MOAB
4.9.3pre
Computes eigenvalues and eigenvectors of selfadjoint matrices. More...
#include <SelfAdjointEigenSolver.h>
Public Types | |
| enum | { Size = MatrixType::RowsAtCompileTime, ColsAtCompileTime = MatrixType::ColsAtCompileTime, Options = MatrixType::Options, MaxColsAtCompileTime = MatrixType::MaxColsAtCompileTime } |
| typedef _MatrixType | MatrixType |
| typedef MatrixType::Scalar | Scalar |
Scalar type for matrices of type _MatrixType. | |
| typedef Eigen::Index | Index |
| typedef Matrix< Scalar, Size, Size, ColMajor, MaxColsAtCompileTime, MaxColsAtCompileTime > | EigenvectorsType |
| typedef NumTraits< Scalar >::Real | RealScalar |
Real scalar type for _MatrixType. | |
| typedef internal::plain_col_type < MatrixType, RealScalar > ::type | RealVectorType |
| Type for vector of eigenvalues as returned by eigenvalues(). | |
| typedef Tridiagonalization < MatrixType > | TridiagonalizationType |
| typedef TridiagonalizationType::SubDiagonalType | SubDiagonalType |
Public Member Functions | |
| EIGEN_DEVICE_FUNC | SelfAdjointEigenSolver () |
| Default constructor for fixed-size matrices. | |
| EIGEN_DEVICE_FUNC | SelfAdjointEigenSolver (Index size) |
| Constructor, pre-allocates memory for dynamic-size matrices. | |
| template<typename InputType > | |
| EIGEN_DEVICE_FUNC | SelfAdjointEigenSolver (const EigenBase< InputType > &matrix, int options=ComputeEigenvectors) |
| Constructor; computes eigendecomposition of given matrix. | |
| EIGEN_DEVICE_FUNC SelfAdjointEigenSolver & | compute (const EigenBase< InputType > &matrix, int options=ComputeEigenvectors) |
| Computes eigendecomposition of given matrix. | |
| EIGEN_DEVICE_FUNC SelfAdjointEigenSolver & | computeDirect (const MatrixType &matrix, int options=ComputeEigenvectors) |
| Computes eigendecomposition of given matrix using a closed-form algorithm. | |
| SelfAdjointEigenSolver & | computeFromTridiagonal (const RealVectorType &diag, const SubDiagonalType &subdiag, int options=ComputeEigenvectors) |
| Computes the eigen decomposition from a tridiagonal symmetric matrix. | |
| EIGEN_DEVICE_FUNC const EigenvectorsType & | eigenvectors () const |
| Returns the eigenvectors of given matrix. | |
| EIGEN_DEVICE_FUNC const RealVectorType & | eigenvalues () const |
| Returns the eigenvalues of given matrix. | |
| EIGEN_DEVICE_FUNC MatrixType | operatorSqrt () const |
| Computes the positive-definite square root of the matrix. | |
| EIGEN_DEVICE_FUNC MatrixType | operatorInverseSqrt () const |
| Computes the inverse square root of the matrix. | |
| EIGEN_DEVICE_FUNC ComputationInfo | info () const |
| Reports whether previous computation was successful. | |
Static Public Attributes | |
| static const int | m_maxIterations = 30 |
| Maximum number of iterations. | |
Static Protected Member Functions | |
| static void | check_template_parameters () |
Protected Attributes | |
| EigenvectorsType | m_eivec |
| RealVectorType | m_eivalues |
| TridiagonalizationType::SubDiagonalType | m_subdiag |
| ComputationInfo | m_info |
| bool | m_isInitialized |
| bool | m_eigenvectorsOk |
Friends | |
| struct | internal::direct_selfadjoint_eigenvalues< SelfAdjointEigenSolver, Size, NumTraits< Scalar >::IsComplex > |
| _MatrixType | the type of the matrix of which we are computing the eigendecomposition; this is expected to be an instantiation of the Matrix class template. |
A matrix
is selfadjoint if it equals its adjoint. For real matrices, this means that the matrix is symmetric: it equals its transpose. This class computes the eigenvalues and eigenvectors of a selfadjoint matrix. These are the scalars
and vectors
such that
. The eigenvalues of a selfadjoint matrix are always real. If
is a diagonal matrix with the eigenvalues on the diagonal, and
is a matrix with the eigenvectors as its columns, then
(for selfadjoint matrices, the matrix
is always invertible). This is called the eigendecomposition.
The algorithm exploits the fact that the matrix is selfadjoint, making it faster and more accurate than the general purpose eigenvalue algorithms implemented in EigenSolver and ComplexEigenSolver.
Only the lower triangular part of the input matrix is referenced.
Call the function compute() to compute the eigenvalues and eigenvectors of a given matrix. Alternatively, you can use the SelfAdjointEigenSolver(const MatrixType&, int) constructor which computes the eigenvalues and eigenvectors at construction time. Once the eigenvalue and eigenvectors are computed, they can be retrieved with the eigenvalues() and eigenvectors() functions.
The documentation for SelfAdjointEigenSolver(const MatrixType&, int) contains an example of the typical use of this class.
To solve the generalized eigenvalue problem
and the likes, see the class GeneralizedSelfAdjointEigenSolver.
Definition at line 70 of file SelfAdjointEigenSolver.h.
| typedef Matrix<Scalar,Size,Size,ColMajor,MaxColsAtCompileTime,MaxColsAtCompileTime> Eigen::SelfAdjointEigenSolver< _MatrixType >::EigenvectorsType |
Definition at line 86 of file SelfAdjointEigenSolver.h.
| typedef Eigen::Index Eigen::SelfAdjointEigenSolver< _MatrixType >::Index |
Definition at line 84 of file SelfAdjointEigenSolver.h.
| typedef _MatrixType Eigen::SelfAdjointEigenSolver< _MatrixType >::MatrixType |
Reimplemented in Eigen::GeneralizedSelfAdjointEigenSolver< _MatrixType >.
Definition at line 74 of file SelfAdjointEigenSolver.h.
| typedef NumTraits<Scalar>::Real Eigen::SelfAdjointEigenSolver< _MatrixType >::RealScalar |
This is just Scalar if Scalar is real (e.g., float or double), and the type of the real part of Scalar if Scalar is complex.
Definition at line 94 of file SelfAdjointEigenSolver.h.
| typedef internal::plain_col_type<MatrixType, RealScalar>::type Eigen::SelfAdjointEigenSolver< _MatrixType >::RealVectorType |
This is a column vector with entries of type RealScalar. The length of the vector is the size of _MatrixType.
Definition at line 103 of file SelfAdjointEigenSolver.h.
| typedef MatrixType::Scalar Eigen::SelfAdjointEigenSolver< _MatrixType >::Scalar |
Definition at line 83 of file SelfAdjointEigenSolver.h.
| typedef TridiagonalizationType::SubDiagonalType Eigen::SelfAdjointEigenSolver< _MatrixType >::SubDiagonalType |
Definition at line 105 of file SelfAdjointEigenSolver.h.
| typedef Tridiagonalization<MatrixType> Eigen::SelfAdjointEigenSolver< _MatrixType >::TridiagonalizationType |
Definition at line 104 of file SelfAdjointEigenSolver.h.
| anonymous enum |
Definition at line 75 of file SelfAdjointEigenSolver.h.
| EIGEN_DEVICE_FUNC Eigen::SelfAdjointEigenSolver< _MatrixType >::SelfAdjointEigenSolver | ( | ) | [inline] |
The default constructor is useful in cases in which the user intends to perform decompositions via compute(). This constructor can only be used if _MatrixType is a fixed-size matrix; use SelfAdjointEigenSolver(Index) for dynamic-size matrices.
Example:
Output:
Definition at line 118 of file SelfAdjointEigenSolver.h.
: m_eivec(), m_eivalues(), m_subdiag(), m_isInitialized(false) { }
| EIGEN_DEVICE_FUNC Eigen::SelfAdjointEigenSolver< _MatrixType >::SelfAdjointEigenSolver | ( | Index | size | ) | [inline, explicit] |
| [in] | size | Positive integer, size of the matrix whose eigenvalues and eigenvectors will be computed. |
This constructor is useful for dynamic-size matrices, when the user intends to perform decompositions via compute(). The size parameter is only used as a hint. It is not an error to give a wrong size, but it may impair performance.
Definition at line 138 of file SelfAdjointEigenSolver.h.
: m_eivec(size, size), m_eivalues(size), m_subdiag(size > 1 ? size - 1 : 1), m_isInitialized(false) {}
| EIGEN_DEVICE_FUNC Eigen::SelfAdjointEigenSolver< _MatrixType >::SelfAdjointEigenSolver | ( | const EigenBase< InputType > & | matrix, |
| int | options = ComputeEigenvectors |
| [in] | matrix | Selfadjoint matrix whose eigendecomposition is to be computed. Only the lower triangular part of the matrix is referenced. |
| [in] | options | Can be ComputeEigenvectors (default) or EigenvaluesOnly. |
This constructor calls compute(const MatrixType&, int) to compute the eigenvalues of the matrix matrix. The eigenvectors are computed if options equals ComputeEigenvectors.
Example:
Output:
Definition at line 162 of file SelfAdjointEigenSolver.h.
: m_eivec(matrix.rows(), matrix.cols()), m_eivalues(matrix.cols()), m_subdiag(matrix.rows() > 1 ? matrix.rows() - 1 : 1), m_isInitialized(false) { compute(matrix.derived(), options); }
| static void Eigen::SelfAdjointEigenSolver< _MatrixType >::check_template_parameters | ( | ) | [inline, static, protected] |
Definition at line 357 of file SelfAdjointEigenSolver.h.
| EIGEN_DEVICE_FUNC SelfAdjointEigenSolver< MatrixType > & Eigen::SelfAdjointEigenSolver< MatrixType >::compute | ( | const EigenBase< InputType > & | matrix, |
*this This function computes the eigenvalues of matrix. The eigenvalues() function can be used to retrieve them. If options equals ComputeEigenvectors, then the eigenvectors are also computed and can be retrieved by calling eigenvectors().
This implementation uses a symmetric QR algorithm. The matrix is first reduced to tridiagonal form using the Tridiagonalization class. The tridiagonal matrix is then brought to diagonal form with implicit symmetric QR steps with Wilkinson shift. Details can be found in Section 8.3 of Golub & Van Loan, Matrix Computations.
The cost of the computation is about
if the eigenvectors are required and
if they are not required.
This method reuses the memory in the SelfAdjointEigenSolver object that was allocated when the object was constructed, if the size of the matrix does not change.
Example:
Output:
Definition at line 400 of file SelfAdjointEigenSolver.h.
check_template_parameters();
const InputType &matrix(a_matrix.derived());
using std::abs;
eigen_assert(matrix.cols() == matrix.rows());
eigen_assert((options&~(EigVecMask|GenEigMask))==0
&& (options&EigVecMask)!=EigVecMask
&& "invalid option parameter");
bool computeEigenvectors = (options&ComputeEigenvectors)==ComputeEigenvectors;
Index n = matrix.cols();
m_eivalues.resize(n,1);
if(n==1)
m_eivalues.coeffRef(0,0) = numext::real(matrix(0,0));
if(computeEigenvectors)
m_eivec.setOnes(n,n);
m_info = Success;
m_isInitialized = true;
m_eigenvectorsOk = computeEigenvectors;
return *this;
// declare some aliases
RealVectorType& diag = m_eivalues;
EigenvectorsType& mat = m_eivec;
// map the matrix coefficients to [-1:1] to avoid over- and underflow.
mat = matrix.template triangularView<Lower>();
RealScalar scale = mat.cwiseAbs().maxCoeff();
if(scale==RealScalar(0)) scale = RealScalar(1);
mat.template triangularView<Lower>() /= scale;
m_subdiag.resize(n-1);
internal::tridiagonalization_inplace(mat, diag, m_subdiag, computeEigenvectors);
m_info = internal::computeFromTridiagonal_impl(diag, m_subdiag, m_maxIterations, computeEigenvectors, m_eivec);
// scale back the eigen values
m_eivalues *= scale;
return *this;
| EIGEN_DEVICE_FUNC SelfAdjointEigenSolver< MatrixType > & Eigen::SelfAdjointEigenSolver< MatrixType >::computeDirect | ( | const MatrixType & | matrix, |
This is a variant of compute(const MatrixType&, int options) which directly solves the underlying polynomial equation.
Currently only 2x2 and 3x3 matrices for which the sizes are known at compile time are supported (e.g., Matrix3d).
This method is usually significantly faster than the QR iterative algorithm but it might also be less accurate. It is also worth noting that for 3x3 matrices it involves trigonometric operations which are not necessarily available for all scalar types.
For the 3x3 case, we observed the following worst case relative error regarding the eigenvalues:
Definition at line 792 of file SelfAdjointEigenSolver.h.
internal::direct_selfadjoint_eigenvalues<SelfAdjointEigenSolver,Size,NumTraits<Scalar>::IsComplex>::run(*this,matrix,options);
return *this;
| SelfAdjointEigenSolver< MatrixType > & Eigen::SelfAdjointEigenSolver< MatrixType >::computeFromTridiagonal | ( | const RealVectorType & | diag, |
| const SubDiagonalType & | subdiag, | ||
| [in] | diag | The vector containing the diagonal of the matrix. |
| [in] | subdiag | The subdiagonal of the matrix. |
*this This function assumes that the matrix has been reduced to tridiagonal form.
Definition at line 450 of file SelfAdjointEigenSolver.h.
//TODO : Add an option to scale the values beforehand
m_eivalues = diag;
m_subdiag = subdiag;
if (computeEigenvectors)
m_eivec.setIdentity(diag.size(), diag.size());
m_info = computeFromTridiagonal_impl(m_eivalues, m_subdiag, m_maxIterations, computeEigenvectors, m_eivec);
return *this;
| EIGEN_DEVICE_FUNC const RealVectorType& Eigen::SelfAdjointEigenSolver< _MatrixType >::eigenvalues | ( | ) | const [inline] |
The eigenvalues are repeated according to their algebraic multiplicity, so there are as many eigenvalues as rows in the matrix. The eigenvalues are sorted in increasing order.
Example:
Output:
Definition at line 282 of file SelfAdjointEigenSolver.h.
eigen_assert(m_isInitialized && "SelfAdjointEigenSolver is not initialized.");
return m_eivalues;
| EIGEN_DEVICE_FUNC const EigenvectorsType& Eigen::SelfAdjointEigenSolver< _MatrixType >::eigenvectors | ( | ) | const [inline] |
Column
of the returned matrix is an eigenvector corresponding to eigenvalue number
as returned by eigenvalues(). The eigenvectors are normalized to have (Euclidean) norm equal to one. If this object was used to solve the eigenproblem for the selfadjoint matrix
, then the matrix returned by this function is the matrix
in the eigendecomposition
Example:
Output:
Definition at line 259 of file SelfAdjointEigenSolver.h.
eigen_assert(m_eigenvectorsOk && "The eigenvectors have not been computed together with the eigenvalues.");
return m_eivec;
| EIGEN_DEVICE_FUNC ComputationInfo Eigen::SelfAdjointEigenSolver< _MatrixType >::info | ( | ) | const [inline] |
Success if computation was succesful, NoConvergence otherwise. Definition at line 343 of file SelfAdjointEigenSolver.h.
return m_info;
| EIGEN_DEVICE_FUNC MatrixType Eigen::SelfAdjointEigenSolver< _MatrixType >::operatorInverseSqrt | ( | ) | const [inline] |
This function uses the eigendecomposition
to compute the inverse square root as
. This is cheaper than first computing the square root with operatorSqrt() and then its inverse with MatrixBase::inverse().
Example:
Output:
Definition at line 331 of file SelfAdjointEigenSolver.h.
return m_eivec * m_eivalues.cwiseInverse().cwiseSqrt().asDiagonal() * m_eivec.adjoint();
| EIGEN_DEVICE_FUNC MatrixType Eigen::SelfAdjointEigenSolver< _MatrixType >::operatorSqrt | ( | ) | const [inline] |
The square root of a positive-definite matrix
is the positive-definite matrix whose square equals
. This function uses the eigendecomposition
to compute the square root as
Example:
Output:
Definition at line 306 of file SelfAdjointEigenSolver.h.
return m_eivec * m_eivalues.cwiseSqrt().asDiagonal() * m_eivec.adjoint();
friend struct internal::direct_selfadjoint_eigenvalues< SelfAdjointEigenSolver, Size, NumTraits< Scalar >::IsComplex > [friend] |
Definition at line 96 of file SelfAdjointEigenSolver.h.
bool Eigen::SelfAdjointEigenSolver< _MatrixType >::m_eigenvectorsOk [protected] |
Definition at line 367 of file SelfAdjointEigenSolver.h.
RealVectorType Eigen::SelfAdjointEigenSolver< _MatrixType >::m_eivalues [protected] |
Definition at line 363 of file SelfAdjointEigenSolver.h.
EigenvectorsType Eigen::SelfAdjointEigenSolver< _MatrixType >::m_eivec [protected] |
Definition at line 362 of file SelfAdjointEigenSolver.h.
ComputationInfo Eigen::SelfAdjointEigenSolver< _MatrixType >::m_info [protected] |
Definition at line 365 of file SelfAdjointEigenSolver.h.
bool Eigen::SelfAdjointEigenSolver< _MatrixType >::m_isInitialized [protected] |
Definition at line 366 of file SelfAdjointEigenSolver.h.
const int Eigen::SelfAdjointEigenSolver< _MatrixType >::m_maxIterations = 30 [static] |
The algorithm terminates if it does not converge within m_maxIterations * n iterations, where n denotes the size of the matrix. This value is currently set to 30 (copied from LAPACK).
Definition at line 354 of file SelfAdjointEigenSolver.h.
TridiagonalizationType::SubDiagonalType Eigen::SelfAdjointEigenSolver< _MatrixType >::m_subdiag [protected] |
Definition at line 364 of file SelfAdjointEigenSolver.h.
