MOAB
4.9.3pre
Performs a complex Schur decomposition of a real or complex square matrix. More...
#include <ComplexSchur.h>
Public Types | |
| enum | { RowsAtCompileTime = MatrixType::RowsAtCompileTime, ColsAtCompileTime = MatrixType::ColsAtCompileTime, Options = MatrixType::Options, MaxRowsAtCompileTime = MatrixType::MaxRowsAtCompileTime, MaxColsAtCompileTime = MatrixType::MaxColsAtCompileTime } |
| typedef _MatrixType | MatrixType |
| typedef MatrixType::Scalar | Scalar |
Scalar type for matrices of type _MatrixType. | |
| typedef NumTraits< Scalar >::Real | RealScalar |
| typedef Eigen::Index | Index |
| typedef std::complex< RealScalar > | ComplexScalar |
Complex scalar type for _MatrixType. | |
| typedef Matrix< ComplexScalar, RowsAtCompileTime, ColsAtCompileTime, Options, MaxRowsAtCompileTime, MaxColsAtCompileTime > | ComplexMatrixType |
| Type for the matrices in the Schur decomposition. | |
Public Member Functions | |
| ComplexSchur (Index size=RowsAtCompileTime==Dynamic?1:RowsAtCompileTime) | |
| Default constructor. | |
| template<typename InputType > | |
| ComplexSchur (const EigenBase< InputType > &matrix, bool computeU=true) | |
| Constructor; computes Schur decomposition of given matrix. | |
| const ComplexMatrixType & | matrixU () const |
| Returns the unitary matrix in the Schur decomposition. | |
| const ComplexMatrixType & | matrixT () const |
| Returns the triangular matrix in the Schur decomposition. | |
| ComplexSchur & | compute (const EigenBase< InputType > &matrix, bool computeU=true) |
| Computes Schur decomposition of given matrix. | |
| template<typename HessMatrixType , typename OrthMatrixType > | |
| ComplexSchur & | computeFromHessenberg (const HessMatrixType &matrixH, const OrthMatrixType &matrixQ, bool computeU=true) |
| Compute Schur decomposition from a given Hessenberg matrix. | |
| ComputationInfo | info () const |
| Reports whether previous computation was successful. | |
| ComplexSchur & | setMaxIterations (Index maxIters) |
| Sets the maximum number of iterations allowed. | |
| Index | getMaxIterations () |
| Returns the maximum number of iterations. | |
Static Public Attributes | |
| static const int | m_maxIterationsPerRow = 30 |
| Maximum number of iterations per row. | |
Protected Attributes | |
| ComplexMatrixType | m_matT |
| ComplexMatrixType | m_matU |
| HessenbergDecomposition < MatrixType > | m_hess |
| ComputationInfo | m_info |
| bool | m_isInitialized |
| bool | m_matUisUptodate |
| Index | m_maxIters |
Private Member Functions | |
| bool | subdiagonalEntryIsNeglegible (Index i) |
| ComplexScalar | computeShift (Index iu, Index iter) |
| void | reduceToTriangularForm (bool computeU) |
Friends | |
| struct | internal::complex_schur_reduce_to_hessenberg< MatrixType, NumTraits< Scalar >::IsComplex > |
| _MatrixType | the type of the matrix of which we are computing the Schur decomposition; this is expected to be an instantiation of the Matrix class template. |
Given a real or complex square matrix A, this class computes the Schur decomposition:
where U is a unitary complex matrix, and T is a complex upper triangular matrix. The diagonal of the matrix T corresponds to the eigenvalues of the matrix A.
Call the function compute() to compute the Schur decomposition of a given matrix. Alternatively, you can use the ComplexSchur(const MatrixType&, bool) constructor which computes the Schur decomposition at construction time. Once the decomposition is computed, you can use the matrixU() and matrixT() functions to retrieve the matrices U and V in the decomposition.
Definition at line 51 of file ComplexSchur.h.
| typedef Matrix<ComplexScalar, RowsAtCompileTime, ColsAtCompileTime, Options, MaxRowsAtCompileTime, MaxColsAtCompileTime> Eigen::ComplexSchur< _MatrixType >::ComplexMatrixType |
This is a square matrix with entries of type ComplexScalar. The size is the same as the size of _MatrixType.
Definition at line 81 of file ComplexSchur.h.
| typedef std::complex<RealScalar> Eigen::ComplexSchur< _MatrixType >::ComplexScalar |
This is std::complex<Scalar> if Scalar is real (e.g., float or double) and just Scalar if Scalar is complex.
Definition at line 74 of file ComplexSchur.h.
| typedef Eigen::Index Eigen::ComplexSchur< _MatrixType >::Index |
Definition at line 66 of file ComplexSchur.h.
| typedef _MatrixType Eigen::ComplexSchur< _MatrixType >::MatrixType |
Definition at line 54 of file ComplexSchur.h.
| typedef NumTraits<Scalar>::Real Eigen::ComplexSchur< _MatrixType >::RealScalar |
Definition at line 65 of file ComplexSchur.h.
| typedef MatrixType::Scalar Eigen::ComplexSchur< _MatrixType >::Scalar |
Definition at line 64 of file ComplexSchur.h.
| anonymous enum |
Definition at line 55 of file ComplexSchur.h.
| Eigen::ComplexSchur< _MatrixType >::ComplexSchur | ( | Index | size = RowsAtCompileTime==Dynamic ? 1 : RowsAtCompileTime | ) | [inline, explicit] |
| [in] | size | Positive integer, size of the matrix whose Schur decomposition will be computed. |
The default constructor is useful in cases in which the user intends to perform decompositions via compute(). The size parameter is only used as a hint. It is not an error to give a wrong size, but it may impair performance.
Definition at line 94 of file ComplexSchur.h.
: RowsAtCompileTime) : m_matT(size,size), m_matU(size,size), m_hess(size), m_isInitialized(false), m_matUisUptodate(false), m_maxIters(-1) {}
| Eigen::ComplexSchur< _MatrixType >::ComplexSchur | ( | const EigenBase< InputType > & | matrix, |
| bool | computeU = true |
| [in] | matrix | Square matrix whose Schur decomposition is to be computed. |
| [in] | computeU | If true, both T and U are computed; if false, only T is computed. |
This constructor calls compute() to compute the Schur decomposition.
Definition at line 113 of file ComplexSchur.h.
: m_matT(matrix.rows(),matrix.cols()), m_matU(matrix.rows(),matrix.cols()), m_hess(matrix.rows()), m_isInitialized(false), m_matUisUptodate(false), m_maxIters(-1) { compute(matrix.derived(), computeU); }
| ComplexSchur< MatrixType > & Eigen::ComplexSchur< MatrixType >::compute | ( | const EigenBase< InputType > & | matrix, |
*this The Schur decomposition is computed by first reducing the matrix to Hessenberg form using the class HessenbergDecomposition. The Hessenberg matrix is then reduced to triangular form by performing QR iterations with a single shift. The cost of computing the Schur decomposition depends on the number of iterations; as a rough guide, it may be taken on the number of iterations; as a rough guide, it may be taken to be
complex flops, or
complex flops if computeU is false.
Example:
Output:
Definition at line 319 of file ComplexSchur.h.
m_matUisUptodate = false;
eigen_assert(matrix.cols() == matrix.rows());
if(matrix.cols() == 1)
m_matT = matrix.derived().template cast<ComplexScalar>();
if(computeU) m_matU = ComplexMatrixType::Identity(1,1);
m_info = Success;
m_isInitialized = true;
m_matUisUptodate = computeU;
return *this;
internal::complex_schur_reduce_to_hessenberg<MatrixType, NumTraits<Scalar>::IsComplex>::run(*this, matrix.derived(), computeU);
computeFromHessenberg(m_matT, m_matU, computeU);
return *this;
| ComplexSchur< MatrixType > & Eigen::ComplexSchur< MatrixType >::computeFromHessenberg | ( | const HessMatrixType & | matrixH, |
| const OrthMatrixType & | matrixQ, | ||
| [in] | matrixH | Matrix in Hessenberg form H |
| [in] | matrixQ | orthogonal matrix Q that transform a matrix A to H : A = Q H Q^T |
| computeU | Computes the matriX U of the Schur vectors |
*this This routine assumes that the matrix is already reduced in Hessenberg form matrixH using either the class HessenbergDecomposition or another mean. It computes the upper quasi-triangular matrix T of the Schur decomposition of H When computeU is true, this routine computes the matrix U such that A = U T U^T = (QZ) T (QZ)^T = Q H Q^T where A is the initial matrix
NOTE Q is referenced if computeU is true; so, if the initial orthogonal matrix is not available, the user should give an identity matrix (Q.setIdentity())
Definition at line 341 of file ComplexSchur.h.
m_matT = matrixH;
if(computeU)
m_matU = matrixQ;
reduceToTriangularForm(computeU);
return *this;
| ComplexSchur< MatrixType >::ComplexScalar Eigen::ComplexSchur< MatrixType >::computeShift | ( | Index | iu, |
| Index | iter | ||
| ) | [private] |
Compute the shift in the current QR iteration.
Definition at line 281 of file ComplexSchur.h.
using std::abs;
if (iter == 10 || iter == 20)
// exceptional shift, taken from http://www.netlib.org/eispack/comqr.f
return abs(numext::real(m_matT.coeff(iu,iu-1))) + abs(numext::real(m_matT.coeff(iu-1,iu-2)));
// compute the shift as one of the eigenvalues of t, the 2x2
// diagonal block on the bottom of the active submatrix
Matrix<ComplexScalar,2,2> t = m_matT.template block<2,2>(iu-1,iu-1);
RealScalar normt = t.cwiseAbs().sum();
t /= normt; // the normalization by sf is to avoid under/overflow
ComplexScalar b = t.coeff(0,1) * t.coeff(1,0);
ComplexScalar c = t.coeff(0,0) - t.coeff(1,1);
ComplexScalar disc = sqrt(c*c + RealScalar(4)*b);
ComplexScalar det = t.coeff(0,0) * t.coeff(1,1) - b;
ComplexScalar trace = t.coeff(0,0) + t.coeff(1,1);
ComplexScalar eival1 = (trace + disc) / RealScalar(2);
ComplexScalar eival2 = (trace - disc) / RealScalar(2);
if(numext::norm1(eival1) > numext::norm1(eival2))
eival2 = det / eival1;
else
eival1 = det / eival2;
// choose the eigenvalue closest to the bottom entry of the diagonal
if(numext::norm1(eival1-t.coeff(1,1)) < numext::norm1(eival2-t.coeff(1,1)))
return normt * eival1;
else
return normt * eival2;
| Index Eigen::ComplexSchur< _MatrixType >::getMaxIterations | ( | ) | [inline] |
Definition at line 235 of file ComplexSchur.h.
return m_maxIters;
| ComputationInfo Eigen::ComplexSchur< _MatrixType >::info | ( | ) | const [inline] |
Success if computation was succesful, NoConvergence otherwise. Definition at line 217 of file ComplexSchur.h.
eigen_assert(m_isInitialized && "ComplexSchur is not initialized.");
return m_info;
| const ComplexMatrixType& Eigen::ComplexSchur< _MatrixType >::matrixT | ( | ) | const [inline] |
It is assumed that either the constructor ComplexSchur(const MatrixType& matrix, bool computeU) or the member function compute(const MatrixType& matrix, bool computeU) has been called before to compute the Schur decomposition of a matrix.
Note that this function returns a plain square matrix. If you want to reference only the upper triangular part, use:
schur.matrixT().triangularView<Upper>()
Example:
Output:
Definition at line 162 of file ComplexSchur.h.
return m_matT;
| const ComplexMatrixType& Eigen::ComplexSchur< _MatrixType >::matrixU | ( | ) | const [inline] |
It is assumed that either the constructor ComplexSchur(const MatrixType& matrix, bool computeU) or the member function compute(const MatrixType& matrix, bool computeU) has been called before to compute the Schur decomposition of a matrix, and that computeU was set to true (the default value).
Example:
Output:
Definition at line 138 of file ComplexSchur.h.
eigen_assert(m_matUisUptodate && "The matrix U has not been computed during the ComplexSchur decomposition.");
return m_matU;
| void Eigen::ComplexSchur< MatrixType >::reduceToTriangularForm | ( | bool | computeU | ) | [private] |
Definition at line 387 of file ComplexSchur.h.
Index maxIters = m_maxIters;
if (maxIters == -1)
maxIters = m_maxIterationsPerRow * m_matT.rows();
// The matrix m_matT is divided in three parts.
// Rows 0,...,il-1 are decoupled from the rest because m_matT(il,il-1) is zero.
// Rows il,...,iu is the part we are working on (the active submatrix).
// Rows iu+1,...,end are already brought in triangular form.
Index iu = m_matT.cols() - 1;
Index il;
Index iter = 0; // number of iterations we are working on the (iu,iu) element
Index totalIter = 0; // number of iterations for whole matrix
while(true)
// find iu, the bottom row of the active submatrix
while(iu > 0)
if(!subdiagonalEntryIsNeglegible(iu-1)) break;
iter = 0;
--iu;
// if iu is zero then we are done; the whole matrix is triangularized
if(iu==0) break;
// if we spent too many iterations, we give up
iter++;
totalIter++;
if(totalIter > maxIters) break;
// find il, the top row of the active submatrix
il = iu-1;
while(il > 0 && !subdiagonalEntryIsNeglegible(il-1))
--il;
/* perform the QR step using Givens rotations. The first rotation
creates a bulge; the (il+2,il) element becomes nonzero. This
bulge is chased down to the bottom of the active submatrix. */
ComplexScalar shift = computeShift(iu, iter);
JacobiRotation<ComplexScalar> rot;
rot.makeGivens(m_matT.coeff(il,il) - shift, m_matT.coeff(il+1,il));
m_matT.rightCols(m_matT.cols()-il).applyOnTheLeft(il, il+1, rot.adjoint());
m_matT.topRows((std::min)(il+2,iu)+1).applyOnTheRight(il, il+1, rot);
if(computeU) m_matU.applyOnTheRight(il, il+1, rot);
for(Index i=il+1 ; i<iu ; i++)
rot.makeGivens(m_matT.coeffRef(i,i-1), m_matT.coeffRef(i+1,i-1), &m_matT.coeffRef(i,i-1));
m_matT.coeffRef(i+1,i-1) = ComplexScalar(0);
m_matT.rightCols(m_matT.cols()-i).applyOnTheLeft(i, i+1, rot.adjoint());
m_matT.topRows((std::min)(i+2,iu)+1).applyOnTheRight(i, i+1, rot);
if(computeU) m_matU.applyOnTheRight(i, i+1, rot);
if(totalIter <= maxIters)
m_info = Success;
else
m_info = NoConvergence;
| ComplexSchur& Eigen::ComplexSchur< _MatrixType >::setMaxIterations | ( | Index | maxIters | ) | [inline] |
If not specified by the user, the maximum number of iterations is m_maxIterationsPerRow times the size of the matrix.
Definition at line 228 of file ComplexSchur.h.
m_maxIters = maxIters;
return *this;
| bool Eigen::ComplexSchur< MatrixType >::subdiagonalEntryIsNeglegible | ( | Index | i | ) | [inline, private] |
If m_matT(i+1,i) is neglegible in floating point arithmetic compared to m_matT(i,i) and m_matT(j,j), then set it to zero and return true, else return false.
Definition at line 266 of file ComplexSchur.h.
RealScalar d = numext::norm1(m_matT.coeff(i,i)) + numext::norm1(m_matT.coeff(i+1,i+1));
RealScalar sd = numext::norm1(m_matT.coeff(i+1,i));
if (internal::isMuchSmallerThan(sd, d, NumTraits<RealScalar>::epsilon()))
m_matT.coeffRef(i+1,i) = ComplexScalar(0);
return true;
return false;
friend struct internal::complex_schur_reduce_to_hessenberg< MatrixType, NumTraits< Scalar >::IsComplex > [friend] |
Definition at line 259 of file ComplexSchur.h.
HessenbergDecomposition<MatrixType> Eigen::ComplexSchur< _MatrixType >::m_hess [protected] |
Definition at line 249 of file ComplexSchur.h.
ComputationInfo Eigen::ComplexSchur< _MatrixType >::m_info [protected] |
Definition at line 250 of file ComplexSchur.h.
bool Eigen::ComplexSchur< _MatrixType >::m_isInitialized [protected] |
Definition at line 251 of file ComplexSchur.h.
ComplexMatrixType Eigen::ComplexSchur< _MatrixType >::m_matT [protected] |
Definition at line 248 of file ComplexSchur.h.
ComplexMatrixType Eigen::ComplexSchur< _MatrixType >::m_matU [protected] |
bool Eigen::ComplexSchur< _MatrixType >::m_matUisUptodate [protected] |
Definition at line 252 of file ComplexSchur.h.
const int Eigen::ComplexSchur< _MatrixType >::m_maxIterationsPerRow = 30 [static] |
If not otherwise specified, the maximum number of iterations is this number times the size of the matrix. It is currently set to 30.
Definition at line 245 of file ComplexSchur.h.
Index Eigen::ComplexSchur< _MatrixType >::m_maxIters [protected] |
Definition at line 253 of file ComplexSchur.h.
