MOAB
4.9.3pre
Computes eigenvalues and eigenvectors of the generalized selfadjoint eigen problem. More...
#include <GeneralizedSelfAdjointEigenSolver.h>
Public Types | |
| typedef _MatrixType | MatrixType |
Public Member Functions | |
| GeneralizedSelfAdjointEigenSolver () | |
| Default constructor for fixed-size matrices. | |
| GeneralizedSelfAdjointEigenSolver (Index size) | |
| Constructor, pre-allocates memory for dynamic-size matrices. | |
| GeneralizedSelfAdjointEigenSolver (const MatrixType &matA, const MatrixType &matB, int options=ComputeEigenvectors|Ax_lBx) | |
| Constructor; computes generalized eigendecomposition of given matrix pencil. | |
| GeneralizedSelfAdjointEigenSolver & | compute (const MatrixType &matA, const MatrixType &matB, int options=ComputeEigenvectors|Ax_lBx) |
| Computes generalized eigendecomposition of given matrix pencil. | |
Private Types | |
| typedef SelfAdjointEigenSolver < _MatrixType > | Base |
| _MatrixType | the type of the matrix of which we are computing the eigendecomposition; this is expected to be an instantiation of the Matrix class template. |
This class solves the generalized eigenvalue problem
. In this case, the matrix
should be selfadjoint and the matrix
should be positive definite.
Only the lower triangular part of the input matrix is referenced.
Call the function compute() to compute the eigenvalues and eigenvectors of a given matrix. Alternatively, you can use the GeneralizedSelfAdjointEigenSolver(const MatrixType&, const MatrixType&, int) constructor which computes the eigenvalues and eigenvectors at construction time. Once the eigenvalue and eigenvectors are computed, they can be retrieved with the eigenvalues() and eigenvectors() functions.
The documentation for GeneralizedSelfAdjointEigenSolver(const MatrixType&, const MatrixType&, int) contains an example of the typical use of this class.
Definition at line 48 of file GeneralizedSelfAdjointEigenSolver.h.
typedef SelfAdjointEigenSolver<_MatrixType> Eigen::GeneralizedSelfAdjointEigenSolver< _MatrixType >::Base [private] |
Definition at line 50 of file GeneralizedSelfAdjointEigenSolver.h.
| typedef _MatrixType Eigen::GeneralizedSelfAdjointEigenSolver< _MatrixType >::MatrixType |
Reimplemented from Eigen::SelfAdjointEigenSolver< _MatrixType >.
Definition at line 53 of file GeneralizedSelfAdjointEigenSolver.h.
| Eigen::GeneralizedSelfAdjointEigenSolver< _MatrixType >::GeneralizedSelfAdjointEigenSolver | ( | ) | [inline] |
The default constructor is useful in cases in which the user intends to perform decompositions via compute(). This constructor can only be used if _MatrixType is a fixed-size matrix; use GeneralizedSelfAdjointEigenSolver(Index) for dynamic-size matrices.
Definition at line 62 of file GeneralizedSelfAdjointEigenSolver.h.
: Base() {}
| Eigen::GeneralizedSelfAdjointEigenSolver< _MatrixType >::GeneralizedSelfAdjointEigenSolver | ( | Index | size | ) | [inline, explicit] |
| [in] | size | Positive integer, size of the matrix whose eigenvalues and eigenvectors will be computed. |
This constructor is useful for dynamic-size matrices, when the user intends to perform decompositions via compute(). The size parameter is only used as a hint. It is not an error to give a wrong size, but it may impair performance.
Definition at line 76 of file GeneralizedSelfAdjointEigenSolver.h.
| Eigen::GeneralizedSelfAdjointEigenSolver< _MatrixType >::GeneralizedSelfAdjointEigenSolver | ( | const MatrixType & | matA, |
| const MatrixType & | matB, | ||
| int | options = ComputeEigenvectors|Ax_lBx |
| ) | [inline] |
| [in] | matA | Selfadjoint matrix in matrix pencil. Only the lower triangular part of the matrix is referenced. |
| [in] | matB | Positive-definite matrix in matrix pencil. Only the lower triangular part of the matrix is referenced. |
| [in] | options | A or-ed set of flags {ComputeEigenvectors,EigenvaluesOnly} | {Ax_lBx,ABx_lx,BAx_lx}. Default is ComputeEigenvectors|Ax_lBx. |
This constructor calls compute(const MatrixType&, const MatrixType&, int) to compute the eigenvalues and (if requested) the eigenvectors of the generalized eigenproblem
with matA the selfadjoint matrix
and matB the positive definite matrix
. Each eigenvector
satisfies the property
. The eigenvectors are computed if options contains ComputeEigenvectors.
In addition, the two following variants can be solved via options:
ABx_lx:
BAx_lx:
Example:
Output:
Definition at line 106 of file GeneralizedSelfAdjointEigenSolver.h.
| GeneralizedSelfAdjointEigenSolver< MatrixType > & Eigen::GeneralizedSelfAdjointEigenSolver< MatrixType >::compute | ( | const MatrixType & | matA, |
*this Accoring to options, this function computes eigenvalues and (if requested) the eigenvectors of one of the following three generalized eigenproblems:
Ax_lBx:
ABx_lx:
BAx_lx:
. In addition, each eigenvector
.The eigenvalues() function can be used to retrieve the eigenvalues. If options contains ComputeEigenvectors, then the eigenvectors are also computed and can be retrieved by calling eigenvectors().
The implementation uses LLT to compute the Cholesky decomposition
and computes the classical eigendecomposition of the selfadjoint matrix
if options contains Ax_lBx and of
otherwise. This solves the generalized eigenproblem, because any solution of the generalized eigenproblem
corresponds to a solution
of the eigenproblem for
. Similar statements can be made for the two other variants.
Example:
Output:
Definition at line 163 of file GeneralizedSelfAdjointEigenSolver.h.
eigen_assert(matA.cols()==matA.rows() && matB.rows()==matA.rows() && matB.cols()==matB.rows());
eigen_assert((options&~(EigVecMask|GenEigMask))==0
&& (options&EigVecMask)!=EigVecMask
&& ((options&GenEigMask)==0 || (options&GenEigMask)==Ax_lBx
|| (options&GenEigMask)==ABx_lx || (options&GenEigMask)==BAx_lx)
&& "invalid option parameter");
bool computeEigVecs = ((options&EigVecMask)==0) || ((options&EigVecMask)==ComputeEigenvectors);
// Compute the cholesky decomposition of matB = L L' = U'U
LLT<MatrixType> cholB(matB);
int type = (options&GenEigMask);
if(type==0)
type = Ax_lBx;
if(type==Ax_lBx)
// compute C = inv(L) A inv(L')
MatrixType matC = matA.template selfadjointView<Lower>();
cholB.matrixL().template solveInPlace<OnTheLeft>(matC);
cholB.matrixU().template solveInPlace<OnTheRight>(matC);
Base::compute(matC, computeEigVecs ? ComputeEigenvectors : EigenvaluesOnly );
// transform back the eigen vectors: evecs = inv(U) * evecs
if(computeEigVecs)
cholB.matrixU().solveInPlace(Base::m_eivec);
else if(type==ABx_lx)
// compute C = L' A L
matC = matC * cholB.matrixL();
matC = cholB.matrixU() * matC;
Base::compute(matC, computeEigVecs ? ComputeEigenvectors : EigenvaluesOnly);
if(computeEigVecs)
else if(type==BAx_lx)
// transform back the eigen vectors: evecs = L * evecs
if(computeEigVecs)
Base::m_eivec = cholB.matrixL() * Base::m_eivec;
return *this;
