MOAB
4.9.3pre
Tridiagonal decomposition of a selfadjoint matrix. More...
#include <Tridiagonalization.h>
Public Types | |
| enum | { Size = MatrixType::RowsAtCompileTime, SizeMinusOne = Size == Dynamic ? Dynamic : (Size > 1 ? Size - 1 : 1), Options = MatrixType::Options, MaxSize = MatrixType::MaxRowsAtCompileTime, MaxSizeMinusOne = MaxSize == Dynamic ? Dynamic : (MaxSize > 1 ? MaxSize - 1 : 1) } |
| typedef _MatrixType | MatrixType |
Synonym for the template parameter _MatrixType. | |
| typedef MatrixType::Scalar | Scalar |
| typedef NumTraits< Scalar >::Real | RealScalar |
| typedef Eigen::Index | Index |
| typedef Matrix< Scalar, SizeMinusOne, 1, Options &~RowMajor, MaxSizeMinusOne, 1 > | CoeffVectorType |
| typedef internal::plain_col_type < MatrixType, RealScalar > ::type | DiagonalType |
| typedef Matrix< RealScalar, SizeMinusOne, 1, Options &~RowMajor, MaxSizeMinusOne, 1 > | SubDiagonalType |
| typedef internal::remove_all < typename MatrixType::RealReturnType > ::type | MatrixTypeRealView |
| typedef internal::TridiagonalizationMatrixTReturnType < MatrixTypeRealView > | MatrixTReturnType |
| typedef internal::conditional < NumTraits< Scalar > ::IsComplex, typename internal::add_const_on_value_type < typename Diagonal< const MatrixType >::RealReturnType > ::type, const Diagonal< const MatrixType > >::type | DiagonalReturnType |
| typedef internal::conditional < NumTraits< Scalar > ::IsComplex, typename internal::add_const_on_value_type < typename Diagonal< const MatrixType,-1 > ::RealReturnType >::type, const Diagonal< const MatrixType,-1 > >::type | SubDiagonalReturnType |
| typedef HouseholderSequence < MatrixType, typename internal::remove_all< typename CoeffVectorType::ConjugateReturnType > ::type > | HouseholderSequenceType |
| Return type of matrixQ() | |
Public Member Functions | |
| Tridiagonalization (Index size=Size==Dynamic?2:Size) | |
| Default constructor. | |
| template<typename InputType > | |
| Tridiagonalization (const EigenBase< InputType > &matrix) | |
| Constructor; computes tridiagonal decomposition of given matrix. | |
| Tridiagonalization & | compute (const EigenBase< InputType > &matrix) |
| Computes tridiagonal decomposition of given matrix. | |
| CoeffVectorType | householderCoefficients () const |
| Returns the Householder coefficients. | |
| const MatrixType & | packedMatrix () const |
| Returns the internal representation of the decomposition. | |
| HouseholderSequenceType | matrixQ () const |
| Returns the unitary matrix Q in the decomposition. | |
| MatrixTReturnType | matrixT () const |
| Returns an expression of the tridiagonal matrix T in the decomposition. | |
| DiagonalReturnType | diagonal () const |
| Returns the diagonal of the tridiagonal matrix T in the decomposition. | |
| SubDiagonalReturnType | subDiagonal () const |
| Returns the subdiagonal of the tridiagonal matrix T in the decomposition. | |
Protected Attributes | |
| MatrixType | m_matrix |
| CoeffVectorType | m_hCoeffs |
| bool | m_isInitialized |
| _MatrixType | the type of the matrix of which we are computing the tridiagonal decomposition; this is expected to be an instantiation of the Matrix class template. |
This class performs a tridiagonal decomposition of a selfadjoint matrix
such that:
where
is unitary and
a real symmetric tridiagonal matrix.
A tridiagonal matrix is a matrix which has nonzero elements only on the main diagonal and the first diagonal below and above it. The Hessenberg decomposition of a selfadjoint matrix is in fact a tridiagonal decomposition. This class is used in SelfAdjointEigenSolver to compute the eigenvalues and eigenvectors of a selfadjoint matrix.
Call the function compute() to compute the tridiagonal decomposition of a given matrix. Alternatively, you can use the Tridiagonalization(const MatrixType&) constructor which computes the tridiagonal Schur decomposition at construction time. Once the decomposition is computed, you can use the matrixQ() and matrixT() functions to retrieve the matrices Q and T in the decomposition.
The documentation of Tridiagonalization(const MatrixType&) contains an example of the typical use of this class.
Definition at line 63 of file Tridiagonalization.h.
| typedef Matrix<Scalar, SizeMinusOne, 1, Options & ~RowMajor, MaxSizeMinusOne, 1> Eigen::Tridiagonalization< _MatrixType >::CoeffVectorType |
Definition at line 82 of file Tridiagonalization.h.
| typedef internal::conditional<NumTraits<Scalar>::IsComplex, typename internal::add_const_on_value_type<typename Diagonal<const MatrixType>::RealReturnType>::type, const Diagonal<const MatrixType> >::type Eigen::Tridiagonalization< _MatrixType >::DiagonalReturnType |
Definition at line 91 of file Tridiagonalization.h.
| typedef internal::plain_col_type<MatrixType, RealScalar>::type Eigen::Tridiagonalization< _MatrixType >::DiagonalType |
Definition at line 83 of file Tridiagonalization.h.
| typedef HouseholderSequence<MatrixType,typename internal::remove_all<typename CoeffVectorType::ConjugateReturnType>::type> Eigen::Tridiagonalization< _MatrixType >::HouseholderSequenceType |
Definition at line 99 of file Tridiagonalization.h.
| typedef Eigen::Index Eigen::Tridiagonalization< _MatrixType >::Index |
Definition at line 72 of file Tridiagonalization.h.
| typedef internal::TridiagonalizationMatrixTReturnType<MatrixTypeRealView> Eigen::Tridiagonalization< _MatrixType >::MatrixTReturnType |
Definition at line 86 of file Tridiagonalization.h.
| typedef _MatrixType Eigen::Tridiagonalization< _MatrixType >::MatrixType |
Definition at line 68 of file Tridiagonalization.h.
| typedef internal::remove_all<typename MatrixType::RealReturnType>::type Eigen::Tridiagonalization< _MatrixType >::MatrixTypeRealView |
Definition at line 85 of file Tridiagonalization.h.
| typedef NumTraits<Scalar>::Real Eigen::Tridiagonalization< _MatrixType >::RealScalar |
Definition at line 71 of file Tridiagonalization.h.
| typedef MatrixType::Scalar Eigen::Tridiagonalization< _MatrixType >::Scalar |
Definition at line 70 of file Tridiagonalization.h.
| typedef internal::conditional<NumTraits<Scalar>::IsComplex, typename internal::add_const_on_value_type<typename Diagonal<const MatrixType, -1>::RealReturnType>::type, const Diagonal<const MatrixType, -1> >::type Eigen::Tridiagonalization< _MatrixType >::SubDiagonalReturnType |
Definition at line 96 of file Tridiagonalization.h.
| typedef Matrix<RealScalar, SizeMinusOne, 1, Options & ~RowMajor, MaxSizeMinusOne, 1> Eigen::Tridiagonalization< _MatrixType >::SubDiagonalType |
Definition at line 84 of file Tridiagonalization.h.
| anonymous enum |
Definition at line 74 of file Tridiagonalization.h.
| Eigen::Tridiagonalization< _MatrixType >::Tridiagonalization | ( | Index | size = Size==Dynamic ? 2 : Size | ) | [inline, explicit] |
| [in] | size | Positive integer, size of the matrix whose tridiagonal decomposition will be computed. |
The default constructor is useful in cases in which the user intends to perform decompositions via compute(). The size parameter is only used as a hint. It is not an error to give a wrong size, but it may impair performance.
Definition at line 113 of file Tridiagonalization.h.
| Eigen::Tridiagonalization< _MatrixType >::Tridiagonalization | ( | const EigenBase< InputType > & | matrix | ) | [inline, explicit] |
| [in] | matrix | Selfadjoint matrix whose tridiagonal decomposition is to be computed. |
This constructor calls compute() to compute the tridiagonal decomposition.
Example:
Output:
Definition at line 130 of file Tridiagonalization.h.
: m_matrix(matrix.derived()), m_hCoeffs(matrix.cols() > 1 ? matrix.cols()-1 : 1), m_isInitialized(false) { internal::tridiagonalization_inplace(m_matrix, m_hCoeffs); m_isInitialized = true; }
| Tridiagonalization& Eigen::Tridiagonalization< _MatrixType >::compute | ( | const EigenBase< InputType > & | matrix | ) | [inline] |
*this The tridiagonal decomposition is computed by bringing the columns of the matrix successively in the required form using Householder reflections. The cost is
flops, where
denotes the size of the given matrix.
This method reuses of the allocated data in the Tridiagonalization object, if the size of the matrix does not change.
Example:
Output:
Definition at line 157 of file Tridiagonalization.h.
m_matrix = matrix.derived();
m_hCoeffs.resize(matrix.rows()-1, 1);
return *this;
| Tridiagonalization< MatrixType >::DiagonalReturnType Eigen::Tridiagonalization< MatrixType >::diagonal | ( | ) | const |
Example:
Output:
Definition at line 307 of file Tridiagonalization.h.
eigen_assert(m_isInitialized && "Tridiagonalization is not initialized.");
return m_matrix.diagonal().real();
| CoeffVectorType Eigen::Tridiagonalization< _MatrixType >::householderCoefficients | ( | ) | const [inline] |
The Householder coefficients allow the reconstruction of the matrix
in the tridiagonal decomposition from the packed data.
Example:
Output:
Definition at line 182 of file Tridiagonalization.h.
return m_hCoeffs;
| HouseholderSequenceType Eigen::Tridiagonalization< _MatrixType >::matrixQ | ( | ) | const [inline] |
This function returns a light-weight object of template class HouseholderSequence. You can either apply it directly to a matrix or you can convert it to a matrix of type MatrixType.
Definition at line 240 of file Tridiagonalization.h.
return HouseholderSequenceType(m_matrix, m_hCoeffs.conjugate())
.setLength(m_matrix.rows() - 1)
.setShift(1);
| MatrixTReturnType Eigen::Tridiagonalization< _MatrixType >::matrixT | ( | ) | const [inline] |
Currently, this function can be used to extract the matrix T from internal data and copy it to a dense matrix object. In most cases, it may be sufficient to directly use the packed matrix or the vector expressions returned by diagonal() and subDiagonal() instead of creating a new dense copy matrix with this function.
Definition at line 265 of file Tridiagonalization.h.
return MatrixTReturnType(m_matrix.real());
| const MatrixType& Eigen::Tridiagonalization< _MatrixType >::packedMatrix | ( | ) | const [inline] |
The returned matrix contains the following information:
. Here, the matrices
are the Householder transformations
where
is the
th Householder coefficient and
is the Householder vector defined by
with M the matrix returned by this function.See LAPACK for further details on this packed storage.
Example:
Output:
Definition at line 219 of file Tridiagonalization.h.
return m_matrix;
| Tridiagonalization< MatrixType >::SubDiagonalReturnType Eigen::Tridiagonalization< MatrixType >::subDiagonal | ( | ) | const |
Definition at line 315 of file Tridiagonalization.h.
return m_matrix.template diagonal<-1>().real();
CoeffVectorType Eigen::Tridiagonalization< _MatrixType >::m_hCoeffs [protected] |
Definition at line 301 of file Tridiagonalization.h.
bool Eigen::Tridiagonalization< _MatrixType >::m_isInitialized [protected] |
Definition at line 302 of file Tridiagonalization.h.
MatrixType Eigen::Tridiagonalization< _MatrixType >::m_matrix [protected] |
Definition at line 300 of file Tridiagonalization.h.
