MOAB: Mesh Oriented datABase
(version 5.4.1)
Definition at line 13 of file GeomUtilTests.cpp.
Referenced by general_box_hex_overlap_test(), general_box_tet_overlap_test(), general_box_tri_overlap_test(), test_box_plane_norm(), test_plucker_ray_tri_intersect(), test_ray_tri_intersect(), and test_segment_box_intersect().
#define ASSERT_DOUBLES_EQUAL | ( | A, | |
B | |||
) | CHECK_REAL_EQUAL( A, B, TOL ) |
Definition at line 12 of file GeomUtilTests.cpp.
Referenced by test_plucker_ray_tri_intersect(), test_ray_tri_intersect(), and test_segment_box_intersect().
#define ASSERT_VECTORS_EQUAL | ( | A, | |
B | |||
) | assert_vectors_equal( ( A ), ( B ), #A, #B, __LINE__ ) |
Definition at line 11 of file GeomUtilTests.cpp.
Referenced by test_closest_location_on_box(), test_closest_location_on_polygon(), and test_closest_location_on_tri().
void assert_vectors_equal | ( | const CartVect & | a, |
const CartVect & | b, | ||
const char * | sa, | ||
const char * | sb, | ||
int | lineno | ||
Definition at line 15 of file GeomUtilTests.cpp.
References FLAG_ERROR, and TOL.
{ if( fabs( a[0] - b[0] ) > TOL || fabs( a[1] - b[1] ) > TOL || fabs( a[2] - b[2] ) > TOL ) { std::cerr << "Assertion failed at line " << lineno << std::endl << "\t" << sa << " == " << sb << std::endl << "\t[" << a[0] << ", " << a[1] << ", " << a[2] << "] == [" << b[0] << ", " << b[1] << ", " << b[2] << "]" << std::endl; FLAG_ERROR; } }
void general_box_hex_overlap_test | ( | const ElemOverlapTest & | overlap | ) |
Definition at line 373 of file GeomUtilTests.cpp.
References ASSERT.
Referenced by test_box_hex_overlap(), and test_box_linear_elem_overlap_hex().
{ CartVect coords[8]; // test against axis-aligned rectilinear hex coords[0] = CartVect( -0.5, -0.5, -0.5 ); coords[1] = CartVect( 0.5, -0.5, -0.5 ); coords[2] = CartVect( 0.5, 0.5, -0.5 ); coords[3] = CartVect( -0.5, 0.5, -0.5 ); coords[4] = CartVect( -0.5, -0.5, 0.5 ); coords[5] = CartVect( 0.5, -0.5, 0.5 ); coords[6] = CartVect( 0.5, 0.5, 0.5 ); coords[7] = CartVect( -0.5, 0.5, 0.5 ); ASSERT( overlap( coords, CartVect( 0, 0, 0 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( 1, 0, 0 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( 0, 1, 0 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( 0, 0, 1 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( -1, 0, 0 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( 0, -1, 0 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( 0, 0, -1 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( 1, 1, 0 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( -1, 1, 0 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( -1, -1, 0 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( 1, -1, 0 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( 1, 0, 1 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( -1, 0, 1 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( -1, 0, -1 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( 1, 0, -1 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( 0, 1, 1 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( 0, -1, 1 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( 0, -1, -1 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( 0, 1, -1 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( -1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( -1, -1, 1 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( 1, -1, 1 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( 1, 1, -1 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( -1, 1, -1 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( -1, -1, -1 ), CartVect( 1, 1, 1 ) ) ); ASSERT( overlap( coords, CartVect( 1, -1, -1 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( 3, 0, 0 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( 0, 3, 0 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( 0, 0, 3 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( -3, 0, 0 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( 0, -3, 0 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( 0, 0, -3 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( 3, 3, 0 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( -3, 3, 0 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( -3, -3, 0 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( 3, -3, 0 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( 3, 0, 3 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( -3, 0, 3 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( -3, 0, -3 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( 3, 0, -3 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( 0, 3, 3 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( 0, -3, 3 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( 0, -3, -3 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( 0, 3, -3 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( 3, 3, 3 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( -3, 3, 3 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( -3, -3, 3 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( 3, -3, 3 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( 3, 3, -3 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( -3, 3, -3 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( -3, -3, -3 ), CartVect( 1, 1, 1 ) ) ); ASSERT( !overlap( coords, CartVect( 3, -3, -3 ), CartVect( 1, 1, 1 ) ) ); // test against rectilinear hex rotated 45 degrees about z axis const double r = sqrt( 2.0 ) / 2.0; coords[0] = CartVect( r, 0, -0.5 ); coords[1] = CartVect( 0, r, -0.5 ); coords[2] = CartVect( -r, 0, -0.5 ); coords[3] = CartVect( 0, -r, -0.5 ); coords[4] = CartVect( r, 0, 0.5 ); coords[5] = CartVect( 0, r, 0.5 ); coords[6] = CartVect( -r, 0, 0.5 ); coords[7] = CartVect( 0, -r, 0.5 ); ASSERT( overlap( coords, CartVect( 1, 0, 0 ), CartVect( 0.5, 0.5, 0.5 ) ) ); ASSERT( overlap( coords, CartVect( -1, 0, 0 ), CartVect( 0.5, 0.5, 0.5 ) ) ); ASSERT( overlap( coords, CartVect( 0, 1, 0 ), CartVect( 0.5, 0.5, 0.5 ) ) ); ASSERT( overlap( coords, CartVect( 0, -1, 0 ), CartVect( 0.5, 0.5, 0.5 ) ) ); ASSERT( !overlap( coords, CartVect( 1, 0, 2 ), CartVect( 0.5, 0.5, 0.5 ) ) ); ASSERT( !overlap( coords, CartVect( -1, 0, 2 ), CartVect( 0.5, 0.5, 0.5 ) ) ); ASSERT( !overlap( coords, CartVect( 0, 1, 2 ), CartVect( 0.5, 0.5, 0.5 ) ) ); ASSERT( !overlap( coords, CartVect( 0, -1, 2 ), CartVect( 0.5, 0.5, 0.5 ) ) ); ASSERT( !overlap( coords, CartVect( 2, 0, 0 ), CartVect( 0.5, 0.5, 0.5 ) ) ); ASSERT( !overlap( coords, CartVect( -2, 0, 0 ), CartVect( 0.5, 0.5, 0.5 ) ) ); ASSERT( !overlap( coords, CartVect( 0, 2, 0 ), CartVect( 0.5, 0.5, 0.5 ) ) ); ASSERT( !overlap( coords, CartVect( 0, -2, 0 ), CartVect( 0.5, 0.5, 0.5 ) ) ); ASSERT( !overlap( coords, CartVect( 1, 1, 0 ), CartVect( 0.5, 0.5, 0.5 ) ) ); ASSERT( !overlap( coords, CartVect( -1, 1, 0 ), CartVect( 0.5, 0.5, 0.5 ) ) ); ASSERT( !overlap( coords, CartVect( -1, -1, 0 ), CartVect( 0.5, 0.5, 0.5 ) ) ); ASSERT( !overlap( coords, CartVect( 1, -1, 0 ), CartVect( 0.5, 0.5, 0.5 ) ) ); ASSERT( overlap( coords, CartVect( 1, 1, 0 ), CartVect( 0.75, 0.75, 0.5 ) ) ); ASSERT( overlap( coords, CartVect( -1, 1, 0 ), CartVect( 0.75, 0.75, 0.5 ) ) ); ASSERT( overlap( coords, CartVect( -1, -1, 0 ), CartVect( 0.75, 0.75, 0.5 ) ) ); ASSERT( overlap( coords, CartVect( 1, -1, 0 ), CartVect( 0.75, 0.75, 0.5 ) ) ); }
void general_box_tet_overlap_test | ( | const ElemOverlapTest & | overlap | ) |
Definition at line 484 of file GeomUtilTests.cpp.
References ASSERT.
Referenced by test_box_linear_elem_overlap_tet(), and test_box_tet_overlap().
{ CartVect coords[4]; // Octant I coords[0] = CartVect( 0, 0, 0 ); coords[1] = CartVect( 1, 0, 0 ); coords[2] = CartVect( 0, 1, 0 ); coords[3] = CartVect( 0, 0, 1 ); // tet entirely within box ASSERT( overlap( coords, CartVect( -1, -1, -1 ), CartVect( 3, 3, 3 ) ) ); // box entirely within tet ASSERT( overlap( coords, CartVect( 0.2, 0.2, 0.2 ), CartVect( 0.1, 0.1, 0.1 ) ) ); // box corner penetrates tet face ASSERT( overlap( coords, CartVect( 0.5, 0.5, 0.5 ), CartVect( 0.2, 0.2, 0.2 ) ) ); // box corner does not penetrate face ASSERT( !overlap( coords, CartVect( 0.5, 0.5, 0.5 ), CartVect( 0.15, 0.15, 0.15 ) ) ); // Octant II coords[0] = CartVect( 0, 1, 0 ); coords[1] = CartVect( -1, 0, 0 ); coords[2] = CartVect( 0, 0, 0 ); coords[3] = CartVect( 0, 0, 1 ); // tet entirely within box ASSERT( overlap( coords, CartVect( 1, -1, -1 ), CartVect( 3, 3, 3 ) ) ); // box entirely within tet ASSERT( overlap( coords, CartVect( -0.2, 0.2, 0.2 ), CartVect( 0.1, 0.1, 0.1 ) ) ); // box corner penetrates tet face ASSERT( overlap( coords, CartVect( -0.5, 0.5, 0.5 ), CartVect( 0.2, 0.2, 0.2 ) ) ); // box corner does not penetrate face ASSERT( !overlap( coords, CartVect( -0.5, 0.5, 0.5 ), CartVect( 0.15, 0.15, 0.15 ) ) ); // Octant III coords[0] = CartVect( 0, -1, 0 ); coords[1] = CartVect( 0, 0, 0 ); coords[2] = CartVect( -1, 0, 0 ); coords[3] = CartVect( 0, 0, 1 ); // tet entirely within box ASSERT( overlap( coords, CartVect( 1, 1, -1 ), CartVect( 3, 3, 3 ) ) ); // box entirely within tet ASSERT( overlap( coords, CartVect( -0.2, -0.2, 0.2 ), CartVect( 0.1, 0.1, 0.1 ) ) ); // box corner penetrates tet face ASSERT( overlap( coords, CartVect( -0.5, -0.5, 0.5 ), CartVect( 0.2, 0.2, 0.2 ) ) ); // box corner does not penetrate face ASSERT( !overlap( coords, CartVect( -0.5, -0.5, 0.5 ), CartVect( 0.15, 0.15, 0.15 ) ) ); // Octant IV coords[0] = CartVect( 1, 0, 0 ); coords[1] = CartVect( 0, -1, 0 ); coords[2] = CartVect( 0, 0, 1 ); coords[3] = CartVect( 0, 0, 0 ); // tet entirely within box ASSERT( overlap( coords, CartVect( -1, 1, -1 ), CartVect( 3, 3, 3 ) ) ); // box entirely within tet ASSERT( overlap( coords, CartVect( 0.2, -0.2, 0.2 ), CartVect( 0.1, 0.1, 0.1 ) ) ); // box corner penetrates tet face ASSERT( overlap( coords, CartVect( 0.5, -0.5, 0.5 ), CartVect( 0.2, 0.2, 0.2 ) ) ); // box corner does not penetrate face ASSERT( !overlap( coords, CartVect( 0.5, -0.5, 0.5 ), CartVect( 0.15, 0.15, 0.15 ) ) ); // Octant V coords[0] = CartVect( 0, 0, 0 ); coords[1] = CartVect( 0, 1, 0 ); coords[2] = CartVect( 1, 0, 0 ); coords[3] = CartVect( 0, 0, -1 ); // tet entirely within box ASSERT( overlap( coords, CartVect( -1, -1, 1 ), CartVect( 3, 3, 3 ) ) ); // box entirely within tet ASSERT( overlap( coords, CartVect( 0.2, 0.2, -0.2 ), CartVect( 0.1, 0.1, 0.1 ) ) ); // box corner penetrates tet face ASSERT( overlap( coords, CartVect( 0.5, 0.5, -0.5 ), CartVect( 0.2, 0.2, 0.2 ) ) ); // box corner does not penetrate face ASSERT( !overlap( coords, CartVect( 0.5, 0.5, -0.5 ), CartVect( 0.15, 0.15, 0.15 ) ) ); // Octant VI coords[0] = CartVect( -1, 0, 0 ); coords[1] = CartVect( 0, 1, 0 ); coords[2] = CartVect( 0, 0, 0 ); coords[3] = CartVect( 0, 0, -1 ); // tet entirely within box ASSERT( overlap( coords, CartVect( 1, -1, 1 ), CartVect( 3, 3, 3 ) ) ); // box entirely within tet ASSERT( overlap( coords, CartVect( -0.2, 0.2, -0.2 ), CartVect( 0.1, 0.1, 0.1 ) ) ); // box corner penetrates tet face ASSERT( overlap( coords, CartVect( -0.5, 0.5, -0.5 ), CartVect( 0.2, 0.2, 0.2 ) ) ); // box corner does not penetrate face ASSERT( !overlap( coords, CartVect( -0.5, 0.5, -0.5 ), CartVect( 0.15, 0.15, 0.15 ) ) ); // Octant VII coords[0] = CartVect( 0, 0, 0 ); coords[1] = CartVect( 0, -1, 0 ); coords[2] = CartVect( -1, 0, 0 ); coords[3] = CartVect( 0, 0, -1 ); // tet entirely within box ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 3, 3, 3 ) ) ); // box entirely within tet ASSERT( overlap( coords, CartVect( -0.2, -0.2, -0.2 ), CartVect( 0.1, 0.1, 0.1 ) ) ); // box corner penetrates tet face ASSERT( overlap( coords, CartVect( -0.5, -0.5, -0.5 ), CartVect( 0.2, 0.2, 0.2 ) ) ); // box corner does not penetrate face ASSERT( !overlap( coords, CartVect( -0.5, -0.5, -0.5 ), CartVect( 0.15, 0.15, 0.15 ) ) ); // Octant VIII coords[0] = CartVect( 0, -1, 0 ); coords[1] = CartVect( 1, 0, 0 ); coords[2] = CartVect( 0, 0, -1 ); coords[3] = CartVect( 0, 0, 0 ); // tet entirely within box ASSERT( overlap( coords, CartVect( -1, 1, 1 ), CartVect( 3, 3, 3 ) ) ); // box entirely within tet ASSERT( overlap( coords, CartVect( 0.2, -0.2, -0.2 ), CartVect( 0.1, 0.1, 0.1 ) ) ); // box corner penetrates tet face ASSERT( overlap( coords, CartVect( 0.5, -0.5, -0.5 ), CartVect( 0.2, 0.2, 0.2 ) ) ); // box corner does not penetrate face ASSERT( !overlap( coords, CartVect( 0.5, -0.5, -0.5 ), CartVect( 0.15, 0.15, 0.15 ) ) ); // Box edge -x,-z coords[0] = CartVect( 0, 0, 0 ); coords[1] = CartVect( 2, -1, 0 ); coords[2] = CartVect( 2, 1, 0 ); coords[3] = CartVect( 0, 0, 2 ); // box edge passes through tet ASSERT( overlap( coords, CartVect( 1.5, 0.0, 1.5 ), CartVect( 1, 1, 1 ) ) ); // box edge does not pass through tet ASSERT( !overlap( coords, CartVect( 2.5, 0.0, 2.5 ), CartVect( 1, 1, 1 ) ) ); // Box edge -y,-z coords[0] = CartVect( 1, 2, 0 ); coords[1] = CartVect( -1, 2, 0 ); coords[2] = CartVect( 0, 0, 0 ); coords[3] = CartVect( 0, 0, 2 ); // box edge passes through tet ASSERT( overlap( coords, CartVect( 0.0, 1.5, 1.5 ), CartVect( 1, 1, 1 ) ) ); // box edge does not pass through tet ASSERT( !overlap( coords, CartVect( 0.0, 2.5, 2.5 ), CartVect( 1, 1, 1 ) ) ); // Box edge +x,-z coords[0] = CartVect( -2, -1, 0 ); coords[1] = CartVect( -2, 1, 0 ); coords[2] = CartVect( 0, 0, 2 ); coords[3] = CartVect( 0, 0, 0 ); // box edge passes through tet ASSERT( overlap( coords, CartVect( -1.5, 0.0, 1.5 ), CartVect( 1, 1, 1 ) ) ); // box edge does not pass through tet ASSERT( !overlap( coords, CartVect( -2.5, 0.0, 2.5 ), CartVect( 1, 1, 1 ) ) ); // Box edge +y,-z coords[0] = CartVect( 2, -1, 0 ); coords[1] = CartVect( 0, 0, 0 ); coords[2] = CartVect( -2, -1, 0 ); coords[3] = CartVect( 0, 0, 2 ); // box edge passes through tet ASSERT( overlap( coords, CartVect( 0.0, -1.5, 1.5 ), CartVect( 1, 1, 1 ) ) ); // box edge does not pass through tet ASSERT( !overlap( coords, CartVect( 0.0, -2.5, 2.5 ), CartVect( 1, 1, 1 ) ) ); // Box edge -x,+z coords[0] = CartVect( 2, -1, 0 ); coords[1] = CartVect( 0, 0, 0 ); coords[2] = CartVect( 2, 1, 0 ); coords[3] = CartVect( 0, 0, -2 ); // box edge passes through tet ASSERT( overlap( coords, CartVect( 1.5, 0.0, -1.5 ), CartVect( 1, 1, 1 ) ) ); // box edge does not pass through tet ASSERT( !overlap( coords, CartVect( 2.5, 0.0, -2.5 ), CartVect( 1, 1, 1 ) ) ); // Box edge -y,+z coords[0] = CartVect( -1, 2, 0 ); coords[1] = CartVect( 1, 2, 0 ); coords[2] = CartVect( 0, 0, 0 ); coords[3] = CartVect( 0, 0, -2 ); // box edge passes through tet ASSERT( overlap( coords, CartVect( 0.0, 1.5, -1.5 ), CartVect( 1, 1, 1 ) ) ); // box edge does not pass through tet ASSERT( !overlap( coords, CartVect( 0.0, 2.5, -2.5 ), CartVect( 1, 1, 1 ) ) ); // Box edge +x,+z coords[0] = CartVect( -2, 1, 0 ); coords[1] = CartVect( -2, -1, 0 ); coords[2] = CartVect( 0, 0, -2 ); coords[3] = CartVect( 0, 0, 0 ); // box edge passes through tet ASSERT( overlap( coords, CartVect( -1.5, 0.0, -1.5 ), CartVect( 1, 1, 1 ) ) ); // box edge does not pass through tet ASSERT( !overlap( coords, CartVect( -2.5, 0.0, -2.5 ), CartVect( 1, 1, 1 ) ) ); // Box edge +y,+z coords[0] = CartVect( 0, 0, 0 ); coords[1] = CartVect( 2, -1, 0 ); coords[2] = CartVect( -2, -1, 0 ); coords[3] = CartVect( 0, 0, -2 ); // box edge passes through tet ASSERT( overlap( coords, CartVect( 0.0, -1.5, -1.5 ), CartVect( 1, 1, 1 ) ) ); // box edge does not pass through tet ASSERT( !overlap( coords, CartVect( 0.0, -2.5, -2.5 ), CartVect( 1, 1, 1 ) ) ); // Box edge -x,-y coords[0] = CartVect( 0, 0, 0 ); coords[1] = CartVect( 0, 2, -1 ); coords[2] = CartVect( 0, 2, 1 ); coords[3] = CartVect( 2, 0, 0 ); // box edge passes through tet ASSERT( overlap( coords, CartVect( 1.5, 1.5, 0.0 ), CartVect( 1, 1, 1 ) ) ); // box edge does not pass through tet ASSERT( !overlap( coords, CartVect( 2.5, 2.5, 0.0 ), CartVect( 1, 1, 1 ) ) ); // Box edge +x,-y coords[0] = CartVect( 0, 2, -1 ); coords[1] = CartVect( 0, 0, 0 ); coords[2] = CartVect( 0, 2, 1 ); coords[3] = CartVect( -2, 0, 0 ); // box edge passes through tet ASSERT( overlap( coords, CartVect( -1.5, 1.5, 0.0 ), CartVect( 1, 1, 1 ) ) ); // box edge does not pass through tet ASSERT( !overlap( coords, CartVect( -2.5, 2.5, 0.0 ), CartVect( 1, 1, 1 ) ) ); // Box edge -x,+y coords[0] = CartVect( 0, -2, 1 ); coords[1] = CartVect( 0, -2, -1 ); coords[2] = CartVect( 0, 0, 0 ); coords[3] = CartVect( 2, 0, 0 ); // box edge passes through tet ASSERT( overlap( coords, CartVect( 1.5, -1.5, 0.0 ), CartVect( 1, 1, 1 ) ) ); // box edge does not pass through tet ASSERT( !overlap( coords, CartVect( 2.5, -2.5, 0.0 ), CartVect( 1, 1, 1 ) ) ); // Box edge +x,+y coords[0] = CartVect( 0, -2, -1 ); coords[1] = CartVect( -2, 0, 0 ); coords[2] = CartVect( 0, -2, 1 ); coords[3] = CartVect( 0, 0, 0 ); // box edge passes through tet ASSERT( overlap( coords, CartVect( -1.5, -1.5, 0.0 ), CartVect( 1, 1, 1 ) ) ); // box edge does not pass through tet ASSERT( !overlap( coords, CartVect( -2.5, -2.5, 0.0 ), CartVect( 1, 1, 1 ) ) ); // Test tet edge through box coords[0] = CartVect( -0.13369421660900116, -2.9871494770050049, 0.0526076555252075 ); coords[1] = CartVect( -0.00350524857640266, -3.3236153125762939, 0.2924639880657196 ); coords[2] = CartVect( 0.16473215818405151, -2.9966945648193359, -0.1936169415712357 ); coords[3] = CartVect( 0.26740345358848572, -2.8492588996887207, 0.1519143134355545 ); ASSERT( overlap( coords, CartVect( -2.5, -2.8, -2.5 ), CartVect( 2.5, 0.31, 2.5 ) ) ); }
void general_box_tri_overlap_test | ( | const ElemOverlapTest & | overlap | ) |
Definition at line 132 of file GeomUtilTests.cpp.
References ASSERT, moab::GeomUtil::box_tri_overlap(), and center().
Referenced by test_box_linear_elem_overlap_tri(), and test_box_tri_overlap().
{ CartVect coords[3]; CartVect center, dims; // test box projection within triangle, z-plane coords[0] = CartVect( 0, 0, 0 ); coords[1] = CartVect( 0, 4, 0 ); coords[2] = CartVect( -4, 0, 0 ); center = CartVect( -2, 1, 0 ); dims = CartVect( 1, 0.5, 3 ); ASSERT( overlap( coords, center, dims ) ); // move box below plane of triangle center[2] = -4; ASSERT( !overlap( coords, center, dims ) ); // move box above plane of triangle center[2] = 4; ASSERT( !overlap( coords, center, dims ) ); // test box projection within triangle, x-plane coords[0] = CartVect( 3, 3, 0 ); coords[1] = CartVect( 3, 3, 1 ); coords[2] = CartVect( 3, 0, 0 ); center = CartVect( 3, 2.5, .25 ); dims = CartVect( 0.001, 0.4, .2 ); ASSERT( overlap( coords, center, dims ) ); // move box below plane of triangle center[0] = 2; ASSERT( !overlap( coords, center, dims ) ); // move box above plane of triangle center[0] = 4; ASSERT( !overlap( coords, center, dims ) ); // test tri slices corner at +x,+y,+z coords[0] = CartVect( 3, 1, 1 ); coords[1] = CartVect( 1, 3, 1 ); coords[2] = CartVect( 1, 1, 3 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri above the corner ASSERT( !overlap( coords, CartVect( 0, 0, 0 ), CartVect( 1, 1, 1 ) ) ); // test tri slices corner at -x,-y,-z coords[0] = CartVect( -1, 1, 1 ); coords[1] = CartVect( 1, -1, 1 ); coords[2] = CartVect( 1, 1, -1 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri below the corner ASSERT( !overlap( coords, CartVect( 2, 2, 2 ), CartVect( 1, 1, 1 ) ) ); // test tri slices corner at -x,+y,+z coords[0] = CartVect( 0.5, 0.0, 2.5 ); coords[1] = CartVect( 0.5, 2.5, 0.0 ); coords[2] = CartVect( -0.5, 0.0, 0.0 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri above the corner ASSERT( !overlap( coords, CartVect( 2, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test tri slices corner at +x,-y,-z coords[0] = CartVect( 0.5, 0.0, -1.5 ); coords[1] = CartVect( 0.5, -1.5, 0.0 ); coords[2] = CartVect( 1.5, 0.0, 0.0 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri above the corner ASSERT( !overlap( coords, CartVect( 0, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test tri slices corner at +x,-y,+z coords[0] = CartVect( 1.0, 1.0, 2.5 ); coords[1] = CartVect( 2.5, 1.0, 1.0 ); coords[2] = CartVect( 1.0, -0.5, 1.0 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri above the corner ASSERT( !overlap( coords, CartVect( -1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test tri slices corner at -x,+y,-z coords[0] = CartVect( 1.0, 1.0, -0.5 ); coords[1] = CartVect( -0.5, 1.0, 1.0 ); coords[2] = CartVect( 1.0, 2.5, 1.0 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri above the corner ASSERT( !overlap( coords, CartVect( 3, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test tri slices corner at +x,+y,-z coords[0] = CartVect( -0.1, 1.0, 1.0 ); coords[1] = CartVect( 1.0, -0.1, 1.0 ); coords[2] = CartVect( 1.0, 1.0, -0.1 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 1, 1, 3 ), CartVect( 1, 1, 1 ) ) ); // test tri slices corner at -x,-y,+z coords[0] = CartVect( 2.1, 1.0, 1.0 ); coords[1] = CartVect( 1.0, 2.1, 1.0 ); coords[2] = CartVect( 1.0, 1.0, 2.1 ); ASSERT( box_tri_overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 1, 1, -1 ), CartVect( 1, 1, 1 ) ) ); // box edge parallel to x at +y,+z passes through triangle coords[0] = CartVect( 1.0, 1.0, 3.0 ); coords[1] = CartVect( 1.0, 3.0, 3.0 ); coords[2] = CartVect( 1.0, 3.0, 1.0 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 1, 1, 0.3 ), CartVect( 1, 1, 1 ) ) ); // box edge parallel to x at +y,-z passes through triangle coords[0] = CartVect( 1.0, 3.0, 1.0 ); coords[1] = CartVect( 1.0, 3.0, -1.0 ); coords[2] = CartVect( 1.0, 1.0, -1.0 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 1, 1, 1.7 ), CartVect( 1, 1, 1 ) ) ); // box edge parallel to x at -y,-z passes through triangle coords[0] = CartVect( 1.0, -1.0, 1.0 ); coords[1] = CartVect( 1.0, -1.0, -1.0 ); coords[2] = CartVect( 1.0, 1.0, -1.0 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 1, 1, 1.7 ), CartVect( 1, 1, 1 ) ) ); // box edge parallel to x at -y,+z passes through triangle coords[0] = CartVect( 1.0, -1.0, 1.0 ); coords[1] = CartVect( 1.0, -1.0, 3.0 ); coords[2] = CartVect( 1.0, 1.0, 3.0 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 1, 1, 0.3 ), CartVect( 1, 1, 1 ) ) ); // box edge parallel to y at +x,+z passes through triangle coords[0] = CartVect( 1.0, 1.0, 3.0 ); coords[1] = CartVect( 3.0, 1.0, 3.0 ); coords[2] = CartVect( 3.0, 1.0, 1.0 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 1, 1, 0.3 ), CartVect( 1, 1, 1 ) ) ); // box edge parallel to y at -x,+z passes through triangle coords[0] = CartVect( 1.0, 1.0, 3.0 ); coords[1] = CartVect( -1.0, 1.0, 3.0 ); coords[2] = CartVect( -1.0, 1.0, 1.0 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 1, 1, 0.3 ), CartVect( 1, 1, 1 ) ) ); // box edge parallel to y at +x,-z passes through triangle coords[0] = CartVect( 1.0, 1.0, -1.0 ); coords[1] = CartVect( 3.0, 1.0, -1.0 ); coords[2] = CartVect( 3.0, 1.0, 1.0 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 1, 1, 1.7 ), CartVect( 1, 1, 1 ) ) ); // box edge parallel to y at -x,-z passes through triangle coords[0] = CartVect( 1.0, 1.0, -1.0 ); coords[1] = CartVect( -1.0, 1.0, -1.0 ); coords[2] = CartVect( -1.0, 1.0, 1.0 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 1, 1, 1.7 ), CartVect( 1, 1, 1 ) ) ); // box edge parallel to z at +x,+y passes through triangle coords[0] = CartVect( 1.0, 3.0, 1.0 ); coords[1] = CartVect( 3.0, 3.0, 1.0 ); coords[2] = CartVect( 3.0, 1.0, 1.0 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 0.3, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // box edge parallel to z at +x,-y passes through triangle coords[0] = CartVect( 1.0, -1.0, 1.0 ); coords[1] = CartVect( 3.0, -1.0, 1.0 ); coords[2] = CartVect( 3.0, 1.0, 1.0 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 0.3, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // box edge parallel to z at -x,+y passes through triangle coords[0] = CartVect( 1.0, 3.0, 1.0 ); coords[1] = CartVect( -1.0, 3.0, 1.0 ); coords[2] = CartVect( -1.0, 1.0, 1.0 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 1.7, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // box edge parallel to z at -x,-y passes through triangle coords[0] = CartVect( 1.0, -1.0, 1.0 ); coords[1] = CartVect( -1.0, -1.0, 1.0 ); coords[2] = CartVect( -1.0, 1.0, 1.0 ); ASSERT( overlap( coords, CartVect( 1, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 1.7, 1, 1 ), CartVect( 1, 1, 1 ) ) ); // triangle penetrates +x face coords[0] = CartVect( 2.0, 2.0, 2.0 ); coords[1] = CartVect( 5.0, 3.0, 2.0 ); coords[2] = CartVect( 5.0, 1.0, 2.0 ); ASSERT( overlap( coords, CartVect( 2, 2, 2 ), CartVect( 2, 2, 2 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( -1, 2, 2 ), CartVect( 2, 2, 2 ) ) ); // triangle penetrates -x face coords[0] = CartVect( 2.0, 2.0, 2.0 ); coords[1] = CartVect( -1.0, 3.0, 2.0 ); coords[2] = CartVect( -1.0, 1.0, 2.0 ); ASSERT( overlap( coords, CartVect( 2, 2, 2 ), CartVect( 2, 2, 2 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 5, 2, 2 ), CartVect( 2, 2, 2 ) ) ); // triangle penetrates +y face coords[0] = CartVect( 2.0, 2.0, 2.0 ); coords[1] = CartVect( 3.0, 5.0, 2.0 ); coords[2] = CartVect( 1.0, 5.0, 2.0 ); ASSERT( overlap( coords, CartVect( 2, 2, 2 ), CartVect( 2, 2, 2 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 2, -1, 2 ), CartVect( 2, 2, 2 ) ) ); // triangle penetrates -y face coords[0] = CartVect( 2.0, 2.0, 2.0 ); coords[1] = CartVect( 3.0, -1.0, 2.0 ); coords[2] = CartVect( 1.0, -1.0, 2.0 ); ASSERT( overlap( coords, CartVect( 2, 2, 2 ), CartVect( 2, 2, 2 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 2, 5, 2 ), CartVect( 2, 2, 2 ) ) ); // triangle penetrates +z face coords[0] = CartVect( 2.0, 2.0, 2.0 ); coords[1] = CartVect( 2.0, 3.0, 5.0 ); coords[2] = CartVect( 2.0, 1.0, 5.0 ); ASSERT( overlap( coords, CartVect( 2, 2, 2 ), CartVect( 2, 2, 2 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 2, 2, -1 ), CartVect( 2, 2, 2 ) ) ); // triangle penetrates -z face coords[0] = CartVect( 2.0, 2.0, 2.0 ); coords[1] = CartVect( 2.0, 3.0, -1.0 ); coords[2] = CartVect( 2.0, 1.0, -1.0 ); ASSERT( overlap( coords, CartVect( 2, 2, 2 ), CartVect( 2, 2, 2 ) ) ); // test with tri outside box ASSERT( !overlap( coords, CartVect( 2, 2, 5 ), CartVect( 2, 2, 2 ) ) ); }
int main | ( | ) |
Definition at line 1240 of file GeomUtilTests.cpp.
References error_count, RUN_TEST, test_box_hex_overlap(), test_box_linear_elem_overlap_hex(), test_box_linear_elem_overlap_tet(), test_box_linear_elem_overlap_tri(), test_box_plane_overlap(), test_box_tet_overlap(), test_box_tri_overlap(), test_closest_location_on_box(), test_closest_location_on_polygon(), test_closest_location_on_tri(), test_plucker_ray_tri_intersect(), test_ray_tri_intersect(), and test_segment_box_intersect().
{ int error_count = 0; error_count += RUN_TEST( test_box_plane_overlap ); error_count += RUN_TEST( test_box_linear_elem_overlap_tri ); error_count += RUN_TEST( test_box_linear_elem_overlap_tet ); error_count += RUN_TEST( test_box_linear_elem_overlap_hex ); error_count += RUN_TEST( test_box_tri_overlap ); error_count += RUN_TEST( test_box_tet_overlap ); error_count += RUN_TEST( test_box_hex_overlap ); error_count += RUN_TEST( test_ray_tri_intersect ); error_count += RUN_TEST( test_plucker_ray_tri_intersect ); error_count += RUN_TEST( test_closest_location_on_tri ); error_count += RUN_TEST( test_closest_location_on_polygon ); error_count += RUN_TEST( test_segment_box_intersect ); error_count += RUN_TEST( test_closest_location_on_box ); return error_count; }
void test_box_hex_overlap | ( | ) |
Definition at line 738 of file GeomUtilTests.cpp.
References moab::GeomUtil::box_hex_overlap(), and general_box_hex_overlap_test().
Referenced by main().
void test_box_linear_elem_overlap_hex | ( | ) |
Definition at line 743 of file GeomUtilTests.cpp.
References general_box_hex_overlap_test(), and MBHEX.
void test_box_linear_elem_overlap_tet | ( | ) |
Definition at line 753 of file GeomUtilTests.cpp.
References general_box_tet_overlap_test(), and MBTET.
void test_box_linear_elem_overlap_tri | ( | ) |
Definition at line 733 of file GeomUtilTests.cpp.
References general_box_tri_overlap_test(), and MBTRI.
void test_box_plane_axis | ( | int | axis, |
double | ns, | ||
const CartVect & | min, | ||
const CartVect & | max | ||
Definition at line 50 of file GeomUtilTests.cpp.
References test_box_plane_norm().
Referenced by test_box_plane_overlap().
{ CartVect norm( 0.0 ); norm[axis] = ns; test_box_plane_norm( norm, min, max ); }
void test_box_plane_corner | ( | int | xdir, |
int | ydir, | ||
int | zdir, | ||
CartVect | min, | ||
CartVect | max | ||
Definition at line 70 of file GeomUtilTests.cpp.
{ CartVect norm( max - min ); norm[0] *= xdir; norm[1] *= ydir; norm[2] *= zdir; test_box_plane_norm( norm, min, max ); }
void test_box_plane_edge | ( | int | axis1, |
int | axis2, | ||
bool | flip_axis2, | ||
CartVect | max | ||
Definition at line 57 of file GeomUtilTests.cpp.
References moab::CartVect::normalize(), and test_box_plane_norm().
{ CartVect norm( 0.0 ); norm[axis1] = max[axis1] - min[axis1]; if( flip_axis2 ) norm[axis2] = min[axis2] - max[axis2]; else norm[axis2] = max[axis2] - min[axis2]; norm.normalize(); test_box_plane_norm( norm, min, max ); }
void test_box_plane_norm | ( | CartVect | norm, |
CartVect | max | ||
Definition at line 27 of file GeomUtilTests.cpp.
References ASSERT, moab::GeomUtil::box_plane_overlap(), and swap().
Referenced by test_box_plane_axis(), test_box_plane_corner(), and test_box_plane_edge().
{ CartVect c_lower = min; CartVect c_upper = max; for( int i = 0; i < 3; ++i ) if( norm[i] < 0.0 ) std::swap( c_lower[i], c_upper[i] ); CartVect p_below = c_lower - norm; CartVect p_lower = c_lower + norm; CartVect p_upper = c_upper - norm; CartVect p_above = c_upper + norm; double below = -( p_below % norm ); double lower = -( p_lower % norm ); double upper = -( p_upper % norm ); double above = -( p_above % norm ); ASSERT( !box_plane_overlap( norm, below, min, max ) ); ASSERT( box_plane_overlap( norm, lower, min, max ) ); ASSERT( box_plane_overlap( norm, upper, min, max ) ); ASSERT( !box_plane_overlap( norm, above, min, max ) ); }
void test_box_plane_overlap | ( | ) |
Definition at line 79 of file GeomUtilTests.cpp.
References test_box_plane_axis(), test_box_plane_corner(), and test_box_plane_edge().
{ const CartVect min( -1, -2, -3 ); const CartVect max( 6, 4, 2 ); // test with planes orthogonal to Z axis test_box_plane_axis( 2, 2.0, min, max ); // test with planes orthogonal to X axis test_box_plane_axis( 1, -2.0, min, max ); // test with planes orthogonal to Y axis test_box_plane_axis( 1, 1.0, min, max ); // test with plane orthogonal to face diagonals test_box_plane_edge( 0, 1, true, min, max ); test_box_plane_edge( 0, 1, false, min, max ); test_box_plane_edge( 0, 2, true, min, max ); test_box_plane_edge( 0, 2, false, min, max ); test_box_plane_edge( 2, 1, true, min, max ); test_box_plane_edge( 2, 1, false, min, max ); // test with plane orthogonal to box diagonals test_box_plane_corner( 1, 1, 1, min, max ); test_box_plane_corner( 1, 1, -1, min, max ); test_box_plane_corner( 1, -1, -1, min, max ); test_box_plane_corner( 1, -1, 1, min, max ); }
void test_box_tet_overlap | ( | ) |
Definition at line 748 of file GeomUtilTests.cpp.
References moab::GeomUtil::box_tet_overlap(), and general_box_tet_overlap_test().
void test_box_tri_overlap | ( | ) |
Definition at line 728 of file GeomUtilTests.cpp.
References moab::GeomUtil::box_tri_overlap(), and general_box_tri_overlap_test().
void test_closest_location_on_box | ( | ) |
Definition at line 1198 of file GeomUtilTests.cpp.
References ASSERT_VECTORS_EQUAL, and moab::GeomUtil::closest_location_on_box().
{ const CartVect min( 0, 0, 0 ), max( 1, 2, 3 ); CartVect pt; // inside closest_location_on_box( min, max, CartVect( 0.5, 0.5, 0.5 ), pt ); ASSERT_VECTORS_EQUAL( CartVect( 0.5, 0.5, 0.5 ), pt ); // closest to min x side closest_location_on_box( min, max, CartVect( -1.0, 0.5, 0.5 ), pt ); ASSERT_VECTORS_EQUAL( CartVect( 0.0, 0.5, 0.5 ), pt ); // closest to max x side closest_location_on_box( min, max, CartVect( 2.0, 0.5, 0.5 ), pt ); ASSERT_VECTORS_EQUAL( CartVect( 1.0, 0.5, 0.5 ), pt ); // closest to min y side closest_location_on_box( min, max, CartVect( 0.5, -1.0, 0.5 ), pt ); ASSERT_VECTORS_EQUAL( CartVect( 0.5, 0.0, 0.5 ), pt ); // closest to max y side closest_location_on_box( min, max, CartVect( 0.5, 2.5, 0.5 ), pt ); ASSERT_VECTORS_EQUAL( CartVect( 0.5, 2.0, 0.5 ), pt ); // closest to min z side closest_location_on_box( min, max, CartVect( 0.5, 0.5, -0.1 ), pt ); ASSERT_VECTORS_EQUAL( CartVect( 0.5, 0.5, 0.0 ), pt ); // closest to max z side closest_location_on_box( min, max, CartVect( 0.5, 0.5, 100.0 ), pt ); ASSERT_VECTORS_EQUAL( CartVect( 0.5, 0.5, 3.0 ), pt ); // closest to min corner closest_location_on_box( min, max, CartVect( -1, -1, -1 ), pt ); ASSERT_VECTORS_EQUAL( min, pt ); // closest to max corner closest_location_on_box( min, max, CartVect( 2, 3, 4 ), pt ); ASSERT_VECTORS_EQUAL( max, pt ); }
void test_closest_location_on_polygon | ( | ) |
Definition at line 934 of file GeomUtilTests.cpp.
References ASSERT_VECTORS_EQUAL, and moab::GeomUtil::closest_location_on_polygon().
{ CartVect result, input; // define a unit square in xy plane const CartVect quad[4] = { CartVect( 0.0, 0.0, 0.0 ), CartVect( 1.0, 0.0, 0.0 ), CartVect( 1.0, 1.0, 0.0 ), CartVect( 0.0, 1.0, 0.0 ) }; // test input in center of square closest_location_on_polygon( CartVect( 0.5, 0.5, 0.0 ), quad, 4, result ); ASSERT_VECTORS_EQUAL( result, CartVect( 0.5, 0.5, 0.0 ) ); // test above center of square closest_location_on_polygon( CartVect( 0.5, 0.5, 1.0 ), quad, 4, result ); ASSERT_VECTORS_EQUAL( result, CartVect( 0.5, 0.5, 0.0 ) ); // test below center of square closest_location_on_polygon( CartVect( 0.5, 0.5, -1.0 ), quad, 4, result ); ASSERT_VECTORS_EQUAL( result, CartVect( 0.5, 0.5, 0.0 ) ); // test points within square, but not at center input = CartVect( 0.25, 0.25, 0 ); closest_location_on_polygon( input, quad, 4, result ); ASSERT_VECTORS_EQUAL( result, input ); input = CartVect( 0.75, 0.25, 0 ); closest_location_on_polygon( input, quad, 4, result ); ASSERT_VECTORS_EQUAL( result, input ); input = CartVect( 0.75, 0.75, 0 ); closest_location_on_polygon( input, quad, 4, result ); ASSERT_VECTORS_EQUAL( result, input ); input = CartVect( 0.25, 0.75, 0 ); closest_location_on_polygon( input, quad, 4, result ); ASSERT_VECTORS_EQUAL( result, input ); // test at each corner closest_location_on_polygon( quad[0], quad, 4, result ); ASSERT_VECTORS_EQUAL( result, quad[0] ); closest_location_on_polygon( quad[1], quad, 4, result ); ASSERT_VECTORS_EQUAL( result, quad[1] ); closest_location_on_polygon( quad[2], quad, 4, result ); ASSERT_VECTORS_EQUAL( result, quad[2] ); closest_location_on_polygon( quad[3], quad, 4, result ); ASSERT_VECTORS_EQUAL( result, quad[3] ); // test at point on each edge input = 0.5 * quad[0] + 0.5 * quad[1]; closest_location_on_polygon( input, quad, 4, result ); ASSERT_VECTORS_EQUAL( result, input ); input = 0.2 * quad[1] + 0.8 * quad[2]; closest_location_on_polygon( input, quad, 4, result ); ASSERT_VECTORS_EQUAL( result, input ); input = 0.7 * quad[2] + 0.3 * quad[3]; closest_location_on_polygon( input, quad, 4, result ); ASSERT_VECTORS_EQUAL( result, input ); input = 0.6 * quad[3] + 0.4 * quad[0]; closest_location_on_polygon( input, quad, 4, result ); ASSERT_VECTORS_EQUAL( result, input ); // test at point outside and closest to each corner closest_location_on_polygon( CartVect( -1.0, -1.0, 0.0 ), quad, 4, result ); ASSERT_VECTORS_EQUAL( result, quad[0] ); closest_location_on_polygon( CartVect( 2.0, -1.0, 0.0 ), quad, 4, result ); ASSERT_VECTORS_EQUAL( result, quad[1] ); closest_location_on_polygon( CartVect( 2.0, 2.0, 0.0 ), quad, 4, result ); ASSERT_VECTORS_EQUAL( result, quad[2] ); closest_location_on_polygon( CartVect( -1.0, 2.0, 0.0 ), quad, 4, result ); ASSERT_VECTORS_EQUAL( result, quad[3] ); // test at point outside and closest to an edge CartVect x( 1.0, 0.0, 0.0 ), y( 0.0, 1.0, 0.0 ); input = 0.5 * quad[0] + 0.5 * quad[1]; closest_location_on_polygon( input - y, quad, 4, result ); ASSERT_VECTORS_EQUAL( result, input ); input = 0.2 * quad[1] + 0.8 * quad[2]; closest_location_on_polygon( input + x, quad, 4, result ); ASSERT_VECTORS_EQUAL( result, input ); input = 0.7 * quad[2] + 0.3 * quad[3]; closest_location_on_polygon( input + y, quad, 4, result ); ASSERT_VECTORS_EQUAL( result, input ); input = 0.6 * quad[3] + 0.4 * quad[0]; closest_location_on_polygon( input - x, quad, 4, result ); ASSERT_VECTORS_EQUAL( result, input ); }
void test_closest_location_on_tri | ( | ) |
Definition at line 848 of file GeomUtilTests.cpp.
References ASSERT_VECTORS_EQUAL, and moab::GeomUtil::closest_location_on_tri().
{ CartVect result, input; // define a triangle const CartVect tri[3] = { CartVect( 1.0, 0.0, 0.0 ), CartVect( 0.0, 1.0, 0.0 ), CartVect( 0.0, 0.0, 1.0 ) }; // try point at triangle centroid input = CartVect( 1.0 / 3.0, 1.0 / 3.0, 1.0 / 3.0 ); closest_location_on_tri( input, tri, result ); ASSERT_VECTORS_EQUAL( result, input ); // try point at each vertex closest_location_on_tri( tri[0], tri, result ); ASSERT_VECTORS_EQUAL( result, tri[0] ); closest_location_on_tri( tri[1], tri, result ); ASSERT_VECTORS_EQUAL( result, tri[1] ); closest_location_on_tri( tri[2], tri, result ); ASSERT_VECTORS_EQUAL( result, tri[2] ); // try point at center of each edge input = 0.5 * ( tri[0] + tri[1] ); closest_location_on_tri( input, tri, result ); ASSERT_VECTORS_EQUAL( result, input ); input = 0.5 * ( tri[0] + tri[2] ); closest_location_on_tri( input, tri, result ); ASSERT_VECTORS_EQUAL( result, input ); input = 0.5 * ( tri[2] + tri[1] ); closest_location_on_tri( input, tri, result ); ASSERT_VECTORS_EQUAL( result, input ); // try a point above the center of the triangle input = CartVect( 1.0, 1.0, 1.0 ); closest_location_on_tri( input, tri, result ); ASSERT_VECTORS_EQUAL( result, CartVect( 1.0 / 3.0, 1.0 / 3.0, 1.0 / 3.0 ) ); // try a point below the center of the triangle input = CartVect( 0.0, 0.0, 0.0 ); closest_location_on_tri( input, tri, result ); ASSERT_VECTORS_EQUAL( result, CartVect( 1.0 / 3.0, 1.0 / 3.0, 1.0 / 3.0 ) ); // try a point closest to each vertex and 'outside' of both adjacent edges. input = 2 * tri[0]; closest_location_on_tri( input, tri, result ); ASSERT_VECTORS_EQUAL( result, tri[0] ); input = 2 * tri[1]; closest_location_on_tri( input, tri, result ); ASSERT_VECTORS_EQUAL( result, tri[1] ); input = 2 * tri[2]; closest_location_on_tri( input, tri, result ); ASSERT_VECTORS_EQUAL( result, tri[2] ); // try a point outside and closest to each edge input = tri[0] + tri[1]; closest_location_on_tri( input, tri, result ); ASSERT_VECTORS_EQUAL( result, 0.5 * input ); input = tri[2] + tri[1]; closest_location_on_tri( input, tri, result ); ASSERT_VECTORS_EQUAL( result, 0.5 * input ); input = tri[0] + tri[2]; closest_location_on_tri( input, tri, result ); ASSERT_VECTORS_EQUAL( result, 0.5 * input ); // define an equilateral triangle in the xy-plane const CartVect tri_xy[3] = { CartVect( 0.0, sqrt( 3.0 ) / 2.0, 0.0 ), CartVect( 0.5, 0.0, 0.0 ), CartVect( -0.5, 0.0, 0.0 ) }; // for each vertex, test point that is // - outside triangle // - closest to vertex // - 'inside' one of the adjacent edges // - 'outside' the other adjacent edge closest_location_on_tri( CartVect( -0.3, 1.2, 0.0 ), tri_xy, result ); ASSERT_VECTORS_EQUAL( result, tri_xy[0] ); closest_location_on_tri( CartVect( 0.3, 1.2, 0.0 ), tri_xy, result ); ASSERT_VECTORS_EQUAL( result, tri_xy[0] ); closest_location_on_tri( CartVect( 1.0, 0.1, 0.0 ), tri_xy, result ); ASSERT_VECTORS_EQUAL( result, tri_xy[1] ); closest_location_on_tri( CartVect( 0.6, -0.5, 0.0 ), tri_xy, result ); ASSERT_VECTORS_EQUAL( result, tri_xy[1] ); closest_location_on_tri( CartVect( -0.6, -0.5, 0.0 ), tri_xy, result ); ASSERT_VECTORS_EQUAL( result, tri_xy[2] ); closest_location_on_tri( CartVect( -1.0, 0.1, 0.0 ), tri_xy, result ); ASSERT_VECTORS_EQUAL( result, tri_xy[2] ); }
void test_plucker_ray_tri_intersect | ( | ) |
Definition at line 788 of file GeomUtilTests.cpp.
References ASSERT, ASSERT_DOUBLES_EQUAL, moab::GeomUtil::EDGE0, moab::GeomUtil::NODE0, moab::GeomUtil::plucker_ray_tri_intersect(), and t.
{ bool xsect; double t; // define a triangle const CartVect tri[3] = { CartVect( 1.0, 0.0, 0.0 ), CartVect( 0.0, 1.0, 0.0 ), CartVect( 0.0, 0.0, 1.0 ) }; // try a ray through the center of the triangle xsect = plucker_ray_tri_intersect( tri, CartVect( 0.0, 0.0, 0.0 ), CartVect( 1.0, 1.0, 1.0 ), t ); ASSERT( xsect ); ASSERT_DOUBLES_EQUAL( 1.0 / 3.0, t ); // try a same ray, but move base point above triangle xsect = plucker_ray_tri_intersect( tri, CartVect( 1.0, 1.0, 1.0 ), CartVect( 1.0, 1.0, 1.0 ), t ); ASSERT( !xsect ); // try a same ray the other direction with base point below triangle xsect = plucker_ray_tri_intersect( tri, CartVect( 0.0, 0.0, 0.0 ), CartVect( -1.0, -1.0, -1.0 ), t ); ASSERT( !xsect ); // try a ray that passes above the triangle xsect = plucker_ray_tri_intersect( tri, CartVect( 1.0, 1.0, 1.0 ), CartVect( -1.0, -1.0, 1.0 ), t ); ASSERT( !xsect ); // try a skew ray xsect = plucker_ray_tri_intersect( tri, CartVect( 0.0, 0.0, 0.0 ), CartVect( 1.0, 1.0, -0.1 ), t ); ASSERT( !xsect ); // try a ray that intersects with wrong orientation const int orientation = -1.0; xsect = plucker_ray_tri_intersect( tri, CartVect( 0.0, 0.0, 0.0 ), CartVect( 1.0, 1.0, 1.0 ), t, NULL, NULL, &orientation ); ASSERT( !xsect ); // try a ray that intersects beyond the nonneg_ray_len const double nonneg_ray_len = 0.25; xsect = plucker_ray_tri_intersect( tri, CartVect( 0.0, 0.0, 0.0 ), CartVect( 1.0, 1.0, 1.0 ), t, &nonneg_ray_len ); ASSERT( !xsect ); // try a ray that intersects behind the origin const double neg_ray_len = -2.0; xsect = plucker_ray_tri_intersect( tri, CartVect( 0.0, 0.0, 0.0 ), CartVect( -1.0, -1.0, -1.0 ), t, NULL, &neg_ray_len ); ASSERT( xsect ); // try a ray that intersects a node intersection_type int_type; xsect = plucker_ray_tri_intersect( tri, CartVect( 0.0, 0.0, 0.0 ), CartVect( 1.0, 0.0, 0.0 ), t, NULL, NULL, NULL, &int_type ); ASSERT( xsect ); ASSERT( NODE0 == int_type ); // try a ray that intersects an edge xsect = plucker_ray_tri_intersect( tri, CartVect( 0.0, 0.0, 0.0 ), CartVect( 1.0, 1.0, 0.0 ), t, NULL, NULL, NULL, &int_type ); ASSERT( xsect ); ASSERT( EDGE0 == int_type ); }
void test_ray_tri_intersect | ( | ) |
Definition at line 758 of file GeomUtilTests.cpp.
References ASSERT, ASSERT_DOUBLES_EQUAL, moab::GeomUtil::ray_tri_intersect(), and t.
{ bool xsect; double t; // define a triangle const CartVect tri[3] = { CartVect( 1.0, 0.0, 0.0 ), CartVect( 0.0, 1.0, 0.0 ), CartVect( 0.0, 0.0, 1.0 ) }; // try a ray through the center of the triangle xsect = ray_tri_intersect( tri, CartVect( 0.0, 0.0, 0.0 ), CartVect( 1.0, 1.0, 1.0 ), t ); ASSERT( xsect ); ASSERT_DOUBLES_EQUAL( 1.0 / 3.0, t ); // try a same ray, but move base point above triangle xsect = ray_tri_intersect( tri, CartVect( 1.0, 1.0, 1.0 ), CartVect( 1.0, 1.0, 1.0 ), t ); ASSERT( !xsect ); // try a same ray the other direction with base point below triangle xsect = ray_tri_intersect( tri, CartVect( 0.0, 0.0, 0.0 ), CartVect( -1.0, -1.0, -1.0 ), t ); ASSERT( !xsect ); // try a ray that passes above the triangle xsect = ray_tri_intersect( tri, CartVect( 1.0, 1.0, 1.0 ), CartVect( -1.0, -1.0, 1.0 ), t ); ASSERT( !xsect ); // try a skew ray xsect = ray_tri_intersect( tri, CartVect( 0.0, 0.0, 0.0 ), CartVect( 1.0, 1.0, -0.1 ), t ); ASSERT( !xsect ); }
void test_segment_box_intersect | ( | ) |
Definition at line 1016 of file GeomUtilTests.cpp.
References ASSERT, ASSERT_DOUBLES_EQUAL, box_max(), box_min(), moab::GeomUtil::segment_box_intersect(), MBMesquite::MeshWriter::X, MBMesquite::MeshWriter::Y, and MBMesquite::MeshWriter::Z.
{ const double box_min = 0.0; const double box_max = 2.0; const double box_wid = box_max - box_min; const double box_mid = 0.5 * ( box_min + box_max ); const CartVect min( box_min ); const CartVect max( box_max ); const CartVect X( 1, 0, 0 ), Y( 0, 1, 0 ), Z( 0, 0, 1 ); CartVect pt; double start, end; bool r; // test line through box in +x direction double offset = 1; pt = CartVect( box_min - offset, box_mid, box_mid ); start = -HUGE_VAL; end = HUGE_VAL; r = segment_box_intersect( min, max, pt, X, start, end ); ASSERT( r ); ASSERT_DOUBLES_EQUAL( start, box_min + offset ); ASSERT_DOUBLES_EQUAL( end - start, box_wid ); // test with ray ending left of the box start = -HUGE_VAL; end = 0; r = segment_box_intersect( min, max, pt, X, start, end ); ASSERT( !r ); // test with ray ending within box start = -HUGE_VAL; end = box_mid + offset; r = segment_box_intersect( min, max, pt, X, start, end ); ASSERT( r ); ASSERT_DOUBLES_EQUAL( start, box_min + offset ); ASSERT_DOUBLES_EQUAL( end, box_mid + offset ); // test with ray beginning within box start = box_mid + offset; end = HUGE_VAL; r = segment_box_intersect( min, max, pt, X, start, end ); ASSERT( r ); ASSERT_DOUBLES_EQUAL( start, box_mid + offset ); ASSERT_DOUBLES_EQUAL( end, box_max + offset ); // test with ray right of box start = offset + offset + box_max; end = HUGE_VAL; r = segment_box_intersect( min, max, pt, X, start, end ); ASSERT( !r ); // test line through box in -y direction offset = 1; pt = CartVect( box_mid, box_min - offset, box_mid ); start = -HUGE_VAL; end = HUGE_VAL; r = segment_box_intersect( min, max, pt, -Y, start, end ); ASSERT( r ); ASSERT_DOUBLES_EQUAL( end - start, box_wid ); ASSERT_DOUBLES_EQUAL( end, box_min - offset ); // test with ray ending left of the box start = box_min; end = HUGE_VAL; r = segment_box_intersect( min, max, pt, -Y, start, end ); ASSERT( !r ); // test with ray beginning within box start = -box_mid - offset; end = HUGE_VAL; r = segment_box_intersect( min, max, pt, -Y, start, end ); ASSERT( r ); ASSERT_DOUBLES_EQUAL( start, -box_mid - offset ); ASSERT_DOUBLES_EQUAL( end, box_min - offset ); // test with ray ending within box start = -HUGE_VAL; end = -box_mid - offset; r = segment_box_intersect( min, max, pt, -Y, start, end ); ASSERT( r ); ASSERT_DOUBLES_EQUAL( start, -box_max - offset ); ASSERT_DOUBLES_EQUAL( end, -box_mid - offset ); // test with ray right of box start = -HUGE_VAL; end = -box_max - offset - offset; r = segment_box_intersect( min, max, pt, -Y, start, end ); ASSERT( !r ); // test ray outside in Z direction, parallel to Z plane, and // intersecting in projections into other planes pt = CartVect( box_mid, box_mid, box_max + 1 ); start = 0; end = box_wid; r = segment_box_intersect( min, max, pt, X, start, end ); ASSERT( !r ); start = 0; end = box_wid; r = segment_box_intersect( min, max, pt, -X, start, end ); ASSERT( !r ); start = 0; end = box_wid; r = segment_box_intersect( min, max, pt, Y, start, end ); ASSERT( !r ); start = 0; end = box_wid; r = segment_box_intersect( min, max, pt, -Y, start, end ); ASSERT( !r ); // try the other side (less than the min Z); pt = CartVect( box_mid, box_mid, box_min - 1 ); start = 0; end = box_wid; r = segment_box_intersect( min, max, pt, X, start, end ); ASSERT( !r ); start = 0; end = box_wid; r = segment_box_intersect( min, max, pt, -X, start, end ); ASSERT( !r ); start = 0; end = box_wid; r = segment_box_intersect( min, max, pt, Y, start, end ); ASSERT( !r ); start = 0; end = box_wid; r = segment_box_intersect( min, max, pt, -Y, start, end ); ASSERT( !r ); // now move the ray such that it lies exactly on the side of the box pt = CartVect( box_mid, box_mid, box_min ); start = 0; end = box_wid; r = segment_box_intersect( min, max, pt, X, start, end ); ASSERT( r ); ASSERT_DOUBLES_EQUAL( start, 0 ); ASSERT_DOUBLES_EQUAL( end, 0.5 * box_wid ); start = 0; end = box_wid; r = segment_box_intersect( min, max, pt, -X, start, end ); ASSERT( r ); ASSERT_DOUBLES_EQUAL( start, 0 ); ASSERT_DOUBLES_EQUAL( end, 0.5 * box_wid ); start = 0; end = box_wid; r = segment_box_intersect( min, max, pt, Y, start, end ); ASSERT( r ); ASSERT_DOUBLES_EQUAL( start, 0 ); ASSERT_DOUBLES_EQUAL( end, 0.5 * box_wid ); start = 0; end = box_wid; r = segment_box_intersect( min, max, pt, -Y, start, end ); ASSERT( r ); ASSERT_DOUBLES_EQUAL( start, 0 ); ASSERT_DOUBLES_EQUAL( end, 0.5 * box_wid ); // try a skew line segment pt = CartVect( box_min - 0.25 * box_wid, box_mid, box_mid ); CartVect dir( 1.0 / sqrt( 2.0 ), 1.0 / sqrt( 2.0 ), 0 ); start = 0; end = 1.5 / sqrt( 2.0 ) * box_wid; r = segment_box_intersect( min, max, pt, dir, start, end ); ASSERT( r ); ASSERT_DOUBLES_EQUAL( start, 0.5 / sqrt( 2.0 ) * box_wid ); ASSERT_DOUBLES_EQUAL( end, box_wid / sqrt( 2.0 ) ); // try with skew line segment that just touches edge of box pt = CartVect( box_min - 0.5 * box_wid, box_mid, box_mid ); start = 0; end = 3.0 / sqrt( 2.0 ) * box_wid; r = segment_box_intersect( min, max, pt, dir, start, end ); ASSERT( r ); ASSERT_DOUBLES_EQUAL( start, box_wid / sqrt( 2.0 ) ); ASSERT_DOUBLES_EQUAL( end, box_wid / sqrt( 2.0 ) ); // try with skew line segment outside of box pt = CartVect( box_min - 0.75 * box_wid, box_mid, box_mid ); start = 0; end = 3.0 / sqrt( 2.0 ) * box_wid; r = segment_box_intersect( min, max, pt, dir, start, end ); ASSERT( !r ); }
const double TOL = 1e-6 |
Definition at line 10 of file GeomUtilTests.cpp.
