MBMesquite::TShapeSizeB3 Class Reference
#include <TShapeSizeB3.hpp>
+ Inheritance diagram for MBMesquite::TShapeSizeB3:
+ Collaboration diagram for MBMesquite::TShapeSizeB3:
Public Member Functions
virtual MESQUITE_EXPORT ~TShapeSizeB3 ()
virtual MESQUITE_EXPORT std::string get_name () const
virtual MESQUITE_EXPORT bool evaluate (const MsqMatrix< 2, 2 > &T, double &result, MsqError &err)
 Evaluate \(\mu(T)\).
virtual MESQUITE_EXPORT bool evaluate_with_grad (const MsqMatrix< 2, 2 > &T, double &result, MsqMatrix< 2, 2 > &deriv_wrt_T, MsqError &err)
 Gradient of \(\mu(T)\) with respect to components of T.
virtual MESQUITE_EXPORT bool evaluate_with_hess (const MsqMatrix< 2, 2 > &T, double &result, MsqMatrix< 2, 2 > &deriv_wrt_T, MsqMatrix< 2, 2 > second_wrt_T[3], MsqError &err)
 Hessian of \(\mu(T)\) with respect to components of T.
virtual MESQUITE_EXPORT bool evaluate (const MsqMatrix< 3, 3 > &T, double &result, MsqError &err)
virtual MESQUITE_EXPORT bool evaluate_with_grad (const MsqMatrix< 3, 3 > &T, double &result, MsqMatrix< 3, 3 > &deriv_wrt_T, MsqError &err)
virtual MESQUITE_EXPORT bool evaluate_with_hess (const MsqMatrix< 3, 3 > &T, double &result, MsqMatrix< 3, 3 > &deriv_wrt_T, MsqMatrix< 3, 3 > second_wrt_T[6], MsqError &err)
Detailed Description
2D: |T|^2 - 2 * ln(tau) - 2 3D: |T|^3 - 3 sqrt(3) ln(tau) - 3 sqrt(3)
Definition at line 43 of file TShapeSizeB3.hpp.
Definition at line 47 of file TShapeSizeB3.cpp.
Member Function Documentation
bool MBMesquite::TShapeSizeB3::evaluate ( const MsqMatrix< 2, 2 > &  T,
double &  result,
MsqError err
) [virtual]
Parameters:
T2x2 relative measure matrix (typically A W^-1)
resultOutput: value of function
Returns:
false if function cannot be evaluated for given T (e.g. division by zero, etc.), true otherwise.
Reimplemented from MBMesquite::TMetric.
Definition at line 49 of file TShapeSizeB3.cpp.
References MBMesquite::MsqError::BARRIER_VIOLATED, MBMesquite::barrier_violated_msg, MBMesquite::det(), MBMesquite::TMetricBarrier::invalid_determinant(), MSQ_SETERR, and MBMesquite::sqr_Frobenius().
    const double tau = det( T );
    if( invalid_determinant( tau ) )
    {  // barrier
        MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED );
        return false;
    result = sqr_Frobenius( T ) - 2.0 * std::log( tau ) - 2;
    return true;
bool MBMesquite::TShapeSizeB3::evaluate ( const MsqMatrix< 3, 3 > &  T,
double &  result,
MsqError err
) [virtual]
Parameters:
T3x3 relative measure matrix (typically A W^-1)
Returns:
Definition at line 110 of file TShapeSizeB3.cpp.
References MBMesquite::MsqError::BARRIER_VIOLATED, MBMesquite::barrier_violated_msg, MBMesquite::det(), MBMesquite::Frobenius(), MBMesquite::TMetricBarrier::invalid_determinant(), MSQ_SETERR, MBMesquite::MSQ_SQRT_THREE, and n.
    {  // barrier
        return false;
    double n = Frobenius( T );
    result   = n * n * n - 3 * MSQ_SQRT_THREE * ( log( tau ) + 1 );
    return true;
bool MBMesquite::TShapeSizeB3::evaluate_with_grad ( const MsqMatrix< 2, 2 > &  T,
double &  result,
MsqMatrix< 2, 2 > &  deriv_wrt_T,
MsqError err
) [virtual]
Parameters:
deriv_wrt_TOutput: partial deriviatve of \(\mu\) wrt each term of T, evaluated at passed T.
\[\left[\begin{array}{cc} \frac{\partial\mu}{\partial T_{0,0}} & \frac{\partial\mu}{\partial T_{0,1}} \\ \frac{\partial\mu}{\partial T_{1,0}} & \frac{\partial\mu}{\partial T_{1,1}} \\ \end{array}\right]\]
Returns:
Definition at line 62 of file TShapeSizeB3.cpp.
References MBMesquite::MsqError::BARRIER_VIOLATED, MBMesquite::barrier_violated_msg, MBMesquite::det(), MBMesquite::TMetricBarrier::invalid_determinant(), MSQ_SETERR, MBMesquite::sqr_Frobenius(), T, and MBMesquite::transpose_adj().
    {  // barrier
        return false;
    deriv_wrt_T = T;
    deriv_wrt_T -= 1 / tau * transpose_adj( T );
    deriv_wrt_T *= 2;
    return true;
bool MBMesquite::TShapeSizeB3::evaluate_with_grad ( const MsqMatrix< 3, 3 > &  T,
double &  result,
MsqMatrix< 3, 3 > &  deriv_wrt_T,
MsqError err
) [virtual]
Parameters:
\[\left[\begin{array}{ccc} \frac{\partial\mu}{\partial T_{0,0}} & \frac{\partial\mu}{\partial T_{0,1}} & \frac{\partial\mu}{\partial T_{0,2}} \\ \frac{\partial\mu}{\partial T_{1,0}} & \frac{\partial\mu}{\partial T_{1,1}} & \frac{\partial\mu}{\partial T_{1,2}} \\ \frac{\partial\mu}{\partial T_{2,0}} & \frac{\partial\mu}{\partial T_{2,1}} & \frac{\partial\mu}{\partial T_{2,2}} \end{array}\right]\]
Returns:
Definition at line 124 of file TShapeSizeB3.cpp.
References MBMesquite::MsqError::BARRIER_VIOLATED, MBMesquite::barrier_violated_msg, MBMesquite::det(), MBMesquite::Frobenius(), MBMesquite::TMetricBarrier::invalid_determinant(), MSQ_SETERR, MBMesquite::MSQ_SQRT_THREE, n, T, and MBMesquite::transpose_adj().
    {  // barrier
        return false;
    const MsqMatrix< 3, 3 > adjt = transpose_adj( T );
    deriv_wrt_T                  = T;
    deriv_wrt_T *= 3 * n;
    deriv_wrt_T -= 3 * MSQ_SQRT_THREE / tau * adjt;
    return true;
bool MBMesquite::TShapeSizeB3::evaluate_with_hess ( const MsqMatrix< 2, 2 > &  T,
double &  result,
MsqError err
) [virtual]
Parameters:
second_wrt_TOutput: 9x9 matrix of second partial deriviatve of \(\mu\) wrt each term of T, in row-major order. The symmetric matrix is decomposed into 3x3 blocks and only the upper diagonal blocks, in row-major order, are returned.
\[\left[\begin{array}{cc|cc} \frac{\partial^{2}\mu}{\partial T_{0,0}^2} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial A_{0,1}} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial A_{1,0}} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial A_{1,1}} \\ \frac{\partial^{2}\mu}{\partial T_{0,0}\partial A_{0,1}} & \frac{\partial^{2}\mu}{\partial T_{0,1}^2} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial A_{1,0}} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial A_{1,1}} \\ \hline & & \frac{\partial^{2}\mu}{\partial T_{1,0}^2} & \frac{\partial^{2}\mu}{\partial T_{1,0}\partial A_{1,1}} \\ & & \frac{\partial^{2}\mu}{\partial T_{1,0}\partial A_{1,1}} & \frac{\partial^{2}\mu}{\partial T_{1,1}^2} \\ \end{array}\right]\]
Returns:
Definition at line 82 of file TShapeSizeB3.cpp.
References MBMesquite::MsqError::BARRIER_VIOLATED, MBMesquite::barrier_violated_msg, MBMesquite::det(), MBMesquite::TMetricBarrier::invalid_determinant(), MSQ_SETERR, MBMesquite::pluseq_scaled_2nd_deriv_of_det(), MBMesquite::pluseq_scaled_I(), MBMesquite::set_scaled_outer_product(), MBMesquite::sqr_Frobenius(), T, and MBMesquite::transpose_adj().
    {  // barrier
        return false;
    const MsqMatrix< 2, 2 > adjt = transpose_adj( T );
    const double it              = 1 / tau;
    deriv_wrt_T                  = T;
    deriv_wrt_T -= it * adjt;
    deriv_wrt_T *= 2;
    set_scaled_outer_product( second_wrt_T, 2 * it * it, adjt );
    pluseq_scaled_2nd_deriv_of_det( second_wrt_T, -2 * it );
    pluseq_scaled_I( second_wrt_T, 2.0 );
    return true;
bool MBMesquite::TShapeSizeB3::evaluate_with_hess ( const MsqMatrix< 3, 3 > &  T,
double &  result,
MsqError err
) [virtual]
Parameters:
\[\left[\begin{array}{ccc|ccc|ccc} \frac{\partial^{2}\mu}{\partial T_{0,0}^2} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{0,1}} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{0,2}} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{1,0}} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{1,1}} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{1,2}} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{2,0}} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{2,1}} & \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{2,2}} \\ \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{0,1}} & \frac{\partial^{2}\mu}{\partial T_{0,1}^2} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial T_{0,2}} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial T_{1,0}} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial T_{1,1}} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial T_{1,2}} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial T_{2,0}} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial T_{2,1}} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial T_{2,2}} \\ \frac{\partial^{2}\mu}{\partial T_{0,0}\partial T_{0,2}} & \frac{\partial^{2}\mu}{\partial T_{0,1}\partial T_{0,2}} & \frac{\partial^{2}\mu}{\partial T_{0,2}^2} & \frac{\partial^{2}\mu}{\partial T_{0,2}\partial T_{1,0}} & \frac{\partial^{2}\mu}{\partial T_{0,2}\partial T_{1,1}} & \frac{\partial^{2}\mu}{\partial T_{0,2}\partial T_{1,2}} & \frac{\partial^{2}\mu}{\partial T_{0,2}\partial T_{2,0}} & \frac{\partial^{2}\mu}{\partial T_{0,2}\partial T_{2,1}} & \frac{\partial^{2}\mu}{\partial T_{0,2}\partial T_{2,2}} \\ \hline & & & \frac{\partial^{2}\mu}{\partial T_{1,0}^2} & \frac{\partial^{2}\mu}{\partial T_{1,0}\partial T_{1,1}} & \frac{\partial^{2}\mu}{\partial T_{1,0}\partial T_{1,2}} & \frac{\partial^{2}\mu}{\partial T_{1,0}\partial T_{2,0}} & \frac{\partial^{2}\mu}{\partial T_{1,0}\partial T_{2,1}} & \frac{\partial^{2}\mu}{\partial T_{1,0}\partial T_{2,2}} \\ & & & \frac{\partial^{2}\mu}{\partial T_{1,0}\partial T_{1,1}} & \frac{\partial^{2}\mu}{\partial T_{1,1}^2} & \frac{\partial^{2}\mu}{\partial T_{1,1}\partial T_{1,2}} & \frac{\partial^{2}\mu}{\partial T_{1,1}\partial T_{2,0}} & \frac{\partial^{2}\mu}{\partial T_{1,1}\partial T_{2,1}} & \frac{\partial^{2}\mu}{\partial T_{1,1}\partial T_{2,2}} \\ & & & \frac{\partial^{2}\mu}{\partial T_{1,0}\partial T_{1,2}} & \frac{\partial^{2}\mu}{\partial T_{1,1}\partial T_{1,2}} & \frac{\partial^{2}\mu}{\partial T_{1,2}^2} & \frac{\partial^{2}\mu}{\partial T_{1,2}\partial T_{2,0}} & \frac{\partial^{2}\mu}{\partial T_{1,2}\partial T_{2,1}} & \frac{\partial^{2}\mu}{\partial T_{1,2}\partial T_{2,2}} \\ \hline & & & & & & \frac{\partial^{2}\mu}{\partial T_{2,0}^2} & \frac{\partial^{2}\mu}{\partial T_{2,0}\partial T_{2,1}} & \frac{\partial^{2}\mu}{\partial T_{2,0}\partial T_{2,2}} \\ & & & & & & \frac{\partial^{2}\mu}{\partial T_{2,0}\partial T_{2,1}} & \frac{\partial^{2}\mu}{\partial T_{2,1}^2} & \frac{\partial^{2}\mu}{\partial T_{2,1}\partial T_{2,2}} \\ & & & & & & \frac{\partial^{2}\mu}{\partial T_{2,0}\partial T_{2,2}} & \frac{\partial^{2}\mu}{\partial T_{2,1}\partial T_{2,2}} & \frac{\partial^{2}\mu}{\partial T_{2,2}^2} \\ \end{array}\right]\]
Returns:
Definition at line 147 of file TShapeSizeB3.cpp.
References MBMesquite::MsqError::BARRIER_VIOLATED, MBMesquite::barrier_violated_msg, MBMesquite::det(), MBMesquite::Frobenius(), MBMesquite::TMetricBarrier::invalid_determinant(), MSQ_SETERR, MBMesquite::MSQ_SQRT_THREE, n, MBMesquite::pluseq_scaled_2nd_deriv_of_det(), MBMesquite::pluseq_scaled_I(), MBMesquite::pluseq_scaled_outer_product(), MBMesquite::set_scaled_outer_product(), T, and MBMesquite::transpose_adj().
    {  // barrier
        return false;
    deriv_wrt_T                  = T;
    deriv_wrt_T -= 3 * MSQ_SQRT_THREE * it * adjt;
    if( n > 1e-50 )
        set_scaled_outer_product( second_wrt_T, 3 / n, T );
        pluseq_scaled_I( second_wrt_T, 3 * n );
        pluseq_scaled_2nd_deriv_of_det( second_wrt_T, -3 * MSQ_SQRT_THREE * it, T );
        pluseq_scaled_outer_product( second_wrt_T, 3 * MSQ_SQRT_THREE * it * it, adjt );
    else
        std::cout << "Warning: Division by zero avoided in TShapeSizeB3::evaluate_with_hess()" << std::endl;
    return true;
std::string MBMesquite::TShapeSizeB3::get_name ( ) const [virtual]
Reimplemented from MBMesquite::TMetricBarrier.
Definition at line 42 of file TShapeSizeB3.cpp.
    return "TShapeSizeB3";
List of all members.
