MeshKit
1.0
External dependencies: Mesquite (http://www.cs.sandia.gov/optimization/knupp/Mesquite.html)
Input: 2D or 3D ModelEnts, already meshed
Output: The input mesh with vertex positions adjusted in improve mesh quality
Interface(s) used: MOAB, iMesh, iGeom, Mesquite
Setup:
None required. Default is to run ShapeImprovementWraper (or ShapeImprover depending on the version of Mesquite) with the mesh boundary fixed.
smooth_with_free_boundary() can be called to change to a "free" smooth, where vertices on the boundary of the mesh may also be moved. This option requires child geomery defining the boundary (with the obvious exception of smoothing a surface that is a topological sphere) so that the optimization problem is properly constrained.
set_mesh_op() may be called to specify an alogithm other than the default shape improver to run.
