MOAB: Mesh Oriented datABase
(version 5.2.1)
Untangle metric. More...
#include <TUntangle1.hpp>
Public Member Functions | |
TUntangle1 (double epsilon=1e-6, double tau_bar=1.0) | |
virtual MESQUITE_EXPORT | ~TUntangle1 () |
virtual MESQUITE_EXPORT std::string | get_name () const |
virtual MESQUITE_EXPORT bool | evaluate (const MsqMatrix< 2, 2 > &T, double &result, MsqError &err) |
Evaluate \(\mu(T)\). | |
virtual MESQUITE_EXPORT bool | evaluate_with_grad (const MsqMatrix< 2, 2 > &T, double &result, MsqMatrix< 2, 2 > &deriv_wrt_T, MsqError &err) |
Gradient of \(\mu(T)\) with respect to components of T. | |
virtual MESQUITE_EXPORT bool | evaluate_with_hess (const MsqMatrix< 2, 2 > &T, double &result, MsqMatrix< 2, 2 > &deriv_wrt_T, MsqMatrix< 2, 2 > second_wrt_T[3], MsqError &err) |
Hessian of \(\mu(T)\) with respect to components of T. | |
virtual MESQUITE_EXPORT bool | evaluate (const MsqMatrix< 3, 3 > &T, double &result, MsqError &err) |
virtual MESQUITE_EXPORT bool | evaluate_with_grad (const MsqMatrix< 3, 3 > &T, double &result, MsqMatrix< 3, 3 > &deriv_wrt_T, MsqError &err) |
virtual MESQUITE_EXPORT bool | evaluate_with_hess (const MsqMatrix< 3, 3 > &T, double &result, MsqMatrix< 3, 3 > &deriv_wrt_T, MsqMatrix< 3, 3 > second_wrt_T[6], MsqError &err) |
Private Member Functions | |
template<unsigned D> | |
bool | eval (const MsqMatrix< D, D > &T, double &result) |
bool | grad (const MsqMatrix< D, D > &T, double &result, MsqMatrix< D, D > &first) |
bool | hess (const MsqMatrix< D, D > &T, double &result, MsqMatrix< D, D > &first, MsqMatrix< D, D > *second) |
Private Attributes | |
double | mFactor |
Untangle metric.
\( \mu_n(T) = \frac{1}{2} \left( - \tau + \sqrt{\tau^2 + \left(\epsilon \, \bar{\tau} \right)^2} \right)\)
Section 3.2.8 of derivs.tex
Definition at line 48 of file TUntangle1.hpp.
MBMesquite::TUntangle1::TUntangle1 | ( | double | epsilon = 1e-6 , |
double | tau_bar = 1.0 |
) | [inline] |
Definition at line 54 of file TUntangle1.hpp.
MBMesquite::TUntangle1::~TUntangle1 | ( | ) | [virtual] |
Definition at line 42 of file TUntangle1.cpp.
bool MBMesquite::TUntangle1::eval | ( | const MsqMatrix< DIM, DIM > & | T, |
double & | result | ||
) | [inline, private] |
Definition at line 50 of file TUntangle1.cpp.
References MBMesquite::det(), and mFactor.
virtual MESQUITE_EXPORT bool MBMesquite::TUntangle1::evaluate | ( | const MsqMatrix< 2, 2 > & | T, |
double & | result, | ||
MsqError & | err | ||
) | [virtual] |
T | 2x2 relative measure matrix (typically A W^-1) |
result | Output: value of function |
Reimplemented from MBMesquite::TMetric.
virtual MESQUITE_EXPORT bool MBMesquite::TUntangle1::evaluate | ( | const MsqMatrix< 3, 3 > & | T, |
) | [virtual] |
T | 3x3 relative measure matrix (typically A W^-1) |
virtual MESQUITE_EXPORT bool MBMesquite::TUntangle1::evaluate_with_grad | ( | const MsqMatrix< 2, 2 > & | T, |
MsqMatrix< 2, 2 > & | deriv_wrt_T, | ||
) | [virtual] |
deriv_wrt_T | Output: partial deriviatve of \(\mu\) wrt each term of T, evaluated at passed T. \[\left[\begin{array}{cc} \frac{\partial\mu}{\partial T_{0,0}} & \frac{\partial\mu}{\partial T_{0,1}} \\ \frac{\partial\mu}{\partial T_{1,0}} & \frac{\partial\mu}{\partial T_{1,1}} \\ \end{array}\right]\] |
virtual MESQUITE_EXPORT bool MBMesquite::TUntangle1::evaluate_with_grad | ( | const MsqMatrix< 3, 3 > & | T, |
MsqMatrix< 3, 3 > & | deriv_wrt_T, | ||
) | [virtual] |
deriv_wrt_T | Output: partial deriviatve of \(\mu\) wrt each term of T, evaluated at passed T. \[\left[\begin{array}{ccc} \frac{\partial\mu}{\partial T_{0,0}} & \frac{\partial\mu}{\partial T_{0,1}} & \frac{\partial\mu}{\partial T_{0,2}} \\ \frac{\partial\mu}{\partial T_{1,0}} & \frac{\partial\mu}{\partial T_{1,1}} & \frac{\partial\mu}{\partial T_{1,2}} \\ \frac{\partial\mu}{\partial T_{2,0}} & \frac{\partial\mu}{\partial T_{2,1}} & \frac{\partial\mu}{\partial T_{2,2}} \end{array}\right]\] |
virtual MESQUITE_EXPORT bool MBMesquite::TUntangle1::evaluate_with_hess | ( | const MsqMatrix< 2, 2 > & | T, |
MsqMatrix< 2, 2 > | second_wrt_T[3], | ||
) | [virtual] |
deriv_wrt_T | Output: partial deriviatve of \(\mu\) wrt each term of T, evaluated at passed T. |
second_wrt_T | Output: 9x9 matrix of second partial deriviatve of \(\mu\) wrt each term of T, in row-major order. The symmetric matrix is decomposed into 3x3 blocks and only the upper diagonal blocks, in row-major order, are returned. \[\left[\begin{array}{cc|cc} \frac{\partial^{2}\mu}{\partial T_{0,0}^2} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial A_{0,1}} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial A_{1,0}} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial A_{1,1}} \\ \frac{\partial^{2}\mu}{\partial T_{0,0}\partial A_{0,1}} & \frac{\partial^{2}\mu}{\partial T_{0,1}^2} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial A_{1,0}} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial A_{1,1}} \\ \hline & & \frac{\partial^{2}\mu}{\partial T_{1,0}^2} & \frac{\partial^{2}\mu}{\partial T_{1,0}\partial A_{1,1}} \\ & & \frac{\partial^{2}\mu}{\partial T_{1,0}\partial A_{1,1}} & \frac{\partial^{2}\mu}{\partial T_{1,1}^2} \\ \end{array}\right]\] |
virtual MESQUITE_EXPORT bool MBMesquite::TUntangle1::evaluate_with_hess | ( | const MsqMatrix< 3, 3 > & | T, |
MsqMatrix< 3, 3 > | second_wrt_T[6], | ||
) | [virtual] |
second_wrt_T | Output: 9x9 matrix of second partial deriviatve of \(\mu\) wrt each term of T, in row-major order. The symmetric matrix is decomposed into 3x3 blocks and only the upper diagonal blocks, in row-major order, are returned. \[\left[\begin{array}{ccc|ccc|ccc} \frac{\partial^{2}\mu}{\partial T_{0,0}^2} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{0,1}} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{0,2}} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{1,0}} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{1,1}} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{1,2}} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{2,0}} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{2,1}} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{2,2}} \\ \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{0,1}} & \frac{\partial^{2}\mu}{\partial T_{0,1}^2} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial T_{0,2}} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial T_{1,0}} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial T_{1,1}} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial T_{1,2}} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial T_{2,0}} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial T_{2,1}} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial T_{2,2}} \\ \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{0,2}} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial T_{0,2}} & \frac{\partial^{2}\mu}{\partial T_{0,2}^2} & \frac{\partial^{2}\mu}{\partial T_{0,2}\partial T_{1,0}} & \frac{\partial^{2}\mu}{\partial T_{0,2}\partial T_{1,1}} & \frac{\partial^{2}\mu}{\partial T_{0,2}\partial T_{1,2}} & \frac{\partial^{2}\mu}{\partial T_{0,2}\partial T_{2,0}} & \frac{\partial^{2}\mu}{\partial T_{0,2}\partial T_{2,1}} & \frac{\partial^{2}\mu}{\partial T_{0,2}\partial T_{2,2}} \\ \hline & & & \frac{\partial^{2}\mu}{\partial T_{1,0}^2} & \frac{\partial^{2}\mu}{\partial T_{1,0}\partial T_{1,1}} & \frac{\partial^{2}\mu}{\partial T_{1,0}\partial T_{1,2}} & \frac{\partial^{2}\mu}{\partial T_{1,0}\partial T_{2,0}} & \frac{\partial^{2}\mu}{\partial T_{1,0}\partial T_{2,1}} & \frac{\partial^{2}\mu}{\partial T_{1,0}\partial T_{2,2}} \\ & & & \frac{\partial^{2}\mu}{\partial T_{1,0}\partial T_{1,1}} & \frac{\partial^{2}\mu}{\partial T_{1,1}^2} & \frac{\partial^{2}\mu}{\partial T_{1,1}\partial T_{1,2}} & \frac{\partial^{2}\mu}{\partial T_{1,1}\partial T_{2,0}} & \frac{\partial^{2}\mu}{\partial T_{1,1}\partial T_{2,1}} & \frac{\partial^{2}\mu}{\partial T_{1,1}\partial T_{2,2}} \\ & & & \frac{\partial^{2}\mu}{\partial T_{1,0}\partial T_{1,2}} & \frac{\partial^{2}\mu}{\partial T_{1,1}\partial T_{1,2}} & \frac{\partial^{2}\mu}{\partial T_{1,2}^2} & \frac{\partial^{2}\mu}{\partial T_{1,2}\partial T_{2,0}} & \frac{\partial^{2}\mu}{\partial T_{1,2}\partial T_{2,1}} & \frac{\partial^{2}\mu}{\partial T_{1,2}\partial T_{2,2}} \\ \hline & & & & & & \frac{\partial^{2}\mu}{\partial T_{2,0}^2} & \frac{\partial^{2}\mu}{\partial T_{2,0}\partial T_{2,1}} & \frac{\partial^{2}\mu}{\partial T_{2,0}\partial T_{2,2}} \\ & & & & & & \frac{\partial^{2}\mu}{\partial T_{2,0}\partial T_{2,1}} & \frac{\partial^{2}\mu}{\partial T_{2,1}^2} & \frac{\partial^{2}\mu}{\partial T_{2,1}\partial T_{2,2}} \\ & & & & & & \frac{\partial^{2}\mu}{\partial T_{2,0}\partial T_{2,2}} & \frac{\partial^{2}\mu}{\partial T_{2,1}\partial T_{2,2}} & \frac{\partial^{2}\mu}{\partial T_{2,2}^2} \\ \end{array}\right]\] |
std::string MBMesquite::TUntangle1::get_name | ( | ) | const [virtual] |
Implements MBMesquite::TMetric.
Definition at line 44 of file TUntangle1.cpp.
{ return "Untangle1"; }
bool MBMesquite::TUntangle1::grad | ( | const MsqMatrix< DIM, DIM > & | T, |
MsqMatrix< DIM, DIM > & | first | ||
Definition at line 58 of file TUntangle1.cpp.
References MBMesquite::det(), mFactor, and MBMesquite::transpose_adj().
{ double tau = det( T ); double g = sqrt( tau * tau + mFactor ); if( g > 1e-50 ) { double f = tau / g - 1; result = 0.5 * ( g - tau ); deriv_wrt_T = transpose_adj( T ); deriv_wrt_T *= 0.5 * f; return true; } else { std::cout << "Warning: Division by zero avoided in TUntangle1::grad()" << std::endl; return false; } }
bool MBMesquite::TUntangle1::hess | ( | const MsqMatrix< DIM, DIM > & | T, |
MsqMatrix< DIM, DIM > & | first, | ||
MsqMatrix< DIM, DIM > * | second | ||
Definition at line 78 of file TUntangle1.cpp.
References MBMesquite::det(), mFactor, MBMesquite::pluseq_scaled_2nd_deriv_of_det(), MBMesquite::set_scaled_outer_product(), and MBMesquite::transpose_adj().
{ const MsqMatrix< DIM, DIM > adjt = transpose_adj( T ); double tau = det( T ); double g = sqrt( tau * tau + mFactor ); if( g == 0 ) return false; double f = 0.5 * ( tau / g - 1 ); result = 0.5 * ( g - tau ); deriv_wrt_T = adjt; deriv_wrt_T *= f; set_scaled_outer_product( second_wrt_T, 0.5 * mFactor / ( g * g * g ), adjt ); pluseq_scaled_2nd_deriv_of_det( second_wrt_T, f, T ); return true; }
double MBMesquite::TUntangle1::mFactor [private] |
Definition at line 51 of file TUntangle1.hpp.
