MOAB
4.9.3pre
Reduces a square matrix to Hessenberg form by an orthogonal similarity transformation. More...
#include <HessenbergDecomposition.h>
Public Types | |
| enum | { Size = MatrixType::RowsAtCompileTime, SizeMinusOne = Size == Dynamic ? Dynamic : Size - 1, Options = MatrixType::Options, MaxSize = MatrixType::MaxRowsAtCompileTime, MaxSizeMinusOne = MaxSize == Dynamic ? Dynamic : MaxSize - 1 } |
| typedef _MatrixType | MatrixType |
Synonym for the template parameter _MatrixType. | |
| typedef MatrixType::Scalar | Scalar |
| Scalar type for matrices of type MatrixType. | |
| typedef Eigen::Index | Index |
| typedef Matrix< Scalar, SizeMinusOne, 1, Options &~RowMajor, MaxSizeMinusOne, 1 > | CoeffVectorType |
| Type for vector of Householder coefficients. | |
| typedef HouseholderSequence < MatrixType, typename internal::remove_all< typename CoeffVectorType::ConjugateReturnType > ::type > | HouseholderSequenceType |
| Return type of matrixQ() | |
| typedef internal::HessenbergDecompositionMatrixHReturnType < MatrixType > | MatrixHReturnType |
Public Member Functions | |
| HessenbergDecomposition (Index size=Size==Dynamic?2:Size) | |
| Default constructor; the decomposition will be computed later. | |
| template<typename InputType > | |
| HessenbergDecomposition (const EigenBase< InputType > &matrix) | |
| Constructor; computes Hessenberg decomposition of given matrix. | |
| HessenbergDecomposition & | compute (const EigenBase< InputType > &matrix) |
| Computes Hessenberg decomposition of given matrix. | |
| const CoeffVectorType & | householderCoefficients () const |
| Returns the Householder coefficients. | |
| const MatrixType & | packedMatrix () const |
| Returns the internal representation of the decomposition. | |
| HouseholderSequenceType | matrixQ () const |
| Reconstructs the orthogonal matrix Q in the decomposition. | |
| MatrixHReturnType | matrixH () const |
| Constructs the Hessenberg matrix H in the decomposition. | |
Protected Attributes | |
| MatrixType | m_matrix |
| CoeffVectorType | m_hCoeffs |
| VectorType | m_temp |
| bool | m_isInitialized |
Private Types | |
| typedef Matrix< Scalar, 1, Size, Options|RowMajor, 1, MaxSize > | VectorType |
| typedef NumTraits< Scalar >::Real | RealScalar |
Static Private Member Functions | |
| static void | _compute (MatrixType &matA, CoeffVectorType &hCoeffs, VectorType &temp) |
| _MatrixType | the type of the matrix of which we are computing the Hessenberg decomposition |
This class performs an Hessenberg decomposition of a matrix
. In the real case, the Hessenberg decomposition consists of an orthogonal matrix
and a Hessenberg matrix
such that
. An orthogonal matrix is a matrix whose inverse equals its transpose (
). A Hessenberg matrix has zeros below the subdiagonal, so it is almost upper triangular. The Hessenberg decomposition of a complex matrix is
with
unitary (that is,
Call the function compute() to compute the Hessenberg decomposition of a given matrix. Alternatively, you can use the HessenbergDecomposition(const MatrixType&) constructor which computes the Hessenberg decomposition at construction time. Once the decomposition is computed, you can use the matrixH() and matrixQ() functions to construct the matrices H and Q in the decomposition.
The documentation for matrixH() contains an example of the typical use of this class.
Definition at line 57 of file HessenbergDecomposition.h.
| typedef Matrix<Scalar, SizeMinusOne, 1, Options & ~RowMajor, MaxSizeMinusOne, 1> Eigen::HessenbergDecomposition< _MatrixType >::CoeffVectorType |
This is column vector with entries of type Scalar. The length of the vector is one less than the size of MatrixType, if it is a fixed-side type.
Definition at line 82 of file HessenbergDecomposition.h.
| typedef HouseholderSequence<MatrixType,typename internal::remove_all<typename CoeffVectorType::ConjugateReturnType>::type> Eigen::HessenbergDecomposition< _MatrixType >::HouseholderSequenceType |
Definition at line 85 of file HessenbergDecomposition.h.
| typedef Eigen::Index Eigen::HessenbergDecomposition< _MatrixType >::Index |
Definition at line 74 of file HessenbergDecomposition.h.
| typedef internal::HessenbergDecompositionMatrixHReturnType<MatrixType> Eigen::HessenbergDecomposition< _MatrixType >::MatrixHReturnType |
Definition at line 87 of file HessenbergDecomposition.h.
| typedef _MatrixType Eigen::HessenbergDecomposition< _MatrixType >::MatrixType |
Definition at line 62 of file HessenbergDecomposition.h.
typedef NumTraits<Scalar>::Real Eigen::HessenbergDecomposition< _MatrixType >::RealScalar [private] |
Definition at line 271 of file HessenbergDecomposition.h.
| typedef MatrixType::Scalar Eigen::HessenbergDecomposition< _MatrixType >::Scalar |
Definition at line 73 of file HessenbergDecomposition.h.
typedef Matrix<Scalar, 1, Size, Options | RowMajor, 1, MaxSize> Eigen::HessenbergDecomposition< _MatrixType >::VectorType [private] |
Definition at line 270 of file HessenbergDecomposition.h.
| anonymous enum |
Definition at line 64 of file HessenbergDecomposition.h.
| Eigen::HessenbergDecomposition< _MatrixType >::HessenbergDecomposition | ( | Index | size = Size==Dynamic ? 2 : Size | ) | [inline, explicit] |
| [in] | size | The size of the matrix whose Hessenberg decomposition will be computed. |
The default constructor is useful in cases in which the user intends to perform decompositions via compute(). The size parameter is only used as a hint. It is not an error to give a wrong size, but it may impair performance.
Definition at line 100 of file HessenbergDecomposition.h.
| Eigen::HessenbergDecomposition< _MatrixType >::HessenbergDecomposition | ( | const EigenBase< InputType > & | matrix | ) | [inline, explicit] |
| [in] | matrix | Square matrix whose Hessenberg decomposition is to be computed. |
This constructor calls compute() to compute the Hessenberg decomposition.
Definition at line 119 of file HessenbergDecomposition.h.
: m_matrix(matrix.derived()), m_temp(matrix.rows()), m_isInitialized(false) { if(matrix.rows()<2) { m_isInitialized = true; return; } m_hCoeffs.resize(matrix.rows()-1,1); _compute(m_matrix, m_hCoeffs, m_temp); m_isInitialized = true; }
| void Eigen::HessenbergDecomposition< MatrixType >::_compute | ( | MatrixType & | matA, |
| CoeffVectorType & | hCoeffs, | ||
| VectorType & | temp | ||
| ) | [static, private] |
Performs a tridiagonal decomposition of matA in place.
| matA | the input selfadjoint matrix |
| hCoeffs | returned Householder coefficients |
The result is written in the lower triangular part of matA.
Implemented from Golub's "%Matrix Computations", algorithm 8.3.1.
Definition at line 294 of file HessenbergDecomposition.h.
eigen_assert(matA.rows()==matA.cols());
Index n = matA.rows();
temp.resize(n);
for (Index i = 0; i<n-1; ++i)
// let's consider the vector v = i-th column starting at position i+1
Index remainingSize = n-i-1;
RealScalar beta;
Scalar h;
matA.col(i).tail(remainingSize).makeHouseholderInPlace(h, beta);
matA.col(i).coeffRef(i+1) = beta;
hCoeffs.coeffRef(i) = h;
// Apply similarity transformation to remaining columns,
// i.e., compute A = H A H'
// A = H A
matA.bottomRightCorner(remainingSize, remainingSize)
.applyHouseholderOnTheLeft(matA.col(i).tail(remainingSize-1), h, &temp.coeffRef(0));
// A = A H'
matA.rightCols(remainingSize)
.applyHouseholderOnTheRight(matA.col(i).tail(remainingSize-1).conjugate(), numext::conj(h), &temp.coeffRef(0));
| HessenbergDecomposition& Eigen::HessenbergDecomposition< _MatrixType >::compute | ( | const EigenBase< InputType > & | matrix | ) | [inline] |
*this The Hessenberg decomposition is computed by bringing the columns of the matrix successively in the required form using Householder reflections (see, e.g., Algorithm 7.4.2 in Golub & Van Loan, Matrix Computations). The cost is
flops, where
denotes the size of the given matrix.
This method reuses of the allocated data in the HessenbergDecomposition object.
Example:
Output:
Definition at line 152 of file HessenbergDecomposition.h.
m_matrix = matrix.derived();
if(matrix.rows()<2)
return *this;
return *this;
| const CoeffVectorType& Eigen::HessenbergDecomposition< _MatrixType >::householderCoefficients | ( | ) | const [inline] |
The Householder coefficients allow the reconstruction of the matrix
in the Hessenberg decomposition from the packed data.
Definition at line 179 of file HessenbergDecomposition.h.
eigen_assert(m_isInitialized && "HessenbergDecomposition is not initialized.");
return m_hCoeffs;
| MatrixHReturnType Eigen::HessenbergDecomposition< _MatrixType >::matrixH | ( | ) | const [inline] |
The object returned by this function constructs the Hessenberg matrix H when it is assigned to a matrix or otherwise evaluated. The matrix H is constructed from the packed matrix as returned by packedMatrix(): The upper part (including the subdiagonal) of the packed matrix contains the matrix H. It may sometimes be better to directly use the packed matrix instead of constructing the matrix H.
Example:
Output:
Definition at line 262 of file HessenbergDecomposition.h.
return MatrixHReturnType(*this);
| HouseholderSequenceType Eigen::HessenbergDecomposition< _MatrixType >::matrixQ | ( | ) | const [inline] |
This function returns a light-weight object of template class HouseholderSequence. You can either apply it directly to a matrix or you can convert it to a matrix of type MatrixType.
Definition at line 234 of file HessenbergDecomposition.h.
return HouseholderSequenceType(m_matrix, m_hCoeffs.conjugate())
.setLength(m_matrix.rows() - 1)
.setShift(1);
| const MatrixType& Eigen::HessenbergDecomposition< _MatrixType >::packedMatrix | ( | ) | const [inline] |
The returned matrix contains the following information:
. Here, the matrices
are the Householder transformations
where
is the
th Householder coefficient and
is the Householder vector defined by
with M the matrix returned by this function.See LAPACK for further details on this packed storage.
Example:
Output:
Definition at line 214 of file HessenbergDecomposition.h.
return m_matrix;
CoeffVectorType Eigen::HessenbergDecomposition< _MatrixType >::m_hCoeffs [protected] |
Definition at line 276 of file HessenbergDecomposition.h.
bool Eigen::HessenbergDecomposition< _MatrixType >::m_isInitialized [protected] |
Definition at line 278 of file HessenbergDecomposition.h.
MatrixType Eigen::HessenbergDecomposition< _MatrixType >::m_matrix [protected] |
Definition at line 275 of file HessenbergDecomposition.h.
VectorType Eigen::HessenbergDecomposition< _MatrixType >::m_temp [protected] |
Definition at line 277 of file HessenbergDecomposition.h.
