MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iostream>
#include <string>
#include <sstream>
#include <ctime>
#include <vector>
#include <algorithm>
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "moab/MeshTopoUtil.hpp"
#include "moab/NestedRefine.hpp"
#include "moab/DiscreteGeometry/HiReconstruction.hpp"
#include "TestUtil.hpp"
#include "geomObject.cpp"
#include <cmath>
#include <cstdlib>
#include <cassert>
Defines | |
#define | nsamples 10 |
Functions | |
ErrorCode | load_meshset_hirec (const char *infile, Interface *mbimpl, EntityHandle &meshset, ParallelComm *&pc, const int degree, const int dim) |
ErrorCode | closedsurface_uref_hirec_convergence_study (const char *infile, std::vector< int > °s2fit, bool interp, int dim, geomObject *obj, int &ntestverts, std::vector< double > &geoml1errs, std::vector< double > &geoml2errs, std::vector< double > &geomlinferrs) |
void | usage () |
int | main (int argc, char *argv[]) |
#define nsamples 10 |
Definition at line 36 of file uref_hirec_test_parallel.cpp.
Referenced by closedsurface_uref_hirec_convergence_study().
ErrorCode closedsurface_uref_hirec_convergence_study | ( | const char * | infile, |
std::vector< int > & | degs2fit, | ||
bool | interp, | ||
int | dim, | ||
geomObject * | obj, | ||
int & | ntestverts, | ||
std::vector< double > & | geoml1errs, | ||
std::vector< double > & | geoml2errs, | ||
std::vector< double > & | geomlinferrs | ||
Definition at line 126 of file uref_hirec_test_parallel.cpp.
References b, moab::Range::begin(), geomObject::compute_projecterror(), conn, moab::Range::end(), moab::error(), ErrorCode, MBMesquite::eta, moab::ParallelComm::filter_pstatus(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), moab::HiReconstruction::hiproj_walf_in_element(), load_meshset_hirec(), MB_CHK_ERR, MBQUAD, MBTRI, MPI_COMM_WORLD, N, nsamples, geomObject::project_points2geom(), PSTATUS_GHOST, PSTATUS_NOT, rank, moab::HiReconstruction::reconstruct3D_surf_geom(), moab::Interface::set_coords(), moab::Range::size(), moab::sum(), moab::TYPE_FROM_HANDLE(), and MBMesquite::xi.
Referenced by main().
{ Core moab; Interface* mbImpl = &moab; ParallelComm* pc = NULL; EntityHandle meshset; #ifdef MOAB_HAVE_MPI int nprocs, rank; MPI_Comm comm = MPI_COMM_WORLD; MPI_Comm_size( comm, &nprocs ); MPI_Comm_rank( comm, &rank ); #endif ErrorCode error; // mesh will be loaded and communicator pc will be updated int mxdeg = 1; for( size_t i = 0; i < degs2fit.size(); ++i ) { mxdeg = std::max( degs2fit[i], mxdeg ); } error = load_meshset_hirec( infile, mbImpl, meshset, pc, mxdeg, dim );MB_CHK_ERR( error ); Range elems, elems_owned; error = mbImpl->get_entities_by_dimension( meshset, dim, elems );MB_CHK_ERR( error ); #ifdef MOAB_HAVE_MPI if( pc ) { error = pc->filter_pstatus( elems, PSTATUS_GHOST, PSTATUS_NOT, -1, &elems_owned );MB_CHK_ERR( error ); } else { elems_owned = elems; } #endif #ifdef MOAB_HAVE_MPI // std::cout << "Mesh has " << nelems << " elements on Processor " << rank << " in total;"; // std::cout << elems_owned.size() << " of which are locally owned elements" << std::endl; #else // std::cout << "Mesh has " << nelems << " elements" << std::endl; #endif /************************ * convergence study * *************************/ // project onto exact geometry since each level with uref has only linear coordinates Range verts; error = mbImpl->get_entities_by_dimension( meshset, 0, verts );MB_CHK_ERR( error ); for( Range::iterator ivert = verts.begin(); ivert != verts.end(); ++ivert ) { EntityHandle currvert = *ivert; double currcoords[3], exactcoords[3]; error = mbImpl->get_coords( &currvert, 1, currcoords );MB_CHK_ERR( error ); obj->project_points2geom( 3, currcoords, exactcoords, NULL ); error = mbImpl->set_coords( &currvert, 1, exactcoords );MB_CHK_ERR( error ); // for debug /*error = mbImpl->get_coords(&currvert,1,currcoords); MB_CHK_ERR(error); assert(currcoords[0]==exactcoords[0]&&currcoords[1]==exactcoords[1]&&currcoords[2]==exactcoords[2]);*/ } // test ahf on mesh with ghost layers /*Range verts_owned; #ifdef MOAB_HAVE_MPI if(pc){ error = pc->filter_pstatus(verts,PSTATUS_GHOST,PSTATUS_NOT,-1,&verts_owned);MB_CHK_ERR(error); }else{ verts_owned = verts; } HalfFacetRep *ahf = new HalfFacetRep(&moab,pc,meshset); error = ahf->initialize(); MB_CHK_ERR(error); for(int i=0;i<nprocs;++i){ if(rank==i){ std::cout << "Processor " << rank << " Local elements: \n"; for(Range::iterator ielem=elems.begin();ielem!=elems.end();++ielem){ EntityHandle currelem = *ielem; std::vector<EntityHandle> conn; error = mbImpl->get_connectivity(&currelem,1,conn); MB_CHK_ERR(error); std::cout << *ielem << ": "; for(size_t k=0;k<conn.size();++k) std::cout << conn[k] << " "; std::cout << std::endl; } std::cout << "Processor " << rank << " Local owned elements: \n"; for(Range::iterator ielem=elems_owned.begin();ielem!=elems_owned.end();++ielem){ EntityHandle currelem = *ielem; std::vector<EntityHandle> conn; error = mbImpl->get_connectivity(&currelem,1,conn); MB_CHK_ERR(error); std::cout << *ielem << ": "; for(size_t k=0;k<conn.size();++k) std::cout << conn[k] << " "; std::cout << std::endl; } std::cout << "Processor " << rank << " Local vertices: "; for(Range::iterator ivert=verts.begin();ivert!=verts.end();++ivert){ std::cout << *ivert << " "; } std::cout << std::endl; std::cout << "Processor " << rank << " Local owned vertices: "; for(Range::iterator ivert=verts_owned.begin();ivert!=verts_owned.end();++ivert){ std::cout << *ivert << " "; } std::cout << std::endl; for(Range::iterator ivert=verts_owned.begin();ivert!=verts_owned.end();++ivert){ EntityHandle currvid = *ivert; std::cout << "Processor " << rank << " local verts: " << *ivert << " has adjfaces: "; std::vector<EntityHandle> adjfaces; //error = ahf->get_up_adjacencies(currvid,2,adjfaces); MB_CHK_ERR(error); error = mbImpl->get_adjacencies(&currvid,1,2,false,adjfaces); MB_CHK_ERR(error); for(size_t k=0;k<adjfaces.size();++k){ std::cout << adjfaces[k] << " "; } std::cout << std::endl; } for(Range::iterator ivert=verts.begin();ivert!=verts.end();++ivert){ EntityHandle currvid = *ivert; std::cout << "Processor " << rank << " all verts: " << *ivert << " has adjfaces: "; std::vector<EntityHandle> adjfaces; //error = ahf->get_up_adjacencies(*ivert,2,adjfaces); MB_CHK_ERR(error); error = mbImpl->get_adjacencies(&currvid,1,2,false,adjfaces); MB_CHK_ERR(error); for(size_t k=0;k<adjfaces.size();++k){ std::cout << adjfaces[k] << " "; } std::cout << std::endl; } }else{ MPI_Barrier(MPI_COMM_WORLD); } } exit(0); #endif*/ // generate random points on each elements, assument 3D coordinates int nvpe = TYPE_FROM_HANDLE( *elems.begin() ) == MBTRI ? 3 : 4; std::vector< double > testpnts, testnaturalcoords; ntestverts = elems_owned.size() * nsamples; testpnts.reserve( 3 * elems_owned.size() * nsamples ); testnaturalcoords.reserve( nvpe * elems_owned.size() * nsamples ); for( Range::iterator ielem = elems_owned.begin(); ielem != elems_owned.end(); ++ielem ) { EntityHandle currelem = *ielem; std::vector< EntityHandle > conn; error = mbImpl->get_connectivity( &currelem, 1, conn );MB_CHK_ERR( error ); std::vector< double > elemcoords( 3 * conn.size() ); error = mbImpl->get_coords( &( conn[0] ), conn.size(), &( elemcoords[0] ) );MB_CHK_ERR( error ); EntityType type = TYPE_FROM_HANDLE( currelem ); for( int s = 0; s < nsamples; ++s ) { if( type == MBTRI ) { double a = (double)rand() / RAND_MAX, b = (double)rand() / RAND_MAX, c = (double)rand() / RAND_MAX, sum; sum = a + b + c; if( sum < 1e-12 ) { --s; continue; } else { a /= sum, b /= sum, c /= sum; } assert( a > 0 && b > 0 && c > 0 && fabs( a + b + c - 1 ) < 1e-12 ); testpnts.push_back( a * elemcoords[0] + b * elemcoords[3] + c * elemcoords[6] ); testpnts.push_back( a * elemcoords[1] + b * elemcoords[4] + c * elemcoords[7] ); testpnts.push_back( a * elemcoords[2] + b * elemcoords[5] + c * elemcoords[8] ); testnaturalcoords.push_back( a ), testnaturalcoords.push_back( b ), testnaturalcoords.push_back( c ); } else if( type == MBQUAD ) { double xi = (double)rand() / RAND_MAX, eta = (double)rand() / RAND_MAX, N[4]; xi = 2 * xi - 1; eta = 2 * eta - 1; N[0] = ( 1 - xi ) * ( 1 - eta ) / 4, N[1] = ( 1 + xi ) * ( 1 - eta ) / 4, N[2] = ( 1 + xi ) * ( 1 + eta ) / 4, N[3] = ( 1 - xi ) * ( 1 + eta ) / 4; testpnts.push_back( N[0] * elemcoords[0] + N[1] * elemcoords[3] + N[2] * elemcoords[6] + N[3] * elemcoords[9] ); testpnts.push_back( N[0] * elemcoords[1] + N[1] * elemcoords[4] + N[2] * elemcoords[7] + N[3] * elemcoords[10] ); testpnts.push_back( N[0] * elemcoords[2] + N[1] * elemcoords[5] + N[2] * elemcoords[8] + N[3] * elemcoords[11] ); testnaturalcoords.push_back( N[0] ), testnaturalcoords.push_back( N[1] ), testnaturalcoords.push_back( N[2] ), testnaturalcoords.push_back( N[3] ); } else { throw std::invalid_argument( "NOT SUPPORTED ELEMENT TYPE" ); } } } // Compute error of linear interpolation in PARALLEL double l1err, l2err, linferr; geoml1errs.clear(); geoml2errs.clear(); geomlinferrs.clear(); obj->compute_projecterror( 3, elems_owned.size() * nsamples, &( testpnts[0] ), l1err, l2err, linferr ); geoml1errs.push_back( l1err ); geoml2errs.push_back( l2err ); geomlinferrs.push_back( linferr ); /*Perform high order projection and compute error*/ // initialize HiReconstruction hirec( &moab, pc, meshset ); for( size_t ideg = 0; ideg < degs2fit.size(); ++ideg ) { // High order reconstruction error = hirec.reconstruct3D_surf_geom( degs2fit[ideg], interp, true, true );MB_CHK_ERR( error ); int index = 0; // for debug /*double maxlinferr=0,elemlinferr=0,eleml1err=0,eleml2err; EntityHandle elem_maxerr;*/ for( Range::iterator ielem = elems_owned.begin(); ielem != elems_owned.end(); ++ielem, ++index ) { // Projection error = hirec.hiproj_walf_in_element( *ielem, nvpe, nsamples, &( testnaturalcoords[nvpe * nsamples * index] ), &( testpnts[3 * nsamples * index] ) );MB_CHK_ERR( error ); // for debug /*obj->compute_projecterror(3,nsamples,&(testpnts[3*nsamples*index]),eleml1err,eleml2err,elemlinferr); if(elemlinferr>maxlinferr){ maxlinferr = elemlinferr; elem_maxerr = *ielem; }*/ } assert( (size_t)index == elems_owned.size() ); // Estimate error obj->compute_projecterror( 3, elems_owned.size() * nsamples, &( testpnts[0] ), l1err, l2err, linferr ); geoml1errs.push_back( l1err ); geoml2errs.push_back( l2err ); geomlinferrs.push_back( linferr ); // for debug /*std::cout << "Degree " << degs2fit[ideg] << " has L-inf error " << maxlinferr << " at element " << elems_owned.index(elem_maxerr) << ":"; std::vector<EntityHandle> conn; error = mbImpl->get_connectivity(&elem_maxerr,1,conn); MB_CHK_ERR(error); for(size_t ii=0;ii<conn.size();++ii) std::cout << verts.index(conn[ii]) << " "; std::cout << std::endl; for(size_t ii=0;ii<conn.size();++ii){ //assume triangle std::vector<double> vertexcoords(3,0); error = mbImpl->get_coords(&(conn[ii]),1,&(vertexcoords[0])); MB_CHK_ERR(error); std::cout << verts.index(conn[ii]) << ":" << vertexcoords[0] << " "<< vertexcoords[1] << " "<< vertexcoords[2] << "\n"; GEOMTYPE geomtype; std::vector<double> local_coords_system, local_coeffs; int deg_out; bool local_interp; bool hasfit = hirec.get_fittings_data(conn[ii],geomtype,local_coords_system,deg_out,local_coeffs,local_interp); assert(hasfit); std::cout << "Local fitting result: " << std::endl; std::cout << "Geom Type: " << geomtype << std::endl; std::cout << "Local coordinates system: " << std::endl; std::cout << local_coords_system[0] << "\t" << local_coords_system[1] << "\t" << local_coords_system[2] << std::endl; std::cout << local_coords_system[3] << "\t" << local_coords_system[4] << "\t" << local_coords_system[5] << std::endl; std::cout << local_coords_system[6] << "\t" << local_coords_system[7] << "\t" << local_coords_system[8] << std::endl; std::cout << "Fitting degree is " << deg_out << " interp is " << local_interp << std::endl; std::cout << "Fitting coefficients are :" << std::endl; for(size_t kk=0;kk<local_coeffs.size();++kk) std::cout << local_coeffs[kk] << "\t"; std::cout << std::endl; }*/ } return error; }
ErrorCode load_meshset_hirec | ( | const char * | infile, |
Interface * | mbimpl, | ||
EntityHandle & | meshset, | ||
ParallelComm *& | pc, | ||
const int | degree, | ||
const int | dim | ||
Definition at line 42 of file uref_hirec_test_parallel.cpp.
References moab::Interface::create_meshset(), moab::error(), ErrorCode, moab::HiReconstruction::estimate_num_ghost_layers(), moab::ParallelComm::get_pcomm(), moab::Interface::load_file(), MB_CHK_ERR, MB_SET_ERR, MESHSET_SET, MPI_COMM_WORLD, rank, and read_options.
{ ErrorCode error; error = mbimpl->create_meshset( moab::MESHSET_SET, meshset );MB_CHK_ERR( error ); #ifdef MOAB_HAVE_MPI int nprocs, rank; MPI_Comm comm = MPI_COMM_WORLD; MPI_Comm_size( comm, &nprocs ); MPI_Comm_rank( comm, &rank ); EntityHandle partnset; error = mbimpl->create_meshset( moab::MESHSET_SET, partnset );MB_CHK_ERR( error ); if( nprocs > 1 ) { pc = moab::ParallelComm::get_pcomm( mbimpl, partnset, &comm ); } if( nprocs > 1 ) { int nghlayers = degree > 0 ? HiReconstruction::estimate_num_ghost_layers( degree, true ) : 0; assert( nghlayers < 10 ); if( nghlayers ) { // get ghost layers if( dim == 2 ) { read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_" "SHARED_ENTS;PARALLEL_GHOSTS=2.0."; } else if( dim == 1 ) { read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_" "SHARED_ENTS;PARALLEL_GHOSTS=1.0."; } else { MB_SET_ERR( MB_FAILURE, "unsupported dimension" ); } read_options += (char)( '0' + nghlayers ); // std::cout << "On processor " << rank << " Degree=" << degree << " "<< read_options << // std::endl; } else { read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;"; } /*for debug*/ /*std::string outfile = std::string(infile); std::size_t dotpos = outfile.find_last_of("."); std::ostringstream convert; convert << rank; std::string localfile = outfile.substr(0,dotpos)+convert.str()+".vtk"; //write local mesh EntityHandle local; error = mbimpl->create_meshset(moab::MESHSET_SET,local);CHECK_ERR(error); std::string local_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;"; error = mbimpl->load_file(infile,&local,local_options.c_str()); MB_CHK_ERR(error); error = mbimpl->write_file(localfile.c_str(),0,0,&local,1);*/ error = mbimpl->load_file( infile, &meshset, read_options.c_str() );MB_CHK_ERR( error ); /*for debug //write local mesh with ghost layers localfile = outfile.substr(0,dotpos)+convert.str()+"_ghost.vtk"; error = mbimpl->write_file(localfile.c_str(),0,0,&meshset,1);*/ } else { error = mbimpl->load_file( infile, &meshset );MB_CHK_ERR( error ); } #else assert( !pc && degree && dim ); error = mbimpl->load_file( infile, &meshset );MB_CHK_ERR( error ); #endif return error; }
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 420 of file uref_hirec_test_parallel.cpp.
References closedsurface_uref_hirec_convergence_study(), dim, moab::error(), ErrorCode, geom, MB_CHK_ERR, MPI_COMM_WORLD, rank, and usage.
{ #ifdef MOAB_HAVE_MPI MPI_Init( &argc, &argv ); int nprocs, rank; MPI_Comm_size( MPI_COMM_WORLD, &nprocs ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); #endif std::string prefix, suffix, istr, iend; int dim = 2, geom = 0; bool interp = false; ErrorCode error; if( argc == 1 ) { usage(); prefix = TestDir + "unittest/sphere_quads_5_ML_"; suffix = ".h5m"; istr = "0"; iend = "1"; std::cout << "Using defaults: MeshFiles/unittest/sphere_quads_5_ML_*.h5m -str 0 -end 1 " "-suffix \".h5m\" -interp 0 -dim 2 -geom s" << std::endl; } else { prefix = std::string( argv[1] ); bool hasdim = false; for( int i = 2; i < argc; ++i ) { if( i + 1 != argc ) { if( std::string( argv[i] ) == "-suffix" ) { suffix = std::string( argv[++i] ); } else if( std::string( argv[i] ) == "-str" ) { istr = std::string( argv[++i] ); } else if( std::string( argv[i] ) == "-end" ) { iend = std::string( argv[++i] ); } else if( std::string( argv[i] ) == "-interp" ) { interp = atoi( argv[++i] ); } else if( std::string( argv[i] ) == "-dim" ) { dim = atoi( argv[++i] ); hasdim = true; } else if( std::string( argv[i] ) == "-geom" ) { geom = std::string( argv[++i] ) == "s" ? 0 : 1; } else { #ifdef MOAB_HAVE_MPI if( 0 == rank ) { usage(); } MPI_Finalize(); #else usage(); #endif return 0; } } } if( !hasdim ) { #ifdef MOAB_HAVE_MPI if( 0 == rank ) { std::cout << "Dimension of input mesh should be provided, positive and less than 3" << std::endl; } #else std::cout << "Dimension of input mesh should be provided, positive and less than 3" << std::endl; #endif return 0; } if( dim > 2 || dim <= 0 ) { #ifdef MOAB_HAVE_MPI if( 0 == rank ) { std::cout << "Input dimesion should be positive and less than 3;" << std::endl; } #else std::cout << "Input dimesion should be positive and less than 3;" << std::endl; #endif return 0; } #ifdef MOAB_HAVE_MPI if( 0 == rank ) { std::cout << "Testing on " << prefix + istr + "-" + iend + suffix << " with dimension " << dim << "\n"; std::string opts = interp ? "interpolation" : "least square fitting"; std::cout << "High order reconstruction in " << opts << std::endl; } #else std::cout << "Testing on " << prefix + istr + "-" + iend + suffix << " with dimension " << dim << "\n"; std::string opts = interp ? "interpolation" : "least square fitting"; std::cout << "High order reconstruction in " << opts << std::endl; #endif } geomObject* obj; if( geom == 0 ) { obj = new sphere(); } else { obj = new torus(); } std::vector< int > degs2fit; for( int d = 1; d <= 6; ++d ) { degs2fit.push_back( d ); } int begin = atoi( istr.c_str() ), end = atoi( iend.c_str() ) + 1; #ifdef MOAB_HAVE_MPI std::vector< std::vector< double > > geoml1errs_global, geoml2errs_global, geomlinferrs_global; if( rank == 0 ) { geoml1errs_global = std::vector< std::vector< double > >( 1 + degs2fit.size(), std::vector< double >( end - begin, 0 ) ); geoml2errs_global = std::vector< std::vector< double > >( 1 + degs2fit.size(), std::vector< double >( end - begin, 0 ) ); geomlinferrs_global = std::vector< std::vector< double > >( 1 + degs2fit.size(), std::vector< double >( end - begin, 0 ) ); } #else std::vector< std::vector< double > > geoml1errs_global( 1 + degs2fit.size(), std::vector< double >( end - begin, 0 ) ); std::vector< std::vector< double > > geoml2errs_global( 1 + degs2fit.size(), std::vector< double >( end - begin, 0 ) ); std::vector< std::vector< double > > geomlinferrs_global( 1 + degs2fit.size(), std::vector< double >( end - begin, 0 ) ); #endif for( int i = begin; i < end; ++i ) { std::ostringstream convert; convert << i; std::string infile = prefix + convert.str() + suffix; int ntestverts; std::vector< double > geoml1errs, geoml2errs, geomlinferrs; #ifdef MOAB_HAVE_MPI std::cout << "Processor " << rank << " is working on file " << infile << std::endl; #endif error = closedsurface_uref_hirec_convergence_study( infile.c_str(), degs2fit, interp, dim, obj, ntestverts, geoml1errs, geoml2errs, geomlinferrs );MB_CHK_ERR( error ); assert( geoml1errs.size() == 1 + degs2fit.size() && geoml2errs.size() == 1 + degs2fit.size() && geomlinferrs.size() == 1 + degs2fit.size() ); #ifdef MOAB_HAVE_MPI if( nprocs > 1 ) { int ntestverts_global = 0; MPI_Reduce( &ntestverts, &ntestverts_global, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD ); for( size_t d = 0; d < degs2fit.size() + 1; ++d ) { double local_l1err = ntestverts * geoml1errs[d], local_l2err = geoml2errs[d] * ( geoml2errs[d] * ntestverts ), local_linferr = geomlinferrs[d]; std::cout << "On Processor " << rank << " with mesh " << i << " Degree = " << ( d == 0 ? 0 : degs2fit[d - 1] ) << " L1:" << geoml1errs[d] << " L2:" << geoml2errs[d] << " Li:" << geomlinferrs[d] << std::endl; double global_l1err = 0, global_l2err = 0, global_linferr = 0; MPI_Reduce( &local_l1err, &global_l1err, 1, MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD ); MPI_Reduce( &local_l2err, &global_l2err, 1, MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD ); MPI_Reduce( &local_linferr, &global_linferr, 1, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD ); if( rank == 0 ) { geoml1errs_global[d][i - begin] = global_l1err / ntestverts_global; geoml2errs_global[d][i - begin] = sqrt( global_l2err / ntestverts_global ); geomlinferrs_global[d][i - begin] = global_linferr; } } } else { for( size_t d = 0; d < degs2fit.size() + 1; ++d ) { geoml1errs_global[d][i - begin] = geoml1errs[d]; geoml2errs_global[d][i - begin] = geoml2errs[d]; geomlinferrs_global[d][i - begin] = geomlinferrs[d]; } } #else for( size_t d = 0; d < degs2fit.size() + 1; ++d ) { geoml1errs_global[d][i - begin] = geoml1errs[d]; geoml2errs_global[d][i - begin] = geoml2errs[d]; geomlinferrs_global[d][i - begin] = geomlinferrs[d]; } #endif } #ifdef MOAB_HAVE_MPI if( rank == 0 ) { std::cout << "Degrees: 0 "; for( size_t ideg = 0; ideg < degs2fit.size(); ++ideg ) { std::cout << degs2fit[ideg] << " "; } std::cout << std::endl; std::cout << "L1-norm error: \n"; for( size_t i = 0; i < geoml1errs_global.size(); ++i ) { for( size_t j = 0; j < geoml1errs_global[i].size(); ++j ) { std::cout << geoml1errs_global[i][j] << " "; } std::cout << std::endl; } std::cout << "L2-norm error: \n"; for( size_t i = 0; i < geoml2errs_global.size(); ++i ) { for( size_t j = 0; j < geoml2errs_global[i].size(); ++j ) { std::cout << geoml2errs_global[i][j] << " "; } std::cout << std::endl; } std::cout << "Linf-norm error: \n"; for( size_t i = 0; i < geomlinferrs_global.size(); ++i ) { for( size_t j = 0; j < geomlinferrs_global[i].size(); ++j ) { std::cout << geomlinferrs_global[i][j] << " "; } std::cout << std::endl; } } #else std::cout << "Degrees: 0 "; for( size_t ideg = 0; ideg < degs2fit.size(); ++ideg ) { std::cout << degs2fit[ideg] << " "; } std::cout << std::endl; std::cout << "L1-norm error: \n"; for( size_t i = 0; i < geoml1errs_global.size(); ++i ) { for( size_t j = 0; j < geoml1errs_global[i].size(); ++j ) { std::cout << geoml1errs_global[i][j] << " "; } std::cout << std::endl; } std::cout << "L2-norm error: \n"; for( size_t i = 0; i < geoml2errs_global.size(); ++i ) { for( size_t j = 0; j < geoml2errs_global[i].size(); ++j ) { std::cout << geoml2errs_global[i][j] << " "; } std::cout << std::endl; } std::cout << "Linf-norm error: \n"; for( size_t i = 0; i < geomlinferrs_global.size(); ++i ) { for( size_t j = 0; j < geomlinferrs_global[i].size(); ++j ) { std::cout << geomlinferrs_global[i][j] << " "; } std::cout << std::endl; } #endif #ifdef MOAB_HAVE_MPI MPI_Finalize(); #endif }
void usage | ( | ) |
Definition at line 412 of file uref_hirec_test_parallel.cpp.
{ std::cout << "usage: mpirun -np <number of processors> ./uref_hirec_test_parallel <prefix of " "files> -str <first number> -end <lastnumber> -suffix <suffix> -interp <0=least " "square, 1=interpolation> -dim <mesh dimension> -geom <s=sphere,t=torus>" << std::endl; }
