MOAB
4.9.3pre
Computes eigenvalues and eigenvectors of general complex matrices. More...
#include <ComplexEigenSolver.h>
Public Types | |
| enum | { RowsAtCompileTime = MatrixType::RowsAtCompileTime, ColsAtCompileTime = MatrixType::ColsAtCompileTime, Options = MatrixType::Options, MaxRowsAtCompileTime = MatrixType::MaxRowsAtCompileTime, MaxColsAtCompileTime = MatrixType::MaxColsAtCompileTime } |
| typedef _MatrixType | MatrixType |
Synonym for the template parameter _MatrixType. | |
| typedef MatrixType::Scalar | Scalar |
| Scalar type for matrices of type MatrixType. | |
| typedef NumTraits< Scalar >::Real | RealScalar |
| typedef Eigen::Index | Index |
| typedef std::complex< RealScalar > | ComplexScalar |
| Complex scalar type for MatrixType. | |
| typedef Matrix< ComplexScalar, ColsAtCompileTime, 1, Options &(~RowMajor), MaxColsAtCompileTime, 1 > | EigenvalueType |
| Type for vector of eigenvalues as returned by eigenvalues(). | |
| typedef Matrix< ComplexScalar, RowsAtCompileTime, ColsAtCompileTime, Options, MaxRowsAtCompileTime, MaxColsAtCompileTime > | EigenvectorType |
| Type for matrix of eigenvectors as returned by eigenvectors(). | |
Public Member Functions | |
| ComplexEigenSolver () | |
| Default constructor. | |
| ComplexEigenSolver (Index size) | |
| Default Constructor with memory preallocation. | |
| template<typename InputType > | |
| ComplexEigenSolver (const EigenBase< InputType > &matrix, bool computeEigenvectors=true) | |
| Constructor; computes eigendecomposition of given matrix. | |
| const EigenvectorType & | eigenvectors () const |
| Returns the eigenvectors of given matrix. | |
| const EigenvalueType & | eigenvalues () const |
| Returns the eigenvalues of given matrix. | |
| ComplexEigenSolver & | compute (const EigenBase< InputType > &matrix, bool computeEigenvectors=true) |
| Computes eigendecomposition of given matrix. | |
| ComputationInfo | info () const |
| Reports whether previous computation was successful. | |
| ComplexEigenSolver & | setMaxIterations (Index maxIters) |
| Sets the maximum number of iterations allowed. | |
| Index | getMaxIterations () |
| Returns the maximum number of iterations. | |
Static Protected Member Functions | |
| static void | check_template_parameters () |
Protected Attributes | |
| EigenvectorType | m_eivec |
| EigenvalueType | m_eivalues |
| ComplexSchur< MatrixType > | m_schur |
| bool | m_isInitialized |
| bool | m_eigenvectorsOk |
| EigenvectorType | m_matX |
Private Member Functions | |
| void | doComputeEigenvectors (const RealScalar &matrixnorm) |
| void | sortEigenvalues (bool computeEigenvectors) |
| _MatrixType | the type of the matrix of which we are computing the eigendecomposition; this is expected to be an instantiation of the Matrix class template. |
The eigenvalues and eigenvectors of a matrix
are scalars
and vectors
such that
. If
is a diagonal matrix with the eigenvalues on the diagonal, and
is a matrix with the eigenvectors as its columns, then
. The matrix
is almost always invertible, in which case we have
. This is called the eigendecomposition.
The main function in this class is compute(), which computes the eigenvalues and eigenvectors of a given function. The documentation for that function contains an example showing the main features of the class.
Definition at line 45 of file ComplexEigenSolver.h.
| typedef std::complex<RealScalar> Eigen::ComplexEigenSolver< _MatrixType >::ComplexScalar |
This is std::complex<Scalar> if Scalar is real (e.g., float or double) and just Scalar if Scalar is complex.
Definition at line 71 of file ComplexEigenSolver.h.
| typedef Matrix<ComplexScalar, ColsAtCompileTime, 1, Options&(~RowMajor), MaxColsAtCompileTime, 1> Eigen::ComplexEigenSolver< _MatrixType >::EigenvalueType |
This is a column vector with entries of type ComplexScalar. The length of the vector is the size of MatrixType.
Definition at line 78 of file ComplexEigenSolver.h.
| typedef Matrix<ComplexScalar, RowsAtCompileTime, ColsAtCompileTime, Options, MaxRowsAtCompileTime, MaxColsAtCompileTime> Eigen::ComplexEigenSolver< _MatrixType >::EigenvectorType |
This is a square matrix with entries of type ComplexScalar. The size is the same as the size of MatrixType.
Definition at line 85 of file ComplexEigenSolver.h.
| typedef Eigen::Index Eigen::ComplexEigenSolver< _MatrixType >::Index |
Definition at line 63 of file ComplexEigenSolver.h.
| typedef _MatrixType Eigen::ComplexEigenSolver< _MatrixType >::MatrixType |
Definition at line 50 of file ComplexEigenSolver.h.
| typedef NumTraits<Scalar>::Real Eigen::ComplexEigenSolver< _MatrixType >::RealScalar |
Definition at line 62 of file ComplexEigenSolver.h.
| typedef MatrixType::Scalar Eigen::ComplexEigenSolver< _MatrixType >::Scalar |
Definition at line 61 of file ComplexEigenSolver.h.
| anonymous enum |
Definition at line 52 of file ComplexEigenSolver.h.
| Eigen::ComplexEigenSolver< _MatrixType >::ComplexEigenSolver | ( | ) | [inline] |
The default constructor is useful in cases in which the user intends to perform decompositions via compute().
Definition at line 92 of file ComplexEigenSolver.h.
: m_eivec(), m_eivalues(), m_schur(), m_isInitialized(false), m_eigenvectorsOk(false), m_matX() {}
| Eigen::ComplexEigenSolver< _MatrixType >::ComplexEigenSolver | ( | Index | size | ) | [inline, explicit] |
Like the default constructor but with preallocation of the internal data according to the specified problem size.
Definition at line 107 of file ComplexEigenSolver.h.
: m_eivec(size, size), m_eivalues(size), m_schur(size), m_isInitialized(false), m_eigenvectorsOk(false), m_matX(size, size) {}
| Eigen::ComplexEigenSolver< _MatrixType >::ComplexEigenSolver | ( | const EigenBase< InputType > & | matrix, |
| bool | computeEigenvectors = true |
| [in] | matrix | Square matrix whose eigendecomposition is to be computed. |
| [in] | computeEigenvectors | If true, both the eigenvectors and the eigenvalues are computed; if false, only the eigenvalues are computed. |
This constructor calls compute() to compute the eigendecomposition.
Definition at line 126 of file ComplexEigenSolver.h.
: m_eivec(matrix.rows(),matrix.cols()), m_eivalues(matrix.cols()), m_schur(matrix.rows()), m_isInitialized(false), m_eigenvectorsOk(false), m_matX(matrix.rows(),matrix.cols()) { compute(matrix.derived(), computeEigenvectors); }
| static void Eigen::ComplexEigenSolver< _MatrixType >::check_template_parameters | ( | ) | [inline, static, protected] |
Definition at line 240 of file ComplexEigenSolver.h.
| ComplexEigenSolver< MatrixType > & Eigen::ComplexEigenSolver< MatrixType >::compute | ( | const EigenBase< InputType > & | matrix, |
*this This function computes the eigenvalues of the complex matrix matrix. The eigenvalues() function can be used to retrieve them. If computeEigenvectors is true, then the eigenvectors are also computed and can be retrieved by calling eigenvectors().
The matrix is first reduced to Schur form using the ComplexSchur class. The Schur decomposition is then used to compute the eigenvalues and eigenvectors.
The cost of the computation is dominated by the cost of the Schur decomposition, which is
where
is the size of the matrix.
Example:
Output:
Definition at line 261 of file ComplexEigenSolver.h.
check_template_parameters();
// this code is inspired from Jampack
eigen_assert(matrix.cols() == matrix.rows());
// Do a complex Schur decomposition, A = U T U^*
// The eigenvalues are on the diagonal of T.
m_schur.compute(matrix.derived(), computeEigenvectors);
if(m_schur.info() == Success)
m_eivalues = m_schur.matrixT().diagonal();
if(computeEigenvectors)
doComputeEigenvectors(m_schur.matrixT().norm());
sortEigenvalues(computeEigenvectors);
m_isInitialized = true;
m_eigenvectorsOk = computeEigenvectors;
return *this;
| void Eigen::ComplexEigenSolver< MatrixType >::doComputeEigenvectors | ( | const RealScalar & | matrixnorm | ) | [private] |
Definition at line 287 of file ComplexEigenSolver.h.
const Index n = m_eivalues.size();
// Compute X such that T = X D X^(-1), where D is the diagonal of T.
// The matrix X is unit triangular.
m_matX = EigenvectorType::Zero(n, n);
for(Index k=n-1 ; k>=0 ; k--)
m_matX.coeffRef(k,k) = ComplexScalar(1.0,0.0);
// Compute X(i,k) using the (i,k) entry of the equation X T = D X
for(Index i=k-1 ; i>=0 ; i--)
m_matX.coeffRef(i,k) = -m_schur.matrixT().coeff(i,k);
if(k-i-1>0)
m_matX.coeffRef(i,k) -= (m_schur.matrixT().row(i).segment(i+1,k-i-1) * m_matX.col(k).segment(i+1,k-i-1)).value();
ComplexScalar z = m_schur.matrixT().coeff(i,i) - m_schur.matrixT().coeff(k,k);
if(z==ComplexScalar(0))
// If the i-th and k-th eigenvalue are equal, then z equals 0.
// Use a small value instead, to prevent division by zero.
numext::real_ref(z) = NumTraits<RealScalar>::epsilon() * matrixnorm;
m_matX.coeffRef(i,k) = m_matX.coeff(i,k) / z;
// Compute V as V = U X; now A = U T U^* = U X D X^(-1) U^* = V D V^(-1)
m_eivec.noalias() = m_schur.matrixU() * m_matX;
// .. and normalize the eigenvectors
for(Index k=0 ; k<n ; k++)
m_eivec.col(k).normalize();
| const EigenvalueType& Eigen::ComplexEigenSolver< _MatrixType >::eigenvalues | ( | ) | const [inline] |
This function returns a column vector containing the eigenvalues. Eigenvalues are repeated according to their algebraic multiplicity, so there are as many eigenvalues as rows in the matrix. The eigenvalues are not sorted in any particular order.
Example:
Output:
Definition at line 182 of file ComplexEigenSolver.h.
eigen_assert(m_isInitialized && "ComplexEigenSolver is not initialized.");
return m_eivalues;
| const EigenvectorType& Eigen::ComplexEigenSolver< _MatrixType >::eigenvectors | ( | ) | const [inline] |
computeEigenvectors was set to true (the default).This function returns a matrix whose columns are the eigenvectors. Column
is an eigenvector corresponding to eigenvalue number
as returned by eigenvalues(). The eigenvectors are normalized to have (Euclidean) norm equal to one. The matrix returned by this function is the matrix
in the eigendecomposition
, if it exists.
Example:
Output:
Definition at line 157 of file ComplexEigenSolver.h.
eigen_assert(m_eigenvectorsOk && "The eigenvectors have not been computed together with the eigenvalues.");
return m_eivec;
| Index Eigen::ComplexEigenSolver< _MatrixType >::getMaxIterations | ( | ) | [inline] |
Definition at line 233 of file ComplexEigenSolver.h.
return m_schur.getMaxIterations();
| ComputationInfo Eigen::ComplexEigenSolver< _MatrixType >::info | ( | ) | const [inline] |
Success if computation was succesful, NoConvergence otherwise. Definition at line 219 of file ComplexEigenSolver.h.
return m_schur.info();
| ComplexEigenSolver& Eigen::ComplexEigenSolver< _MatrixType >::setMaxIterations | ( | Index | maxIters | ) | [inline] |
Definition at line 226 of file ComplexEigenSolver.h.
m_schur.setMaxIterations(maxIters);
return *this;
| void Eigen::ComplexEigenSolver< MatrixType >::sortEigenvalues | ( | bool | computeEigenvectors | ) | [private] |
Definition at line 325 of file ComplexEigenSolver.h.
for (Index i=0; i<n; i++)
Index k;
m_eivalues.cwiseAbs().tail(n-i).minCoeff(&k);
if (k != 0)
k += i;
std::swap(m_eivalues[k],m_eivalues[i]);
m_eivec.col(i).swap(m_eivec.col(k));
bool Eigen::ComplexEigenSolver< _MatrixType >::m_eigenvectorsOk [protected] |
Definition at line 249 of file ComplexEigenSolver.h.
EigenvalueType Eigen::ComplexEigenSolver< _MatrixType >::m_eivalues [protected] |
Definition at line 246 of file ComplexEigenSolver.h.
EigenvectorType Eigen::ComplexEigenSolver< _MatrixType >::m_eivec [protected] |
Definition at line 245 of file ComplexEigenSolver.h.
bool Eigen::ComplexEigenSolver< _MatrixType >::m_isInitialized [protected] |
Definition at line 248 of file ComplexEigenSolver.h.
EigenvectorType Eigen::ComplexEigenSolver< _MatrixType >::m_matX [protected] |
Definition at line 250 of file ComplexEigenSolver.h.
ComplexSchur<MatrixType> Eigen::ComplexEigenSolver< _MatrixType >::m_schur [protected] |
Definition at line 247 of file ComplexEigenSolver.h.
