MeshKit
1.0
External dependencies: CGM --with a geometry engine
Input: AssyGen input file
Output: Assembly geometry file (.sat or .stp) and Cubit meshing scripts for meshing this assembly
Interface(s) used: iGeom
Setup:
Need to call PrepareIO with with command line arguments to input the AssyGen input file.
Notes:
Default test file case: test/algs/test_assygen.cpp uses input file: data/assygen_default.inp. To run other AssyGen input files using the program use executable 'test_assygen' in 'MeshKit/test/algs' folder; specying the filename:- 'Your Dir> test_assygen s1' where, s1.inp is the AssyGen input file. See paper: http://link.springer.com/chapter/10.1007/978-3-642-15414-0_21
