MOAB
4.9.3pre
Classes | |
| class | Eigen::Map< const Quaternion< _Scalar >, _Options > |
| Quaternion expression mapping a constant memory buffer. More... | |
| class | Eigen::Map< Quaternion< _Scalar >, _Options > |
| Expression of a quaternion from a memory buffer. More... | |
| class | Eigen::AlignedBox< _Scalar, _AmbientDim > |
| An axis aligned box. More... | |
| class | Eigen::AngleAxis< _Scalar > |
| Represents a 3D rotation as a rotation angle around an arbitrary 3D axis. More... | |
| class | Eigen::Homogeneous< MatrixType, _Direction > |
| Expression of one (or a set of) homogeneous vector(s) More... | |
| class | Eigen::Hyperplane< _Scalar, _AmbientDim, _Options > |
| A hyperplane. More... | |
| class | Eigen::ParametrizedLine< _Scalar, _AmbientDim, _Options > |
| A parametrized line. More... | |
| class | Eigen::QuaternionBase< Derived > |
| Base class for quaternion expressions. More... | |
| class | Eigen::Quaternion< _Scalar, _Options > |
| The quaternion class used to represent 3D orientations and rotations. More... | |
| class | Eigen::Rotation2D< _Scalar > |
| Represents a rotation/orientation in a 2 dimensional space. More... | |
| class | Scaling |
| Represents a generic uniform scaling transformation. More... | |
| class | Eigen::Transform< _Scalar, _Dim, _Mode, _Options > |
| Represents an homogeneous transformation in a N dimensional space. More... | |
| class | Eigen::Translation< _Scalar, _Dim > |
| Represents a translation transformation. More... | |
Modules | |
| Global aligned box typedefs | |
Typedefs | |
| typedef AngleAxis< float > | Eigen::AngleAxisf |
| typedef AngleAxis< double > | Eigen::AngleAxisd |
| typedef Quaternion< float > | Eigen::Quaternionf |
| typedef Quaternion< double > | Eigen::Quaterniond |
| typedef Map< Quaternion< float >, 0 > | Eigen::QuaternionMapf |
| typedef Map< Quaternion < double >, 0 > | Eigen::QuaternionMapd |
| typedef Map< Quaternion< float > , Aligned > | Eigen::QuaternionMapAlignedf |
| typedef Map< Quaternion < double >, Aligned > | Eigen::QuaternionMapAlignedd |
| typedef Rotation2D< float > | Eigen::Rotation2Df |
| typedef Rotation2D< double > | Eigen::Rotation2Dd |
| typedef DiagonalMatrix< float, 2 > | Eigen::AlignedScaling2f |
| typedef DiagonalMatrix< double, 2 > | Eigen::AlignedScaling2d |
| typedef DiagonalMatrix< float, 3 > | Eigen::AlignedScaling3f |
| typedef DiagonalMatrix< double, 3 > | Eigen::AlignedScaling3d |
| typedef Transform< float, 2, Isometry > | Eigen::Isometry2f |
| typedef Transform< float, 3, Isometry > | Eigen::Isometry3f |
| typedef Transform< double, 2, Isometry > | Eigen::Isometry2d |
| typedef Transform< double, 3, Isometry > | Eigen::Isometry3d |
| typedef Transform< float, 2, Affine > | Eigen::Affine2f |
| typedef Transform< float, 3, Affine > | Eigen::Affine3f |
| typedef Transform< double, 2, Affine > | Eigen::Affine2d |
| typedef Transform< double, 3, Affine > | Eigen::Affine3d |
| typedef Transform< float, 2, AffineCompact > | Eigen::AffineCompact2f |
| typedef Transform< float, 3, AffineCompact > | Eigen::AffineCompact3f |
| typedef Transform< double, 2, AffineCompact > | Eigen::AffineCompact2d |
| typedef Transform< double, 3, AffineCompact > | Eigen::AffineCompact3d |
| typedef Transform< float, 2, Projective > | Eigen::Projective2f |
| typedef Transform< float, 3, Projective > | Eigen::Projective3f |
| typedef Transform< double, 2, Projective > | Eigen::Projective2d |
| typedef Transform< double, 3, Projective > | Eigen::Projective3d |
| typedef Translation< float, 2 > | Eigen::Translation2f |
| typedef Translation< double, 2 > | Eigen::Translation2d |
| typedef Translation< float, 3 > | Eigen::Translation3f |
| typedef Translation< double, 3 > | Eigen::Translation3d |
Functions | |
| static UniformScaling< float > | Eigen::Scaling (float s) |
| static UniformScaling< double > | Eigen::Scaling (double s) |
| template<typename RealScalar > | |
| static UniformScaling < std::complex< RealScalar > > | Eigen::Scaling (const std::complex< RealScalar > &s) |
| template<typename Scalar > | |
| static DiagonalMatrix< Scalar, 2 > | Eigen::Scaling (const Scalar &sx, const Scalar &sy) |
| static DiagonalMatrix< Scalar, 3 > | Eigen::Scaling (const Scalar &sx, const Scalar &sy, const Scalar &sz) |
| template<typename Derived > | |
| static const DiagonalWrapper < const Derived > | Eigen::Scaling (const MatrixBase< Derived > &coeffs) |
| template<typename Derived , typename OtherDerived > | |
| internal::umeyama_transform_matrix_type < Derived, OtherDerived > ::type | Eigen::umeyama (const MatrixBase< Derived > &src, const MatrixBase< OtherDerived > &dst, bool with_scaling=true) |
| Returns the transformation between two point sets. | |
| Matrix< Scalar, 3, 1 > | Eigen::MatrixBase< Derived >::eulerAngles (Index a0, Index a1, Index a2) const |
| HomogeneousReturnType | Eigen::MatrixBase< Derived >::homogeneous () const |
| HomogeneousReturnType | Eigen::VectorwiseOp< ExpressionType, Direction >::homogeneous () const |
| const HNormalizedReturnType | Eigen::MatrixBase< Derived >::hnormalized () const |
| const HNormalizedReturnType | Eigen::VectorwiseOp< ExpressionType, Direction >::hnormalized () const |
| template<typename OtherDerived > | |
| EIGEN_DEVICE_FUNC cross_product_return_type < OtherDerived >::type | Eigen::MatrixBase< Derived >::cross (const MatrixBase< OtherDerived > &other) const |
| EIGEN_DEVICE_FUNC PlainObject | Eigen::MatrixBase< Derived >::cross3 (const MatrixBase< OtherDerived > &other) const |
| EIGEN_DEVICE_FUNC const CrossReturnType | Eigen::VectorwiseOp< ExpressionType, Direction >::cross (const MatrixBase< OtherDerived > &other) const |
| EIGEN_DEVICE_FUNC PlainObject | Eigen::MatrixBase< Derived >::unitOrthogonal (void) const |
| ScalarMultipleReturnType | Eigen::MatrixBase< Derived >::operator* (const UniformScaling< Scalar > &s) const |
| typedef Transform<double,2,Affine> Eigen::Affine2d |
Definition at line 692 of file Transform.h.
| typedef Transform<float,2,Affine> Eigen::Affine2f |
Definition at line 688 of file Transform.h.
| typedef Transform<double,3,Affine> Eigen::Affine3d |
Definition at line 694 of file Transform.h.
| typedef Transform<float,3,Affine> Eigen::Affine3f |
Definition at line 690 of file Transform.h.
| typedef Transform<double,2,AffineCompact> Eigen::AffineCompact2d |
Definition at line 701 of file Transform.h.
| typedef Transform<float,2,AffineCompact> Eigen::AffineCompact2f |
Definition at line 697 of file Transform.h.
| typedef Transform<double,3,AffineCompact> Eigen::AffineCompact3d |
Definition at line 703 of file Transform.h.
| typedef Transform<float,3,AffineCompact> Eigen::AffineCompact3f |
Definition at line 699 of file Transform.h.
| typedef DiagonalMatrix<double,2> Eigen::AlignedScaling2d |
| typedef DiagonalMatrix<float, 2> Eigen::AlignedScaling2f |
| typedef DiagonalMatrix<double,3> Eigen::AlignedScaling3d |
| typedef DiagonalMatrix<float, 3> Eigen::AlignedScaling3f |
| typedef AngleAxis<double> Eigen::AngleAxisd |
double precision angle-axis type
Definition at line 158 of file AngleAxis.h.
| typedef AngleAxis<float> Eigen::AngleAxisf |
single precision angle-axis type
Definition at line 155 of file AngleAxis.h.
| typedef Transform<double,2,Isometry> Eigen::Isometry2d |
Definition at line 683 of file Transform.h.
| typedef Transform<float,2,Isometry> Eigen::Isometry2f |
Definition at line 679 of file Transform.h.
| typedef Transform<double,3,Isometry> Eigen::Isometry3d |
Definition at line 685 of file Transform.h.
| typedef Transform<float,3,Isometry> Eigen::Isometry3f |
Definition at line 681 of file Transform.h.
| typedef Transform<double,2,Projective> Eigen::Projective2d |
Definition at line 710 of file Transform.h.
| typedef Transform<float,2,Projective> Eigen::Projective2f |
Definition at line 706 of file Transform.h.
| typedef Transform<double,3,Projective> Eigen::Projective3d |
Definition at line 712 of file Transform.h.
| typedef Transform<float,3,Projective> Eigen::Projective3f |
Definition at line 708 of file Transform.h.
| typedef Quaternion<double> Eigen::Quaterniond |
double precision quaternion type
Definition at line 303 of file Quaternion.h.
| typedef Quaternion<float> Eigen::Quaternionf |
single precision quaternion type
Definition at line 300 of file Quaternion.h.
| typedef Map<Quaternion<double>, Aligned> Eigen::QuaternionMapAlignedd |
Map a 16-byte aligned array of double precision scalars as a quaternion
Definition at line 415 of file Quaternion.h.
| typedef Map<Quaternion<float>, Aligned> Eigen::QuaternionMapAlignedf |
Map a 16-byte aligned array of single precision scalars as a quaternion
Definition at line 412 of file Quaternion.h.
| typedef Map<Quaternion<double>, 0> Eigen::QuaternionMapd |
Map an unaligned array of double precision scalars as a quaternion
Definition at line 409 of file Quaternion.h.
| typedef Map<Quaternion<float>, 0> Eigen::QuaternionMapf |
Map an unaligned array of single precision scalars as a quaternion
Definition at line 406 of file Quaternion.h.
| typedef Rotation2D<double> Eigen::Rotation2Dd |
double precision 2D rotation type
Definition at line 168 of file Rotation2D.h.
| typedef Rotation2D<float> Eigen::Rotation2Df |
single precision 2D rotation type
Definition at line 165 of file Rotation2D.h.
| typedef Translation<double,2> Eigen::Translation2d |
Definition at line 173 of file Translation.h.
| typedef Translation<float, 2> Eigen::Translation2f |
Definition at line 172 of file Translation.h.
| typedef Translation<double,3> Eigen::Translation3d |
Definition at line 175 of file Translation.h.
| typedef Translation<float, 3> Eigen::Translation3f |
Definition at line 174 of file Translation.h.
| MatrixBase< Derived >::template cross_product_return_type< OtherDerived >::type Eigen::MatrixBase< Derived >::cross | ( | const MatrixBase< OtherDerived > & | other | ) | const [inline] |
*this and other Here is a very good explanation of cross-product: http://xkcd.com/199/
With complex numbers, the cross product is implemented as
Definition at line 34 of file OrthoMethods.h.
EIGEN_STATIC_ASSERT_VECTOR_SPECIFIC_SIZE(Derived,3)
EIGEN_STATIC_ASSERT_VECTOR_SPECIFIC_SIZE(OtherDerived,3)
// Note that there is no need for an expression here since the compiler
// optimize such a small temporary very well (even within a complex expression)
typename internal::nested_eval<Derived,2>::type lhs(derived());
typename internal::nested_eval<OtherDerived,2>::type rhs(other.derived());
return typename cross_product_return_type<OtherDerived>::type(
numext::conj(lhs.coeff(1) * rhs.coeff(2) - lhs.coeff(2) * rhs.coeff(1)),
numext::conj(lhs.coeff(2) * rhs.coeff(0) - lhs.coeff(0) * rhs.coeff(2)),
numext::conj(lhs.coeff(0) * rhs.coeff(1) - lhs.coeff(1) * rhs.coeff(0))
| const VectorwiseOp< ExpressionType, Direction >::CrossReturnType Eigen::VectorwiseOp< ExpressionType, Direction >::cross | ( | const MatrixBase< OtherDerived > & | other | ) | const |
The referenced matrix must have one dimension equal to 3. The result matrix has the same dimensions than the referenced one.
Definition at line 109 of file OrthoMethods.h.
EIGEN_STATIC_ASSERT((internal::is_same<Scalar, typename OtherDerived::Scalar>::value),
YOU_MIXED_DIFFERENT_NUMERIC_TYPES__YOU_NEED_TO_USE_THE_CAST_METHOD_OF_MATRIXBASE_TO_CAST_NUMERIC_TYPES_EXPLICITLY)
typename internal::nested_eval<ExpressionType,2>::type mat(_expression());
typename internal::nested_eval<OtherDerived,2>::type vec(other.derived());
CrossReturnType res(_expression().rows(),_expression().cols());
if(Direction==Vertical)
eigen_assert(CrossReturnType::RowsAtCompileTime==3 && "the matrix must have exactly 3 rows");
res.row(0) = (mat.row(1) * vec.coeff(2) - mat.row(2) * vec.coeff(1)).conjugate();
res.row(1) = (mat.row(2) * vec.coeff(0) - mat.row(0) * vec.coeff(2)).conjugate();
res.row(2) = (mat.row(0) * vec.coeff(1) - mat.row(1) * vec.coeff(0)).conjugate();
else
eigen_assert(CrossReturnType::ColsAtCompileTime==3 && "the matrix must have exactly 3 columns");
res.col(0) = (mat.col(1) * vec.coeff(2) - mat.col(2) * vec.coeff(1)).conjugate();
res.col(1) = (mat.col(2) * vec.coeff(0) - mat.col(0) * vec.coeff(2)).conjugate();
res.col(2) = (mat.col(0) * vec.coeff(1) - mat.col(1) * vec.coeff(0)).conjugate();
return res;
| MatrixBase< Derived >::PlainObject Eigen::MatrixBase< Derived >::cross3 | ( | const MatrixBase< OtherDerived > & | other | ) | const [inline] |
*this and other using only the x, y, and z coefficientsThe size of *this and other must be four. This function is especially useful when using 4D vectors instead of 3D ones to get advantage of SSE/AltiVec vectorization.
Definition at line 82 of file OrthoMethods.h.
EIGEN_STATIC_ASSERT_VECTOR_SPECIFIC_SIZE(Derived,4)
EIGEN_STATIC_ASSERT_VECTOR_SPECIFIC_SIZE(OtherDerived,4)
typedef typename internal::nested_eval<Derived,2>::type DerivedNested;
typedef typename internal::nested_eval<OtherDerived,2>::type OtherDerivedNested;
DerivedNested lhs(derived());
OtherDerivedNested rhs(other.derived());
return internal::cross3_impl<Architecture::Target,
typename internal::remove_all<DerivedNested>::type,
typename internal::remove_all<OtherDerivedNested>::type>::run(lhs,rhs);
| Matrix< typename MatrixBase< Derived >::Scalar, 3, 1 > Eigen::MatrixBase< Derived >::eulerAngles | ( | Index | a0, |
| Index | a1, | ||
| Index | a2 | ||
*this using the convention defined by the triplet (a0,a1,a2)Each of the three parameters a0,a1,a2 represents the respective rotation axis as an integer in {0,1,2}. For instance, in:
Vector3f ea = mat.eulerAngles(2, 0, 2);
"2" represents the z axis and "0" the x axis, etc. The returned angles are such that we have the following equality:
mat == AngleAxisf(ea[0], Vector3f::UnitZ()) * AngleAxisf(ea[1], Vector3f::UnitX()) * AngleAxisf(ea[2], Vector3f::UnitZ());
This corresponds to the right-multiply conventions (with right hand side frames).
The returned angles are in the ranges [0:pi]x[-pi:pi]x[-pi:pi].
Definition at line 37 of file EulerAngles.h.
using std::atan2;
using std::sin;
using std::cos;
/* Implemented from Graphics Gems IV */
EIGEN_STATIC_ASSERT_MATRIX_SPECIFIC_SIZE(Derived,3,3)
Matrix<Scalar,3,1> res;
typedef Matrix<typename Derived::Scalar,2,1> Vector2;
const Index odd = ((a0+1)%3 == a1) ? 0 : 1;
const Index i = a0;
const Index j = (a0 + 1 + odd)%3;
const Index k = (a0 + 2 - odd)%3;
if (a0==a2)
res[0] = atan2(coeff(j,i), coeff(k,i));
if((odd && res[0]<Scalar(0)) || ((!odd) && res[0]>Scalar(0)))
res[0] = (res[0] > Scalar(0)) ? res[0] - Scalar(EIGEN_PI) : res[0] + Scalar(EIGEN_PI);
Scalar s2 = Vector2(coeff(j,i), coeff(k,i)).norm();
res[1] = -atan2(s2, coeff(i,i));
else
res[1] = atan2(s2, coeff(i,i));
// With a=(0,1,0), we have i=0; j=1; k=2, and after computing the first two angles,
// we can compute their respective rotation, and apply its inverse to M. Since the result must
// be a rotation around x, we have:
// c2 s1.s2 c1.s2 1 0 0
// 0 c1 -s1 * M = 0 c3 s3
// -s2 s1.c2 c1.c2 0 -s3 c3
// Thus: m11.c1 - m21.s1 = c3 & m12.c1 - m22.s1 = s3
Scalar s1 = sin(res[0]);
Scalar c1 = cos(res[0]);
res[2] = atan2(c1*coeff(j,k)-s1*coeff(k,k), c1*coeff(j,j) - s1 * coeff(k,j));
else
res[0] = atan2(coeff(j,k), coeff(k,k));
Scalar c2 = Vector2(coeff(i,i), coeff(i,j)).norm();
if((odd && res[0]<Scalar(0)) || ((!odd) && res[0]>Scalar(0))) {
res[1] = atan2(-coeff(i,k), -c2);
else
res[1] = atan2(-coeff(i,k), c2);
res[2] = atan2(s1*coeff(k,i)-c1*coeff(j,i), c1*coeff(j,j) - s1 * coeff(k,j));
if (!odd)
res = -res;
return res;
| const MatrixBase< Derived >::HNormalizedReturnType Eigen::MatrixBase< Derived >::hnormalized | ( | ) | const [inline] |
*this Example:
Output:
Definition at line 159 of file Homogeneous.h.
EIGEN_STATIC_ASSERT_VECTOR_ONLY(Derived);
return ConstStartMinusOne(derived(),0,0,
ColsAtCompileTime==1?size()-1:1,
ColsAtCompileTime==1?1:size()-1) / coeff(size()-1);
| const VectorwiseOp< ExpressionType, Direction >::HNormalizedReturnType Eigen::VectorwiseOp< ExpressionType, Direction >::hnormalized | ( | ) | const [inline] |
*this Example:
Output:
Definition at line 177 of file Homogeneous.h.
return HNormalized_Block(_expression(),0,0,
Direction==Vertical ? _expression().rows()-1 : _expression().rows(),
Direction==Horizontal ? _expression().cols()-1 : _expression().cols()).cwiseQuotient(
Replicate<HNormalized_Factors,
Direction==Vertical ? HNormalized_SizeMinusOne : 1,
Direction==Horizontal ? HNormalized_SizeMinusOne : 1>
(HNormalized_Factors(_expression(),
Direction==Vertical ? _expression().rows()-1:0,
Direction==Horizontal ? _expression().cols()-1:0,
Direction==Vertical ? 1 : _expression().rows(),
Direction==Horizontal ? 1 : _expression().cols()),
Direction==Vertical ? _expression().rows()-1 : 1,
Direction==Horizontal ? _expression().cols()-1 : 1));
| MatrixBase< Derived >::HomogeneousReturnType Eigen::MatrixBase< Derived >::homogeneous | ( | ) | const [inline] |
Example:
Output:
Definition at line 128 of file Homogeneous.h.
return HomogeneousReturnType(derived());
| Homogeneous< ExpressionType, Direction > Eigen::VectorwiseOp< ExpressionType, Direction >::homogeneous | ( | ) | const [inline] |
Example:
Output:
Definition at line 144 of file Homogeneous.h.
return HomogeneousReturnType(_expression());
| MatrixBase< Derived >::ScalarMultipleReturnType Eigen::MatrixBase< Derived >::operator* | ( | const UniformScaling< Scalar > & | s | ) | const [inline] |
| static UniformScaling<float> Eigen::Scaling | ( | float | s | ) | [inline, static] |
| static UniformScaling<double> Eigen::Scaling | ( | double | s | ) | [inline, static] |
| static UniformScaling<std::complex<RealScalar> > Eigen::Scaling | ( | const std::complex< RealScalar > & | s | ) | [inline, static] |
| static DiagonalMatrix<Scalar,2> Eigen::Scaling | ( | const Scalar & | sx, |
| const Scalar & | sy | ||
| static DiagonalMatrix<Scalar,3> Eigen::Scaling | ( | const Scalar & | sx, |
| const Scalar & | sy, | ||
| const Scalar & | sz | ||
| static const DiagonalWrapper<const Derived> Eigen::Scaling | ( | const MatrixBase< Derived > & | coeffs | ) | [inline, static] |
| internal::umeyama_transform_matrix_type<Derived, OtherDerived>::type Eigen::umeyama | ( | const MatrixBase< Derived > & | src, |
| const MatrixBase< OtherDerived > & | dst, | ||
| bool | with_scaling = true |
The algorithm is based on: "Least-squares estimation of transformation parameters between two point patterns", Shinji Umeyama, PAMI 1991, DOI: 10.1109/34.88573
It estimates parameters
and
such that
is minimized.
The algorithm is based on the analysis of the covariance matrix
of the input point sets
and
where
is corresponding to the dimension (which is typically small). The analysis is involving the SVD having a complexity of
though the actual computational effort lies in the covariance matrix computation which has an asymptotic lower bound of
when the input point sets have dimension
Currently the method is working only for floating point matrices.
| src | Source points . |
| dst | Destination points . |
| with_scaling | Sets when false is passed. |
Definition at line 95 of file Umeyama.h.
typedef typename internal::umeyama_transform_matrix_type<Derived, OtherDerived>::type TransformationMatrixType;
typedef typename internal::traits<TransformationMatrixType>::Scalar Scalar;
typedef typename NumTraits<Scalar>::Real RealScalar;
EIGEN_STATIC_ASSERT(!NumTraits<Scalar>::IsComplex, NUMERIC_TYPE_MUST_BE_REAL)
EIGEN_STATIC_ASSERT((internal::is_same<Scalar, typename internal::traits<OtherDerived>::Scalar>::value),
enum { Dimension = EIGEN_SIZE_MIN_PREFER_DYNAMIC(Derived::RowsAtCompileTime, OtherDerived::RowsAtCompileTime) };
typedef Matrix<Scalar, Dimension, 1> VectorType;
typedef Matrix<Scalar, Dimension, Dimension> MatrixType;
typedef typename internal::plain_matrix_type_row_major<Derived>::type RowMajorMatrixType;
const Index m = src.rows(); // dimension
const Index n = src.cols(); // number of measurements
// required for demeaning ...
const RealScalar one_over_n = RealScalar(1) / static_cast<RealScalar>(n);
// computation of mean
const VectorType src_mean = src.rowwise().sum() * one_over_n;
const VectorType dst_mean = dst.rowwise().sum() * one_over_n;
// demeaning of src and dst points
const RowMajorMatrixType src_demean = src.colwise() - src_mean;
const RowMajorMatrixType dst_demean = dst.colwise() - dst_mean;
// Eq. (36)-(37)
const Scalar src_var = src_demean.rowwise().squaredNorm().sum() * one_over_n;
// Eq. (38)
const MatrixType sigma = one_over_n * dst_demean * src_demean.transpose();
JacobiSVD<MatrixType> svd(sigma, ComputeFullU | ComputeFullV);
// Initialize the resulting transformation with an identity matrix...
TransformationMatrixType Rt = TransformationMatrixType::Identity(m+1,m+1);
// Eq. (39)
VectorType S = VectorType::Ones(m);
if ( svd.matrixU().determinant() * svd.matrixV().determinant() < 0 )
S(m-1) = -1;
// Eq. (40) and (43)
Rt.block(0,0,m,m).noalias() = svd.matrixU() * S.asDiagonal() * svd.matrixV().transpose();
if (with_scaling)
// Eq. (42)
const Scalar c = Scalar(1)/src_var * svd.singularValues().dot(S);
// Eq. (41)
Rt.col(m).head(m) = dst_mean;
Rt.col(m).head(m).noalias() -= c*Rt.topLeftCorner(m,m)*src_mean;
Rt.block(0,0,m,m) *= c;
else
Rt.col(m).head(m).noalias() -= Rt.topLeftCorner(m,m)*src_mean;
return Rt;
| MatrixBase< Derived >::PlainObject Eigen::MatrixBase< Derived >::unitOrthogonal | ( | void | ) | const [inline] |
*this The size of *this must be at least 2. If the size is exactly 2, then the returned vector is a counter clock wise rotation of *this, i.e., (-y,x).normalized().
Definition at line 225 of file OrthoMethods.h.
return internal::unitOrthogonal_selector<Derived>::run(derived());
