MOAB: Mesh Oriented datABase
(version 5.2.1)
Public Member Functions | |
BoundedCylinderDomainTest () | |
void | setUp () |
void | tearDown () |
void | test_domain_DoF () |
void | test_z_snap_to () |
void | test_x_snap_to () |
void | test_create_curve_from_mesh () |
Private Member Functions | |
CPPUNIT_TEST_SUITE (BoundedCylinderDomainTest) | |
CPPUNIT_TEST (test_domain_DoF) | |
CPPUNIT_TEST (test_z_snap_to) | |
CPPUNIT_TEST (test_x_snap_to) | |
CPPUNIT_TEST (test_create_curve_from_mesh) | |
CPPUNIT_TEST_SUITE_END () |
Definition at line 17 of file BoundedCylinderDomainTest.cpp.
BoundedCylinderDomainTest::BoundedCylinderDomainTest | ( | ) | [inline] |
Definition at line 28 of file BoundedCylinderDomainTest.cpp.
BoundedCylinderDomainTest::CPPUNIT_TEST | ( | test_domain_DoF | ) | [private] |
BoundedCylinderDomainTest::CPPUNIT_TEST | ( | test_z_snap_to | ) | [private] |
BoundedCylinderDomainTest::CPPUNIT_TEST | ( | test_x_snap_to | ) | [private] |
BoundedCylinderDomainTest::CPPUNIT_TEST_SUITE_END | ( | ) | [private] |
void BoundedCylinderDomainTest::setUp | ( | ) | [inline] |
Definition at line 30 of file BoundedCylinderDomainTest.cpp.
void BoundedCylinderDomainTest::tearDown | ( | ) | [inline] |
Definition at line 31 of file BoundedCylinderDomainTest.cpp.
Definition at line 194 of file BoundedCylinderDomainTest.cpp.
References MBMesquite::arrptr(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::BoundedCylinderDomain::create_curve(), MBMesquite::BoundedCylinderDomain::domain_DoF(), MBMesquite::EPSILON, filename, MBMesquite::MeshImpl::get_all_vertices(), mesh, MBMesquite::MeshImpl::read_vtk(), and MBMesquite::MeshImpl::vertices_get_coordinates().
{ // create the input file to read char filename[] = "BCDTestTMP"; FILE* file = fopen( filename, "w" ); size_t s = fwrite( vtk_file, sizeof( vtk_file ), 1, file ); if( !s ) { remove( filename ); CPPUNIT_ASSERT( s ); } fclose( file ); // read the file into a Mesh object MsqPrintError err( std::cout ); MeshImpl mesh; mesh.read_vtk( filename, err ); remove( filename ); CPPUNIT_ASSERT( !err ); // create a domain such that the four corner vertices // of the 4-quad square mesh lie on the bounding curves // of the cylinder. BoundedCylinderDomain d( 1, Vector3D( 0, 1, 0 ) ); d.create_curve( 1, &mesh, EPSILON, err ); CPPUNIT_ASSERT( !err ); d.create_curve( -1, &mesh, EPSILON, err ); CPPUNIT_ASSERT( !err ); // Get list of vertex coordinates from mesh std::vector< Mesh::VertexHandle > handles; mesh.get_all_vertices( handles, err ); CPPUNIT_ASSERT( !err ); CPPUNIT_ASSERT_EQUAL( handles.size(), (size_t)9 ); std::vector< MsqVertex > vertices( handles.size() ); mesh.vertices_get_coordinates( arrptr( handles ), arrptr( vertices ), handles.size(), err ); CPPUNIT_ASSERT( !err ); // Get the dimension of the geometry each vertex is bound to std::vector< unsigned short > dims( handles.size() ); d.domain_DoF( arrptr( handles ), arrptr( dims ), handles.size(), err ); CPPUNIT_ASSERT( !err ); // Check that the four corner vertices are on the curves // and all others are not for( size_t i = 0; i < handles.size(); ++i ) { if( fabs( vertices[i].x() ) < EPSILON || fabs( vertices[i].y() ) < EPSILON ) CPPUNIT_ASSERT_EQUAL( (unsigned short)2, dims[i] ); else CPPUNIT_ASSERT_EQUAL( (unsigned short)1, dims[i] ); } }
Definition at line 41 of file BoundedCylinderDomainTest.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::BoundedCylinderDomain::create_curve(), and MBMesquite::BoundedCylinderDomain::domain_DoF().
{ MsqError err; const Mesh::EntityHandle list[] = { (void*)5, (void*)9, (void*)1, (void*)2, (void*)3 }; const size_t len = sizeof( list ) / sizeof( list[0] ); BoundedCylinderDomain d( 1000 ); std::vector< Mesh::EntityHandle > handles; std::copy( list, list + len, std::back_inserter( handles ) ); d.create_curve( 10, handles ); const Mesh::EntityHandle list2[] = { (void*)1, (void*)2, (void*)3, (void*)4, (void*)5, (void*)6, (void*)7, (void*)8, (void*)9, (void*)10 }; const size_t len2 = sizeof( list2 ) / sizeof( list2[0] ); unsigned short dof_list[len2]; d.domain_DoF( list2, dof_list, len2, err ); CPPUNIT_ASSERT( !err ); for( size_t i = 0; i < len2; ++i ) { Mesh::EntityHandle handle = list2[i]; const Mesh::EntityHandle* f = std::find( list, list + len, handle ); unsigned short expected_dim = ( f < list + len ) ? 1 : 2; CPPUNIT_ASSERT_EQUAL( expected_dim, dof_list[i] ); } }
Definition at line 119 of file BoundedCylinderDomainTest.cpp.
References ASSERT_VECTORS_EQUAL, center(), CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::BoundedCylinderDomain::create_curve(), MBMesquite::EPSILON, MBMesquite::CylinderDomain::radius(), MBMesquite::Vector3D::set(), MBMesquite::CylinderDomain::snap_to(), MBMesquite::Vector3D::x(), MBMesquite::Vector3D::y(), and MBMesquite::Vector3D::z().
{ const Mesh::EntityHandle HANDLE = 0; const double XPLANE = -3; // Define a circle in the X=-3 plane, centered at (-3,1,1) // with a radius of 1 std::vector< Mesh::EntityHandle > handles( 1 ); handles[0] = HANDLE; BoundedCylinderDomain d( 1, Vector3D( 1, 0, 0 ), Vector3D( 0, 1, 1 ) ); d.create_curve( XPLANE, handles ); Vector3D point, center( -3, 1, 1 ); // try a point inside and below the circle point.set( XPLANE - 2, 1.5, 1.5 ); d.snap_to( HANDLE, point ); CPPUNIT_ASSERT_DOUBLES_EQUAL( XPLANE, point.x(), EPSILON ); CPPUNIT_ASSERT_DOUBLES_EQUAL( point.y(), point.z(), EPSILON ); point -= center; CPPUNIT_ASSERT_DOUBLES_EQUAL( d.radius(), point.length(), EPSILON ); // try a point outside and above the circle point.set( XPLANE + 20, 50, 50 ); d.snap_to( HANDLE, point ); CPPUNIT_ASSERT_DOUBLES_EQUAL( XPLANE, point.x(), EPSILON ); CPPUNIT_ASSERT_DOUBLES_EQUAL( point.y(), point.z(), EPSILON ); point -= center; CPPUNIT_ASSERT_DOUBLES_EQUAL( d.radius(), point.length(), EPSILON ); // try a point on the circle Vector3D on_circ( XPLANE, d.radius(), 0 ); point = on_circ; d.snap_to( HANDLE, point ); ASSERT_VECTORS_EQUAL( on_circ, point ); // try a point at the center of the circle point = center; d.snap_to( HANDLE, point ); CPPUNIT_ASSERT_DOUBLES_EQUAL( XPLANE, point.x(), EPSILON ); point -= center; CPPUNIT_ASSERT_DOUBLES_EQUAL( d.radius(), point.length(), EPSILON ); // try a different handle to make sure a handle not // on the the circle results in a point not on the circle double pplane = XPLANE + 5; point.set( pplane, 0, 0 ); d.snap_to( (void*)( (size_t)HANDLE + 1 ), point ); CPPUNIT_ASSERT_DOUBLES_EQUAL( pplane, point.x(), EPSILON ); }
Definition at line 68 of file BoundedCylinderDomainTest.cpp.
References ASSERT_VECTORS_EQUAL, CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::BoundedCylinderDomain::create_curve(), MBMesquite::EPSILON, MBMesquite::CylinderDomain::radius(), MBMesquite::Vector3D::set(), MBMesquite::CylinderDomain::snap_to(), MBMesquite::Vector3D::x(), MBMesquite::Vector3D::y(), and MBMesquite::Vector3D::z().
{ const Mesh::EntityHandle HANDLE = (void*)20; const double ZPLANE = 5; // Define a circle in the Z=5 plane, centered at (0,0,5) // with a radius of 10. std::vector< Mesh::EntityHandle > handles( 1 ); handles[0] = HANDLE; BoundedCylinderDomain d( 10 ); d.create_curve( ZPLANE, handles ); Vector3D point; // try a point inside and below the circle point.set( 5, 5, 2 ); d.snap_to( HANDLE, point ); CPPUNIT_ASSERT_DOUBLES_EQUAL( ZPLANE, point.z(), EPSILON ); CPPUNIT_ASSERT_DOUBLES_EQUAL( point.x(), point.y(), EPSILON ); point[2] = 0.0; CPPUNIT_ASSERT_DOUBLES_EQUAL( d.radius(), point.length(), EPSILON ); // try a point outside and above the circle point.set( 50, 50, 50 ); d.snap_to( HANDLE, point ); CPPUNIT_ASSERT_DOUBLES_EQUAL( ZPLANE, point.z(), EPSILON ); CPPUNIT_ASSERT_DOUBLES_EQUAL( point.x(), point.y(), EPSILON ); point[2] = 0.0; CPPUNIT_ASSERT_DOUBLES_EQUAL( d.radius(), point.length(), EPSILON ); // try a point on the circle Vector3D on_circ( d.radius(), 0, ZPLANE ); point = on_circ; d.snap_to( HANDLE, point ); ASSERT_VECTORS_EQUAL( on_circ, point ); // try a point at the center of the circle point.set( d.radius(), 0, ZPLANE ); d.snap_to( HANDLE, point ); CPPUNIT_ASSERT_DOUBLES_EQUAL( ZPLANE, point.z(), EPSILON ); point[2] = 0.0; CPPUNIT_ASSERT_DOUBLES_EQUAL( d.radius(), point.length(), EPSILON ); // try a different handle to make sure a handle not // on the the circle results in a point not on the circle double pplane = ZPLANE - 5; point.set( 0, 0, pplane ); d.snap_to( (void*)( (size_t)HANDLE + 1 ), point ); CPPUNIT_ASSERT_DOUBLES_EQUAL( pplane, point.z(), EPSILON ); }
