PMeanPMetricTest Class Reference
+ Inheritance diagram for PMeanPMetricTest:
+ Collaboration diagram for PMeanPMetricTest:
Public Member Functions
void setUp ()
void test_get_metric_type ()
void test_get_element_evaluations ()
void test_get_vertex_evaluations ()
void test_element_evaluate ()
void test_vertex_evaluate ()
void test_indices ()
void test_gradient ()
void test_hessian ()
void test_hessian_diagonal ()
Private Member Functions
 CPPUNIT_TEST_SUITE (PMeanPMetricTest)
 CPPUNIT_TEST (test_get_metric_type)
 CPPUNIT_TEST (test_get_element_evaluations)
 CPPUNIT_TEST (test_get_vertex_evaluations)
 CPPUNIT_TEST (test_element_evaluate)
 CPPUNIT_TEST (test_vertex_evaluate)
 CPPUNIT_TEST (test_indices)
 CPPUNIT_TEST (test_gradient)
 CPPUNIT_TEST (test_hessian)
 CPPUNIT_TEST (test_hessian_diagonal)
 CPPUNIT_TEST_SUITE_END ()
Private Attributes
PatchData pd
Detailed Description
Definition at line 40 of file PMeanPMetricTest.cpp.
Member Function Documentation
Definition at line 287 of file PMeanPMetricTest.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::ElementPMeanP::evaluate(), FauxMetric< B >::evaluate(), and FauxMetric< B >::get_element_evaluations().
    MsqError err;
    FauxMetric m;
    ElementPMeanP m1( 1.0, &m );
    ElementPMeanP m2( 2.0, &m );
    // evaluate average over element
    double v1, v2;
    m1.evaluate( pd, 0, v1, err );
    CPPUNIT_ASSERT( !err );
    m2.evaluate( pd, 0, v2, err );
    // get sample points within element
    std::vector< size_t > handles;
    m.get_element_evaluations( pd, 0, handles, err );
    // calculate expected values from underyling metric
    double ev1 = 0.0, ev2 = 0.0;
    for( unsigned i = 0; i < handles.size(); ++i )
        double v;
        m.evaluate( pd, handles[i], v, err );
        ev1 += v;
        ev2 += v * v;
    ev1 /= handles.size();
    ev2 /= handles.size();
    CPPUNIT_ASSERT_DOUBLES_EQUAL( ev1, v1, 1e-6 );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( ev2, v2, 1e-6 );
Definition at line 203 of file PMeanPMetricTest.cpp.
References CPPUNIT_ASSERT_EQUAL, and MBMesquite::ElementQM::get_evaluations().
    MsqError err;
    FauxMetric m;
    ElementPMeanP e( 1.0, &m );
    // test that handles array contains all elements
    e.get_evaluations( pd, handles, false, err );
    std::sort( handles.begin(), handles.end() );
    CPPUNIT_ASSERT_EQUAL( pd.num_elements(), handles.size() );
    for( unsigned i = 1; i < handles.size(); ++i )
        CPPUNIT_ASSERT_EQUAL( handles[i - 1] + 1, handles[i] );
    e.get_evaluations( pd, handles, true, err );
Definition at line 194 of file PMeanPMetricTest.cpp.
References CPPUNIT_ASSERT, MBMesquite::QualityMetric::ELEMENT_BASED, MBMesquite::VertexQM::get_metric_type(), MBMesquite::ElementQM::get_metric_type(), and MBMesquite::QualityMetric::VERTEX_BASED.
    FauxMetric m;
    VertexPMeanP v( 1.0, &m );
    CPPUNIT_ASSERT( QualityMetric::ELEMENT_BASED == e.get_metric_type() );
    CPPUNIT_ASSERT( QualityMetric::VERTEX_BASED == v.get_metric_type() );
Definition at line 223 of file PMeanPMetricTest.cpp.
References CPPUNIT_ASSERT_EQUAL, and MBMesquite::VertexQM::get_evaluations().
    MsqError err;
    FauxMetric m;
    VertexPMeanP e( 1.0, &m );
    // test that handles array contains all vertices
    CPPUNIT_ASSERT_EQUAL( pd.num_nodes(), handles.size() );
Definition at line 351 of file PMeanPMetricTest.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::ElementPMeanP::evaluate_with_gradient(), FauxMetric< B >::evaluate_with_gradient(), MBMesquite::ElementQM::evaluate_with_indices(), FauxMetric< B >::get_element_evaluations(), and index_of().
    MsqError err;
    FauxMetric m;
    // get vertices for later
    std::vector< size_t > vertices;
    pd.element_by_index( 0 ).get_vertex_indices( vertices );
    // evaluate without gradients
    double v1, v2, v3, v4;
    std::vector< size_t > indices1, indices2, indices3, indices4;
    std::vector< Vector3D > grads1, grads2;
    m1.evaluate_with_indices( pd, 0, v1, indices1, err );
    m2.evaluate_with_indices( pd, 0, v2, indices2, err );
    // evaluate with gradients
    m1.evaluate_with_gradient( pd, 0, v3, indices3, grads1, err );
    m2.evaluate_with_gradient( pd, 0, v4, indices4, grads2, err );
    // compare value and indices to eval w/out gradient
    CPPUNIT_ASSERT_DOUBLES_EQUAL( v1, v3, 1e-6 );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( v2, v4, 1e-6 );
    std::sort( indices1.begin(), indices1.end() );
    std::vector< size_t > tm( indices3 );
    std::sort( tm.begin(), tm.end() );
    CPPUNIT_ASSERT( tm == indices1 );
    std::sort( indices2.begin(), indices2.end() );
    tm = indices4;
    CPPUNIT_ASSERT( tm == indices2 );
    // setup evaluation of underying metric
    // calculate expected gradients
    std::vector< Vector3D > expected1, expected2, temp;
    expected1.resize( vertices.size(), Vector3D( 0, 0, 0 ) );
    expected2.resize( vertices.size(), Vector3D( 0, 0, 0 ) );
        double v;
        m.evaluate_with_gradient( pd, handles[i], v, indices3, temp, err );
        for( unsigned k = 0; k < indices3.size(); ++k )
            unsigned idx = index_of( vertices, indices3[k] );
            CPPUNIT_ASSERT( idx < vertices.size() );
            expected1[idx] += temp[k];
            expected2[idx] += 2 * v * temp[k];
    for( unsigned i = 0; i < vertices.size(); ++i )
        expected1[i] /= handles.size();
        expected2[i] /= handles.size();
    // compare gradients
    for( unsigned i = 0; i < indices1.size(); ++i )
        unsigned k = index_of( vertices, indices1[i] );
        CPPUNIT_ASSERT( k < vertices.size() );
        CPPUNIT_ASSERT_VECTORS_EQUAL( expected1[k], grads1[i], 1e-6 );
        CPPUNIT_ASSERT_VECTORS_EQUAL( expected2[k], grads2[i], 1e-6 );
Definition at line 427 of file PMeanPMetricTest.cpp.
References C, CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_MATRICES_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::ElementPMeanP::evaluate_with_gradient(), MBMesquite::ElementPMeanP::evaluate_with_Hessian(), FauxMetric< B >::evaluate_with_Hessian(), FauxMetric< B >::get_element_evaluations(), index_of(), N, MBMesquite::outer(), MBMesquite::Matrix3D::outer_product(), moab::R, and MBMesquite::transpose().
    MsqError err;
    FauxMetric m;
    // evaluate gradient
    std::vector< size_t > indices1, indices2, indices3, indices4, tmpi;
    std::vector< Vector3D > grad1, grad2, grad3, grad4;
    std::vector< Matrix3D > hess3, hess4;
    m1.evaluate_with_gradient( pd, 0, v1, indices1, grad1, err );
    m2.evaluate_with_gradient( pd, 0, v2, indices2, grad2, err );
    // evaluate with Hessian
    m1.evaluate_with_Hessian( pd, 0, v3, indices3, grad3, hess3, err );
    m2.evaluate_with_Hessian( pd, 0, v4, indices4, grad4, hess4, err );
    // It isn't a requirement that the index order remain the same
    // for both eval_with_grad and eval_with_Hess, but assuming it
    // does simplifies a lot of stuff in this test.  Check that the
    // assumption remains valid.
    CPPUNIT_ASSERT( indices3 == indices1 );
    CPPUNIT_ASSERT( indices4 == indices2 );
    // for any value of P, but assuming it does simplifies a lot
    // of stuff in this test, so check that the assumption is valid.
    CPPUNIT_ASSERT( indices1 == indices2 );
    // check that gradient values match
    for( size_t i = 0; i < indices1.size(); ++i )
        CPPUNIT_ASSERT_VECTORS_EQUAL( grad1[i], grad3[i], 1e-5 );
        CPPUNIT_ASSERT_VECTORS_EQUAL( grad2[i], grad4[i], 1e-5 );
    // calculate expected Hessians
    std::vector< Vector3D > g;
    std::vector< Matrix3D > expected1, expected2, h;
    std::vector< Matrix3D >::iterator h_iter;
    const unsigned N = vertices.size();
    expected1.resize( N * ( N + 1 ) / 2, Matrix3D( 0, 0, 0, 0, 0, 0, 0, 0, 0 ) );
    expected2 = expected1;
    Matrix3D outer;
        double v;
        m.evaluate_with_Hessian( pd, handles[i], v, tmpi, g, h, err );
        h_iter = h.begin();
        for( unsigned r = 0; r < tmpi.size(); ++r )
            unsigned R = index_of( vertices, tmpi[r] );
            CPPUNIT_ASSERT( R < N );
            for( unsigned c = r; c < tmpi.size(); ++c, ++h_iter )
                unsigned C = index_of( vertices, tmpi[c] );
                CPPUNIT_ASSERT( C < N );
                if( R <= C )
                    unsigned idx = N * R - R * ( R + 1 ) / 2 + C;
                    expected1[idx] += 1.0 / handles.size() * *h_iter;
                    expected2[idx] += 2.0 * v / handles.size() * *h_iter;
                    outer.outer_product( g[r], g[c] );
                    expected2[idx] += 2.0 / handles.size() * outer;
                else
                    unsigned idx = N * C - C * ( C + 1 ) / 2 + R;
                    expected1[idx] += 1.0 / handles.size() * transpose( *h_iter );
                    expected2[idx] += 2.0 * v / handles.size() * transpose( *h_iter );
                    outer.outer_product( g[c], g[r] );
    // compare Hessians
    unsigned H_idx = 0;
    for( unsigned R = 0; R < vertices.size(); ++R )
        if( vertices[R] >= pd.num_free_vertices() ) continue;
        unsigned r = index_of( indices3, vertices[R] );
        CPPUNIT_ASSERT( r < indices3.size() );
        for( unsigned C = R; C < vertices.size(); ++C, ++H_idx )
            if( vertices[C] >= pd.num_free_vertices() ) continue;
            unsigned c = index_of( indices3, vertices[C] );
            CPPUNIT_ASSERT( c < indices3.size() );
            if( r <= c )
                unsigned idx = indices3.size() * r - r * ( r + 1 ) / 2 + c;
                CPPUNIT_ASSERT_MATRICES_EQUAL( expected1[H_idx], hess3[idx], 1e-5 );
                CPPUNIT_ASSERT_MATRICES_EQUAL( expected2[H_idx], hess4[idx], 1e-5 );
            else
                unsigned idx = indices3.size() * c - c * ( c + 1 ) / 2 + r;
                CPPUNIT_ASSERT_MATRICES_EQUAL( transpose( expected1[H_idx] ), hess3[idx], 1e-5 );
                CPPUNIT_ASSERT_MATRICES_EQUAL( transpose( expected2[H_idx] ), hess4[idx], 1e-5 );
Definition at line 550 of file PMeanPMetricTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_MATRICES_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::ElementPMeanP::evaluate_with_Hessian(), and MBMesquite::ElementPMeanP::evaluate_with_Hessian_diagonal().
    MsqError err;
    FauxMetric m;
    // we've already validated the Hessian results in the
    // previous test, so just check that the diagonal terms
    // match the terms for the full Hessian.
    std::vector< size_t > m1_indices_h, m1_indices_d, m2_indices_h, m2_indices_d;
    std::vector< Vector3D > m1_g_h, m1_g_d, m2_g_h, m2_g_d;
    std::vector< Matrix3D > m1_h_h, m2_h_h;
    std::vector< SymMatrix3D > m1_h_d, m2_h_d;
    double m1_v_h, m1_v_d, m2_v_h, m2_v_d;
    m1.evaluate_with_Hessian( pd, 0, m1_v_h, m1_indices_h, m1_g_h, m1_h_h, err );
    ASSERT_NO_ERROR( err );
    m2.evaluate_with_Hessian( pd, 0, m2_v_h, m2_indices_h, m2_g_h, m2_h_h, err );
    m1.evaluate_with_Hessian_diagonal( pd, 0, m1_v_d, m1_indices_d, m1_g_d, m1_h_d, err );
    m2.evaluate_with_Hessian_diagonal( pd, 0, m2_v_d, m2_indices_d, m2_g_d, m2_h_d, err );
    // compare values
    CPPUNIT_ASSERT_DOUBLES_EQUAL( m1_v_h, m1_v_d, 1e-6 );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( m2_v_h, m2_v_d, 1e-6 );
    // Assume indices in same order because
    // it simplifiers later code in test
    CPPUNIT_ASSERT( m1_indices_h == m1_indices_d );
    CPPUNIT_ASSERT( m2_indices_h == m1_indices_d );
    // compare gradient values
    CPPUNIT_ASSERT_EQUAL( m1_indices_h.size(), m1_g_h.size() );
    CPPUNIT_ASSERT_EQUAL( m2_indices_h.size(), m2_g_h.size() );
    CPPUNIT_ASSERT_EQUAL( m1_indices_d.size(), m1_g_d.size() );
    CPPUNIT_ASSERT_EQUAL( m2_indices_d.size(), m2_g_d.size() );
    for( unsigned i = 0; i < m1_indices_h.size(); ++i )
        CPPUNIT_ASSERT_VECTORS_EQUAL( m1_g_h[i], m1_g_d[i], 1e-6 );
        CPPUNIT_ASSERT_VECTORS_EQUAL( m2_g_h[i], m2_g_d[i], 1e-6 );
    // compare hessian diagonal terms
    CPPUNIT_ASSERT_EQUAL( m1_indices_h.size() * ( m1_indices_h.size() + 1 ) / 2, m1_h_h.size() );
    CPPUNIT_ASSERT_EQUAL( m2_indices_h.size() * ( m2_indices_h.size() + 1 ) / 2, m2_h_h.size() );
    CPPUNIT_ASSERT_EQUAL( m1_indices_d.size(), m1_h_d.size() );
    CPPUNIT_ASSERT_EQUAL( m2_indices_d.size(), m2_h_d.size() );
    unsigned h = 0;
    for( unsigned r = 0; r < m1_indices_h.size(); ++r )
        CPPUNIT_ASSERT_MATRICES_EQUAL( m1_h_h[h], m1_h_d[r], 1e-6 );
        CPPUNIT_ASSERT_MATRICES_EQUAL( m2_h_h[h], m2_h_d[r], 1e-6 );
        h += ( m1_indices_h.size() - r );
Definition at line 323 of file PMeanPMetricTest.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::ElementPMeanP::evaluate(), and MBMesquite::ElementQM::evaluate_with_indices().
    MsqError err;
    FauxMetric m;
    double v1, v2;
    std::vector< size_t > indices;
    m2.evaluate_with_indices( pd, 0, v1, indices, err );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( v2, v1, 1e-6 );
    std::sort( vertices.begin(), vertices.end() );
    std::sort( indices.begin(), indices.end() );
    CPPUNIT_ASSERT( vertices == indices );
Definition at line 243 of file PMeanPMetricTest.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::VertexPMeanP::evaluate(), FauxMetric< B >::evaluate(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::ElemSampleQM::handle(), and MBMesquite::MsqMeshEntity::node_count().
    MsqError err;
    FauxMetric m;
    VertexPMeanP m1( 1.0, &m );
    VertexPMeanP m2( 2.0, &m );
    // evaluate average around vertex
    double v1, v2;
    // get elements adjacent to vertex
    size_t num_elem;
    const size_t* elems = pd.get_vertex_element_adjacencies( 0, num_elem, err );
    for( unsigned i = 0; i < num_elem; ++i )
        const MsqMeshEntity& elem = pd.element_by_index( elems[i] );
        const size_t* verts       = elem.get_vertex_index_array();
        const size_t* end         = verts + elem.node_count();
        const size_t* p           = std::find( verts, end, (size_t)0 );
        CPPUNIT_ASSERT( p < end );
        size_t h = ElemSampleQM::handle( Sample( 0, p - verts ), elems[i] );
        double v;
        m.evaluate( pd, h, v, err );
        ev1 += v;
        ev2 += v * v;
    ev1 /= num_elem;
    ev2 /= num_elem;
Member Data Documentation
Definition at line 56 of file PMeanPMetricTest.cpp.
List of all members.
