TagTest.cpp File Reference
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "TestUtil.hpp"
#include <cstdlib>
#include <algorithm>
+ Include dependency graph for TagTest.cpp:
Enumerations
enum  SetMode { NORMAL, POINTER, ONE_VALUE }
Functions
void test_create_tag ()
void test_get_set_sparse_int ()
void test_get_set_dense_int ()
void test_get_set_dense_double ()
void test_get_set_bit ()
void test_get_by_tag ()
void test_get_by_tag_value ()
void test_get_by_tag_value_dense ()
void test_mesh_value ()
void test_get_pointers_sparse ()
void test_get_pointers_dense ()
void test_set_pointers_sparse ()
void test_set_pointers_dense ()
void test_get_entity_tags ()
void test_delete_sparse_tag ()
void test_delete_dense_tag ()
void test_delete_mesh_tag ()
void test_delete_sparse_data ()
void test_delete_dense_data ()
void test_delete_bit_data ()
void test_create_variable_length_tag ()
void test_get_set_variable_length_sparse ()
void test_get_set_variable_length_dense ()
void test_get_set_variable_length_mesh ()
void test_get_ents_with_default_value ()
void test_bit_tag_big ()
void test_clear_dense ()
void test_clear_sparse ()
void test_clear_bit ()
void test_clear_dense_varlen ()
void test_clear_sparse_varlen ()
void test_tag_iterate_sparse ()
void test_tag_iterate_dense ()
void test_tag_iterate_sparse_default ()
void test_tag_iterate_dense_default ()
void test_tag_iterate_invalid ()
void regression_one_entity_by_var_tag ()
void regression_tag_on_nonexistent_entity ()
int main ()
void setup_mesh (Interface &mesh)
Tag test_create_tag (Interface &mb, const char *name, int num_vals, TagType storage, DataType type, const void *defval, ErrorCode expect=MB_SUCCESS)
Tag test_create_var_len_tag (Interface &mb, const char *name, TagType storage, DataType type, const void *defval, int defval_size, ErrorCode expect=MB_SUCCESS)
void test_get_set (const char *name, int vals_per_ent, TagType storage, DataType type, const void *some_values, int num_values, const void *default_value, SetMode set_by_pointer=NORMAL, bool get_by_pointer=false)
void test_get_set_variable_length (const char *name, TagType storage, DataType type, const void **values, const int *lengths, int num_values, const void *default_value, int default_value_length)
void test_mesh_value (Interface &mb, const char *tag_name, unsigned tag_size, TagType tag_storage, DataType tag_type, const void *value)
static void concat_to_list (const void *concat, std::vector< const void * > &list, size_t bytes)
static void test_delete_type_tag (TagType storage)
template<typename Container >
ErrorCode set_bit_data (Interface &mb, Tag tag, const Container &handles, const std::vector< unsigned char > &data)
static bool contains_tag (Tag tag, const std::vector< Tag > &list)
void test_delete_tag_data (TagType storage, bool with_default_value)
void test_clear_variable_length (TagType storage)
void test_tag_iterate_common (TagType storage, bool with_default)
Enumeration Type Documentation
enum SetMode
Enumerator:
NORMAL
POINTER
ONE_VALUE
Definition at line 115 of file TagTest.cpp.
Function Documentation
static void concat_to_list ( const void *  concat,
std::vector< const void * > &  list,
size_t  bytes
) [static]
Definition at line 352 of file TagTest.cpp.
Referenced by test_get_set().
    const unsigned char* ptr                  = reinterpret_cast< const unsigned char* >( concat );
    std::vector< const void* >::iterator iter = list.begin();
    for( ; iter != list.end(); ++iter, ptr += bytes )
        *iter = ptr;
static bool contains_tag ( Tag  tag,
const std::vector< Tag > &  list
) [static]
Definition at line 1185 of file TagTest.cpp.
Referenced by test_get_entity_tags().
    return std::find( list.begin(), list.end(), tag ) != list.end();
int main ( )
Definition at line 49 of file TagTest.cpp.
References regression_one_entity_by_var_tag(), regression_tag_on_nonexistent_entity(), RUN_TEST, test_bit_tag_big(), test_clear_bit(), test_clear_dense(), test_clear_dense_varlen(), test_clear_sparse(), test_clear_sparse_varlen(), test_create_tag(), test_create_variable_length_tag(), test_delete_bit_data(), test_delete_dense_data(), test_delete_dense_tag(), test_delete_mesh_tag(), test_delete_sparse_data(), test_delete_sparse_tag(), test_get_by_tag(), test_get_by_tag_value(), test_get_by_tag_value_dense(), test_get_entity_tags(), test_get_ents_with_default_value(), test_get_pointers_dense(), test_get_pointers_sparse(), test_get_set_bit(), test_get_set_dense_double(), test_get_set_dense_int(), test_get_set_sparse_int(), test_get_set_variable_length_dense(), test_get_set_variable_length_mesh(), test_get_set_variable_length_sparse(), test_mesh_value(), test_set_pointers_dense(), test_set_pointers_sparse(), test_tag_iterate_dense(), test_tag_iterate_dense_default(), test_tag_iterate_invalid(), test_tag_iterate_sparse(), and test_tag_iterate_sparse_default().
    int failures = 0;
    failures += RUN_TEST( test_create_tag );
    failures += RUN_TEST( test_get_set_sparse_int );
    failures += RUN_TEST( test_get_set_dense_int );
    failures += RUN_TEST( test_get_set_dense_double );
    failures += RUN_TEST( test_get_set_bit );
    failures += RUN_TEST( test_get_by_tag );
    failures += RUN_TEST( test_get_by_tag_value );
    failures += RUN_TEST( test_get_by_tag_value_dense );
    failures += RUN_TEST( test_mesh_value );
    failures += RUN_TEST( test_get_pointers_sparse );
    failures += RUN_TEST( test_get_pointers_dense );
    failures += RUN_TEST( test_set_pointers_sparse );
    failures += RUN_TEST( test_set_pointers_dense );
    failures += RUN_TEST( test_get_entity_tags );
    failures += RUN_TEST( test_delete_sparse_tag );
    failures += RUN_TEST( test_delete_dense_tag );
    failures += RUN_TEST( test_delete_mesh_tag );
    failures += RUN_TEST( test_delete_sparse_data );
    failures += RUN_TEST( test_delete_dense_data );
    failures += RUN_TEST( test_delete_bit_data );
    failures += RUN_TEST( test_create_variable_length_tag );
    failures += RUN_TEST( test_get_set_variable_length_sparse );
    failures += RUN_TEST( test_get_set_variable_length_dense );
    failures += RUN_TEST( test_get_set_variable_length_mesh );
    failures += RUN_TEST( test_get_ents_with_default_value );
    failures += RUN_TEST( test_bit_tag_big );
    failures += RUN_TEST( regression_one_entity_by_var_tag );
    failures += RUN_TEST( regression_tag_on_nonexistent_entity );
    failures += RUN_TEST( test_clear_dense );
    failures += RUN_TEST( test_clear_sparse );
    failures += RUN_TEST( test_clear_bit );
    failures += RUN_TEST( test_clear_dense_varlen );
    failures += RUN_TEST( test_clear_sparse_varlen );
    failures += RUN_TEST( test_tag_iterate_sparse );
    failures += RUN_TEST( test_tag_iterate_dense );
    failures += RUN_TEST( test_tag_iterate_sparse_default );
    failures += RUN_TEST( test_tag_iterate_dense_default );
    failures += RUN_TEST( test_tag_iterate_invalid );
    if( failures ) std::cerr << "<<<< " << failures << " TESTS FAILED >>>>" << std::endl;
    return failures;
Definition at line 1934 of file TagTest.cpp.
References CHECK_EQUAL, CHECK_ERR, moab::Core::create_vertex(), ErrorCode, moab::Range::front(), moab::Core::get_entities_by_type_and_tag(), MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_VARLEN, MB_TYPE_INTEGER, MBVERTEX, moab::Range::size(), moab::Core::tag_get_handle(), and moab::Core::tag_set_by_ptr().
Referenced by main().
    Core moab;
    ErrorCode rval;
    EntityHandle vertex;
    const double coords[] = { 0, 0, 0 };
    rval                  = moab.create_vertex( coords, vertex );CHECK_ERR( rval );
    Tag tag;
    rval = moab.tag_get_handle( "testtag", 0, MB_TYPE_INTEGER, tag, MB_TAG_DENSE | MB_TAG_VARLEN | MB_TAG_EXCL );CHECK_ERR( rval );
    int taglen            = 1;
    const void* ptrarr[1] = { &taglen };
    rval                  = moab.tag_set_by_ptr( tag, &vertex, 1, ptrarr, &taglen );CHECK_ERR( rval );
    Range ents;
    rval = moab.get_entities_by_type_and_tag( 0, MBVERTEX, &tag, 0, 1, ents );CHECK_ERR( rval );
    CHECK_EQUAL( (size_t)1, ents.size() );
    CHECK_EQUAL( vertex, ents.front() );
Definition at line 1960 of file TagTest.cpp.
References CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), moab::Core::create_meshset(), ErrorCode, moab::Range::insert(), MB_ENTITY_NOT_FOUND, MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_BIT, MB_TYPE_INTEGER, moab::Core::tag_get_handle(), moab::Core::tag_set_by_ptr(), and moab::Core::tag_set_data().
    Core moab;
    ErrorCode rval;
    const int tagval      = 0xdeadbeef;
    const void* valarr[1] = { &tagval };
    const int numval      = 1;
    // create all three types of tags
    Tag dense, sparse, bit;
    rval = moab.tag_get_handle( "test_dense", 1, MB_TYPE_INTEGER, dense, MB_TAG_DENSE | MB_TAG_EXCL );CHECK_ERR( rval );
    rval = moab.tag_get_handle( "test_sparse", 1, MB_TYPE_INTEGER, sparse, MB_TAG_SPARSE | MB_TAG_EXCL );CHECK_ERR( rval );
    rval = moab.tag_get_handle( "test_bit", 4, MB_TYPE_BIT, bit, MB_TAG_EXCL );CHECK_ERR( rval );
    // for each tag type, check all four mechanisms for setting tag data
    // (fixed and variable length given array or range).
    EntityHandle handle = (EntityHandle)1;
    Range handles;
    handles.insert( handle );
    rval = moab.tag_set_data( dense, &handle, 1, &tagval );
    CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval );
    rval = moab.tag_set_data( sparse, &handle, 1, &tagval );
    rval = moab.tag_set_data( bit, &handle, 1, &tagval );
    rval = moab.tag_set_data( dense, handles, &tagval );
    rval = moab.tag_set_data( sparse, handles, &tagval );
    rval = moab.tag_set_data( bit, handles, &tagval );
    rval = moab.tag_set_by_ptr( dense, &handle, 1, valarr, &numval );
    rval = moab.tag_set_by_ptr( sparse, &handle, 1, valarr, &numval );
    rval = moab.tag_set_by_ptr( dense, handles, valarr, &numval );
    rval = moab.tag_set_by_ptr( sparse, handles, valarr, &numval );
    // now add create an entity and try an adjacent handle
    EntityHandle set;
    rval = moab.create_meshset( 0, set );CHECK_ERR( rval );
    handle = (EntityHandle)( set + 1 );
    handles.clear();
ErrorCode set_bit_data ( Interface mb,
Tag  tag,
const Container &  handles,
const std::vector< unsigned char > &  data
Definition at line 1173 of file TagTest.cpp.
References ErrorCode, MB_SUCCESS, and moab::Interface::tag_set_data().
    ErrorCode rval;
    data.resize( handles.size() );
    std::vector< unsigned char >::const_iterator j = data.begin();
    for( typename Container::const_iterator i = handles.begin(); i != handles.end(); ++i, ++j )
        rval = mb.tag_set_data( tag, &*i, 1, &*j );
        if( MB_SUCCESS != rval ) return rval;
void setup_mesh ( Interface mesh)
Definition at line 1897 of file TagTest.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, conn, moab::Interface::create_element(), moab::Interface::create_vertices(), moab::Interface::delete_entities(), ErrorCode, MBHEX, moab::Range::size(), u, and vertex_coords().
Referenced by test_clear_bit(), test_delete_bit_data(), test_delete_tag_data(), test_delete_type_tag(), test_get_by_tag(), test_get_by_tag_value(), test_get_by_tag_value_dense(), test_get_entity_tags(), test_get_set(), test_get_set_bit(), and test_get_set_variable_length().
    Range vertex_handles;
    const double vertex_coords[] = { 0, 0, 0, 1, 0, 0, 2, 0, 0, 0, 1, 0, 1, 1, 0, 2, 1, 0, 0, 2, 0, 1, 2, 0, 2, 2, 0,
                                     0, 0, 1, 1, 0, 1, 2, 0, 1, 0, 1, 1, 1, 1, 1, 2, 1, 1, 0, 2, 1, 1, 2, 1, 2, 2, 1,
                                     0, 0, 2, 1, 0, 2, 2, 0, 2, 0, 1, 2, 1, 1, 2, 2, 1, 2, 0, 2, 2, 1, 2, 2, 2, 2, 2 };
    const unsigned num_vtx       = sizeof( vertex_coords ) / ( 3 * sizeof( double ) );
    ErrorCode rval               = mb.create_vertices( vertex_coords, num_vtx, vertex_handles );CHECK_ERR( rval );
    CHECK_EQUAL( num_vtx, (unsigned)vertex_handles.size() );
    CHECK_EQUAL( 27u, num_vtx );
    EntityHandle elements[8];
    EntityHandle conn[8][8] = { { 0, 1, 4, 3, 9, 10, 13, 12 },      { 1, 2, 5, 4, 10, 11, 14, 13 },
                                { 3, 4, 7, 6, 12, 13, 16, 15 },     { 4, 5, 8, 7, 13, 14, 17, 16 },
                                { 9, 10, 13, 12, 18, 19, 22, 21 },  { 10, 11, 14, 13, 19, 20, 23, 22 },
                                { 12, 13, 16, 15, 21, 22, 25, 24 }, { 13, 14, 17, 16, 22, 23, 26, 25 } };
    for( unsigned i = 0; i < 8; ++i )
        rval = mb.create_element( MBHEX, conn[i], 8, elements[i] );CHECK_ERR( rval );
    // delete some stuff so there are multiple sequences
    rval = mb.delete_entities( elements + 2, 2 );CHECK_ERR( rval );
    Range::iterator i = vertex_handles.begin();
    i += 16;
    rval = mb.delete_entities( &*i, 1 );CHECK_ERR( rval );
    i += 2;
void test_bit_tag_big ( )
Definition at line 1827 of file TagTest.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, moab::Interface::create_vertices(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_type_and_tag(), moab::Range::insert(), MB_TAG_BIT, MB_TYPE_BIT, MBVERTEX, NUM_VTX, moab::Range::rbegin(), moab::Range::rend(), moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), test_create_tag(), and value().
    Core moab;
    Interface& mb = moab;
    ErrorCode rval;
    const size_t NUM_VTX = 30000;
    // create a lot of vertices
    std::vector< double > coords( 3 * NUM_VTX, 0.0 );
    Range verts;
    rval = mb.create_vertices( &coords[0], NUM_VTX, verts );CHECK_ERR( rval );
    CHECK_EQUAL( NUM_VTX, (size_t)verts.size() );
    // create a bit tag
    Tag tag = test_create_tag( mb, "bb", 4, MB_TAG_BIT, MB_TYPE_BIT, 0 );
    // for each vertex, store last four bits of handle as tag value
    std::vector< unsigned char > values( NUM_VTX );
    std::vector< unsigned char >::iterator it = values.begin();
    for( Range::iterator j = verts.begin(); j != verts.end(); ++j, ++it )
        *it = (unsigned char)( *j & 0xF );
    rval = mb.tag_set_data( tag, verts, &values[0] );CHECK_ERR( rval );
    // retrieve values
    std::vector< unsigned char > values2( NUM_VTX, 0 );
    rval = mb.tag_get_data( tag, verts, &values2[0] );
    CHECK_EQUAL( values, values2 );
    // retrieve individual values
        char value;
        rval = mb.tag_get_data( tag, &*j, 1, &value );CHECK_ERR( rval );
        CHECK_EQUAL( *it, value );
    // retrieve entities
    unsigned char value = 0xC;
    Range expected, results;
    for( Range::reverse_iterator j = verts.rbegin(); j != verts.rend(); ++j )
        if( (unsigned char)( *j & 0xF ) == value ) expected.insert( *j );
    const void* vals[] = { &value };
    rval               = mb.get_entities_by_type_and_tag( 0, MBVERTEX, &tag, vals, 1, results );CHECK_ERR( rval );
    CHECK_EQUAL( expected, results );
    // test singe-bit tag
    Tag tag1 = test_create_tag( mb, "bb1", 1, MB_TAG_BIT, MB_TYPE_BIT, 0 );
    // set tag to 1 on all vertices
    values.clear();
    values.resize( NUM_VTX, '\001' );
    rval = mb.tag_set_data( tag1, verts, &values[0] );CHECK_ERR( rval );
    // retrieve values individually
    for( Range::iterator j = verts.begin(); j != verts.end(); ++j )
        char cvalue;
        rval = mb.tag_get_data( tag1, &*j, 1, &cvalue );CHECK_ERR( rval );
        CHECK_EQUAL( 1, (int)cvalue );
    // clear values individually
        char cvalue = '\0';
        rval        = mb.tag_set_data( tag1, &*j, 1, &cvalue );CHECK_ERR( rval );
    // retrieve values using range
    rval = mb.tag_get_data( tag1, verts, &values[0] );CHECK_ERR( rval );
    size_t first_one = std::find( values.begin(), values.end(), '\001' ) - values.begin();
    CHECK_EQUAL( values.size(), first_one );
void test_clear_bit ( )
Definition at line 808 of file TagTest.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::empty(), moab::Range::end(), entities, ErrorCode, moab::Interface::get_entities_by_handle(), mb, MB_TAG_BIT, MB_TYPE_BIT, setup_mesh(), moab::Interface::tag_clear_data(), moab::Interface::tag_get_data(), and test_create_tag().
    // create mesh and tag
    Core moab;
    setup_mesh( mb );
    Tag tag = test_create_tag( mb, "clear_bit_val", 2, MB_TAG_BIT, MB_TYPE_BIT, 0 );
    // get some handles to work with
    Range entities;
    ErrorCode rval = mb.get_entities_by_handle( 0, entities );CHECK_ERR( rval );
    CHECK( !entities.empty() );
    const unsigned char bits = 2;
    rval                     = mb.tag_clear_data( tag, entities, &bits );CHECK_ERR( rval );
    // set bits on every entity
    for( Range::iterator i = entities.begin(); i != entities.end(); ++i )
        unsigned char bits_out = 0;
        rval                   = mb.tag_get_data( tag, &*i, 1, &bits_out );
        CHECK_EQUAL( bits, bits_out );
void test_clear_dense ( )
Definition at line 734 of file TagTest.cpp.
References MB_TAG_DENSE, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, ONE_VALUE, and test_get_set().
    const int int_val = 0xcab;
    test_get_set( "clear_dense_int", 1, MB_TAG_DENSE, MB_TYPE_INTEGER, &int_val, 1, 0, ONE_VALUE, false );
    const double dbl_val[]     = { 3.14159, -3.14159 };
    const double default_val[] = { -2, 5 };
    test_get_set( "clear_dense_double", 2, MB_TAG_DENSE, MB_TYPE_DOUBLE, &dbl_val, 1, default_val, ONE_VALUE, false );
Definition at line 1746 of file TagTest.cpp.
References MB_TAG_DENSE, and test_clear_variable_length().
Definition at line 744 of file TagTest.cpp.
References MB_TAG_SPARSE, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, ONE_VALUE, and test_get_set().
    test_get_set( "clear_sparse_int", 1, MB_TAG_SPARSE, MB_TYPE_INTEGER, &int_val, 1, 0, ONE_VALUE, false );
    test_get_set( "clear_sparse_double", 2, MB_TAG_SPARSE, MB_TYPE_DOUBLE, &dbl_val, 1, default_val, ONE_VALUE, false );
Definition at line 1741 of file TagTest.cpp.
References MB_TAG_SPARSE, and test_clear_variable_length().
Definition at line 1726 of file TagTest.cpp.
References doubles, ints, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, and test_get_set_variable_length().
Referenced by test_clear_dense_varlen(), and test_clear_sparse_varlen().
    const double doubles[3] = { 1e-1, 1e-2, 1e-3 };
    const void* dvals[]     = { doubles };
    const int dlen          = sizeof( doubles ) / sizeof( double );
    test_get_set_variable_length( "vnodef_clear", storage, MB_TYPE_DOUBLE, dvals, &dlen, 1, 0, 0 );
    const int ints[32]  = { 1,  2,  3,  4,  5,  6,  7,  8,  9,  10,  11,  12,  13,  14,  15,
                           -1, -2, -3, -4, -5, -6, -7, -8, -9, -10, -11, -12, -13, -14, -15 };
    const void* ivals[] = { ints };
    const int ilen      = sizeof( ints ) / sizeof( int );
    const int defvals[] = { 42, 5, 8, 74 };
    test_get_set_variable_length( "vdef_clear", storage, MB_TYPE_INTEGER, ivals, &ilen, 1, defvals, 4 );
void test_create_tag ( )
Definition at line 297 of file TagTest.cpp.
References mb, MB_TAG_BIT, MB_TAG_DENSE, MB_TAG_SPARSE, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, and MB_TYPE_OPAQUE.
Referenced by main(), test_bit_tag_big(), test_clear_bit(), test_delete_bit_data(), test_delete_tag_data(), test_delete_type_tag(), test_get_by_tag(), test_get_by_tag_value(), test_get_by_tag_value_dense(), test_get_entity_tags(), test_get_ents_with_default_value(), test_get_set(), test_get_set_bit(), and test_mesh_value().
    Core mb;
    unsigned char defval[] = { 1, 2, 3, 4, 0, 0, 0, 0 };
    // opaque tags
    test_create_tag( mb, "opaque_tag_sparse", 8, MB_TAG_SPARSE, MB_TYPE_OPAQUE, defval );
    test_create_tag( mb, "opaque_tag_dense", 4, MB_TAG_DENSE, MB_TYPE_OPAQUE, defval );
    test_create_tag( mb, "opaque_tag_dense2", 1, MB_TAG_DENSE, MB_TYPE_OPAQUE, 0 );
    // integer tags
    test_create_tag( mb, "int_tag_sparse", 1, MB_TAG_SPARSE, MB_TYPE_INTEGER, defval );
    test_create_tag( mb, "int_tag_dense", 8, MB_TAG_DENSE, MB_TYPE_INTEGER, 0 );
    // double tags
    double defval2[] = { 3.14159, 2.71828 };
    test_create_tag( mb, "dbl_tag_sparse", 1, MB_TAG_SPARSE, MB_TYPE_DOUBLE, 0 );
    test_create_tag( mb, "dbl_tag_dense", 2, MB_TAG_DENSE, MB_TYPE_DOUBLE, defval2 );
    // handle tags
    test_create_tag( mb, "h_tag_dense", 1, MB_TAG_DENSE, MB_TYPE_HANDLE, defval );
    // bit tags
    unsigned char def_bit_val = 0xBF;
    test_create_tag( mb, "bit_tag_1", 2, MB_TAG_BIT, MB_TYPE_BIT, &def_bit_val );
Tag test_create_tag ( Interface mb,
const char *  name,
int  num_vals,
TagType  storage,
DataType  type,
const void *  defval,
ErrorCode  expect = MB_SUCCESS
Definition at line 148 of file TagTest.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, ErrorCode, MB_ALREADY_ALLOCATED, MB_ENTITY_NOT_FOUND, MB_SUCCESS, MB_TAG_EXCL, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, n, t, moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_name(), moab::Interface::tag_get_type(), and TagType.
    ErrorCode rval;
    Tag tag;
    rval = mb.tag_get_handle( name, num_vals, type, tag, storage | MB_TAG_EXCL, defval );
    if( expect != MB_SUCCESS )
        CHECK_EQUAL( expect, rval );
        return 0;
    CHECK_ERR( rval );
    std::string n;
    rval = mb.tag_get_name( tag, n );CHECK_ERR( rval );
    CHECK( n == name );
    Tag tag2;
    rval = mb.tag_get_handle( name, num_vals, type, tag2 );CHECK_ERR( rval );
    CHECK_EQUAL( tag, tag2 );
    int s;
    rval = mb.tag_get_length( tag, s );CHECK_ERR( rval );
    CHECK_EQUAL( num_vals, s );
    TagType t;
    rval = mb.tag_get_type( tag, t );CHECK_ERR( rval );
    CHECK_EQUAL( storage, t );
    DataType d;
    rval = mb.tag_get_data_type( tag, d );CHECK_ERR( rval );
    CHECK_EQUAL( type, d );
    int bytes;
    rval = mb.tag_get_bytes( tag, bytes );CHECK_ERR( rval );
    int exp_bytes = 0;
    switch( type )
        case MB_TYPE_INTEGER:
            exp_bytes = num_vals * sizeof( int );
            break;
        case MB_TYPE_DOUBLE:
            exp_bytes = num_vals * sizeof( double );
            break;
        case MB_TYPE_HANDLE:
            exp_bytes = num_vals * sizeof( EntityHandle );
            break;
        case MB_TYPE_BIT:
            exp_bytes = 1;
            break;
        case MB_TYPE_OPAQUE:
            exp_bytes = num_vals;
            break;
    CHECK_EQUAL( exp_bytes, bytes );
    std::vector< unsigned char > defv( bytes );
    rval = mb.tag_get_default_value( tag, &defv[0] );
    if( defval )
        CHECK_ERR( rval );
        CHECK( !memcmp( defval, &defv[0], bytes ) );
    else
    // make sure we can't create a second tag w/ the same name
    rval = mb.tag_get_handle( name, num_vals, type, tag2, storage | MB_TAG_EXCL, defval );
    CHECK_EQUAL( MB_ALREADY_ALLOCATED, rval );
    // we should get back the handle of the existing tag
    return tag;
Tag test_create_var_len_tag ( Interface mb,
const char *  name,
TagType  storage,
DataType  type,
int  defval_size,
Definition at line 231 of file TagTest.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, ErrorCode, MB_ALREADY_ALLOCATED, MB_ENTITY_NOT_FOUND, MB_SUCCESS, MB_TAG_EXCL, MB_TAG_VARLEN, MB_VARIABLE_DATA_LENGTH, n, size, t, moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_name(), moab::Interface::tag_get_type(), and TagType.
Referenced by test_create_variable_length_tag(), test_get_set_variable_length(), and test_get_set_variable_length_mesh().
    ErrorCode rval;
    Tag tag;
    rval = mb.tag_get_handle( name, defval_size, type, tag, storage | MB_TAG_VARLEN | MB_TAG_EXCL, defval );
        return 0;
    CHECK_ERR( rval );
    std::string n;
    CHECK( n == name );
    Tag tag2;
    rval = mb.tag_get_handle( name, 0, type, tag2 );CHECK_ERR( rval );
    int s;
    rval = mb.tag_get_bytes( tag, s );
    CHECK_EQUAL( MB_VARIABLE_DATA_LENGTH, rval );
    // CHECK_ERR(rval);
    // CHECK_EQUAL( MB_VARIABLE_LENGTH, s );
    TagType t;
    DataType d;
    int size;
    const void* defv;
    rval = mb.tag_get_default_value( tag, defv, size );
    if( defval )
        CHECK_ERR( rval );
        CHECK_EQUAL( defval_size, size );
        CHECK( !memcmp( defval, defv, size ) );
    else
    rval = mb.tag_get_handle( name, defval_size, type, tag2, storage | MB_TAG_VARLEN | MB_TAG_EXCL );
    return tag;
Definition at line 324 of file TagTest.cpp.
References mb, MB_TAG_DENSE, MB_TAG_SPARSE, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, and test_create_var_len_tag().
    Core mb;
    // opaque tags
    const void* defptr = defval;
    test_create_var_len_tag( mb, "opaque_tag_sparse", MB_TAG_SPARSE, MB_TYPE_OPAQUE, defptr, 8 );
    test_create_var_len_tag( mb, "opaque_tag_dense", MB_TAG_DENSE, MB_TYPE_OPAQUE, defptr, 4 );
    test_create_var_len_tag( mb, "opaque_tag_dense2", MB_TAG_DENSE, MB_TYPE_OPAQUE, 0, 0 );
    // integer tags
    test_create_var_len_tag( mb, "int_tag_sparse", MB_TAG_SPARSE, MB_TYPE_INTEGER, defptr, 1 );
    test_create_var_len_tag( mb, "int_tag_dense", MB_TAG_DENSE, MB_TYPE_INTEGER, 0, 0 );
    // double tags
    defptr           = defval2;
    test_create_var_len_tag( mb, "dbl_tag_sparse", MB_TAG_SPARSE, MB_TYPE_DOUBLE, 0, 0 );
    test_create_var_len_tag( mb, "dbl_tag_dense", MB_TAG_DENSE, MB_TYPE_DOUBLE, defptr, 2 );
    // handle tags
    test_create_var_len_tag( mb, "h_tag_dense", MB_TAG_DENSE, MB_TYPE_HANDLE, 0, 0 );
Definition at line 1405 of file TagTest.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::empty(), entities, ErrorCode, moab::Range::front(), moab::Interface::get_entities_by_handle(), MB_SUCCESS, MB_TAG_BIT, MB_TAG_NOT_FOUND, MB_TYPE_BIT, setup_mesh(), moab::Interface::tag_delete_data(), moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), and test_create_tag().
    Core moab;
    ErrorCode rval;
    // get an entity to set data on
    setup_mesh( mb );
    Range entities;
    EntityHandle handle = entities.front();
    // create two tags, one with a default value and one without
    unsigned char defval = '\006';  // 110
    Tag tag1, tag2;
    tag1 = test_create_tag( mb, "tag1", 2, MB_TAG_BIT, MB_TYPE_BIT, 0 );
    tag2 = test_create_tag( mb, "tag2", 3, MB_TAG_BIT, MB_TYPE_BIT, &defval );
    // set value for each tag
    unsigned char val = '\001';
    rval              = mb.tag_set_data( tag1, &handle, 1, &val );CHECK_ERR( rval );
    rval = mb.tag_set_data( tag2, &handle, 1, &val );CHECK_ERR( rval );
    // delete both tag values
    rval = mb.tag_delete_data( tag1, &handle, 1 );CHECK_ERR( rval );
    rval = mb.tag_delete_data( tag2, &handle, 1 );CHECK_ERR( rval );
    // try to get value for tag w/out default.
    // should get back either not found, or a zero value.
    val  = 0xFF;
    rval = mb.tag_get_data( tag1, &handle, 1, &val );
    if( MB_SUCCESS == rval )
        CHECK_EQUAL( val, '\0' );
    else
        CHECK_EQUAL( MB_TAG_NOT_FOUND, rval );
    // test that we get back default value for second tag
    val  = 0xFF;
    rval = mb.tag_get_data( tag2, &handle, 1, &val );CHECK_ERR( rval );
    CHECK_EQUAL( defval, val );
Definition at line 1399 of file TagTest.cpp.
References MB_TAG_SPARSE, and test_delete_tag_data().
Definition at line 1286 of file TagTest.cpp.
References MB_TAG_DENSE, and test_delete_type_tag().
Definition at line 1291 of file TagTest.cpp.
References MB_TAG_MESH, and test_delete_type_tag().
Definition at line 1393 of file TagTest.cpp.
References MB_TAG_DENSE, and test_delete_tag_data().
Definition at line 1281 of file TagTest.cpp.
References MB_TAG_SPARSE, and test_delete_type_tag().
void test_delete_tag_data ( TagType  storage,
Definition at line 1296 of file TagTest.cpp.
References moab::Range::begin(), CHECK, CHECK_ERR, moab::Range::end(), ErrorCode, moab::GeomUtil::first(), moab::Range::front(), moab::Interface::get_entities_by_handle(), moab::Range::insert(), MB_TAG_NOT_FOUND, MB_TAG_SPARSE, MB_TYPE_HANDLE, setup_mesh(), moab::Range::size(), moab::Interface::tag_delete_data(), moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), tagname, and test_create_tag().
Referenced by test_delete_dense_data(), and test_delete_sparse_data().
    Core moab;
    ErrorCode rval;
    setup_mesh( mb );
    // subdivide entity handles into three groups:
    // 1) entities for which the tag data will be deleted using the array-based function
    // 2) entities for which the tag data will be deleted using the range-based function
    // 3) entities for which the tag data will not be deleted
    Range all_entities, del1_range, keep_range;
    std::vector< EntityHandle > del1_list, del2_list, keep_list;
    rval = mb.get_entities_by_handle( 0, all_entities );CHECK_ERR( rval );
    int c = 0;
    for( Range::iterator i = all_entities.begin(); i != all_entities.end(); ++i, ++c )
        switch( c % 3 )
            case 0:
                del1_range.insert( *i );
                break;
            case 1:
                keep_range.insert( *i );
                break;
            case 2:
                del2_list.push_back( *i );
                break;
    del1_list.resize( del1_range.size() );
    std::copy( del1_range.begin(), del1_range.end(), del1_list.begin() );
    keep_list.resize( keep_range.size() );
    std::copy( keep_range.begin(), keep_range.end(), keep_list.begin() );
    // create tag
    EntityHandle first   = all_entities.front();
    EntityHandle* defval = with_default_value ? &first : 0;
    const char* tagname  = "dead_tag";
    Tag tag              = test_create_tag( mb, tagname, 1, storage, MB_TYPE_HANDLE, defval );
    // set value for each entity to its handle
    rval = mb.tag_set_data( tag, del1_range, &del1_list[0] );CHECK_ERR( rval );
    rval = mb.tag_set_data( tag, keep_range, &keep_list[0] );CHECK_ERR( rval );
    rval = mb.tag_set_data( tag, &del2_list[0], del2_list.size(), &del2_list[0] );CHECK_ERR( rval );
    // delete tag data
    rval = mb.tag_delete_data( tag, del1_range );CHECK_ERR( rval );
    rval = mb.tag_delete_data( tag, &del2_list[0], del2_list.size() );CHECK_ERR( rval );
    // test that keep list is unaffected
    std::vector< EntityHandle > tag_data( keep_range.size(), 0 );
    rval = mb.tag_get_data( tag, keep_range, &tag_data[0] );CHECK_ERR( rval );
    CHECK( tag_data == keep_list );
    // try to get data for deleted range
    tag_data.clear();
    tag_data.resize( del1_range.size(), (EntityHandle)-1 );
    rval = mb.tag_get_data( tag, del1_range, &tag_data[0] );
    // if we have a default value, should get that for deleted entities
    if( with_default_value )
        CHECK_ERR( rval );
        std::vector< EntityHandle > expected( del1_range.size(), *defval );
        CHECK( expected == tag_data );
    else if( rval != MB_TAG_NOT_FOUND )
        // dense and bit tags might return either MB_TAG_NOT_FOUND or zero bytes.
        // sparse tags should always return MB_TAG_NOT_FOUND
        CHECK( MB_TAG_SPARSE != storage );
        std::vector< EntityHandle > expected( del1_range.size(), 0 );
    // try to get data for deleted list
    tag_data.clear();
        CHECK_ERR( rval );
static void test_delete_type_tag ( TagType  storage) [static]
Definition at line 1101 of file TagTest.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::empty(), ErrorCode, moab::Range::front(), moab::Interface::get_entities_by_type(), MB_TAG_MESH, MB_TAG_NOT_FOUND, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, MBVERTEX, mesh, setup_mesh(), size, moab::Interface::tag_delete(), moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_name(), moab::Interface::tag_get_tags(), moab::Interface::tag_get_tags_on_entity(), moab::Interface::tag_set_data(), tagname, test_create_tag(), and value().
Referenced by test_delete_dense_tag(), test_delete_mesh_tag(), and test_delete_sparse_tag().
    Core moab;
    ErrorCode rval;
    setup_mesh( mb );
    // create tag
    int default_val     = 42;
    Tag tag             = test_create_tag( mb, tagname, 1, storage, MB_TYPE_INTEGER, &default_val );
    // get an entity handle to work with
    Range verts;
    rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval );
    CHECK( !verts.empty() );
    EntityHandle handle = verts.front();
    // set tag value on entity
    int value = -5;
    if( storage != MB_TAG_MESH )
        rval = mb.tag_set_data( tag, &handle, 1, &value );CHECK_ERR( rval );
    // set tag value on mesh
    const EntityHandle mesh = 0;
    value                   = 2;
    rval                    = mb.tag_set_data( tag, &mesh, 1, &value );CHECK_ERR( rval );
    // delete tag
    rval = mb.tag_delete( tag );CHECK_ERR( rval );
    // make sure all basic queries fail with MB_TAG_NOT_FOUND
    std::string name;
    rval = mb.tag_get_name( tag, name );
    Tag tag2;
    rval = mb.tag_get_handle( tagname, 1, MB_TYPE_INTEGER, tag2 );
    int size;
    rval = mb.tag_get_bytes( tag, size );
    rval = mb.tag_get_length( tag, size );
    // get get the type from the handle, so this still succeeds
    // TagType storage2;
    // rval = mb.tag_get_type( tag, storage2 );
    // CHECK_EQUAL( MB_TAG_NOT_FOUND, rval );
    DataType type;
    rval = mb.tag_get_data_type( tag, type );
    rval = mb.tag_get_default_value( tag, &value );
    // check global list of tags
    std::vector< Tag > tags;
    rval = mb.tag_get_tags( tags );CHECK_ERR( rval );
    CHECK( std::find( tags.begin(), tags.end(), tag ) == tags.end() );
    // check tags on entity
    tags.clear();
    rval = mb.tag_get_tags_on_entity( handle, tags );CHECK_ERR( rval );
    // check that a new tag w/ the same name can be created
    tag  = test_create_tag( mb, tagname, 1, storage, MB_TYPE_DOUBLE, 0 );
void test_get_by_tag ( )
Definition at line 833 of file TagTest.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), moab::Interface::create_meshset(), moab::Range::empty(), entities, ErrorCode, moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_number_entities_by_type_and_tag(), mb, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBVERTEX, setup_mesh(), moab::Range::size(), moab::Interface::tag_set_data(), test_create_tag(), and u.
    Core moab;
    setup_mesh( mb );
    Tag tag = test_create_tag( mb, "sparse_count", 1, MB_TAG_SPARSE, MB_TYPE_INTEGER, 0 );
    Range entities;
    ErrorCode rval = mb.get_entities_by_type( 0, MBVERTEX, entities );CHECK_ERR( rval );
    // get five handles
    CHECK( entities.size() > 6 );
    EntityHandle arr[5] = { *( entities.begin() += entities.size() / 6 ),
                            *( entities.begin() += 2 * entities.size() / 6 ),
                            *( entities.begin() += 3 * entities.size() / 6 ),
                            *( entities.begin() += 4 * entities.size() / 6 ),
                            *( entities.begin() += 5 * entities.size() / 6 ) };
    int values[5]       = { 1, 2, 3, 4, 5 };
    rval                = mb.tag_set_data( tag, arr, 5, values );CHECK_ERR( rval );
    const void* const valarr[1] = { 0 };
    // put some in a mesh set
    EntityHandle set;
    const int num_in_set = 3;
    rval                 = mb.create_meshset( 0, set );CHECK_ERR( rval );
    rval = mb.add_entities( set, arr, num_in_set );CHECK_ERR( rval );
    // try for whole mesh will null tag value array
    int count = -1;
    rval      = mb.get_number_entities_by_type_and_tag( 0, MBVERTEX, &tag, 0, 1, count );CHECK_ERR( rval );
    CHECK_EQUAL( 5, count );
    // try for whole mesh will null tag value, but non-null array
    count = -1;
    rval  = mb.get_number_entities_by_type_and_tag( 0, MBVERTEX, &tag, valarr, 1, count );CHECK_ERR( rval );
    // try for mesh set
    rval = mb.get_number_entities_by_type_and_tag( set, MBVERTEX, &tag, 0, 1, count );CHECK_ERR( rval );
    CHECK_EQUAL( num_in_set, count );
    Range found;
    rval = mb.get_entities_by_type_and_tag( 0, MBVERTEX, &tag, 0, 1, found );CHECK_ERR( rval );
    CHECK_EQUAL( 5u, (unsigned)found.size() );
    Range::iterator i = found.begin();
    CHECK_EQUAL( arr[0], *i );
    ++i;
    CHECK_EQUAL( arr[1], *i );
    ++i;
    CHECK_EQUAL( arr[2], *i );
    ++i;
    CHECK_EQUAL( arr[3], *i );
    ++i;
    CHECK_EQUAL( arr[4], *i );
    found.clear();
    rval = mb.get_entities_by_type_and_tag( 0, MBVERTEX, &tag, valarr, 1, found );CHECK_ERR( rval );
    i = found.begin();
    ++i;
    ++i;
    ++i;
    ++i;
    // try for mesh set
    found.clear();
    rval = mb.get_entities_by_type_and_tag( set, MBVERTEX, &tag, 0, 1, found );CHECK_ERR( rval );
    CHECK_EQUAL( 3u, (unsigned)found.size() );
    i = found.begin();
    ++i;
    ++i;
Definition at line 919 of file TagTest.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), moab::Interface::create_meshset(), moab::Range::empty(), entities, ErrorCode, moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_number_entities_by_type_and_tag(), MB_TAG_SPARSE, MB_TYPE_INTEGER, MBVERTEX, setup_mesh(), moab::Range::size(), moab::Interface::tag_set_data(), test_create_tag(), and u.
    Core moab;
    setup_mesh( mb );
    Range entities;
    // get five handles
    int values[5]       = { 0xBEEF, 0xBEEF, 0xBEEF, 0xBEEF, 0xBEEF };
    const void* const valarr[1] = { values };
    EntityHandle set;
    int count = -1;
    // try for mesh set
    rval = mb.get_number_entities_by_type_and_tag( set, MBVERTEX, &tag, valarr, 1, count );CHECK_ERR( rval );
    Range found;
    ++i;
    ++i;
    ++i;
    ++i;
    CHECK_EQUAL( arr[4], *i );  //++i;
    // try for mesh set
    found.clear();
    rval = mb.get_entities_by_type_and_tag( set, MBVERTEX, &tag, valarr, 1, found );CHECK_ERR( rval );
    i = found.begin();
    ++i;
    ++i;
    CHECK_EQUAL( arr[2], *i );  //++i;
Definition at line 985 of file TagTest.cpp.
References moab::Range::back(), moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), moab::Range::empty(), moab::Range::erase(), ErrorCode, moab::Range::front(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::INTERSECT, MB_TAG_DENSE, MB_TYPE_INTEGER, MBHEX, MBVERTEX, setup_mesh(), moab::Range::size(), moab::Interface::tag_clear_data(), moab::Interface::tag_set_data(), and test_create_tag().
    ErrorCode rval;
    Core moab;
    setup_mesh( mb );
    const int def_val  = 0xABCD;
    const int fill_val = 0xBEEF;
    const int find_val = 0xFEED;
    Tag tag            = test_create_tag( mb, "dense_gbv", 1, MB_TAG_DENSE, MB_TYPE_INTEGER, &def_val );
    Range elements, vertices, results;
    rval = mb.get_entities_by_type( 0, MBHEX, elements );CHECK_ERR( rval );
    rval = mb.get_entities_by_type( 0, MBVERTEX, vertices );CHECK_ERR( rval );
    CHECK( !elements.empty() );
    // set tag on all vertices to fill_val
    rval = mb.tag_clear_data( tag, vertices, &fill_val );CHECK_ERR( rval );
    // select three handles
    CHECK( elements.size() > 4 );
    EntityHandle arr[3] = { *( elements.begin() += elements.size() / 4 ),
                            *( elements.begin() += 2 * elements.size() / 4 ),
                            *( elements.begin() += 3 * elements.size() / 4 ) };
    int values[3]       = { find_val, find_val, find_val };
    rval                = mb.tag_set_data( tag, arr, 3, values );CHECK_ERR( rval );
    // get the entities tagged with 'find_val'
    const void* const findarr[1] = { &find_val };
    results.clear();
    rval = mb.get_entities_by_type_and_tag( 0, MBHEX, &tag, findarr, 1, results );CHECK_ERR( rval );
    CHECK_EQUAL( (size_t)3, results.size() );
    CHECK_EQUAL( arr[0], results.front() );
    CHECK_EQUAL( arr[1], *++results.begin() );
    CHECK_EQUAL( arr[2], results.back() );
    // should get no vertices
    results.clear();
    rval = mb.get_entities_by_type_and_tag( 0, MBVERTEX, &tag, findarr, 1, results );CHECK_ERR( rval );
    CHECK( results.empty() );
    // try intersecting with an existing range
    results = elements;
    results.erase( arr[1] );
    results.insert( vertices.front() );
    rval = mb.get_entities_by_type_and_tag( 0, MBHEX, &tag, findarr, 1, results, Interface::INTERSECT );CHECK_ERR( rval );
    CHECK_EQUAL( (size_t)2, results.size() );
    // try getting entities with default value
    const void* const defarr[1] = { &def_val };
    results.clear();
    rval = mb.get_entities_by_type_and_tag( 0, MBHEX, &tag, defarr, 1, results );CHECK_ERR( rval );
    CHECK_EQUAL( elements.size() - 3, results.size() );
    Range expected( elements );
    expected.erase( arr[0] );
    expected.erase( arr[1] );
    expected.erase( arr[2] );
    CHECK( expected == results );
Definition at line 1190 of file TagTest.cpp.
References moab::Range::begin(), CHECK, CHECK_ERR, contains_tag(), entities, ErrorCode, moab::Interface::get_entities_by_handle(), MB_TAG_BIT, MB_TAG_DENSE, MB_TAG_SPARSE, MB_TYPE_BIT, MB_TYPE_INTEGER, setup_mesh(), moab::Range::size(), moab::Interface::tag_get_tags_on_entity(), moab::Interface::tag_set_data(), and test_create_tag().
    Core moab;
    ErrorCode rval;
    // get 8 handles to work with
    setup_mesh( mb );
    Range entities;
    CHECK( entities.size() >= 8 );
    EntityHandle sparse_ent = *i;
    ++i;
    EntityHandle dense_ent = *i;
    ++i;
    EntityHandle bit_ent = *i;
    ++i;
    EntityHandle sparse_dense_ent = *i;
    ++i;
    EntityHandle sparse_bit_ent = *i;
    ++i;
    EntityHandle dense_bit_ent = *i;
    ++i;
    EntityHandle all_tag_ent = *i;
    ++i;
    EntityHandle no_tag_ent = *i;
    ++i;
    // create three tags to work with
    Tag sparse, dense, bit;
    sparse = test_create_tag( mb, "sparse", 1, MB_TAG_SPARSE, MB_TYPE_INTEGER, 0 );
    dense  = test_create_tag( mb, "dense_", 1, MB_TAG_DENSE, MB_TYPE_INTEGER, 0 );
    bit    = test_create_tag( mb, "bit___", 1, MB_TAG_BIT, MB_TYPE_BIT, 0 );
    // set tags on handles
    EntityHandle sparse_ents[4] = { sparse_ent, sparse_dense_ent, sparse_bit_ent, all_tag_ent };
    EntityHandle dense_ents[4]  = { dense_ent, sparse_dense_ent, dense_bit_ent, all_tag_ent };
    EntityHandle bit_ents[4]    = { bit_ent, sparse_bit_ent, dense_bit_ent, all_tag_ent };
    int values[4]               = { -1, -2, -3, -4 };
    rval                        = mb.tag_set_data( sparse, sparse_ents, 4, &values );CHECK_ERR( rval );
    rval = mb.tag_set_data( dense, dense_ents, 4, &values );CHECK_ERR( rval );
    for( int j = 0; j < 4; ++j )
        unsigned char bitval = 0xF;
        rval                 = mb.tag_set_data( bit, bit_ents + j, 1, &bitval );CHECK_ERR( rval );
    // get tags on each entity
    std::vector< Tag > sparse_ent_tags, dense_ent_tags, bit_ent_tags, sparse_dense_ent_tags, sparse_bit_ent_tags,
        dense_bit_ent_tags, all_tag_ent_tags, no_tag_ent_tags;
    rval = mb.tag_get_tags_on_entity( sparse_ent, sparse_ent_tags );CHECK_ERR( rval );
    rval = mb.tag_get_tags_on_entity( dense_ent, dense_ent_tags );CHECK_ERR( rval );
    rval = mb.tag_get_tags_on_entity( bit_ent, bit_ent_tags );CHECK_ERR( rval );
    rval = mb.tag_get_tags_on_entity( sparse_dense_ent, sparse_dense_ent_tags );CHECK_ERR( rval );
    rval = mb.tag_get_tags_on_entity( sparse_bit_ent, sparse_bit_ent_tags );CHECK_ERR( rval );
    rval = mb.tag_get_tags_on_entity( dense_bit_ent, dense_bit_ent_tags );CHECK_ERR( rval );
    rval = mb.tag_get_tags_on_entity( all_tag_ent, all_tag_ent_tags );CHECK_ERR( rval );
    rval = mb.tag_get_tags_on_entity( no_tag_ent, no_tag_ent_tags );CHECK_ERR( rval );
    // check expected values
    // NOTE:  could potentially get back bit and dense tags for any entity
    //        depending on the storage layout.  Only sparse tags guarantee
    //        no false positives.  False negatives should never happen for any type.
    //        Also, there could be other dense tags already defined.
    // verify sparse tag in all expected lists
    CHECK( contains_tag( sparse, sparse_ent_tags ) );
    CHECK( contains_tag( sparse, sparse_dense_ent_tags ) );
    CHECK( contains_tag( sparse, sparse_bit_ent_tags ) );
    CHECK( contains_tag( sparse, all_tag_ent_tags ) );
    // verify sparse tag not in any other lists
    CHECK( !contains_tag( sparse, dense_ent_tags ) );
    CHECK( !contains_tag( sparse, bit_ent_tags ) );
    CHECK( !contains_tag( sparse, dense_bit_ent_tags ) );
    CHECK( !contains_tag( sparse, no_tag_ent_tags ) );
    // verify dense tag in all expected lists
    CHECK( contains_tag( dense, dense_ent_tags ) );
    CHECK( contains_tag( dense, sparse_dense_ent_tags ) );
    CHECK( contains_tag( dense, dense_bit_ent_tags ) );
    CHECK( contains_tag( dense, all_tag_ent_tags ) );
    // verify bit tag in all expected lists
    CHECK( contains_tag( bit, bit_ent_tags ) );
    CHECK( contains_tag( bit, sparse_bit_ent_tags ) );
    CHECK( contains_tag( bit, dense_bit_ent_tags ) );
    CHECK( contains_tag( bit, all_tag_ent_tags ) );
Definition at line 1751 of file TagTest.cpp.
References moab::Range::back(), moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), moab::Interface::create_element(), moab::Interface::create_vertices(), moab::Range::end(), ErrorCode, moab::Range::front(), moab::Interface::get_entities_by_type_and_tag(), moab::Range::insert(), moab::Interface::INTERSECT, MB_TAG_DENSE, MB_TAG_SPARSE, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, MBEDGE, MBVERTEX, size, moab::Range::size(), moab::subtract(), moab::Interface::tag_set_data(), test_create_tag(), and moab::Interface::UNION.
    Core moab;
    ErrorCode rval;
    Range result;
    // create a bunch of vertices
    std::vector< double > coords( 90, 0.0 );
    Range verts;
    rval = mb.create_vertices( &coords[0], coords.size() / 3, verts );CHECK_ERR( rval );
    CHECK_EQUAL( coords.size() / 3, (size_t)verts.size() );
    // create one edge, which we should never get back from
    // our queries with type == MBVERTEX
    EntityHandle edge, ends[] = { verts.front(), verts.back() };
    rval = mb.create_element( MBEDGE, ends, 2, edge );CHECK_ERR( rval );
    // split vertices into four groups
    Range sets[4];
    size_t s = 0;
    for( Range::iterator i = verts.begin(); i != verts.end(); ++i )
        sets[s].insert( *i );
        s = ( s + 1 ) % 4;
    // create a sparse tag and set some verts to non-default value
    int default_sparse = 5;
    Tag tag_sparse     = test_create_tag( mb, "int", 1, MB_TAG_SPARSE, MB_TYPE_INTEGER, &default_sparse );
    std::vector< int > sparse_vals( sets[0].size(), -1 );
    rval = mb.tag_set_data( tag_sparse, sets[0], &sparse_vals[0] );CHECK_ERR( rval );
    // get all entities with default value for sparse tag
    result.clear();
    const void* ptrs[] = { &default_sparse };
    rval               = mb.get_entities_by_type_and_tag( 0, MBVERTEX, &tag_sparse, ptrs, 1, result );CHECK_ERR( rval );
    CHECK_EQUAL( subtract( verts, sets[0] ), result );
    // create a dense tag and set some verts to non-default value
    double default_dense = -1.0;
    Tag tag_dense        = test_create_tag( mb, "double", 1, MB_TAG_DENSE, MB_TYPE_DOUBLE, &default_dense );
    std::vector< double > dense_vals( sets[1].size(), 3.14159 );
    rval = mb.tag_set_data( tag_dense, sets[1], &dense_vals[0] );CHECK_ERR( rval );
    // get all entities with default value for dense tag
    result.clear();
    ptrs[0] = &default_dense;
    rval    = mb.get_entities_by_type_and_tag( 0, MBVERTEX, &tag_dense, ptrs, 1, result );CHECK_ERR( rval );
    CHECK_EQUAL( subtract( verts, sets[1] ), result );
    // create a variable-length tag and set some verts to non-default value
    // SKIP THIS: NO API FOR QUERYING ENTITIES WITH VARIABLE-LENGTH VALUE
    // int default_vlen[] = { 1, 2, 3 };
    // Tag tag_vlen = test_create_var_len_tag( mb, "vlen", MB_TAG_SPARSE, MB_TYPE_INTEGER,
    // default_vlen, sizeof(default_vlen) ); int other_vlen[] = { 4, 5, 6, 7 }; std::vector<const
    // void*> vlen_ptrs( sets[2].size(), other_vlen ); std::vector<int> vlen_sizes( sets[2].size)(),
    // sizeof(other_vlen) ); rval = mb.tag_set_data( tag_vlen, sets[2], &vlen_ptrs[0],
    // &vlen_sizes[0]
    // ); CHECK_ERR(rval);
    // check that INTERSECT option works as expected
    result.clear();
    result.insert( sets[1].front() );
    ptrs[0] = &default_sparse;
    rval    = mb.get_entities_by_type_and_tag( 0, MBVERTEX, &tag_sparse, ptrs, 1, result, Interface::INTERSECT );CHECK_ERR( rval );
    CHECK_EQUAL( (size_t)1, result.size() );
    CHECK_EQUAL( sets[1].front(), result.front() );
    // check that UNITE option works as expected
    result.clear();
    result.insert( edge );
    rval    = mb.get_entities_by_type_and_tag( 0, MBVERTEX, &tag_sparse, ptrs, 1, result, Interface::UNION );CHECK_ERR( rval );
    CHECK_EQUAL( edge, result.back() );
Definition at line 690 of file TagTest.cpp.
References MB_TAG_DENSE, MB_TYPE_OPAQUE, NORMAL, and test_get_set().
    const unsigned char data[] = "a few aribtrary bytes entered as a string";
    const int num_val          = sizeof( data ) / sizeof( data[0] );
    test_get_set( "dense_byte_ptr", 2, MB_TAG_DENSE, MB_TYPE_OPAQUE, data, num_val / 2, 0, NORMAL, true );
    const unsigned char defaultval[] = "XY";
    test_get_set( "dense_byte_ptr_def", 2, MB_TAG_DENSE, MB_TYPE_OPAQUE, data, num_val / 2, defaultval, NORMAL, true );
Definition at line 679 of file TagTest.cpp.
References MB_TAG_SPARSE, MB_TYPE_DOUBLE, NORMAL, and test_get_set().
    const double data[] = { 1, 2, 3, 4, 5, 6, 7, 9, 10, 11, 12, 13, 14, 15, 16 };
    test_get_set( "sparse_dbl_ptr", 2, MB_TAG_SPARSE, MB_TYPE_DOUBLE, data, num_val / 2, 0, NORMAL, true );
    const double defaultval[] = { -1, -2 };
    test_get_set( "sparse_dbl_ptr_def", 2, MB_TAG_SPARSE, MB_TYPE_DOUBLE, data, num_val / 2, defaultval, NORMAL, true );
void test_get_set ( const char *  name,
int  vals_per_ent,
TagType  storage,
DataType  type,
const void *  some_values,
int  num_values,
const void *  default_value,
SetMode  set_by_pointer = NORMAL,
bool  get_by_pointer = false
Definition at line 361 of file TagTest.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, concat_to_list(), moab::Range::const_pair_begin(), moab::Range::const_pair_end(), moab::Range::empty(), entities, moab::Range::erase(), ErrorCode, moab::Interface::get_entities_by_handle(), h1, moab::Range::insert(), mb, MB_TAG_DENSE, MB_TAG_NOT_FOUND, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, n, NORMAL, ONE_VALUE, POINTER, setup_mesh(), moab::Range::size(), moab::subtract(), moab::Interface::tag_clear_data(), moab::Interface::tag_get_by_ptr(), moab::Interface::tag_get_data(), moab::Interface::tag_set_by_ptr(), moab::Interface::tag_set_data(), test_create_tag(), and MBMesquite::zeros.
    std::vector< unsigned char > data;
    Core moab;
    setup_mesh( mb );
    Tag tag = test_create_tag( mb, name, vals_per_ent, storage, type, default_value );
    Range entities;
    int bytes = 0;
    switch( type )
            bytes = vals_per_ent * sizeof( int );
            break;
            bytes = vals_per_ent * sizeof( double );
            break;
            bytes = vals_per_ent * sizeof( EntityHandle );
            break;
        case MB_TYPE_BIT:
            bytes = 1;
            break;
            bytes = vals_per_ent;
            break;
    // split handles into four groups
    // a) a single handle
    // b) some non-consecutive handles in an array
    // c) some handles in an Range
    // d) remaining handles (remaining in 'entities');
    EntityHandle one_handle;
    Range::iterator it = entities.begin() += entities.size() / 2;
    one_handle         = *it;
    entities.erase( it );
    Range handle_range;
    std::vector< EntityHandle > handle_list;
    for( Range::const_pair_iterator i = entities.const_pair_begin(); i != entities.const_pair_end(); ++i )
        if( i->first == i->second || i->second - i->first == 1 )
            EntityHandle h1 = i->first, h2 = i->second;
            ++i;
            handle_range.insert( h1, h2 );
        else
            EntityHandle mid = (EntityHandle)( i->first + ( i->second - i->first + 1 ) / 2 );
            handle_list.push_back( mid );
            handle_range.insert( mid + 1, i->second );
    entities = subtract( entities, handle_range );
    for( unsigned i = 0; i < handle_list.size(); ++i )
        entities.erase( handle_list[i] );
    // try getting/setting single handle value
    std::vector< const void* > list( 1 );
    if( set_mode == NORMAL )
        rval = mb.tag_set_data( tag, &one_handle, 1, some_values );
    else if( set_mode == POINTER )
        list[0] = some_values;
        rval    = mb.tag_set_by_ptr( tag, &one_handle, 1, &list[0] );
    else
    {  // set_mode == ONE_VALUE
        rval = mb.tag_clear_data( tag, &one_handle, 1, some_values );
    CHECK_ERR( rval );
    data.resize( bytes );
    if( get_by_pointer )
        // test that correct size is returned
        int rsize;
        rval = mb.tag_get_by_ptr( tag, &one_handle, 1, &list[0], &rsize );CHECK_ERR( rval );
        CHECK_EQUAL( vals_per_ent, rsize );
        // try again with NULL size pointer
        list[0] = 0;
        rval    = mb.tag_get_by_ptr( tag, &one_handle, 1, &list[0] );CHECK_ERR( rval );
        CHECK( !memcmp( some_values, list[0], bytes ) );
    else
        rval = mb.tag_get_data( tag, &one_handle, 1, &data[0] );CHECK_ERR( rval );
        CHECK( !memcmp( some_values, &data[0], bytes ) );
    // try getting/setting for arrays of handles
    const int step = std::min( (int)handle_list.size(), num_values );
    data.resize( step * bytes );
    for( int i = 0; i < (int)handle_list.size(); i += step )
        const int n = std::min( (int)handle_list.size() - i, step );
        list.resize( n );
            rval = mb.tag_set_data( tag, &handle_list[i], n, some_values );
            concat_to_list( some_values, list, bytes );
            rval = mb.tag_set_by_ptr( tag, &handle_list[i], n, &list[0] );
        else
            rval = mb.tag_clear_data( tag, &handle_list[i], n, some_values );
        CHECK_ERR( rval );
            // check that valid sizes are returned if requested
            std::vector< int > rsizes( n, 0 );
            rval = mb.tag_get_by_ptr( tag, &handle_list[i], n, &list[0], &rsizes[0] );CHECK_ERR( rval );
            for( int j = 0; j < n; ++j )
                CHECK_EQUAL( vals_per_ent, rsizes[j] );
            // query a second time to verify that it works w/ NULL size array
            list.clear();
            list.resize( n, 0 );
            rval = mb.tag_get_by_ptr( tag, &handle_list[i], n, &list[0] );
        else
            rval = mb.tag_get_data( tag, &handle_list[i], n, &data[0] );
            concat_to_list( &data[0], list, bytes );
        CHECK_ERR( rval );
        const unsigned char* ptr = reinterpret_cast< const unsigned char* >( some_values );
        for( int j = 0; j < n; ++j, ptr += bytes )
            CHECK( !memcmp( ptr, list[j], bytes ) );
    // try getting/setting for Range of handles
    // set data for range
        std::vector< unsigned char > input_data( handle_range.size() * bytes );
        for( int i = 0; i < (int)input_data.size(); i += num_values * bytes )
            memcpy( &input_data[i], some_values, std::min( (int)input_data.size() - i, num_values * bytes ) );
        rval = mb.tag_set_data( tag, handle_range, &input_data[0] );
        list.resize( num_values );
        while( list.size() < handle_range.size() )
            size_t s = list.size();
            list.resize( 2 * s );
            std::copy( list.begin(), list.begin() + s, list.begin() + s );
        rval = mb.tag_set_by_ptr( tag, handle_range, &list[0] );
    else
        rval = mb.tag_clear_data( tag, handle_range, some_values );
    CHECK_ERR( rval );
    // get data for range
    list.clear();
    list.resize( handle_range.size(), 0 );
        std::vector< int > rsizes( handle_range.size(), 0 );
        rval = mb.tag_get_by_ptr( tag, handle_range, &list[0], &rsizes[0] );CHECK_ERR( rval );
        for( size_t j = 0; j < handle_range.size(); ++j )
        // query w/ NULL size array to make sure that works also
        list.clear();
        rval = mb.tag_get_by_ptr( tag, handle_range, &list[0] );
    else
        data.resize( handle_range.size() * bytes );
        rval = mb.tag_get_data( tag, handle_range, &data[0] );
    CHECK_ERR( rval );
    // compare values
    const bool dstep = ( set_mode != ONE_VALUE );
    for( size_t i = 0; i < list.size(); ++i )
        CHECK( list[i * dstep] != NULL );
        const void* ptr = reinterpret_cast< const char* >( some_values ) + ( i % num_values ) * bytes;
        CHECK( !memcmp( list[i * dstep], ptr, bytes ) );
    // try getting unset values
    list.resize( entities.size() );
        rval = mb.tag_get_by_ptr( tag, entities, &list[0] );
    else
        data.clear(), data.resize( entities.size() * bytes, '\001' );
        rval = mb.tag_get_data( tag, entities, &data[0] );
    // if there was a default value, we should have gotten it for all unset entities
    if( default_value )
        CHECK_ERR( rval );
        for( unsigned i = 0; i < entities.size(); ++i )
            CHECK( !memcmp( default_value, list[i], bytes ) );
    // otherwise we should get MB_TAG_NOT_FOUND, *unless* the tag
    // is dense, in which case we /might/ get all zero bytes instead.
    else if( MB_TAG_NOT_FOUND != rval )
        CHECK_EQUAL( MB_TAG_DENSE, storage );
        std::vector< unsigned char > zeros( bytes, 0 );
            CHECK( !memcmp( &zeros[0], list[i], bytes ) );
    // Check that handles for other entities didn't change.
    // Ignore get_by_pointer/set_by_pointer flags from here on.
    // We've established (hopefully) that both methods work in
    // the above code.  Now we just want to verify correct values,
    // regardless of the API used to get them.
    // one handle
    // array values
        rval        = mb.tag_get_data( tag, &handle_list[i], n, &data[0] );CHECK_ERR( rval );
        CHECK( !memcmp( some_values, &data[0], step * bytes ) );
        rval = mb.tag_set_data( tag, &handle_list[i], n, some_values );CHECK_ERR( rval );
    // range values
    list.clear();
    rval = mb.tag_get_by_ptr( tag, handle_range, &list[0] );CHECK_ERR( rval );
    for( size_t i = 0; i < handle_range.size(); ++i )
        CHECK( !memcmp( ptr, list[i], bytes ) );
void test_get_set_bit ( )
Definition at line 754 of file TagTest.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::empty(), moab::Range::end(), entities, ErrorCode, moab::Interface::get_entities_by_handle(), h1, mb, MB_TAG_BIT, MB_TYPE_BIT, setup_mesh(), moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), and test_create_tag().
    Core moab;
    setup_mesh( mb );
    Tag tag = test_create_tag( mb, "bit_val", 2, MB_TAG_BIT, MB_TYPE_BIT, 0 );
    Range entities;
    unsigned counter = 0;
        srand( counter++ );
        unsigned char bits = (unsigned char)( rand() & 3 );
        rval               = mb.tag_set_data( tag, &*i, 1, &bits );CHECK_ERR( rval );
        rval                   = mb.tag_get_data( tag, &*i, 1, &bits_out );CHECK_ERR( rval );
    // test default value
    unsigned char defval = '\003';
    unsigned char zero   = '\0';
    Tag tag2             = test_create_tag( mb, "bit_val2", 3, MB_TAG_BIT, MB_TYPE_BIT, &defval );
    CHECK( entities.size() >= 3 );
    Range::iterator j = entities.begin();
    EntityHandle h1   = *j;
    ++j;
    EntityHandle h2 = *j;
    ++j;
    EntityHandle h3 = *j;
    ++j;
    rval = mb.tag_set_data( tag2, &h1, 1, &zero );CHECK_ERR( rval );
    rval = mb.tag_set_data( tag2, &h3, 1, &zero );CHECK_ERR( rval );
    unsigned char byte;
    rval = mb.tag_get_data( tag2, &h2, 1, &byte );CHECK_ERR( rval );
    CHECK_EQUAL( defval, byte );
    rval = mb.tag_get_data( tag2, &h1, 1, &byte );CHECK_ERR( rval );
    CHECK_EQUAL( zero, byte );
    rval = mb.tag_get_data( tag2, &h3, 1, &byte );CHECK_ERR( rval );
    // test default value for uninitialized data (tag not set for any entity)
    defval   = '\002';
    Tag tag3 = test_create_tag( mb, "bit_val3", 2, MB_TAG_BIT, MB_TYPE_BIT, &defval );
    rval     = mb.tag_get_data( tag3, &h2, 1, &byte );CHECK_ERR( rval );
Definition at line 664 of file TagTest.cpp.
References MB_TAG_DENSE, MB_TYPE_DOUBLE, and test_get_set().
    const double pi     = 3.1415926535897931;
    const double e      = 2.7182818284590451;
    const double data[] = { 1,      1.,     pi,     e,      2,      1. / 2, 2 * pi, e / 2,  3,      1. / 3,
                            3 * pi, e / 3,  4,      1. / 4, 4 * pi, e / 4,  5,      1. / 5, 5 * pi, e / 5,
                            6,      1. / 6, 6 * pi, e / 6,  0,      100,    1000,   10000 };
    test_get_set( "dense_dbl", 1, MB_TAG_DENSE, MB_TYPE_DOUBLE, data, num_val, 0 );
    const double defaultval[] = { 0.11, 0.22 };
    test_get_set( "dense_dbl_def", 2, MB_TAG_DENSE, MB_TYPE_DOUBLE, data, num_val / 2, defaultval );
Definition at line 652 of file TagTest.cpp.
References MB_TAG_DENSE, MB_TYPE_INTEGER, and test_get_set().
    const int data[]  = { 231, 416, 294, 504, 318, 558, 494, 006, 464, 648, 737, 045, 179, 852, 944, 336,
                         773, 248, 434, 615, 677, 667, 521, 748, 820, 533, 955, 300, 108, 726, 747, 597 };
    test_get_set( "dense_int", 1, MB_TAG_DENSE, MB_TYPE_INTEGER, data, num_val, 0 );
    const int defaultval[] = { 5, 8, 1974 };
    test_get_set( "dense_int_def", 3, MB_TAG_DENSE, MB_TYPE_INTEGER, data, num_val / 3, defaultval );
Definition at line 640 of file TagTest.cpp.
References MB_TAG_SPARSE, MB_TYPE_INTEGER, and test_get_set().
    const int data[]  = { 21, 00, 46, 30, 26, 63, 05, 49, 31, 39, 86, 77, 24, 37, 25, 98,
                         26, 20, 01, 54, 16, 28, 55, 49, 96, 18, 28, 18, 53, 00, 80, 48 };
    test_get_set( "sparse_int", 2, MB_TAG_SPARSE, MB_TYPE_INTEGER, data, num_val / 2, 0 );
    const int defaultval = 19740508;
    test_get_set( "sparse_int_def", 1, MB_TAG_SPARSE, MB_TYPE_INTEGER, data, num_val, &defaultval );
void test_get_set_variable_length ( const char *  name,
TagType  storage,
DataType  type,
const void **  values,
const int *  lengths,
int  num_values,
Definition at line 1448 of file TagTest.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::const_pair_begin(), moab::Range::const_pair_end(), moab::Range::empty(), entities, moab::Range::erase(), ErrorCode, moab::Interface::get_entities_by_handle(), h1, moab::Range::insert(), MB_TAG_NOT_FOUND, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, setup_mesh(), moab::Range::size(), moab::subtract(), moab::Interface::tag_clear_data(), moab::Interface::tag_get_by_ptr(), moab::Interface::tag_set_by_ptr(), and test_create_var_len_tag().
Referenced by test_clear_variable_length(), test_get_set_variable_length_dense(), and test_get_set_variable_length_sparse().
    std::vector< const void* > data;
    std::vector< int > data_lens;
    Core moab;
    setup_mesh( mb );
    Tag tag = test_create_var_len_tag( mb, name, storage, type, default_value, default_value_length );
    Range entities;
    one_handle         = *it;
    Range handle_range;
            ++i;
        else
    if( num_values == 1 )
        rval = mb.tag_clear_data( tag, &one_handle, 1, values[0], lengths[0] );
    else
        rval = mb.tag_set_by_ptr( tag, &one_handle, 1, values, lengths );CHECK_ERR( rval );
    const void* data_ptr;
    int data_len;
    rval = mb.tag_get_by_ptr( tag, &one_handle, 1, &data_ptr, &data_len );CHECK_ERR( rval );
    CHECK_EQUAL( lengths[0], data_len );
    CHECK( !memcmp( values[0], data_ptr, data_len ) );
    int typesize = 0;
    switch( type )
            typesize = sizeof( int );
            break;
            typesize = sizeof( double );
            break;
            typesize = sizeof( EntityHandle );
            break;
        case MB_TYPE_BIT:
            typesize = 1;
            break;
            typesize = 1;
            break;
    int count, step;
        count = handle_list.size();
        step  = 0;
        rval  = mb.tag_clear_data( tag, &handle_list[0], count, values[0], lengths[0] );
    else
        count = std::min( (int)handle_list.size(), num_values );
        step  = 1;
        rval  = mb.tag_set_by_ptr( tag, &handle_list[0], count, values, lengths );
    CHECK_ERR( rval );
    data.clear();
    data.resize( count, 0 );
    data_lens.clear();
    data_lens.resize( count, 0 );
    rval = mb.tag_get_by_ptr( tag, &handle_list[0], count, &data[0], &data_lens[0] );CHECK_ERR( rval );
    for( int i = 0; i < count; ++i )
        CHECK_EQUAL( lengths[i * step], data_lens[i] );
        CHECK( NULL != data[i] );
        CHECK( !memcmp( values[i], data[i * step], typesize * lengths[i * step] ) );
    if( num_values > 1 )
        data.resize( num_values );
        data_lens.resize( num_values );
        std::copy( values, values + num_values, data.begin() );
        std::copy( lengths, lengths + num_values, data_lens.begin() );
        while( data.size() < handle_range.size() )
            size_t s = data.size();
            data.resize( 2 * s );
            std::copy( data.begin(), data.begin() + s, data.begin() + s );
            data_lens.resize( 2 * s );
            std::copy( data_lens.begin(), data_lens.begin() + s, data_lens.begin() + s );
        rval = mb.tag_set_by_ptr( tag, handle_range, &data[0], &data_lens[0] );
    else
        rval = mb.tag_clear_data( tag, handle_range, values[0], lengths[0] );
    CHECK_ERR( rval );
    data.clear();
    data.resize( handle_range.size(), 0 );
    data_lens.clear();
    data_lens.resize( handle_range.size(), 0 );
    rval = mb.tag_get_by_ptr( tag, handle_range, &data[0], &data_lens[0] );CHECK_ERR( rval );
    for( size_t i = 0; i < data.size(); ++i )
        const void* expect = values[( i * step ) % num_values];
        int expect_len     = lengths[( i * step ) % num_values];
        CHECK_EQUAL( expect_len, data_lens[i] );
        CHECK( !memcmp( expect, data[i], expect_len * typesize ) );
    data.resize( entities.size() );
    data_lens.resize( entities.size() );
    rval = mb.tag_get_by_ptr( tag, entities, &data[0], &data_lens[0] );
    if( default_value )
        CHECK_ERR( rval );
            CHECK_EQUAL( default_value_length, data_lens[i] );
            CHECK( !memcmp( default_value, data[i], typesize * default_value_length ) );
    else
    // one handle
    CHECK( !memcmp( values[0], data_ptr, typesize * data_len ) );
    // array values
    data.clear();
    data_lens.clear();
        CHECK_EQUAL( lengths[i], data_lens[i] );
        CHECK( !memcmp( values[i], data[i], typesize * lengths[i] ) );
    // range values
    data.clear();
    data_lens.clear();
        const void* expect = values[i % num_values];
        int expect_len     = lengths[i % num_values];
        CHECK( !memcmp( expect, data[i], typesize * expect_len ) );
Definition at line 1676 of file TagTest.cpp.
References doubles, ints, MB_TAG_DENSE, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, and test_get_set_variable_length().
    const double doubles[14] = { 1, 2, 3, 4, -4, -3, -2, -1, 42, 0, 1974, -0.5, 1. / 3, -1e-10 };
    const void* dvals[5]     = { doubles, doubles + 3, doubles + 4, doubles + 8, doubles + 10 };
    const int dlens[5]       = { 3, 1, 4, 2, 4 };
    test_get_set_variable_length( "vnodef", MB_TAG_DENSE, MB_TYPE_DOUBLE, dvals, dlens, 5, 0, 0 );
    const void* ivals[9] = { ints,      ints + 1,  ints + 3,  ints + 12, ints + 17,
                             ints + 21, ints + 28, ints + 29, ints + 31 };
    const int ilens[9]   = { 1, 2, 9, 5, 4, 7, 1, 2, 1 };
    test_get_set_variable_length( "vdef", MB_TAG_DENSE, MB_TYPE_INTEGER, ivals, ilens, 9, defvals, 4 );
Definition at line 1692 of file TagTest.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, MB_TAG_MESH, MB_TYPE_INTEGER, mesh, moab::Interface::tag_get_by_ptr(), moab::Interface::tag_set_by_ptr(), and test_create_var_len_tag().
    Core moab;
    ErrorCode rval;
    Tag tag       = test_create_var_len_tag( mb, "vmesh", MB_TAG_MESH, MB_TYPE_INTEGER, 0, 0 );
    int values1[] = { 6 };
    int values5[] = { 1, 2, 3, 4, 5 };
    int one = 1;
    const void* data[1];
    data[0]                 = values1;
    rval                    = mb.tag_set_by_ptr( tag, &mesh, 1, data, &one );CHECK_ERR( rval );
    int len;
    rval = mb.tag_get_by_ptr( tag, &mesh, 1, data, &len );CHECK_ERR( rval );
    CHECK_EQUAL( 1, len );
    CHECK_EQUAL( values1[0], *reinterpret_cast< const int* >( data[0] ) );
    int five = 5;
    data[0]  = values5;
    rval     = mb.tag_set_by_ptr( tag, &mesh, 1, data, &five );CHECK_ERR( rval );
    CHECK_EQUAL( 5, len );
    CHECK_EQUAL( values5[0], reinterpret_cast< const int* >( data[0] )[0] );
    CHECK_EQUAL( values5[1], reinterpret_cast< const int* >( data[0] )[1] );
    CHECK_EQUAL( values5[2], reinterpret_cast< const int* >( data[0] )[2] );
    CHECK_EQUAL( values5[3], reinterpret_cast< const int* >( data[0] )[3] );
    CHECK_EQUAL( values5[4], reinterpret_cast< const int* >( data[0] )[4] );
Definition at line 1660 of file TagTest.cpp.
References doubles, ints, MB_TAG_SPARSE, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, and test_get_set_variable_length().
    test_get_set_variable_length( "vnodef", MB_TAG_SPARSE, MB_TYPE_DOUBLE, dvals, dlens, 5, 0, 0 );
    test_get_set_variable_length( "vdef", MB_TAG_SPARSE, MB_TYPE_INTEGER, ivals, ilens, 9, defvals, 4 );
void test_mesh_value ( )
Definition at line 1084 of file TagTest.cpp.
References MB_TAG_BIT, MB_TAG_DENSE, MB_TAG_MESH, MB_TAG_SPARSE, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, and MB_TYPE_INTEGER.
    Core moab;
    double dval = -0.5;
    test_mesh_value( moab, "mvd", 1, MB_TAG_DENSE, MB_TYPE_DOUBLE, &dval );
    int sval = 42;
    test_mesh_value( moab, "mvs", 1, MB_TAG_SPARSE, MB_TYPE_INTEGER, &sval );
    EntityHandle mval = 0;
    test_mesh_value( moab, "mvm", 1, MB_TAG_MESH, MB_TYPE_HANDLE, &mval );
    unsigned char bits = '\002';
    test_mesh_value( moab, "mvb", 2, MB_TAG_BIT, MB_TYPE_BIT, &bits );
void test_mesh_value ( Interface mb,
const char *  tag_name,
unsigned  tag_size,
TagType  tag_storage,
DataType  tag_type,
const void *  value
Definition at line 1049 of file TagTest.cpp.
References CHECK, CHECK_ERR, ErrorCode, MB_TAG_BIT, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, mesh, moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), test_create_tag(), and value().
    // create  tag
    Tag tag = test_create_tag( mb, tag_name, tag_size, tag_storage, tag_type, 0 );
    unsigned memcmp_size = tag_size;
    if( tag_storage == MB_TAG_BIT || tag_type == MB_TYPE_BIT )
        memcmp_size = 1;
    else if( tag_type == MB_TYPE_DOUBLE )
        memcmp_size = sizeof( double );
    else if( tag_type == MB_TYPE_INTEGER )
        memcmp_size = sizeof( int );
    if( tag_type == MB_TYPE_HANDLE ) memcmp_size = sizeof( EntityHandle );
    ErrorCode rval          = mb.tag_set_data( tag, &mesh, 1, value );CHECK_ERR( rval );
    std::vector< unsigned char > bytes( memcmp_size, 0 );
    rval = mb.tag_get_data( tag, &mesh, 1, &bytes[0] );CHECK_ERR( rval );
    CHECK( !memcmp( value, &bytes[0], memcmp_size ) );
    // test again, this time for default value
    std::string name2( tag_name );
    name2 += "_DEF";
    Tag tag2 = test_create_tag( mb, name2.c_str(), tag_size, tag_storage, tag_type, value );
    bytes.clear();
    bytes.resize( memcmp_size, 0 );
    rval = mb.tag_get_data( tag2, &mesh, 1, &bytes[0] );CHECK_ERR( rval );
Definition at line 713 of file TagTest.cpp.
References MB_TAG_DENSE, MB_TYPE_DOUBLE, MB_TYPE_OPAQUE, POINTER, and test_get_set().
    test_get_set( "dense_byte_ptr", 2, MB_TAG_DENSE, MB_TYPE_OPAQUE, data, num_val / 2, 0, POINTER, false );
    test_get_set( "dense_byte_ptr_def", 2, MB_TAG_DENSE, MB_TYPE_OPAQUE, data, num_val / 2, defaultval, POINTER,
                  false );
    const double dbldata[3] = { 1.0, 2.0, 3.0 };
    const int dbl_num_val   = sizeof( dbldata ) / sizeof( double );
    test_get_set( "dense_double_ptr", 3, MB_TAG_DENSE, MB_TYPE_DOUBLE, dbldata, dbl_num_val, 0, POINTER, false );
    const double dbldefaultval[3] = { 0.0, 0.0, 0.0 };
    test_get_set( "dense_byte_ptr_def", 3, MB_TAG_DENSE, MB_TYPE_DOUBLE, dbldata, dbl_num_val, dbldefaultval, POINTER,
                  false );
Definition at line 701 of file TagTest.cpp.
References MB_TAG_SPARSE, MB_TYPE_DOUBLE, POINTER, and test_get_set().
    test_get_set( "sparse_dbl_ptr", 2, MB_TAG_SPARSE, MB_TYPE_DOUBLE, data, num_val / 2, 0, POINTER, false );
    test_get_set( "sparse_dbl_ptr_def", 2, MB_TAG_SPARSE, MB_TYPE_DOUBLE, data, num_val / 2, defaultval, POINTER,
                  false );
void test_tag_iterate_common ( TagType  storage,
bool  with_default
Definition at line 2037 of file TagTest.cpp.
References moab::Range::begin(), CHECK, CHECK_ARRAYS_EQUAL, CHECK_EQUAL, CHECK_ERR, moab::Interface::create_vertices(), moab::Interface::delete_entities(), moab::Range::end(), moab::Range::erase(), ErrorCode, moab::Range::insert(), MB_ENTITY_NOT_FOUND, MB_TAG_CREAT, MB_TAG_NOT_FOUND, MB_TAG_SPARSE, MB_TYPE_INTEGER, NUM_VTX, moab::Range::size(), moab::Interface::tag_get_handle(), moab::Interface::tag_iterate(), and moab::Interface::tag_set_data().
Referenced by test_tag_iterate_dense(), test_tag_iterate_dense_default(), test_tag_iterate_sparse(), and test_tag_iterate_sparse_default().
    // create 1000 vertices
    const int NUM_VTX = 1000;
    Core moab;
    std::vector< double > coords( 3 * NUM_VTX );
    Range verts, dead;
    ErrorCode rval = mb.create_vertices( &coords[0], NUM_VTX, verts );CHECK_ERR( rval );
    // delete about 1% of vertices
    const int step    = 100;
    int remaining     = NUM_VTX;
    for( int j = 0; j < remaining; j += step )
        dead.insert( *i );
        i = verts.erase( i );
        i += step - 1;
    // Remove some additional values from the range
    // so that our handle blocks don't always align with
    // sequences
    verts.erase( verts.begin() + ( step - 5 ), verts.begin() + ( step + 5 ) );
    // Create an integer tag
    Tag tag;
    const int defval = 0;
    rval = mb.tag_get_handle( "TEST_TAG", 1, MB_TYPE_INTEGER, tag, storage | MB_TAG_CREAT, with_default ? &defval : 0 );CHECK_ERR( rval );
    // Set tag values
    std::vector< int > values( verts.size(), defval );
    if( !with_default )
        for( size_t j = 0; j < values.size(); ++j )
            values[j] = j;
    // Check that we get back expected values
    i = verts.begin();
    void* ptr;
    int count, total = 0;
    while( i != verts.end() )
        ptr  = 0;
        rval = mb.tag_iterate( tag, i, verts.end(), count, ptr );CHECK_ERR( rval );
        assert( total + count <= (int)verts.size() );
        CHECK_ARRAYS_EQUAL( &values[total], count, reinterpret_cast< int* >( ptr ), count );
        if( i == verts.begin() && with_default && storage == MB_TAG_SPARSE ) ( (int*)ptr )[0] = 1.0;
        i += count;
        total += count;
    // Check that we can set values
    i = verts.begin();
        ptr  = 0;
        Range::iterator end = i + count;
        int* arr            = reinterpret_cast< int* >( ptr );
        while( end != i )
            *arr = static_cast< int >( ( *i ) % NUM_VTX );
            ++i;
            ++arr;
    // Check that we got back the values that we set
    i = verts.begin();
        ptr  = 0;
        while( end != i )
            CHECK_EQUAL( *arr, static_cast< int >( ( *i ) % NUM_VTX ) );
            ++i;
            ++arr;
    // Check that we cannot get tag values for invalid handles
    rval = mb.tag_iterate( tag, dead.begin(), dead.end(), count, ptr );
    CHECK( MB_ENTITY_NOT_FOUND == rval || MB_TAG_NOT_FOUND == rval );
Definition at line 2142 of file TagTest.cpp.
References MB_TAG_DENSE, and test_tag_iterate_common().
Referenced by main().
Definition at line 2146 of file TagTest.cpp.
Definition at line 2151 of file TagTest.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, moab::Interface::create_vertices(), moab::Range::end(), ErrorCode, MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TAG_VARLEN, MB_TYPE_BIT, MB_TYPE_INTEGER, MB_TYPE_OUT_OF_RANGE, MB_VARIABLE_DATA_LENGTH, NUM_VTX, moab::Interface::tag_get_handle(), and moab::Interface::tag_iterate().
    Core moab;
    Range verts;
    Tag tag;
    const int zero = 0;
    void* ptr;
    int count;
    // Check that we cannot iterate over bit tags
    // (this will never be possible because the storage for bit tags
    //  is compressed and therefore cannot be directly accessed.)
    rval = mb.tag_get_handle( "bits", 1, MB_TYPE_BIT, tag, MB_TAG_EXCL, &zero );CHECK_ERR( rval );
    rval = mb.tag_iterate( tag, verts.begin(), verts.end(), count, ptr );
    CHECK_EQUAL( MB_TYPE_OUT_OF_RANGE, rval );
    // Check that we cannot iterate over variable-length tags
    // (this will never be possible because this API function cannot
    //  pass back the length of the tag values)
    rval = mb.tag_get_handle( "vden", 1, MB_TYPE_INTEGER, tag, MB_TAG_VARLEN | MB_TAG_DENSE | MB_TAG_EXCL, &zero );CHECK_ERR( rval );
    rval = mb.tag_get_handle( "vspr", 1, MB_TYPE_INTEGER, tag, MB_TAG_VARLEN | MB_TAG_SPARSE | MB_TAG_EXCL, &zero );CHECK_ERR( rval );
Definition at line 2134 of file TagTest.cpp.
References MB_TAG_SPARSE, and test_tag_iterate_common().
Definition at line 2138 of file TagTest.cpp.
