MOAB: Mesh Oriented datABase
(version 5.4.0)
#include <algorithm>
#include <iostream>
#include "cppunit/extensions/HelperMacros.h"
#include "Mesquite.hpp"
#include "MsqError.hpp"
#include "TopologyInfo.hpp"
Classes | |
class | TopologyInfoTest |
struct | ho_result |
Functions | |
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (TopologyInfoTest,"TopologyInfoTest") | |
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (TopologyInfoTest,"Unit") | |
static void | shift (const unsigned *in, unsigned *out, unsigned size, unsigned offset) |
static void | reverse (const unsigned *in, unsigned *out, unsigned size, unsigned offset) |
Variables | |
const ho_result | HEX27 [] |
const ho_result *const | HEX20 = HEX27 |
const ho_result *const | HEX26 = HEX27 |
const ho_result | HEX15 [] |
const ho_result *const | HEX14 = HEX15 |
const ho_result | HEX9 [] = { { 3, 0, 8 } } |
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION | ( | TopologyInfoTest | , |
"TopologyInfoTest" | |||
"Unit" | |||
static void reverse | ( | const unsigned * | in, |
unsigned * | out, | ||
unsigned | size, | ||
unsigned | offset | ||
) | [static] |
Definition at line 1444 of file TopologyInfoTest.cpp.
References size.
Referenced by moab::DualTool::atomic_pillow(), moab::ReadCCMIO::create_cell_from_faces(), moab::ReadCGM::create_curve_facets(), TopologyInfoTest::find_face(), TopologyInfoTest::find_side(), mb_skin_reversed_common(), moab::Tqdcfr::process_sideset_10(), moab::Tqdcfr::process_sideset_11(), moab::ReadCCMIO::read_faces(), moab::MeshTopoUtil::star_entities(), moab::ReadCGM::store_surface_senses(), test_remove_entities(), and types_in_group().
static void shift | ( | const unsigned * | in, |
) | [static] |
Definition at line 1438 of file TopologyInfoTest.cpp.
References size.
Referenced by TopologyInfoTest::find_face(), and moab::TupleList::radix_index_sort().
Definition at line 1302 of file TopologyInfoTest.cpp.
Referenced by TopologyInfoTest::higher_order_from_side(), and TopologyInfoTest::side_from_higher_order().
{ { 2, 0, 8 }, { 2, 1, 9 }, { 2, 2, 10 }, { 2, 3, 11 }, { 2, 4, 12 }, { 2, 5, 13 }, { 3, 0, 14 } }
Definition at line 1299 of file TopologyInfoTest.cpp.
Definition at line 1296 of file TopologyInfoTest.cpp.
Definition at line 1297 of file TopologyInfoTest.cpp.
{ { 1, 0, 8 }, { 1, 1, 9 }, { 1, 2, 10 }, { 1, 3, 11 }, { 1, 4, 12 }, { 1, 5, 13 }, { 1, 6, 14 }, { 1, 7, 15 }, { 1, 8, 16 }, { 1, 9, 17 }, { 1, 10, 18 }, { 1, 11, 19 }, { 2, 0, 20 }, { 2, 1, 21 }, { 2, 2, 22 }, { 2, 3, 23 }, { 2, 4, 24 }, { 2, 5, 25 }, { 3, 0, 26 } }
Definition at line 1291 of file TopologyInfoTest.cpp.
Definition at line 1304 of file TopologyInfoTest.cpp.
