*result_entity_set); 05792 if (NULL == set3) { 05793 set3 = RefEntityFactory::instance()->construct_RefGroup(); 05794 *result_entity_set = reinterpret_cast<iBase_EntitySetHandle>(set3); 05795 } 05796 05797 const_cast<RefGroup*>(set1)->unite(const_cast<RefGroup*>(set2), set3); 05798 RETURN(iBase_SUCCESS); 05799 } 05800 05801 ITAPS_API void 05802 iGeom_copyEnt( iGeom_Instance instance, 05803 /*in*/ iBase_EntityHandle geom_entity, 05804 /*out*/ iBase_EntityHandle *geom_entity2, 05805 int* err ) 05806 { 05807 Body *this_body = dynamic_cast<Body*>(ENTITY_HANDLE(geom_entity)); 05808 RefVolume *this_vol = dynamic_cast<RefVolume*>(ENTITY_HANDLE(geom_entity)); 05809 if (NULL != this_vol || NULL != this_body) { 05810 // need to get the associated body, since cgm only supports copying bodies, 05811 // not volumes 05812 if (NULL == this_body) { 05813 this_body = this_vol->get_body_ptr(); 05814 if (NULL == this_body) { 05815 ERROR(iBase_FAILURE, "Can't get body from volume."); 05816 } 05817 } 05818 05819 RefEntity *temp_entity = gmt->copy_body(this_body); 05820 *geom_entity2 = reinterpret_cast<iBase_EntityHandle>(temp_entity); 05821 } 05822 else { 05823 RefEntity *this_ent = ENTITY_HANDLE(geom_entity); 05824 RefEntity *temp_entity = gmt->copy_refentity(this_ent); 05825 *geom_entity2 = reinterpret_cast<iBase_EntityHandle>(temp_entity); 05826 } 05827 05828 if (NULL == *geom_entity2) { 05829 ERROR(iBase_FAILURE, "NULL returned from CGM copy."); 05830 } 05831 05832 RETURN(iBase_SUCCESS); 05833 } 05834 05835 ITAPS_API void 05836 iGeom_sweepEntAboutAxis( iGeom_Instance instance, 05837 /*in*/ iBase_EntityHandle geom_entity, 05838 /*in*/ const double angle, 05839 /*in*/ const double axis_normal_x, 05840 /*in*/ const double axis_normal_y, 05841 /*in*/ const double axis_normal_z, 05842 /*out*/ iBase_EntityHandle *geom_entity2, 05843 int* err ) 05844 { 05845 DLIList<RefEntity*> ents; 05846 RefEntity *this_ent = ENTITY_HANDLE(geom_entity); 05847 if (NULL == this_ent) { 05848 ERROR(iBase_FAILURE, "Can't get ref entity from specified entity."); 05849 } 05850 else if (this_ent->dimension() > 2) { 05851 ERROR(iBase_INVALID_ENTITY_TYPE, "Can't sweep 3-d entities."); 05852 } 05853 05854 RefEntity *new_ent = gmt->copy_refentity(this_ent); 05855 ents.append(new_ent); 05856 05857 CubitVector origin(0.0, 0.0, 0.0); 05858 CubitVector direction(axis_normal_x, axis_normal_y, axis_normal_z); 05859 05860 double radian_angle = angle * DEG_TO_RAD; 05861 05862 DLIList<Body*> new_bodies; 05863 CubitStatus result = gmt->sweep_rotational(ents, origin, direction, 05864 radian_angle, new_bodies, 05865 CUBIT_FALSE, CUBIT_FALSE); 05866 if (CUBIT_FAILURE == result) { 05867 // destroy entity we copied before 05868 gqt->delete_RefEntity(new_ent); 05869 ERROR(iBase_FAILURE, "Sweep returned failure."); 05870 } 05871 05872 else { 05873 // HACK to get last entity created, because cgm doesn't return 05874 // body created by sweep 05875 RefEntity *new_body = new_bodies.get(); 05876 *geom_entity2 = reinterpret_cast<iBase_EntityHandle>(new_body); 05877 05878 // now we know it's succeeded, delete original body 05879 Body *this_body = dynamic_cast<TopologyEntity*>(this_ent)->body(); 05880 if (NULL != this_body) 05881 gqt->delete_RefEntity(this_body); 05882 else 05883 gqt->delete_RefEntity(this_ent); 05884 } 05885 05886 05887 if (NULL == *geom_entity2) { 05888 RETURN(iBase_FAILURE); 05889 } 05890 05891 RETURN(iBase_SUCCESS); 05892 } 05893 05894 ITAPS_API void 05895 iGeom_deleteAll( iGeom_Instance, 05896 int* err ) 05897 { 05898 GeometryQueryTool::instance()->delete_geometry(); 05899 *err = iBase_SUCCESS; 05900 } 05901 05902 05903 ITAPS_API void 05904 iGeom_deleteEnt( iGeom_Instance instance, 05905 /*in*/ iBase_EntityHandle geom_entity, 05906 int* err ) 05907 { 05908 RefEntity *this_ent = ENTITY_HANDLE(geom_entity); 05909 05910 // special case: if this is a volume, delete the body instead 05911 CubitStatus result; 05912 RefVolume *this_vol = CAST_TO(this_ent, RefVolume); 05913 if (NULL != this_vol) 05914 result = gqt->delete_Body(this_vol->body()); 05915 else 05916 result = gqt->delete_RefEntity(this_ent); 05917 05918 if (CUBIT_FAILURE == result) { 05919 ERROR(iBase_FAILURE, "Problems deleting entity."); 05920 } 05921 05922 // check to see if this was last thing deleted; if so, reset ids 05923 RefEntityFactory *rfi = RefEntityFactory::instance(); 05924 if (rfi->num_bodies() == 0 && 05925 rfi->num_ref_volumes() == 0 && 05926 rfi->num_ref_faces() == 0 && 05927 rfi->num_ref_edges() == 0 && 05928 rfi->num_ref_vertices() == 0) 05929 rfi->reset_ids(); 05930 05931 RETURN(iBase_SUCCESS); 05932 } 05933 05934 ITAPS_API void 05935 iGeom_createSphere( iGeom_Instance instance, 05936 double radius, 05937 iBase_EntityHandle *geom_entity, 05938 int* err ) 05939 { 05940 if (radius <= 0.0) { 05941 ERROR(iBase_INVALID_ARGUMENT, "Sphere radius must be must be positive."); 05942 } 05943 05944 RefEntity* tmp_body = gmt->sphere( radius ); 05945 *geom_entity = reinterpret_cast<iBase_EntityHandle>(tmp_body); 05946 RETURN ((tmp_body ? iBase_SUCCESS : iBase_FAILURE)); 05947 } 05948 05949 05950 ITAPS_API void 05951 iGeom_createPrism( iGeom_Instance instance, 05952 /*in*/ double height, 05953 /*in*/ int n_sides, 05954 /*in*/ double major_rad, 05955 /*in*/ double minor_rad, 05956 /*out*/ iBase_EntityHandle *geom_entity, 05957 int* err ) 05958 { 05959 if ( 0.0>=height ) { 05960 ERROR(iBase_INVALID_ARGUMENT, "Prism height must be positive."); 05961 } else if ( 3>n_sides ) { 05962 ERROR(iBase_INVALID_ARGUMENT, "Prism must have at least three sides."); 05963 } 05964 05965 RefEntity* tmp_body = gmt->prism( height, n_sides, major_rad, minor_rad ); 05966 *geom_entity = reinterpret_cast<iBase_EntityHandle>(tmp_body); 05967 RETURN ((tmp_body ? iBase_SUCCESS :iBase_FAILURE)); 05968 } 05969 05970 05971 ITAPS_API void 05972 iGeom_createBrick( iGeom_Instance instance, 05973 /*in*/ double x, 05974 /*in*/ double y, 05975 /*in*/ double z, 05976 /*out*/ iBase_EntityHandle *geom_entity, 05977 int* err ) 05978 { 05979 double tmp_x = x; 05980 double tmp_y = y; 05981 double tmp_z = z; 05982 05983 if (0.0 == y && 0.0 == z) { 05984 tmp_y = x; 05985 tmp_z = x; 05986 } 05987 05988 if (0.0 >= tmp_x || 0.0 >= tmp_y || 0.0 >= tmp_z) { 05989 ERROR(iBase_INVALID_ARGUMENT, "Dimensions must be >= 0, or y & z must both be zero."); 05990 } 05991 05992 RefEntity *temp_body = gmt->brick(tmp_x, tmp_y, tmp_z); 05993 *geom_entity = reinterpret_cast<iBase_EntityHandle>(temp_body); 05994 05995 if (NULL == *geom_entity) { 05996 RETURN(iBase_FAILURE); 05997 } 05998 05999 RETURN(iBase_SUCCESS); 06000 } 06001 06002 ITAPS_API void 06003 iGeom_createCylinder( iGeom_Instance instance, 06004 /*in*/ double height, 06005 /*in*/ double major_rad, 06006 /*in*/ double minor_rad, 06007 /*out*/ iBase_EntityHandle *geom_entity, 06008 int* err ) 06009 { 06010 double tmp_minor = (0.0 == minor_rad ? major_rad : minor_rad); 06011 RefEntity *temp_body = 06012 gmt->cylinder(height, major_rad, tmp_minor, major_rad); 06013 *geom_entity = reinterpret_cast<iBase_EntityHandle>(temp_body); 06014 06015 06016 if (NULL == *geom_entity) { 06017 RETURN(iBase_FAILURE); 06018 } 06019 06020 RETURN(iBase_SUCCESS); 06021 } 06022 06023 ITAPS_API void 06024 iGeom_createCone( iGeom_Instance instance, 06025 /*in*/ double height, 06026 /*in*/ double major_rad_base, 06027 /*in*/ double minor_rad_base, 06028 /*in*/ double rad_top, 06029 /*out*/ iBase_EntityHandle *geom_entity, 06030 int* err ) 06031 { 06032 double tmp_minor = (0.0 == minor_rad_base ? major_rad_base : minor_rad_base); 06033 RefEntity *temp_body = 06034 gmt->cylinder(height, major_rad_base, tmp_minor, rad_top); 06035 *geom_entity = reinterpret_cast<iBase_EntityHandle>(temp_body); 06036 06037 06038 if (NULL == *geom_entity) { 06039 RETURN(iBase_FAILURE); 06040 } 06041 06042 RETURN(iBase_SUCCESS); 06043 } 06044 06045 ITAPS_API void 06046 iGeom_createTorus( iGeom_Instance instance, 06047 /*in*/ double major_rad, 06048 /*in*/ double minor_rad, 06049 /*out*/ iBase_EntityHandle *geom_entity, 06050 int* err ) 06051 { 06052 if (minor_rad >= major_rad) { 06053 ERROR(iBase_INVALID_ARGUMENT, "Major radius must be greater than minor radius for tori."); 06054 } 06055 06056 RefEntity *temp_body = gmt->torus(major_rad, minor_rad); 06057 *geom_entity = reinterpret_cast<iBase_EntityHandle>(temp_body); 06058 06059 if (NULL == *geom_entity) { 06060 RETURN(iBase_FAILURE); 06061 } 06062 06063 RETURN(iBase_SUCCESS); 06064 } 06065 06066 ITAPS_API void 06067 iGeom_moveEnt( iGeom_Instance instance, 06068 /*inout*/ iBase_EntityHandle geom_entity, 06069 /*in*/ double x, 06070 /*in*/ double y, 06071 /*in*/ double z, 06072 int* err ) 06073 { 06074 CubitVector vec(x, y, z); 06075 Body *this_bod = dynamic_cast<Body*>(ENTITY_HANDLE(geom_entity)); 06076 DLIList<Body*> bods; 06077 bods.append(this_bod); 06078 CubitStatus result; 06079 if (NULL != this_bod) { 06080 result = gqt->translate(bods, vec); 06081 if (CUBIT_SUCCESS != result) { 06082 ERROR(iBase_FAILURE, "Failed to move body."); 06083 RETURN(iBase_FAILURE); 06084 } 06085 06086 RETURN(iBase_SUCCESS); 06087 } 06088 06089 BasicTopologyEntity *this_bte = dynamic_cast<BasicTopologyEntity*>(ENTITY_HANDLE(geom_entity)); 06090 if (NULL != this_bte) { 06091 // non-body move; check to see if there are any siblings to this entity in the 06092 // same body; if so, we can't move it; if not, get the body and move that; if 06093 // there is no body, it's a free entity and we can move it anyway 06094 Body *this_body = this_bte->body(); 06095 if (NULL == this_body) { 06096 DLIList<BasicTopologyEntity*> btes; 06097 btes.append(this_bte); 06098 result = gqt->translate(btes, vec); 06099 if (CUBIT_SUCCESS != result) { 06100 ERROR(iBase_FAILURE, "Failed to move entity."); 06101 } 06102 } 06103 else { 06104 int num_sibs = -1; 06105 switch (this_bte->dimension()) { 06106 case 0: num_sibs = this_body->num_ref_vertices(); break; 06107 case 1: num_sibs = this_body->num_ref_edges(); break; 06108 case 2: num_sibs = this_body->num_ref_faces(); break; 06109 } 06110 if (num_sibs == 1) { 06111 // ok to move the body instead 06112 result = gqt->translate(bods, vec); 06113 if (CUBIT_SUCCESS != result) { 06114 ERROR(iBase_FAILURE, "Failed to move body even only one entity of that" 06115 " dimension in the body."); 06116 } 06117 } 06118 else { 06119 ERROR(iBase_FAILURE, "Too many siblings for an entity to move it."); 06120 } 06121 } 06122 06123 RETURN(iBase_SUCCESS); 06124 } 06125 06126 ERROR(iBase_INVALID_ENTITY_TYPE, "Wrong type of entity specified for move."); 06127 } 06128 06129 ITAPS_API void 06130 iGeom_rotateEnt( iGeom_Instance instance, 06131 /*inout*/ iBase_EntityHandle geom_entity, 06132 /*in*/ double angle, 06133 /*in*/ double axis_normal_x, 06134 /*in*/ double axis_normal_y, 06135 /*in*/ double axis_normal_z, 06136 int* err ) 06137 { 06138 CubitVector this_axis(axis_normal_x, axis_normal_y, axis_normal_z); 06139 Body *this_bod = dynamic_cast<Body*>(ENTITY_HANDLE(geom_entity)); 06140 DLIList<Body*> bods; 06141 bods.append(this_bod); 06142 CubitStatus result; 06143 if (NULL != this_bod) { 06144 result = gqt->rotate(bods, this_axis, angle); 06145 if (CUBIT_SUCCESS != result) { 06146 ERROR(iBase_FAILURE, "Failed to rotate body."); 06147 } 06148 06149 RETURN(iBase_SUCCESS); 06150 } 06151 06152 BasicTopologyEntity *this_bte = dynamic_cast<BasicTopologyEntity*>(ENTITY_HANDLE(geom_entity)); 06153 if (NULL != this_bte) { 06154 DLIList<BasicTopologyEntity*> btes; 06155 btes.append(this_bte); 06156 result = gqt->rotate(btes, this_axis, angle); 06157 if (CUBIT_SUCCESS != result) { 06158 ERROR(iBase_FAILURE, "Failed to rotate entity."); 06159 } 06160 06161 RETURN(iBase_SUCCESS); 06162 } 06163 06164 ERROR(iBase_INVALID_ENTITY_TYPE, "Wrong type of entity specified for move."); 06165 } 06166 06167 ITAPS_API void 06168 iGeom_reflectEnt( iGeom_Instance instance, 06169 /*inout*/ iBase_EntityHandle geom_entity, 06170 /*in*/ double point_x, 06171 /*in*/ double point_y, 06172 /*in*/ double point_z, 06173 /*in*/ double plane_normal_x, 06174 /*in*/ double plane_normal_y, 06175 /*in*/ double plane_normal_z, 06176 int* err ) 06177 { 06178 CubitVector this_plane(plane_normal_x, plane_normal_y, plane_normal_z); 06179 CubitVector point(point_x, point_y, point_z); 06180 Body *this_bod = dynamic_cast<Body*>(ENTITY_HANDLE(geom_entity)); 06181 DLIList<Body*> bods; 06182 bods.append(this_bod); 06183 CubitStatus result; 06184 if (NULL != this_bod) { 06185 result = gqt->reflect(bods, point , this_plane); 06186 if (CUBIT_SUCCESS != result) { 06187 ERROR(iBase_FAILURE, "Failed to reflect body."); 06188 } 06189 06190 RETURN(iBase_SUCCESS); 06191 } 06192 06193 BasicTopologyEntity *this_bte = dynamic_cast<BasicTopologyEntity*>(ENTITY_HANDLE(geom_entity)); 06194 if (NULL != this_bte) { 06195 DLIList<BasicTopologyEntity*> btes; 06196 btes.append(this_bte); 06197 result = gqt->reflect(btes, point, this_plane); 06198 if (CUBIT_SUCCESS != result) { 06199 ERROR(iBase_FAILURE, "Failed to reflect entity."); 06200 } 06201 06202 RETURN(iBase_SUCCESS); 06203 } 06204 06205 ERROR(iBase_INVALID_ENTITY_TYPE, "Wrong type of entity specified for reflect."); 06206 } 06207 06208 ITAPS_API void 06209 iGeom_scaleEnt( iGeom_Instance instance, 06210 /*inout*/ iBase_EntityHandle geom_entity, 06211 /*in*/ double point_x, 06212 /*in*/ double point_y, 06213 /*in*/ double point_z, 06214 /*in*/ double scale_x, 06215 /*in*/ double scale_y, 06216 /*in*/ double scale_z, 06217 int* err ) 06218 { 06219 CubitVector factor(scale_x, scale_y, scale_z); 06220 CubitVector point(point_x, point_y, point_z); 06221 Body *this_bod = dynamic_cast<Body*>(ENTITY_HANDLE(geom_entity)); 06222 CubitStatus result; 06223 if (NULL != this_bod) { 06224 result = gqt->scale(this_bod, point, factor); 06225 if (CUBIT_SUCCESS != result) { 06226 ERROR(iBase_FAILURE, "Failed to scale body."); 06227 } 06228 06229 RETURN(iBase_SUCCESS); 06230 } 06231 06232 BasicTopologyEntity *this_bte = dynamic_cast<BasicTopologyEntity*>(ENTITY_HANDLE(geom_entity)); 06233 // non-body move; check to see if there are any siblings to this entity in the 06234 // same body; if so, we can't move it; if not, get the body and move that; if 06235 // there is no body, it's a free entity and we can move it anyway 06236 Body *this_body = this_bte->body(); 06237 if (NULL == this_body && NULL != this_bte) { 06238 result = gqt->scale(this_bte, point, factor); 06239 if (CUBIT_SUCCESS != result) { 06240 ERROR(iBase_FAILURE, "Failed to scale entity."); 06241 } 06242 } 06243 else if (NULL != this_body && NULL != this_bte) { 06244 int num_sibs = -1; 06245 switch (this_bte->dimension()) { 06246 case 0: num_sibs = this_body->num_ref_vertices(); break; 06247 case 1: num_sibs = this_body->num_ref_edges(); break; 06248 case 2: num_sibs = this_body->num_ref_faces(); break; 06249 // for TSTT, always scale volumes 06250 case 3: num_sibs = 1; break; 06251 } 06252 if (num_sibs == 1) { 06253 // ok to scale the body instead 06254 result = gqt->scale(this_body, point, factor); 06255 if (CUBIT_SUCCESS != result) { 06256 ERROR(iBase_FAILURE, "Failed to scale body even only one entity of that" 06257 " dimension in the body."); 06258 } 06259 } 06260 else { 06261 ERROR(iBase_FAILURE, "Too many siblings for an entity to scale it."); 06262 } 06263 } 06264 06265 RETURN(iBase_SUCCESS); 06266 } 06267 06268 ITAPS_API void 06269 iGeom_uniteEnts( iGeom_Instance instance, 06270 /*in*/ iBase_EntityHandle const* geom_entities, 06271 int geom_entities_size, 06272 /*out*/ iBase_EntityHandle *geom_entity, 06273 int* err ) 06274 { 06275 DLIList<Body*> bods, orig_bods; 06276 RefEntity* const* handle_array = ENTITY_HANDLE_CONST_ARRAY(geom_entities); 06277 for (int i = 0; i < geom_entities_size; i++) { 06278 Body *this_body = dynamic_cast<Body*>(handle_array[i]); 06279 if (NULL != this_body) { 06280 Body *new_body = gmt->copy_body(this_body); 06281 if (NULL != new_body) { 06282 bods.append(this_body); 06283 orig_bods.append(new_body); 06284 } 06285 } 06286 } 06287 if (bods.size() < geom_entities_size) { 06288 ERROR(iBase_INVALID_ARGUMENT, "Not all entities input were regions."); 06289 for (int i = bods.size(); i > 0; i--) 06290 gqt->delete_RefEntity(bods.get_and_step()); 06291 06292 RETURN(iBase_SUCCESS); 06293 } 06294 06295 DLIList<Body*> new_bods; 06296 CubitStatus result = gmt->unite(bods, new_bods, false); 06297 if (CUBIT_SUCCESS != result || 1 != new_bods.size()) { 06298 ERROR(iBase_FAILURE, "Unite failed."); 06299 } 06300 06301 else { 06302 *geom_entity = reinterpret_cast<iBase_EntityHandle>(dynamic_cast<RefEntity*>(new_bods.get())); 06303 for (int i = orig_bods.size(); i > 0; i--) 06304 gqt->delete_RefEntity(orig_bods.get_and_step()); 06305 } 06306 06307 RETURN(iBase_SUCCESS); 06308 } 06309 06310 ITAPS_API void 06311 iGeom_subtractEnts( iGeom_Instance instance, 06312 /*in*/ iBase_EntityHandle blank, 06313 /*in*/ iBase_EntityHandle tool, 06314 /*out*/ iBase_EntityHandle *geom_entity, 06315 int* err ) 06316 { 06317 Body *this_blank = dynamic_cast<Body*>(ENTITY_HANDLE(blank)); 06318 Body *blank_copy = gmt->copy_body(this_blank); 06319 if (NULL == blank_copy) { 06320 ERROR(iBase_FAILURE, "Trouble copying blank."); 06321 } 06322 Body *this_tool = dynamic_cast<Body*>(ENTITY_HANDLE(tool)); 06323 Body *tool_copy = gmt->copy_body(this_tool); 06324 if (NULL == tool_copy) { 06325 ERROR(iBase_FAILURE, "Trouble copying tool."); 06326 gqt->delete_RefEntity(blank_copy); 06327 RETURN(iBase_FAILURE); 06328 } 06329 06330 DLIList<Body*> blank_list, new_body_list; 06331 blank_list.append(blank_copy); 06332 06333 RefEntity *new_body = NULL; 06334 CubitStatus result = gmt->subtract(tool_copy, blank_list, new_body_list); 06335 if (CUBIT_SUCCESS != result || 0 == new_body_list.size()) { 06336 ERROR(iBase_FAILURE, "Subtract failed."); 06337 } 06338 else { 06339 new_body = new_body_list.get(); 06340 *geom_entity = reinterpret_cast<iBase_EntityHandle>(new_body); 06341 gqt->delete_RefEntity(this_blank); 06342 gqt->delete_RefEntity(this_tool); 06343 } 06344 06345 RETURN(iBase_SUCCESS); 06346 } 06347 06348 ITAPS_API void 06349 iGeom_intersectEnts( iGeom_Instance instance, 06350 /*in*/ iBase_EntityHandle ent1, 06351 /*in*/ iBase_EntityHandle ent2, 06352 /*out*/ iBase_EntityHandle *geom_entity, 06353 int* err ) 06354 { 06355 Body *this_ent1 = dynamic_cast<Body*>(ENTITY_HANDLE(ent1)); 06356 Body *ent1_copy = gmt->copy_body(this_ent1); 06357 if (NULL == ent1_copy) { 06358 ERROR(iBase_FAILURE, "Trouble copying blank."); 06359 } 06360 Body *this_ent2 = dynamic_cast<Body*>(ENTITY_HANDLE(ent2)); 06361 Body *ent2_copy = gmt->copy_body(this_ent2); 06362 if (NULL == ent2_copy) { 06363 ERROR(iBase_FAILURE, "Trouble copying tool."); 06364 gqt->delete_RefEntity(ent1_copy); 06365 RETURN(iBase_FAILURE); 06366 } 06367 06368 DLIList<Body*> ent1_list, new_body_list; 06369 ent1_list.append(ent1_copy); 06370 06371 RefEntity *new_body = NULL; 06372 CubitStatus result = gmt->intersect(ent2_copy, ent1_list, new_body_list); 06373 if (CUBIT_SUCCESS != result || 0 == new_body_list.size()) { 06374 ERROR(iBase_FAILURE, "Intersect failed."); 06375 } 06376 else { 06377 new_body = new_body_list.get(); 06378 *geom_entity = reinterpret_cast<iBase_EntityHandle>(new_body); 06379 gqt->delete_RefEntity(this_ent2); 06380 gqt->delete_RefEntity(this_ent1); 06381 } 06382 06383 RETURN(iBase_SUCCESS); 06384 } 06385 06386 ITAPS_API void 06387 iGeom_sectionEnt( iGeom_Instance instance, 06388 /*inout*/ iBase_EntityHandle geom_entity, 06389 /*in*/ double plane_normal_x, 06390 /*in*/ double plane_normal_y, 06391 /*in*/ double plane_normal_z, 06392 /*in*/ double offset, 06393 /*in*/ int reverse, 06394 /*out*/ iBase_EntityHandle *geom_entity2, 06395 int* err ) 06396 { 06397 Body *this_body = dynamic_cast<Body*>(ENTITY_HANDLE(geom_entity)); 06398 if (NULL == this_body) { 06399 RefVolume *this_vol = dynamic_cast<RefVolume*>(ENTITY_HANDLE(geom_entity)); 06400 if (NULL != this_vol) 06401 this_body = this_vol->get_body_ptr(); 06402 } 06403 if (NULL == this_body) { 06404 ERROR(iBase_INVALID_ARGUMENT, "Can only section bodies."); 06405 } 06406 06407 CubitVector normal(plane_normal_x, plane_normal_y, plane_normal_z); 06408 if (normal.length_squared() == 0.0) { 06409 ERROR(iBase_INVALID_ARGUMENT, "Zero-length vector input."); 06410 } 06411 06412 CubitVector point1 = normal * CubitVector(1.0, 0.0, 0.0); 06413 if (point1.length_squared() == 0.0) 06414 point1 = normal * CubitVector(0.0, 1.0, 0.0); 06415 06416 CubitVector point2 = normal * point1; 06417 CubitVector point3(0.0, 0.0, 0.0); 06418 06419 if (0.0 != offset) { 06420 normal.normalize(); 06421 normal *= offset; 06422 point1 += normal; 06423 point2 += normal; 06424 point3 += normal; 06425 } 06426 06427 06428 DLIList<Body*> blank_list, new_body_list; 06429 blank_list.append(gmt->copy_body(this_body)); 06430 CubitStatus result = gmt->section(blank_list, point1, point2, point3, 06431 new_body_list, !reverse, 06432 false); 06433 if (CUBIT_SUCCESS != result || 0 == new_body_list.size()) { 06434 gqt->delete_RefEntity(blank_list.get()); 06435 ERROR(iBase_FAILURE, "Section failed."); 06436 } 06437 06438 else { 06439 // need to assign it to a RE* first so the void cast gets done right 06440 RefEntity *new_body = new_body_list.get(); 06441 *geom_entity2 = reinterpret_cast<iBase_EntityHandle>(new_body); 06442 // also, delete the original body, now that the section worked 06443 gqt->delete_RefEntity(this_body); 06444 } 06445 06446 RETURN(iBase_SUCCESS); 06447 } 06448 06449 ITAPS_API void 06450 iGeom_imprintEnts( iGeom_Instance instance, 06451 /*in*/ iBase_EntityHandle const* gentity_handles, 06452 int gentity_handles_size, 06453 int* err ) 06454 { 06455 if (gentity_handles_size < 1) // GMT::imprint segfaults if passed an empty list 06456 RETURN(iBase_SUCCESS); 06457 06458 DLIList<Body*> bods; 06459 DLIList<RefVolume*> vols, temp_vols; 06460 RefEntity* const* handle_array = ENTITY_HANDLE_CONST_ARRAY(gentity_handles); 06461 CubitStatus status = CUBIT_SUCCESS; 06462 for (int i = 0; i < gentity_handles_size; i++) { 06463 Body *temp_bod = dynamic_cast<Body*>(handle_array[i]); 06464 if (NULL != temp_bod) { 06465 bods.append_unique(temp_bod); 06466 continue; 06467 } 06468 06469 RefVolume *temp_vol = dynamic_cast<RefVolume*>(handle_array[i]); 06470 if (NULL != temp_vol) { 06471 TopologyEntity *topo_ent = dynamic_cast<TopologyEntity*>(handle_array[i]); 06472 if (NULL == topo_ent) { 06473 status = CUBIT_FAILURE; 06474 continue; 06475 } 06476 temp_bod = topo_ent->body(); 06477 if (NULL == temp_bod) { 06478 status = CUBIT_FAILURE; 06479 continue; 06480 } 06481 bods.append_unique(temp_bod); 06482 continue; 06483 } 06484 06485 // if we've gotten here, it's an error 06486 status = CUBIT_FAILURE; 06487 } 06488 06489 if (CUBIT_SUCCESS != status) RETURN(iBase_FAILURE); 06490 06491 DLIList<Body*> temp_bods; 06492 status = GeometryModifyTool::instance()->imprint(bods, temp_bods, false); 06493 06494 RETURN(iBase_SUCCESS); 06495 } 06496 06497 ITAPS_API void 06498 iGeom_mergeEnts( iGeom_Instance instance, 06499 /*in*/ iBase_EntityHandle const* gentity_handles, 06500 int gentity_handles_size, 06501 double tolerance, 06502 int* err ) 06503 { 06504 double old_factor = GeometryQueryTool::instance()->get_geometry_factor(); 06505 if (tolerance != old_factor) 06506 GeometryQueryTool::instance()->set_geometry_factor(tolerance*1.0e6); 06507 else old_factor = 0.0; 06508 06509 DLIList<Body*> bods; 06510 DLIList<RefVolume*> vols, temp_vols; 06511 DLIList<RefFace*> faces; 06512 DLIList<RefEdge*> edges; 06513 DLIList<RefVertex*> verts; 06514 RefEntity* const* handle_array = ENTITY_HANDLE_CONST_ARRAY(gentity_handles); 06515 for (int i = 0; i < gentity_handles_size; i++) { 06516 TopologyEntity *topo_ent = dynamic_cast<TopologyEntity*>(handle_array[i]); 06517 if (NULL == topo_ent) continue; 06518 Body *temp_bod; 06519 RefVolume *temp_vol; 06520 RefFace *temp_face; 06521 RefEdge *temp_edge; 06522 RefVertex *temp_vert; 06523 switch (handle_array[i]->dimension()) { 06524 case -1: 06525 // it should be a body 06526 temp_bod = dynamic_cast<Body*>(handle_array[i]); 06527 if (NULL == temp_bod) RETURN(iBase_FAILURE); 06528 temp_vols.clean_out(); 06529 topo_ent->ref_volumes(temp_vols); 06530 vols += temp_vols; 06531 break; 06532 case 0: 06533 temp_vert = dynamic_cast<RefVertex*>(handle_array[i]); 06534 if (NULL == temp_vert) RETURN(iBase_FAILURE); 06535 verts.append(temp_vert); 06536 break; 06537 case 1: 06538 temp_edge = dynamic_cast<RefEdge*>(handle_array[i]); 06539 if (NULL == temp_edge) RETURN(iBase_FAILURE); 06540 edges.append(temp_edge); 06541 break; 06542 case 2: 06543 temp_face = dynamic_cast<RefFace*>(handle_array[i]); 06544 if (NULL == temp_face) RETURN(iBase_FAILURE); 06545 faces.append(temp_face); 06546 break; 06547 case 3: 06548 temp_vol = dynamic_cast<RefVolume*>(handle_array[i]); 06549 if (NULL == temp_vol) RETURN(iBase_FAILURE); 06550 vols.append(temp_vol); 06551 break; 06552 } 06553 } 06554 06555 CubitStatus status = CUBIT_SUCCESS, temp_status; 06556 06557 if (verts.size() != 0) { 06558 temp_status = MergeTool::instance()->merge_refvertices(verts, false); 06559 if (CUBIT_SUCCESS != temp_status) status = temp_status; 06560 } 06561 06562 if (edges.size() != 0) { 06563 temp_status = MergeTool::instance()->merge_refedges(edges, true, false); 06564 if (CUBIT_SUCCESS != temp_status) status = temp_status; 06565 } 06566 06567 if (faces.size() != 0) { 06568 temp_status = MergeTool::instance()->merge_reffaces(faces, false); 06569 if (CUBIT_SUCCESS != temp_status) status = temp_status; 06570 } 06571 06572 if (vols.size() != 0) { 06573 temp_status = MergeTool::instance()->merge_volumes(vols, false); 06574 if (CUBIT_SUCCESS != temp_status) status = temp_status; 06575 } 06576 06577 if (bods.size() != 0) { 06578 temp_status = MergeTool::instance()->merge_bodies(bods); 06579 if (CUBIT_SUCCESS != temp_status) status = temp_status; 06580 } 06581 06582 if (0 != old_factor) 06583 GeometryQueryTool::instance()->set_geometry_factor(old_factor); 06584 06585 if (CUBIT_SUCCESS != status) { 06586 RETURN(iBase_FAILURE); 06587 } 06588 06589 else { 06590 RETURN(iBase_SUCCESS); 06591 } 06592 } 06593 06594 ITAPS_API void 06595 iGeom_isPositionOn( iGeom_Instance instance, 06596 iBase_EntityHandle entity, 06597 double x, 06598 double y, 06599 double z, 06600 int* IsOn ) 06601 { 06602 CubitVector position(x,y,z); 06603 RefVertex* ref_v = dynamic_cast<RefVertex*>(ENTITY_HANDLE(entity)); 06604 if(ref_v) 06605 { 06606 CubitVector v_loc = ref_v->coordinates(); 06607 CubitBoolean test = v_loc.about_equal(position); 06608 if (test == CUBIT_TRUE) 06609 *IsOn = 1; 06610 else 06611 *IsOn = 0; 06612 return; 06613 } 06614 06615 CubitPointContainment pc = CUBIT_PNT_UNKNOWN; 06616 RefFace *ref_face = dynamic_cast<RefFace*>(ENTITY_HANDLE(entity)); 06617 if(ref_face) 06618 pc = ref_face->point_containment(position); 06619 06620 RefEdge *ref_edge = dynamic_cast<RefEdge*>(ENTITY_HANDLE(entity)); 06621 if(ref_edge) 06622 pc = ref_edge->point_containment(position); 06623 06624 Body *body = dynamic_cast<Body*>(ENTITY_HANDLE(entity)); 06625 if(body) 06626 pc = body->point_containment(position); 06627 06628 if (pc == CUBIT_PNT_INSIDE || pc == CUBIT_PNT_BOUNDARY) 06629 *IsOn = 1; 06630 06631 else 06632 *IsOn = 0; 06633 return; 06634 } 06635 06636 } // extern "C" 06637 06638 /********************* HELPER FUNCTION IMPLEMENTATIONS ***************************/ 06639 06640 static void tokenize( const std::string& str, 06641 std::vector<std::string>& tokens ) 06642 { 06643 char delim = str[0]; 06644 std::string::size_type last = str.find_first_not_of( delim, 1 ); 06645 std::string::size_type pos = str.find_first_of( delim, last ); 06646 while (std::string::npos != pos && std::string::npos != last) { 06647 tokens.push_back( str.substr( last, pos - last ) ); 06648 last = str.find_first_not_of( delim, pos ); 06649 pos = str.find_first_of( delim, last ); 06650 } 06651 } 06652 06653 // Expect option of the form "NAME=VALUE". 06654 // If NAME portion matches, pass back VALUE and return true. 06655 // Otherwise, leave 'value' unchanged and return false. 06656 static bool match_option( const std::string& opt, 06657 const char* name, 06658 std::string& value ) 06659 { 06660 std::string::size_type len = strlen( name ); 06661 if (opt[len] != '=') 06662 return false; 06663 if (opt.compare( 0, len, name, len )) 06664 return false; 06665 value = opt.substr( len + 1 ); 06666 return true; 06667 } 06668 06669 06670 static void 06671 iGeom_get_adjacent_entities( const RefEntity *from, 06672 const int to_dim, 06673 DLIList<RefEntity*> &adj_ents, 06674 int* err ) 06675 { 06676 TopologyEntity *topo_ent = const_cast<TopologyEntity*>(dynamic_cast<const TopologyEntity*>(from)); 06677 if (NULL == topo_ent) { 06678 ERROR(iBase_INVALID_ARGUMENT, "Bad entity input."); 06679 } 06680 06681 adj_ents.clean_out(); 06682 static DLIList<RefVertex*> tmp_verts; 06683 static DLIList<RefEdge*> tmp_edges; 06684 static DLIList<RefFace*> tmp_faces; 06685 static DLIList<Body*> tmp_bodies; 06686 06687 switch (to_dim) { 06688 case 0: 06689 tmp_verts.clean_out(); 06690 topo_ent->ref_vertices(tmp_verts); 06691 CAST_LIST_TO_PARENT(tmp_verts, adj_ents); 06692 break; 06693 case 1: 06694 tmp_edges.clean_out(); 06695 topo_ent->ref_edges(tmp_edges); 06696 CAST_LIST_TO_PARENT(tmp_edges, adj_ents); 06697 break; 06698 case 2: 06699 tmp_faces.clean_out(); 06700 topo_ent->ref_faces(tmp_faces); 06701 CAST_LIST_TO_PARENT(tmp_faces, adj_ents); 06702 break; 06703 case 3: 06704 tmp_bodies.clean_out(); 06705 topo_ent->bodies(tmp_bodies); 06706 CAST_LIST_TO_PARENT(tmp_bodies, adj_ents); 06707 break; 06708 default: 06709 ERROR(iBase_INVALID_ARGUMENT, "Bad input dimension getting adjacent entities."); 06710 } 06711 06712 RETURN(iBase_SUCCESS); 06713 } 06714 06715 /* Common implementation for both single-entity and array functions. */ 06716 static CubitStatus iGeom_closest_point( RefEntity* this_entity, 06717 const CubitVector& near, 06718 CubitVector& on ) 06719 { 06720 RefEdge *this_edge; 06721 RefFace *this_face; 06722 Surface *this_surf; 06723 CubitStatus status; 06724 06725 switch (this_entity->dimension()) { 06726 case 0: 06727 on = dynamic_cast<RefVertex*>(this_entity)->coordinates(); 06728 status = CUBIT_SUCCESS; 06729 break; 06730 case 1: 06731 this_edge = dynamic_cast<RefEdge*>(this_entity); 06732 if (NULL == this_edge) return CUBIT_FAILURE; 06733 06734 status = this_edge->closest_point(near, on); 06735 06736 if (debug) { 06737 std::cout << "Edge " << this_edge->id() << " closest point to (" 06738 << near.x() << ", " << near.y() << ", " << near.z() 06739 << ") is " 06740 << on.x() << ", " << on.y() << ", " << on.z() 06741 << ")" << std::endl; 06742 } 06743 break; 06744 case 2: 06745 this_face = dynamic_cast<RefFace*>(this_entity); 06746 if (NULL == this_face) return CUBIT_FAILURE; 06747 this_surf = this_face->get_surface_ptr(); 06748 if (NULL == this_surf) return CUBIT_FAILURE; 06749 status = this_surf->closest_point( near, &on ); 06750 break; 06751 default: 06752 // just copy over the coordinates 06753 on = near; 06754 status = CUBIT_SUCCESS; 06755 break; 06756 } 06757 06758 return status; 06759 } 06760 06761 static CubitStatus iGeom_closest_point_trimmed( RefEntity* this_entity, 06762 const CubitVector& near, 06763 CubitVector& on ) 06764 { 06765 RefEdge *this_edge; 06766 RefFace *this_face; 06767 Surface *this_surf; 06768 CubitStatus status; 06769 06770 switch (this_entity->dimension()) { 06771 case 0: 06772 on = dynamic_cast<RefVertex*>(this_entity)->coordinates(); 06773 status = CUBIT_SUCCESS; 06774 break; 06775 case 1: 06776 this_edge = dynamic_cast<RefEdge*>(this_entity); 06777 if (NULL == this_edge) return CUBIT_FAILURE; 06778 06779 status = this_edge->closest_point(near, on); 06780 06781 if (debug) { 06782 std::cout << "Edge " << this_edge->id() << " closest point to (" 06783 << near.x() << ", " << near.y() << ", " << near.z() 06784 << ") is " 06785 << on.x() << ", " << on.y() << ", " << on.z() 06786 << ")" << std::endl; 06787 } 06788 break; 06789 case 2: 06790 this_face = dynamic_cast<RefFace*>(this_entity); 06791 if (NULL == this_face) return CUBIT_FAILURE; 06792 this_surf = this_face->get_surface_ptr(); 06793 if (NULL == this_surf) return CUBIT_FAILURE; 06794 this_surf->closest_point_trimmed( near, on ); 06795 status = CUBIT_SUCCESS; 06796 break; 06797 default: 06798 // just copy over the coordinates 06799 on = near; 06800 status = CUBIT_SUCCESS; 06801 break; 06802 } 06803 06804 return status; 06805 } 06806 06807 static CubitStatus 06808 iGeom_closest_point_and_normal( RefEntity* this_entity, 06809 const CubitVector& near, 06810 CubitVector& on, 06811 CubitVector& normal ) 06812 { 06813 RefEdge* this_edge; 06814 RefFace* this_face; 06815 Surface* this_surf; 06816 CubitStatus status; 06817 switch (this_entity->dimension()) { 06818 case 0: 06819 on = dynamic_cast<RefVertex*>(this_entity)->coordinates(); 06820 normal.set( 0, 0, 0 ); 06821 status = CUBIT_SUCCESS; 06822 break; 06823 case 1: 06824 this_edge = dynamic_cast<RefEdge*>(this_entity); 06825 if (NULL == this_edge) return CUBIT_FAILURE; 06826 06827 status = this_edge->closest_point( near, on ); 06828 if (debug) { 06829 std::cout << "Edge " << this_edge->id() << " closest point to (" 06830 << near.x() << ", " << near.y() << ", " << near.z() 06831 << ") is " 06832 << on.x() << ", " << on.y() << ", " << on.x() 06833 << ")" << std::endl; 06834 } 06835 break; 06836 case 2: 06837 this_face = dynamic_cast<RefFace*>(this_entity); 06838 if (NULL == this_face) return CUBIT_FAILURE; 06839 this_surf = this_face->get_surface_ptr(); 06840 if (NULL == this_surf) return CUBIT_FAILURE; 06841 status = this_surf->closest_point( near, &on, &normal ); 06842 if (this_surf->bridge_sense() == CUBIT_REVERSED) 06843 normal = -normal; 06844 break; 06845 default: 06846 // just copy over the coordinates 06847 on = near; 06848 normal.set( 0, 0, 0 ); 06849 status = CUBIT_SUCCESS; 06850 break; 06851 } 06852 06853 return status; 06854 } 06855 06856 static CubitStatus 06857 iGeom_bounding_box( RefEntity* entity, CubitVector& minc, CubitVector& maxc ) 06858 { 06859 CubitBox box; 06860 if (BasicTopologyEntity* bte = dynamic_cast<BasicTopologyEntity*>(entity)) 06861 box = bte->bounding_box(); 06862 else if(Body* body = dynamic_cast<Body*>(entity)) 06863 box = body->bounding_box(); 06864 else { 06865 CGM_iGeom_setLastError(iBase_INVALID_ENTITY_HANDLE, "Entities passed into gentityBoundingBox must be vertex, edge, face, or region."); 06866 return CUBIT_FAILURE; 06867 } 06868 06869 minc = box.minimum(); 06870 maxc = box.maximum(); 06871 return CUBIT_SUCCESS; 06872 } 06873 06876 /* 06877 static inline void box_min_max( double dir, 06878 double min, 06879 double max, 06880 double pt, 06881 double& tmin, 06882 double& tmax ) 06883 { 06884 if (dir == 0) { 06885 tmin = std::numeric_limits<double>::min(); 06886 tmax = std::numeric_limits<double>::max(); 06887 } 06888 else if (dir > 0.0) { 06889 tmin = (min - pt) / dir; 06890 tmax = (max - pt) / dir; 06891 } 06892 else { 06893 tmin = (max - pt) / dir; 06894 tmax = (min - pt) / dir; 06895 } 06896 } 06897 */ 06898 06899 /* 06900 static bool 06901 iBase_intersect_ray_box( const CubitBox& box, 06902 const CubitVector& point, 06903 const CubitVector& direction ) 06904 { 06905 double txmin, txmax, tymin, tymax, tzmin, tzmax; 06906 box_min_max( direction.x(), box.minimum().x(), box.maximum().x(), point.x(), txmin, txmax ); 06907 box_min_max( direction.y(), box.minimum().y(), box.maximum().y(), point.y(), tymin, tymax ); 06908 if (txmin > tymax || tymin > txmax) 06909 return false; 06910 06911 if (tymin > txmin) 06912 txmin = tymin; 06913 if (tymax < txmax) 06914 txmax = tymax; 06915 06916 box_min_max( direction.z(), box.minimum().z(), box.maximum().z(), point.z(), tzmin, tzmax ); 06917 if (txmin > txmax || tzmin > txmax) 06918 return false; 06919 06920 return true; 06921 } 06922 */ 06923 06924 static CubitStatus 06925 iGeom_fire_ray( const CubitVector& point, 06926 const CubitVector& direction, 06927 DLIList<RefEntity*>& entities, 06928 DLIList<double>& ray_params ) 06929 { 06930 const double EPSILON = 0.0; 06931 CubitStatus s; 06932 CubitVector nc_point(point), nc_direction(direction); 06933 06934 // get all free entities in model 06935 DLIList<RefEntity*> target_entities; 06936 s = GeometryQueryTool::instance()->get_free_ref_entities( target_entities ); 06937 if (CUBIT_SUCCESS != s) return s; 06938 DLIList<Body*> bodies; 06939 GeometryQueryTool::instance()->bodies( bodies ); 06940 CAST_LIST_TO_PARENT( bodies, target_entities ); 06941 06942 // do ray fire at list of free entities 06943 return GeometryQueryTool::instance()-> 06944 fire_ray( nc_point, nc_direction, target_entities, ray_params, 0, EPSILON, &entities ); 06945 } 06946 06947 static RefEntity* point_classification( const CubitVector& pt, RefVertex* vtx ) 06948 { 06949 return (pt - vtx->coordinates()).length_squared() > GEOMETRY_RESABS*GEOMETRY_RESABS ? 0 : vtx; 06950 } 06951 06952 static RefEntity* point_classification( const CubitVector& pt, RefEdge* edge ) 06953 { 06954 CubitVector closest; 06955 edge->closest_point_trimmed( pt, closest ); 06956 if ((pt - closest).length_squared() > GEOMETRY_RESABS*GEOMETRY_RESABS) 06957 return 0; 06958 06959 if (RefEntity* vtx = point_classification( pt, edge->start_vertex() )) 06960 return vtx; 06961 else if (RefEntity* vtx = point_classification( pt, edge->end_vertex() )) 06962 return vtx; 06963 else 06964 return edge; 06965 } 06966 06967 static RefEntity* point_classification( const CubitVector& pt, RefFace* face ) 06968 { 06969 CubitBox extents = face->bounding_box(); 06970 if (extents.distance_squared(pt) > GEOMETRY_RESABS*GEOMETRY_RESABS) 06971 return 0; 06972 06973 CubitVector closest; 06974 face->find_closest_point_trimmed( pt, closest ); 06975 if ((pt - closest).length_squared() > GEOMETRY_RESABS*GEOMETRY_RESABS) 06976 return 0; 06977 06978 DLIList<RefEdge*> edges; 06979 face->ref_edges( edges ); 06980 edges.last(); 06981 for (int i = 0; i < edges.size(); ++i) 06982 if (RefEntity* ent = point_classification( pt, edges.step_and_get() )) 06983 return ent; 06984 06985 return face; 06986 } 06987 06988 static RefEntity* point_classification( const CubitVector& pt, Body* body ) 06989 { 06990 CubitVector nonconst_pt(pt); 06991 CubitPointContainment pc = body->point_containment( nonconst_pt ); 06992 if (CUBIT_PNT_INSIDE == pc) 06993 return body; 06994 else if (CUBIT_PNT_BOUNDARY != pc) 06995 return 0; 06996 06997 // If we're here, then we're on the boundary. 06998 // Find which boundary entity we're on. 06999 DLIList<RefFace*> faces; 07000 body->ref_faces( faces ); 07001 faces.last(); 07002 for (int i = 0; i < faces.size(); ++i) 07003 if (RefEntity* ent = point_classification( pt, faces.step_and_get() )) 07004 return ent; 07005 07006 // We don't appear to be on any face. Is the tolerance for 07007 // Body::point_classification something other than GEOMETRY_RESABS?? 07008 return body; 07009 } 07010 07011 07012 07013 static RefEntity* 07014 iGeom_get_point_containment( const CubitVector& pt ) 07015 { 07016 DLIList<RefEntity*> ents; 07017 gqt->get_free_ref_entities( ents ); 07018 07019 ents.reset(); 07020 for (int i = 0; i < ents.size(); ++i) 07021 if (RefVertex* vtx = dynamic_cast<RefVertex*>(ents.get_and_step())) 07022 if (RefEntity* ent = point_classification( pt, vtx )) 07023 return ent; 07024 for (int i = 0; i < ents.size(); ++i) 07025 if (RefEdge* edge = dynamic_cast<RefEdge*>(ents.get_and_step())) 07026 if (RefEntity* ent = point_classification( pt, edge )) 07027 return ent; 07028 for (int i = 0; i < ents.size(); ++i) 07029 if (RefFace* face = dynamic_cast<RefFace*>(ents.get_and_step())) 07030 if (RefEntity* ent = point_classification( pt, face )) 07031 return ent; 07032 07033 DLIList<Body*> bodies; 07034 gqt->bodies( bodies ); 07035 bodies.reset(); 07036 for (int i = 0; i < bodies.size(); ++i) 07037 if (RefEntity* ent = point_classification( pt, bodies.get_and_step() )) 07038 return ent; 07039 07040 return 0; 07041 } 07042 07043 static int iGeom_get_nonmanifold_sense( const BasicTopologyEntity* child, 07044 const BasicTopologyEntity* parent, 07045 int* err ) 07046 { 07047 DLIList<SenseEntity*> se_list(1); 07048 const_cast<BasicTopologyEntity*>(child) 07049 ->get_sense_entities( se_list, const_cast<BasicTopologyEntity*>(parent) ); 07050 if (se_list.size() == 0) { 07051 CGM_iGeom_setLastError((*err = iBase_INVALID_ENTITY_HANDLE), "Relative senes of unrelated entities"); 07052 return 2; 07053 } 07054 se_list.reset(); 07055 CubitSense sense = se_list.get_and_step()->get_sense(); 07056 for (int i = se_list.size() - 1; i > 0; --i) 07057 if (se_list.get_and_step()->get_sense() != sense) { 07058 *err = iBase_SUCCESS; 07059 return 0; 07060 } 07061 *err = iBase_SUCCESS; 07062 return sense == CUBIT_FORWARD ? 1 : -1; 07063 } 07064 07065 static 07066 int iGeom_edge_vertex_sense( const RefEdge* cedge, 07067 const RefVertex* vtx1, 07068 const RefVertex* vtx2, 07069 int* err ) 07070 { 07071 RefEdge* edge = const_cast<RefEdge*>(cedge); 07072 if (edge->start_vertex() == vtx1 && edge->end_vertex() == vtx2) 07073 return vtx1 == vtx2 ? 0 : 1; 07074 else if (edge->start_vertex() == vtx2 && edge->end_vertex() == vtx1) 07075 return -1; 07076 CGM_iGeom_setLastError((*err = iBase_INVALID_ENTITY_HANDLE), "Relative senes of unrelated entities"); 07077 return 2; 07078 } 07079 07080 static int iGeom_is_parametric( RefEntity* entity ) 07081 { 07082 if (RefFace* face = dynamic_cast<RefFace*>(entity)) 07083 return face->is_parametric(); 07084 else if (dynamic_cast<RefEdge*>(entity)) 07085 return true; 07086 else 07087 return false; 07088 } 07089 07090 static iBase_ErrorType 07091 iGeom_get_vtx_to_u(RefVertex* vertex, 07092 RefEdge* edge, 07093 double& u) 07094 { 07095 if (edge->start_vertex() == vertex) 07096 u = edge->start_param(); 07097 else if (edge->end_vertex() == vertex) 07098 u = edge->end_param(); 07099 else 07100 return iBase_INVALID_ARGUMENT; 07101 return iBase_SUCCESS; 07102 } 07103 07104 static iBase_ErrorType 07105 iGeom_get_vtx_to_uv(RefVertex* vertex, RefFace* face, double& u, double& v) 07106 { 07107 DLIList<RefVertex*> pts; 07108 TopologyEntity *topo_ent = dynamic_cast<TopologyEntity*>(face); 07109 topo_ent->ref_vertices(pts); 07110 07111 pts.reset(); 07112 for(int i=0; i<pts.size(); i++) { 07113 if (pts.get_and_step() == vertex) { 07114 face->u_v_from_position( vertex->coordinates(), u, v ); 07115 return iBase_SUCCESS; 07116 } 07117 } 07118 return iBase_INVALID_ARGUMENT; 07119 } 07120 07121 static CubitStatus 07122 iGeom_normal_from_uv( RefFace* face, double u, double v, CubitVector& normal ) 07123 { 07124 07125 CubitVector coords = face->position_from_u_v( u, v ); 07126 Surface* surf_ptr = face->get_surface_ptr(); 07127 CubitStatus rval = surf_ptr->closest_point_uv_guess( coords, u, v, 0, &normal ); 07128 if (surf_ptr->bridge_sense() == CUBIT_REVERSED) 07129 normal = -normal; 07130 return rval; 07131 } 07132 07133 static CubitStatus 07134 iGeom_is_periodic( RefEntity* entity, int& u, int& v ) 07135 { 07136 if (RefEdge* edge = dynamic_cast<RefEdge*>(entity)) { 07137 u = edge->is_periodic(); 07138 v = CUBIT_FALSE; 07139 } 07140 else if (RefFace* face = dynamic_cast<RefFace*>(entity)) { 07141 double period; 07142 u = face->is_periodic_in_U(period); 07143 v = face->is_periodic_in_V(period); 07144 } 07145 else { 07146 u = v = CUBIT_FALSE; 07147 } 07148 07149 return CUBIT_SUCCESS; 07150 } 07151 07152 static bool 07153 iGeom_is_face_degenerate( RefFace* face ) 07154 { 07155 double param = 0; 07156 CubitBoolean b1 = face->is_singular_in_U(param); 07157 CubitBoolean b2 = face->is_singular_in_V(param); 07158 return b1 || b2; 07159 } 07160 07161 static iBase_ErrorType 07162 process_attribs(iGeom_Instance instance, DLIList<RefEntity*> &ref_list) 07163 { 07164 // go through all entities, checking for remaining simple attribs 07165 DLIList<CubitSimpleAttrib> csa_list; 07166 iBase_ErrorType result = iBase_SUCCESS; 07167 07168 for (int i = ref_list.size(); i > 0; i--) { 07169 csa_list.clean_out(); 07170 07171 // get all the csa's still on this entity 07172 RefEntity *this_ent = ref_list.get_and_step(); 07173 TopologyEntity *topo_ent = dynamic_cast<TopologyEntity*>(this_ent); 07174 topo_ent->bridge_manager()->topology_bridge()->get_simple_attribute(csa_list); 07175 07176 for (int j = csa_list.size(); j > 0; j--) { 07177 // see if there's a tag for this csa already 07178 CubitSimpleAttrib csa = csa_list.get_and_step(); 07179 const char *tag_name = csa.character_type().c_str(); 07180 long tag = TM->getTagHandle(tag_name); 07181 if (tag < 0) continue; 07182 else if (0 == tag) { 07183 // don't have a tag handle for this yet - make one 07184 result = TM->create_csa_tag(tag_name, &tag); 07185 if (iBase_SUCCESS != result || 0 == tag) return iBase_FAILURE; 07186 } 07187 07188 // now set the tag 07189 iBase_ErrorType tmp_result = TM->set_csa_tag(this_ent, tag, &csa); 07190 if (iBase_SUCCESS != tmp_result) result = tmp_result; 07191 } 07192 } 07193 07194 return iBase_SUCCESS; 07195 } 07196 07197 07198 template <typename T> static inline 07199 int count_type( const DLIList<CubitEntity*>& list ) 07200 { 07201 int count = 0, size = list.size(); 07202 for (int i = 0; i < size; ++i) 07203 if (dynamic_cast<T*>(list[i])) 07204 ++count; 07205 return count; 07206 } 07207 07208 static inline 07209 int count_ibase_type( int ibase_type, const DLIList<CubitEntity*>& list, int* err ) 07210 { 07211 *err = iBase_SUCCESS; 07212 switch (ibase_type) { 07213 case iBase_ALL_TYPES: return list.size() - count_type<RefGroup>(list); 07214 case iBase_REGION: return count_type<Body>(list); 07215 case iBase_FACE: return count_type<RefFace>(list); 07216 case iBase_EDGE: return count_type<RefEdge>(list); 07217 case iBase_VERTEX: return count_type<RefVertex>(list); 07218 default: 07219 *err = iBase_INVALID_ENTITY_TYPE; 07220 CGM_iGeom_setLastError( *err ); 07221 return -1; 07222 } 07223 } 07224 07225 template <typename TARGET_TYPE, typename LIST_TYPE> static inline 07226 void append_type( const DLIList<CubitEntity*>& source_list, 07227 DLIList<LIST_TYPE*>& target_list ) 07228 { 07229 int size = source_list.size(); 07230 for (int i = 0; i < size; ++i) 07231 if (TARGET_TYPE* ent = dynamic_cast<TARGET_TYPE*>(source_list[i])) 07232 target_list.append(ent); 07233 } 07234 07235 template <typename SKIP_TYPE, typename LIST_TYPE> static inline 07236 void append_not_type( const DLIList<CubitEntity*>& source_list, 07237 DLIList<LIST_TYPE*>& target_list ) 07238 { 07239 int size = source_list.size(); 07240 for (int i = 0; i < size; ++i) 07241 if (!dynamic_cast<SKIP_TYPE*>(source_list[i])) 07242 if (RefEntity* ent = dynamic_cast<LIST_TYPE*>(source_list[i])) 07243 target_list.append(ent); 07244 } 07245 07246 // Returns count of entities appended. 07247 template <typename TARGET_TYPE> static inline 07248 int append_type( const DLIList<CubitEntity*>& source_list, 07249 iBase_EntityHandle* array, int array_size ) 07250 { 07251 RefEntity* re_ptr; 07252 int len = source_list.size(); 07253 int count = 0; 07254 for (int i = 0; i < len; ++i) { 07255 if (TARGET_TYPE* ent = dynamic_cast<TARGET_TYPE*>(source_list[i])) { 07256 if (count < array_size) 07257 array[count] = reinterpret_cast<iBase_EntityHandle>(re_ptr = ent); 07258 ++count; 07259 } 07260 } 07261 return count; 07262 } 07263 07264 template <typename SKIP_TYPE> static inline 07265 int append_not_type( const DLIList<CubitEntity*>& source_list, 07266 iBase_EntityHandle* array, int array_size ) 07267 { 07268 int len = source_list.size(); 07269 int count = 0; 07270 for (int i = 0; i < len; ++i) { 07271 if (!dynamic_cast<SKIP_TYPE*>(source_list[i])) { 07272 if (count == array_size) 07273 return -1; 07274 else if (RefEntity* ent = dynamic_cast<RefEntity*>(source_list[i])) 07275 array[count++] = reinterpret_cast<iBase_EntityHandle>(ent); 07276 } 07277 } 07278 return count; 07279 } 07280 07281 static 07282 void copy_ibase_type( int ibase_type, 07283 const DLIList<CubitEntity*>& list, 07284 iBase_EntityHandle** entity_handles, 07285 int* entity_handles_alloc, 07286 int* entity_handles_size, 07287 int* err ) 07288 { 07289 int count; 07290 if (*entity_handles_alloc == 0) { 07291 count = count_ibase_type( ibase_type, list, err ); 07292 if (count < 0) 07293 return; 07294 *entity_handles = (iBase_EntityHandle*)malloc( count * sizeof(iBase_EntityHandle) ); 07295 if (!*entity_handles) 07296 RETURN(iBase_MEMORY_ALLOCATION_FAILED); 07297 *entity_handles_alloc = count; 07298 } 07299 07300 switch (ibase_type) { 07301 case iBase_ALL_TYPES: 07302 count = append_not_type<RefGroup>(list,*entity_handles, *entity_handles_alloc); 07303 break; 07304 case iBase_REGION: 07305 count = append_type<Body>(list,*entity_handles, *entity_handles_alloc); 07306 break; 07307 case iBase_FACE: 07308 count = append_type<RefFace>(list,*entity_handles, *entity_handles_alloc); 07309 break; 07310 case iBase_EDGE: 07311 count = append_type<RefEdge>(list,*entity_handles, *entity_handles_alloc); 07312 break; 07313 case iBase_VERTEX: 07314 count = append_type<RefVertex>(list,*entity_handles, *entity_handles_alloc); 07315 break; 07316 default: 07317 RETURN(iBase_INVALID_ENTITY_TYPE); 07318 break; 07319 } 07320 07321 *entity_handles_size = count; 07322 if (count > *entity_handles_alloc) 07323 RETURN(iBase_BAD_ARRAY_DIMENSION); 07324 07325 RETURN(iBase_SUCCESS); 07326 } 07327 07328 static 07329 void append_ibase_type( int ibase_type, 07330 const DLIList<CubitEntity*>& source_list, 07331 DLIList<RefEntity*>& target_list, 07332 int* err ) 07333 { 07334 switch (ibase_type) { 07335 case iBase_ALL_TYPES: 07336 append_not_type<RefGroup>(source_list, target_list); 07337 break; 07338 case iBase_REGION: 07339 append_type<Body>(source_list, target_list); 07340 break; 07341 case iBase_FACE: 07342 append_type<RefFace>(source_list, target_list); 07343 break; 07344 case iBase_EDGE: 07345 append_type<RefEdge>(source_list, target_list); 07346 break; 07347 case iBase_VERTEX: 07348 append_type<RefVertex>(source_list, target_list); 07349 break; 07350 default: 07351 RETURN(iBase_INVALID_ENTITY_TYPE); 07352 break; 07353 } 07354 07355 RETURN(iBase_SUCCESS); 07356 } 07357 07358 static 07359 void append_all_ibase_type( int ibase_type, 07360 DLIList<RefEntity*>& target_list, 07361 int* err ) 07362 { 07363 RefEntityFactory *const ref = RefEntityFactory::instance(); 07364 if (ibase_type == iBase_ALL_TYPES) { 07365 for (int i = 0; i < 4; ++i) { 07366 DLIList<RefEntity*> tmp; 07367 ref->ref_entity_list( iGeom_entity_type_names[i], tmp ); 07368 target_list += tmp; 07369 } 07370 } 07371 else if (abs(ibase_type) < iBase_ALL_TYPES) { 07372 ref->ref_entity_list( iGeom_entity_type_names[ibase_type], target_list ); 07373 } 07374 else { 07375 RETURN(iBase_INVALID_ENTITY_TYPE); 07376 } 07377 07378 RETURN(iBase_SUCCESS); 07379 } 07380 07381 void iGeom_getFacets(iGeom_Instance instance, 07382 iBase_EntityHandle entity, 07383 double dist_tolerance, 07384 double **points, int *points_allocated, int *points_size, 07385 int **facets, int *facets_allocated, int *facets_size, 07386 int *err) 07387 { 07388 GMem gMem; 07389 CubitStatus resl = CUBIT_SUCCESS; 07390 RefFace *ref_face = dynamic_cast<RefFace*>(ENTITY_HANDLE(entity)); 07391 if(ref_face) 07392 resl = ref_face->get_graphics(gMem, 15, dist_tolerance); 07393 07394 RefEdge *ref_edge = dynamic_cast<RefEdge*>(ENTITY_HANDLE(entity)); 07395 if(ref_edge) 07396 resl = ref_edge->get_graphics(gMem, 15, dist_tolerance); 07397 07398 if(resl == CUBIT_FAILURE) 07399 ERROR(iBase_FAILURE, "Can't get facets for this entity."); 07400 07401 if(ref_face || ref_edge) 07402 { 07403 int p_count = gMem.point_list_size(); 07404 int f_count = gMem.facet_list_size(); 07405 if(p_count) 07406 { 07407 ALLOC_CHECK_ARRAY_NOFAIL(points, p_count * 3); 07408 GPoint* gpoints = gMem.point_list(); 07409 double *x, *y, *z; 07410 x = *points; 07411 y = x + 1; 07412 z = x + 2; 07413 size_t step = 3; 07414 for(int i = 0; i < p_count; i++) 07415 { 07416 GPoint pt = gpoints[i]; 07417 *x = pt.x; 07418 *y = pt.y; 07419 *z = pt.z; 07420 x += step; 07421 y += step; 07422 z += step; 07423 } 07424 } 07425 if(f_count) 07426 { 07427 //return all the triangles. Current gMem gives 4*triangle facets which 07428 //includes a '3' for each facet set to indicate there are 3 nodes on 07429 //the tessilation. Here trying to ignore the '3'. 07430 ALLOC_CHECK_ARRAY_NOFAIL(facets, f_count*3/4); 07431 int *connectivity; 07432 connectivity = *facets; 07433 int* list = gMem.facet_list(); 07434 for (int i = 0; i < f_count/4; i++) 07435 { 07436 *connectivity = list[i*4 + 1]; 07437 *(connectivity + 1) = list[i*4 + 2]; 07438 *(connectivity + 2) = list[i*4 + 3]; 07439 connectivity += 3; 07440 } 07441 } 07442 RETURN(iBase_SUCCESS); 07443 } 07444 else 07445 RETURN(iBase_INVALID_ENTITY_TYPE); 07446 } 07447
