- a -
- abort_imprint()
: PartitionLumpImprint
- about_equal()
: CubitVector
- about_spatially_equal()
: GeometryQueryTool
, MergeTool
, CompositeEngine
, MergeTool
, GeometryQueryTool
, MergeTool
, CoEdge
, Loop
, RefEdge
, RefFace
, MergeTool
, RefVertex
, RefVolume
- Abs()
: AnalyticGeometryTool
- ac_at_edge()
: FacetEvalTool
- ACos()
- actuate()
: CubitAttrib
, CABodies
, CACompositeVG
, CAPartitionVG
, CAVirtualVG
, CAAssemblyData
, CATag
, CADeferredAttrib
, CAEntityColor
, CAEntityId
, CAEntityName
, CAEntitySense
, CAEntityTol
, CAGroup
, CAMergePartner
, CAMergeStatus
, CASourceFeature
, CAUniqueId
- actuate_after_geom_changes()
: CubitAttrib
, CubitAttribManager
- actuate_all()
: CAUniqueId
- actuate_cubit_attrib()
: CubitAttribUser
- actuate_in_constructor()
: CubitAttrib
- actuate_list()
: CAMergePartner
, CubitAttrib
- add()
: CompositeShell
, CompositeSurface
, PartitionBody
, PartitionCurve
, PartitionLump
, PartitionLumpImprint
, PartitionShell
, PartitionSurface
, AbstractTree< Z >
, CubitMatrix
, CubitSparseMatrix
, KDDTree< Z >
, RTree< Z >
, Hasher< Y, B >
, HasherVector< Y, S >
, Vector3d
, GeometryContext::NamedGroup
- Add()
: OCCShapeAttributeSet
- add()
: RefEntityFactory
, GridSearchTreeNode
, CompositeBody
, CompositeCurve
, CompositeLump
, CompositeShell
- add_a_coedges()
: TDSplitSurface
- add_adjacent_unmarked_cells()
: CubitOctreeCell
- add_attribute()
: CubitAttrib
, CompositeGeom
, SubEntitySet
- add_b_coedges()
: TDSplitSurface
- add_bdry_edges()
: FBRetriangulate
- add_body()
: FacetLump
, OCCLump
- add_bridge()
: BridgeManager
- add_bridge_as_representation()
: BridgeManager
- add_c_coedges()
: TDSplitSurface
- add_child()
: RStarTreeNode< Y >
, RTreeNode< Y >
- add_cholla_curve()
: TDGeomFacet
- add_cholla_owner()
: TDGeomFacet
- add_cholla_point()
: TDGeomFacet
- add_cholla_surf()
: TDGeomFacet
- add_coedge()
: FacetCurve
- add_coedges()
: TDSplitSurface
- add_compare_data()
: RefEntity
- add_csa_data()
: CATag
- add_cubit_attrib()
: CubitAttribUser
- add_curve()
: ChollaPoint
, ChollaSurface
, FacetPoint
, OCCPoint
- add_curve_unique()
: ChollaSurface
- add_d_coedges()
: TDSplitSurface
- add_deactivated_DAG_node()
: DAG
- add_edge()
: CubitFacet
- add_edge_down()
: FBRetriangulate
- add_edge_up()
: FBRetriangulate
- add_element()
: GeoNode
- add_error_id()
: GSaveOpen
- add_event()
: CGMHistory
, OCCHistory
- add_facet()
: FaceterPointData
, ImprintPointData
, ChollaCurve
, ChollaPoint
, ChollaSurface
, CubitFacetEdge
, CubitFacetEdgeData
, CubitPoint
, CubitPointData
- add_facet_boundary_edge()
: TDFacetBoundaryEdge
- add_facet_boundary_point()
: TDFacetBoundaryPoint
- add_facet_unique()
: ChollaCurve
- add_facetbool_facet()
: TDFacetboolData
- add_facets()
: CubitFacetEdge
- add_geom_facet()
: TDGeomFacet
- add_gfe()
: GeometryFeatureTool
- add_ghe()
: GeometryHealerTool
- add_ghost_proc()
: TDParallel
- add_gme()
: GeometryModifyTool
- add_gqe()
: GeometryQueryTool
- add_grouping_entity()
: BasicTopologyEntity
- add_hard_point()
: RefFace
- add_hardpoint()
: OCCSurface
- add_hash_point()
: FacetQueryEngine
- add_intersection_edges()
: FBIntersect
- add_loop()
: FacetCoEdge
, OCCCurve
- add_lower_order()
: SubEntitySet
- add_lump()
: FacetBody
, FacetShell
- add_match_data()
: ImprintLineSegment
, ImprintPointData
- add_merge_tool_assistant()
: MergeTool
- add_mesh_unique()
: ChollaSurface
- add_name_to_path()
: CubitFileUtil
- add_new_triangle_data()
: FBPolyhedron
- add_nodes()
: OctTreeCell< X, E >
- add_observer()
: CubitEventDispatcher
, CubitObservable
- add_origin_to_rotation_mtx()
- add_partition()
: SubEntitySet
- add_partner_edge()
: TDGeomFacet
- add_partner_point()
: TDGeomFacet
- add_point()
: CubitPolygon
, ChollaCurve
, PointGridSearch
, TDGeomFacet
- add_point_to_cell()
: PointGridSearch
- add_port_event()
: CGMHistory
- add_preexisting_feature_edges()
: ChollaSurface
- add_ref_entity()
: RefGroup
- add_refentity_name()
: RefEntityName
- add_refentity_tracking_id_pair()
: OCCHistory
- add_sense_entity()
, GroupingEntity
- add_setting()
: SettingHandler
- add_shape_to_map()
: OCCQueryEngine
- add_shared_proc()
: TDParallel
- add_shell()
: FacetLump
, FacetSurface
- add_surf()
, TDFacetBoundaryPoint
- add_surf_facet()
- add_surf_facets()
- add_surface()
: ChollaCurve
, ChollaVolume
, FacetLoop
- add_surface_unique()
: ChollaVolume
- add_td()
: TDOctreeRefEdge
, TDOctreeRefFace
- add_TD()
: ToolDataUser
- add_this_bdry_edge()
: FBRetriangulate
- add_to_deactivated_list()
: PartitionEngine
- add_to_error_count()
: CubitMessage
- add_to_id_map()
: PartitionEngine
- add_to_TD()
: TDPtr
- add_to_tracking_ids_tb_map()
: OCCHistory
- add_to_warning_count()
: CubitMessage
- add_tooldata()
: SplitSurfaceTool
- add_TopoDS_Shape()
: OCCHistory
- add_transformation()
: CubitEvaluator
, FacetSurface
- add_tri_edge()
: FBRetriangulate
- add_triangle()
: FBTiler
- add_type()
: TDSplitSurface
- add_unactuated_ca()
: CADeferredAttrib
- add_unique_point()
: FBDataUtil
- add_volume()
: ChollaSurface
- add_volume_unique()
: ChollaSurface
- addavertex()
: FBPolyhedron
- AddEntry()
: NCubitFile::CMetaData
- AddGeometry()
- addNode()
: WeightedOctree< X, C, E >::Cell
, WeightedOctree< X, C, E >
- addOpt()
: ProgOptions
- addOptionalArgs()
: ProgOptions
- addOptionHelpHeading()
: ProgOptions
- addRequiredArg()
: ProgOptions
- addRow()
: VariableArray< T >
- addtoHashList()
: IntegerHash
- addToVolumeGroup()
: GeometryContext
- addWeight()
- adj_facet()
: CubitFacetEdge
- adj_facet_edges()
: ChollaCurve
- adj_facet_on_surf()
: CubitFacetEdge
- adjacent()
: CubitFacet
- adjacent_points()
: CubitPoint
- adjoins()
: RefFace
- adjoint()
: CubitMatrix
- adjust_for_split_direction()
: SplitSurfaceTool
- adjust_periodic_parameter()
: FacetCurve
, OCCCurve
- adjust_tree()
, RTreeNode< Y >
- AdjustBuffer()
: NCubitFile::CFEModel
, NCubitFile::CSimModel
- align_entities()
- all_chars_are()
: CubitFileUtil
- allocate_8()
: OctTree< X, E >
- allocate_edge()
: CubitFacetData
- allocate_more_polylines()
: GMem
- allocate_polylines()
: GMem
- allocate_tri()
: GMem
- allocateMoreHash()
: IntegerHash
- AnalyticGeometryTool()
- analyze_badgeom()
: GeometryHealerEngine
, GeometryHealerTool
- Angle()
- angle()
: CurveOverlapFacet
, SurfaceOverlapFacet
, CubitFacet
- angle_between()
: RefEdge
- angle_between_facets()
: CubitFacetEdge
- angle_metric()
: LoopAngles
- angle_vec_vec()
- AngleAxisToMatrix()
- angles_between_volume_surfaces()
: GeomMeasureTool
- apd_vector_item()
: CubitOctree
- append()
: DLIList< X >
, OrderedSet< X >
, CompositeGeom
- append_all_nodes()
- append_attrib()
: CompositeEngine
- append_attrib_internal()
: CubitAttribUser
- append_attribute()
: FacetAttribSet
, OCCAttribSet
- append_body_points()
: BoundingBoxTool
- append_curve_points()
: BoundingBoxTool
- append_link()
: DLList
, SDLList
- append_list_item()
: CubitOctreeNode
, TDOctreeRefFace
, CubitOctreeCell
- append_nodes()
- append_points()
: PST_Face
- append_ref_entity_points()
: BoundingBoxTool
- append_refentity_list()
: CGMMemFile
- append_simple_attribute()
: CubitAttribUser
- append_simple_attribute_virt()
: FacetCurve
, OCCShell
, PartitionBody
, FacetBody
, PartitionCoEdge
, FacetPoint
, TopologyBridge
, FacetLoop
, FacetLump
, FacetSurface
, OCCLoop
, OCCPoint
, OCCSurface
, FacetCoEdge
, CompositeLoop
, CompositeLump
, CompositePoint
, CompositeSurface
, PartitionLoop
, PartitionPoint
, PartitionSurface
, CompositeBody
, CompositeCoEdge
, OCCCurve
, OCCLump
, FacetShell
, OCCBody
, PartitionCurve
, PartPTCurve
, PartitionShell
, PartitionLump
, CompositeCurve
, CompositeShell
, OCCCoEdge
- append_surface_points()
: BoundingBoxTool
- append_to_buffer()
: CGMParallelComm
- append_to_csa()
: CompositeAttrib
- append_to_current()
: CAActuateSet
- append_to_lists()
: CompositeAttrib
- append_unique()
: DLList
, DLIList< X >
- append_vertex_points()
: BoundingBoxTool
- append_volume_points()
: BoundingBoxTool
- appendAllNodes()
- appendNodes()
- AppUtil()
: AppUtil
- apputil_getrusage()
: AppUtil
- are_connected()
: ImprintBoundaryTool
- are_fb_coords_in_fb_triangle()
: FB_Triangle
- are_nodes_colinear()
: FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC >
- are_positions_on()
: Surface
- area()
: RefFace
, FacetEvalTool
- Area()
- area()
: CubitFacet
- AreaHashTuple()
: AreaHashTuple
- AreaIntersection()
- AreaTriangle()
- ArrayBasedContainer()
: ArrayBasedContainer
- ArrayMemory()
: ArrayMemory
- as_vector()
: DLIList< X >
, OrderedSet< X >
- ask_type()
: SphereEvaluatorData
, CylinderEvaluatorData
, SphereEvaluator
, CubitEvaluator
, CubitEvaluatorData
, CylinderEvaluator
- aspect_ratio()
: CubitFacet
- assign_ancestor_group()
: CAGroup
- assign_default_name()
: RefEntity
- assign_eval_tool()
: ChollaSurface
, ChollaCurve
- assign_geometric_curve()
: ChollaCurve
- assign_geometric_point()
: ChollaPoint
- assign_geometric_surface()
: ChollaSurface
- assign_geometric_volume()
: ChollaVolume
- assign_group()
: CAGroup
- assign_to_owner()
: CADeferredAttrib
- associate_curves()
: VirtualQueryEngine
- associate_points()
: PartSurfFacetTool
- at_end()
: CGMAIterator
- ATan2()
- att_internal_name()
: CubitAttribManager
, CubitAttrib
- att_name()
- attach_basic_topology_entity()
: SenseEntity
- attempt_barycentric_coordinates_adjustment()
: CubitVector
- attrib_manager()
: CGMApp
- attrib_owner()
: CubitAttrib
- attrib_type()
- attrib_type_from_internal_name()
- attribute_after_imprinting()
: PartitionEngine
, CompositeEngine
, IntermediateGeomEngine
- attribute_count()
: OCCAttribSet
, FacetAttribSet
- auto_actuate_cubit_attrib()
: CubitAttribUser
- auto_actuate_flag()
: CubitAttrib
- auto_collapse()
: CollapseAngleTool
- auto_create_for_merge()
: CubitAttribUser
- auto_flag()
- auto_heal_bodies()
, GeometryHealerEngine
- auto_mid_surface()
- auto_read_cubit_attrib()
: CubitAttribUser
- auto_read_flag()
: CubitAttrib
, CubitAttrib
- auto_reset_cubit_attrib()
: CubitAttribUser
- auto_unique_id()
: CAUniqueId
- auto_update_attribs()
- auto_update_cubit_attrib()
: CubitAttribUser
- auto_update_flag()
, CubitAttrib
- auto_write_flag()
: CubitAttrib
, CubitAttrib
- AutoMidsurfaceTool()
: AutoMidsurfaceTool
- available_feature_types()
: GeometryFeatureEngine
, GeometryFeatureTool
- average_points_per_occupied_cell()
: PointGridSearch
- avoid_facet()
: Faceter
- axis_extraction()
: ChordalAxis
