- f -
- face()
: PST_CoEdge
- face_between()
: GeoNode
- face_edge_imprint()
: OCCModifyEngine
- face_list_from_volume_list()
: GeomMeasureTool
- faces()
: PST_Point
, PST_Edge
- facet_area_coordinate()
: FacetEvalTool
- facet_dimension()
: ChollaEngine
- facet_factory()
: Faceter
- facet_list()
: GMem
- facet_list_size()
: GMem
- facet_loop()
: Faceter
- facet_point()
: PartitionPoint
- facet_points_within_tol()
: SurfaceOverlapFacet
- facet_surface()
: Faceter
- facet_to_facet_distance()
: CurveOverlapFacet
- FacetAttrib()
: FacetAttrib
- FacetAttribSet()
: FacetAttribSet
- FacetBody()
: FacetBody
- facetbody_to_facetbool()
: FacetboolInterface
- FacetboolInterface()
- FacetCoEdge()
: FacetCoEdge
- FacetCurve()
: FacetCurve
- FacetEntity()
: FacetEntity
- Faceter()
: Faceter
- FaceterFacetData()
: FaceterFacetData
- FaceterPointData()
: FaceterPointData
- FacetEvalTool()
: FacetEvalTool
- FacetGeometryCreator()
: FacetGeometryCreator
- FacetLoop()
: FacetLoop
- FacetLump()
: FacetLump
- FacetModifyEngine()
: FacetModifyEngine
- FacetorTool()
: FacetorTool< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC >
- FacetorUtil()
: FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC >
- FacetParamTool()
: FacetParamTool
- FacetPoint()
: FacetPoint
- FacetProjectTool()
: FacetProjectTool
- FacetQueryEngine()
: FacetQueryEngine
- facets()
: CubitFacet
, CubitFacetEdge
, CubitFacetEdgeData
, CubitPoint
, CubitPointData
, CubitQuadFacet
, FacetEntity
, FaceterPointData
, ImprintPointData
- facets_from_search_grid()
: FacetEvalTool
- facets_on_surf()
: CubitPoint
- FacetShell()
: FacetShell
- FacetSurface()
: FacetSurface
- facing()
- factor()
: CubitMatrix
- fast_edge_sort()
: CompositeTool
- FB_Coord()
: FB_Coord
- FB_Edge()
: FB_Edge
- FB_imprint_with_curves()
- FB_Triangle()
: FB_Triangle
- FBClassify()
: FBClassify
- FBImprint()
: FBImprint
- FBIntersect()
: FBIntersect
- FBmake_cylinder()
: FBDataUtil
- FBmake_xy_plane()
: FBDataUtil
- FBPolyhedron()
: FBPolyhedron
- FBRetriangulate()
: FBRetriangulate
- FBTiler()
: FBTiler
- FBTilerChainVert()
: FBTilerChainVert
- feature_angle()
: ChollaCurve
, ChollaSurface
- feature_type()
: GeometryFeatureEngine
, GeometryFeatureTool
- feature_type_to_string()
: CASourceFeature
- file()
: CubitFile
- file_exist()
: CubitUtil
- file_info()
: CubitFileUtil
- FileOptions()
: FileOptions
- Fill()
: Fill
- fill_boundary_coords()
: SplitSurfaceTool
- fill_corners()
: SplitSurfaceTool
- fill_group()
: FBClassify
- fill_interior_coords()
: SplitSurfaceTool
- fill_side_intervals()
: SplitSurfaceTool
- fillinedge()
: FacetModifyEngine
- FillNode()
: FillNode
- final_match()
: ImprintBoundaryTool
- final_match_loop()
- finalize_results()
: FacetProjectTool
- find()
: VGArray< T >
, AbstractTree< Z >
, CubitString
, KDDTree< Z >
, RTree< Z >
, OrderedMap< X, Y >
- Find()
: NCubitFile::CMetaData
- find_adjacent_face_ratios()
: GeomMeasureTool
- find_area_overlap()
: SurfaceOverlapTool
- find_attribute()
: OCCAttribSet
- find_attribute_by_name()
: CompositeEngine
- find_bad_geometry()
: GeomMeasureTool
- find_best_curves_to_merge()
: GeometryModifyTool
- find_blend_chains()
: GeomMeasureTool
- find_blends()
: GeomMeasureTool
- find_blends_from_edge()
: GeomMeasureTool
- find_candidate_surfaces_for_imprinting()
- find_cell_list_intersecting_line_segment()
: CubitOctree
- find_cells_based_on_surface_angle()
: CubitOctree
- find_close_loops()
: GeomMeasureTool
- find_closed_narrow_faces()
: GeomMeasureTool
- find_closest()
: PartitionLumpImprint
- find_closest_int_point_with_boundary()
: FacetProjectTool
- find_closest_point_trimmed()
: RefFace
- find_closest_points()
- find_closest_points_trimmed()
: RefFace
- find_closest_vertex_curve_pairs()
: GeomMeasureTool
- find_closest_vertex_vertex_pairs()
: GeomMeasureTool
- find_coedges()
: CompositeEngine
, PartitionEngine
- find_connected_ref_edge()
: GeometryUtil
- find_connected_ref_edge_by_coord()
: GeometryUtil
- find_connected_ref_edges()
: GeometryUtil
- find_connected_ref_edges_by_coord()
: GeometryUtil
- find_coord()
- find_crossings()
- find_cubit_attrib_type()
: CubitAttribUser
- find_curv_sense()
: CurveFacetEvalTool
- find_curve_curvature_using_three_points()
: TDOctreeRefEdge
- find_curves()
: OldUnmergeCode
- find_dihedral_angles()
: GeomMeasureTool
- find_distance_at_adj_node()
: CubitOctreeNode
- find_element()
: ChollaMesh
- find_face_with_non_zero_param_dir()
: SplitCompositeSurfaceTool
- find_faces_for_pos()
- find_facet()
: FacetDataUtil
- find_file_use()
: CubitMessage
- find_first()
: CompositeShell
, CompositeSurface
, PartitionShell
, PartitionSurface
, CubitString
- find_first_of()
: CubitString
- find_first_small_curve()
: GeomMeasureTool
- find_floating_volumes()
: GeometryQueryTool
- find_graph_for_surf()
- find_half_space()
: CubitOctreeNode
- find_home_path()
: CubitFileUtil
- find_id()
: DLT_IdTable
- find_imprinting_edge()
: OCCModifyEngine
- find_index()
: GeomMeasureTool
- find_indices_in_parent()
: CubitOctreeCell
- find_interior_curve_angles()
: GeomMeasureTool
- find_intersection_between_grid_edges_and_facet()
: CubitOctree
- find_intersection_between_octree_and_facets()
: CubitOctreeGeneratorVolumes
- find_intersection_point()
: CubitOctreeNode
- find_intersection_with_facet()
: CubitOctreeNode
- find_irregular_valence()
: GeomMeasureTool
- find_item()
: DynamicTreeIterator< TreeType, OutType, Which >
- find_last()
: CubitString
- find_leaf()
: RStarTreeNode< Y >
, RTreeNode< Y >
- find_leaf_octree_cell()
: CubitOctreeCell
- find_loop_start()
: SplitSurfaceTool
- find_matching_points()
- find_max_height()
: KDDTree< Z >
- find_max_min_size_grid_node_for_scaling()
: CubitOctree
- find_merge_tool_assistant()
: MergeTool
- find_mergeable_refedges()
: MergeTool
- find_mergeable_refentities()
: MergeTool
- find_mergeable_reffaces()
: MergeTool
- find_mergeable_refvertices()
: MergeTool
- find_merged_coedgesm()
: GeometryQueryTool
- find_min_depth_cell_and_depth_difference()
: CubitOctreeNode
- find_minimum_node_of_dimension()
: KDDTree< Z >
- find_narrow_faces()
: GeomMeasureTool
- find_near_coincident_vertex_curve_pairs()
: GeomMeasureTool
- find_near_coincident_vertex_surface_pairs()
: GeomMeasureTool
- find_near_coincident_vertices()
: GeomMeasureTool
- find_near_coincident_vertices_unique()
: GeomMeasureTool
- find_nearest_curve_for_normal_projection()
: SplitSurfaceTool
- find_next()
: PartitionShell
, CompositeShell
, CompositeSurface
, PartitionSurface
- find_next_point_coedge()
: CompositeEngine
- find_node_containing_data()
: KDDTree< Z >
- find_nonmanifold_curves()
: GeometryQueryTool
- find_nonmanifold_vertices()
: GeometryQueryTool
- find_octree_cells_contained_inside_bbox()
: CubitOctree
- find_octreecell()
: CubitOctree
- find_offset_pair_patches()
: AutoMidsurfaceTool
- find_only_mergeable_curves()
: MergeTool
- find_only_mergeable_refedges()
: MergeTool
- find_only_mergeable_surfaces()
: MergeTool
- find_opposite_edge()
: GeomMeasureTool
- find_optimal_min_and_max_depth()
- find_optimal_min_and_max_octree_depths()
- find_overlap_region()
- find_overlapping_curves()
- find_overlapping_surfaces()
- find_parent_body()
: PartitionLump
- find_parent_loop()
: PartitionCoEdge
- find_radius_at_boundary_node()
: CubitOctree
- find_sense()
: PartitionShell
, CompositeShell
- find_sense_entity()
: BasicTopologyEntity
- find_sharp_tangential_meets()
: GeomMeasureTool
- find_shells()
: GeomMeasureTool
- find_size_using_adj_node()
: CubitOctreeNode
- find_small_curves()
: GeomMeasureTool
- find_small_faces()
: GeomMeasureTool
- find_small_faces_hydraulic_radius()
: GeomMeasureTool
- find_small_volumes()
: GeomMeasureTool
- find_small_volumes_hydraulic_radius()
: GeomMeasureTool
- find_spline_curves()
: SplitSurfaceTool
- find_split_points_for_narrow_regions()
: GeomMeasureTool
- find_start_point_for_edge_list()
: CubitFacetEdge
- find_surfaces()
: OldUnmergeCode
- find_surfs_with_narrow_regions()
: GeomMeasureTool
- find_td_unique_id()
: TDUniqueId
- find_the_median()
: KDTree
- findcurve()
- FindExtendedEndPt()
- FindExtendedPoints()
- FindExtendedStartPt()
- FindModel()
: NCubitFile::CCubitFile
- FindShape()
: OCCAttribSet
- finish()
: TetFacetorTool< TET, SUBTET, NODE >
, CellCardImpl
- finish_bc_webcut()
- finish_copy()
- finish_facet_Body()
: FacetModifyEngine
- finish_merge()
: MergeToolAssistant
- finish_sm_op()
- finish_unmerge()
- finish_webcut()
- fire_ray()
: GeometryQueryEngine
, GeometryQueryTool
, FacetQueryEngine
, OCCQueryEngine
, GeometryQueryTool
, VirtualQueryEngine
- first()
: OrderedSet< X >
- first_co_surf()
: CompositeShell
- first_coedge()
: PST_Face
, CompositeLoop
, PartitionLoop
, CompositeCurve
- first_loop()
: CompositeSurface
- first_shell()
: PartitionLump
, CompositeLump
- fit_points()
: CubitPlane
- fix()
: GridSearchTree
- fix_edge()
: ChollaEngine
- fix_facet_data()
: PartitionCurve
- fix_geometry()
: ChollaEngine
- fix_move_point()
: PartSurfFacetTool
- fix_non_manifold_edge()
: ChollaEngine
- fix_point_edge_order()
- fix_split_edge()
: ChollaEngine
- fix_split_non_manifold_edge()
: ChollaEngine
- fixup_merged_entities()
- fixup_periodic_param()
: SubCurve
, CompositeCurve
- flag_boundary()
: ChordalAxis
- flag_boundary_edge()
: TDChordal
- flagging_boundary()
: ChordalAxis
- flip()
: CubitFacetEdge
, CubitFacet
, FaceterFacetData
, CubitFacetData
- flip_edge()
: CubitFacetData
- flip_facets()
: ChollaSurface
- flip_normals()
: OCCModifyEngine
, GeometryModifyEngine
, FacetModifyEngine
- flush()
: RTreeNode< Y >
, GfxPreview
, RStarTreeNode< Y >
, GfxDebug
- force_insert()
: OrderedSet< X >
- force_merge()
: MergeTool
- force_simplify_to_cone()
: GeometryHealerEngine
, GeometryHealerTool
- force_simplify_to_cylinder()
: GeometryHealerTool
, GeometryHealerEngine
- force_simplify_to_plane()
- force_simplify_to_sphere()
- force_simplify_to_torus()
- form_ref_edge_chain()
: GeometryUtil
- form_ref_edge_chain_by_coord()
: GeometryUtil
- form_ref_edge_loop()
: GeometryUtil
- form_ref_edge_loop_by_coord()
: GeometryUtil
- format()
: CubitString
- forward()
: PST_Edge
- fraction_empty_cells()
: PointGridSearch
- fraction_from_arc_length()
: RefEdge
- free_curves_lists()
: SplitSurfaceTool
- free_instance()
: CubitMessage
- FreeAll()
, NCubitFile::CCubitFile
- FreeAt()
- FreeValueAt()
- frobenius_norm_squared()
: CubitMatrix
- frobenius_norm_squared_adj()
: CubitMatrix
- frobenius_norm_squared_inv()
: CubitMatrix
- frobenius_norm_squared_symm()
: CubitMatrix
- FSBoundingBox()
: FSBoundingBox
- functional_type()
: DagType
