MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2008-2014 Gael Guennebaud <[email protected]> 00005 // 00006 // This Source Code Form is subject to the terms of the Mozilla 00007 // Public License v. 2.0. If a copy of the MPL was not distributed 00008 // with this file, You can obtain one at http://mozilla.org/MPL/2.0/. 00009 00010 #ifndef EIGEN_SPARSE_BLOCK_H 00011 #define EIGEN_SPARSE_BLOCK_H 00012 00013 namespace Eigen { 00014 00015 // Subset of columns or rows 00016 template<typename XprType, int BlockRows, int BlockCols> 00017 class BlockImpl<XprType,BlockRows,BlockCols,true,Sparse> 00018 : public SparseMatrixBase<Block<XprType,BlockRows,BlockCols,true> > 00019 { 00020 typedef typename internal::remove_all<typename XprType::Nested>::type _MatrixTypeNested; 00021 typedef Block<XprType, BlockRows, BlockCols, true> BlockType; 00022 public: 00023 enum { IsRowMajor = internal::traits<BlockType>::IsRowMajor }; 00024 protected: 00025 enum { OuterSize = IsRowMajor ? BlockRows : BlockCols }; 00026 typedef SparseMatrixBase<BlockType> Base; 00027 using Base::convert_index; 00028 public: 00029 EIGEN_SPARSE_PUBLIC_INTERFACE(BlockType) 00030 00031 inline BlockImpl(XprType& xpr, Index i) 00032 : m_matrix(xpr), m_outerStart(convert_index(i)), m_outerSize(OuterSize) 00033 {} 00034 00035 inline BlockImpl(XprType& xpr, Index startRow, Index startCol, Index blockRows, Index blockCols) 00036 : m_matrix(xpr), m_outerStart(convert_index(IsRowMajor ? startRow : startCol)), m_outerSize(convert_index(IsRowMajor ? blockRows : blockCols)) 00037 {} 00038 00039 EIGEN_STRONG_INLINE Index rows() const { return IsRowMajor ? m_outerSize.value() : m_matrix.rows(); } 00040 EIGEN_STRONG_INLINE Index cols() const { return IsRowMajor ? m_matrix.cols() : m_outerSize.value(); } 00041 00042 Index nonZeros() const 00043 { 00044 typedef internal::evaluator<XprType> EvaluatorType; 00045 EvaluatorType matEval(m_matrix); 00046 Index nnz = 0; 00047 Index end = m_outerStart + m_outerSize.value(); 00048 for(Index j=m_outerStart; j<end; ++j) 00049 for(typename EvaluatorType::InnerIterator it(matEval, j); it; ++it) 00050 ++nnz; 00051 return nnz; 00052 } 00053 00054 inline const Scalar coeff(Index row, Index col) const 00055 { 00056 return m_matrix.coeff(row + (IsRowMajor ? m_outerStart : 0), col + (IsRowMajor ? 0 : m_outerStart)); 00057 } 00058 00059 inline const Scalar coeff(Index index) const 00060 { 00061 return m_matrix.coeff(IsRowMajor ? m_outerStart : index, IsRowMajor ? index : m_outerStart); 00062 } 00063 00064 inline const XprType& nestedExpression() const { return m_matrix; } 00065 inline XprType& nestedExpression() { return m_matrix; } 00066 Index startRow() const { return IsRowMajor ? m_outerStart : 0; } 00067 Index startCol() const { return IsRowMajor ? 0 : m_outerStart; } 00068 Index blockRows() const { return IsRowMajor ? m_outerSize.value() : m_matrix.rows(); } 00069 Index blockCols() const { return IsRowMajor ? m_matrix.cols() : m_outerSize.value(); } 00070 00071 protected: 00072 00073 typename internal::ref_selector<XprType>::non_const_type m_matrix; 00074 Index m_outerStart; 00075 const internal::variable_if_dynamic<Index, OuterSize> m_outerSize; 00076 00077 protected: 00078 // Disable assignment with clear error message. 00079 // Note that simply removing operator= yields compilation errors with ICC+MSVC 00080 template<typename T> 00081 BlockImpl& operator=(const T&) 00082 { 00083 EIGEN_STATIC_ASSERT(sizeof(T)==0, THIS_SPARSE_BLOCK_SUBEXPRESSION_IS_READ_ONLY); 00084 return *this; 00085 } 00086 }; 00087 00088 00089 /*************************************************************************** 00090 * specialization for SparseMatrix 00091 ***************************************************************************/ 00092 00093 namespace internal { 00094 00095 template<typename SparseMatrixType, int BlockRows, int BlockCols> 00096 class sparse_matrix_block_impl 00097 : public SparseCompressedBase<Block<SparseMatrixType,BlockRows,BlockCols,true> > 00098 { 00099 typedef typename internal::remove_all<typename SparseMatrixType::Nested>::type _MatrixTypeNested; 00100 typedef Block<SparseMatrixType, BlockRows, BlockCols, true> BlockType; 00101 typedef SparseCompressedBase<Block<SparseMatrixType,BlockRows,BlockCols,true> > Base; 00102 using Base::convert_index; 00103 public: 00104 enum { IsRowMajor = internal::traits<BlockType>::IsRowMajor }; 00105 EIGEN_SPARSE_PUBLIC_INTERFACE(BlockType) 00106 protected: 00107 typedef typename Base::IndexVector IndexVector; 00108 enum { OuterSize = IsRowMajor ? BlockRows : BlockCols }; 00109 public: 00110 00111 inline sparse_matrix_block_impl(SparseMatrixType& xpr, Index i) 00112 : m_matrix(xpr), m_outerStart(convert_index(i)), m_outerSize(OuterSize) 00113 {} 00114 00115 inline sparse_matrix_block_impl(SparseMatrixType& xpr, Index startRow, Index startCol, Index blockRows, Index blockCols) 00116 : m_matrix(xpr), m_outerStart(convert_index(IsRowMajor ? startRow : startCol)), m_outerSize(convert_index(IsRowMajor ? blockRows : blockCols)) 00117 {} 00118 00119 template<typename OtherDerived> 00120 inline BlockType& operator=(const SparseMatrixBase<OtherDerived>& other) 00121 { 00122 typedef typename internal::remove_all<typename SparseMatrixType::Nested>::type _NestedMatrixType; 00123 _NestedMatrixType& matrix = m_matrix; 00124 // This assignment is slow if this vector set is not empty 00125 // and/or it is not at the end of the nonzeros of the underlying matrix. 00126 00127 // 1 - eval to a temporary to avoid transposition and/or aliasing issues 00128 Ref<const SparseMatrix<Scalar, IsRowMajor ? RowMajor : ColMajor, StorageIndex> > tmp(other.derived()); 00129 eigen_internal_assert(tmp.outerSize()==m_outerSize.value()); 00130 00131 // 2 - let's check whether there is enough allocated memory 00132 Index nnz = tmp.nonZeros(); 00133 Index start = m_outerStart==0 ? 0 : matrix.outerIndexPtr()[m_outerStart]; // starting position of the current block 00134 Index end = m_matrix.outerIndexPtr()[m_outerStart+m_outerSize.value()]; // ending position of the current block 00135 Index block_size = end - start; // available room in the current block 00136 Index tail_size = m_matrix.outerIndexPtr()[m_matrix.outerSize()] - end; 00137 00138 Index free_size = m_matrix.isCompressed() 00139 ? Index(matrix.data().allocatedSize()) + block_size 00140 : block_size; 00141 00142 bool update_trailing_pointers = false; 00143 if(nnz>free_size) 00144 { 00145 // realloc manually to reduce copies 00146 typename SparseMatrixType::Storage newdata(m_matrix.data().allocatedSize() - block_size + nnz); 00147 00148 internal::smart_copy(m_matrix.valuePtr(), m_matrix.valuePtr() + start, newdata.valuePtr()); 00149 internal::smart_copy(m_matrix.innerIndexPtr(), m_matrix.innerIndexPtr() + start, newdata.indexPtr()); 00150 00151 internal::smart_copy(tmp.valuePtr(), tmp.valuePtr() + nnz, newdata.valuePtr() + start); 00152 internal::smart_copy(tmp.innerIndexPtr(), tmp.innerIndexPtr() + nnz, newdata.indexPtr() + start); 00153 00154 internal::smart_copy(matrix.valuePtr()+end, matrix.valuePtr()+end + tail_size, newdata.valuePtr()+start+nnz); 00155 internal::smart_copy(matrix.innerIndexPtr()+end, matrix.innerIndexPtr()+end + tail_size, newdata.indexPtr()+start+nnz); 00156 00157 newdata.resize(m_matrix.outerIndexPtr()[m_matrix.outerSize()] - block_size + nnz); 00158 00159 matrix.data().swap(newdata); 00160 00161 update_trailing_pointers = true; 00162 } 00163 else 00164 { 00165 if(m_matrix.isCompressed()) 00166 { 00167 // no need to realloc, simply copy the tail at its respective position and insert tmp 00168 matrix.data().resize(start + nnz + tail_size); 00169 00170 internal::smart_memmove(matrix.valuePtr()+end, matrix.valuePtr() + end+tail_size, matrix.valuePtr() + start+nnz); 00171 internal::smart_memmove(matrix.innerIndexPtr()+end, matrix.innerIndexPtr() + end+tail_size, matrix.innerIndexPtr() + start+nnz); 00172 00173 update_trailing_pointers = true; 00174 } 00175 00176 internal::smart_copy(tmp.valuePtr(), tmp.valuePtr() + nnz, matrix.valuePtr() + start); 00177 internal::smart_copy(tmp.innerIndexPtr(), tmp.innerIndexPtr() + nnz, matrix.innerIndexPtr() + start); 00178 } 00179 00180 // update outer index pointers and innerNonZeros 00181 if(IsVectorAtCompileTime) 00182 { 00183 if(!m_matrix.isCompressed()) 00184 matrix.innerNonZeroPtr()[m_outerStart] = StorageIndex(nnz); 00185 matrix.outerIndexPtr()[m_outerStart] = StorageIndex(start); 00186 } 00187 else 00188 { 00189 StorageIndex p = StorageIndex(start); 00190 for(Index k=0; k<m_outerSize.value(); ++k) 00191 { 00192 Index nnz_k = tmp.innerVector(k).nonZeros(); 00193 if(!m_matrix.isCompressed()) 00194 matrix.innerNonZeroPtr()[m_outerStart+k] = StorageIndex(nnz_k); 00195 matrix.outerIndexPtr()[m_outerStart+k] = p; 00196 p += nnz_k; 00197 } 00198 } 00199 00200 if(update_trailing_pointers) 00201 { 00202 StorageIndex offset = internal::convert_index<StorageIndex>(nnz - block_size); 00203 for(Index k = m_outerStart + m_outerSize.value(); k<=matrix.outerSize(); ++k) 00204 { 00205 matrix.outerIndexPtr()[k] += offset; 00206 } 00207 } 00208 00209 return derived(); 00210 } 00211 00212 inline BlockType& operator=(const BlockType& other) 00213 { 00214 return operator=<BlockType>(other); 00215 } 00216 00217 inline const Scalar* valuePtr() const 00218 { return m_matrix.valuePtr(); } 00219 inline Scalar* valuePtr() 00220 { return m_matrix.valuePtr(); } 00221 00222 inline const StorageIndex* innerIndexPtr() const 00223 { return m_matrix.innerIndexPtr(); } 00224 inline StorageIndex* innerIndexPtr() 00225 { return m_matrix.innerIndexPtr(); } 00226 00227 inline const StorageIndex* outerIndexPtr() const 00228 { return m_matrix.outerIndexPtr() + m_outerStart; } 00229 inline StorageIndex* outerIndexPtr() 00230 { return m_matrix.outerIndexPtr() + m_outerStart; } 00231 00232 inline const StorageIndex* innerNonZeroPtr() const 00233 { return isCompressed() ? 0 : (m_matrix.innerNonZeroPtr()+m_outerStart); } 00234 inline StorageIndex* innerNonZeroPtr() 00235 { return isCompressed() ? 0 : (m_matrix.innerNonZeroPtr()+m_outerStart); } 00236 00237 bool isCompressed() const { return m_matrix.innerNonZeroPtr()==0; } 00238 00239 inline Scalar& coeffRef(Index row, Index col) 00240 { 00241 return m_matrix.coeffRef(row + (IsRowMajor ? m_outerStart : 0), col + (IsRowMajor ? 0 : m_outerStart)); 00242 } 00243 00244 inline const Scalar coeff(Index row, Index col) const 00245 { 00246 return m_matrix.coeff(row + (IsRowMajor ? m_outerStart : 0), col + (IsRowMajor ? 0 : m_outerStart)); 00247 } 00248 00249 inline const Scalar coeff(Index index) const 00250 { 00251 return m_matrix.coeff(IsRowMajor ? m_outerStart : index, IsRowMajor ? index : m_outerStart); 00252 } 00253 00254 const Scalar& lastCoeff() const 00255 { 00256 EIGEN_STATIC_ASSERT_VECTOR_ONLY(sparse_matrix_block_impl); 00257 eigen_assert(Base::nonZeros()>0); 00258 if(m_matrix.isCompressed()) 00259 return m_matrix.valuePtr()[m_matrix.outerIndexPtr()[m_outerStart+1]-1]; 00260 else 00261 return m_matrix.valuePtr()[m_matrix.outerIndexPtr()[m_outerStart]+m_matrix.innerNonZeroPtr()[m_outerStart]-1]; 00262 } 00263 00264 EIGEN_STRONG_INLINE Index rows() const { return IsRowMajor ? m_outerSize.value() : m_matrix.rows(); } 00265 EIGEN_STRONG_INLINE Index cols() const { return IsRowMajor ? m_matrix.cols() : m_outerSize.value(); } 00266 00267 inline const SparseMatrixType& nestedExpression() const { return m_matrix; } 00268 inline SparseMatrixType& nestedExpression() { return m_matrix; } 00269 Index startRow() const { return IsRowMajor ? m_outerStart : 0; } 00270 Index startCol() const { return IsRowMajor ? 0 : m_outerStart; } 00271 Index blockRows() const { return IsRowMajor ? m_outerSize.value() : m_matrix.rows(); } 00272 Index blockCols() const { return IsRowMajor ? m_matrix.cols() : m_outerSize.value(); } 00273 00274 protected: 00275 00276 typename internal::ref_selector<SparseMatrixType>::non_const_type m_matrix; 00277 Index m_outerStart; 00278 const internal::variable_if_dynamic<Index, OuterSize> m_outerSize; 00279 00280 }; 00281 00282 } // namespace internal 00283 00284 template<typename _Scalar, int _Options, typename _StorageIndex, int BlockRows, int BlockCols> 00285 class BlockImpl<SparseMatrix<_Scalar, _Options, _StorageIndex>,BlockRows,BlockCols,true,Sparse> 00286 : public internal::sparse_matrix_block_impl<SparseMatrix<_Scalar, _Options, _StorageIndex>,BlockRows,BlockCols> 00287 { 00288 public: 00289 typedef _StorageIndex StorageIndex; 00290 typedef SparseMatrix<_Scalar, _Options, _StorageIndex> SparseMatrixType; 00291 typedef internal::sparse_matrix_block_impl<SparseMatrixType,BlockRows,BlockCols> Base; 00292 inline BlockImpl(SparseMatrixType& xpr, Index i) 00293 : Base(xpr, i) 00294 {} 00295 00296 inline BlockImpl(SparseMatrixType& xpr, Index startRow, Index startCol, Index blockRows, Index blockCols) 00297 : Base(xpr, startRow, startCol, blockRows, blockCols) 00298 {} 00299 00300 using Base::operator=; 00301 }; 00302 00303 template<typename _Scalar, int _Options, typename _StorageIndex, int BlockRows, int BlockCols> 00304 class BlockImpl<const SparseMatrix<_Scalar, _Options, _StorageIndex>,BlockRows,BlockCols,true,Sparse> 00305 : public internal::sparse_matrix_block_impl<const SparseMatrix<_Scalar, _Options, _StorageIndex>,BlockRows,BlockCols> 00306 { 00307 public: 00308 typedef _StorageIndex StorageIndex; 00309 typedef const SparseMatrix<_Scalar, _Options, _StorageIndex> SparseMatrixType; 00310 typedef internal::sparse_matrix_block_impl<SparseMatrixType,BlockRows,BlockCols> Base; 00311 inline BlockImpl(SparseMatrixType& xpr, Index i) 00312 : Base(xpr, i) 00313 {} 00314 00315 inline BlockImpl(SparseMatrixType& xpr, Index startRow, Index startCol, Index blockRows, Index blockCols) 00316 : Base(xpr, startRow, startCol, blockRows, blockCols) 00317 {} 00318 00319 using Base::operator=; 00320 private: 00321 template<typename Derived> BlockImpl(const SparseMatrixBase<Derived>& xpr, Index i); 00322 template<typename Derived> BlockImpl(const SparseMatrixBase<Derived>& xpr); 00323 }; 00324 00325 //---------- 00326 00330 template<typename Derived> 00331 typename SparseMatrixBase<Derived>::InnerVectorReturnType SparseMatrixBase<Derived>::innerVector(Index outer) 00332 { return InnerVectorReturnType(derived(), outer); } 00333 00337 template<typename Derived> 00338 const typename SparseMatrixBase<Derived>::ConstInnerVectorReturnType SparseMatrixBase<Derived>::innerVector(Index outer) const 00339 { return ConstInnerVectorReturnType(derived(), outer); } 00340 00344 template<typename Derived> 00345 typename SparseMatrixBase<Derived>::InnerVectorsReturnType 00346 SparseMatrixBase<Derived>::innerVectors(Index outerStart, Index outerSize) 00347 { 00348 return Block<Derived,Dynamic,Dynamic,true>(derived(), 00349 IsRowMajor ? outerStart : 0, IsRowMajor ? 0 : outerStart, 00350 IsRowMajor ? outerSize : rows(), IsRowMajor ? cols() : outerSize); 00351 00352 } 00353 00357 template<typename Derived> 00358 const typename SparseMatrixBase<Derived>::ConstInnerVectorsReturnType 00359 SparseMatrixBase<Derived>::innerVectors(Index outerStart, Index outerSize) const 00360 { 00361 return Block<const Derived,Dynamic,Dynamic,true>(derived(), 00362 IsRowMajor ? outerStart : 0, IsRowMajor ? 0 : outerStart, 00363 IsRowMajor ? outerSize : rows(), IsRowMajor ? cols() : outerSize); 00364 00365 } 00366 00370 template<typename XprType, int BlockRows, int BlockCols, bool InnerPanel> 00371 class BlockImpl<XprType,BlockRows,BlockCols,InnerPanel,Sparse> 00372 : public SparseMatrixBase<Block<XprType,BlockRows,BlockCols,InnerPanel> >, internal::no_assignment_operator 00373 { 00374 typedef Block<XprType, BlockRows, BlockCols, InnerPanel> BlockType; 00375 typedef SparseMatrixBase<BlockType> Base; 00376 using Base::convert_index; 00377 public: 00378 enum { IsRowMajor = internal::traits<BlockType>::IsRowMajor }; 00379 EIGEN_SPARSE_PUBLIC_INTERFACE(BlockType) 00380 00381 typedef typename internal::remove_all<typename XprType::Nested>::type _MatrixTypeNested; 00382 00385 inline BlockImpl(XprType& xpr, Index i) 00386 : m_matrix(xpr), 00387 m_startRow( (BlockRows==1) && (BlockCols==XprType::ColsAtCompileTime) ? convert_index(i) : 0), 00388 m_startCol( (BlockRows==XprType::RowsAtCompileTime) && (BlockCols==1) ? convert_index(i) : 0), 00389 m_blockRows(BlockRows==1 ? 1 : xpr.rows()), 00390 m_blockCols(BlockCols==1 ? 1 : xpr.cols()) 00391 {} 00392 00395 inline BlockImpl(XprType& xpr, Index startRow, Index startCol, Index blockRows, Index blockCols) 00396 : m_matrix(xpr), m_startRow(convert_index(startRow)), m_startCol(convert_index(startCol)), m_blockRows(convert_index(blockRows)), m_blockCols(convert_index(blockCols)) 00397 {} 00398 00399 inline Index rows() const { return m_blockRows.value(); } 00400 inline Index cols() const { return m_blockCols.value(); } 00401 00402 inline Scalar& coeffRef(Index row, Index col) 00403 { 00404 return m_matrix.coeffRef(row + m_startRow.value(), col + m_startCol.value()); 00405 } 00406 00407 inline const Scalar coeff(Index row, Index col) const 00408 { 00409 return m_matrix.coeff(row + m_startRow.value(), col + m_startCol.value()); 00410 } 00411 00412 inline Scalar& coeffRef(Index index) 00413 { 00414 return m_matrix.coeffRef(m_startRow.value() + (RowsAtCompileTime == 1 ? 0 : index), 00415 m_startCol.value() + (RowsAtCompileTime == 1 ? index : 0)); 00416 } 00417 00418 inline const Scalar coeff(Index index) const 00419 { 00420 return m_matrix.coeff(m_startRow.value() + (RowsAtCompileTime == 1 ? 0 : index), 00421 m_startCol.value() + (RowsAtCompileTime == 1 ? index : 0)); 00422 } 00423 00424 inline const XprType& nestedExpression() const { return m_matrix; } 00425 inline XprType& nestedExpression() { return m_matrix; } 00426 Index startRow() const { return m_startRow.value(); } 00427 Index startCol() const { return m_startCol.value(); } 00428 Index blockRows() const { return m_blockRows.value(); } 00429 Index blockCols() const { return m_blockCols.value(); } 00430 00431 protected: 00432 // friend class internal::GenericSparseBlockInnerIteratorImpl<XprType,BlockRows,BlockCols,InnerPanel>; 00433 friend class ReverseInnerIterator; 00434 friend struct internal::unary_evaluator<Block<XprType,BlockRows,BlockCols,InnerPanel>, internal::IteratorBased, Scalar >; 00435 00436 Index nonZeros() const { return Dynamic; } 00437 00438 typename internal::ref_selector<XprType>::non_const_type m_matrix; 00439 const internal::variable_if_dynamic<Index, XprType::RowsAtCompileTime == 1 ? 0 : Dynamic> m_startRow; 00440 const internal::variable_if_dynamic<Index, XprType::ColsAtCompileTime == 1 ? 0 : Dynamic> m_startCol; 00441 const internal::variable_if_dynamic<Index, RowsAtCompileTime> m_blockRows; 00442 const internal::variable_if_dynamic<Index, ColsAtCompileTime> m_blockCols; 00443 00444 protected: 00445 // Disable assignment with clear error message. 00446 // Note that simply removing operator= yields compilation errors with ICC+MSVC 00447 template<typename T> 00448 BlockImpl& operator=(const T&) 00449 { 00450 EIGEN_STATIC_ASSERT(sizeof(T)==0, THIS_SPARSE_BLOCK_SUBEXPRESSION_IS_READ_ONLY); 00451 return *this; 00452 } 00453 00454 }; 00455 00456 namespace internal { 00457 00458 template<typename ArgType, int BlockRows, int BlockCols, bool InnerPanel> 00459 struct unary_evaluator<Block<ArgType,BlockRows,BlockCols,InnerPanel>, IteratorBased > 00460 : public evaluator_base<Block<ArgType,BlockRows,BlockCols,InnerPanel> > 00461 { 00462 class InnerVectorInnerIterator; 00463 class OuterVectorInnerIterator; 00464 public: 00465 typedef Block<ArgType,BlockRows,BlockCols,InnerPanel> XprType; 00466 typedef typename XprType::StorageIndex StorageIndex; 00467 typedef typename XprType::Scalar Scalar; 00468 00469 class ReverseInnerIterator; 00470 00471 enum { 00472 IsRowMajor = XprType::IsRowMajor, 00473 00474 OuterVector = (BlockCols==1 && ArgType::IsRowMajor) 00475 | // FIXME | instead of || to please GCC 4.4.0 stupid warning "suggest parentheses around &&". 00476 // revert to || as soon as not needed anymore. 00477 (BlockRows==1 && !ArgType::IsRowMajor), 00478 00479 CoeffReadCost = evaluator<ArgType>::CoeffReadCost, 00480 Flags = XprType::Flags 00481 }; 00482 00483 typedef typename internal::conditional<OuterVector,OuterVectorInnerIterator,InnerVectorInnerIterator>::type InnerIterator; 00484 00485 explicit unary_evaluator(const XprType& op) 00486 : m_argImpl(op.nestedExpression()), m_block(op) 00487 {} 00488 00489 inline Index nonZerosEstimate() const { 00490 Index nnz = m_block.nonZeros(); 00491 if(nnz<0) 00492 return m_argImpl.nonZerosEstimate() * m_block.size() / m_block.nestedExpression().size(); 00493 return nnz; 00494 } 00495 00496 protected: 00497 typedef typename evaluator<ArgType>::InnerIterator EvalIterator; 00498 00499 evaluator<ArgType> m_argImpl; 00500 const XprType &m_block; 00501 }; 00502 00503 template<typename ArgType, int BlockRows, int BlockCols, bool InnerPanel> 00504 class unary_evaluator<Block<ArgType,BlockRows,BlockCols,InnerPanel>, IteratorBased>::InnerVectorInnerIterator 00505 : public EvalIterator 00506 { 00507 const XprType& m_block; 00508 Index m_end; 00509 public: 00510 00511 EIGEN_STRONG_INLINE InnerVectorInnerIterator(const unary_evaluator& aEval, Index outer) 00512 : EvalIterator(aEval.m_argImpl, outer + (IsRowMajor ? aEval.m_block.startRow() : aEval.m_block.startCol())), 00513 m_block(aEval.m_block), 00514 m_end(IsRowMajor ? aEval.m_block.startCol()+aEval.m_block.blockCols() : aEval.m_block.startRow()+aEval.m_block.blockRows()) 00515 { 00516 while( (EvalIterator::operator bool()) && (EvalIterator::index() < (IsRowMajor ? m_block.startCol() : m_block.startRow())) ) 00517 EvalIterator::operator++(); 00518 } 00519 00520 inline StorageIndex index() const { return EvalIterator::index() - convert_index<StorageIndex>(IsRowMajor ? m_block.startCol() : m_block.startRow()); } 00521 inline Index outer() const { return EvalIterator::outer() - (IsRowMajor ? m_block.startRow() : m_block.startCol()); } 00522 inline Index row() const { return EvalIterator::row() - m_block.startRow(); } 00523 inline Index col() const { return EvalIterator::col() - m_block.startCol(); } 00524 00525 inline operator bool() const { return EvalIterator::operator bool() && EvalIterator::index() < m_end; } 00526 }; 00527 00528 template<typename ArgType, int BlockRows, int BlockCols, bool InnerPanel> 00529 class unary_evaluator<Block<ArgType,BlockRows,BlockCols,InnerPanel>, IteratorBased>::OuterVectorInnerIterator 00530 { 00531 const unary_evaluator& m_eval; 00532 Index m_outerPos; 00533 Index m_innerIndex; 00534 Scalar m_value; 00535 Index m_end; 00536 public: 00537 00538 EIGEN_STRONG_INLINE OuterVectorInnerIterator(const unary_evaluator& aEval, Index outer) 00539 : m_eval(aEval), 00540 m_outerPos( (IsRowMajor ? aEval.m_block.startCol() : aEval.m_block.startRow()) - 1), // -1 so that operator++ finds the first non-zero entry 00541 m_innerIndex(IsRowMajor ? aEval.m_block.startRow() : aEval.m_block.startCol()), 00542 m_value(0), 00543 m_end(IsRowMajor ? aEval.m_block.startCol()+aEval.m_block.blockCols() : aEval.m_block.startRow()+aEval.m_block.blockRows()) 00544 { 00545 EIGEN_UNUSED_VARIABLE(outer); 00546 eigen_assert(outer==0); 00547 00548 ++(*this); 00549 } 00550 00551 inline StorageIndex index() const { return convert_index<StorageIndex>(m_outerPos - (IsRowMajor ? m_eval.m_block.startCol() : m_eval.m_block.startRow())); } 00552 inline Index outer() const { return 0; } 00553 inline Index row() const { return IsRowMajor ? 0 : index(); } 00554 inline Index col() const { return IsRowMajor ? index() : 0; } 00555 00556 inline Scalar value() const { return m_value; } 00557 00558 inline OuterVectorInnerIterator& operator++() 00559 { 00560 // search next non-zero entry 00561 while(++m_outerPos<m_end) 00562 { 00563 EvalIterator it(m_eval.m_argImpl, m_outerPos); 00564 // search for the key m_innerIndex in the current outer-vector 00565 while(it && it.index() < m_innerIndex) ++it; 00566 if(it && it.index()==m_innerIndex) 00567 { 00568 m_value = it.value(); 00569 break; 00570 } 00571 } 00572 return *this; 00573 } 00574 00575 inline operator bool() const { return m_outerPos < m_end; } 00576 }; 00577 00578 template<typename _Scalar, int _Options, typename _StorageIndex, int BlockRows, int BlockCols> 00579 struct unary_evaluator<Block<SparseMatrix<_Scalar, _Options, _StorageIndex>,BlockRows,BlockCols,true>, IteratorBased> 00580 : evaluator<SparseCompressedBase<Block<SparseMatrix<_Scalar, _Options, _StorageIndex>,BlockRows,BlockCols,true> > > 00581 { 00582 typedef Block<SparseMatrix<_Scalar, _Options, _StorageIndex>,BlockRows,BlockCols,true> XprType; 00583 typedef evaluator<SparseCompressedBase<XprType> > Base; 00584 explicit unary_evaluator(const XprType &xpr) : Base(xpr) {} 00585 }; 00586 00587 template<typename _Scalar, int _Options, typename _StorageIndex, int BlockRows, int BlockCols> 00588 struct unary_evaluator<Block<const SparseMatrix<_Scalar, _Options, _StorageIndex>,BlockRows,BlockCols,true>, IteratorBased> 00589 : evaluator<SparseCompressedBase<Block<const SparseMatrix<_Scalar, _Options, _StorageIndex>,BlockRows,BlockCols,true> > > 00590 { 00591 typedef Block<const SparseMatrix<_Scalar, _Options, _StorageIndex>,BlockRows,BlockCols,true> XprType; 00592 typedef evaluator<SparseCompressedBase<XprType> > Base; 00593 explicit unary_evaluator(const XprType &xpr) : Base(xpr) {} 00594 }; 00595 00596 } // end namespace internal 00597 00598 00599 } // end namespace Eigen 00600 00601 #endif // EIGEN_SPARSE_BLOCK_H
