MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"
#include "TestUtil.hpp"
#include "moab/Range.hpp"
#include "moab/ReadUtilIface.hpp"
#include "WriteHDF5.hpp"
#include "moab/FileOptions.hpp"
#include <algorithm>
#include <iostream>
#include <sstream>
#include <cstdlib>
#include <cmath>
Functions | |
void | test_write_invalid_elem () |
void | test_write_read_many_tags () |
int | main (int argc, char *argv[]) |
Variables | |
const char | filename [] = "bad.h5m" |
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 25 of file h5regression.cpp.
References moab::fail(), RUN_TEST, test_write_invalid_elem(), and test_write_read_many_tags().
{ #ifdef MOAB_HAVE_MPI int fail = MPI_Init( &argc, &argv ); if( fail ) return fail; #else argv[0] = argv[argc - argc]; // warning in serial #endif int exitval = 0; exitval += RUN_TEST( test_write_invalid_elem ); exitval += RUN_TEST( test_write_read_many_tags ); #ifdef MOAB_HAVE_MPI fail = MPI_Finalize(); if( fail ) return fail; #endif return exitval; }
void test_write_invalid_elem | ( | ) |
Definition at line 46 of file h5regression.cpp.
References CHECK, CHECK_ERR, conn, ErrorCode, filename, moab::ReadUtilIface::get_element_connect(), moab::ReadUtilIface::get_node_coords(), MB_SUCCESS, mbcore, MBTRI, moab::Interface::query_interface(), and moab::WriteHDF5::write_file().
Referenced by main().
{ Core mbcore; Interface& moab = mbcore; ReadUtilIface* readtool = 0; ErrorCode rval; rval = moab.query_interface( readtool );CHECK_ERR( rval ); CHECK( readtool != 0 ); // create two nodes EntityHandle first_node; std::vector< double* > coords; rval = readtool->get_node_coords( 3, 2, 1, first_node, coords );CHECK_ERR( rval ); // Cppcheck warning (false positive): variable coords is assigned a value that is never used coords[0][0] = coords[0][1] = 0.0; coords[1][0] = coords[1][1] = 0.0; coords[2][0] = coords[2][1] = 0.0; // create a triangle with an invalid node handle for its // third vertex EntityHandle tri; EntityHandle* conn = 0; rval = readtool->get_element_connect( 1, 3, MBTRI, 1, tri, conn );CHECK_ERR( rval ); conn[0] = first_node; // valid conn[1] = first_node + 1; // valid conn[2] = first_node + 2; // invalid // try to write the file (should fail) WriteHDF5 writer( &moab ); FileOptions opts( 0 ); rval = writer.write_file( filename, true, opts, 0, 0, std::vector< std::string >() ); CHECK( MB_SUCCESS != rval ); }
void test_write_read_many_tags | ( | ) |
Definition at line 81 of file h5regression.cpp.
References CHECK_EQUAL, CHECK_ERR, moab::Interface::create_vertex(), moab::Interface::delete_mesh(), ErrorCode, filename, moab::Interface::load_file(), mb, MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_INTEGER, mbcore, N, size, t, moab::Interface::tag_delete(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_type(), TagType, and moab::Interface::write_file().
{ const int N = 200; Core mbcore; Interface& mb = mbcore; ErrorCode rval; double coords[3] = { 0, 0, 0 }; EntityHandle node; rval = mb.create_vertex( coords, node );CHECK_ERR( rval ); // create a lot of tags std::vector< Tag > tags; for( int i = 0; i < N; ++i ) { Tag t; std::ostringstream name( "IntTag" ); name << i; rval = mb.tag_get_handle( name.str().c_str(), 1, MB_TYPE_INTEGER, t, ( i % 2 ? MB_TAG_SPARSE : MB_TAG_DENSE ) | MB_TAG_EXCL, &i );CHECK_ERR( rval ); tags.push_back( t ); } // write the file rval = mb.write_file( filename, "MOAB" );CHECK_ERR( rval ); // clear moab instance rval = mb.delete_mesh();CHECK_ERR( rval ); for( int i = 0; i < N; ++i ) { rval = mb.tag_delete( tags[i] );CHECK_ERR( rval ); } // read the file rval = mb.load_file( filename );CHECK_ERR( rval ); remove( filename ); // check that we have the expected tags for( int i = 0; i < N; ++i ) { Tag t; std::ostringstream name( "IntTag" ); name << i; rval = mb.tag_get_handle( name.str().c_str(), 1, MB_TYPE_INTEGER, t );CHECK_ERR( rval ); TagType storage; rval = mb.tag_get_type( t, storage );CHECK_ERR( rval ); CHECK_EQUAL( ( i % 2 ) ? MB_TAG_SPARSE : MB_TAG_DENSE, storage ); DataType type; rval = mb.tag_get_data_type( t, type );CHECK_ERR( rval ); CHECK_EQUAL( MB_TYPE_INTEGER, type ); int size; rval = mb.tag_get_length( t, size );CHECK_ERR( rval ); CHECK_EQUAL( 1, size ); int def; rval = mb.tag_get_default_value( t, &def );CHECK_ERR( rval ); CHECK_EQUAL( i, def ); } }
const char filename[] = "bad.h5m" |
Definition at line 20 of file h5regression.cpp.
