- b -
- back()
: DLIList< X >
, DLList
- balance()
: AbstractTree< Z >
, KDDTree< Z >
- balance_round_robin()
: CGMReadParallel
- barycentric_coordinates()
: CubitVector
- base()
: CylinderEvaluator
- base_name()
: RefEntityName
- BasicTopologyEntity()
: BasicTopologyEntity
- bbox_overlap()
: CurveOverlapFacet
, SurfaceOverlapFacet
- bcast_and_delete_entity_list()
: CGMMemFile
- bcast_buffer()
: CGMParallelComm
, CGMMemFile
- bcast_entity_list()
: CGMMemFile
- begin()
: SimpleArray< T >
, DLIList< X >
, ManagedPtrVector< X >
, Hasher< Y, B >
- begin_loop()
: PartitionLumpImprint
- BeginQuery()
: ModelQueryEngine::BeginQuery
- BeginReadBlock()
: NCubitFile::CIOWrapper
- BeginReadFEModel()
: NCubitFile::CCubitFile
- BeginReadGeomModel()
- BeginReadModel()
- BeginReadSimModel()
- BeginRewriteBlock()
- BeginWriteBlock()
- BeginWriteFEModel()
- BeginWriteGeomModel()
- BeginWriteModel()
- BeginWriteSimModel()
- bezier_order()
: CubitFacetEdge
- bfs_to_find_contained_nodes()
: CubitOctreeNode
- binary_search()
: SDLList
- block_size()
: MemoryBlock
- blow_out()
: CubitVector
- bodies()
: GeometryQueryTool
, RefEntityFactory
, TopologyEntity
- bodies_interfering()
: GeometryModifyEngine
, OCCModifyEngine
- bodies_overlap()
: GeometryQueryEngine
, GeometryQueryTool
, FacetQueryEngine
, OCCQueryEngine
, VirtualQueryEngine
- Body()
: Body
- body()
: TopologyEntity
, SubEntitySet
- body_attributes_for_writing()
: OCCQueryEngine
- body_type()
: DagType
- BodySM()
: BodySM
- bodysm()
: TopologyBridge
- bodysms()
: TopologyBridge
- boolean_regularize()
: GeometryModifyTool
- bound_TopoDS_Shape()
: OCCQueryEngine
- boundary_edge_points()
: CubitFacetEdge
- BoundaryConstrainTool()
: BoundaryConstrainTool< SURF, TRI, EDGE, NODE, TRICHILD >
- bounding_box()
, Body
, BodySM
, CubitEvaluator
, CylinderEvaluator
, GeometryEntity
, GeomSeg
, Loop
, TBPoint
, PartPTCurve
, RefGroup
, Shell
, SphereEvaluator
, PartitionEntity
, CubitFacet
, CompositeLump
, CubitFacetEdge
, CubitPoint
, CurveFacetEvalTool
, FacetEvalTool
, FacetCurve
, FacetLoop
, FacetLump
, FacetPoint
, FacetSurface
, ContainmentPoint
, OCCCurve
, OCCLoop
, OCCLump
, OCCPoint
, OCCSurface
, CompositeCurve
, CompositeGeom
, CompositeSurface
, PartitionBody
, PartitionCoEdge
, PartitionLump
, PartitionPoint
, PartitionSurface
, SegmentedCurve
, SubCurve
, CubitBox
, CubitCoordinateSystem
, CubitEntity
, RStarTreeNode< Y >
, RTreeNode< Y >
- bounding_box_of_bodies()
: GeometryQueryTool
- bounding_cell_maximum_x()
: PointGridSearch
- bounding_cell_maximum_y()
: PointGridSearch
- bounding_cell_maximum_z()
: PointGridSearch
- bounding_cell_minimum_x()
: PointGridSearch
- bounding_cell_minimum_y()
: PointGridSearch
- bounding_cell_minimum_z()
: PointGridSearch
- bounding_length()
: PST_Face
- bounding_range()
: PointGridSearch
- bounding_range_maximum()
: PointGridSearch
- bounding_range_minimum()
: PointGridSearch
- BoundingBoxTool()
: BoundingBoxTool
- bowyer_watson_insert()
: FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC >
- box_kdtree_intersect()
: KDTree
- boxintersection()
: FBPolyhedron
- BoxVolume()
: BoxVolume
- brick()
, OCCModifyEngine
, GeometryModifyEngine
, FacetModifyEngine
, GeometryModifyTool
- bridge_destroyed()
: SubEntitySet
, TBOwner
, BridgeManager
- bridge_manager()
: TopologyEntity
, TopologyBridge
, TopologyEntity
, TopologyBridge
- bridge_sense()
: TopologyBridge
, CAMergePartner
- BridgeManager()
: BridgeManager
- broadcast_entities()
: CGMParallelComm
- build()
: InputDeck
- build_ancestor_list()
: CAGroup
- build_cholla_curve_geometry()
: FacetModifyEngine
- build_cholla_geometry()
: FacetModifyEngine
- build_cholla_loop_geometry()
: FacetModifyEngine
- build_cholla_point_geometry()
: FacetModifyEngine
- build_cholla_surface_geometry()
: FacetModifyEngine
- build_cholla_surfaces()
: FacetModifyEngine
- build_curve_eval_tools()
: ChollaEngine
- build_curve_facet_eval_tool()
: ChollaCurve
- build_curve_from_edges()
: ChollaCurve
- build_curve_geometry()
: FacetGeometryCreator
- build_eval_tools()
: ChollaEngine
- build_facet_surface()
: FacetModifyEngine
- build_geometry()
- build_loop_geometry()
- build_octree_till_min_depth()
: CubitOctree
- build_octree_till_skl_max_depth_based_on_facets()
: CubitOctreeGeneratorVolumes
- build_param_list()
: SSSide
- build_param_list_from_facets()
: SSSide
- build_point_geometry()
- build_surface_and_curve_eval_tools()
: ChollaEngine
- build_surface_geometry()
- build_td_mref_edges()
- build_td_mref_faces()
