MOAB: Mesh Oriented datABase
(version 5.4.0)
#include "Mesquite.hpp"
#include "UnitUtil.hpp"
#include "DomainClassifier.hpp"
#include "MeshDomain1D.hpp"
#include "MsqError.hpp"
#include "MeshImpl.hpp"
#include "MsqVertex.hpp"
#include "PlanarDomain.hpp"
#include <cstdio>
#include <iostream>
#include <algorithm>
Classes | |
class | DomainClassifierTest |
Functions | |
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (DomainClassifierTest,"Unit") | |
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (DomainClassifierTest,"DomainClassifierTest") | |
static void | print_domain (int i, DomainClassifier::DomainSet &set) |
Definition in file DomainClassifierTest.cpp.
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION | ( | DomainClassifierTest | , |
"DomainClassifierTest" | |||
static void print_domain | ( | int | i, |
DomainClassifier::DomainSet & | set | ||
) | [static] |
Definition at line 81 of file DomainClassifierTest.cpp.
{ if( PointDomain* pd = dynamic_cast< PointDomain* >( set.domain ) ) printf( "%d: PointDomain( %f %f %f ) @ %p\n", i, pd->geom()[0], pd->geom()[1], pd->geom()[2], pd ); else if( LineDomain* ld = dynamic_cast< LineDomain* >( set.domain ) ) { if( fabs( ld->geom().direction()[0] ) < 1e-6 && fabs( ld->geom().direction()[1] ) < 1e-6 ) printf( "%d: LineDomain( x = %f, y = %f ) @ %p\n", i, ld->geom().point()[0], ld->geom().point()[1], ld ); else if( fabs( ld->geom().direction()[1] ) < 1e-6 && fabs( ld->geom().direction()[2] ) < 1e-6 ) printf( "%d: LineDomain( y = %f, z = %f ) @ %p\n", i, ld->geom().point()[1], ld->geom().point()[2], ld ); else if( fabs( ld->geom().direction()[0] ) < 1e-6 && fabs( ld->geom().direction()[2] ) < 1e-6 ) printf( "%d: LineDomain( x = %f, z = %f ) @ %p\n", i, ld->geom().point()[0], ld->geom().point()[2], ld ); else printf( "%d: LineDomain( ? ) @ %p\n", i, ld ); } else if( PlanarDomain* pd = dynamic_cast< PlanarDomain* >( set.domain ) ) { if( fabs( pd->get_normal()[0] ) < 1e-6 && fabs( pd->get_normal()[1] ) < 1e-6 ) printf( "%d: PlanarDomain( z = %f ) @ %p\n", i, pd->get_origin()[2], pd ); else if( fabs( pd->get_normal()[1] ) < 1e-6 && fabs( pd->get_normal()[2] ) < 1e-6 ) printf( "%d: PlanarDomain( x = %f ) @ %p\n", i, pd->get_origin()[1], pd ); else if( fabs( pd->get_normal()[0] ) < 1e-6 && fabs( pd->get_normal()[2] ) < 1e-6 ) printf( "%d: PlanarDomain( y = %f ) @ %p\n", i, pd->get_origin()[0], pd ); else printf( "%d: PlanarDomain( ? ) @ %p\n", i, pd ); } else { printf( "%d: unknown domain type @ %p\n", i, set.domain ); } if( !set.vertices.empty() ) { printf( " vertices: " ); std::vector< Mesh::VertexHandle >::iterator vi = set.vertices.begin(); for( ; vi != set.vertices.end(); ++vi ) printf( "%lu, ", (unsigned long)*vi ); printf( "\n" ); } if( !set.elements.empty() ) { printf( " elements: " ); std::vector< Mesh::ElementHandle >::iterator ei = set.elements.begin(); for( ; ei != set.elements.end(); ++ei ) printf( "%lu, ", (unsigned long)*ei ); printf( "\n" ); } }
