MOAB
4.9.3pre
Performs a real QZ decomposition of a pair of square matrices. More...
#include <RealQZ.h>
Public Types | |
| enum | { RowsAtCompileTime = MatrixType::RowsAtCompileTime, ColsAtCompileTime = MatrixType::ColsAtCompileTime, Options = MatrixType::Options, MaxRowsAtCompileTime = MatrixType::MaxRowsAtCompileTime, MaxColsAtCompileTime = MatrixType::MaxColsAtCompileTime } |
| typedef _MatrixType | MatrixType |
| typedef MatrixType::Scalar | Scalar |
| typedef std::complex< typename NumTraits< Scalar >::Real > | ComplexScalar |
| typedef Eigen::Index | Index |
| typedef Matrix< ComplexScalar, ColsAtCompileTime, 1, Options &~RowMajor, MaxColsAtCompileTime, 1 > | EigenvalueType |
| typedef Matrix< Scalar, ColsAtCompileTime, 1, Options &~RowMajor, MaxColsAtCompileTime, 1 > | ColumnVectorType |
Public Member Functions | |
| RealQZ (Index size=RowsAtCompileTime==Dynamic?1:RowsAtCompileTime) | |
| Default constructor. | |
| RealQZ (const MatrixType &A, const MatrixType &B, bool computeQZ=true) | |
| Constructor; computes real QZ decomposition of given matrices. | |
| const MatrixType & | matrixQ () const |
| Returns matrix Q in the QZ decomposition. | |
| const MatrixType & | matrixZ () const |
| Returns matrix Z in the QZ decomposition. | |
| const MatrixType & | matrixS () const |
| Returns matrix S in the QZ decomposition. | |
| const MatrixType & | matrixT () const |
| RealQZ & | compute (const MatrixType &A, const MatrixType &B, bool computeQZ=true) |
| Computes QZ decomposition of given matrix. | |
| ComputationInfo | info () const |
| Reports whether previous computation was successful. | |
| Index | iterations () const |
| Returns number of performed QR-like iterations. | |
| RealQZ & | setMaxIterations (Index maxIters) |
Private Types | |
| typedef Matrix< Scalar, 3, 1 > | Vector3s |
| typedef Matrix< Scalar, 2, 1 > | Vector2s |
| typedef Matrix< Scalar, 2, 2 > | Matrix2s |
| typedef JacobiRotation< Scalar > | JRs |
Private Member Functions | |
| void | hessenbergTriangular () |
| void | computeNorms () |
| Index | findSmallSubdiagEntry (Index iu) |
| Index | findSmallDiagEntry (Index f, Index l) |
| void | splitOffTwoRows (Index i) |
| void | pushDownZero (Index z, Index f, Index l) |
| void | step (Index f, Index l, Index iter) |
Private Attributes | |
| MatrixType | m_S |
| MatrixType | m_T |
| MatrixType | m_Q |
| MatrixType | m_Z |
| Matrix< Scalar, Dynamic, 1 > | m_workspace |
| ComputationInfo | m_info |
| Index | m_maxIters |
| bool | m_isInitialized |
| bool | m_computeQZ |
| Scalar | m_normOfT |
| Scalar | m_normOfS |
| Index | m_global_iter |
| _MatrixType | the type of the matrix of which we are computing the real QZ decomposition; this is expected to be an instantiation of the Matrix class template. |
Given a real square matrices A and B, this class computes the real QZ decomposition:
where Q and Z are real orthogonal matrixes, T is upper-triangular matrix, and S is upper quasi-triangular matrix. An orthogonal matrix is a matrix whose inverse is equal to its transpose,
. A quasi-triangular matrix is a block-triangular matrix whose diagonal consists of 1-by-1 blocks and 2-by-2 blocks where further reduction is impossible due to complex eigenvalues.
The eigenvalues of the pencil
can be obtained from 1x1 and 2x2 blocks on the diagonals of S and T.
Call the function compute() to compute the real QZ decomposition of a given pair of matrices. Alternatively, you can use the RealQZ(const MatrixType& B, const MatrixType& B, bool computeQZ) constructor which computes the real QZ decomposition at construction time. Once the decomposition is computed, you can use the matrixS(), matrixT(), matrixQ() and matrixZ() functions to retrieve the matrices S, T, Q and Z in the decomposition. If computeQZ==false, some time is saved by not computing matrices Q and Z.
Example:
Output:
| typedef Matrix<Scalar, ColsAtCompileTime, 1, Options & ~RowMajor, MaxColsAtCompileTime, 1> Eigen::RealQZ< _MatrixType >::ColumnVectorType |
| typedef std::complex<typename NumTraits<Scalar>::Real> Eigen::RealQZ< _MatrixType >::ComplexScalar |
| typedef Matrix<ComplexScalar, ColsAtCompileTime, 1, Options & ~RowMajor, MaxColsAtCompileTime, 1> Eigen::RealQZ< _MatrixType >::EigenvalueType |
| typedef Eigen::Index Eigen::RealQZ< _MatrixType >::Index |
typedef JacobiRotation<Scalar> Eigen::RealQZ< _MatrixType >::JRs [private] |
typedef Matrix<Scalar,2,2> Eigen::RealQZ< _MatrixType >::Matrix2s [private] |
| typedef _MatrixType Eigen::RealQZ< _MatrixType >::MatrixType |
| typedef MatrixType::Scalar Eigen::RealQZ< _MatrixType >::Scalar |
typedef Matrix<Scalar,2,1> Eigen::RealQZ< _MatrixType >::Vector2s [private] |
typedef Matrix<Scalar,3,1> Eigen::RealQZ< _MatrixType >::Vector3s [private] |
| anonymous enum |
Definition at line 61 of file RealQZ.h.
| Eigen::RealQZ< _MatrixType >::RealQZ | ( | Index | size = RowsAtCompileTime==Dynamic ? 1 : RowsAtCompileTime | ) | [inline, explicit] |
| [in] | size | Positive integer, size of the matrix whose QZ decomposition will be computed. |
The default constructor is useful in cases in which the user intends to perform decompositions via compute(). The size parameter is only used as a hint. It is not an error to give a wrong size, but it may impair performance.
Definition at line 86 of file RealQZ.h.
: RowsAtCompileTime) : m_S(size, size), m_T(size, size), m_Q(size, size), m_Z(size, size), m_workspace(size*2), m_maxIters(400), m_isInitialized(false) { }
| Eigen::RealQZ< _MatrixType >::RealQZ | ( | const MatrixType & | A, |
| const MatrixType & | B, | ||
| bool | computeQZ = true |
| ) | [inline] |
This constructor calls compute() to compute the QZ decomposition.
Definition at line 104 of file RealQZ.h.
m_S(A.rows(),A.cols()),
m_T(A.rows(),A.cols()),
m_Q(A.rows(),A.cols()),
m_Z(A.rows(),A.cols()),
m_workspace(A.rows()*2),
m_maxIters(400),
compute(A, B, computeQZ);
| RealQZ< MatrixType > & Eigen::RealQZ< MatrixType >::compute | ( | const MatrixType & | A, |
*this Definition at line 557 of file RealQZ.h.
const Index dim = A_in.cols();
eigen_assert (A_in.rows()==dim && A_in.cols()==dim
&& B_in.rows()==dim && B_in.cols()==dim
&& "Need square matrices of the same dimension");
m_isInitialized = true;
m_computeQZ = computeQZ;
m_S = A_in; m_T = B_in;
m_workspace.resize(dim*2);
m_global_iter = 0;
// entrance point: hessenberg triangular decomposition
hessenbergTriangular();
// compute L1 vector norms of T, S into m_normOfS, m_normOfT
computeNorms();
Index l = dim-1,
f,
local_iter = 0;
while (l>0 && local_iter<m_maxIters)
f = findSmallSubdiagEntry(l);
// now rows and columns f..l (including) decouple from the rest of the problem
if (f>0) m_S.coeffRef(f,f-1) = Scalar(0.0);
if (f == l) // One root found
l--;
local_iter = 0;
else if (f == l-1) // Two roots found
splitOffTwoRows(f);
l -= 2;
local_iter = 0;
else // No convergence yet
// if there's zero on diagonal of T, we can isolate an eigenvalue with Givens rotations
Index z = findSmallDiagEntry(f,l);
if (z>=f)
// zero found
pushDownZero(z,f,l);
else
// We are sure now that S.block(f,f, l-f+1,l-f+1) is underuced upper-Hessenberg
// and T.block(f,f, l-f+1,l-f+1) is invertible uper-triangular, which allows to
// apply a QR-like iteration to rows and columns f..l.
step(f,l, local_iter);
local_iter++;
m_global_iter++;
// check if we converged before reaching iterations limit
m_info = (local_iter<m_maxIters) ? Success : NoConvergence;
return *this;
} // end compute
| void Eigen::RealQZ< MatrixType >::computeNorms | ( | ) | [inline, private] |
Computes vector L1 norms of S and T when in Hessenberg-Triangular form already
| Index Eigen::RealQZ< MatrixType >::findSmallDiagEntry | ( | Index | f, |
| Index | l | ||
| Index Eigen::RealQZ< MatrixType >::findSmallSubdiagEntry | ( | Index | iu | ) | [inline, private] |
Look for single small sub-diagonal element S(res, res-1) and return res (or 0)
| void Eigen::RealQZ< MatrixType >::hessenbergTriangular | ( | ) | [private] |
Reduces S and T to upper Hessenberg - triangular form
Definition at line 217 of file RealQZ.h.
const Index dim = m_S.cols();
// perform QR decomposition of T, overwrite T with R, save Q
HouseholderQR<MatrixType> qrT(m_T);
m_T = qrT.matrixQR();
m_T.template triangularView<StrictlyLower>().setZero();
m_Q = qrT.householderQ();
// overwrite S with Q* S
m_S.applyOnTheLeft(m_Q.adjoint());
// init Z as Identity
if (m_computeQZ)
m_Z = MatrixType::Identity(dim,dim);
// reduce S to upper Hessenberg with Givens rotations
for (Index j=0; j<=dim-3; j++) {
for (Index i=dim-1; i>=j+2; i--) {
JRs G;
// kill S(i,j)
if(m_S.coeff(i,j) != 0)
G.makeGivens(m_S.coeff(i-1,j), m_S.coeff(i,j), &m_S.coeffRef(i-1, j));
m_S.coeffRef(i,j) = Scalar(0.0);
m_S.rightCols(dim-j-1).applyOnTheLeft(i-1,i,G.adjoint());
m_T.rightCols(dim-i+1).applyOnTheLeft(i-1,i,G.adjoint());
// update Q
if (m_computeQZ)
m_Q.applyOnTheRight(i-1,i,G);
// kill T(i,i-1)
if(m_T.coeff(i,i-1)!=Scalar(0))
G.makeGivens(m_T.coeff(i,i), m_T.coeff(i,i-1), &m_T.coeffRef(i,i));
m_T.coeffRef(i,i-1) = Scalar(0.0);
m_S.applyOnTheRight(i,i-1,G);
m_T.topRows(i).applyOnTheRight(i,i-1,G);
// update Z
if (m_computeQZ)
m_Z.applyOnTheLeft(i,i-1,G.adjoint());
| ComputationInfo Eigen::RealQZ< _MatrixType >::info | ( | ) | const [inline] |
Success if computation was succesful, NoConvergence otherwise. Definition at line 166 of file RealQZ.h.
eigen_assert(m_isInitialized && "RealQZ is not initialized.");
return m_info;
| Index Eigen::RealQZ< _MatrixType >::iterations | ( | ) | const [inline] |
Definition at line 174 of file RealQZ.h.
return m_global_iter;
| const MatrixType& Eigen::RealQZ< _MatrixType >::matrixQ | ( | ) | const [inline] |
Definition at line 119 of file RealQZ.h.
eigen_assert(m_computeQZ && "The matrices Q and Z have not been computed during the QZ decomposition.");
return m_Q;
| const MatrixType& Eigen::RealQZ< _MatrixType >::matrixS | ( | ) | const [inline] |
Definition at line 139 of file RealQZ.h.
return m_S;
| const MatrixType& Eigen::RealQZ< _MatrixType >::matrixT | ( | ) | const [inline] |
Definition at line 148 of file RealQZ.h.
return m_T;
| const MatrixType& Eigen::RealQZ< _MatrixType >::matrixZ | ( | ) | const [inline] |
Definition at line 129 of file RealQZ.h.
return m_Z;
| void Eigen::RealQZ< MatrixType >::pushDownZero | ( | Index | z, |
| Index | f, | ||
| Index | l | ||
use zero in T(z,z) to zero S(l,l-1), working in block f..l
Definition at line 361 of file RealQZ.h.
JRs G;
for (Index zz=z; zz<l; zz++)
// push 0 down
Index firstColS = zz>f ? (zz-1) : zz;
G.makeGivens(m_T.coeff(zz, zz+1), m_T.coeff(zz+1, zz+1));
m_S.rightCols(dim-firstColS).applyOnTheLeft(zz,zz+1,G.adjoint());
m_T.rightCols(dim-zz).applyOnTheLeft(zz,zz+1,G.adjoint());
m_T.coeffRef(zz+1,zz+1) = Scalar(0.0);
// update Q
if (m_computeQZ)
m_Q.applyOnTheRight(zz,zz+1,G);
// kill S(zz+1, zz-1)
if (zz>f)
G.makeGivens(m_S.coeff(zz+1, zz), m_S.coeff(zz+1,zz-1));
m_S.topRows(zz+2).applyOnTheRight(zz, zz-1,G);
m_T.topRows(zz+1).applyOnTheRight(zz, zz-1,G);
m_S.coeffRef(zz+1,zz-1) = Scalar(0.0);
// update Z
if (m_computeQZ)
m_Z.applyOnTheLeft(zz,zz-1,G.adjoint());
// finally kill S(l,l-1)
G.makeGivens(m_S.coeff(l,l), m_S.coeff(l,l-1));
m_S.applyOnTheRight(l,l-1,G);
m_T.applyOnTheRight(l,l-1,G);
m_S.coeffRef(l,l-1)=Scalar(0.0);
// update Z
if (m_computeQZ)
m_Z.applyOnTheLeft(l,l-1,G.adjoint());
| RealQZ& Eigen::RealQZ< _MatrixType >::setMaxIterations | ( | Index | maxIters | ) | [inline] |
Sets the maximal number of iterations allowed to converge to one eigenvalue or decouple the problem.
Definition at line 183 of file RealQZ.h.
m_maxIters = maxIters;
return *this;
| void Eigen::RealQZ< MatrixType >::splitOffTwoRows | ( | Index | i | ) | [inline, private] |
decouple 2x2 diagonal block in rows i, i+1 if eigenvalues are real
Definition at line 311 of file RealQZ.h.
using std::abs;
using std::sqrt;
const Index dim=m_S.cols();
if (abs(m_S.coeff(i+1,i))==Scalar(0))
return;
Index j = findSmallDiagEntry(i,i+1);
if (j==i-1)
// block of (S T^{-1})
Matrix2s STi = m_T.template block<2,2>(i,i).template triangularView<Upper>().
template solve<OnTheRight>(m_S.template block<2,2>(i,i));
Scalar p = Scalar(0.5)*(STi(0,0)-STi(1,1));
Scalar q = p*p + STi(1,0)*STi(0,1);
if (q>=0) {
Scalar z = sqrt(q);
// one QR-like iteration for ABi - lambda I
// is enough - when we know exact eigenvalue in advance,
// convergence is immediate
JRs G;
if (p>=0)
G.makeGivens(p + z, STi(1,0));
else
G.makeGivens(p - z, STi(1,0));
m_S.rightCols(dim-i).applyOnTheLeft(i,i+1,G.adjoint());
m_T.rightCols(dim-i).applyOnTheLeft(i,i+1,G.adjoint());
// update Q
if (m_computeQZ)
m_Q.applyOnTheRight(i,i+1,G);
G.makeGivens(m_T.coeff(i+1,i+1), m_T.coeff(i+1,i));
m_S.topRows(i+2).applyOnTheRight(i+1,i,G);
m_T.topRows(i+2).applyOnTheRight(i+1,i,G);
// update Z
if (m_computeQZ)
m_Z.applyOnTheLeft(i+1,i,G.adjoint());
m_S.coeffRef(i+1,i) = Scalar(0.0);
m_T.coeffRef(i+1,i) = Scalar(0.0);
else
pushDownZero(j,i,i+1);
| void Eigen::RealQZ< MatrixType >::step | ( | Index | f, |
| Index | l, | ||
| Index | iter | ||
QR-like iterative step for block f..l
Definition at line 400 of file RealQZ.h.
using std::abs;
// x, y, z
Scalar x, y, z;
if (iter==10)
// Wilkinson ad hoc shift
const Scalar
a11=m_S.coeff(f+0,f+0), a12=m_S.coeff(f+0,f+1),
a21=m_S.coeff(f+1,f+0), a22=m_S.coeff(f+1,f+1), a32=m_S.coeff(f+2,f+1),
b12=m_T.coeff(f+0,f+1),
b11i=Scalar(1.0)/m_T.coeff(f+0,f+0),
b22i=Scalar(1.0)/m_T.coeff(f+1,f+1),
a87=m_S.coeff(l-1,l-2),
a98=m_S.coeff(l-0,l-1),
b77i=Scalar(1.0)/m_T.coeff(l-2,l-2),
b88i=Scalar(1.0)/m_T.coeff(l-1,l-1);
Scalar ss = abs(a87*b77i) + abs(a98*b88i),
lpl = Scalar(1.5)*ss,
ll = ss*ss;
x = ll + a11*a11*b11i*b11i - lpl*a11*b11i + a12*a21*b11i*b22i
- a11*a21*b12*b11i*b11i*b22i;
y = a11*a21*b11i*b11i - lpl*a21*b11i + a21*a22*b11i*b22i
- a21*a21*b12*b11i*b11i*b22i;
z = a21*a32*b11i*b22i;
else if (iter==16)
// another exceptional shift
x = m_S.coeff(f,f)/m_T.coeff(f,f)-m_S.coeff(l,l)/m_T.coeff(l,l) + m_S.coeff(l,l-1)*m_T.coeff(l-1,l) /
(m_T.coeff(l-1,l-1)*m_T.coeff(l,l));
y = m_S.coeff(f+1,f)/m_T.coeff(f,f);
z = 0;
else if (iter>23 && !(iter%8))
// extremely exceptional shift
x = internal::random<Scalar>(-1.0,1.0);
y = internal::random<Scalar>(-1.0,1.0);
z = internal::random<Scalar>(-1.0,1.0);
else
// Compute the shifts: (x,y,z,0...) = (AB^-1 - l1 I) (AB^-1 - l2 I) e1
// where l1 and l2 are the eigenvalues of the 2x2 matrix C = U V^-1 where
// U and V are 2x2 bottom right sub matrices of A and B. Thus:
// = AB^-1AB^-1 + l1 l2 I - (l1+l2)(AB^-1)
// = AB^-1AB^-1 + det(M) - tr(M)(AB^-1)
// Since we are only interested in having x, y, z with a correct ratio, we have:
const Scalar
a11 = m_S.coeff(f,f), a12 = m_S.coeff(f,f+1),
a21 = m_S.coeff(f+1,f), a22 = m_S.coeff(f+1,f+1),
a32 = m_S.coeff(f+2,f+1),
a88 = m_S.coeff(l-1,l-1), a89 = m_S.coeff(l-1,l),
a98 = m_S.coeff(l,l-1), a99 = m_S.coeff(l,l),
b11 = m_T.coeff(f,f), b12 = m_T.coeff(f,f+1),
b22 = m_T.coeff(f+1,f+1),
b88 = m_T.coeff(l-1,l-1), b89 = m_T.coeff(l-1,l),
b99 = m_T.coeff(l,l);
x = ( (a88/b88 - a11/b11)*(a99/b99 - a11/b11) - (a89/b99)*(a98/b88) + (a98/b88)*(b89/b99)*(a11/b11) ) * (b11/a21)
+ a12/b22 - (a11/b11)*(b12/b22);
y = (a22/b22-a11/b11) - (a21/b11)*(b12/b22) - (a88/b88-a11/b11) - (a99/b99-a11/b11) + (a98/b88)*(b89/b99);
z = a32/b22;
JRs G;
for (Index k=f; k<=l-2; k++)
// variables for Householder reflections
Vector2s essential2;
Scalar tau, beta;
Vector3s hr(x,y,z);
// Q_k to annihilate S(k+1,k-1) and S(k+2,k-1)
hr.makeHouseholderInPlace(tau, beta);
essential2 = hr.template bottomRows<2>();
Index fc=(std::max)(k-1,Index(0)); // first col to update
m_S.template middleRows<3>(k).rightCols(dim-fc).applyHouseholderOnTheLeft(essential2, tau, m_workspace.data());
m_T.template middleRows<3>(k).rightCols(dim-fc).applyHouseholderOnTheLeft(essential2, tau, m_workspace.data());
if (m_computeQZ)
m_Q.template middleCols<3>(k).applyHouseholderOnTheRight(essential2, tau, m_workspace.data());
if (k>f)
m_S.coeffRef(k+2,k-1) = m_S.coeffRef(k+1,k-1) = Scalar(0.0);
// Z_{k1} to annihilate T(k+2,k+1) and T(k+2,k)
hr << m_T.coeff(k+2,k+2),m_T.coeff(k+2,k),m_T.coeff(k+2,k+1);
Index lr = (std::min)(k+4,dim); // last row to update
Map<Matrix<Scalar,Dynamic,1> > tmp(m_workspace.data(),lr);
// S
tmp = m_S.template middleCols<2>(k).topRows(lr) * essential2;
tmp += m_S.col(k+2).head(lr);
m_S.col(k+2).head(lr) -= tau*tmp;
m_S.template middleCols<2>(k).topRows(lr) -= (tau*tmp) * essential2.adjoint();
// T
tmp = m_T.template middleCols<2>(k).topRows(lr) * essential2;
tmp += m_T.col(k+2).head(lr);
m_T.col(k+2).head(lr) -= tau*tmp;
m_T.template middleCols<2>(k).topRows(lr) -= (tau*tmp) * essential2.adjoint();
if (m_computeQZ)
// Z
Map<Matrix<Scalar,1,Dynamic> > tmp(m_workspace.data(),dim);
tmp = essential2.adjoint()*(m_Z.template middleRows<2>(k));
tmp += m_Z.row(k+2);
m_Z.row(k+2) -= tau*tmp;
m_Z.template middleRows<2>(k) -= essential2 * (tau*tmp);
m_T.coeffRef(k+2,k) = m_T.coeffRef(k+2,k+1) = Scalar(0.0);
// Z_{k2} to annihilate T(k+1,k)
G.makeGivens(m_T.coeff(k+1,k+1), m_T.coeff(k+1,k));
m_S.applyOnTheRight(k+1,k,G);
m_T.applyOnTheRight(k+1,k,G);
// update Z
if (m_computeQZ)
m_Z.applyOnTheLeft(k+1,k,G.adjoint());
m_T.coeffRef(k+1,k) = Scalar(0.0);
// update x,y,z
x = m_S.coeff(k+1,k);
y = m_S.coeff(k+2,k);
if (k < l-2)
z = m_S.coeff(k+3,k);
} // loop over k
// Q_{n-1} to annihilate y = S(l,l-2)
G.makeGivens(x,y);
m_S.applyOnTheLeft(l-1,l,G.adjoint());
m_T.applyOnTheLeft(l-1,l,G.adjoint());
if (m_computeQZ)
m_Q.applyOnTheRight(l-1,l,G);
m_S.coeffRef(l,l-2) = Scalar(0.0);
// Z_{n-1} to annihilate T(l,l-1)
G.makeGivens(m_T.coeff(l,l),m_T.coeff(l,l-1));
if (m_computeQZ)
m_T.coeffRef(l,l-1) = Scalar(0.0);
bool Eigen::RealQZ< _MatrixType >::m_computeQZ [private] |
Index Eigen::RealQZ< _MatrixType >::m_global_iter [private] |
ComputationInfo Eigen::RealQZ< _MatrixType >::m_info [private] |
bool Eigen::RealQZ< _MatrixType >::m_isInitialized [private] |
Index Eigen::RealQZ< _MatrixType >::m_maxIters [private] |
Scalar Eigen::RealQZ< _MatrixType >::m_normOfS [private] |
Scalar Eigen::RealQZ< _MatrixType >::m_normOfT [private] |
MatrixType Eigen::RealQZ< _MatrixType >::m_Q [private] |
MatrixType Eigen::RealQZ< _MatrixType >::m_S [private] |
MatrixType Eigen::RealQZ< _MatrixType >::m_T [private] |
Matrix<Scalar,Dynamic,1> Eigen::RealQZ< _MatrixType >::m_workspace [private] |
MatrixType Eigen::RealQZ< _MatrixType >::m_Z [private] |
