TopologyInfoTest Class Reference
+ Inheritance diagram for TopologyInfoTest:
+ Collaboration diagram for TopologyInfoTest:
Public Member Functions
void setUp ()
void tearDown ()
 TopologyInfoTest ()
bool compare_edge (const unsigned *a, const unsigned *b)
bool compare_face (unsigned len, const unsigned *a, const unsigned *b)
bool compare_vol (unsigned len, const unsigned *a, const unsigned *b)
void test_face_elem (EntityTopology topo, unsigned num_nodes, unsigned num_sides)
void test_vol_elem (EntityTopology topo, unsigned num_nodes, unsigned num_verts, unsigned num_edges, unsigned num_faces)
void test_poly (EntityTopology topo)
void tri ()
void tri3 ()
void tri4 ()
void tri6 ()
void tri7 ()
void quad ()
void quad4 ()
void quad5 ()
void quad8 ()
void quad9 ()
void tet ()
void tet4 ()
void tet5 ()
void tet8 ()
void tet9 ()
void tet10 ()
void tet11 ()
void tet14 ()
void tet15 ()
void hex ()
void hex8 ()
void hex9 ()
void hex14 ()
void hex15 ()
void hex20 ()
void hex21 ()
void hex26 ()
void hex27 ()
void pyramid ()
void pyramid5 ()
void pyramid13 ()
void wedge ()
void wedge6 ()
void wedge15 ()
void polygon ()
void polyhedron ()
void bad_type ()
void tri_adj_vert ()
void quad_adj_vert ()
void tet_adj_vert ()
void hex_adj_vert ()
void pyr_adj_vert ()
void wdg_adj_vert ()
void test_adj (MBMesquite::EntityTopology, const unsigned expected[][5])
void tri_rev_adj_vert ()
void quad_rev_adj_vert ()
void tet_rev_adj_vert ()
void hex_rev_adj_vert ()
void pyr_rev_adj_vert ()
void wdg_rev_adj_vert ()
void test_rev_adj (MBMesquite::EntityTopology type)
void higher_order_from_side ()
void side_from_higher_order ()
void find_edge ()
void find_face ()
void find_side ()
void compare_sides ()
Private Member Functions
 CPPUNIT_TEST_SUITE (TopologyInfoTest)
 CPPUNIT_TEST (tri)
 CPPUNIT_TEST (tri3)
 CPPUNIT_TEST (tri4)
 CPPUNIT_TEST (tri6)
 CPPUNIT_TEST (tri7)
 CPPUNIT_TEST (quad)
 CPPUNIT_TEST (quad4)
 CPPUNIT_TEST (quad5)
 CPPUNIT_TEST (quad8)
 CPPUNIT_TEST (quad9)
 CPPUNIT_TEST (tet)
 CPPUNIT_TEST (tet4)
 CPPUNIT_TEST (tet5)
 CPPUNIT_TEST (tet8)
 CPPUNIT_TEST (tet9)
 CPPUNIT_TEST (tet10)
 CPPUNIT_TEST (tet11)
 CPPUNIT_TEST (tet14)
 CPPUNIT_TEST (tet15)
 CPPUNIT_TEST (hex)
 CPPUNIT_TEST (hex8)
 CPPUNIT_TEST (hex9)
 CPPUNIT_TEST (hex14)
 CPPUNIT_TEST (hex15)
 CPPUNIT_TEST (hex20)
 CPPUNIT_TEST (hex21)
 CPPUNIT_TEST (hex26)
 CPPUNIT_TEST (hex27)
 CPPUNIT_TEST (pyramid)
 CPPUNIT_TEST (pyramid5)
 CPPUNIT_TEST (pyramid13)
 CPPUNIT_TEST (wedge)
 CPPUNIT_TEST (wedge6)
 CPPUNIT_TEST (wedge15)
 CPPUNIT_TEST (polygon)
 CPPUNIT_TEST (polyhedron)
 CPPUNIT_TEST (bad_type)
 CPPUNIT_TEST (tri_adj_vert)
 CPPUNIT_TEST (quad_adj_vert)
 CPPUNIT_TEST (tet_adj_vert)
 CPPUNIT_TEST (hex_adj_vert)
 CPPUNIT_TEST (pyr_adj_vert)
 CPPUNIT_TEST (wdg_adj_vert)
 CPPUNIT_TEST (tri_rev_adj_vert)
 CPPUNIT_TEST (quad_rev_adj_vert)
 CPPUNIT_TEST (tet_rev_adj_vert)
 CPPUNIT_TEST (hex_rev_adj_vert)
 CPPUNIT_TEST (pyr_rev_adj_vert)
 CPPUNIT_TEST (wdg_rev_adj_vert)
 CPPUNIT_TEST (higher_order_from_side)
 CPPUNIT_TEST (side_from_higher_order)
 CPPUNIT_TEST (find_edge)
 CPPUNIT_TEST (find_face)
 CPPUNIT_TEST (find_side)
 CPPUNIT_TEST (compare_sides)
 CPPUNIT_TEST_SUITE_END ()
Detailed Description
Definition at line 38 of file TopologyInfoTest.cpp.
Definition at line 116 of file TopologyInfoTest.cpp.
Member Function Documentation
Definition at line 1119 of file TopologyInfoTest.cpp.
References b, corners, CPPUNIT_ASSERT, dim, edges, MBMesquite::faces, MBMesquite::MIXED, and moab::side_number().
    MBMesquite::MsqError err;
    EntityTopology bad_types[] = { (EntityTopology)0, (EntityTopology)1, MIXED, (EntityTopology)( MIXED + 1 ) };
    for( unsigned i = 0; i < ( sizeof( bad_types ) / sizeof( EntityTopology ) ); ++i )
        CPPUNIT_ASSERT( TopologyInfo::dimension( bad_types[i] ) == 0 );
        CPPUNIT_ASSERT( TopologyInfo::adjacent( bad_types[i], 1 ) == 0 );
        CPPUNIT_ASSERT( TopologyInfo::sides( bad_types[i] ) == 0 );
        CPPUNIT_ASSERT( TopologyInfo::corners( bad_types[i] ) == 0 );
        CPPUNIT_ASSERT( TopologyInfo::edges( bad_types[i] ) == 0 );
        CPPUNIT_ASSERT( TopologyInfo::faces( bad_types[i] ) == 0 );
        bool a, b, c;
        TopologyInfo::higher_order( bad_types[i], 20, a, b, c, err );
        CPPUNIT_ASSERT( err );
        const unsigned* ptr;
        ptr = TopologyInfo::edge_vertices( bad_types[i], 0, err );
        unsigned count;
        ptr = TopologyInfo::face_vertices( bad_types[i], 0, count, err );
        for( unsigned j = 0; j < 4; ++j )
            ptr = TopologyInfo::side_vertices( bad_types[i], j, 0, count, err );
        unsigned dim, side;
        for( unsigned idx = 0; idx < 20; ++idx )
            TopologyInfo::side_number( bad_types[i], idx, idx / 2, dim, side, err );
bool TopologyInfoTest::compare_edge ( const unsigned *  a,
const unsigned *  b
Definition at line 224 of file TopologyInfoTest.cpp.
    return ( a[0] == b[0] && a[1] == b[1] ) || ( a[0] == b[1] && a[1] == b[0] );
bool TopologyInfoTest::compare_face ( unsigned  len,
const unsigned *  a,
const unsigned *  b
Definition at line 229 of file TopologyInfoTest.cpp.
    unsigned i, j;
    for( i = 0; i < len; ++i )
        for( j = 0; j < len; ++j )
            if( a[j] != b[( i + j ) % len] ) break;
        if( j == len ) return true;
    return false;
Definition at line 1589 of file TopologyInfoTest.cpp.
References MBMesquite::compare_sides(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::edges, MBMesquite::faces, and MBMesquite::HEXAHEDRON.
    // define two hexes sharing a face:
    //    6-------7-------8
    //  0-------1-------2 |
    //  | 9-----|-10----|-11
    //  3-------4-------5
    const size_t hex1[] = { 3, 4, 10, 9, 0, 1, 7, 6 };
    const size_t hex2[] = { 4, 5, 11, 10, 1, 2, 8, 7 };
    // shared edges: { hex1_edge, hex2_edge }
    const unsigned edges[][2] = { { 1, 3 }, { 5, 4 }, { 6, 7 }, { 9, 11 } };
    const unsigned num_edges  = sizeof( edges ) / sizeof( edges[0] );
    // shared faces: { hex1_face, hex2_face }
    const unsigned faces[][2] = { { 1, 3 } };
    const unsigned num_faces  = sizeof( faces ) / sizeof( faces[0] );
    MsqPrintError err( std::cerr );
    // try every possible edge combination
    for( unsigned e1 = 0; e1 < 12; ++e1 )
        unsigned match;
        for( match = 0; match < num_edges; ++match )
            if( edges[match][0] == e1 ) break;
        for( unsigned e2 = 0; e2 < 12; ++e2 )
            const bool expected = ( match < num_edges ) && ( edges[match][1] == e2 );
            const bool result = TopologyInfo::compare_sides( hex1, HEXAHEDRON, e1, hex2, HEXAHEDRON, e2, 1, err );
            CPPUNIT_ASSERT( !err );
            CPPUNIT_ASSERT_EQUAL( expected, result );
    // try every possible face combination
    for( unsigned f1 = 0; f1 < 6; ++f1 )
        unsigned match;
        for( match = 0; match < num_faces; ++match )
            if( faces[match][0] == f1 ) break;
        for( unsigned f2 = 0; f2 < 6; ++f2 )
            const bool expected = ( match < num_faces ) && ( faces[match][1] == f2 );
            const bool result = TopologyInfo::compare_sides( hex1, HEXAHEDRON, f1, hex2, HEXAHEDRON, f2, 2, err );
bool TopologyInfoTest::compare_vol ( unsigned  len,
const unsigned *  a,
const unsigned *  b
Definition at line 243 of file TopologyInfoTest.cpp.
    for( unsigned i = 0; i < len; ++i )
        if( a[i] != b[i] ) return false;
    return true;
Definition at line 1407 of file TopologyInfoTest.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::edges, MBMesquite::HEXAHEDRON, MBMesquite::PRISM, MBMesquite::PYRAMID, MBMesquite::QUADRILATERAL, t, MBMesquite::TETRAHEDRON, and MBMesquite::TRIANGLE.
    bool reversed;
    EntityTopology types[]   = { TRIANGLE, QUADRILATERAL, TETRAHEDRON, HEXAHEDRON, PRISM, PYRAMID };
    const unsigned num_types = sizeof( types ) / sizeof( types[0] );
    unsigned idx;
    for( unsigned t = 0; t < num_types; ++t )
        const EntityTopology type = types[t];
        for( unsigned e = 0; e < TopologyInfo::edges( type ); ++e )
            const unsigned* const v = TopologyInfo::edge_vertices( type, e, err );
            idx = TopologyInfo::find_edge( type, v, reversed, err );
            CPPUNIT_ASSERT_EQUAL( e, idx );
            CPPUNIT_ASSERT( !reversed );
            const unsigned switched[2] = { v[1], v[0] };
            idx                        = TopologyInfo::find_edge( type, switched, reversed, err );
            CPPUNIT_ASSERT( reversed );
Definition at line 1450 of file TopologyInfoTest.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::faces, find_face(), MBMesquite::HEXAHEDRON, n, MBMesquite::PRISM, MBMesquite::PYRAMID, reverse(), shift(), t, and MBMesquite::TETRAHEDRON.
    bool reversed;
    unsigned switched[4], idx;
    EntityTopology types[]   = { TETRAHEDRON, HEXAHEDRON, PRISM, PYRAMID };
        for( unsigned f = 0; f < TopologyInfo::faces( type ); ++f )
            unsigned n;
            const unsigned* const v = TopologyInfo::face_vertices( type, f, n, err );
            CPPUNIT_ASSERT( n == 3 || n == 4 );
            idx = TopologyInfo::find_face( type, v, n, reversed, err );
            CPPUNIT_ASSERT_EQUAL( f, idx );
            // advance by 1 and try again
            shift( v, switched, n, 1 );
            idx = TopologyInfo::find_face( type, switched, n, reversed, err );
            // advance by 2 and try again
            shift( v, switched, n, 2 );
            // advance by 3 and try again
            shift( v, switched, n, 3 );
            // reverse and try again
            reverse( v, switched, n, 0 );
            // reverse, advance by 1 and try again
            reverse( v, switched, n, 1 );
            // reverse, advance by 2 and try again
            reverse( v, switched, n, 2 );
            // reverse, advance by 3 and try again
            reverse( v, switched, n, 3 );
Definition at line 1527 of file TopologyInfoTest.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, dim, MBMesquite::edges, MBMesquite::faces, find_side(), MBMesquite::HEXAHEDRON, n, MBMesquite::PRISM, MBMesquite::PYRAMID, MBMesquite::QUADRILATERAL, reverse(), t, MBMesquite::TETRAHEDRON, MBMesquite::TRIANGLE, and u.
    bool reversed;
    unsigned i, dim, switched[4];
            TopologyInfo::find_side( type, v, 2, dim, i, reversed, err );
            CPPUNIT_ASSERT_EQUAL( e, i );
            CPPUNIT_ASSERT_EQUAL( 1u, dim );
            switched[0] = v[1];
            switched[1] = v[0];
            TopologyInfo::find_side( type, switched, 2, dim, i, reversed, err );
    for( unsigned t = 2; t < num_types; ++t )
            unsigned n;
            TopologyInfo::find_side( type, v, n, dim, i, reversed, err );
            CPPUNIT_ASSERT_EQUAL( f, i );
            CPPUNIT_ASSERT_EQUAL( 2u, dim );
            TopologyInfo::find_side( type, switched, n, dim, i, reversed, err );
Definition at line 709 of file TopologyInfoTest.cpp.
References compare_edge(), corners, CPPUNIT_ASSERT, MBMesquite::edges, edges, MBMesquite::faces, and MBMesquite::HEXAHEDRON.
    MsqPrintError err( cout );
    const unsigned num_verts = 8;
    const unsigned num_edges = 12;
    const unsigned num_faces = 6;
    CPPUNIT_ASSERT( 3 == TopologyInfo::dimension( HEXAHEDRON ) );
    CPPUNIT_ASSERT( 1 == TopologyInfo::adjacent( HEXAHEDRON, 3 ) );
    CPPUNIT_ASSERT( num_faces == TopologyInfo::adjacent( HEXAHEDRON, 2 ) );
    CPPUNIT_ASSERT( num_edges == TopologyInfo::adjacent( HEXAHEDRON, 1 ) );
    CPPUNIT_ASSERT( num_verts == TopologyInfo::adjacent( HEXAHEDRON, 0 ) );
    CPPUNIT_ASSERT( num_faces == TopologyInfo::sides( HEXAHEDRON ) );
    CPPUNIT_ASSERT( num_verts == TopologyInfo::corners( HEXAHEDRON ) );
    CPPUNIT_ASSERT( num_edges == TopologyInfo::edges( HEXAHEDRON ) );
    CPPUNIT_ASSERT( num_faces == TopologyInfo::faces( HEXAHEDRON ) );
    const unsigned* side;
    unsigned i, count;
    const unsigned vert_per_face             = 4;
    unsigned edges[num_edges][2]             = { { 0, 1 }, { 1, 2 }, { 2, 3 }, { 3, 0 }, { 0, 4 }, { 1, 5 },
                                     { 2, 6 }, { 3, 7 }, { 4, 5 }, { 5, 6 }, { 6, 7 }, { 7, 4 } };
    unsigned faces[num_faces][vert_per_face] = { { 0, 1, 5, 4 }, { 1, 2, 6, 5 }, { 2, 3, 7, 6 },
                                                 { 3, 0, 4, 7 }, { 3, 2, 1, 0 }, { 4, 5, 6, 7 } };
    for( i = 0; i < num_edges; ++i )
        side = TopologyInfo::edge_vertices( HEXAHEDRON, i, err );
        CPPUNIT_ASSERT( compare_edge( side, edges[i] ) );
        side = TopologyInfo::side_vertices( HEXAHEDRON, 1, i, count, err );
        CPPUNIT_ASSERT( 2 == count );
    for( i = 0; i < num_faces; ++i )
        side = TopologyInfo::face_vertices( HEXAHEDRON, i, count, err );
        CPPUNIT_ASSERT( count == vert_per_face );
        CPPUNIT_ASSERT( compare_face( vert_per_face, side, faces[i] ) );
        side = TopologyInfo::side_vertices( HEXAHEDRON, 2, i, count, err );
    side = TopologyInfo::side_vertices( HEXAHEDRON, 3, 0, count, err );
    CPPUNIT_ASSERT( count == num_verts );
    for( i = 0; i < num_verts; ++i )
        CPPUNIT_ASSERT( side[i] == i );
Definition at line 797 of file TopologyInfoTest.cpp.
References CPPUNIT_ASSERT, and MBMesquite::HEXAHEDRON.
    bool edge, face, vol;
    const int num_nodes = 14;
    TopologyInfo::higher_order( HEXAHEDRON, num_nodes, edge, face, vol, err );
    CPPUNIT_ASSERT( !edge );
    CPPUNIT_ASSERT( face );
    CPPUNIT_ASSERT( !vol );
    test_vol_elem( HEXAHEDRON, num_nodes, 8, 12, 6 );
Definition at line 812 of file TopologyInfoTest.cpp.
    const int num_nodes = 15;
    CPPUNIT_ASSERT( vol );
Definition at line 827 of file TopologyInfoTest.cpp.
    const int num_nodes = 20;
    CPPUNIT_ASSERT( edge );
    CPPUNIT_ASSERT( !face );
Definition at line 842 of file TopologyInfoTest.cpp.
    const int num_nodes = 21;
Definition at line 857 of file TopologyInfoTest.cpp.
    const int num_nodes = 26;
Definition at line 872 of file TopologyInfoTest.cpp.
    const int num_nodes = 27;
Definition at line 767 of file TopologyInfoTest.cpp.
    const int num_nodes = 8;
Definition at line 782 of file TopologyInfoTest.cpp.
    const int num_nodes = 9;
Definition at line 1178 of file TopologyInfoTest.cpp.
References MBMesquite::HEXAHEDRON.
    unsigned data[][5] = { { 3, 1, 3, 4, 0 }, { 3, 2, 0, 5, 0 }, { 3, 3, 1, 6, 0 }, { 3, 0, 2, 7, 0 },
                           { 3, 7, 5, 0, 0 }, { 3, 4, 6, 1, 0 }, { 3, 5, 7, 2, 0 }, { 3, 6, 4, 3, 0 } };
    test_adj( MBMesquite::HEXAHEDRON, data );
Definition at line 1306 of file TopologyInfoTest.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, dim, HEX14, HEX15, HEX20, HEX26, HEX27, HEX9, and MBMesquite::HEXAHEDRON.
    // HEX-27
    for( unsigned i = 0; i < 19; ++i )
        unsigned result = TopologyInfo::higher_order_from_side( HEXAHEDRON, 27, HEX27[i].dim, HEX27[i].num, err );
        CPPUNIT_ASSERT_EQUAL( HEX27[i].idx, result );
    // HEX-26
    for( unsigned i = 0; i < 18; ++i )
        unsigned result = TopologyInfo::higher_order_from_side( HEXAHEDRON, 26, HEX26[i].dim, HEX26[i].num, err );
        CPPUNIT_ASSERT_EQUAL( HEX26[i].idx, result );
    // HEX-20
    for( unsigned i = 0; i < 12; ++i )
        unsigned result = TopologyInfo::higher_order_from_side( HEXAHEDRON, 20, HEX20[i].dim, HEX20[i].num, err );
        CPPUNIT_ASSERT_EQUAL( HEX20[i].idx, result );
    // HEX-15
    for( unsigned i = 0; i < 7; ++i )
        unsigned result = TopologyInfo::higher_order_from_side( HEXAHEDRON, 15, HEX15[i].dim, HEX15[i].num, err );
        CPPUNIT_ASSERT_EQUAL( HEX15[i].idx, result );
    // HEX-14
    for( unsigned i = 0; i < 6; ++i )
        unsigned result = TopologyInfo::higher_order_from_side( HEXAHEDRON, 14, HEX14[i].dim, HEX14[i].num, err );
        CPPUNIT_ASSERT_EQUAL( HEX14[i].idx, result );
    // HEX-9
    for( unsigned i = 0; i < 1; ++i )
        unsigned result = TopologyInfo::higher_order_from_side( HEXAHEDRON, 9, HEX9[i].dim, HEX9[i].num, err );
        CPPUNIT_ASSERT_EQUAL( HEX9[i].idx, result );
Definition at line 1107 of file TopologyInfoTest.cpp.
References CPPUNIT_ASSERT, and MBMesquite::POLYGON.
    CPPUNIT_ASSERT( TopologyInfo::dimension( POLYGON ) == 2 );
    test_poly( POLYGON );
Definition at line 1113 of file TopologyInfoTest.cpp.
References CPPUNIT_ASSERT, and MBMesquite::POLYHEDRON.
    CPPUNIT_ASSERT( TopologyInfo::dimension( POLYHEDRON ) == 3 );
    test_poly( POLYHEDRON );
Definition at line 1185 of file TopologyInfoTest.cpp.
References MBMesquite::PYRAMID.
        { 3, 1, 3, 4, 0 }, { 3, 2, 0, 4, 0 }, { 3, 3, 1, 4, 0 }, { 3, 0, 2, 4, 0 }, { 4, 3, 2, 1, 0 } };
    test_adj( MBMesquite::PYRAMID, data );
Definition at line 203 of file TopologyInfoTest.cpp.
Definition at line 887 of file TopologyInfoTest.cpp.
References compare_edge(), corners, CPPUNIT_ASSERT, MBMesquite::edges, edges, MBMesquite::faces, and MBMesquite::PYRAMID.
    const unsigned num_verts = 5;
    const unsigned num_edges = 8;
    const unsigned num_faces = 5;
    CPPUNIT_ASSERT( 3 == TopologyInfo::dimension( PYRAMID ) );
    CPPUNIT_ASSERT( 1 == TopologyInfo::adjacent( PYRAMID, 3 ) );
    CPPUNIT_ASSERT( num_faces == TopologyInfo::adjacent( PYRAMID, 2 ) );
    CPPUNIT_ASSERT( num_edges == TopologyInfo::adjacent( PYRAMID, 1 ) );
    CPPUNIT_ASSERT( num_verts == TopologyInfo::adjacent( PYRAMID, 0 ) );
    CPPUNIT_ASSERT( num_faces == TopologyInfo::sides( PYRAMID ) );
    CPPUNIT_ASSERT( num_verts == TopologyInfo::corners( PYRAMID ) );
    CPPUNIT_ASSERT( num_edges == TopologyInfo::edges( PYRAMID ) );
    CPPUNIT_ASSERT( num_faces == TopologyInfo::faces( PYRAMID ) );
    unsigned i, count;
    const unsigned num_tri_faces  = 4;
    const unsigned num_quad_faces = 1;
    const bool tri_before_quad    = true;
    CPPUNIT_ASSERT( num_tri_faces + num_quad_faces == num_faces );
    unsigned edges[num_edges][2] = { { 0, 1 }, { 1, 2 }, { 2, 3 }, { 3, 0 }, { 0, 4 }, { 1, 4 }, { 2, 4 }, { 3, 4 } };
    unsigned tris[num_tri_faces][3]   = { { 0, 1, 4 }, { 1, 2, 4 }, { 2, 3, 4 }, { 3, 0, 4 } };
    unsigned quads[num_quad_faces][4] = { { 3, 2, 1, 0 } };
        side = TopologyInfo::edge_vertices( PYRAMID, i, err );
        side = TopologyInfo::side_vertices( PYRAMID, 1, i, count, err );
    const unsigned tri_off = num_quad_faces * !tri_before_quad;
    for( i = 0; i < num_tri_faces; ++i )
        side = TopologyInfo::face_vertices( PYRAMID, i + tri_off, count, err );
        CPPUNIT_ASSERT( count == 3 );
        CPPUNIT_ASSERT( compare_face( 3, side, tris[i] ) );
        side = TopologyInfo::side_vertices( PYRAMID, 2, i + tri_off, count, err );
    const unsigned quad_off = num_tri_faces * tri_before_quad;
    for( i = 0; i < num_quad_faces; ++i )
        side = TopologyInfo::face_vertices( PYRAMID, i + quad_off, count, err );
        CPPUNIT_ASSERT( count == 4 );
        CPPUNIT_ASSERT( compare_face( 4, side, quads[i] ) );
        side = TopologyInfo::side_vertices( PYRAMID, 2, i + quad_off, count, err );
    side = TopologyInfo::side_vertices( PYRAMID, 3, 0, count, err );
Definition at line 977 of file TopologyInfoTest.cpp.
References CPPUNIT_ASSERT, and MBMesquite::PYRAMID.
    const int num_nodes = 13;
    TopologyInfo::higher_order( PYRAMID, num_nodes, edge, face, vol, err );
    test_vol_elem( PYRAMID, num_nodes, 5, 8, 5 );
Definition at line 962 of file TopologyInfoTest.cpp.
    const int num_nodes = 5;
Definition at line 434 of file TopologyInfoTest.cpp.
References compare_edge(), corners, CPPUNIT_ASSERT, MBMesquite::edges, edges, MBMesquite::faces, and MBMesquite::QUADRILATERAL.
    CPPUNIT_ASSERT( 2 == TopologyInfo::dimension( QUADRILATERAL ) );
    CPPUNIT_ASSERT( 4 == TopologyInfo::adjacent( QUADRILATERAL, 1 ) );
    CPPUNIT_ASSERT( 4 == TopologyInfo::adjacent( QUADRILATERAL, 0 ) );
    CPPUNIT_ASSERT( 1 == TopologyInfo::adjacent( QUADRILATERAL, 2 ) );
    CPPUNIT_ASSERT( 0 == TopologyInfo::adjacent( QUADRILATERAL, 3 ) );
    CPPUNIT_ASSERT( 4 == TopologyInfo::sides( QUADRILATERAL ) );
    CPPUNIT_ASSERT( 4 == TopologyInfo::corners( QUADRILATERAL ) );
    CPPUNIT_ASSERT( 4 == TopologyInfo::edges( QUADRILATERAL ) );
    CPPUNIT_ASSERT( 1 == TopologyInfo::faces( QUADRILATERAL ) );
    const unsigned num_edges = 4;
    const unsigned edges[num_edges][2] = { { 0, 1 }, { 1, 2 }, { 2, 3 }, { 3, 0 } };
    unsigned count;
    const unsigned face[] = { 0, 1, 2, 3 };
    for( unsigned i = 0; i < num_edges; ++i )
        side = TopologyInfo::edge_vertices( QUADRILATERAL, i, err );
        side = TopologyInfo::side_vertices( QUADRILATERAL, 1, i, count, err );
    side = TopologyInfo::side_vertices( QUADRILATERAL, 2, 0, count, err );
    CPPUNIT_ASSERT( 4 == count );
    CPPUNIT_ASSERT( compare_face( 4, side, face ) );
Definition at line 473 of file TopologyInfoTest.cpp.
References CPPUNIT_ASSERT, and MBMesquite::QUADRILATERAL.
    const int num_nodes = 4;
    TopologyInfo::higher_order( QUADRILATERAL, num_nodes, edge, face, vol, err );
    test_face_elem( QUADRILATERAL, num_nodes, 4 );
Definition at line 488 of file TopologyInfoTest.cpp.
Definition at line 503 of file TopologyInfoTest.cpp.
Definition at line 518 of file TopologyInfoTest.cpp.
Definition at line 1166 of file TopologyInfoTest.cpp.
References MBMesquite::QUADRILATERAL.
    unsigned data[][5] = { { 2, 1, 3, 0, 0 }, { 2, 2, 0, 0, 0 }, { 2, 3, 1, 0, 0 }, { 2, 0, 2, 0, 0 } };
    test_adj( MBMesquite::QUADRILATERAL, data );
void TopologyInfoTest::setUp ( ) [inline]
Definition at line 112 of file TopologyInfoTest.cpp.
Definition at line 1353 of file TopologyInfoTest.cpp.
    unsigned dim, num;
    // HEX-27
        TopologyInfo::side_from_higher_order( HEXAHEDRON, 27, HEX27[i].idx, dim, num, err );
        CPPUNIT_ASSERT_EQUAL( HEX27[i].dim, dim );
        CPPUNIT_ASSERT_EQUAL( HEX27[i].num, num );
    // HEX-26
        TopologyInfo::side_from_higher_order( HEXAHEDRON, 26, HEX26[i].idx, dim, num, err );
        CPPUNIT_ASSERT_EQUAL( HEX26[i].dim, dim );
        CPPUNIT_ASSERT_EQUAL( HEX26[i].num, num );
    // HEX-20
        TopologyInfo::side_from_higher_order( HEXAHEDRON, 20, HEX20[i].idx, dim, num, err );
        CPPUNIT_ASSERT_EQUAL( HEX20[i].dim, dim );
        CPPUNIT_ASSERT_EQUAL( HEX20[i].num, num );
    // HEX-15
        TopologyInfo::side_from_higher_order( HEXAHEDRON, 15, HEX15[i].idx, dim, num, err );
        CPPUNIT_ASSERT_EQUAL( HEX15[i].dim, dim );
        CPPUNIT_ASSERT_EQUAL( HEX15[i].num, num );
    // HEX-14
        TopologyInfo::side_from_higher_order( HEXAHEDRON, 14, HEX14[i].idx, dim, num, err );
        CPPUNIT_ASSERT_EQUAL( HEX14[i].dim, dim );
        CPPUNIT_ASSERT_EQUAL( HEX14[i].num, num );
    // HEX-9
        TopologyInfo::side_from_higher_order( HEXAHEDRON, 9, HEX9[i].idx, dim, num, err );
        CPPUNIT_ASSERT_EQUAL( HEX9[i].dim, dim );
        CPPUNIT_ASSERT_EQUAL( HEX9[i].num, num );
void TopologyInfoTest::tearDown ( ) [inline]
Definition at line 114 of file TopologyInfoTest.cpp.
void TopologyInfoTest::test_adj ( MBMesquite::EntityTopology  type,
Definition at line 1199 of file TopologyInfoTest.cpp.
References corners, CPPUNIT_ASSERT, and n.
    // Get num vertices from type
    unsigned n = TopologyInfo::corners( type );
    CPPUNIT_ASSERT( n > 0 );
    // The first index into data is the vertex.
    // Each column of "data", indexed by vertex, is a
    // vector containing the number of adjacent vertices
    // followed by the list if adjacent vertex indices.
    // for each vertex
    for( unsigned i = 0; i < n; ++i )
        // Get the data corresponding to this vertex of the element
        unsigned const* corner  = data[i];
        unsigned expected_count = corner[0];
        // Query TopologyInfo for the same data
        unsigned actual_count;
        unsigned const* actual_adj = TopologyInfo::adjacent_vertices( type, i, actual_count );
        // Check result is valid and counts match
        CPPUNIT_ASSERT( actual_adj != NULL );
        CPPUNIT_ASSERT( expected_count == actual_count );
        // For 3-D elements, returned vertices are expected to be oriented
        // such that  a face bounded by the vertices in the counter-clockwise
        // order will have a normal pointing away from the input vertex.
        // So the vertices must be in a certain order, but may begin with
        // any of the adjacent vertices.
        // Find the location in the result list at which the first
        // vertex in the expected list occurs.
        unsigned j;
        for( j = 0; j < actual_count; ++j )
            if( corner[1] == actual_adj[j] ) break;
        // Asssert that the first expected vertex was somewhere in
        // the result list.
        CPPUNIT_ASSERT( j < actual_count );
        // Compare the remaining vertices, enforcing the order.
        for( unsigned k = 1; k < actual_count; ++k )
            CPPUNIT_ASSERT( corner[k + 1] == actual_adj[( k + j ) % actual_count] );
void TopologyInfoTest::test_face_elem ( EntityTopology  topo,
unsigned  num_nodes,
unsigned  num_sides
Definition at line 250 of file TopologyInfoTest.cpp.
References CPPUNIT_ASSERT, dim, and moab::side_number().
    unsigned index = 0;
    TopologyInfo::higher_order( topo, num_nodes, edge, face, vol, err );
    unsigned nodes = num_sides + edge * num_sides + face;
    CPPUNIT_ASSERT( num_nodes == nodes );
    unsigned side, dim;
    for( index = 0; index < num_sides; ++index )
        TopologyInfo::side_number( topo, num_nodes, index, dim, side, err );
        CPPUNIT_ASSERT( dim == 0 && side == index );
    if( edge )
        for( unsigned s = 0; s < num_sides; ++s )
            TopologyInfo::side_number( topo, num_nodes, index++, dim, side, err );
            CPPUNIT_ASSERT( dim == 1 && side == s );
    if( face )
        CPPUNIT_ASSERT( dim == 2 && side == 0 );
Definition at line 1098 of file TopologyInfoTest.cpp.
References corners, CPPUNIT_ASSERT, edges, and MBMesquite::faces.
    CPPUNIT_ASSERT( TopologyInfo::adjacent( topo, 1 ) == 0 );
    CPPUNIT_ASSERT( TopologyInfo::sides( topo ) == 0 );
    CPPUNIT_ASSERT( TopologyInfo::corners( topo ) == 0 );
    CPPUNIT_ASSERT( TopologyInfo::edges( topo ) == 0 );
    CPPUNIT_ASSERT( TopologyInfo::faces( topo ) == 0 );
Definition at line 1243 of file TopologyInfoTest.cpp.
    // for each vertex
        // get adjacent vertex list
        unsigned num_adj_idx;
        unsigned const* adj_idx = TopologyInfo::adjacent_vertices( type, i, num_adj_idx );
        CPPUNIT_ASSERT( adj_idx != NULL );
        CPPUNIT_ASSERT( num_adj_idx > 1 );
        // make sure adjacent vertex list is unique
        std::vector< unsigned > adj_idx_copy( num_adj_idx );
        std::copy( adj_idx, adj_idx + num_adj_idx, adj_idx_copy.begin() );
        std::sort( adj_idx_copy.begin(), adj_idx_copy.end() );
        std::vector< unsigned >::iterator iter;
        iter = std::unique( adj_idx_copy.begin(), adj_idx_copy.end() );
        CPPUNIT_ASSERT( iter == adj_idx_copy.end() );
        // Get reverse mapping indices
        unsigned num_rev_idx;
        unsigned const* rev_idx = TopologyInfo::reverse_vertex_adjacency_offsets( type, i, num_rev_idx );
        CPPUNIT_ASSERT( rev_idx != NULL );
        CPPUNIT_ASSERT( num_rev_idx == num_adj_idx );
        // for each adjacent vertex, test reverse mapping
        for( unsigned j = 0; j < num_adj_idx; ++j )
            unsigned num_adj_adj_idx;
            unsigned const* adj_adj_idx = TopologyInfo::adjacent_vertices( type, adj_idx[j], num_adj_adj_idx );
            CPPUNIT_ASSERT( rev_idx[j] < num_adj_adj_idx );
            CPPUNIT_ASSERT( adj_adj_idx[rev_idx[j]] == i );
void TopologyInfoTest::test_vol_elem ( EntityTopology  topo,
unsigned  num_nodes,
unsigned  num_verts,
unsigned  num_edges,
unsigned  num_faces
Definition at line 287 of file TopologyInfoTest.cpp.
    unsigned index = 0;
    unsigned nodes = num_verts + edge * num_edges + face * num_faces + vol;
    unsigned side, dim;
    for( index = 0; index < num_verts; ++index )
    if( edge )
        for( unsigned s = 0; s < num_edges; ++s )
    if( face )
        for( unsigned s = 0; s < num_faces; ++s )
            CPPUNIT_ASSERT( dim == 2 && side == s );
    if( vol )
        CPPUNIT_ASSERT( dim == 3 && side == 0 );
Definition at line 533 of file TopologyInfoTest.cpp.
References compare_edge(), corners, CPPUNIT_ASSERT, MBMesquite::edges, edges, MBMesquite::faces, and MBMesquite::TETRAHEDRON.
    const unsigned num_verts = 4;
    const unsigned num_edges = 6;
    const unsigned num_faces = 4;
    CPPUNIT_ASSERT( 3 == TopologyInfo::dimension( TETRAHEDRON ) );
    CPPUNIT_ASSERT( 1 == TopologyInfo::adjacent( TETRAHEDRON, 3 ) );
    CPPUNIT_ASSERT( num_faces == TopologyInfo::adjacent( TETRAHEDRON, 2 ) );
    CPPUNIT_ASSERT( num_edges == TopologyInfo::adjacent( TETRAHEDRON, 1 ) );
    CPPUNIT_ASSERT( num_verts == TopologyInfo::adjacent( TETRAHEDRON, 0 ) );
    CPPUNIT_ASSERT( num_faces == TopologyInfo::sides( TETRAHEDRON ) );
    CPPUNIT_ASSERT( num_verts == TopologyInfo::corners( TETRAHEDRON ) );
    CPPUNIT_ASSERT( num_edges == TopologyInfo::edges( TETRAHEDRON ) );
    CPPUNIT_ASSERT( num_faces == TopologyInfo::faces( TETRAHEDRON ) );
    unsigned i, count;
    const unsigned vert_per_face             = 3;
    unsigned edges[num_edges][2]             = { { 0, 1 }, { 1, 2 }, { 2, 0 }, { 0, 3 }, { 1, 3 }, { 2, 3 } };
    unsigned faces[num_faces][vert_per_face] = { { 0, 1, 3 }, { 1, 2, 3 }, { 2, 0, 3 }, { 2, 1, 0 } };
        side = TopologyInfo::edge_vertices( TETRAHEDRON, i, err );
        side = TopologyInfo::side_vertices( TETRAHEDRON, 1, i, count, err );
        side = TopologyInfo::face_vertices( TETRAHEDRON, i, count, err );
        side = TopologyInfo::side_vertices( TETRAHEDRON, 2, i, count, err );
    side = TopologyInfo::side_vertices( TETRAHEDRON, 3, 0, count, err );
Definition at line 649 of file TopologyInfoTest.cpp.
References CPPUNIT_ASSERT, and MBMesquite::TETRAHEDRON.
    const int num_nodes = 10;
    TopologyInfo::higher_order( TETRAHEDRON, num_nodes, edge, face, vol, err );
    test_vol_elem( TETRAHEDRON, num_nodes, 4, 6, 4 );
Definition at line 664 of file TopologyInfoTest.cpp.
    const int num_nodes = 11;
Definition at line 679 of file TopologyInfoTest.cpp.
Definition at line 694 of file TopologyInfoTest.cpp.
Definition at line 589 of file TopologyInfoTest.cpp.
Definition at line 604 of file TopologyInfoTest.cpp.
Definition at line 619 of file TopologyInfoTest.cpp.
Definition at line 634 of file TopologyInfoTest.cpp.
Definition at line 1172 of file TopologyInfoTest.cpp.
References MBMesquite::TETRAHEDRON.
    unsigned data[][5] = { { 3, 1, 2, 3, 0 }, { 3, 2, 0, 3, 0 }, { 3, 0, 1, 3, 0 }, { 3, 2, 1, 0, 0 } };
    test_adj( MBMesquite::TETRAHEDRON, data );
Definition at line 336 of file TopologyInfoTest.cpp.
References compare_edge(), corners, CPPUNIT_ASSERT, MBMesquite::edges, edges, MBMesquite::faces, and MBMesquite::TRIANGLE.
    CPPUNIT_ASSERT( 2 == TopologyInfo::dimension( TRIANGLE ) );
    CPPUNIT_ASSERT( 3 == TopologyInfo::adjacent( TRIANGLE, 1 ) );
    CPPUNIT_ASSERT( 3 == TopologyInfo::adjacent( TRIANGLE, 0 ) );
    CPPUNIT_ASSERT( 1 == TopologyInfo::adjacent( TRIANGLE, 2 ) );
    CPPUNIT_ASSERT( 0 == TopologyInfo::adjacent( TRIANGLE, 3 ) );
    CPPUNIT_ASSERT( 3 == TopologyInfo::sides( TRIANGLE ) );
    CPPUNIT_ASSERT( 3 == TopologyInfo::corners( TRIANGLE ) );
    CPPUNIT_ASSERT( 3 == TopologyInfo::edges( TRIANGLE ) );
    CPPUNIT_ASSERT( 1 == TopologyInfo::faces( TRIANGLE ) );
    const unsigned num_edges = 3;
    const unsigned edges[num_edges][2] = { { 0, 1 }, { 1, 2 }, { 2, 0 } };
    unsigned count;
    const unsigned face[] = { 0, 1, 2 };
        side = TopologyInfo::edge_vertices( TRIANGLE, i, err );
        side = TopologyInfo::side_vertices( TRIANGLE, 1, i, count, err );
    side = TopologyInfo::side_vertices( TRIANGLE, 2, 0, count, err );
    CPPUNIT_ASSERT( 3 == count );
    CPPUNIT_ASSERT( compare_face( 3, side, face ) );
Definition at line 375 of file TopologyInfoTest.cpp.
References CPPUNIT_ASSERT, and MBMesquite::TRIANGLE.
    const int num_nodes = 3;
    TopologyInfo::higher_order( TRIANGLE, num_nodes, edge, face, vol, err );
    test_face_elem( TRIANGLE, num_nodes, 3 );
Definition at line 389 of file TopologyInfoTest.cpp.
Definition at line 404 of file TopologyInfoTest.cpp.
    const int num_nodes = 6;
Definition at line 419 of file TopologyInfoTest.cpp.
    const int num_nodes = 7;
Definition at line 1160 of file TopologyInfoTest.cpp.
References MBMesquite::TRIANGLE.
    unsigned data[][5] = { { 2, 1, 2, 0, 0 }, { 2, 2, 0, 0, 0 }, { 2, 0, 1, 0, 0 } };
    test_adj( MBMesquite::TRIANGLE, data );
Definition at line 187 of file TopologyInfoTest.cpp.
Definition at line 1192 of file TopologyInfoTest.cpp.
References MBMesquite::PRISM.
    unsigned data[][5] = { { 3, 1, 2, 3, 0 }, { 3, 2, 0, 4, 0 }, { 3, 0, 1, 5, 0 },
                           { 3, 5, 4, 0, 0 }, { 3, 3, 5, 1, 0 }, { 3, 4, 3, 2, 0 } };
    test_adj( MBMesquite::PRISM, data );
Definition at line 207 of file TopologyInfoTest.cpp.
Definition at line 992 of file TopologyInfoTest.cpp.
References compare_edge(), corners, CPPUNIT_ASSERT, MBMesquite::edges, edges, MBMesquite::faces, and MBMesquite::PRISM.
    const unsigned num_verts = 6;
    const unsigned num_edges = 9;
    CPPUNIT_ASSERT( 3 == TopologyInfo::dimension( PRISM ) );
    CPPUNIT_ASSERT( 1 == TopologyInfo::adjacent( PRISM, 3 ) );
    CPPUNIT_ASSERT( num_faces == TopologyInfo::adjacent( PRISM, 2 ) );
    CPPUNIT_ASSERT( num_edges == TopologyInfo::adjacent( PRISM, 1 ) );
    CPPUNIT_ASSERT( num_verts == TopologyInfo::adjacent( PRISM, 0 ) );
    CPPUNIT_ASSERT( num_faces == TopologyInfo::sides( PRISM ) );
    CPPUNIT_ASSERT( num_verts == TopologyInfo::corners( PRISM ) );
    CPPUNIT_ASSERT( num_edges == TopologyInfo::edges( PRISM ) );
    CPPUNIT_ASSERT( num_faces == TopologyInfo::faces( PRISM ) );
    unsigned i, count;
    const unsigned num_tri_faces  = 2;
    const unsigned num_quad_faces = 3;
    const bool tri_before_quad    = false;
    unsigned edges[num_edges][2]      = { { 0, 1 }, { 1, 2 }, { 2, 0 }, { 0, 3 }, { 1, 4 },
                                     { 2, 5 }, { 3, 4 }, { 4, 5 }, { 5, 3 } };
    unsigned tris[num_tri_faces][3]   = { { 2, 1, 0 }, { 3, 4, 5 } };
    unsigned quads[num_quad_faces][4] = { { 0, 1, 4, 3 }, { 1, 2, 5, 4 }, { 2, 0, 3, 5 } };
        side = TopologyInfo::edge_vertices( PRISM, i, err );
        side = TopologyInfo::side_vertices( PRISM, 1, i, count, err );
        side = TopologyInfo::face_vertices( PRISM, i + tri_off, count, err );
        side = TopologyInfo::side_vertices( PRISM, 2, i + tri_off, count, err );
        side = TopologyInfo::face_vertices( PRISM, i + quad_off, count, err );
        side = TopologyInfo::side_vertices( PRISM, 2, i + quad_off, count, err );
    side = TopologyInfo::side_vertices( PRISM, 3, 0, count, err );
Definition at line 1083 of file TopologyInfoTest.cpp.
References CPPUNIT_ASSERT, and MBMesquite::PRISM.
    TopologyInfo::higher_order( PRISM, num_nodes, edge, face, vol, err );
    test_vol_elem( PRISM, num_nodes, 6, 9, 5 );
Definition at line 1068 of file TopologyInfoTest.cpp.
List of all members.
