MOAB
4.9.3pre
Sequence of Householder reflections acting on subspaces with decreasing size. More...
#include <HouseholderSequence.h>
Public Types | |
| enum | { RowsAtCompileTime = internal::traits<HouseholderSequence>::RowsAtCompileTime, ColsAtCompileTime = internal::traits<HouseholderSequence>::ColsAtCompileTime, MaxRowsAtCompileTime = internal::traits<HouseholderSequence>::MaxRowsAtCompileTime, MaxColsAtCompileTime = internal::traits<HouseholderSequence>::MaxColsAtCompileTime } |
| typedef internal::traits < HouseholderSequence > ::Scalar | Scalar |
| typedef HouseholderSequence < typename internal::conditional < NumTraits< Scalar > ::IsComplex, typename internal::remove_all< typename VectorsType::ConjugateReturnType > ::type, VectorsType >::type, typename internal::conditional < NumTraits< Scalar > ::IsComplex, typename internal::remove_all< typename CoeffsType::ConjugateReturnType > ::type, CoeffsType >::type, Side > | ConjugateReturnType |
Public Member Functions | |
| HouseholderSequence (const VectorsType &v, const CoeffsType &h) | |
| Constructor. | |
| HouseholderSequence (const HouseholderSequence &other) | |
| Copy constructor. | |
| Index | rows () const |
| Number of rows of transformation viewed as a matrix. | |
| Index | cols () const |
| Number of columns of transformation viewed as a matrix. | |
| const EssentialVectorType | essentialVector (Index k) const |
| Essential part of a Householder vector. | |
| HouseholderSequence | transpose () const |
| Transpose of the Householder sequence. | |
| ConjugateReturnType | conjugate () const |
| Complex conjugate of the Householder sequence. | |
| ConjugateReturnType | adjoint () const |
| Adjoint (conjugate transpose) of the Householder sequence. | |
| ConjugateReturnType | inverse () const |
| Inverse of the Householder sequence (equals the adjoint). | |
| template<typename DestType > | |
| void | evalTo (DestType &dst) const |
| template<typename Dest , typename Workspace > | |
| void | evalTo (Dest &dst, Workspace &workspace) const |
| template<typename Dest > | |
| void | applyThisOnTheRight (Dest &dst) const |
| void | applyThisOnTheRight (Dest &dst, Workspace &workspace) const |
| void | applyThisOnTheLeft (Dest &dst) const |
| void | applyThisOnTheLeft (Dest &dst, Workspace &workspace) const |
| template<typename OtherDerived > | |
| internal::matrix_type_times_scalar_type < Scalar, OtherDerived >::Type | operator* (const MatrixBase< OtherDerived > &other) const |
| Computes the product of a Householder sequence with a matrix. | |
| HouseholderSequence & | setLength (Index length) |
| Sets the length of the Householder sequence. | |
| HouseholderSequence & | setShift (Index shift) |
| Sets the shift of the Householder sequence. | |
| Index | length () const |
| Returns the length of the Householder sequence. | |
| Index | shift () const |
| Returns the shift of the Householder sequence. | |
Protected Member Functions | |
| HouseholderSequence & | setTrans (bool trans) |
| Sets the transpose flag. | |
| bool | trans () const |
| Returns the transpose flag. | |
Protected Attributes | |
| VectorsType::Nested | m_vectors |
| CoeffsType::Nested | m_coeffs |
| bool | m_trans |
| Index | m_length |
| Index | m_shift |
Private Types | |
| typedef internal::hseq_side_dependent_impl < VectorsType, CoeffsType, Side >::EssentialVectorType | EssentialVectorType |
Friends | |
| struct | internal::hseq_side_dependent_impl |
| class | HouseholderSequence |
| VectorsType | type of matrix containing the Householder vectors |
| CoeffsType | type of vector containing the Householder coefficients |
| Side | either OnTheLeft (the default) or OnTheRight |
This class represents a product sequence of Householder reflections where the first Householder reflection acts on the whole space, the second Householder reflection leaves the one-dimensional subspace spanned by the first unit vector invariant, the third Householder reflection leaves the two-dimensional subspace spanned by the first two unit vectors invariant, and so on up to the last reflection which leaves all but one dimensions invariant and acts only on the last dimension. Such sequences of Householder reflections are used in several algorithms to zero out certain parts of a matrix. Indeed, the methods HessenbergDecomposition::matrixQ(), Tridiagonalization::matrixQ(), HouseholderQR::householderQ(), and ColPivHouseholderQR::householderQ() all return a HouseholderSequence.
More precisely, the class HouseholderSequence represents an
matrix
of the form
where the i-th Householder reflection is
. The i-th Householder coefficient
is a scalar and the i-th Householder vector
is a vector of the form
The last
entries of
are called the essential part of the Householder vector.
Typical usages are listed below, where H is a HouseholderSequence:
A.applyOnTheRight(H); // A = A * H A.applyOnTheLeft(H); // A = H * A A.applyOnTheRight(H.adjoint()); // A = A * H^* A.applyOnTheLeft(H.adjoint()); // A = H^* * A MatrixXd Q = H; // conversion to a dense matrix
In addition to the adjoint, you can also apply the inverse (=adjoint), the transpose, and the conjugate operators.
See the documentation for HouseholderSequence(const VectorsType&, const CoeffsType&) for an example.
Definition at line 119 of file HouseholderSequence.h.
| typedef HouseholderSequence< typename internal::conditional<NumTraits<Scalar>::IsComplex, typename internal::remove_all<typename VectorsType::ConjugateReturnType>::type, VectorsType>::type, typename internal::conditional<NumTraits<Scalar>::IsComplex, typename internal::remove_all<typename CoeffsType::ConjugateReturnType>::type, CoeffsType>::type, Side > Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::ConjugateReturnType |
Definition at line 141 of file HouseholderSequence.h.
typedef internal::hseq_side_dependent_impl<VectorsType,CoeffsType,Side>::EssentialVectorType Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::EssentialVectorType [private] |
Definition at line 122 of file HouseholderSequence.h.
| typedef internal::traits<HouseholderSequence>::Scalar Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::Scalar |
Definition at line 131 of file HouseholderSequence.h.
| anonymous enum |
Definition at line 125 of file HouseholderSequence.h.
| Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::HouseholderSequence | ( | const VectorsType & | v, |
| const CoeffsType & | h | ||
| ) | [inline] |
Constructor.
| [in] | v | Matrix containing the essential parts of the Householder vectors |
| [in] | h | Vector containing the Householder coefficients |
Constructs the Householder sequence with coefficients given by h and vectors given by v. The i-th Householder coefficient
is given by h(i) and the essential part of the i-th Householder vector
is given by v(k,i) with k > i (the subdiagonal part of the i-th column). If v has fewer columns than rows, then the Householder sequence contains as many Householder reflections as there are columns.
v and h by reference.Example:
Output:
Definition at line 160 of file HouseholderSequence.h.
| Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::HouseholderSequence | ( | const HouseholderSequence< VectorsType, CoeffsType, Side > & | other | ) | [inline] |
| ConjugateReturnType Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::adjoint | ( | ) | const [inline] |
Definition at line 224 of file HouseholderSequence.h.
| void Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::applyThisOnTheLeft | ( | Dest & | dst | ) | const [inline] |
Reimplemented from Eigen::EigenBase< HouseholderSequence< VectorsType, CoeffsType, Side > >.
Definition at line 306 of file HouseholderSequence.h.
Matrix<Scalar,1,Dest::ColsAtCompileTime,RowMajor,1,Dest::MaxColsAtCompileTime> workspace(dst.cols());
applyThisOnTheLeft(dst, workspace);
| void Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::applyThisOnTheLeft | ( | Dest & | dst, |
| Workspace & | workspace | ||
Definition at line 314 of file HouseholderSequence.h.
const Index BlockSize = 48;
// if the entries are large enough, then apply the reflectors by block
if(m_length>=BlockSize && dst.cols()>1)
for(Index i = 0; i < m_length; i+=BlockSize)
Index end = m_trans ? (std::min)(m_length,i+BlockSize) : m_length-i;
Index k = m_trans ? i : (std::max)(Index(0),end-BlockSize);
Index bs = end-k;
Index start = k + m_shift;
typedef Block<typename internal::remove_all<VectorsType>::type,Dynamic,Dynamic> SubVectorsType;
SubVectorsType sub_vecs1(m_vectors.const_cast_derived(), Side==OnTheRight ? k : start,
Side==OnTheRight ? start : k,
Side==OnTheRight ? bs : m_vectors.rows()-start,
Side==OnTheRight ? m_vectors.cols()-start : bs);
typename internal::conditional<Side==OnTheRight, Transpose<SubVectorsType>, SubVectorsType&>::type sub_vecs(sub_vecs1);
Block<Dest,Dynamic,Dynamic> sub_dst(dst,dst.rows()-rows()+m_shift+k,0, rows()-m_shift-k,dst.cols());
apply_block_householder_on_the_left(sub_dst, sub_vecs, m_coeffs.segment(k, bs), !m_trans);
else
workspace.resize(dst.cols());
for(Index k = 0; k < m_length; ++k)
Index actual_k = m_trans ? k : m_length-k-1;
dst.bottomRows(rows()-m_shift-actual_k)
.applyHouseholderOnTheLeft(essentialVector(actual_k), m_coeffs.coeff(actual_k), workspace.data());
| void Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::applyThisOnTheRight | ( | Dest & | dst | ) | const [inline] |
Definition at line 286 of file HouseholderSequence.h.
Matrix<Scalar,1,Dest::RowsAtCompileTime,RowMajor,1,Dest::MaxRowsAtCompileTime> workspace(dst.rows());
applyThisOnTheRight(dst, workspace);
| void Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::applyThisOnTheRight | ( | Dest & | dst, |
Definition at line 294 of file HouseholderSequence.h.
| Index Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::cols | ( | void | ) | const [inline] |
This equals the dimension of the space that the transformation acts on.
Definition at line 186 of file HouseholderSequence.h.
{ return rows(); }
| ConjugateReturnType Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::conjugate | ( | ) | const [inline] |
| const EssentialVectorType Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::essentialVector | ( | Index | k | ) | const [inline] |
| [in] | k | Index of Householder reflection |
This function returns the essential part of the Householder vector
. This is a vector of length
containing the last
entries of the vector
The index
equals k + shift(), corresponding to the k-th column of the matrix v passed to the constructor.
Definition at line 202 of file HouseholderSequence.h.
eigen_assert(k >= 0 && k < m_length);
return internal::hseq_side_dependent_impl<VectorsType,CoeffsType,Side>::essentialVector(*this, k);
| void Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::evalTo | ( | DestType & | dst | ) | const [inline] |
Definition at line 233 of file HouseholderSequence.h.
Matrix<Scalar, DestType::RowsAtCompileTime, 1,
AutoAlign|ColMajor, DestType::MaxRowsAtCompileTime, 1> workspace(rows());
evalTo(dst, workspace);
| void Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::evalTo | ( | Dest & | dst, |
Definition at line 242 of file HouseholderSequence.h.
workspace.resize(rows());
Index vecs = m_length;
if( internal::is_same<typename internal::remove_all<VectorsType>::type,Dest>::value
&& internal::extract_data(dst) == internal::extract_data(m_vectors))
// in-place
dst.diagonal().setOnes();
dst.template triangularView<StrictlyUpper>().setZero();
for(Index k = vecs-1; k >= 0; --k)
Index cornerSize = rows() - k - m_shift;
if(m_trans)
dst.bottomRightCorner(cornerSize, cornerSize)
.applyHouseholderOnTheRight(essentialVector(k), m_coeffs.coeff(k), workspace.data());
else
.applyHouseholderOnTheLeft(essentialVector(k), m_coeffs.coeff(k), workspace.data());
// clear the off diagonal vector
dst.col(k).tail(rows()-k-1).setZero();
// clear the remaining columns if needed
for(Index k = 0; k<cols()-vecs ; ++k)
else
dst.setIdentity(rows(), rows());
if(m_trans)
.applyHouseholderOnTheRight(essentialVector(k), m_coeffs.coeff(k), &workspace.coeffRef(0));
else
.applyHouseholderOnTheLeft(essentialVector(k), m_coeffs.coeff(k), &workspace.coeffRef(0));
| ConjugateReturnType Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::inverse | ( | ) | const [inline] |
Definition at line 230 of file HouseholderSequence.h.
{ return adjoint(); }
| Index Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::length | ( | ) | const [inline] |
Definition at line 399 of file HouseholderSequence.h.
| internal::matrix_type_times_scalar_type<Scalar, OtherDerived>::Type Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::operator* | ( | const MatrixBase< OtherDerived > & | other | ) | const [inline] |
| [in] | other | Matrix being multiplied. |
This function computes
where
is the Householder sequence represented by *this and
is the matrix other.
Definition at line 357 of file HouseholderSequence.h.
typename internal::matrix_type_times_scalar_type<Scalar, OtherDerived>::Type
res(other.template cast<typename internal::matrix_type_times_scalar_type<Scalar,OtherDerived>::ResultScalar>());
applyThisOnTheLeft(res);
return res;
| Index Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::rows | ( | void | ) | const [inline] |
Definition at line 180 of file HouseholderSequence.h.
| HouseholderSequence& Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::setLength | ( | Index | length | ) | [inline] |
| [in] | length | New value for the length. |
By default, the length
is set to the number of columns of the matrix v passed to the constructor, or the number of rows if that is smaller. After this function is called, the length equals length.
Definition at line 376 of file HouseholderSequence.h.
| HouseholderSequence& Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::setShift | ( | Index | shift | ) | [inline] |
| [in] | shift | New value for the shift. |
By default, a HouseholderSequence object represents
and the i-th column of the matrix v passed to the constructor corresponds to the i-th Householder reflection. After this function is called, the object represents
and the i-th column of v corresponds to the (shift+i)-th Householder reflection.
Definition at line 393 of file HouseholderSequence.h.
| HouseholderSequence& Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::setTrans | ( | bool | trans | ) | [inline, protected] |
| [in] | trans | New value of the transpose flag. |
By default, the transpose flag is not set. If the transpose flag is set, then this object represents
instead of
Definition at line 415 of file HouseholderSequence.h.
| Index Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::shift | ( | ) | const [inline] |
Definition at line 400 of file HouseholderSequence.h.
| bool Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::trans | ( | ) | const [inline, protected] |
Definition at line 421 of file HouseholderSequence.h.
| HouseholderSequence Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::transpose | ( | ) | const [inline] |
Definition at line 209 of file HouseholderSequence.h.
return HouseholderSequence(*this).setTrans(!m_trans);
friend class HouseholderSequence [friend] |
Definition at line 403 of file HouseholderSequence.h.
friend struct internal::hseq_side_dependent_impl [friend] |
Definition at line 365 of file HouseholderSequence.h.
CoeffsType::Nested Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::m_coeffs [protected] |
Definition at line 424 of file HouseholderSequence.h.
Index Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::m_length [protected] |
Definition at line 426 of file HouseholderSequence.h.
Index Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::m_shift [protected] |
Definition at line 427 of file HouseholderSequence.h.
bool Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::m_trans [protected] |
Definition at line 425 of file HouseholderSequence.h.
VectorsType::Nested Eigen::HouseholderSequence< VectorsType, CoeffsType, Side >::m_vectors [protected] |
Definition at line 423 of file HouseholderSequence.h.
