MOAB
4.9.3pre
Base class for quaternion expressions. More...
#include <Quaternion.h>
Public Types | |
| enum | { Flags = Eigen::internal::traits<Derived>::Flags } |
| typedef RotationBase< Derived, 3 > | Base |
| typedef internal::traits < Derived >::Scalar | Scalar |
| typedef NumTraits< Scalar >::Real | RealScalar |
| typedef internal::traits < Derived >::Coefficients | Coefficients |
| typedef Matrix< Scalar, 3, 1 > | Vector3 |
| typedef Matrix< Scalar, 3, 3 > | Matrix3 |
| typedef AngleAxis< Scalar > | AngleAxisType |
Public Member Functions | |
| Scalar | x () const |
| Scalar | y () const |
| Scalar | z () const |
| Scalar | w () const |
| Scalar & | x () |
| Scalar & | y () |
| Scalar & | z () |
| Scalar & | w () |
| const VectorBlock< const Coefficients, 3 > | vec () const |
| VectorBlock< Coefficients, 3 > | vec () |
| const internal::traits < Derived >::Coefficients & | coeffs () const |
| internal::traits< Derived > ::Coefficients & | coeffs () |
| EIGEN_STRONG_INLINE QuaternionBase< Derived > & | operator= (const QuaternionBase< Derived > &other) |
| template<class OtherDerived > | |
| EIGEN_STRONG_INLINE Derived & | operator= (const QuaternionBase< OtherDerived > &other) |
| Derived & | operator= (const AngleAxisType &aa) |
| Derived & | operator= (const MatrixBase< OtherDerived > &m) |
| QuaternionBase & | setIdentity () |
| Scalar | squaredNorm () const |
| Scalar | norm () const |
| void | normalize () |
| Quaternion< Scalar > | normalized () const |
| Scalar | dot (const QuaternionBase< OtherDerived > &other) const |
| Scalar | angularDistance (const QuaternionBase< OtherDerived > &other) const |
| Matrix3 | toRotationMatrix () const |
| template<typename Derived1 , typename Derived2 > | |
| Derived & | setFromTwoVectors (const MatrixBase< Derived1 > &a, const MatrixBase< Derived2 > &b) |
| EIGEN_STRONG_INLINE Quaternion < Scalar > | operator* (const QuaternionBase< OtherDerived > &q) const |
| EIGEN_STRONG_INLINE Derived & | operator*= (const QuaternionBase< OtherDerived > &q) |
| Quaternion< Scalar > | inverse () const |
| Quaternion< Scalar > | conjugate () const |
| Quaternion< Scalar > | slerp (const Scalar &t, const QuaternionBase< OtherDerived > &other) const |
| bool | isApprox (const QuaternionBase< OtherDerived > &other, const RealScalar &prec=NumTraits< Scalar >::dummy_precision()) const |
| EIGEN_STRONG_INLINE Vector3 | _transformVector (const Vector3 &v) const |
| template<typename NewScalarType > | |
| internal::cast_return_type < Derived, Quaternion < NewScalarType > >::type | cast () const |
| template<class MatrixDerived > | |
| Derived & | operator= (const MatrixBase< MatrixDerived > &xpr) |
Static Public Member Functions | |
| static Quaternion< Scalar > | Identity () |
| Derived | derived type (CRTP) |
Definition at line 35 of file Quaternion.h.
| typedef AngleAxis<Scalar> Eigen::QuaternionBase< Derived >::AngleAxisType |
the equivalent angle-axis type
Reimplemented in Eigen::Quaternion< _Scalar, _Options >.
Definition at line 56 of file Quaternion.h.
| typedef RotationBase<Derived, 3> Eigen::QuaternionBase< Derived >::Base |
Reimplemented in Eigen::Map< Quaternion< _Scalar >, _Options >, Eigen::Map< const Quaternion< _Scalar >, _Options >, and Eigen::Quaternion< _Scalar, _Options >.
Definition at line 38 of file Quaternion.h.
| typedef internal::traits<Derived>::Coefficients Eigen::QuaternionBase< Derived >::Coefficients |
Definition at line 45 of file Quaternion.h.
| typedef Matrix<Scalar,3,3> Eigen::QuaternionBase< Derived >::Matrix3 |
the equivalent rotation matrix type
Definition at line 54 of file Quaternion.h.
| typedef NumTraits<Scalar>::Real Eigen::QuaternionBase< Derived >::RealScalar |
Definition at line 44 of file Quaternion.h.
| typedef internal::traits<Derived>::Scalar Eigen::QuaternionBase< Derived >::Scalar |
the scalar type of the coefficients
Reimplemented from Eigen::RotationBase< Derived, 3 >.
Definition at line 43 of file Quaternion.h.
| typedef Matrix<Scalar,3,1> Eigen::QuaternionBase< Derived >::Vector3 |
the type of a 3D vector
Definition at line 52 of file Quaternion.h.
| anonymous enum |
Definition at line 46 of file Quaternion.h.
| EIGEN_STRONG_INLINE QuaternionBase< Derived >::Vector3 Eigen::QuaternionBase< Derived >::_transformVector | ( | const Vector3 & | v | ) | const |
return the result vector of v through the rotation
Rotation of a vector by a quaternion.
Definition at line 469 of file Quaternion.h.
// Note that this algorithm comes from the optimization by hand
// of the conversion to a Matrix followed by a Matrix/Vector product.
// It appears to be much faster than the common algorithm found
// in the literature (30 versus 39 flops). It also requires two
// Vector3 as temporaries.
Vector3 uv = this->vec().cross(v);
uv += uv;
return v + this->w() * uv + this->vec().cross(uv);
| internal::traits< Derived >::Scalar Eigen::QuaternionBase< Derived >::angularDistance | ( | const QuaternionBase< OtherDerived > & | other | ) | const [inline] |
| internal::cast_return_type<Derived,Quaternion<NewScalarType> >::type Eigen::QuaternionBase< Derived >::cast | ( | ) | const [inline] |
*this with scalar type casted to NewScalarType Note that if NewScalarType is equal to the current scalar type of *this then this function smartly returns a const reference to *this.
Definition at line 173 of file Quaternion.h.
| const internal::traits<Derived>::Coefficients& Eigen::QuaternionBase< Derived >::coeffs | ( | ) | const [inline] |
Definition at line 85 of file Quaternion.h.
{ return derived().coeffs(); }
| internal::traits<Derived>::Coefficients& Eigen::QuaternionBase< Derived >::coeffs | ( | ) | [inline] |
Reimplemented in Eigen::Map< Quaternion< _Scalar >, _Options >, and Eigen::Quaternion< _Scalar, _Options >.
Definition at line 88 of file Quaternion.h.
| Quaternion< typename internal::traits< Derived >::Scalar > Eigen::QuaternionBase< Derived >::conjugate | ( | ) | const [inline] |
*this which is equal to the multiplicative inverse if the quaternion is normalized. The conjugate of a quaternion represents the opposite rotation.Definition at line 671 of file Quaternion.h.
return internal::quat_conj<Architecture::Target, Derived,
typename internal::traits<Derived>::Scalar,
internal::traits<Derived>::Alignment>::run(*this);
| Scalar Eigen::QuaternionBase< Derived >::dot | ( | const QuaternionBase< OtherDerived > & | other | ) | const [inline] |
*this and other Geometrically speaking, the dot product of two unit quaternions corresponds to the cosine of half the angle between the two rotations. Definition at line 134 of file Quaternion.h.
{ return coeffs().dot(other.coeffs()); }
| static Quaternion<Scalar> Eigen::QuaternionBase< Derived >::Identity | ( | ) | [inline, static] |
Definition at line 106 of file Quaternion.h.
| Quaternion< typename internal::traits< Derived >::Scalar > Eigen::QuaternionBase< Derived >::inverse | ( | ) | const [inline] |
*this Note that in most cases, i.e., if you simply want the opposite rotation, and/or the quaternion is normalized, then it is enough to use the conjugate.Reimplemented from Eigen::RotationBase< Derived, 3 >.
Definition at line 640 of file Quaternion.h.
// FIXME should this function be called multiplicativeInverse and conjugate() be called inverse() or opposite() ??
Scalar n2 = this->squaredNorm();
if (n2 > Scalar(0))
return Quaternion<Scalar>(conjugate().coeffs() / n2);
else
// return an invalid result to flag the error
return Quaternion<Scalar>(Coefficients::Zero());
| bool Eigen::QuaternionBase< Derived >::isApprox | ( | const QuaternionBase< OtherDerived > & | other, |
| const RealScalar & | prec = NumTraits<Scalar>::dummy_precision() |
true if *this is approximately equal to other, within the precision determined by prec.Definition at line 161 of file Quaternion.h.
{ return coeffs().isApprox(other.coeffs(), prec); }
| Scalar Eigen::QuaternionBase< Derived >::norm | ( | ) | const [inline] |
Definition at line 120 of file Quaternion.h.
{ return coeffs().norm(); }
| void Eigen::QuaternionBase< Derived >::normalize | ( | void | ) | [inline] |
Normalizes the quaternion *this
Definition at line 124 of file Quaternion.h.
{ coeffs().normalize(); }
| Quaternion<Scalar> Eigen::QuaternionBase< Derived >::normalized | ( | ) | const [inline] |
*this Definition at line 127 of file Quaternion.h.
{ return Quaternion<Scalar>(coeffs().normalized()); }
| EIGEN_STRONG_INLINE Quaternion< typename internal::traits< Derived >::Scalar > Eigen::QuaternionBase< Derived >::operator* | ( | const QuaternionBase< OtherDerived > & | other | ) | const |
Definition at line 442 of file Quaternion.h.
EIGEN_STATIC_ASSERT((internal::is_same<typename Derived::Scalar, typename OtherDerived::Scalar>::value),
YOU_MIXED_DIFFERENT_NUMERIC_TYPES__YOU_NEED_TO_USE_THE_CAST_METHOD_OF_MATRIXBASE_TO_CAST_NUMERIC_TYPES_EXPLICITLY)
return internal::quat_product<Architecture::Target, Derived, OtherDerived,
EIGEN_PLAIN_ENUM_MIN(internal::traits<Derived>::Alignment, internal::traits<OtherDerived>::Alignment)>::run(*this, other);
| EIGEN_STRONG_INLINE Derived & Eigen::QuaternionBase< Derived >::operator*= | ( | const QuaternionBase< OtherDerived > & | other | ) |
Definition at line 454 of file Quaternion.h.
| EIGEN_STRONG_INLINE QuaternionBase< Derived > & Eigen::QuaternionBase< Derived >::operator= | ( | const QuaternionBase< Derived > & | other | ) |
Definition at line 482 of file Quaternion.h.
| EIGEN_STRONG_INLINE Derived & Eigen::QuaternionBase< Derived >::operator= | ( | const QuaternionBase< OtherDerived > & | other | ) |
Definition at line 490 of file Quaternion.h.
| EIGEN_STRONG_INLINE Derived & Eigen::QuaternionBase< Derived >::operator= | ( | const AngleAxisType & | aa | ) |
Set *this from an angle-axis aa and returns a reference to *this
Definition at line 499 of file Quaternion.h.
| Derived& Eigen::QuaternionBase< Derived >::operator= | ( | const MatrixBase< OtherDerived > & | m | ) |
| Derived& Eigen::QuaternionBase< Derived >::operator= | ( | const MatrixBase< MatrixDerived > & | xpr | ) | [inline] |
Set *this from the expression xpr:
Definition at line 517 of file Quaternion.h.
EIGEN_STATIC_ASSERT((internal::is_same<typename Derived::Scalar, typename MatrixDerived::Scalar>::value),
internal::quaternionbase_assign_impl<MatrixDerived>::run(*this, xpr.derived());
return derived();
| Derived & Eigen::QuaternionBase< Derived >::setFromTwoVectors | ( | const MatrixBase< Derived1 > & | a, |
| const MatrixBase< Derived2 > & | b | ||
| ) | [inline] |
Sets *this to be a quaternion representing a rotation between the two arbitrary vectors a and b. In other words, the built rotation represent a rotation sending the line of direction a to the line of direction b, both lines passing through the origin.
*this.Note that the two input vectors do not have to be normalized, and do not need to have the same norm.
Definition at line 576 of file Quaternion.h.
using std::sqrt;
Vector3 v0 = a.normalized();
Vector3 v1 = b.normalized();
Scalar c = v1.dot(v0);
// if dot == -1, vectors are nearly opposites
// => accurately compute the rotation axis by computing the
// intersection of the two planes. This is done by solving:
// x^T v0 = 0
// x^T v1 = 0
// under the constraint:
// ||x|| = 1
// which yields a singular value problem
if (c < Scalar(-1)+NumTraits<Scalar>::dummy_precision())
c = numext::maxi(c,Scalar(-1));
Matrix<Scalar,2,3> m; m << v0.transpose(), v1.transpose();
JacobiSVD<Matrix<Scalar,2,3> > svd(m, ComputeFullV);
Vector3 axis = svd.matrixV().col(2);
Scalar w2 = (Scalar(1)+c)*Scalar(0.5);
this->w() = sqrt(w2);
this->vec() = axis * sqrt(Scalar(1) - w2);
return derived();
Vector3 axis = v0.cross(v1);
Scalar s = sqrt((Scalar(1)+c)*Scalar(2));
Scalar invs = Scalar(1)/s;
this->vec() = axis * invs;
this->w() = s * Scalar(0.5);
return derived();
| QuaternionBase& Eigen::QuaternionBase< Derived >::setIdentity | ( | ) | [inline] |
Definition at line 110 of file Quaternion.h.
| Quaternion< typename internal::traits< Derived >::Scalar > Eigen::QuaternionBase< Derived >::slerp | ( | const Scalar & | t, |
| const QuaternionBase< OtherDerived > & | other | ||
| ) | const |
*this and other at the parameter t in [0;1].This represents an interpolation for a constant motion between *this and other, see also http://en.wikipedia.org/wiki/Slerp.
Definition at line 704 of file Quaternion.h.
using std::acos;
using std::sin;
using std::abs;
static const Scalar one = Scalar(1) - NumTraits<Scalar>::epsilon();
Scalar d = this->dot(other);
Scalar absD = abs(d);
Scalar scale0;
Scalar scale1;
if(absD>=one)
scale0 = Scalar(1) - t;
scale1 = t;
else
// theta is the angle between the 2 quaternions
Scalar theta = acos(absD);
Scalar sinTheta = sin(theta);
scale0 = sin( ( Scalar(1) - t ) * theta) / sinTheta;
scale1 = sin( ( t * theta) ) / sinTheta;
if(d<Scalar(0)) scale1 = -scale1;
return Quaternion<Scalar>(scale0 * coeffs() + scale1 * other.coeffs());
| Scalar Eigen::QuaternionBase< Derived >::squaredNorm | ( | ) | const [inline] |
Definition at line 115 of file Quaternion.h.
{ return coeffs().squaredNorm(); }
| QuaternionBase< Derived >::Matrix3 Eigen::QuaternionBase< Derived >::toRotationMatrix | ( | void | ) | const [inline] |
Convert the quaternion to a 3x3 rotation matrix. The quaternion is required to be normalized, otherwise the result is undefined.
Definition at line 530 of file Quaternion.h.
// NOTE if inlined, then gcc 4.2 and 4.4 get rid of the temporary (not gcc 4.3 !!)
// if not inlined then the cost of the return by value is huge ~ +35%,
// however, not inlining this function is an order of magnitude slower, so
// it has to be inlined, and so the return by value is not an issue
Matrix3 res;
const Scalar tx = Scalar(2)*this->x();
const Scalar ty = Scalar(2)*this->y();
const Scalar tz = Scalar(2)*this->z();
const Scalar twx = tx*this->w();
const Scalar twy = ty*this->w();
const Scalar twz = tz*this->w();
const Scalar txx = tx*this->x();
const Scalar txy = ty*this->x();
const Scalar txz = tz*this->x();
const Scalar tyy = ty*this->y();
const Scalar tyz = tz*this->y();
const Scalar tzz = tz*this->z();
res.coeffRef(0,0) = Scalar(1)-(tyy+tzz);
res.coeffRef(0,1) = txy-twz;
res.coeffRef(0,2) = txz+twy;
res.coeffRef(1,0) = txy+twz;
res.coeffRef(1,1) = Scalar(1)-(txx+tzz);
res.coeffRef(1,2) = tyz-twx;
res.coeffRef(2,0) = txz-twy;
res.coeffRef(2,1) = tyz+twx;
res.coeffRef(2,2) = Scalar(1)-(txx+tyy);
return res;
| const VectorBlock<const Coefficients,3> Eigen::QuaternionBase< Derived >::vec | ( | ) | const [inline] |
Definition at line 79 of file Quaternion.h.
{ return coeffs().template head<3>(); }
| VectorBlock<Coefficients,3> Eigen::QuaternionBase< Derived >::vec | ( | ) | [inline] |
Definition at line 82 of file Quaternion.h.
| Scalar Eigen::QuaternionBase< Derived >::w | ( | ) | const [inline] |
w coefficient Definition at line 67 of file Quaternion.h.
{ return this->derived().coeffs().coeff(3); }
| Scalar& Eigen::QuaternionBase< Derived >::w | ( | ) | [inline] |
w coefficient Definition at line 76 of file Quaternion.h.
{ return this->derived().coeffs().coeffRef(3); }
| Scalar Eigen::QuaternionBase< Derived >::x | ( | ) | const [inline] |
x coefficient Definition at line 61 of file Quaternion.h.
{ return this->derived().coeffs().coeff(0); }
| Scalar& Eigen::QuaternionBase< Derived >::x | ( | ) | [inline] |
x coefficient Definition at line 70 of file Quaternion.h.
{ return this->derived().coeffs().coeffRef(0); }
| Scalar Eigen::QuaternionBase< Derived >::y | ( | ) | const [inline] |
y coefficient Definition at line 63 of file Quaternion.h.
{ return this->derived().coeffs().coeff(1); }
| Scalar& Eigen::QuaternionBase< Derived >::y | ( | ) | [inline] |
y coefficient Definition at line 72 of file Quaternion.h.
{ return this->derived().coeffs().coeffRef(1); }
| Scalar Eigen::QuaternionBase< Derived >::z | ( | ) | const [inline] |
z coefficient Definition at line 65 of file Quaternion.h.
{ return this->derived().coeffs().coeff(2); }
| Scalar& Eigen::QuaternionBase< Derived >::z | ( | ) | [inline] |
z coefficient Definition at line 74 of file Quaternion.h.
{ return this->derived().coeffs().coeffRef(2); }
